Alexandr Kuznetsov Posted July 14, 2016 Share Posted July 14, 2016 Good afternoon dear gurus. help to transfer please system with sdcard to sata hdd in OrangePI +2. Debian jessy and additional software is established. what needs to be made? if it is possible, then on steps. the point is that I want to refuse completely loading with sdcard and emmc. To be loaded only with sata hdd. Thanks in advance. Link to comment Share on other sites More sharing options...
Igor Posted July 15, 2016 Share Posted July 15, 2016 http://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb Link to comment Share on other sites More sharing options...
Alexandr Kuznetsov Posted July 15, 2016 Author Share Posted July 15, 2016 how to make full transfer, to leave loading only from sata without emmc/nand or sdcard? Link to comment Share on other sites More sharing options...
Igor Posted July 15, 2016 Share Posted July 15, 2016 No go. At minimum you need to load u-boot from emmc / sd. Link to comment Share on other sites More sharing options...
Alexandr Kuznetsov Posted July 15, 2016 Author Share Posted July 15, 2016 if now the system is installed on sdcard, then having chosen option boot from SD, system on SATA/USB, the same sdcard for storage of the loader will be used? I will be able to transfer then the loader to sdcard of the smaller size? if I am able, then how then to transfer the loader? Link to comment Share on other sites More sharing options...
rodolfo Posted July 15, 2016 Share Posted July 15, 2016 Image 1MB of the old SDcard to the new SDcard. This contains the loader. On Linux as root : stick in old SDcard, check device with lsblk ( e.g. /dev/sdb ) dd if=/dev/sdb of=loader.img bs=1M count=1 eject sdcard, stick in new SDcard, check device with lsblk ( e.g. /dev/sdb ) dd if=loader.img of=/dev/sdb Link to comment Share on other sites More sharing options...
Alexandr Kuznetsov Posted July 18, 2016 Author Share Posted July 18, 2016 Thanks a lot Link to comment Share on other sites More sharing options...
