Nanopi R2S - 10.6(20.11.1) wget 'Segmentation fault'
Armbianmonitor:
After dist-upgrade, I got seg fault when using wget.
root@nanopi-r2s:~/lepup# cat /etc/debian_version
10.6
root@nanopi-r2s:~/# uname -a
Linux nanopi-r2s 5.9.11-rockchip64 #20.11.1 SMP PREEMPT Fri Nov 27 21:59:08 CET 2020 aarch64 GNU/Linux
root@nanopi-r2s:~/# apt-get install wget
Reading package lists... Done
Building dependency tree
wget is already the newest version (1.20.1-1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@nanopi-r2s:~/# strace -o /tmp/wget.tr wget
Segmentation fault
root@nanopi-r2s:~/# cat /tmp/wget.tr
execve("/usr/bin/wget", ["wget"], 0xffffcfbd4160 /* 23 vars */) = 0
brk(NULL)                               = 0xaaaae4ff2000
faccessat(AT_FDCWD, "/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=23818, ...}) = 0
mmap(NULL, 23818, PROT_READ, MAP_PRIVATE, 3, 0) = 0xffff92619000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libpcre2-8.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\20#\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=469552, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff92617000
mmap(NULL, 533224, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff92570000
mprotect(0xffff925e2000, 61440, PROT_NONE) = 0
mmap(0xffff925f1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x71000) = 0xffff925f1000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libuuid.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\200\27\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=30712, ...}) = 0
mmap(NULL, 94240, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff92558000
mprotect(0xffff9255e000, 65536, PROT_NONE) = 0
mmap(0xffff9256e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0xffff9256e000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libidn2.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\360\27\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=116584, ...}) = 0
mmap(NULL, 180248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff9252b000
mprotect(0xffff92547000, 61440, PROT_NONE) = 0
mmap(0xffff92556000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b000) = 0xffff92556000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libnettle.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0 \230\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=224424, ...}) = 0
mmap(NULL, 287928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff924e4000
mprotect(0xffff92519000, 65536, PROT_NONE) = 0
mmap(0xffff92529000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x35000) = 0xffff92529000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libgnutls.so.30", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\200<\3\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1846504, ...}) = 0
mmap(NULL, 1915040, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff92310000
mprotect(0xffff924c3000, 61440, PROT_NONE) = 0
mmap(0xffff924d2000, 69632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b2000) = 0xffff924d2000
mmap(0xffff924e3000, 2208, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff924e3000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0`$\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=117032, ...}) = 0
mmap(NULL, 180616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff922e3000
mprotect(0xffff922ff000, 61440, PROT_NONE) = 0
mmap(0xffff9230e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b000) = 0xffff9230e000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libpsl.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\300\23\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=67352, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff92615000
mmap(NULL, 131088, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff922c2000
mprotect(0xffff922d2000, 61440, PROT_NONE) = 0
mmap(0xffff922e1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0xffff922e1000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0p\16\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1439544, ...}) = 0
mmap(NULL, 1511520, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff92150000
mprotect(0xffff922a9000, 61440, PROT_NONE) = 0
mmap(0xffff922b8000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x158000) = 0xffff922b8000
mmap(0xffff922be000, 12384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff922be000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libunistring.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\20\32\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1529704, ...}) = 0
mmap(NULL, 1595552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91fca000
mprotect(0xffff9213c000, 61440, PROT_NONE) = 0
mmap(0xffff9214b000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x171000) = 0xffff9214b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libp11-kit.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0P\266\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1269264, ...}) = 0
mmap(NULL, 1334224, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91e84000
mprotect(0xffff91fa6000, 61440, PROT_NONE) = 0
mmap(0xffff91fb5000, 86016, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x121000) = 0xffff91fb5000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libtasn1.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\360,\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=67432, ...}) = 0
mmap(NULL, 131624, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91e63000
mprotect(0xffff91e73000, 61440, PROT_NONE) = 0
mmap(0xffff91e82000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0xffff91e82000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libhogweed.so.4", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0\203\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=225032, ...}) = 0
mmap(NULL, 288536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91e1c000
mprotect(0xffff91e52000, 61440, PROT_NONE) = 0
mmap(0xffff91e61000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x35000) = 0xffff91e61000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libgmp.so.10", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\300\300\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=492192, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff92613000
mmap(NULL, 555816, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91d94000
mprotect(0xffff91e0a000, 65536, PROT_NONE) = 0
mmap(0xffff91e1a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x76000) = 0xffff91e1a000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/aarch64-linux-gnu/libffi.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\220\30\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=31016, ...}) = 0
mmap(NULL, 95744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91d7c000
mprotect(0xffff91d83000, 61440, PROT_NONE) = 0
mmap(0xffff91d92000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0xffff91d92000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0P\17\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14560, ...}) = 0
mmap(NULL, 78080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91d68000
mprotect(0xffff91d6b000, 61440, PROT_NONE) = 0
mmap(0xffff91d7a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0xffff91d7a000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0d\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=151656, ...}) = 0
mmap(NULL, 189448, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xffff91d39000
mprotect(0xffff91d53000, 61440, PROT_NONE) = 0
mmap(0xffff91d62000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19000) = 0xffff91d62000
mmap(0xffff91d64000, 13320, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff91d64000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff91d37000
mprotect(0xffff922b8000, 16384, PROT_READ) = 0
mprotect(0xffff91d62000, 4096, PROT_READ) = 0
mprotect(0xffff91d7a000, 4096, PROT_READ) = 0
mprotect(0xffff91d92000, 4096, PROT_READ) = 0
mprotect(0xffff91e1a000, 4096, PROT_READ) = 0
mprotect(0xffff92529000, 4096, PROT_READ) = 0
mprotect(0xffff91e61000, 4096, PROT_READ) = 0
mprotect(0xffff91e82000, 4096, PROT_READ) = 0
mprotect(0xffff91fb5000, 45056, PROT_READ) = 0
mprotect(0xffff9214b000, 16384, PROT_READ) = 0
mprotect(0xffff92556000, 4096, PROT_READ) = 0
mprotect(0xffff922e1000, 4096, PROT_READ) = 0
mprotect(0xffff9230e000, 4096, PROT_READ) = 0
mprotect(0xffff924d2000, 65536, PROT_READ) = 0
mprotect(0xffff9256e000, 4096, PROT_READ) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x8} ---
+++ killed by SIGSEGV +++
root@nanopi-r2s:~/# armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/2GHs
Please post the URL in the forum where you've been asked for.
root@nanopi-r2s:~/#
Edited by TRS-80
put long output inside code block inside spoiler
apt update/upgrade again after two days later, Then issue resolved as for now( without any notifications )
debian_version finally changed to 10.7 and wget seg fault was gone.:)
root@nanopi-r2s:~/lepup# apt-get update
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://httpredir.debian.org/debian buster InRelease [121 kB]
Get:4 http://httpredir.debian.org/debian buster-updates InRelease [51.9 kB]
Get:5 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
Get:6 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
Get:3 https://armbian.tnahosting.net/apt buster InRelease [18.3 kB]
Get:7 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
Get:8 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.5 MB]
Get:9 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.5 MB]
Get:10 http://httpredir.debian.org/debian buster/contrib arm64 Packages [45.6 kB]
Get:11 http://httpredir.debian.org/debian buster/contrib armhf Packages [47.7 kB]
Get:12 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.0 kB]
Get:13 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [84.8 kB]
Get:14 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [36.9 kB]
Get:15 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [36.9 kB]
Get:16 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [37.0 kB]
Get:17 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [37.0 kB]
Get:18 http://httpredir.debian.org/debian buster-backports/contrib armhf Packages.diff/Index [28.4 kB]
Get:19 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages.diff/Index [27.1 kB]
Get:20 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-12-05-2008.41.pdiff [177 B]
Get:21 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-12-06-0201.27.pdiff [276 B]
Get:22 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-12-07-0202.36.pdiff [204 B]
Get:23 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-12-05-2008.41.pdiff [177 B]
Get:24 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-12-06-0201.27.pdiff [275 B]
Get:25 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-12-07-0202.36.pdiff [204 B]
Get:26 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-12-05-2008.41.pdiff [100 B]
Get:27 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-12-06-0201.27.pdiff [254 B]
Get:28 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-12-07-0202.36.pdiff [6,005 B]
Get:29 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-12-05-2008.41.pdiff [100 B]
Get:30 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-12-06-0201.27.pdiff [258 B]
Get:31 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-12-07-0202.36.pdiff [6,007 B]
Get:32 http://httpredir.debian.org/debian buster-backports/contrib armhf Packages 2020-12-06-0201.27.pdiff [222 B]
Get:33 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages 2020-12-06-0201.27.pdiff [223 B]
Fetched 94.7 MB in 40s (2,359 kB/s)
N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.6' to '10.7'
root@nanopi-r2s:~/lepup# apt-get upgrade
Calculating upgrade... Done
The following packages will be upgraded:
  base-files distro-info-data iptables-persistent libnss-myhostname libpam-systemd libsqlite3-0 libsystemd0 libudev1 libxml2 linux-libc-dev netfilter-persistent systemd systemd-sysv udev
14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 8,103 kB of archives.
After this operation, 21.5 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u7 [69.8 kB]
Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u5 [100.0 kB]
Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u5 [200 kB]
Get:4 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u5 [314 kB]
Get:5 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u5 [122 kB]
Get:6 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u5 [3,256 kB]
Get:7 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u5 [1,244 kB]
Get:8 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u5 [146 kB]
Get:9 http://httpredir.debian.org/debian buster/main arm64 iptables-persistent all 1.0.11+deb10u1 [11.8 kB]
Get:10 http://httpredir.debian.org/debian buster/main arm64 netfilter-persistent all 1.0.11+deb10u1 [10.2 kB]
Get:11 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u3 [6,640 B]
Get:12 http://httpredir.debian.org/debian buster/main arm64 libsqlite3-0 arm64 3.27.2-3+deb10u1 [603 kB]
Get:13 http://httpredir.debian.org/debian buster/main arm64 libxml2 arm64 2.9.4+dfsg1-7+deb10u1 [625 kB]
Get:14 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.160-2 [1,396 kB]
Fetched 8,103 kB in 1s (10.5 MB/s)
Preconfiguring packages ...
(Reading database ... 37908 files and directories currently installed.)
Preparing to unpack .../base-files_10.3+deb10u7_arm64.deb ...
Unpacking base-files (10.3+deb10u7) over (10.3+deb10u6) ...
Setting up base-files (10.3+deb10u7) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../systemd-sysv_241-7~deb10u5_arm64.deb ...
Unpacking systemd-sysv (241-7~deb10u5) over (241-7~deb10u4) ...
Preparing to unpack .../libpam-systemd_241-7~deb10u5_arm64.deb ...
Unpacking libpam-systemd:arm64 (241-7~deb10u5) over (241-7~deb10u4) ...
Preparing to unpack .../libsystemd0_241-7~deb10u5_arm64.deb ...
Unpacking libsystemd0:arm64 (241-7~deb10u5) over (241-7~deb10u4) ...
Setting up libsystemd0:arm64 (241-7~deb10u5) ...
Preparing to unpack .../libnss-myhostname_241-7~deb10u5_arm64.deb ...
Unpacking libnss-myhostname:arm64 (241-7~deb10u5) over (241-7~deb10u4) ...
Preparing to unpack .../systemd_241-7~deb10u5_arm64.deb ...
Unpacking systemd (241-7~deb10u5) over (241-7~deb10u4) ...
Preparing to unpack .../udev_241-7~deb10u5_arm64.deb ...
Unpacking udev (241-7~deb10u5) over (241-7~deb10u4) ...
Preparing to unpack .../libudev1_241-7~deb10u5_arm64.deb ...
Unpacking libudev1:arm64 (241-7~deb10u5) over (241-7~deb10u4) ...
Setting up libudev1:arm64 (241-7~deb10u5) ...
Preparing to unpack .../0-iptables-persistent_1.0.11+deb10u1_all.deb ...
Unpacking iptables-persistent (1.0.11+deb10u1) over (1.0.11) ...
Preparing to unpack .../1-netfilter-persistent_1.0.11+deb10u1_all.deb ...
Unpacking netfilter-persistent (1.0.11+deb10u1) over (1.0.11) ...
Preparing to unpack .../2-distro-info-data_0.41+deb10u3_all.deb ...
Unpacking distro-info-data (0.41+deb10u3) over (0.41+deb10u2) ...
Preparing to unpack .../3-libsqlite3-0_3.27.2-3+deb10u1_arm64.deb ...
Unpacking libsqlite3-0:arm64 (3.27.2-3+deb10u1) over (3.27.2-3) ...
Preparing to unpack .../4-libxml2_2.9.4+dfsg1-7+deb10u1_arm64.deb ...
Unpacking libxml2:arm64 (2.9.4+dfsg1-7+deb10u1) over (2.9.4+dfsg1-7+b3) ...
Preparing to unpack .../5-linux-libc-dev_4.19.160-2_arm64.deb ...
Unpacking linux-libc-dev:arm64 (4.19.160-2) over (4.19.152-1) ...
Setting up distro-info-data (0.41+deb10u3) ...
Setting up libsqlite3-0:arm64 (3.27.2-3+deb10u1) ...
Setting up linux-libc-dev:arm64 (4.19.160-2) ...
Setting up systemd (241-7~deb10u5) ...
Setting up udev (241-7~deb10u5) ...
update-initramfs: deferring update (trigger activated)
Setting up libnss-myhostname:arm64 (241-7~deb10u5) ...
Setting up netfilter-persistent (1.0.11+deb10u1) ...
Setting up libxml2:arm64 (2.9.4+dfsg1-7+deb10u1) ...
Setting up systemd-sysv (241-7~deb10u5) ...
Setting up iptables-persistent (1.0.11+deb10u1) ...
Setting up libpam-systemd:arm64 (241-7~deb10u5) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.20-0+deb10u1) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for initramfs-tools (0.133+deb10u1) ...
update-initramfs: Generating /boot/initrd.img-5.9.11-rockchip64
update-initramfs: Converting to u-boot format
root@nanopi-r2s:~/lepup# apt-get dist-upgrade
10.7
root@nanopi-r2s:~/lepup# uname -a
root@nanopi-r2s:~/lepup# wget
wget: missing URL
Usage: wget [OPTION]... ...
Try `wget --help' for more options.
Edited by TRS-80
Glad to hear it's working, thanks for reporting back (and for your initial report).
Devs do read these forums, I don't know in this case if anything was done specifically to address this or not, however they don't always have time to reply to everyone on individual basis.  So I try and fill in the communications gaps as much as I can on forums, IRC and elsewhere.
Cheers!
Edited by TRS-80
