Hi, Armbian gurus.
I have make a new kernel and related modules for my pineh64 and want to test it. Thus they are not from dpkg.
To test this kernel and modules.
I have few questions:
1. About the symbolic links in /boot, are they all mandatory? What if I don't have an initramfs?
2. The Image linked file, is it have to be limited to certain compressed format to work properly?
3. Is there a recommended work flow to test a external kernel? Or I can just test by replacing Image, dtb, and the modules?
Thank you.
you need to know how u-boot boots linux kernel and brings it userspace.
the only thing you need to care is boot command,
but the boot command you should make u-boot to know where to find kernel/initramfs/dtb, no mater where you put them.
for no initramfs,. if your kernel has enough driver to mount your root device, I guess that's fine. but usually initramfs is required.
