plz help me out with HP1112 printter. Dmesg detects it as a printer. I have also install HPLIP but the hp tool doesnt detect it .The auto detect driver utility detects my system to be missing in libsnmp-dev, libtool, sane-utils,python-reportlab .But it doesnt  get installed by itself . Can someone help me out what do to do ?  I  need to print some study materials . after checking this above missing stuffs , they are already here in my system.
HP Linux Imaging and Printing System (ver. 3.14.6)
Self Diagnse Utility and Healing Utility ver. 1.0
Copyright © 2001-13 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Checking for Deprecated items....
error: This distro (i.e debian  8.5) is either deprecated or not yet supported.
The diagnosis is limited on unsupported platforms. Do you want to continue?(y=yes*, n=no):y
Checking for HPLIP updates....
error: Failed to locate hp-upgrade utility
Checking for Dependencies....
warning: debian-8.5 version is not supported. Using debian-7.5 versions dependencies to verify and install...
| SYSTEM INFO |
 Kernel: 3.4.112-sun8i #14 SMP PREEMPT Tue Jul 5 16:28:14 CEST 2016 GNU/Linux
 Host: orangepipc
 Proc: 3.4.112-sun8i #14 SMP PREEMPT Tue Jul 5 16:28:14 CEST 2016 GNU/Linux
 Distribution: debian 8.5
 Bitness: 32 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.14.6
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for debian distro  8.5 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf.  Generated from hplip.conf.in by configure.
[hplip]
version=3.14.6
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-doc/HTML
html=/usr/share/doc/hplip-3.14.6
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.14.6
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
Current contents of '/var/lib/hp/hplip.state' file:
[plugin]
installed = 1
eula = 1
version = 3.14.6
Current contents of '~/.hplip/hplip.conf' file:
[installation]
date_time = 07/19/2016 06:24:48
version = 3.14.6
[settings]
systray_visible = 0
systray_messages = 0
[last_used]
device_uri =
printer_name =
working_dir = .
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
notify_upgrade = true
last_upgraded_time = 1468874290.19515
pending_upgrade_time = 0
 <Package-name>        <Package-Desc>      <Required/Optional> <Min-Version> <Installed-Version> <Status>   <Comment>
|  External Dependencies |
 policykit            Admin-Policy-framework    OPTIONAL        -               0.105           OK         -
 gs                   Ghostscript               REQUIRED        7.05            9.06            OK         -
 network              Network-wget              OPTIONAL        -               1.16            OK         -
 scanimage            Shell-Scanning            OPTIONAL        1.0             1.0.24          OK         -
 avahi-utils          avahi-utils               OPTIONAL        -               0.6.31          OK         -
 dbus                 DBus                      REQUIRED        -               1.8.20          OK         -
 cups                 CUPS                      REQUIRED        1.1             1.7.5           OK         'CUPS Scheduler is running'
 xsane                SANE-GUI                  OPTIONAL        0.9             0.998           OK         -
|  General Dependencies |
 error: reportlab     Python-PDF-Lib            OPTIONAL        2.0             3.1.8           MISSING    'reportlab needs to be installed'
 libcrypto            OpenSSL-Crypto-Lib        REQUIRED        -               1.0.1           OK         -
 pil                  Python-Image-Lib          OPTIONAL        -               1.1.7           OK         -
 pyqt4-dbus           PyQt4-DBUS                REQUIRED        4.0             4.11.2          OK         -
 libjpeg              JPEG-Lib                  REQUIRED        -               -               OK         -
 libpthread           POSIX-Threads-Lib         REQUIRED        -               2.19            OK         -
 python-dbus          Python-DBUS               REQUIRED        0.80.0          1.2.0           OK         -
 python-devel         Python-SDK                REQUIRED        2.2             2.7.9           OK         -
 pyqt4                Python-Qt4                REQUIRED        4.0             4.11.2          OK         -
 cups-devel           CUPS-SDK                  REQUIRED        -               1.7.5           OK         -
 sane-devel           SANE-SDK                  REQUIRED        -               1.0.24          OK         -
 libusb               USB-Lib                   REQUIRED        -               1.0             OK         -
 sane                 Scan-Lib                  REQUIRED        -               1.0.24          OK         -
 cups-image           CUPS-Image-Lib            REQUIRED        -               1.7.5           OK         -
 libnetsnmp-devel     SNMP-Networking-SDK       REQUIRED        5.0.9           5.7.2           OK         -
 python-xml           Python-XML-Lib            REQUIRED        -               2.1.0           OK         -
 python-notify        Desktop-notifications     OPTIONAL        -               -               OK         -
|  Compile Time Dependencies |
 gcc                  gcc-Compiler              REQUIRED        -               4.9.2           OK         -
 error: libtool       Build-tools               REQUIRED        -               -               MISSING    'libtool needs to be installed'
 make                 GNU-Build-tools           REQUIRED        3.0             4.0             OK         -
|  Python Extentions |
 cupsext              CUPS-Extension            REQUIRED        -               3.14.6          OK         -
 pcardext             PhotoCard-Extension       REQUIRED        -               3.14.6          OK         -
 hpmudext             IO-Extension              REQUIRED        -               3.14.6          OK         -
|  Scan Configuration |
 hpaio                HPLIP-SANE-Backend        REQUIRED        -               3.14.6          OK         'hpaio found in /etc/sane.d/dll.conf'
 scanext              Scan-SANE-Extension       REQUIRED        -               3.14.6          OK         -
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
lpstat
Type: Unknown
Device URI: No destinations added.
| PERMISSION |
Missing Required Dependencies
error: 'libtool' package is missing/incompatible
Missing Optional Dependencies
error: 'python-reportlab' package is missing/incompatible
ENTER ROOT/SUPERUSER PASSWORD
Please enter the root/superuser password:
Do you want to update repository and Install missing/incompatible packages. (a=install all*, c=custom_install, s=skip):a
Updating repository
cmd =su -c "dpkg --configure -a"
cmd =su -c "apt-get install -f"
cmd =su -c "apt-get update"
warning: Failed to update Repository, check if any update/installation is running.
cmd =su -c "apt-get install --yes cupsys-bsd"
Installing Missing/Incompatible packages
cmd =su -c "apt-get install --force-yes -y libtool"
cmd =su -c "apt-get install --force-yes -y python-reportlab"
Checking Permissions....
Permissions are correct.
Guest premo
Thankyou. But I figured it out myself. I did installed hplip.cups..But didn't worked. SO I opened a browser and added user in CUPS , added a printer and took time to get a suitable model driver.My first print threw a blank one.but It had worked.
