horiatm Posted January 1, 2021 Posted January 1, 2021 (edited) Hello, I have a custom tv box named dsQuad from Dotsmart that comes with custom Buid Root linux kernel 3.10 and has kodi on it. I want to transform the box into a desktop to help my kids with online school. Need to run windows manager with internet browser to have acces to google classroom and google meet. I have also a loghitech c920 and bt mouse and keyboard that i want to connect to the box. All of the hardwre are working in android version of the box. https://yadi.sk/i/RJr5jiuXBf1dZw - image of the device and remote control https://yadi.sk/i/BeonUuLNdJIxmA - image of the back ports https://yadi.sk/i/t8BwT9377hta0A - image of the side ports https://yadi.sk/i/ymxZ0aD5i-3NrQ - image of the board inside I am in posesion of root password and have acces to ssh and also have the system os arhived in a zip file. android and linux. https://yadi.sk/d/U1UhBjDqhld8QQ - system arhive The version of build root that is installed dose not have install manger and has minimal program installed. I managed to extract dtb file from uimage. https://yadi.sk/d/3szT7xgZUrVA5w - dtb and dts Spoiler /dts-v1/; / { compatible = "AMLOGIC,8726_M8"; model = "AMLOGIC"; interrupt-parent = <0x01>; #address-cells = <0x01>; #size-cells = <0x01>; cpus { #address-cells = <0x01>; #size-cells = <0x00>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x200>; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x01>; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x02>; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x03>; }; }; cache-controller { compatible = "arm,meson-pl310-cache"; reg = <0xc4200000 0x1000>; arm,data-latency = <0x03 0x03 0x03>; arm,tag-latency = <0x02 0x02 0x02>; arm,filter-ranges = <0x100000 0xc0000000>; cache-unified; cache-level = <0x02>; aux-instruction_prefetch; aux-data_prefetch; aux-ns_lockdown; aux-force_no_write_alloc; aux-cache_replace_policy_round_robin; aux-early_write_response; aux-full_line_of_zero; aux-ns_int_ctrl; aux-share_override; prefetch-double_line_fill; prefetch-prefetch_drop; prefetch-prefetch_offset = <0x07>; }; memory { device_type = "memory"; aml_reserved_start = <0x6000000>; aml_reserved_end = <0x5000000>; phys_offset = <0x200000>; linux,total-memory = <0x7fe00000>; #address-cells = <0x01>; #size-cells = <0x01>; region@0 { region_name = "cma_0"; reg = <0x00 0x1200000>; linux,contiguous-region; linux,phandle = <0x02>; phandle = <0x02>; }; }; interrupt-controller { compatible = "arm,cortex-a9-gic"; reg = <0xc4301000 0x1000 0xc4300100 0x100>; interrupt-controller; #interrupt-cells = <0x03>; #address-cells = <0x00>; linux,phandle = <0x01>; phandle = <0x01>; }; vpu { compatible = "amlogic,vpu"; dev_name = "vpu"; status = "ok"; clk_level = <0x07>; }; mesonfb { compatible = "amlogic,mesonfb"; dev_name = "mesonfb"; status = "okay"; reserve-memory = <0x1800000 0x100000>; reserve-iomap = "true"; vmode = <0x03>; scale_mode = <0x01>; 4k2k_fb = <0x00>; display_size_default = <0x780 0x438 0x780 0xca8 0x20>; }; deinterlace { compatible = "amlogic,deinterlace"; dev_name = "deinterlace"; status = "ok"; reserve-memory = <0x2100000>; }; mesonstream { compatible = "amlogic,mesonstream"; dev_name = "mesonstream.0"; status = "okay"; reserve-memory = <0x2000000>; reserve-iomap = "true"; }; vdec { compatible = "amlogic,vdec"; dev_name = "vdec.0"; status = "okay"; reserve-memory = <0x10000000>; reserve-iomap = "true"; }; ppmgr { compatible = "amlogic,ppmgr"; dev_name = "ppmgr"; status = "okay"; reserve-memory = <0x1000000>; }; amvenc_avc { compatible = "amlogic,amvenc_avc"; dev_name = "amvenc_avc.0"; status = "okay"; linux,contiguous-region = <0x02>; }; vdin1 { compatible = "amlogic,vdin"; dev_name = "vdin1"; status = "ok"; reserve-memory = <0x1000000>; miracast_size = <0x780 0x438>; reserve-iomap = "true"; irq = <0x75>; vdin_id = <0x01>; }; amlvideo2 { compatible = "amlogic,amlvideo2"; dev_name = "amlvideo2.0"; status = "okay"; reserve-memory = <0x1800000>; reserve-iomap = "true"; }; ion_dev { compatible = "amlogic,ion_dev"; dev_name = "ion_dev"; status = "ok"; share-memory-name = "ppmgr0"; share-memory-offset = <0x00>; share-memory-size = <0x1000000>; }; mesonvout { compatible = "amlogic,mesonvout"; dev_name = "mesonvout"; status = "okay"; }; rtc { compatible = "amlogic,aml_rtc"; status = "okay"; }; uart_ao { compatible = "amlogic,aml_uart"; port_name = "uart_ao"; status = "okay"; dev_name = "uart_ao"; pinctrl-names = "default"; pinctrl-0 = <0x03>; }; uart_0 { compatible = "amlogic,aml_uart"; port_name = "uart_a"; status = "okay"; dev_name = "uart_0"; pinctrl-names = "default"; pinctrl-0 = <0x04>; }; uart_1 { compatible = "amlogic,aml_uart"; port_name = "uart_b"; status = "disabled"; dev_name = "uart_1"; }; uart_2 { compatible = "amlogic,aml_uart"; port_name = "uart_c"; status = "disabled"; dev_name = "uart_2"; }; uart_3 { compatible = "amlogic,aml_uart"; port_name = "uart_d"; status = "ok"; dev_name = "uart_3"; }; bt-dev { compatible = "amlogic,bt-dev"; dev_name = "bt-dev"; status = "ok"; gpio_reset = "GPIOX_20"; }; wifi { compatible = "amlogic,aml_broadcm_wifi"; dev_name = "aml_broadcm_wifi"; status = "okay"; interrupt_pin = "GPIOX_21"; irq_num = <0x04>; irq_trigger_type = "GPIO_IRQ_HIGH"; power_on_pin = "GPIOAO_6"; power_on_pin2 = "GPIOX_11"; clock_32k_pin = "GPIOX_10"; }; wifi_power { compatible = "amlogic,wifi_power"; dev_name = "wifi_power"; status = "okay"; power_gpio = "GPIOAO_6"; power_gpio2 = "GPIOX_11"; }; sdio { compatible = "amlogic,aml_sdio"; dev_name = "aml_sdio.0"; status = "okay"; reg = <0xc1108c20 0x20>; pinctrl-names = "sd_clk_cmd_pins\0sd_all_pins\0emmc_clk_cmd_pins\0emmc_all_pins\0sdio_clk_cmd_pins\0sdio_all_pins\0sd_1bit_pins"; pinctrl-0 = <0x05>; pinctrl-1 = <0x06>; pinctrl-2 = <0x07>; pinctrl-3 = <0x08>; pinctrl-4 = <0x09>; pinctrl-5 = <0x0a>; pinctrl-6 = <0x0b>; sd { status = "okay"; port = <0x01>; pinname = "sd"; ocr_avail = <0x200000>; caps = "MMC_CAP_4_BIT_DATA\0MMC_CAP_MMC_HIGHSPEED\0MMC_CAP_SD_HIGHSPEED"; f_min = <0x493e0>; f_max = <0x2faf080>; max_req_size = <0x20000>; gpio_dat3 = "CARD_4"; jtag_pin = "CARD_0"; gpio_cd = "CARD_6"; irq_in = <0x03>; irq_out = <0x05>; card_type = <0x05>; }; emmc { status = "ok"; port = <0x02>; pinname = "emmc"; ocr_avail = <0x200000>; caps = "MMC_CAP_4_BIT_DATA\0MMC_CAP_MMC_HIGHSPEED\0MMC_CAP_SD_HIGHSPEED\0MMC_CAP_NONREMOVABLE\0MMC_CAP_ERASE\0MMC_CAP_HW_RESET"; f_min = <0x493e0>; f_max = <0x2faf080>; f_max_w = <0x2faf080>; max_req_size = <0x20000>; gpio_dat3 = "BOOT_3"; card_type = <0x01>; }; sdio { status = "ok"; port = <0x00>; pinname = "sdio"; ocr_avail = <0x200000>; caps = "MMC_CAP_4_BIT_DATA\0MMC_CAP_MMC_HIGHSPEED\0MMC_CAP_SD_HIGHSPEED\0MMC_CAP_NONREMOVABLE"; f_min = <0x493e0>; f_max = <0x2faf080>; max_req_size = <0x20000>; card_type = <0x03>; }; }; i2c@c8100500 { compatible = "amlogic,aml_i2c"; dev_name = "i2c-AO"; status = "ok"; reg = <0xc8100500 0x1d>; #address-cells = <0x01>; #size-cells = <0x00>; device_id = <0x00>; pinctrl-names = "default"; pinctrl-0 = <0x0c>; use_pio = <0x00>; master_i2c_speed = <0x186a0>; }; i2c@c1108500 { compatible = "amlogic,aml_i2c"; dev_name = "i2c-A"; status = "ok"; reg = <0xc1108500 0x20>; device_id = <0x01>; pinctrl-names = "default"; #address-cells = <0x01>; #size-cells = <0x00>; use_pio = <0x00>; master_i2c_speed = <0x493e0>; }; i2c@c11087c0 { compatible = "amlogic,aml_i2c"; dev_name = "i2c-B"; status = "ok"; reg = <0xc11087c0 0x20>; device_id = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x0d>; #address-cells = <0x01>; #size-cells = <0x00>; use_pio = <0x00>; master_i2c_speed = <0x493e0>; }; i2c@c11087e0 { compatible = "amlogic,aml_i2c"; dev_name = "i2c-C"; status = "ok"; reg = <0xc11087e0 0x20>; device_id = <0x03>; pinctrl-names = "default"; #address-cells = <0x01>; #size-cells = <0x00>; use_pio = <0x00>; master_i2c_speed = <0x493e0>; }; dvfs { compatible = "amlogic, amlogic-dvfs"; #address-cells = <0x01>; #size-cells = <0x00>; status = "ok"; vcck_dvfs { dvfs_id = <0x01>; table_count = <0x0e>; dvfs_table = <0x17700 0xc96a8 0xc96a8 0x2ee00 0xc96a8 0xc96a8 0x4c2c0 0xc96a8 0xc96a8 0x639c0 0xc96a8 0xc96a8 0x7b0c0 0xc96a8 0xc96a8 0x927c0 0xcf850 0xcf850 0xafc80 0xcf850 0xcf850 0xc7380 0xd59f8 0xd59f8 0xf6180 0xe1d48 0xe1d48 0x124f80 0xee098 0xee098 0x159b40 0xfa3e8 0xfa3e8 0x188940 0x10c8e0 0x10c8e0 0x1b7740 0x112a88 0x112a88 0x1e6540 0x118c30 0x118c30>; }; }; arm_pmu { compatible = "arm,cortex-a9-pmu"; status = "ok"; interrupts = <0x00 0x89 0x04 0x00 0x8a 0x04 0x00 0x99 0x04 0x00 0x9a 0x04>; }; pmu { compatible = "amlogic, aml_pmu_prober"; #address-cells = <0x01>; #size-cells = <0x00>; rn5t618 { compatible = "ricoh_pmu"; sub_type = "rn5t618"; i2c_bus = "i2c_bus_ao"; reg = <0x32>; soft_limit_to99 = <0x00>; ddr_voltage = <0x16e360>; vddao_voltage = <0x124f80>; status = "okay"; }; }; usb_con { lm-compatible = "logicmodule-bus"; usb_b { lm-compatible = "amlogic,usb"; lm-periph-id = <0x01>; clock-src = "usb1"; port-id = <0x01>; port-type = <0x01>; port-speed = <0x00>; port-config = <0x00>; port-dma = <0x00>; port-id-mode = <0x01>; status = "okay"; }; usb_a { lm-compatible = "amlogic,usb"; lm-periph-id = <0x00>; clock-src = "usb0"; port-id = <0x00>; port-type = <0x00>; port-speed = <0x00>; port-config = <0x00>; port-dma = <0x00>; port-id-mode = <0x00>; gpio-vbus-power = "GPIOZ_1"; gpio-work-mask = <0x01>; status = "okay"; }; }; spi@cc000000 { compatible = "amlogic,apollo_spi_nor"; status = "ok"; reg = <0xcc000000 0x4000000>; pinctrl-names = "default"; pinctrl-0 = <0x0e>; nr-parts = <0x02>; nr-part-0 = <0x0f>; nr-part-1 = <0x10>; bootloader { offset = <0x00>; size = <0x100000>; linux,phandle = <0x0f>; phandle = <0x0f>; }; ubootenv { offset = <0x100000>; size = <0x10000>; linux,phandle = <0x10>; phandle = <0x10>; }; }; nand { compatible = "amlogic,aml_nand"; dev_name = "nand"; status = "ok"; reg = <0xd0048600 0x24>; pinctrl-names = "nand_rb_mod\0nand_norb_mod"; pinctrl-0 = <0x11 0x12 0x13 0x14>; pinctrl-1 = <0x11 0x12 0x13 0x14>; device_id = <0x00>; plat-names = "nandnormal"; plat-num = <0x01>; plat-part-0 = <0x15>; normal { enable_pad = "ce0\0ce1\0ce2\0ce3"; busy_pad = "rb0"; linux,phandle = <0x15>; phandle = <0x15>; }; }; efuse { compatible = "amlogic,efuse"; dev_name = "efuse"; status = "okay"; plat-pos = <0x00 0x1c6>; plat-count = <0x3a>; usid-min = <0x08>; usid-max = <0x1f>; }; thermal { compatible = "amlogic-thermal"; #thermal-cells = <0x07>; dev_name = "aml_thermal"; trip_point = <0x46 0x188941 0x188941 0x1ff 0x1ff 0x03 0x05 0x50 0x124f81 0x124f81 0x1b3 0x1b3 0x02 0x04 0x5a 0xc3501 0xc3501 0x148 0x148 0x02 0x03 0x104 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff>; cpu_cali_a = <0x00>; idle_interval = <0x3e8>; use_virtual_thermal; freq_sample_period = <0x1e>; report_time = <0x01 0x0a 0x1e 0x3c>; cpu_virtual = <0x7a120 0x28 0x28 0x28 0x28 0x927c0 0x2d 0x37 0x3c 0x41 0xc3500 0x32 0x3c 0x41 0x46 0xf4240 0x37 0x41 0x46 0x4b 0x124f80 0x3c 0x46 0x4b 0x50 0x155cc0 0x41 0x4b 0x50 0x55>; gpu_virtual = <0xb7 0x28 0x28 0x28 0x28 0xfb 0x28 0x2d 0x32 0x37 0x13f 0x32 0x3c 0x41 0x46 0x1aa 0x37 0x41 0x46 0x4b 0x1ff 0x3c 0x46 0x4b 0x50>; }; audio_platform { compatible = "amlogic,aml-i2s"; dev_name = "aml-i2s.0"; status = "okay"; }; audio_dai { compatible = "amlogic,aml-i2s-dai"; dev_name = "aml-i2s-dai.0"; status = "okay"; }; audio_spdif_dai { compatible = "amlogic,aml-spdif-dai"; dev_name = "aml-spdif-dai.0"; status = "okay"; }; audio_spdif_codec { compatible = "amlogic,aml-spdif-codec"; dev_name = "spdif-dit.0"; pinctrl-names = "aml_audio_spdif"; pinctrl-0 = <0x16>; status = "okay"; }; audio_pcm2BT_codec { compatible = "amlogic,pcm2BT-codec"; dev_name = "pcm2bt.0"; status = "okay"; }; audio_pcm_dai { compatible = "amlogic,aml-pcm-dai"; dev_name = "aml-pcm-dai.0"; status = "okay"; }; audio_pcm { compatible = "amlogic,aml-pcm"; dev_name = "aml-pcm.0"; status = "okay"; }; audio_m8_audio { compatible = "amlogic,m8_audio_codec"; dev_name = "aml_m8_codec.0"; status = "disable"; }; dummy_codec { compatible = "amlogic,aml_dummy_codec"; dev_name = "dummy_codec.0"; status = "okay"; }; aml_audio_codec { compatible = "amlogic,audio_codec"; dummy { codec_name = "dummy_codec"; status = "okay"; }; }; aml_m8_sound_card { compatible = "sound_card, aml_snd_m8"; aml,sound_card = "AML-M8AUDIO"; aml,codec_dai = "AML-M8\0dummy_codec"; aml,audio-routing-rt5616 = "Ext Spk\0LOUTL\0Ext Spk\0LOUTR\0HP\0HPOL\0HP\0HPOR\0micbias1\0MAIN MIC\0IN2P\0micbias1"; aml,audio-routing-amlm8 = "Ext Spk\0LINEOUTL\0Ext Spk\0LINEOUTR\0HP\0HP_L\0HP\0HP_R\0MICBIAS\0MAIN MIC\0LINPUT1\0MICBIAS"; aml,audio-routing-dummy = "Ext Spk\0LOUTL\0Ext Spk\0LOUTR"; mute_gpio = "GPIO_BSD_EN"; hp_disable; hp_paraments = <0x320 0x12c 0x00 0x05 0x01>; pinctrl-names = "aml_snd_m8"; pinctrl-0 = <0x17>; status = "okay"; }; gpio_keypad { compatible = "amlogic,gpio_keypad"; status = "okay"; scan_period = <0x14>; key_num = <0x01>; key_name = "power"; key_code = <0x74>; key_pin = "GPIOAO_3"; irq_keyup = <0x06>; irq_keydown = <0x07>; }; saradc { compatible = "amlogic,saradc"; status = "okay"; }; meson-remote { compatible = "amlogic,aml_remote"; dev_name = "meson-remote"; status = "ok"; ao_baseaddr = <0xf3100480>; pinctrl-names = "default"; pinctrl-0 = <0x18>; }; securitykey { compatible = "amlogic,aml_keys"; status = "ok"; }; unifykey { compatible = "amlogic,unifykey"; status = "ok"; unifykey-num = <0x06>; unifykey-index-0 = <0x19>; unifykey-index-1 = <0x1a>; unifykey-index-2 = <0x1b>; unifykey-index-3 = <0x1c>; unifykey-index-4 = <0x1d>; unifykey-index-5 = <0x1e>; key_0 { key-name = "usid"; key-device = "nandkey"; key-dataformat = "allascii"; key-permit = "read\0write\0del"; linux,phandle = <0x19>; phandle = <0x19>; }; key_1 { key-name = "mac"; key-device = "nandkey"; key-dataformat = "hexdata"; key-permit = "read\0write\0del"; linux,phandle = <0x1a>; phandle = <0x1a>; }; key_2 { key-name = "hdcp"; key-device = "nandkey"; key-dataformat = "hexdata"; key-permit = "read\0write\0del"; linux,phandle = <0x1b>; phandle = <0x1b>; }; key_3 { key-name = "secure_boot_set"; key-device = "efusekey"; key-dataformat = "hexdata"; key-permit = "read\0write"; linux,phandle = <0x1c>; phandle = <0x1c>; }; key_4 { key-name = "mac_bt"; key-device = "nandkey"; key-dataformat = "hexdata"; key-permit = "read\0write\0del"; linux,phandle = <0x1d>; phandle = <0x1d>; }; key_5 { key-name = "mac_wifi"; key-device = "nandkey"; key-dataformat = "hexdata"; key-permit = "read\0write\0del"; linux,phandle = <0x1e>; phandle = <0x1e>; }; }; amhdmitx { compatible = "amlogic,amhdmitx"; dev_name = "amhdmitx"; status = "ok"; vend-data = <0x1f>; pwr-ctrl = <0x20>; vend_data { vendor_name = "dotSmart"; vendor_id = <0x00>; product_desc = "dotSmart dsQuad"; cec_osd_string = "smart dsQuad"; linux,phandle = <0x1f>; phandle = <0x1f>; }; pwr_ctrl { pwr_5v_on = [00]; pwr_5v_off = [00]; pwr_3v3_on = [00]; pwr_3v3_off = [00]; pwr_hpll_vdd_on = [00]; pwr_hpll_vdd_off = [00]; linux,phandle = <0x20>; phandle = <0x20>; }; }; aml_pm { compatible = "amlogic,pm-m8"; dev_name = "aml_pm_m8"; status = "okay"; }; cpufreq-meson { compatible = "amlogic,cpufreq-meson"; status = "okay"; }; crypto_device { compatible = "amlogic,crypto-device"; dev_name = "crypto_device"; }; gpio { compatible = "amlogic,m8-gpio"; dev_name = "gpio"; #gpio-cells = <0x02>; }; pinmux { compatible = "amlogic,pinmux-m8"; dev_name = "pinmux"; #pinmux-cells = <0x02>; ao_uart { amlogic,setmask = <0x0a 0x1800>; amlogic,pins = "GPIOAO_0\0GPIOAO_1"; linux,phandle = <0x03>; phandle = <0x03>; }; a_uart { amlogic,setmask = <0x04 0x3c00>; amlogic,pins = "GPIOX_12\0GPIOX_13\0GPIOX_14\0GPIOX_15"; linux,phandle = <0x04>; phandle = <0x04>; }; nand_input { amlogic,pins = "BOOT_0\0BOOT_1\0BOOT_2\0BOOT_3\0BOOT_4\0BOOT_5\0BOOT_6\0BOOT_7\0BOOT_12\0BOOT_13\0BOOT_8\0BOOT_9\0BOOT_10\0BOOT_11\0BOOT_14\0BOOT_15\0BOOT_16\0BOOT_17"; amlogic,enable-output = <0x01>; linux,phandle = <0x11>; phandle = <0x11>; }; conf_nand { amlogic,pins = "BOOT_0\0BOOT_1\0BOOT_2\0BOOT_3\0BOOT_4\0BOOT_5\0BOOT_6\0BOOT_7\0BOOT_15"; amlogic,pullup = <0x00>; amlogic,pullupen = <0x01>; linux,phandle = <0x12>; phandle = <0x12>; }; conf_nand1 { amlogic,pins = "BOOT_8\0BOOT_10"; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x13>; phandle = <0x13>; }; nand { amlogic,setmask = <0x02 0x7fe0000>; amlogic,clrmask = <0x05 0x0e 0x06 0x3f000000 0x04 0x7c000000>; amlogic,pins = "BOOT_0\0BOOT_1\0BOOT_2\0BOOT_3\0BOOT_4\0BOOT_5\0BOOT_6\0BOOT_7\0BOOT_8\0BOOT_9\0BOOT_10\0BOOT_12\0BOOT_13\0BOOT_14\0BOOT_15\0BOOT_16\0BOOT_17"; linux,phandle = <0x14>; phandle = <0x14>; }; sdhc_b_pin { amlogic,setmask = <0x02 0xfc00>; amlogic,clrmask = <0x02 0xf0 0x08 0x600>; amlogic,pins = "CARD_0\0CARD_1\0CARD_2\0CARD_3\0CARD_4\0CARD_5"; }; sdhc_c_pin { amlogic,setmask = <0x06 0x3f000000>; amlogic,clrmask = <0x04 0x6c000000 0x02 0x4c00000>; amlogic,pins = "BOOT_0\0BOOT_1\0BOOT_2\0BOOT_3\0BOOT_10\0BOOT_11"; }; sdhc_a_pin { amlogic,setmask = <0x08 0x3f>; amlogic,clrmask = <0x05 0x6c00>; amlogic,pins = "GPIOX_0\0GPIOX_1\0GPIOX_2\0GPIOX_3\0GPIOX_8\0GPIOX_9"; }; sdio_all_pins { amlogic,setmask = <0x08 0x3f>; amlogic,clrmask = <0x06 0x3f000000 0x02 0xfc00 0x05 0x6c00>; amlogic,pins = "GPIOX_0\0GPIOX_1\0GPIOX_2\0GPIOX_3\0GPIOX_8\0GPIOX_9"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x0a>; phandle = <0x0a>; }; sdio_clk_cmd_pins { amlogic,setmask = <0x08 0x03>; amlogic,clrmask = <0x06 0x3f000000 0x02 0xfc00 0x05 0x6c00>; amlogic,pins = "GPIOX_8\0GPIOX_9"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x09>; phandle = <0x09>; }; sd_all_pins { amlogic,setmask = <0x02 0xfc00>; amlogic,clrmask = <0x06 0x3f000000 0x08 0x63f 0x02 0xf0>; amlogic,pins = "CARD_0\0CARD_1\0CARD_2\0CARD_3\0CARD_4\0CARD_5"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x06>; phandle = <0x06>; }; sd_1bit_pins { amlogic,setmask = <0x02 0x8c00>; amlogic,clrmask = <0x06 0x3f000000 0x08 0x3f 0x02 0xf0>; amlogic,pins = "CARD_0\0CARD_1\0CARD_2\0CARD_3\0CARD_4\0CARD_5"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x0b>; phandle = <0x0b>; }; sd_clk_cmd_pins { amlogic,setmask = <0x02 0xc00>; amlogic,clrmask = <0x06 0x3f000000 0x08 0x3f 0x02 0xf0>; amlogic,pins = "CARD_2\0CARD_3"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x05>; phandle = <0x05>; }; emmc_all_pins { amlogic,setmask = <0x06 0x3f000000>; amlogic,clrmask = <0x02 0x4c0fc00 0x08 0x3f 0x04 0x6c000000>; amlogic,pins = "BOOT_0\0BOOT_1\0BOOT_2\0BOOT_3\0BOOT_16\0BOOT_17"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x08>; phandle = <0x08>; }; emmc_clk_cmd_pins { amlogic,setmask = <0x06 0x3000000>; amlogic,clrmask = <0x02 0x4c0fc00 0x08 0x3f 0x04 0x6c000000>; amlogic,pins = "BOOT_16\0BOOT_17"; amlogic,enable-output = <0x01>; amlogic,pullup = <0x01>; amlogic,pullupen = <0x01>; linux,phandle = <0x07>; phandle = <0x07>; }; ao_i2c { amlogic,setmask = <0x0a 0x60>; amlogic,clrmask = <0x0a 0x1800006>; amlogic,pins = "GPIOAO_4\0GPIOAO_5"; linux,phandle = <0x0c>; phandle = <0x0c>; }; b_i2c { amlogic,setmask = <0x05 0xc000000>; amlogic,pins = "GPIOZ_2\0GPIOZ_3"; linux,phandle = <0x0d>; phandle = <0x0d>; }; remote_pin { amlogic,setmask = <0x0a 0x01>; amlogic,pins = "GPIOAO_7"; linux,phandle = <0x18>; phandle = <0x18>; }; audio_pin { amlogic,setmask = <0x03 0x78000000 0x0a 0x78000000>; amlogic,clrmask = <0x04 0x3c000 0x05 0x1000>; amlogic,pins = "GPIOX_4\0GPIOX_5\0GPIOX_6\0GPIOX_7\0GPIOAO_8\0GPIOAO_9\0GPIOAO_10\0GPIOAO_11"; linux,phandle = <0x17>; phandle = <0x17>; }; audio_pin1 { amlogic,setmask = <0x01 0x80>; amlogic,clrmask = <0x01 0x10000>; amlogic,pins = "GPIOY_3"; linux,phandle = <0x16>; phandle = <0x16>; }; aml_spi_nor_pins { amlogic,setmask = <0x05 0x0f>; amlogic,clrmask = <0x02 0x380000>; amlogic,pins = "BOOT_11\0BOOT_12\0BOOT_13\0BOOT_18"; linux,phandle = <0x0e>; phandle = <0x0e>; }; }; meson-eth { compatible = "amlogic,meson-eth"; dev_name = "meson-eth"; status = "okay"; ethbaseaddr = <0xfe0c0000>; interruptnum = <0x28>; new_maclogic = <0x01>; }; }; Tried to boot several images like Armbian_21.02.0-trunk_Aml s812_buster_current_5.10.0_xfce_desktop, but no luck so far. So what can i do? Edited January 1, 2021 by Werner Use spoiler for large pastes
SteeMan Posted January 1, 2021 Posted January 1, 2021 @horiatm welcome to armbian and the TV box club. Since this is your first post, I want to point you to the 'Please Read First' post: https://forum.armbian.com/topic/16407-please-read-first I have never heard of your box before. In doing some searching, I don't see anyone ever posting about it in the armbian forums either. Actually I can't find much information at all about the box. Therefore it is unlikely that anyone around here is going to own one or have any direct experience with it. Therefore while we might be able to give you some general guidance, you are likely on your own trying to hack armbian onto your box. If you are looking for help, more information would be helpful. Like where are you downloading the images you are trying from? What steps/instructions are you using to attempt to get this working. Simply saying 'Tried to boot..' doesn't give us much to go on. Things like what dtb's you have tried (and how) would be helpful. 1
horiatm Posted January 1, 2021 Author Posted January 1, 2021 short story The box was designed in 2015 by a romanian guy,and produced in china, you can’t find anything about it becouse in 2019 the guy has some legal problems and the goverment shut down his site and all his forums. dotsmart.ro I’ve called the guy last month to ask for help, at first he told me he is out of business but he called me back and give me the root password. Now to answer what i’ve tried to boot: 1. format the sd card with sd card formater for Mac 2. burn the image with balenaetcher for Mac Armbian_20.09_Aml-s812_focal_current_5.9.0-rc7_desktop.img Armbian_20.09_Aml-s812_bionic_current_5.9.0-rc7.img Armbian_20.09_Aml-s812_bullseye_current_5.9.0-rc7_desktop.img Armbian_21.02.0-trunk_Aml-s812_buster_current_5.10.0_xfce_desktop.img Armbian_21.02.0-trunk_Aml-s812_focal_current_5.10.0_xfce_desktop 3. edit uEnv first i’ve tried meson6-atv1200.dtb, meson8-minix-neo-x8.dtb, meson8m2-m8s.dtb,meson8m2-mxiii-plus.dtb, meson8b-mxq.dtb then the dtb i posted rename armbian_first_run.txt.template to armbian_first_run.txt, tried with no edit first but can’t see the box on my router and then: FR_general_delete_this_file_after_completion=1 FR_net_change_defaults=1 FR_net_ethernet_enabled=1 FR_net_wifi_enabled=0 FR_net_use_static=1 FR_net_static_ip='192.168.1.89' FR_net_static_mask='255.255.255.0' FR_net_static_gateway='192.168.1.1' FR_net_static_dns=‘192.168.1.1' #2 entries max, seperated by a space. but box not listed in router, tried with ping, ssh, no luck the monitor on hdmi port keeps telling me wrong refresh rate 32-30 MHz Change VMODE=1080P50HZ and #VMODE=1080P in uEnv.txt Every day i’ve tried somnting else and stil in the dark. don't know what to do.
SteeMan Posted January 4, 2021 Posted January 4, 2021 Interesting history. To get any further on this I am going to recommend that you need to be able to see the boot loader messages on the serial console. Which would entail identifying the proper pins on the board and connecting a serial terminal to them.
horiatm Posted January 6, 2021 Author Posted January 6, 2021 Out off the Dark With help I was able to connect UART and get the log. I found a image that booted all the way, Armbian_5.44_S812_Debian_stretch_3.10.108_xfce_20180521.img from https://yadi.sk/d/QCGU0PIv3G5kEa/OLD/5.44 with my dtb that I've posted in my first post. The desktop is very laggy and i think drivers are not ok. after that i've tried to boot with Armbian_21.02.0-trunk_Aml-s812_buster_current_5.10.0_xfce_desktop.img with my dtb, it hang's at strating kernel and with meson8-minix-neo-x8.dtb hang's after starting kernel. my uart log: Spoiler EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102623 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 18 -> 28 DC02 v:1150, 0x[37]: 18 -> 2c DC03 v:1500, 0x[38]: 38 -> 48 LDO01 v:2900, 0x[4c]: 4e -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12093 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489212 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x1d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 76 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=charging TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: ATran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 31715229696 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 1706 bytes read ## Executing script at 11000000 ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** reading uInitrd 3265095 bytes read reading uImage 6006126 bytes read reading dtb.img 21708 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux-3.10.108 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 6006062 Bytes = 5.7 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3265031 Bytes = 3.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 12223438 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5327001 Loading Ramdisk to 05009000, end 05326207 ... OK Loading Device Tree to 05000000, end 050084cb ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Tue May 22 12:53:17 MSK 2018 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is d9fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x0d9fffff, size: 122 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(high) : 0x79f00000 - 0x7df00000 ( 64 MiB) [ 0.000000@0] ppmgr0(high) : 0x77f00000 - 0x79f00000 ( 32 MiB) [ 0.000000@0] vdin00(low) : 0x09a00000 - 0x0aa00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x0aa00000 - 0x0ba00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x0ba00000 - 0x0d200000 ( 24 MiB) [ 0.000000@0] amvideocap0(low) : 0x0d200000 - 0x0da00000 ( 8 MiB) [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 8 pages/cpu @c1d42000 s8512 r8192 d16064 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 454416 [ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootfstype=ext4 rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=AE:9E:BA:9B:60:CB logo=osd1,loaded,0x7900000,1080p,full [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:15 [ 0.000000@0] full:2 [ 0.000000@0] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000@0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000@0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Memory: 64MB 16MB 1701MB = 1781MB total [ 0.000000@0] Memory: 1789612k/1789612k available, 34132k reserved, 1184768K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc0aeacc0 (11148 kB) [ 0.000000@0] .init : 0xc0aeb000 - 0xc0b24140 ( 229 kB) [ 0.000000@0] .data : 0xc0b26000 - 0xc0b8c0b8 ( 409 kB) [ 0.000000@0] .bss : 0xc0b8c0b8 - 0xc0e2e1b0 (2697 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [tty0] enabled [ 0.000000@0] console [ttyS0] enabled [ 0.336508@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.346805@0] pid_max: default: 32768 minimum: 301 [ 0.351691@0] Security Framework initialized [ 0.355824@0] SELinux: Initializing. [ 0.359539@0] Mount-cache hash table entries: 512 [ 0.367578@0] Initializing cgroup subsys debug [ 0.368565@0] Initializing cgroup subsys freezer [ 0.373231@0] CPU: Testing write buffer coherency: ok [ 0.378490@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.384053@0] Setting up static identity map for 0xc07f2108 - 0xc07f2160 [ 0.390784@0] L310 cache controller enabled [ 0.394826@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.402400@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.410519@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.490136@0] write pen_release: 1 [ 0.490406@1] CPU1: Booted secondary processor [ 0.490421@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.510133@0] write pen_release: 2 [ 0.518367@2] CPU2: Booted secondary processor [ 0.518381@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.530134@0] write pen_release: 3 [ 0.538368@3] CPU3: Booted secondary processor [ 0.538382@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.538448@0] Brought up 4 CPUs [ 0.551491@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.557721@0] CPU: All CPU(s) started in SVC mode. [ 0.562967@0] devtmpfs: initialized [ 0.570144@0] clkrate [ xtal ] : 24000000 [ 0.570179@0] clkrate [ pll_sys ] : 1200000000 [ 0.574538@0] clkrate [ pll_fixed ] : 2550000000 [ 0.579219@0] clkrate [ pll_vid ] : 366000000 [ 0.583647@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.589793@0] clkrate [ pll_hpll ] : 0 [ 0.593613@0] clkrate [ pll_ddr ] : 0 [ 0.597336@0] clkrate [ a9_clk ] : 1200000000 [ 0.601762@0] clkrate [ clk81 ] : 141666666 [ 0.606230@0] xor: measuring software checksum speed [ 0.710011@0] arm4regs : 1610.400 MB/sec [ 0.810011@0] 8regs : 1260.000 MB/sec [ 0.910012@0] 32regs : 1297.600 MB/sec [ 0.910044@0] xor: using function: arm4regs (1610.400 MB/sec) [ 0.914455@0] pinctrl core: initialized pinctrl subsystem [ 0.919964@0] regulator-dummy: no parameters [ 0.924228@0] NET: Registered protocol family 16 [ 0.933913@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.936474@0] VPU driver version: v03 [ 0.939417@0] vpu driver detect cpu type: m8 [ 0.943693@0] load vpu_clk in dts: 364300000Hz(7) [ 0.948356@0] vpu_probe OK [ 0.952716@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.956757@0] register lm device lm-root [ 0.960512@0] register lm device lm1 [ 0.964054@0] register lm device lm0 [ 0.967710@0] Init pinux probe! [ 0.971192@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.976446@0] tv_init_module [ 0.979295@0] major number 254 for disp [ 0.983113@0] vout_register_server [ 0.986485@0] register tv module server ok [ 0.990603@0] aml_i2c version: 20140813 [ 0.994481@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef354ca8) [ 1.000452@0] aml-i2c i2c-AO: aml i2c bus driver. [ 1.005195@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef3550a8) [ 1.011112@0] aml-i2c i2c-A: aml i2c bus driver. [ 1.015778@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3554a8) [ 1.021688@0] aml-i2c i2c-B: aml i2c bus driver. [ 1.026344@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3558a8) [ 1.032263@0] aml-i2c i2c-C: aml i2c bus driver. [ 1.036900@0] aml_pmu_init, 458 [ 1.039982@0] call aml_dvfs_init in [ 1.043599@0] hdmitx: system: amhdmitx_init [ 1.047596@0] hdmitx: system: Ver: 2014May6 [ 1.051820@0] hdmitx: system: amhdmitx_probe [ 1.056127@0] hdmitx: system: not find ao cec [ 1.060346@0] hdmitx: system: not find vend_init_data [ 1.065408@0] hdmitx: system: gate/pwr cmd: 7 [ 1.069702@0] hdmitx: system: ALREADY init VIC = 16 [ 1.074561@0] hdmitx: system: gate/pwr cmd: 0 [ 1.079278@1] hdmitx: system: reset intr mask [ 1.100444@0] hdmitx: system: irq 1 [ 1.101708@0] bio: create slab <bio-0> at 0 [ 1.210764@1] hdmitx: system: gate/pwr cmd: 4 [ 1.270193@0] raid6: int32x1 197 MB/s [ 1.420686@1] hdmitx: system: gate/pwr cmd: 5 [ 1.420719@1] hdmitx: edid: edid ready [ 1.423133@1] hdmitx: system: gate/pwr cmd: 4 [ 1.440233@0] raid6: int32x2 273 MB/s [ 1.610179@0] raid6: int32x4 342 MB/s [ 1.630688@1] hdmitx: system: gate/pwr cmd: 5 [ 1.630720@1] hdmitx: edid: edid ready [ 1.633137@1] hdmitx: edid: check sum valid [ 1.637295@1] hdmitx: edid: check sum valid [ 1.641464@1] hdmitx: edid: blk0 raw data [ 1.645443@1] 00ffffffffffff001e6dac59010101010516010380331d78ea6275a3554fa027 [ 1.652638@1] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.659832@1] 4500fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.667027@1] 34454135330a202020202020000000ff000a2020202020202020202020200106 [ 1.674221@1] [ 1.675869@1] hdmitx: edid: blk1 raw data [ 1.679856@1] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 1.687050@1] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 1.694245@1] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 1.701440@1] 22110000180000000000000000000000000000000000000000000000000000e6 [ 1.708634@1] [ 1.710669@1] hdmitx: edid: find IEEEOUT [ 1.714210@1] hdmitx: video: cann't get valid mode [ 1.718951@1] hdmitx: audio: audio channel num is 0 [ 1.723816@1] hdmitx: audio: SPDIF [ 1.727193@1] hdmitx: audio: current VIC: 16 [ 1.731439@1] hdmitx: audio: audio sample rate: 0 [ 1.736113@1] hdmitx: audio: set audio N para [ 1.740460@1] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 1.748683@1] pgd = c0004000 [ 1.751549@1] [00000000] *pgd=00000000 [ 1.755273@1] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 1.760731@1] Modules linked in: [ 1.763942@1] CPU: 1 PID: 31 Comm: kthread_hdmi Not tainted 3.10.108-vegas812 #1 [ 1.771308@1] task: ef2d8cc0 ti: ef36a000 task.ti: ef36a000 [ 1.776863@1] PC is at hdmitx_set_audmode+0x330/0x788 [ 1.780139@0] raid6: int32x8 346 MB/s [ 1.780142@0] raid6: using algorithm int32x8 (346 MB/s) [ 1.780144@0] raid6: using intx1 recovery algorithm [ 1.780340@0] SCSI subsystem initialized [ 1.780452@0] usbcore: registered new interface driver usbfs [ 1.780479@0] usbcore: registered new interface driver hub [ 1.810840@1] LR is at _raw_spin_unlock_irqrestore+0x28/0x48 [ 1.816470@1] pc : [<c002370c>] lr : [<c07f1b80>] psr: 80000113 [ 1.816470@1] sp : ef36bea8 ip : ffbf6cff fp : 00000001 [ 1.828257@1] r10: 00000000 r9 : 14001000 r8 : 00003000 [ 1.833632@1] r7 : 00000000 r6 : c0e1e3e8 r5 : c0e1ecb8 r4 : c0b47fb8 [ 1.840306@1] r3 : 00000000 r2 : 00000001 r1 : 00007b20 r0 : 00000000 [ 1.846982@1] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 1.854436@1] Control: 10c5387d Table: 0020404a DAC: 00000015 [ 1.860329@1] [ 1.860329@1] PC: 0xc002368c: [ 1.864923@1] 368c e3a0005d eb000a71 e3c01030 e3a0005d e3811020 eb000a85 ea000011 e3a0005d [ 1.873244@1] 36ac eb000a6a e3c01030 e3a0005d e3811010 eb000a7e ea00000a e3a0005d eb000a63 [ 1.881566@1] 36cc e3801030 e3a0005d eb000a78 ea000004 e3a0005d eb000a5d e3c01030 e3a0005d [ 1.889887@1] 36ec eb000a72 e5953000 e353000a 0a000001 e353000b 1a000000 e1a08108 e3071b20 [ 1.898209@1] 370c e5970000 e3a02009 e34c109c eb0ffb56 e3500000 e6ef1078 030c3808 034c30b8 [ 1.906530@1] 372c e3a0001c 05838404 e3a07a05 eb000a5f e7e71458 e3a0001d eb000a5c e7e31858 [ 1.914852@1] 374c e3a0001e e3811030 e34f7e10 eb000a57 e3a0005d eb000a3d e3801001 e3a0005d [ 1.923173@1] 376c eb000a52 e5d42000 e3a03000 e1520003 03a08002 13a08001 e58734a8 f57ff05f [ 1.931496@1] [ 1.931496@1] LR: 0xc07f1b00: [ 1.936089@1] 1b00 e5930000 e7e000d0 e3500000 1afffff3 e8bd8070 e92d4010 f57ff05f e1d030b0 [ 1.944410@1] 1b20 e2833001 e1c030b0 f57ff04f e320f004 e3a00001 ebe181dc e1a0300d e3c33d7f [ 1.952732@1] 1b40 e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc70 e92d4010 f57ff05f [ 1.961053@1] 1b60 e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e3a00001 ebe181ca [ 1.969375@1] 1b80 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc5e [ 1.977696@1] 1ba0 e92d4010 f57ff05f e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080 [ 1.986018@1] 1bc0 e3a00001 ebe181b8 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 [ 1.994339@1] 1be0 e8bd4010 eafffc4c e92d4070 e1a04000 e3a00001 ebe18171 e1943f9f e3a05000 [ 2.002661@1] [ 2.002661@1] SP: 0xef36be28: [ 2.007255@1] be28 00000000 00000000 00000000 00000000 c0b8ef04 0000001f 0000003c 00000000 [ 2.015577@1] be48 c002370c 80000113 ffffffff ef36be94 00003000 c000da58 00000000 00007b20 [ 2.023898@1] be68 00000001 00000000 c0b47fb8 c0e1ecb8 c0e1e3e8 00000000 00003000 14001000 [ 2.032220@1] be88 00000000 00000001 ffbf6cff ef36bea8 c07f1b80 c002370c 80000113 ffffffff [ 2.040541@1] bea8 c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 c0e1ecb8 15000013 [ 2.048862@1] bec8 14001000 00000000 00000001 c06525a0 00000000 00000000 00000000 00000000 [ 2.057184@1] bee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.065506@1] bf08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.073828@1] [ 2.073828@1] IP: 0xffbf6c7f: [ 2.078421@1] 6c7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.086743@1] 6c9c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.095064@1] 6cbc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.103386@1] 6cdc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.111707@1] 6cfc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.120029@1] 6d1c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.128350@1] 6d3c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.136672@1] 6d5c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.144993@1] 6d7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.153315@1] [ 2.153315@1] R4: 0xc0b47f38: [ 2.157909@1] 7f38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.166231@1] 7f58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 fe1080b0 [ 2.174552@1] 7f78 fe1080b4 fe1080b8 fe1080bc fe1080c0 fe1080c4 fe1080c8 fe1080cc fe1080d0 [ 2.182873@1] 7f98 fe1080d4 fe600014 00000001 00000000 c0b47fa8 c0b47fa8 00000000 00000000 [ 2.191195@1] 7fb8 00004901 00000001 00000101 00000001 00000001 00001b8d 00004040 00001c3a [ 2.199516@1] 7fd8 00000112 00001c3b 00000892 00001c3c 00000029 00001c3d 00000461 00001c30 [ 2.207838@1] 7ff8 00000052 00001c31 0000007e 00001c32 00000000 00001c34 00000005 00001c36 [ 2.216159@1] 8018 00000052 00001c38 00000052 00001c51 00000000 00001b62 0000809d 00000000 [ 2.224482@1] [ 2.224482@1] R5: 0xc0e1ec38: [ 2.229075@1] ec38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.237397@1] ec58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.245718@1] ec78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.254040@1] ec98 00000000 00000000 00000000 00000000 00000000 00000006 00000000 0000000a [ 2.262361@1] ecb8 00000000 00000000 00000000 00000000 00000000 00001000 00010001 00000000 [ 2.270683@1] ecd8 00000000 00000001 00000001 00000002 00000001 00000001 00003f03 00000000 [ 2.279004@1] ecf8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.287326@1] ed18 00000000 00000000 00000000 00000000 00000040 00000000 00000005 6f010001 [ 2.295648@1] [ 2.295648@1] R6: 0xc0e1e368: [ 2.300241@1] e368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.308563@1] e388 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.316884@1] e3a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.325206@1] e3c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.333527@1] e3e8 00000000 c0e1e3ec c0e1e3ec 00000000 00000000 c0b4e794 00000000 00000001 [ 2.341849@1] e408 00000001 00000000 c08b1078 c0e1e414 c0e1e414 0fd00000 00000020 00000000 [ 2.350170@1] e428 ef2d8cc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.358492@1] e448 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.366815@1] Process kthread_hdmi (pid: 31, stack limit = 0xef36a238) [ 2.373316@1] Stack: (0xef36bea8 to 0xef36c000) [ 2.377826@1] bea0: c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 [ 2.386148@1] bec0: c0e1ecb8 15000013 14001000 00000000 00000001 c06525a0 00000000 00000000 [ 2.394469@1] bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.402790@1] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.411112@1] bf20: 00000000 00000000 c0e1e3e8 c0e1e3e8 c0e1e3e8 c0b7ce34 13000002 c0651dd4 [ 2.419433@1] bf40: ef2d8cc0 ef279df0 00000000 c0e1e3e8 c0651970 00000000 00000000 00000000 [ 2.427755@1] bf60: 00000000 c0049920 ffffffff 00000000 ffffffff c0e1e3e8 00000000 00000000 [ 2.436077@1] bf80: ef36bf80 ef36bf80 00000000 00000000 ef36bf90 ef36bf90 ef36bfac ef279df0 [ 2.444398@1] bfa0: c0049870 00000000 00000000 c000df80 00000000 00000000 00000000 00000000 [ 2.452719@1] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.461041@1] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff [ 2.469377@1] [<c002370c>] (hdmitx_set_audmode+0x330/0x788) from [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) [ 2.479076@1] [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) from [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) [ 2.488613@1] [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) from [<c0049920>] (kthread+0xb0/0xb8) [ 2.497280@1] [<c0049920>] (kthread+0xb0/0xb8) from [<c000df80>] (ret_from_fork+0x14/0x34) [ 2.505510@1] Code: e353000b 1a000000 e1a08108 e3071b20 (e5970000) [ 2.511807@1] ---[ end trace b6fde6707b293155 ]--- [ 2.511833@0] usbcore: registered new device driver usb [ 2.511888@0] pps_core: LinuxPPS API ver. 1 registered [ 2.511890@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.511898@0] PTP clock support registered [ 2.512057@0] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 2.512062@0] TV mode 1080p selected. [ 2.512066@0] already display in uboot [ 2.512068@0] vinfo mode is: 1080p [ 2.513988@0] call aml_pmu_probe_init in [ 2.514040@0] aml_pmus_probe, child name:rn5t618 [ 2.514043@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 2.514311@0] board_has_battery:false [ 2.514317@0] [DVFS]aml_dvfs_register_driver, driver rn5t618-dvfs regist success, mask:7, source id:1 [ 2.514320@0] [RN5T618]ricoh_pmu_probe, 287 [ 2.515112@0] [RN5T618]coulomb_flag:0x00 [ 2.515114@0] [RN5T618]no saved coulomb counter [ 2.515146@0] ricoh_pmu_probe, 302 [ 2.515150@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 2.515358@0] Advanced Linux Sound Architecture Driver Initialized. [ 2.614095@0] Switching to clocksource Timer-E [ 2.618269@0] FS-Cache: Loaded [ 2.625116@0] NET: Registered protocol family 2 [ 2.626114@0] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 2.632944@0] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 2.639523@0] TCP: Hash tables configured (established 8192 bind 8192) [ 2.645967@0] TCP: reno registered [ 2.649324@0] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 2.655399@0] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 2.662038@0] NET: Registered protocol family 1 [ 2.666556@0] RPC: Registered named UNIX socket transport module. [ 2.672467@0] RPC: Registered udp transport module. [ 2.677311@0] RPC: Registered tcp transport module. [ 2.682175@0] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.688815@0] wifi_dev_probe [ 2.691616@0] wifi_dt : interrupt_pin=GPIOX_21 [ 2.696042@0] wifi_dt : irq_num=null [ 2.699598@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 2.704703@0] wifi_dt : power_on_pin=GPIOAO_6 [ 2.709058@0] wifi_dt : power_on_pin2=GPIOX_11 [ 2.713465@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 2.722495@0] Unpacking initramfs... [ 2.846571@0] Freeing initrd memory: 3188K [ 2.847256@0] audit: initializing netlink socket (disabled) [ 2.850656@0] type=2000 audit(2.750:1): initialized [ 2.856021@0] bounce pool size: 64 pages [ 2.863676@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.865473@0] exFAT: Core Version 1.2.4 [ 2.869166@0] exFAT: FS Version 1.2.4 [ 2.873440@0] NFS: Registering the id_resolver key type [ 2.878010@0] Key type id_resolver registered [ 2.882454@0] Key type id_legacy registered [ 2.886807@0] NTFS driver 2.1.30 [Flags: R/O]. [ 2.891189@0] fuse init (API version 7.22) [ 2.895431@0] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.905315@0] SGI XFS with security attributes, large block/inode numbers, no debug enabled [ 2.909372@0] bio: create slab <bio-1> at 1 [ 2.912940@0] Btrfs loaded [ 2.915144@0] msgmni has been set to 1187 [ 2.919030@0] SELinux: Registering netfilter hooks [ 2.925032@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.931409@0] io scheduler noop registered [ 2.935457@0] io scheduler deadline registered [ 2.939902@0] io scheduler cfq registered (default) [ 2.944741@0] io scheduler fiops registered [ 2.951136@0] loop: module loaded [ 2.952614@0] tun: Universal TUN/TAP device driver, 1.6 [ 2.957388@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.964082@0] PPP generic driver version 2.4.2 [ 2.968228@0] PPP BSD Compression module registered [ 2.972990@0] PPP Deflate Compression module registered [ 2.978212@0] PPP MPPE Compression module registered [ 2.983133@0] NET: Registered protocol family 24 [ 2.987764@0] usbcore: registered new interface driver asix [ 2.993329@0] usbcore: registered new interface driver ax88179_178a [ 2.999548@0] usbcore: registered new interface driver cdc_ether [ 3.005517@0] usbcore: registered new interface driver dm9601 [ 3.011250@0] usbcore: registered new interface driver net1080 [ 3.017049@0] usbcore: registered new interface driver cdc_subset [ 3.023120@0] usbcore: registered new interface driver zaurus [ 3.028863@0] usbcore: registered new interface driver cdc_ncm [ 3.034641@0] usbcore: registered new interface driver qf9700 [ 3.040372@0] usbcore: registered new interface driver sr9600 [ 3.046156@0] usbcore: registered new interface driver cdc_acm [ 3.051880@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.060058@0] usbcore: registered new interface driver usb-storage [ 3.066337@0] mousedev: PS/2 mouse device common for all mice [ 3.072084@0] usbcore: registered new interface driver xpad [ 3.077464@0] usbcore: registered new interface driver usb_acecad [ 3.083549@0] usbcore: registered new interface driver aiptek [ 3.089263@0] usbcore: registered new interface driver gtco [ 3.094807@0] usbcore: registered new interface driver hanwang [ 3.100622@0] usbcore: registered new interface driver kbtab [ 3.106241@0] usbcore: registered new interface driver wacom [ 3.111935@0] i2c /dev entries driver [ 3.115920@0] device-mapper: uevent: version 1.0.3 [ 3.120433@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 3.129211@0] hidraw: raw HID events driver (C) Jiri Kosina [ 3.134524@0] usbcore: registered new interface driver usbhid [ 3.140124@0] usbhid: USB HID core driver [ 3.144378@0] zram: Created 1 device(s) ... [ 3.148493@0] ashmem: initialized [ 3.151644@0] logger: created 256K log 'log_main' [ 3.156313@0] logger: created 256K log 'log_events' [ 3.161181@0] logger: created 256K log 'log_radio' [ 3.165940@0] logger: created 256K log 'log_system' [ 3.170733@0] vout_init_module [ 3.173788@0] start init vout module [ 3.177321@0] create vout attribute ok [ 3.181202@0] ge2d_init [ 3.183544@0] ge2d_dev major:244 [ 3.186840@0] ge2d start monitor [ 3.190014@0] osd_init [ 3.190020@1] ge2d workqueue monitor start [ 3.196403@0] osd_probe, vinfo:c0855140 [ 3.200361@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 3.208344@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.213884@0] init fbdev bpp is :32 [ 3.217347@0] ---------------clear framebuffer0 memory [ 3.268449@0] Console: switching to colour frame buffer device 240x67 [ 3.294951@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0a00000, size=1024K [ 3.299542@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.305078@0] don't find to display_size_default from mesonfb-dts [ 3.311154@0] init fbdev bpp is :24 [ 3.328210@0] osd probe ok [ 3.328360@0] enter aml_sysled_init [ 3.329053@0] DI: di_init [ 3.331419@0] DI: di_probe [ 3.334326@0] aml_wdt_driver_init,306 [ 3.337721@0] ** disable watchdog [ 3.341177@0] keys=========================================== [ 3.346742@0] keys_devno=f100000 [ 3.350052@0] securitykey: device aml_keys created [ 3.354719@0] amlkeys=0 [ 3.357162@0] platform_driver_register--aml_keys_driver-------------------- [ 3.364297@0] set uart_ao pinmux use pinctrl subsystem [ 3.369219@0] P_AO_RTI_PIN_MUX_REG:5860 [ 3.373017@0] start uart_ao_ttyS0:(irq = 122) [ 3.377336@0] register uart_ao ok [ 3.380800@0] set uart_a pinmux use pinctrl subsystem [ 3.385657@0] P_AO_RTI_PIN_MUX_REG:5860 [ 3.389512@0] start uart_a_ttyS1:(irq = 58) [ 3.393632@0] register uart_a ok [ 3.396957@0] start uart_d_ttyS4:(irq = 126) [ 3.401111@0] register uart_d ok [ 3.404369@0] dwc_otg: version 3.10a 12-MAY-2014 [ 3.408934@0] dwc_otg_driver_probe NOT match [ 3.413162@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 3.421750@0] USB (1) use clock source: XTAL input [ 3.447518@0] Core Release: 3.10a [ 3.447600@0] Setting default values for core params [ 3.450224@0] curmode: 1, host_only: 1 [ 3.474386@0] Using Buffer DMA mode [ 3.478477@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.482555@0] Working on port type = HOST [ 3.486646@0] dwc_otg lm1: DWC OTG Controller [ 3.490721@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 3.496432@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 3.501369@0] -------hcd->flags.d32 = 0 [ 3.505344@0] Init: Port Power? op_state=1 [ 3.509301@0] Init1: Power Port (0) [ 3.513307@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.519663@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.527011@0] usb usb1: Product: DWC OTG Controller [ 3.531883@0] usb usb1: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.537846@0] usb usb1: SerialNumber: lm1 [ 3.542248@0] hub 1-0:1.0: USB hub found [ 3.546396@0] hub 1-0:1.0: 1 port detected [ 3.550655@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 3.558416@0] USB (0) use clock source: XTAL input [ 3.584196@0] Core Release: 3.10a [ 3.588503@0] Setting default values for core params [ 3.592865@0] curmode: 1, host_only: 0 [ 3.657293@0] Using Buffer DMA mode [ 3.661668@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.666048@0] Working on port type = OTG [ 3.670380@0] Current port type: SLAVE [ 3.674649@0] dwc_otg lm0: DWC OTG Controller [ 3.678905@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 3.684254@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 3.689222@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.696119@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.703498@0] usb usb2: Product: DWC OTG Controller [ 3.708351@0] usb usb2: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.714321@0] usb usb2: SerialNumber: lm0 [ 3.718676@0] hub 2-0:1.0: USB hub found [ 3.722814@0] hub 2-0:1.0: 1 port detected [ 3.727023@0] Dedicated Tx FIFOs mode [ 3.731247@0] using timer detect id change, ef5e1400 [ 3.735538@0] boot_device_flag : 0 [ 3.739747@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 3.747782@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 3.754648@0] amlnf_phy_init : amlnf init flag 0 [ 3.754673@2] Indeed it is in host mode hprt0 = 00021501 [ 3.764593@0] ######STS IRQ mode for nand driver [ 3.769170@0] NAND device id: ad de 14 a7 42 4a ad de [ 3.774130@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 3.820834@0] AML_NAND_NEW_OOB : new oob [ 3.825199@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 3.831963@0] boot_device_flag = 0 [ 3.839289@0] uncorrect ecc here at page:2048, chip:0 [ 3.843866@0] blk check good but read failed at chip 0 page 2048 [ 3.849782@0] hynix nand get default reg value at blk:8, page:2049 [ 3.857008@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 3.868460@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 3.876331@0] nand shipped bbt at block 0 [ 3.883750@0] uncorrect ecc here at page:2048, chip:0 [ 3.888493@0] nand blk check good but read failed at chip 0 page 2048 [ 3.928149@2] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 3.934002@3] Indeed it is in host mode hprt0 = 00001101 [ 3.939650@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 76 [ 3.948051@0] i=0,register --- nand_key [ 3.952835@0] nand adjust phy offset : block 4 [ 3.957582@0] nand adjust phy offset : block 4 [ 3.962319@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 3.971093@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 3.980630@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 3.991389@0] bad block count = 0 [ 3.991389@0] [ 4.004060@0] bad block count = 0 [ 4.004060@0] [ 4.024778@0] bad block count = 0 [ 4.024778@0] [ 4.033992@0] amlnand_add_nftl: [ 4.038562@0] Creating 1 ntd partitions [ 4.043088@0] block_num 76 [ 4.048835@0] ------init_ntd [ 4.053461@0] ntd: Giving out device 0 to nfcache [ 4.057959@0] Creating 7 ntd partitions [ 4.062495@0] block_num 204 [ 4.070282@0] ntd: Giving out device 1 to nfcode [ 4.074671@0] Creating 1 ntd partitions [ 4.079067@0] block_num 720 [ 4.094908@0] ntd: Giving out device 2 to nfdata [ 4.099538@0] ethernet_driver probe! [ 4.103900@0] Please config phy interface. [ 4.108284@0] Please config savepowermode. [ 4.112627@0] Please config reset_pin_enable. [ 4.116958@0] Please config reset_delay. [ 4.121267@0] Please config reset_pin. [ 4.125511@0] ethernetinit(dbg[c0b77388]=1) [ 4.129788@0] ethernet base addr is fe0c0000 [ 4.133972@0] write mac add to:ee60f5c8: 00 01 23 cd ee af |..#...| [ 4.139309@3] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.139314@3] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.139317@3] usb 1-1: Product: USB2.0 Hub [ 4.139740@3] hub 1-1:1.0: USB hub found [ 4.140009@3] hub 1-1:1.0: 4 ports detected [ 4.170272@0] libphy: AMLMAC MII Bus: probed [ 4.174502@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 4.179295@0] Amlogic A/V streaming port init [ 4.184163@0] buffersize=262144,0,start=0 [ 4.188357@0] Subtitle stbuf alloced at 0xee700000, size = 262144 [ 4.193223@0] changed the (2) buffer size from 0 to 262144 [ 4.198846@0] init vdec memsource 79f00000->7defffff [ 4.203716@0] [tsync_pcr_init]init success. [ 4.207872@0] amvideocap_init_module [ 4.211977@0] amvideocap_probe,amvideocap [ 4.215991@0] amvideocap_dev_register buf:0d200000,size:800000. [ 4.221501@0] regist mpeg12 codec profile [ 4.225503@0] regist mpeg4 codec profile [ 4.229397@0] amvdec_vc1 module init [ 4.233282@0] regist vc1 codec profile [ 4.237092@0] amvdec_h264 module init [ 4.240928@0] regist h264 codec profile [ 4.244622@0] amvdec_h264mvc module init [ 4.248407@0] regist hmvc codec profile [ 4.252057@0] amvdec_h264_4k2k module init [ 4.255761@0] regist h264_4k2k codec profile [ 4.259986@0] amvdec_h265 module init [ 4.263652@0] regist hevc_unsupport codec profile [ 4.268342@0] regist mjpeg codec profile [ 4.272190@0] amvdec_real module init [ 4.275868@0] amvdec_avs module init [ 4.279503@0] amvenc_avc memory resource undefined. [ 4.284240@0] amvenc_avc memory is invaild, probe fail! [ 4.289463@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 4.295922@0] jpegenc module init [ 4.299507@0] picdec buffer size is 4000000 [ 4.303421@0] alloc_keep_buffer keep_y_addr ee200000 [ 4.308280@0] alloc_keep_buffer keep_u_addr ee800000 [ 4.313200@0] alloc_keep_buffer keep_v_addr ee780000 [ 4.318150@0] yaddr=ee200000,u_addr=ee800000,v_addr=ee780000 [ 4.323955@0] create_ge2d_work_queue video task ok [ 4.328903@0] efuse=========================================== [ 4.334513@0] efuse: device efuse created [ 4.338482@0] efuse-------------------------------------------- [ 4.344311@0] SARADC Driver init. [ 4.347943@0] __saradc_probe__ [ 4.498260@0] saradc calibration: ref_val = 508 [ 4.501797@0] saradc calibration: ref_nominal = 512 [ 4.505523@0] saradc calibration: coef = 4064 [ 4.510042@0] ir irblaster probe [ 4.513627@0] Remote Driver [ 4.517152@0] Remote platform_data g_remote_base=fe600580 [ 4.521250@0] set drvdata completed [ 4.524773@0] device_create_file completed [ 4.529316@0] input: aml_keypad as /devices/platform/meson-remote/input/input0 [ 4.536347@0] input_register_device completed [ 4.540776@0] [0xffffff00] = 0x1dd0190 [ 4.544445@0] [0xffffff04] = 0xf800ca [ 4.548101@0] [0xffffff08] = 0x82006e [ 4.551739@0] [0xffffff0c] = 0x3c0030 [ 4.555364@0] [0xffffff10] = 0x30fa0013 [ 4.559194@0] [0xffffff18] = 0x6f19000 [ 4.562914@0] [0xffffff1c] = 0xbe40 [ 4.566372@0] [0x0] = 0xfa00a0 [ 4.569733@0] [0x4] = 0xfa00a0 [ 4.573052@0] [0x8] = 0xfa00a0 [ 4.576348@0] [0xc] = 0x640030 [ 4.579629@0] [0x10] = 0x30fa0013 [ 4.582855@0] [0x18] = 0x961b800 [ 4.586025@0] [0x1c] = 0x9740 [ 4.589166@0] [0x20] = 0x104 [ 4.592233@0] [0x24] = 0x0 [ 4.595237@0] [0x28] = 0x0 [ 4.598189@0] set_remote_mode[69] [ 4.601126@0] remote config major:235 [ 4.604136@0] physical address:0x2e958000 [ 4.607234@0] Meson KeyInput init [ 4.610598@0] GPIO Keypad Driver init. [ 4.614290@0] ==gpio_key_probe== [ 4.617451@0] reg:2620,clearmask=400040,setmask=1 [ 4.622187@0] reg:2622,clearmask=ff0000,set pin=3 [ 4.626867@0] reg:2623,clearmask=7000000,setmask=7 [ 4.631677@0] reg:2620,clearmask=800080,setmask=10001 [ 4.636749@0] reg:2622,clearmask=ff000000,set pin=3 [ 4.641603@0] reg:2623,clearmask=70000000,setmask=7 [ 4.646526@0] power key(116) registed. [ 4.650298@0] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1 [ 4.657636@0] gpio keypad register input device completed. [ 4.663057@0] gpio keypad major:234 [ 4.666586@0] spi_nor_init [ 4.669715@0] amlogic_spi_nor_probe: [ 4.672781@0] amlogic_spi->state_name:default [ 4.677127@0] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 4.684677@0] check_storage_device : spi boot_device_flag : 0 [ 4.690344@0] spi_nor_probe [ 4.693535@0] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 4.699422@0] Creating 2 MTD partitions on "apollospi:32766": [ 4.704554@0] 0x000000000000-0x000000100000 : "bootloader" [ 4.710503@0] 0x000000100000-0x000000110000 : "ubootenv" [ 4.715710@0] amlogic_spi_nor_probe over [ 4.719334@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 4.728753@0] host->base fe108c20 [ 4.732151@0] pdata->caps 7 [ 4.735469@0] pdata->caps2 0 [ 4.738752@0] get property: port, value:0x00000001 [ 4.744073@0] get property: ocr_avail, value:0x00200000 [ 4.750598@0] get property: f_min, value:0x000493e0 [ 4.757075@0] get property: f_max, value:0x02faf080 [ 4.763602@0] get property: max_req_size, value:0x00020000 [ 4.770093@0] get property: irq_in, value:0x00000003 [ 4.776579@0] get property: irq_out, value:0x00000005 [ 4.783104@0] get property: gpio_cd, str:CARD_6 [ 4.789078@0] get property: gpio_ro, str:GPIOZ_0 [ 4.795137@0] get property: pinname, str:sd [ 4.800779@0] get property: jtag_pin, str:CARD_0 [ 4.806745@0] get property: card_type, value:0x00000005 [ 4.813266@0] get property: gpio_dat3, str:CARD_4 [ 4.819257@0] normal card in [ 4.858167@3] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 4.858175@0] reg:2620,clearmask=80008,setmask=10001 [ 4.858178@0] reg:2621,clearmask=ff000000,set pin=64 [ 4.858180@0] reg:2623,clearmask=7000,setmask=7 [ 4.858182@0] reg:2620,clearmask=200020,setmask=1 [ 4.858185@0] reg:2622,clearmask=ff00,set pin=64 [ 4.858187@0] reg:2623,clearmask=700000,setmask=7 [ 4.858318@0] pdata->caps 107 [ 4.858320@0] pdata->caps2 0 [ 4.858323@0] get property: port, value:0x00000000 [ 4.858326@0] get property: ocr_avail, value:0x00200000 [ 4.858328@0] get property: f_min, value:0x000493e0 [ 4.858330@0] get property: f_max, value:0x02faf080 [ 4.858333@0] get property: max_req_size, value:0x00020000 [ 4.858338@0] get property: pinname, str:sdio [ 4.858340@0] get property: card_type, value:0x00000003 [ 4.976837@2] sd: new high speed SDHC card at address 0001, clock 35416666, 4-bit-bus-width [ 4.983286@2] mmcblk0: sd:0001 SD32G 29.5 GiB (ro) [ 5.008869@2] mmcblk0: p1 p2 [ 5.068156@0] [aml_sdio_probe] aml_sdio_probe() success! [ 5.072779@0] host->base fe108e00 [ 5.076417@0] pdata->caps 80000547 [ 5.080030@0] pdata->caps2 0 [ 5.083558@0] get property: port, value:0x00000005 [ 5.088011@0] get property: ocr_avail, value:0x00200000 [ 5.094528@0] get property: f_min, value:0x000493e0 [ 5.101039@0] get property: f_max, value:0x05f5e100 [ 5.107515@0] get property: max_req_size, value:0x00020000 [ 5.114040@0] get property: pinname, str:emmc [ 5.119837@0] get property: card_type, value:0x00000001 [ 5.126327@0] get property: gpio_dat3, str:BOOT_3 [ 5.132333@0] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=5 [ 5.178161@2] emmc: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 5.182785@2] aml_emmc_hw_reset 1338 [ 5.194480@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=1, iSTA=0x2, STAT=0xf0003e [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.219588@2] ***********SDHC_REGS*********** [ 5.223905@2] SDHC_ARGU: 0x00000000 [ 5.227812@2] SDHC_SEND: 0x00000241 [ 5.231684@2] SDHC_CTRL: 0xe7ffe000 [ 5.235504@2] SDHC_STAT: 0x00f0003e [ 5.238150@0] [aml_sdhc_probe] aml_sdhc_probe() success! [ 5.238218@0] [dsp]DSP start addr 0xc5e00000 [ 5.238240@0] [dsp]register dsp to char divece(257) [ 5.238446@0] amlogic audio spdif interface device init! [ 5.238502@0] name=nand_key nand_key [ 5.238527@0] pinmux-m8 pinmux: pin BOOT_0 already requested by aml_sdhc.0; cannot claim for nand [ 5.238531@0] pinmux-m8 pinmux: pin-39 (nand) status -22 [ 5.238536@0] pinmux-m8 pinmux: could not request pin 39 on device pinmux [ 5.238538@0] nand_get_chip:160 nand can't get pinctrl [ 5.287278@2] SDHC_CLKC: 0x0002f84d [ 5.291243@2] SDHC_ADDR: 0x2eb80000 [ 5.295187@2] SDHC_PDMA: 0x0c43bcf0 [ 5.299130@2] SDHC_MISC: 0xe0000150 [ 5.303070@2] SDHC_DATA: 0x00000000 [ 5.306986@2] SDHC_ICTL: 0x00003067 [ 5.310904@2] SDHC_ISTA: 0x00000002 [ 5.314804@2] SDHC_SRST: 0x00000000 [ 5.318692@2] SDHC_ESTA: 0x00000000 [ 5.322544@2] SDHC_ENHC: 0x00fe0cff [ 5.326371@2] SDHC_CLK2: 0x00001425 [ 5.330994@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=2, iSTA=0x4002, STAT=0x20 [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.356266@2] ***********SDHC_REGS*********** [ 5.360591@2] SDHC_ARGU: 0x00000000 [ 5.364860@2] SDHC_SEND: 0x00000241 [ 5.369101@2] SDHC_CTRL: 0xe7ffe000 [ 5.373309@2] SDHC_STAT: 0x00000020 [ 5.377516@2] SDHC_CLKC: 0x0002f84d [ 5.381696@2] SDHC_ADDR: 0x2eb80000 [ 5.385882@2] SDHC_PDMA: 0x0c43bcf0 [ 5.390042@2] SDHC_MISC: 0xe0000150 [ 5.394202@2] SDHC_DATA: 0x00000000 [ 5.398363@2] SDHC_ICTL: 0x00003067 [ 5.402517@2] SDHC_ISTA: 0x00004002 [ 5.406662@2] SDHC_SRST: 0x00000000 [ 5.410787@2] SDHC_ESTA: 0x00000000 [ 5.414881@2] SDHC_ENHC: 0x00fe0cff [ 5.418882@2] SDHC_CLK2: 0x00001425 [ 5.423598@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=3, iSTA=0x4002, STAT=0x20 [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.448998@2] ***********SDHC_REGS*********** [ 5.453398@2] SDHC_ARGU: 0x00000000 [ 5.457793@2] SDHC_SEND: 0x00000241 [ 5.462191@2] SDHC_CTRL: 0xe7ffe000 [ 5.466550@2] SDHC_STAT: 0x00000020 [ 5.470912@2] SDHC_CLKC: 0x0002f84d [ 5.475262@2] SDHC_ADDR: 0x2eb80000 [ 5.479621@2] SDHC_PDMA: 0x0c43bcf0 [ 5.483963@2] SDHC_MISC: 0xe0000150 [ 5.488290@2] SDHC_DATA: 0x00000000 [ 5.492586@2] SDHC_ICTL: 0x00003067 [ 5.496857@2] SDHC_ISTA: 0x00004002 [ 5.501065@2] SDHC_SRST: 0x00000000 [ 5.505195@2] SDHC_ESTA: 0x00000000 [ 5.509258@2] SDHC_ENHC: 0x00fe0cff [ 5.513088@2] SDHC_CLK2: 0x00001425 [ 5.517481@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=4, iSTA=0x4002, STAT=0x20 [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.542459@2] ***********SDHC_REGS*********** [ 5.546777@2] SDHC_ARGU: 0x00000000 [ 5.550834@2] SDHC_SEND: 0x00000241 [ 5.554880@2] SDHC_CTRL: 0xe7ffe000 [ 5.558887@2] SDHC_STAT: 0x00000020 [ 5.562843@2] SDHC_CLKC: 0x0002f84d [ 5.566771@2] SDHC_ADDR: 0x2eb80000 [ 5.570669@2] SDHC_PDMA: 0x0c43bcf0 [ 5.574522@2] SDHC_MISC: 0xe0000150 [ 5.578290@2] SDHC_DATA: 0x00000000 [ 5.581979@2] SDHC_ICTL: 0x00003067 [ 5.585626@2] SDHC_ISTA: 0x00004002 [ 5.589216@2] SDHC_SRST: 0x00000000 [ 5.592750@2] SDHC_ESTA: 0x00000000 [ 5.596273@2] SDHC_ENHC: 0x00fe0cff [ 5.599799@2] SDHC_CLK2: 0x00001425 [ 5.604345@2] emmc: mmc_rescan_try_freq: trying to init card at 300000 Hz [ 5.648141@2] aml_emmc_hw_reset 1338 [ 5.660236@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=1, iSTA=0x2, STAT=0xf0003e [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.685533@2] ***********SDHC_REGS*********** [ 5.689858@2] SDHC_ARGU: 0x00000000 [ 5.694185@2] SDHC_SEND: 0x00000241 [ 5.698515@2] SDHC_CTRL: 0xe7ffe000 [ 5.702616@2] SDHC_STAT: 0x00f0003e [ 5.706470@2] SDHC_CLKC: 0x0002fb11 [ 5.710193@2] SDHC_ADDR: 0x2eb80000 [ 5.713884@2] SDHC_PDMA: 0x0c43bcf0 [ 5.717578@2] SDHC_MISC: 0xe0000150 [ 5.721278@2] SDHC_DATA: 0x00000000 [ 5.724966@2] SDHC_ICTL: 0x00003067 [ 5.728655@2] SDHC_ISTA: 0x00000002 [ 5.732331@2] SDHC_SRST: 0x00000000 [ 5.736000@2] SDHC_ESTA: 0x00000000 [ 5.739665@2] SDHC_ENHC: 0x00fe0cff [ 5.743327@2] SDHC_CLK2: 0x00001425 [ 5.748064@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=2, iSTA=0x2, STAT=0xf0003e [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.773363@2] ***********SDHC_REGS*********** [ 5.777681@2] SDHC_ARGU: 0x00000000 [ 5.782017@2] SDHC_SEND: 0x00000241 [ 5.786346@2] SDHC_CTRL: 0xe7ffe000 [ 5.790458@2] SDHC_STAT: 0x00f0003e [ 5.794320@2] SDHC_CLKC: 0x0002fb11 [ 5.798044@2] SDHC_ADDR: 0x2eb80000 [ 5.801747@2] SDHC_PDMA: 0x0c43bcf0 [ 5.805455@2] SDHC_MISC: 0xe0000150 [ 5.809169@2] SDHC_DATA: 0x00000000 [ 5.812871@2] SDHC_ICTL: 0x00003067 [ 5.816567@2] SDHC_ISTA: 0x00000002 [ 5.820261@2] SDHC_SRST: 0x00000000 [ 5.823943@2] SDHC_ESTA: 0x00000000 [ 5.827612@2] SDHC_ENHC: 0x00fe0cff [ 5.831290@2] SDHC_CLK2: 0x00001425 [ 5.836034@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=3, iSTA=0x2, STAT=0xf0003e [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.861343@2] ***********SDHC_REGS*********** [ 5.865671@2] SDHC_ARGU: 0x00000000 [ 5.870016@2] SDHC_SEND: 0x00000241 [ 5.874352@2] SDHC_CTRL: 0xe7ffe000 [ 5.878473@2] SDHC_STAT: 0x00f0003e [ 5.882344@2] SDHC_CLKC: 0x0002fb11 [ 5.886076@2] SDHC_ADDR: 0x2eb80000 [ 5.889788@2] SDHC_PDMA: 0x0c43bcf0 [ 5.893499@2] SDHC_MISC: 0xe0000150 [ 5.897208@2] SDHC_DATA: 0x00000000 [ 5.900924@2] SDHC_ICTL: 0x00003067 [ 5.904634@2] SDHC_ISTA: 0x00000002 [ 5.908337@2] SDHC_SRST: 0x00000000 [ 5.912025@2] SDHC_ESTA: 0x00000000 [ 5.915703@2] SDHC_ENHC: 0x00fe0cff [ 5.919388@2] SDHC_CLK2: 0x00001425 [ 5.924142@2] [aml_sdhc_print_err][0;40;32m emmc: rsp timeout error, port=5, Cmd1 Arg 00000000, xfer_step=3, status=5, cmd25=0, fifo_empty=0, fifo_full=0, timeout=4, iSTA=0x2, STAT=0xf0003e [0mPinmux: REG2=0x0000fc00, REG3=0x00000000, REG4=0x7c003c00, REG5=0x0c000000, REG6=0x00007de0, REG8=0x00000000 [ 5.949461@2] ***********SDHC_REGS*********** [ 5.953799@2] SDHC_ARGU: 0x00000000 [ 5.958158@2] SDHC_SEND: 0x00000241 [ 5.962504@2] SDHC_CTRL: 0xe7ffe000 [ 5.966786@2] SDHC_STAT: 0x00f0003e [ 5.971014@2] SDHC_CLKC: 0x0002fb11 [ 5.975009@2] SDHC_ADDR: 0x2eb80000 [ 5.978764@2] SDHC_PDMA: 0x0c43bcf0 [ 5.982376@2] SDHC_MISC: 0xe0000150 [ 5.985960@2] SDHC_DATA: 0x00000000 [ 5.989549@2] SDHC_ICTL: 0x00003067 [ 5.993127@2] SDHC_ISTA: 0x00000002 [ 5.996696@2] SDHC_SRST: 0x00000000 [ 6.000265@2] SDHC_ESTA: 0x00000000 [ 6.003822@2] SDHC_ENHC: 0x00fe0cff [ 6.007373@2] SDHC_CLK2: 0x00001425 [ 557.224460@0] aml_keys_notify_reboot:1717 [ 557.269766@0] i2c 0-0032: Bus i2c calling i2c_device_shutdown shutdown [ 557.270840@0] i2c i2c-3: Bus i2c calling i2c_device_shutdown shutdown [ 557.277280@0] i2c i2c-2: Bus i2c calling i2c_device_shutdown shutdown [ 557.283707@0] i2c i2c-1: Bus i2c calling i2c_device_shutdown shutdown [ 557.290112@0] i2c i2c-0: Bus i2c calling i2c_device_shutdown shutdown [ 557.296573@0] amlnfdev nand: Driver amlnfdev calling platform_drv_shutdown shutdown [ 557.304172@0] boot_device_flag : 0 [ 557.307603@0] aml_rtc rtc.0: Driver aml_rtc calling platform_drv_shutdown shutdown [ 557.315790@0] Restarting system. [ 557.318241@0] [ 557.319883@0] Restarting Linux version 3.10.105 (dev_user@dev) (gcc version 5.4.0 (Buildroot 2017.02-00100-gc2abd0d-dirty) ) #1 SMP PREEMPT Fri Mar 10 07:36:38 EET 2017 [ 557.319883@0] [ ‡EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102621 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 28 -> 28 DC02 v:1150, 0x[37]: 2c -> 2c DC03 v:1500, 0x[38]: 48 -> 48 LDO01 v:2900, 0x[4c]: 50 -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12100 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489333 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x0d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=normal TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: ATran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 31715229696 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 1706 bytes read ## Executing script at 11000000 ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** reading uInitrd 3265095 bytes read reading uImage 6006126 bytes read reading dtb.img 18432 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux-3.10.108 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 6006062 Bytes = 5.7 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3265031 Bytes = 3.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 12143665 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5326001 Loading Ramdisk to 05008000, end 05325207 ... OK Loading Device Tree to 05000000, end 05007786 ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Tue May 22 12:53:17 MSK 2018 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is 1c1fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x1c1fffff, size: 354 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(low) : 0x09a00000 - 0x19a00000 (256 MiB) [ 0.000000@0] ppmgr0(high) : 0x7cf00000 - 0x7df00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x19a00000 - 0x1aa00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x1aa00000 - 0x1c200000 ( 24 MiB) [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 8 pages/cpu @c1de1000 s8512 r8192 d16064 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 415504 [ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootfstype=ext4 rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=AE:9E:BA:9B:60:CB logo=osd1,loaded,0x7900000,1080p,full [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:15 [ 0.000000@0] full:2 [ 0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000@0] Memory: 64MB 16MB 1549MB = 1629MB total [ 0.000000@0] Memory: 1633724k/1633724k available, 34372k reserved, 1266688K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc0aeacc0 (11148 kB) [ 0.000000@0] .init : 0xc0aeb000 - 0xc0b24140 ( 229 kB) [ 0.000000@0] .data : 0xc0b26000 - 0xc0b8c0b8 ( 409 kB) [ 0.000000@0] .bss : 0xc0b8c0b8 - 0xc0e2e1b0 (2697 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [tty0] enabled [ 0.000000@0] console [ttyS0] enabled [ 0.323696@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.333993@0] pid_max: default: 32768 minimum: 301 [ 0.338862@0] Security Framework initialized [ 0.343035@0] SELinux: Initializing. [ 0.346734@0] Mount-cache hash table entries: 512 [ 0.354261@0] Initializing cgroup subsys debug [ 0.355753@0] Initializing cgroup subsys freezer [ 0.360420@0] CPU: Testing write buffer coherency: ok [ 0.365676@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.371242@0] Setting up static identity map for 0xc07f2108 - 0xc07f2160 [ 0.377950@0] L310 cache controller enabled [ 0.382048@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.389554@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.397707@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.480140@0] write pen_release: 1 [ 0.480416@1] CPU1: Booted secondary processor [ 0.480430@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.500136@0] write pen_release: 2 [ 0.508371@2] CPU2: Booted secondary processor [ 0.508385@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.520135@0] write pen_release: 3 [ 0.528367@3] CPU3: Booted secondary processor [ 0.528383@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.528450@0] Brought up 4 CPUs [ 0.541492@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.547721@0] CPU: All CPU(s) started in SVC mode. [ 0.552963@0] devtmpfs: initialized [ 0.560147@0] clkrate [ xtal ] : 24000000 [ 0.560182@0] clkrate [ pll_sys ] : 1200000000 [ 0.564539@0] clkrate [ pll_fixed ] : 2550000000 [ 0.569219@0] clkrate [ pll_vid ] : 366000000 [ 0.573647@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.579794@0] clkrate [ pll_hpll ] : 0 [ 0.583614@0] clkrate [ pll_ddr ] : 0 [ 0.587336@0] clkrate [ a9_clk ] : 1200000000 [ 0.591762@0] clkrate [ clk81 ] : 141666666 [ 0.596229@0] xor: measuring software checksum speed [ 0.700012@0] arm4regs : 1610.400 MB/sec [ 0.800012@0] 8regs : 1260.000 MB/sec [ 0.900014@0] 32regs : 1302.400 MB/sec [ 0.900047@0] xor: using function: arm4regs (1610.400 MB/sec) [ 0.904457@0] pinctrl core: initialized pinctrl subsystem [ 0.909969@0] regulator-dummy: no parameters [ 0.914223@0] NET: Registered protocol family 16 [ 0.923850@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.926489@0] VPU driver version: v03 [ 0.929419@0] vpu driver detect cpu type: m8 [ 0.933695@0] load vpu_clk in dts: 364300000Hz(7) [ 0.938358@0] vpu_probe OK [ 0.942512@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.946665@0] register lm device lm-root [ 0.950514@0] register lm device lm1 [ 0.954062@0] register lm device lm0 [ 0.957697@0] Init pinux probe! [ 0.961093@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.966445@0] tv_init_module [ 0.969297@0] major number 254 for disp [ 0.973115@0] vout_register_server [ 0.976487@0] register tv module server ok [ 0.980607@0] aml_i2c version: 20140813 [ 0.984478@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef334ca8) [ 0.990454@0] aml-i2c i2c-AO: aml i2c bus driver. [ 0.995202@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef3350a8) [ 1.001115@0] aml-i2c i2c-A: aml i2c bus driver. [ 1.005779@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3354a8) [ 1.011690@0] aml-i2c i2c-B: aml i2c bus driver. [ 1.016347@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3358a8) [ 1.022265@0] aml-i2c i2c-C: aml i2c bus driver. [ 1.026899@0] aml_pmu_init, 458 [ 1.029985@0] call aml_dvfs_init in [ 1.033594@0] hdmitx: system: amhdmitx_init [ 1.037598@0] hdmitx: system: Ver: 2014May6 [ 1.041813@0] hdmitx: system: amhdmitx_probe [ 1.046131@0] hdmitx: system: not find ao cec [ 1.050349@0] hdmitx: system: not find vend_init_data [ 1.055409@0] hdmitx: system: gate/pwr cmd: 7 [ 1.059703@0] hdmitx: system: ALREADY init VIC = 16 [ 1.064563@0] hdmitx: system: gate/pwr cmd: 0 [ 1.069281@1] hdmitx: system: reset intr mask [ 1.090453@0] hdmitx: system: irq 1 [ 1.091543@0] bio: create slab <bio-0> at 0 [ 1.200774@1] hdmitx: system: gate/pwr cmd: 4 [ 1.260043@0] raid6: int32x1 197 MB/s [ 1.410696@1] hdmitx: system: gate/pwr cmd: 5 [ 1.410728@1] hdmitx: edid: edid ready [ 1.413143@1] hdmitx: system: gate/pwr cmd: 4 [ 1.430217@0] raid6: int32x2 273 MB/s [ 1.600186@0] raid6: int32x4 342 MB/s [ 1.620698@1] hdmitx: system: gate/pwr cmd: 5 [ 1.620730@1] hdmitx: edid: edid ready [ 1.623147@1] hdmitx: edid: check sum valid [ 1.627305@1] hdmitx: edid: check sum valid [ 1.631474@1] hdmitx: edid: blk0 raw data [ 1.635453@1] 00ffffffffffff001e6dac59010101010516010380331d78ea6275a3554fa027 [ 1.642648@1] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.649842@1] 4500fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.657037@1] 34454135330a202020202020000000ff000a2020202020202020202020200106 [ 1.664231@1] [ 1.665879@1] hdmitx: edid: blk1 raw data [ 1.669866@1] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 1.677060@1] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 1.684255@1] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 1.691450@1] 22110000180000000000000000000000000000000000000000000000000000e6 [ 1.698644@1] [ 1.700674@1] hdmitx: edid: find IEEEOUT [ 1.704220@1] hdmitx: video: cann't get valid mode [ 1.708961@1] hdmitx: audio: audio channel num is 0 [ 1.713826@1] hdmitx: audio: SPDIF [ 1.717203@1] hdmitx: audio: current VIC: 16 [ 1.721449@1] hdmitx: audio: audio sample rate: 0 [ 1.726123@1] hdmitx: audio: set audio N para [ 1.730470@1] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 1.738693@1] pgd = c0004000 [ 1.741558@1] [00000000] *pgd=00000000 [ 1.745283@1] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 1.750741@1] Modules linked in: [ 1.753952@1] CPU: 1 PID: 31 Comm: kthread_hdmi Not tainted 3.10.108-vegas812 #1 [ 1.761318@1] task: ef2d8cc0 ti: ef36a000 task.ti: ef36a000 [ 1.766873@1] PC is at hdmitx_set_audmode+0x330/0x788 [ 1.770103@0] raid6: int32x8 346 MB/s [ 1.770105@0] raid6: using algorithm int32x8 (346 MB/s) [ 1.770107@0] raid6: using intx1 recovery algorithm [ 1.770307@0] SCSI subsystem initialized [ 1.770419@0] usbcore: registered new interface driver usbfs [ 1.770447@0] usbcore: registered new interface driver hub [ 1.800850@1] LR is at _raw_spin_unlock_irqrestore+0x28/0x48 [ 1.806481@1] pc : [<c002370c>] lr : [<c07f1b80>] psr: 80000113 [ 1.806481@1] sp : ef36bea8 ip : ffbf6cff fp : 00000001 [ 1.818267@1] r10: 00000000 r9 : 14001000 r8 : 00003000 [ 1.823642@1] r7 : 00000000 r6 : c0e1e3e8 r5 : c0e1ecb8 r4 : c0b47fb8 [ 1.830316@1] r3 : 00000000 r2 : 00000001 r1 : 00007b20 r0 : 00000000 [ 1.836992@1] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 1.844446@1] Control: 10c5387d Table: 0020404a DAC: 00000015 [ 1.850339@1] [ 1.850339@1] PC: 0xc002368c: [ 1.854933@1] 368c e3a0005d eb000a71 e3c01030 e3a0005d e3811020 eb000a85 ea000011 e3a0005d [ 1.863254@1] 36ac eb000a6a e3c01030 e3a0005d e3811010 eb000a7e ea00000a e3a0005d eb000a63 [ 1.871575@1] 36cc e3801030 e3a0005d eb000a78 ea000004 e3a0005d eb000a5d e3c01030 e3a0005d [ 1.879897@1] 36ec eb000a72 e5953000 e353000a 0a000001 e353000b 1a000000 e1a08108 e3071b20 [ 1.888219@1] 370c e5970000 e3a02009 e34c109c eb0ffb56 e3500000 e6ef1078 030c3808 034c30b8 [ 1.896540@1] 372c e3a0001c 05838404 e3a07a05 eb000a5f e7e71458 e3a0001d eb000a5c e7e31858 [ 1.904861@1] 374c e3a0001e e3811030 e34f7e10 eb000a57 e3a0005d eb000a3d e3801001 e3a0005d [ 1.913183@1] 376c eb000a52 e5d42000 e3a03000 e1520003 03a08002 13a08001 e58734a8 f57ff05f [ 1.921505@1] [ 1.921505@1] LR: 0xc07f1b00: [ 1.926099@1] 1b00 e5930000 e7e000d0 e3500000 1afffff3 e8bd8070 e92d4010 f57ff05f e1d030b0 [ 1.934420@1] 1b20 e2833001 e1c030b0 f57ff04f e320f004 e3a00001 ebe181dc e1a0300d e3c33d7f [ 1.942742@1] 1b40 e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc70 e92d4010 f57ff05f [ 1.951063@1] 1b60 e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e3a00001 ebe181ca [ 1.959385@1] 1b80 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc5e [ 1.967706@1] 1ba0 e92d4010 f57ff05f e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080 [ 1.976028@1] 1bc0 e3a00001 ebe181b8 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 [ 1.984349@1] 1be0 e8bd4010 eafffc4c e92d4070 e1a04000 e3a00001 ebe18171 e1943f9f e3a05000 [ 1.992671@1] [ 1.992671@1] SP: 0xef36be28: [ 1.997265@1] be28 00000000 00000000 00000000 00000000 c0b8ef04 0000001f 0000003c 00000000 [ 2.005586@1] be48 c002370c 80000113 ffffffff ef36be94 00003000 c000da58 00000000 00007b20 [ 2.013908@1] be68 00000001 00000000 c0b47fb8 c0e1ecb8 c0e1e3e8 00000000 00003000 14001000 [ 2.022229@1] be88 00000000 00000001 ffbf6cff ef36bea8 c07f1b80 c002370c 80000113 ffffffff [ 2.030551@1] bea8 c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 c0e1ecb8 15000013 [ 2.038872@1] bec8 14001000 00000000 00000001 c06525a0 00000000 00000000 00000000 00000000 [ 2.047194@1] bee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.055515@1] bf08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.063838@1] [ 2.063838@1] IP: 0xffbf6c7f: [ 2.068431@1] 6c7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.076753@1] 6c9c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.085074@1] 6cbc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.093396@1] 6cdc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.101717@1] 6cfc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.110039@1] 6d1c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.118360@1] 6d3c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.126682@1] 6d5c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.135003@1] 6d7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.143325@1] [ 2.143325@1] R4: 0xc0b47f38: [ 2.147919@1] 7f38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.156240@1] 7f58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 fe1080b0 [ 2.164562@1] 7f78 fe1080b4 fe1080b8 fe1080bc fe1080c0 fe1080c4 fe1080c8 fe1080cc fe1080d0 [ 2.172883@1] 7f98 fe1080d4 fe600014 00000001 00000000 c0b47fa8 c0b47fa8 00000000 00000000 [ 2.181205@1] 7fb8 00004901 00000001 00000101 00000001 00000001 00001b8d 00004040 00001c3a [ 2.189526@1] 7fd8 00000112 00001c3b 00000892 00001c3c 00000029 00001c3d 00000461 00001c30 [ 2.197848@1] 7ff8 00000052 00001c31 0000007e 00001c32 00000000 00001c34 00000005 00001c36 [ 2.206169@1] 8018 00000052 00001c38 00000052 00001c51 00000000 00001b62 0000809d 00000000 [ 2.214492@1] [ 2.214492@1] R5: 0xc0e1ec38: [ 2.219085@1] ec38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.227407@1] ec58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.235728@1] ec78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.244050@1] ec98 00000000 00000000 00000000 00000000 00000000 00000006 00000000 0000000a [ 2.252371@1] ecb8 00000000 00000000 00000000 00000000 00000000 00001000 00010001 00000000 [ 2.260693@1] ecd8 00000000 00000001 00000001 00000002 00000001 00000001 00003f03 00000000 [ 2.269014@1] ecf8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.277336@1] ed18 00000000 00000000 00000000 00000000 00000040 00000000 00000005 6f010001 [ 2.285658@1] [ 2.285658@1] R6: 0xc0e1e368: [ 2.290251@1] e368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.298573@1] e388 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.306894@1] e3a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.315216@1] e3c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.323537@1] e3e8 00000000 c0e1e3ec c0e1e3ec 00000000 00000000 c0b4e794 00000000 00000001 [ 2.331859@1] e408 00000001 00000000 c08b1078 c0e1e414 c0e1e414 0fd00000 00000020 00000000 [ 2.340180@1] e428 ef2d8cc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.348502@1] e448 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.356825@1] Process kthread_hdmi (pid: 31, stack limit = 0xef36a238) [ 2.363326@1] Stack: (0xef36bea8 to 0xef36c000) [ 2.367836@1] bea0: c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 [ 2.376157@1] bec0: c0e1ecb8 15000013 14001000 00000000 00000001 c06525a0 00000000 00000000 [ 2.384478@1] bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.392800@1] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.401122@1] bf20: 00000000 00000000 c0e1e3e8 c0e1e3e8 c0e1e3e8 c0b7ce34 13000002 c0651dd4 [ 2.409443@1] bf40: ef2d8cc0 ef279df0 00000000 c0e1e3e8 c0651970 00000000 00000000 00000000 [ 2.417765@1] bf60: 00000000 c0049920 00000000 00000000 00000000 c0e1e3e8 00000000 00000000 [ 2.426086@1] bf80: ef36bf80 ef36bf80 00000000 00000000 ef36bf90 ef36bf90 ef36bfac ef279df0 [ 2.434408@1] bfa0: c0049870 00000000 00000000 c000df80 00000000 00000000 00000000 00000000 [ 2.442729@1] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.451050@1] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 2.459387@1] [<c002370c>] (hdmitx_set_audmode+0x330/0x788) from [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) [ 2.469086@1] [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) from [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) [ 2.478623@1] [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) from [<c0049920>] (kthread+0xb0/0xb8) [ 2.487290@1] [<c0049920>] (kthread+0xb0/0xb8) from [<c000df80>] (ret_from_fork+0x14/0x34) [ 2.495519@1] Code: e353000b 1a000000 e1a08108 e3071b20 (e5970000) [ 2.501818@1] ---[ end trace 56292b63f4aaf7b4 ]--- [ 2.501831@0] usbcore: registered new device driver usb [ 2.501890@0] pps_core: LinuxPPS API ver. 1 registered [ 2.501892@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.501904@0] PTP clock support registered [ 2.502048@0] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 2.502052@0] TV mode 1080p selected. [ 2.502056@0] already display in uboot [ 2.502058@0] vinfo mode is: 1080p [ 2.504031@0] call aml_pmu_probe_init in [ 2.504074@0] aml_pmus_probe, child name:rn5t618 [ 2.504077@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 2.504336@0] board_has_battery:false [ 2.504341@0] [DVFS]aml_dvfs_register_driver, driver rn5t618-dvfs regist success, mask:7, source id:1 [ 2.504345@0] [RN5T618]ricoh_pmu_probe, 287 [ 2.505139@0] [RN5T618]coulomb_flag:0x00 [ 2.505140@0] [RN5T618]no saved coulomb counter [ 2.505171@0] ricoh_pmu_probe, 302 [ 2.505176@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 2.505369@0] Advanced Linux Sound Architecture Driver Initialized. [ 2.604107@0] Switching to clocksource Timer-E [ 2.608274@0] FS-Cache: Loaded [ 2.615141@0] NET: Registered protocol family 2 [ 2.616121@0] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 2.622911@0] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.629499@0] TCP: Hash tables configured (established 4096 bind 4096) [ 2.635975@0] TCP: reno registered [ 2.639334@0] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.645317@0] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.651850@0] NET: Registered protocol family 1 [ 2.656393@0] RPC: Registered named UNIX socket transport module. [ 2.662307@0] RPC: Registered udp transport module. [ 2.667147@0] RPC: Registered tcp transport module. [ 2.672009@0] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.678650@0] wifi_dev_probe [ 2.681452@0] wifi_dt : interrupt_pin=GPIOX_21 [ 2.685874@0] wifi_dt : irq_num=null [ 2.689435@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 2.694543@0] wifi_dt : power_on_pin=GPIOAO_6 [ 2.698895@0] wifi_dt : power_on_pin2=GPIOX_11 [ 2.703298@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 2.712319@0] Unpacking initramfs... [ 2.836389@0] Freeing initrd memory: 3188K [ 2.837087@0] audit: initializing netlink socket (disabled) [ 2.840470@0] type=2000 audit(2.750:1): initialized [ 2.845827@0] bounce pool size: 64 pages [ 2.853464@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.855289@0] exFAT: Core Version 1.2.4 [ 2.858990@0] exFAT: FS Version 1.2.4 [ 2.863254@0] NFS: Registering the id_resolver key type [ 2.867828@0] Key type id_resolver registered [ 2.872269@0] Key type id_legacy registered [ 2.876618@0] NTFS driver 2.1.30 [Flags: R/O]. [ 2.881012@0] fuse init (API version 7.22) [ 2.885247@0] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.895031@0] SGI XFS with security attributes, large block/inode numbers, no debug enabled [ 2.899220@0] bio: create slab <bio-1> at 1 [ 2.902736@0] Btrfs loaded [ 2.904968@0] msgmni has been set to 723 [ 2.908761@0] SELinux: Registering netfilter hooks [ 2.914754@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.921135@0] io scheduler noop registered [ 2.925189@0] io scheduler deadline registered [ 2.929638@0] io scheduler cfq registered (default) [ 2.934472@0] io scheduler fiops registered [ 2.940801@0] loop: module loaded [ 2.942337@0] tun: Universal TUN/TAP device driver, 1.6 [ 2.947119@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.953774@0] PPP generic driver version 2.4.2 [ 2.957938@0] PPP BSD Compression module registered [ 2.962735@0] PPP Deflate Compression module registered [ 2.967930@0] PPP MPPE Compression module registered [ 2.972873@0] NET: Registered protocol family 24 [ 2.977497@0] usbcore: registered new interface driver asix [ 2.983057@0] usbcore: registered new interface driver ax88179_178a [ 2.989282@0] usbcore: registered new interface driver cdc_ether [ 2.995251@0] usbcore: registered new interface driver dm9601 [ 3.000979@0] usbcore: registered new interface driver net1080 [ 3.006776@0] usbcore: registered new interface driver cdc_subset [ 3.012855@0] usbcore: registered new interface driver zaurus [ 3.018591@0] usbcore: registered new interface driver cdc_ncm [ 3.024373@0] usbcore: registered new interface driver qf9700 [ 3.030116@0] usbcore: registered new interface driver sr9600 [ 3.035875@0] usbcore: registered new interface driver cdc_acm [ 3.041612@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.049791@0] usbcore: registered new interface driver usb-storage [ 3.056067@0] mousedev: PS/2 mouse device common for all mice [ 3.061812@0] usbcore: registered new interface driver xpad [ 3.067200@0] usbcore: registered new interface driver usb_acecad [ 3.073278@0] usbcore: registered new interface driver aiptek [ 3.078998@0] usbcore: registered new interface driver gtco [ 3.084530@0] usbcore: registered new interface driver hanwang [ 3.090349@0] usbcore: registered new interface driver kbtab [ 3.095977@0] usbcore: registered new interface driver wacom [ 3.101669@0] i2c /dev entries driver [ 3.105653@0] device-mapper: uevent: version 1.0.3 [ 3.110176@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 3.118934@0] hidraw: raw HID events driver (C) Jiri Kosina [ 3.124263@0] usbcore: registered new interface driver usbhid [ 3.129860@0] usbhid: USB HID core driver [ 3.134097@0] zram: Created 1 device(s) ... [ 3.138223@0] ashmem: initialized [ 3.141368@0] logger: created 256K log 'log_main' [ 3.146051@0] logger: created 256K log 'log_events' [ 3.150909@0] logger: created 256K log 'log_radio' [ 3.155669@0] logger: created 256K log 'log_system' [ 3.160468@0] vout_init_module [ 3.163510@0] start init vout module [ 3.167053@0] create vout attribute ok [ 3.170917@0] ge2d_init [ 3.173275@0] ge2d_dev major:244 [ 3.176570@0] ge2d start monitor [ 3.179742@0] osd_init [ 3.179748@1] ge2d workqueue monitor start [ 3.186135@0] osd_probe, vinfo:c0855140 [ 3.190092@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 3.198069@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.203622@0] init fbdev bpp is :32 [ 3.207079@0] ---------------clear framebuffer0 memory [ 3.249069@0] Console: switching to colour frame buffer device 240x67 [ 3.275572@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0a00000, size=1024K [ 3.280164@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.285699@0] don't find to display_size_default from mesonfb-dts [ 3.291775@0] init fbdev bpp is :24 [ 3.308831@0] osd probe ok [ 3.308971@0] enter aml_sysled_init [ 3.309661@0] DI: di_init [ 3.312032@0] DI: di_probe [ 3.314916@0] aml_wdt_driver_init,306 [ 3.318377@0] ** disable watchdog [ 3.321757@0] keys=========================================== [ 3.327362@0] keys_devno=f100000 [ 3.330679@0] securitykey: device aml_keys created [ 3.335339@0] amlkeys=0 [ 3.337779@0] platform_driver_register--aml_keys_driver-------------------- [ 3.344913@0] set uart_ao pinmux use pinctrl subsystem [ 3.349837@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.353981@0] start uart_ao_ttyS0:(irq = 122) [ 3.358325@0] register uart_ao ok [ 3.361741@0] set uart_a pinmux use pinctrl subsystem [ 3.366624@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.370821@0] start uart_a_ttyS1:(irq = 58) [ 3.374946@0] register uart_a ok [ 3.378314@0] start uart_d_ttyS4:(irq = 126) [ 3.382400@0] register uart_d ok [ 3.385678@0] dwc_otg: version 3.10a 12-MAY-2014 [ 3.390245@0] dwc_otg_driver_probe NOT match [ 3.394475@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 3.403062@0] USB (1) use clock source: XTAL input [ 3.428835@0] Core Release: 3.10a [ 3.428917@0] Setting default values for core params [ 3.431515@0] curmode: 1, host_only: 1 [ 3.455688@0] Using Buffer DMA mode [ 3.459776@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.463850@0] Working on port type = HOST [ 3.467933@0] dwc_otg lm1: DWC OTG Controller [ 3.472003@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 3.477724@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 3.482663@0] -------hcd->flags.d32 = 0 [ 3.486633@0] Init: Port Power? op_state=1 [ 3.490583@0] Init1: Power Port (0) [ 3.494577@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.500958@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.508321@0] usb usb1: Product: DWC OTG Controller [ 3.513164@0] usb usb1: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.519156@0] usb usb1: SerialNumber: lm1 [ 3.523539@0] hub 1-0:1.0: USB hub found [ 3.527686@0] hub 1-0:1.0: 1 port detected [ 3.531938@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 3.539713@0] USB (0) use clock source: XTAL input [ 3.565492@0] Core Release: 3.10a [ 3.569801@0] Setting default values for core params [ 3.574164@0] curmode: 1, host_only: 0 [ 3.638608@0] Using Buffer DMA mode [ 3.642959@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.647336@0] Working on port type = OTG [ 3.651670@0] Current port type: SLAVE [ 3.655941@0] dwc_otg lm0: DWC OTG Controller [ 3.660199@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 3.665544@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 3.670514@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.677412@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.684790@0] usb usb2: Product: DWC OTG Controller [ 3.689643@0] usb usb2: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.695613@0] usb usb2: SerialNumber: lm0 [ 3.699966@0] hub 2-0:1.0: USB hub found [ 3.704107@0] hub 2-0:1.0: 1 port detected [ 3.708321@0] Dedicated Tx FIFOs mode [ 3.712527@0] using timer detect id change, ef5c1400 [ 3.716814@0] boot_device_flag : 0 [ 3.721019@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 3.729096@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 3.729118@2] Indeed it is in host mode hprt0 = 00021501 [ 3.741221@0] amlnf_phy_init : amlnf init flag 0 [ 3.745860@0] ######STS IRQ mode for nand driver [ 3.750462@0] NAND device id: ad de 14 a7 42 4a ad de [ 3.755423@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 3.802104@0] AML_NAND_NEW_OOB : new oob [ 3.806455@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 3.813210@0] boot_device_flag = 0 [ 3.820512@0] uncorrect ecc here at page:2048, chip:0 [ 3.825075@0] blk check good but read failed at chip 0 page 2048 [ 3.830991@0] hynix nand get default reg value at blk:8, page:2049 [ 3.838216@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 3.849633@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 3.857488@0] nand shipped bbt at block 0 [ 3.864885@0] uncorrect ecc here at page:2048, chip:0 [ 3.869616@0] nand blk check good but read failed at chip 0 page 2048 [ 3.908160@2] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 3.913996@3] Indeed it is in host mode hprt0 = 00001101 [ 3.924059@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 [ 3.932136@0] i=0,register --- nand_key [ 3.936890@0] nand adjust phy offset : block 4 [ 3.941637@0] nand adjust phy offset : block 4 [ 3.946348@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 3.955106@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 3.964644@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 3.975388@0] bad block count = 0 [ 3.975388@0] [ 3.987978@0] bad block count = 0 [ 3.987978@0] [ 4.008501@0] bad block count = 0 [ 4.008501@0] [ 4.017664@0] amlnand_add_nftl: [ 4.022220@0] Creating 1 ntd partitions [ 4.026738@0] block_num 76 [ 4.032409@0] ------init_ntd [ 4.037012@0] ntd: Giving out device 0 to nfcache [ 4.041525@0] Creating 7 ntd partitions [ 4.046032@0] block_num 204 [ 4.053741@0] ntd: Giving out device 1 to nfcode [ 4.058118@0] Creating 1 ntd partitions [ 4.062500@0] block_num 720 [ 4.078172@0] ntd: Giving out device 2 to nfdata [ 4.082754@0] ethernet_driver probe! [ 4.087107@0] Please config phy interface. [ 4.091475@0] Please config savepowermode. [ 4.095805@0] Please config reset_pin_enable. [ 4.100137@0] Please config reset_delay. [ 4.104420@0] Please config reset_pin. [ 4.108663@0] ethernetinit(dbg[c0b77388]=1) [ 4.109319@3] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.109323@3] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.109327@3] usb 1-1: Product: USB2.0 Hub [ 4.109746@3] hub 1-1:1.0: USB hub found [ 4.110013@3] hub 1-1:1.0: 4 ports detected [ 4.138176@0] ethernet base addr is fe0c0000 [ 4.142353@0] write mac add to:ef5f1ac8: 00 01 23 cd ee af |..#...| [ 4.154350@0] libphy: AMLMAC MII Bus: probed [ 4.158650@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 4.163445@0] Amlogic A/V streaming port init [ 4.168375@0] buffersize=262144,0,start=0 [ 4.172571@0] Subtitle stbuf alloced at 0xee6c0000, size = 262144 [ 4.177406@0] changed the (2) buffer size from 0 to 262144 [ 4.183011@0] init vdec memsource 9a00000->199fffff [ 4.187801@0] [tsync_pcr_init]init success. [ 4.191984@0] amvideocap_init_module [ 4.196188@0] regist mpeg12 codec profile [ 4.200304@0] regist mpeg4 codec profile [ 4.204308@0] amvdec_vc1 module init [ 4.208300@0] regist vc1 codec profile [ 4.212160@0] amvdec_h264 module init [ 4.216049@0] regist h264 codec profile [ 4.219866@0] amvdec_h264mvc module init [ 4.223658@0] regist hmvc codec profile [ 4.227346@0] amvdec_h264_4k2k module init [ 4.231123@0] regist h264_4k2k codec profile [ 4.234774@0] amvdec_h265 module init [ 4.238449@0] regist hevc_unsupport codec profile [ 4.242539@0] regist mjpeg codec profile [ 4.246400@0] amvdec_real module init [ 4.250093@0] amvdec_avs module init [ 4.253687@0] amvenc_avc memory resource undefined. [ 4.258464@0] amvenc_avc memory is invaild, probe fail! [ 4.263659@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 4.270134@0] jpegenc module init [ 4.273649@0] alloc_keep_buffer keep_y_addr ee200000 [ 4.278332@0] alloc_keep_buffer keep_u_addr ee800000 [ 4.283246@0] alloc_keep_buffer keep_v_addr ee780000 [ 4.288196@0] yaddr=ee200000,u_addr=ee800000,v_addr=ee780000 [ 4.294019@0] create_ge2d_work_queue video task ok [ 4.298946@0] efuse=========================================== [ 4.304561@0] efuse: device efuse created [ 4.308530@0] efuse-------------------------------------------- [ 4.314374@0] SARADC Driver init. [ 4.317984@0] __saradc_probe__ [ 4.468274@0] saradc calibration: ref_val = 508 [ 4.471813@0] saradc calibration: ref_nominal = 512 [ 4.475551@0] saradc calibration: coef = 4064 [ 4.480061@0] ir irblaster probe [ 4.483646@0] Remote Driver [ 4.487175@0] Remote platform_data g_remote_base=fe600580 [ 4.491268@0] set drvdata completed [ 4.494806@0] device_create_file completed [ 4.499317@0] input: aml_keypad as /devices/platform/meson-remote/input/input0 [ 4.506374@0] input_register_device completed [ 4.510800@0] [0xffffff00] = 0x1dd0190 [ 4.514461@0] [0xffffff04] = 0xf800ca [ 4.518100@0] [0xffffff08] = 0x82006e [ 4.521755@0] [0xffffff0c] = 0x3c0030 [ 4.525381@0] [0xffffff10] = 0x30fa0013 [ 4.529219@0] [0xffffff18] = 0x6f19000 [ 4.532922@0] [0xffffff1c] = 0xbe40 [ 4.536388@0] [0x0] = 0xfa00a0 [ 4.539816@0] [0x4] = 0xfa00a0 [ 4.543166@0] [0x8] = 0xfa00a0 [ 4.546478@0] [0xc] = 0x640030 [ 4.549785@0] [0x10] = 0x30fa0013 [ 4.553062@0] [0x18] = 0x961b800 [ 4.556280@0] [0x1c] = 0x9740 [ 4.559452@0] [0x20] = 0x104 [ 4.562553@0] [0x24] = 0x0 [ 4.565586@0] [0x28] = 0x0 [ 4.568591@0] set_remote_mode[69] [ 4.571569@0] remote config major:237 [ 4.574577@0] physical address:0x2e8b6000 [ 4.577532@0] Meson KeyInput init [ 4.580606@0] GPIO Keypad Driver init. [ 4.584294@0] ==gpio_key_probe== [ 4.587467@0] reg:2620,clearmask=400040,setmask=1 [ 4.592203@0] reg:2622,clearmask=ff0000,set pin=3 [ 4.596884@0] reg:2623,clearmask=7000000,setmask=7 [ 4.601690@0] reg:2620,clearmask=800080,setmask=10001 [ 4.606766@0] reg:2622,clearmask=ff000000,set pin=3 [ 4.611620@0] reg:2623,clearmask=70000000,setmask=7 [ 4.616541@0] power key(116) registed. [ 4.620322@0] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1 [ 4.627660@0] gpio keypad register input device completed. [ 4.633063@0] gpio keypad major:236 [ 4.636605@0] spi_nor_init [ 4.639732@0] amlogic_spi_nor_probe: [ 4.642812@0] amlogic_spi->state_name:default [ 4.647142@0] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 4.654690@0] check_storage_device : spi boot_device_flag : 0 [ 4.660370@0] spi_nor_probe [ 4.663588@0] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 4.669437@0] Creating 2 MTD partitions on "apollospi:32766": [ 4.674571@0] 0x000000000000-0x000000100000 : "bootloader" [ 4.680509@0] 0x000000100000-0x000000110000 : "ubootenv" [ 4.685713@0] amlogic_spi_nor_probe over [ 4.689337@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 4.698771@0] host->base fe108c20 [ 4.702174@0] pdata->caps 7 [ 4.705495@0] pdata->caps2 0 [ 4.708773@0] get property: port, value:0x00000001 [ 4.714100@0] get property: ocr_avail, value:0x00200000 [ 4.720606@0] get property: f_min, value:0x000493e0 [ 4.727100@0] get property: f_max, value:0x02faf080 [ 4.733615@0] get property: max_req_size, value:0x00020000 [ 4.740109@0] get property: irq_in, value:0x00000003 [ 4.746605@0] get property: irq_out, value:0x00000005 [ 4.753115@0] get property: gpio_cd, str:CARD_6 [ 4.759101@0] get property: pinname, str:sd [ 4.764714@0] get property: jtag_pin, str:CARD_0 [ 4.770707@0] get property: card_type, value:0x00000005 [ 4.777203@0] get property: gpio_dat3, str:CARD_4 [ 4.783201@0] normal card in [ 4.818182@3] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 4.818189@0] reg:2620,clearmask=80008,setmask=10001 [ 4.818192@0] reg:2621,clearmask=ff000000,set pin=64 [ 4.818194@0] reg:2623,clearmask=7000,setmask=7 [ 4.818197@0] reg:2620,clearmask=200020,setmask=1 [ 4.818199@0] reg:2622,clearmask=ff00,set pin=64 [ 4.818201@0] reg:2623,clearmask=700000,setmask=7 [ 4.818340@0] pdata->caps 80000507 [ 4.818343@0] pdata->caps2 0 [ 4.818346@0] get property: port, value:0x00000002 [ 4.818348@0] get property: ocr_avail, value:0x00200000 [ 4.818350@0] get property: f_min, value:0x000493e0 [ 4.818352@0] get property: f_max, value:0x02faf080 [ 4.818354@0] get property: f_max_w, value:0x02faf080 [ 4.818357@0] get property: max_req_size, value:0x00020000 [ 4.818363@0] get property: pinname, str:emmc [ 4.818365@0] get property: card_type, value:0x00000001 [ 4.818369@0] get property: gpio_dat3, str:BOOT_3 [ 4.818372@0] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=5 [ 4.956851@2] sd: new high speed SDHC card at address 0001, clock 35416666, 4-bit-bus-width [ 4.963330@2] mmcblk0: sd:0001 SD32G 29.5 GiB [ 4.988216@0] pdata->caps 107 [ 4.991768@0] pdata->caps2 0 [ 4.995306@0] get property: port, value:0x00000000 [ 4.995351@2] mmcblk0: p1 p2 [ 4.995684@2] emmc: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 4.995687@2] aml_emmc_hw_reset 1338 [ 5.013103@0] get property: ocr_avail, value:0x00200000 [ 5.019536@0] get property: f_min, value:0x000493e0 [ 5.026028@0] get property: f_max, value:0x02faf080 [ 5.032536@0] get property: max_req_size, value:0x00020000 [ 5.039038@0] get property: pinname, str:sdio [ 5.044837@0] get property: card_type, value:0x00000003 [ 6.008157@0] [aml_sdio_timeout][0;40;33m time_start_cnt:992 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:998 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[ 9.134063@2] emmc: mmc_rescan_try_freq: trying to init card at 300000 Hz [ 9.178151@2] aml_emmc_hw_reset 1338 [aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:993 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f001f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:991 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_probe] aml_sdio_probe() success! [ 13.376548@0] [dsp]DSP start addr 0xc5e00000 [ 13.384811@0] [dsp]register dsp to char divece(257) [ 13.393255@0] amlogic audio spdif interface device init! [ 13.401518@0] name=nand_key nand_key [ 13.410293@0] register_aes_algorithm:488,new way [ 13.419813@0] key name:keyexample, key data:1234567890 [ 13.428711@0] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0 [ 13.438634@0] [AML1216]call aml1216_battery_init, ret = 0 [ 13.447008@0] [AML1218]call aml1218_battery_init, ret = 0 [ 13.455335@0] [RN5T618]call rn5t618_battery_probe in[ 13.463687@0] [RN5T618]no special flag, clear RTC mem, force using ocv [ 13.473746@0] input: rn5t618_pmu as /devices/i2c-0/0-0032/rn5t618_pmu.0/input/input2 [ 13.484553@0] [RN5T618]use BSP configed battery parameters [ 13.493255@0] [RN5T618] NO BATTERY_PARAMETERS FOUND [ 13.507917@0] [RN5T618]call rn5t618_battery_probe exit, ret:0 [ 13.508067@0] [RN5T618]call rn5t618_battery_init, ret = 0 [ 13.525968@0] amaudio2: device amaudio2 created [ 13.534832@0] Amlogic CEC Driver, (c) 2016 Gerald Dachs, Version: 0.0.1 [ 13.544780@0] Error: Didn't get power valid value --- wifi_power_probe 323 [ 13.554924@0] wifi_power power_gpio is 6 [ 13.563819@0] wifi_power power_gpio2 is 123 [ 13.572730@0] bcmdhd_wlan_init() [ 13.581446@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[0]=ef36a9c0, size=3760 [ 13.591637@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[1]=ef36a900, size=3760 [ 13.601832@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[2]=ef36a840, size=3760 [ 13.611978@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[3]=ef36a780, size=3760 [ 13.622075@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[4]=ef36a6c0, size=3760 [ 13.632112@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[5]=ef36a600, size=3760 [ 13.642068@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[6]=ef36a540, size=3760 [ 13.651958@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[7]=ef36a480, size=3760 [ 13.661835@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[8]=ef36a3c0, size=7856 [ 13.671703@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[9]=ef36a300, size=7856 [ 13.681554@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[10]=ef36a240, size=7856 [ 13.691485@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[11]=ef36a180, size=7856 [ 13.701389@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[12]=ef36a0c0, size=7856 [ 13.711219@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[13]=ef36a000, size=7856 [ 13.720717@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[14]=ef36ad80, size=7856 [ 13.729904@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[15]=ef36ae40, size=7856 [ 13.739020@0] 3 bcmdhd_init_wlan_mem: wlan_static_skb[16]=ef445f00, size=16048 [ 13.747930@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[0]=ef36a9c0, size=20504 [ 13.756396@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[1]=ef36a900, size=20504 [ 13.764807@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[2]=ef36a840, size=81944 [ 13.772920@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[3]=ef36a780, size=163864 [ 13.780814@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[4]=ef36a6c0, size=20504 [ 13.788563@0] 5 bcmdhd_init_wlan_mem: wlan_static_scan_buf0=ee950000, size=65536 [ 13.796406@0] 6 bcmdhd_init_wlan_mem: wlan_static_scan_buf1=ee9c0000, size=65536 [ 13.803935@0] bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 13.809706@0] amlogic rfkill init [ 13.815380@0] Error: Driver 'bt-dev' is already registered, aborting... [ 13.822782@0] enter rt5616_modinit [ 13.828372@0] dummy_codec_platform_probe [ 13.833653@0] == ES8323 == es8323_modinit() [ 13.838892@0] *****enter pcm2bt_codec_probe [ 13.843790@0] pcm2bt_codec_probe ok! [ 13.848692@0] enter aml_i2s_dai_probe [ 13.853252@0] i2s get no clk src setting in dts, use the default mpll 0 [ 13.858590@0] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000 [ 13.866562@0] enter aml_pcm_dai_probe [ 13.870750@0] [aml-spdif-dai]enter aml_dai_spdif_init [ 13.875129@0] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4 [ 13.882254@0] audio_set_958_clk, freq=4, [ 13.886139@0] IEC958 16bit [ 13.889767@0] hdmitx: audio: aout notify rate 48000 [ 13.893683@0] hdmitx: audio: aout notify size 16 [ 13.898285@0] hdmitx: audio: aout notify format CT_PCM [ 13.903386@0] hdmitx: audio: audio channel num is 1 [ 13.908256@0] hdmitx: audio: SPDIF [ 13.911771@0] hdmitx: audio: current VIC: 16 [ 13.915865@0] hdmitx: audio: audio sample rate: 3 [ 13.920561@0] hdmitx: audio: set audio N para [ 13.924885@0] hdmitx: audio: PCM out to HDMI [ 13.929151@0] hdmitx: audio: i2s_to_spdif_flag:1 [ 13.933808@0] hdmitx: audio: Enable audio spdif to HDMI [ 13.939025@0] hdmitx: audio: Audio Type: PCM [ 13.943305@0] hdmitx: audio: set audio param [ 13.947558@0] [aml-spdif-dai]aml_spdif_probe [ 13.951856@0] test codec dummy_codec [ 13.955309@0] using external codec, index = 1 [ 13.959663@0] using external dummy codec [ 13.963619@0] enter spdif_dit_probe [ 13.967096@0] aml_spdif_unmute [ 13.970359@0] codec_name = dummy_codec.0 [ 13.974408@0] enter aml_asoc_init [ 13.977526@0] p_aml_audio->hp_disable=1 [ 13.981331@0] falied to get spk event delay time paraments from dts file [ 13.987985@0] spk_event delay_time = 0 [ 13.992675@0] aml-i2s 0:playback preallocate_dma_buffer: area=f0b51000, addr=2e100000, size=524288 [ 14.000874@0] aml-i2s 1:capture preallocate_dma_buffer: area=f0bd3000, addr=2e200000, size=65536 [ 14.009433@0] aml_snd_m8 aml_m8_sound_card.5: dummy_codec <-> aml-i2s-dai.0 mapping ok [ 14.017517@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 0 [ 14.023391@0] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0b2b000 buf->addr: 0x2ebf0000 buf->bytes: 65536 [ 14.033779@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 1 [ 14.039766@0] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0bf4000 buf->addr: 0x2e220000 buf->bytes: 65536 [ 14.050160@0] aml_snd_m8 aml_m8_sound_card.5: pcm2bt-pcm <-> aml-pcm-dai.0 mapping ok [ 14.059043@0] aml-i2s 0:playback preallocate_dma_buffer: area=f0c05000, addr=2e300000, size=524288 [ 14.067166@0] aml-i2s 1:capture preallocate_dma_buffer: area=f0c87000, addr=2e1a0000, size=65536 [ 14.075745@0] aml_snd_m8 aml_m8_sound_card.5: dit-hifi <-> aml-spdif-dai.0 mapping ok [ 14.084286@0] -----ext_codec=1--- [ 14.088641@0] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0 [ 14.093523@0] GACT probability NOT on [ 14.097978@0] Mirror/redirect action on [ 14.102423@0] u32 classifier [ 14.106860@0] Actions configured [ 14.111351@0] Netfilter messages via NETLINK v0.30. [ 14.115922@0] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 14.121641@0] ctnetlink v0.93: registering with nfnetlink. [ 14.126857@0] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 14.133925@0] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 14.140075@0] xt_time: kernel timezone is -0000 [ 14.144853@0] ipip: IPv4 over IPv4 tunneling driver [ 14.149911@0] ip_tables: (C) 2000-2006 Netfilter Core Team [ 14.154808@0] arp_tables: (C) 2002 David S. Miller [ 14.159547@0] TCP: cubic registered [ 14.164202@0] Initializing XFRM netlink socket [ 14.169206@0] NET: Registered protocol family 10 [ 14.174550@0] mip6: Mobile IPv6 [ 14.179283@0] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 14.184149@0] sit: IPv6 over IPv4 tunneling driver [ 14.189407@0] NET: Registered protocol family 17 [ 14.194042@0] NET: Registered protocol family 15 [ 14.198671@0] Bridge firewalling registered [ 14.203234@0] l2tp_core: L2TP core driver, V2.0 [ 14.207714@0] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 14.212348@0] l2tp_netlink: L2TP netlink interface [ 14.217085@0] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 14.223178@0] l2tp_debugfs: L2TP debugfs support [ 14.227795@0] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 14.234376@0] NET: Registered protocol family 35 [ 14.239148@0] Key type dns_resolver registered [ 14.244215@0] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 14.251190@0] Registering SWP/SWPB emulation handler [ 14.256079@0] enter meson_pm_init [ 14.261072@0] enter meson_pm_probe! [ 14.265932@0] ---meson_pm_probe----set output pin success [ 14.270858@0] meson_pm_probe done ! [ 14.276089@0] regulator-dummy: disabling [ 14.281217@0] file system registered [ 14.286637@0] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 14.293058@0] android_usb gadget: Number of LUNs=2 [ 14.298051@0] lun0: LUN: removable file: (no medium) [ 14.303090@0] lun1: LUN: removable file: (no medium) [ 14.308238@0] android_usb gadget: android_usb ready [ 14.313676@0] aml_rtc rtc.0: setting system clock to 1970-01-01 00:09:40 UTC (580) [ 14.320718@0] ### dt-test ### No testcase data in device tree; not running tests [ 14.328175@0] meson_cpufreq: no voltage_control prop [ 14.333367@0] voltage_control = 0 [ 14.339752@0] buf[0]=a7,buf[1]=9b,err=4 [ 14.343356@0] M8:adc=442,TS_C=7,flag=1 [ 14.346899@0] efuse_flag=a [ 14.350388@0] amlogic_thermal_probe, this chip is trimmed, use thermal [ 14.354753@0] amlogic-thermal aml_thermal: amlogic thermal probe start [ 14.361267@0] #thermal-cells=7 [ 14.364649@0] pdata->temp_trip_count=4 [ 14.368013@0] temperature=70000 on trip point=0 [ 14.372531@0] fixing high_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.379627@0] fixing low_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.386248@0] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511 [ 14.392383@0] cpu[0] core num==3 [ 14.395576@0] gpu[0] core num==5 [ 14.398793@0] temperature=80000 on trip point=1 [ 14.403290@0] fixing high_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.410244@0] fixing low_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.416927@0] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435 [ 14.423162@0] cpu[1] core num==2 [ 14.426355@0] gpu[1] core num==4 [ 14.429566@0] temperature=90000 on trip point=2 [ 14.434063@0] fixing high_freq=800001 to 696000 at trip point 2,level=11 [ 14.440954@0] fixing low_freq=800001 to 696000 at trip point 2,level=11 [ 14.447527@0] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328 [ 14.453749@0] cpu[2] core num==2 [ 14.456947@0] gpu[2] core num==3 [ 14.460169@0] temperature=260000 on trip point=3 [ 14.464748@0] fixing high_freq=-1 to -22 at trip point 3,level=-1 [ 14.471253@0] fixing low_freq=-1 to -22 at trip point 3,level=-1 [ 14.477232@0] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1 [ 14.483049@0] cpu[3] core num==-1 [ 14.486332@0] gpu[3] core num==-1 [ 14.489637@0] idle interval=1000 [ 14.492839@0] pdata->name:aml_thermal [ 14.496591@0] tmp_trip[0].cpu_core_upper=1 [ 14.500570@0] tmp_trip[1].cpu_core_upper=2 [ 14.504628@0] tmp_trip[2].cpu_core_upper=2 [ 14.508712@0] tmp_trip[3].cpu_core_upper=-1 [ 14.512869@0] aml_thermal bind thermal-cpucore-0 okay ! [ 14.518077@0] aml_thermal bind thermal-cpufreq-0 okay ! [ 14.523391@0] amlogic: Kernel Thermal management registered [ 14.528825@0] amlogic-thermal aml_thermal: amlogic thermal probe done [ 14.535288@0] ALSA device list: [ 14.538355@0] #0: AML-M8AUDIO [ 14.541638@0] Freeing unused kernel memory: 228K [ 14.552098@3] tvmode set to 720p [ 14.552098@3] [ 14.557687@3] mode is 11,sync_duration_den=1,sync_duration_num=60 [ 14.562966@3] TV mode 720p selected. [ 14.566509@3] tvoutc_setmode[505] [ 14.569808@3] tvoutc_setmode[516] mode is 11 [ 14.574047@3] vinfo mode is: 720p [ 14.577341@3] new mode 720p set ok [ 14.580731@3] hdmitx: video: get current mode: 720p [ 14.585577@3] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.591308@3] hdmitx: video: get current mode: 720p [ 14.596155@3] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.601883@3] hdmitx: system: gate/pwr cmd: 7 [ 14.606248@3] hdmitx: system: already init VIC = 0 Now VIC = 4 [ 14.612110@3] hdmitx: system: 4 (cd0,cs0,pm1,vd0,1) [ 14.617128@3] hdmitx: system: gate/pwr cmd: 0 [ 14.621471@3] hdmitx: system: hw reset [ 14.626230@3] hdmitx: audio: SPDIF [ 14.629298@3] hdmitx: system: reconfig packet setting done [ 14.654042@3] hdmitx: system: set pll [ 14.657073@3] hdmitx: system: param->VIC:4 [ 14.660078@3] mode is: 11 [ 14.663024@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.665956@3] viu chan = 1 [ 14.668882@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.672235@3] config HPLL [ 14.675104@3] set_hpll_clk_out[81] clk = 2970 [ 14.698143@3] config HPLL done [ 14.700975@3] enc_vpu_bridge_reset[292] [ 14.838325@1] hdmitx: system: phy setting done [ 14.883239@1] Sink is HDMI device [ 14.927798@1] No sink attached [ 14.971827@1] hdmitx: audio: audio channel num is 1 [ 15.015866@1] hdmitx: audio: SPDIF [ 15.021718@1] hdmitx: audio: current VIC: 4 [ 15.024125@1] hdmitx: audio: audio sample rate: 3 [ 15.028293@1] hdmitx: audio: set audio N para [ 15.032620@1] hdmitx: audio: PCM out to HDMI [ 15.036864@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 15.041564@2] hdmitx: audio: Enable audio spdif to HDMI [ 15.046748@2] hdmitx: audio: Audio Type: PCM [ 15.054801@2] set_vout_mode[183] [ 15.501213@0] [RN5T618]battery vol change: 0->0 [ 22.042376@0] force enable DISCARD here for ext4 fs [ 22.119367@0] EXT4-fs (mmcblk0p2): recovery complete [ 22.166576@0] checked enable EXT4 DISCARD here [ 22.213966@0] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard [ 22.225986@0] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 23.246891@0] systemd[1]: System time before build time, advancing clock. [ 23.396818@0] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 23.471143@1] systemd[1]: Detected architecture arm. [ 23.542733@1] systemd[1]: Set hostname to <vegas812>. [ 23.608175@3] Changing uart_ao_ttyS0: baud from 0 to 115200 [ 25.111489@1] systemd[1]: Reached target Swap. [ 25.220740@1] systemd[1]: Listening on Syslog Socket. [ 25.227737@1] systemd[1]: Created slice System Slice. [ 25.234859@1] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 25.242741@1] systemd[1]: dev-hugepages.mount: Couldn't determine result for ConditionVirtualization=!private-users, assuming failed: No such file or directory [ 25.255169@1] systemd[1]: Created slice User and Session Slice. [ 25.264826@1] systemd[1]: Reached target Slices. [ 25.272827@1] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 25.284783@1] systemd[1]: Reached target Remote File Systems. [ 25.294434@1] systemd[1]: Mounting Debug File System... [ 25.303282@1] systemd[1]: Listening on Journal Socket (/dev/log). [ 25.312527@1] systemd[1]: Listening on fsck to fsckd communication Socket. [ 25.322913@1] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 25.332682@1] systemd[1]: Listening on udev Kernel Socket. [ 25.342029@1] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 25.353696@1] systemd[1]: Listening on Journal Socket. [ 25.369746@1] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 25.385409@1] systemd[1]: Starting Nameserver information manager... [ 25.399564@1] systemd[1]: Starting Restore / save the current clock... [ 25.412500@1] systemd[1]: Starting Set the console keyboard layout... [ 25.432641@1] systemd[1]: Starting Load Kernel Modules... [ 25.443586@1] systemd[1]: Listening on udev Control Socket. [ 25.456641@1] systemd[1]: Starting Remount Root and Kernel File Systems... [ 25.469377@1] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 25.483665@1] systemd[1]: Reached target Encrypted Volumes. [ 25.494104@1] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 25.508221@1] systemd[1]: Mounted Debug File System. [ 25.518714@1] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 25.534841@1] systemd[1]: Started Restore / save the current clock. [ 25.546091@1] systemd[1]: Time has been changed [ 25.552729@1] systemd[1]: Starting Create Static Device Nodes in /dev... [ 26.073418@2] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 26.145698@1] systemd[1]: Started Nameserver information manager. [ 26.223377@2] boot_device_flag : 0 [ 26.223379@2] register_ntd_blktrans start [ 26.223382@2] ntd device 250! [ 26.223383@2] ntd->name: nfcache [ 26.223387@2] adjust_block_num : 4,reserved_block_ratio 10 [ 26.223391@2] nftl version 140911a [ 26.223397@2] nftl part attr 0 [ 26.224573@2] nftl start:76,12 [ 26.224755@2] first [ 26.273189@2] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 26.280970@0] systemd[1]: Started Remount Root and Kernel File Systems. [ 26.297317@0] systemd[1]: Starting Load/Save Random Seed... [ 26.298381@2] average_erase_count:0 [ 26.298387@2] second 55,64 [ 26.298389@2] part->max_discard_block = 4 [ 26.325871@0] systemd[1]: Starting udev Coldplug all Devices... [ 26.358627@2] current_block1:19 [ 26.365027@2] recover_current_block_mapping invalid page data!! [ 26.370653@2] recover_current_block_mapping invalid page data!! [ 26.376488@2] recover_current_block_mapping invalid page data!! [ 26.382357@2] recover_current_block_mapping invalid page data!! [ 26.388387@2] recover_current_block_mapping invalid page data!! [ 26.394274@2] recover_current_block_mapping invalid page data!! [ 26.400014@2] all discard block full!! [ 26.403831@2] free list: [ 26.407695@2] free block cnt = 61 [ 26.411550@2] new current block is 21 [ 26.420030@0] systemd[1]: Started Set the console keyboard layout. [ 26.441231@0] systemd[1]: Started Load/Save Random Seed. [ 26.536613@3] systemd[1]: Started Create Static Device Nodes in /dev. [ 26.550418@3] systemd[1]: Starting udev Kernel Device Manager... [ 26.559130@3] systemd[1]: Reached target Local File Systems (Pre). [ 26.576727@3] systemd[1]: Mounting /tmp... [ 26.591971@3] systemd[1]: Mounted /tmp. [ 26.604147@3] systemd[1]: Started udev Coldplug all Devices. [ 26.679426@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 26.713435@3] systemd[1]: Started udev Kernel Device Manager. [ 27.083095@3] systemd[1]: Found device /dev/ttyS0. [ 27.258476@2] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 27.308343@1] systemd[1]: Reached target Sound Card. [ 27.354304@1] systemd[1]: Found device /dev/disk/by-label/BOOT. [ 27.383119@0] recover_current_block_mapping : fill the current block, from page 255 [ 27.388290@1] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT... [ 27.412201@0] total discard page count is 0 [ 27.412211@0] create_part_list:1235,current_used_discard_block=20,current_discard_block_used_count=159 [ 27.412864@0] unmappig_pages=15832,discarded_pages=0,mapping_pages=552 [ 27.412866@0] nftl ok! [ 27.414510@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 27.415158@0] aml_nftl_add_ntd ok [ 27.415164@0] ntd device 250! [ 27.415167@0] ntd->name: nfcode [ 27.415174@0] adjust_block_num : 4,reserved_block_ratio 10 [ 27.415180@0] nftl version 140911a [ 27.415225@0] nftl part attr 0 [ 27.416122@3] aml_nftl_open ok! [ 27.422376@3] size_in_blk 204; total_block 203; [ 27.422381@3] nftl start:203,23 [ 27.423093@3] first [ 27.560124@3] found discard block:139 [ 27.625821@3] average_erase_count:6 [ 27.629681@3] second 202,180 [ 27.633378@3] part->max_discard_block = 4 [ 27.744518@1] systemd[1]: Started File System Check Daemon to report status. [ 27.863161@3] current_block1:39 [ 27.936095@3] recover_current_block_mapping invalid page data!! [ 27.941164@3] recover_current_block_mapping invalid page data!! [ 27.947030@3] recover_current_block_mapping invalid page data!! [ 27.952983@3] recover_current_block_mapping invalid page data!! [ 27.958835@3] recover_current_block_mapping invalid page data!! [ 27.964721@3] recover_current_block_mapping invalid page data!! [ 27.971528@3] currnet_discard_block1:139 [ 28.011491@3] reach the last discard page:28 [ 28.015238@3] free list: [ 28.019006@3] free block cnt = 91 [ 28.024070@3] new current block is 171 [ 28.198875@1] systemd[1]: Started File System Check on /dev/disk/by-label/BOOT. [ 28.216267@1] systemd[1]: Mounting /boot... [ 28.244771@1] systemd[1]: Mounted /boot. [ 28.256547@1] systemd[1]: Reached target Local File Systems. [ 28.270649@1] systemd[1]: Starting Armbian enhanced Log2Ram... [ 28.285979@1] systemd[1]: Starting HDMI init... [ 28.291211@3] tvmode set to 1080p [ 28.291211@3] [ 28.291227@3] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 28.291231@3] TV mode 1080p selected. [ 28.291236@3] tvoutc_setmode[505] [ 28.291239@3] tvoutc_setmode[516] mode is 15 [ 28.291241@3] vinfo mode is: 1080p [ 28.291243@3] new mode 1080p set ok [ 28.291248@3] hdmitx: video: get current mode: 1080p [ 28.291251@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 28.291255@3] hdmitx: video: get current mode: 1080p [ 28.291261@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 28.291718@3] hdmitx: system: gate/pwr cmd: 7 [ 28.291790@3] hdmitx: system: already init VIC = 0 Now VIC = 16 [ 28.291796@3] hdmitx: system: 16 (cd0,cs0,pm1,vd0,1) [ 28.291797@3] hdmitx: system: gate/pwr cmd: 0 [ 28.291811@3] hdmitx: system: hw reset [ 28.292862@3] hdmitx: audio: SPDIF [ 28.292922@3] hdmitx: system: reconfig packet setting done [ 28.313688@3] hdmitx: system: set pll [ 28.313691@3] hdmitx: system: param->VIC:16 [ 28.313696@3] mode is: 15 [ 28.313699@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 28.313700@3] viu chan = 1 [ 28.313702@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 28.313703@3] config HPLL [ 28.313705@3] set_hpll_clk_out[81] clk = 2970 [ 28.328153@3] config HPLL done [ 28.328162@3] enc_vpu_bridge_reset[292] [ 28.332039@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 28.430960@1] systemd[1]: Starting Set console font and keymap... [ 28.468208@3] hdmitx: system: phy setting done [ 28.471535@3] Sink is HDMI device [ 28.474792@3] No sink attached [ 28.475191@1] systemd[1]: Started Armbian enhanced Log2Ram. [ 28.482265@3] hdmitx: audio: audio channel num is 1 [ 28.482271@3] hdmitx: audio: SPDIF [ 28.482279@3] hdmitx: audio: current VIC: 16 [ 28.482280@3] hdmitx: audio: audio sample rate: 3 [ 28.482282@3] hdmitx: audio: set audio N para [ 28.482287@3] hdmitx: audio: PCM out to HDMI [ 28.482289@3] hdmitx: audio: i2s_to_spdif_flag:1 [ 28.482290@3] hdmitx: audio: Enable audio spdif to HDMI [ 28.482293@3] hdmitx: audio: Audio Type: PCM [ 28.529217@3] set_vout_mode[183] [ 28.537476@1] systemd[1]: Started Set console font and keymap. [ 28.548692@1] systemd[1]: Starting Journal Service... [ 28.631111@1] systemd[1]: Started HDMI init. [ 28.704573@1] systemd[1]: Started Journal Service. [ 28.744317@3] systemd-journald[441]: Received request to flush runtime journal from PID 1 [ 28.931273@0] recover_current_block_mapping : fill the current block, from page 255 [ 28.940904@0] total discard page count is 28 [ 28.948717@0] create_part_list:1235,current_used_discard_block=139,current_discard_block_used_count=91 [ 28.961161@0] unmappig_pages=25320,discarded_pages=119,mapping_pages=20641 [ 28.970348@0] nftl ok! [ 28.979140@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 28.988228@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 28.991438@3] aml_nftl_open ok! [ 29.005636@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 29.009309@3] aml_nftl_open ok! [ 29.024017@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 29.026070@3] aml_nftl_open ok! [ 29.033858@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 29.035819@3] aml_nftl_open ok! [ 29.043560@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 29.045614@3] aml_nftl_open ok! [ 29.053355@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 29.055345@3] aml_nftl_open ok! [ 29.063081@0] aml_nftl_add_ntd ok [ 29.065196@3] aml_nftl_open ok! [ 29.072461@0] ntd device 250! [ 29.076825@0] ntd->name: nfdata [ 29.081225@0] adjust_block_num : 4,reserved_block_ratio 10 [ 29.085648@0] nftl version 140911a [ 29.090139@0] nftl part attr 0 [ 29.103994@0] size_in_blk 720; total_block 714; [ 29.108450@0] nftl start:714,69 [ 29.113504@0] first [ 29.777036@0] found discard block:701 [ 29.793827@0] average_erase_count:2 [ 29.798256@0] second 713,645 [ 29.802555@0] part->max_discard_block = 4 [ 30.567094@0] current_block1:263 [ 30.675012@0] recover_current_block_mapping invalid page data!! [ 30.680548@0] recover_current_block_mapping invalid page data!! [ 30.686439@0] recover_current_block_mapping invalid page data!! [ 30.692349@0] recover_current_block_mapping invalid page data!! [ 30.698241@0] recover_current_block_mapping invalid page data!! [ 30.704137@0] recover_current_block_mapping invalid page data!! [ 30.710867@0] currnet_discard_block1:701 [ 30.746527@0] reach the last discard page:28 [ 30.750974@0] free list: [ 30.754908@0] free block cnt = 23 [ 30.758853@0] new current block is 576 [ 31.090233@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 31.711174@0] recover_current_block_mapping : fill the current block, from page 255 [ 31.787390@0] total discard page count is 28 [ 31.831309@0] create_part_list:1235,current_used_discard_block=701,current_discard_block_used_count=30 [ 31.841103@0] unmappig_pages=116929,discarded_pages=3583,mapping_pages=44608 [ 31.846820@0] nftl ok! [ 31.851887@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 31.856700@0] aml_nftl_add_ntd ok [ 31.858765@3] aml_nftl_open ok! [ 31.865660@0] init_aml_nftl end Debian GNU/Linux 9 vegas812 ttyS0 vegas812 login: [ 636.774667@0] Restarting system. [ 636.778500@0] Restarting Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PRE≈EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102634 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 28 -> 28 DC02 v:1150, 0x[37]: 2c -> 2c DC03 v:1500, 0x[38]: 48 -> 48 LDO01 v:2900, 0x[4c]: 50 -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12091 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489322 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x0d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=normal TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: ATran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 31715229696 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 1706 bytes read ## Executing script at 11000000 ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** reading uInitrd 3265095 bytes read reading uImage 6006126 bytes read reading dtb.img 18432 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux-3.10.108 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 6006062 Bytes = 5.7 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3265031 Bytes = 3.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 13878354 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5326001 Loading Ramdisk to 05008000, end 05325207 ... OK Loading Device Tree to 05000000, end 05007786 ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Tue May 22 12:53:17 MSK 2018 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is 1c1fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x1c1fffff, size: 354 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(low) : 0x09a00000 - 0x19a00000 (256 MiB) [ 0.000000@0] ppmgr0(high) : 0x7cf00000 - 0x7df00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x19a00000 - 0x1aa00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x1aa00000 - 0x1c200000 ( 24 MiB) [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 8 pages/cpu @c1de1000 s8512 r8192 d16064 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 415504 [ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootfstype=ext4 rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=AE:9E:BA:9B:60:CB logo=osd1,loaded,0x7900000,1080p,full [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:15 [ 0.000000@0] full:2 [ 0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000@0] Memory: 64MB 16MB 1549MB = 1629MB total [ 0.000000@0] Memory: 1633724k/1633724k available, 34372k reserved, 1266688K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc0aeacc0 (11148 kB) [ 0.000000@0] .init : 0xc0aeb000 - 0xc0b24140 ( 229 kB) [ 0.000000@0] .data : 0xc0b26000 - 0xc0b8c0b8 ( 409 kB) [ 0.000000@0] .bss : 0xc0b8c0b8 - 0xc0e2e1b0 (2697 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [tty0] enabled [ 0.000000@0] console [ttyS0] enabled [ 0.323764@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.334058@0] pid_max: default: 32768 minimum: 301 [ 0.338929@0] Security Framework initialized [ 0.343101@0] SELinux: Initializing. [ 0.346802@0] Mount-cache hash table entries: 512 [ 0.354405@0] Initializing cgroup subsys debug [ 0.355819@0] Initializing cgroup subsys freezer [ 0.360491@0] CPU: Testing write buffer coherency: ok [ 0.365761@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.371308@0] Setting up static identity map for 0xc07f2108 - 0xc07f2160 [ 0.378023@0] L310 cache controller enabled [ 0.382113@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.389620@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.397773@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.480149@0] write pen_release: 1 [ 0.480449@1] CPU1: Booted secondary processor [ 0.480461@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.500141@0] write pen_release: 2 [ 0.508377@2] CPU2: Booted secondary processor [ 0.508391@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.520137@0] write pen_release: 3 [ 0.528371@3] CPU3: Booted secondary processor [ 0.528386@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.528451@0] Brought up 4 CPUs [ 0.541495@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.547724@0] CPU: All CPU(s) started in SVC mode. [ 0.552965@0] devtmpfs: initialized [ 0.560176@0] clkrate [ xtal ] : 24000000 [ 0.560211@0] clkrate [ pll_sys ] : 1200000000 [ 0.564542@0] clkrate [ pll_fixed ] : 2550000000 [ 0.569222@0] clkrate [ pll_vid ] : 366000000 [ 0.573650@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.579797@0] clkrate [ pll_hpll ] : 0 [ 0.583617@0] clkrate [ pll_ddr ] : 0 [ 0.587339@0] clkrate [ a9_clk ] : 1200000000 [ 0.591765@0] clkrate [ clk81 ] : 141666666 [ 0.596234@0] xor: measuring software checksum speed [ 0.700013@0] arm4regs : 1605.200 MB/sec [ 0.800015@0] 8regs : 1256.400 MB/sec [ 0.900014@0] 32regs : 1298.400 MB/sec [ 0.900046@0] xor: using function: arm4regs (1605.200 MB/sec) [ 0.904458@0] pinctrl core: initialized pinctrl subsystem [ 0.909966@0] regulator-dummy: no parameters [ 0.914226@0] NET: Registered protocol family 16 [ 0.924122@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.926489@0] VPU driver version: v03 [ 0.929419@0] vpu driver detect cpu type: m8 [ 0.933695@0] load vpu_clk in dts: 364300000Hz(7) [ 0.938359@0] vpu_probe OK [ 0.942509@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.946664@0] register lm device lm-root [ 0.950513@0] register lm device lm1 [ 0.954061@0] register lm device lm0 [ 0.957696@0] Init pinux probe! [ 0.961093@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.966445@0] tv_init_module [ 0.969297@0] major number 254 for disp [ 0.973115@0] vout_register_server [ 0.976487@0] register tv module server ok [ 0.980607@0] aml_i2c version: 20140813 [ 0.984477@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef334ca8) [ 0.990454@0] aml-i2c i2c-AO: aml i2c bus driver. [ 0.995200@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef3350a8) [ 1.001115@0] aml-i2c i2c-A: aml i2c bus driver. [ 1.005779@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3354a8) [ 1.011690@0] aml-i2c i2c-B: aml i2c bus driver. [ 1.016345@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3358a8) [ 1.022265@0] aml-i2c i2c-C: aml i2c bus driver. [ 1.026899@0] aml_pmu_init, 458 [ 1.029986@0] call aml_dvfs_init in [ 1.033597@0] hdmitx: system: amhdmitx_init [ 1.037598@0] hdmitx: system: Ver: 2014May6 [ 1.041813@0] hdmitx: system: amhdmitx_probe [ 1.046130@0] hdmitx: system: not find ao cec [ 1.050349@0] hdmitx: system: not find vend_init_data [ 1.055411@0] hdmitx: system: gate/pwr cmd: 7 [ 1.059704@0] hdmitx: system: ALREADY init VIC = 16 [ 1.064563@0] hdmitx: system: gate/pwr cmd: 0 [ 1.069279@1] hdmitx: system: reset intr mask [ 1.090486@0] hdmitx: system: irq 1 [ 1.091422@0] bio: create slab <bio-0> at 0 [ 1.200806@1] hdmitx: system: gate/pwr cmd: 4 [ 1.260100@0] raid6: int32x1 197 MB/s [ 1.410727@1] hdmitx: system: gate/pwr cmd: 5 [ 1.410760@1] hdmitx: edid: edid ready [ 1.413175@1] hdmitx: system: gate/pwr cmd: 4 [ 1.430230@0] raid6: int32x2 273 MB/s [ 1.600177@0] raid6: int32x4 342 MB/s [ 1.620730@1] hdmitx: system: gate/pwr cmd: 5 [ 1.620762@1] hdmitx: edid: edid ready [ 1.623179@1] hdmitx: edid: check sum valid [ 1.627338@1] hdmitx: edid: check sum valid [ 1.631507@1] hdmitx: edid: blk0 raw data [ 1.635486@1] 00ffffffffffff001e6dac59010101010516010380331d78ea6275a3554fa027 [ 1.642680@1] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.649875@1] 4500fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.657070@1] 34454135330a202020202020000000ff000a2020202020202020202020200106 [ 1.664264@1] [ 1.665912@1] hdmitx: edid: blk1 raw data [ 1.669898@1] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 1.677093@1] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 1.684288@1] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 1.691482@1] 22110000180000000000000000000000000000000000000000000000000000e6 [ 1.698677@1] [ 1.700710@1] hdmitx: edid: find IEEEOUT [ 1.704251@1] hdmitx: video: cann't get valid mode [ 1.708994@1] hdmitx: audio: audio channel num is 0 [ 1.713859@1] hdmitx: audio: SPDIF [ 1.717236@1] hdmitx: audio: current VIC: 16 [ 1.721481@1] hdmitx: audio: audio sample rate: 0 [ 1.726156@1] hdmitx: audio: set audio N para [ 1.730502@1] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 1.738725@1] pgd = c0004000 [ 1.741591@1] [00000000] *pgd=00000000 [ 1.745316@1] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 1.750774@1] Modules linked in: [ 1.753985@1] CPU: 1 PID: 31 Comm: kthread_hdmi Not tainted 3.10.108-vegas812 #1 [ 1.761350@1] task: ef2d8cc0 ti: ef36a000 task.ti: ef36a000 [ 1.766906@1] PC is at hdmitx_set_audmode+0x330/0x788 [ 1.770106@0] raid6: int32x8 346 MB/s [ 1.770108@0] raid6: using algorithm int32x8 (346 MB/s) [ 1.770110@0] raid6: using intx1 recovery algorithm [ 1.770313@0] SCSI subsystem initialized [ 1.770427@0] usbcore: registered new interface driver usbfs [ 1.770455@0] usbcore: registered new interface driver hub [ 1.800883@1] LR is at _raw_spin_unlock_irqrestore+0x28/0x48 [ 1.806513@1] pc : [<c002370c>] lr : [<c07f1b80>] psr: 80000113 [ 1.806513@1] sp : ef36bea8 ip : ffbf6cff fp : 00000001 [ 1.818300@1] r10: 00000000 r9 : 14001000 r8 : 00003000 [ 1.823675@1] r7 : 00000000 r6 : c0e1e3e8 r5 : c0e1ecb8 r4 : c0b47fb8 [ 1.830349@1] r3 : 00000000 r2 : 00000001 r1 : 00007b20 r0 : 00000000 [ 1.837024@1] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 1.844479@1] Control: 10c5387d Table: 0020404a DAC: 00000015 [ 1.850372@1] [ 1.850372@1] PC: 0xc002368c: [ 1.854965@1] 368c e3a0005d eb000a71 e3c01030 e3a0005d e3811020 eb000a85 ea000011 e3a0005d [ 1.863287@1] 36ac eb000a6a e3c01030 e3a0005d e3811010 eb000a7e ea00000a e3a0005d eb000a63 [ 1.871608@1] 36cc e3801030 e3a0005d eb000a78 ea000004 e3a0005d eb000a5d e3c01030 e3a0005d [ 1.879930@1] 36ec eb000a72 e5953000 e353000a 0a000001 e353000b 1a000000 e1a08108 e3071b20 [ 1.888251@1] 370c e5970000 e3a02009 e34c109c eb0ffb56 e3500000 e6ef1078 030c3808 034c30b8 [ 1.896573@1] 372c e3a0001c 05838404 e3a07a05 eb000a5f e7e71458 e3a0001d eb000a5c e7e31858 [ 1.904894@1] 374c e3a0001e e3811030 e34f7e10 eb000a57 e3a0005d eb000a3d e3801001 e3a0005d [ 1.913216@1] 376c eb000a52 e5d42000 e3a03000 e1520003 03a08002 13a08001 e58734a8 f57ff05f [ 1.921538@1] [ 1.921538@1] LR: 0xc07f1b00: [ 1.926131@1] 1b00 e5930000 e7e000d0 e3500000 1afffff3 e8bd8070 e92d4010 f57ff05f e1d030b0 [ 1.934453@1] 1b20 e2833001 e1c030b0 f57ff04f e320f004 e3a00001 ebe181dc e1a0300d e3c33d7f [ 1.942774@1] 1b40 e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc70 e92d4010 f57ff05f [ 1.951096@1] 1b60 e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e3a00001 ebe181ca [ 1.959417@1] 1b80 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc5e [ 1.967739@1] 1ba0 e92d4010 f57ff05f e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080 [ 1.976060@1] 1bc0 e3a00001 ebe181b8 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 [ 1.984382@1] 1be0 e8bd4010 eafffc4c e92d4070 e1a04000 e3a00001 ebe18171 e1943f9f e3a05000 [ 1.992704@1] [ 1.992704@1] SP: 0xef36be28: [ 1.997298@1] be28 00000000 00000000 00000000 00000000 c0b8ef04 0000001f 0000003c 00000000 [ 2.005619@1] be48 c002370c 80000113 ffffffff ef36be94 00003000 c000da58 00000000 00007b20 [ 2.013941@1] be68 00000001 00000000 c0b47fb8 c0e1ecb8 c0e1e3e8 00000000 00003000 14001000 [ 2.022262@1] be88 00000000 00000001 ffbf6cff ef36bea8 c07f1b80 c002370c 80000113 ffffffff [ 2.030584@1] bea8 c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 c0e1ecb8 15000013 [ 2.038905@1] bec8 14001000 00000000 00000001 c06525a0 00000000 00000000 00000000 00000000 [ 2.047227@1] bee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.055548@1] bf08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.063870@1] [ 2.063870@1] IP: 0xffbf6c7f: [ 2.068464@1] 6c7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.076785@1] 6c9c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.085107@1] 6cbc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.093428@1] 6cdc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.101750@1] 6cfc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.110071@1] 6d1c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.118393@1] 6d3c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.126714@1] 6d5c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.135036@1] 6d7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.143358@1] [ 2.143358@1] R4: 0xc0b47f38: [ 2.147952@1] 7f38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.156273@1] 7f58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 fe1080b0 [ 2.164595@1] 7f78 fe1080b4 fe1080b8 fe1080bc fe1080c0 fe1080c4 fe1080c8 fe1080cc fe1080d0 [ 2.172916@1] 7f98 fe1080d4 fe600014 00000001 00000000 c0b47fa8 c0b47fa8 00000000 00000000 [ 2.181237@1] 7fb8 00004901 00000001 00000101 00000001 00000001 00001b8d 00004040 00001c3a [ 2.189559@1] 7fd8 00000112 00001c3b 00000892 00001c3c 00000029 00001c3d 00000461 00001c30 [ 2.197881@1] 7ff8 00000052 00001c31 0000007e 00001c32 00000000 00001c34 00000005 00001c36 [ 2.206202@1] 8018 00000052 00001c38 00000052 00001c51 00000000 00001b62 0000809d 00000000 [ 2.214524@1] [ 2.214524@1] R5: 0xc0e1ec38: [ 2.219118@1] ec38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.227439@1] ec58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.235761@1] ec78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.244082@1] ec98 00000000 00000000 00000000 00000000 00000000 00000006 00000000 0000000a [ 2.252404@1] ecb8 00000000 00000000 00000000 00000000 00000000 00001000 00010001 00000000 [ 2.260725@1] ecd8 00000000 00000001 00000001 00000002 00000001 00000001 00003f03 00000000 [ 2.269047@1] ecf8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.277368@1] ed18 00000000 00000000 00000000 00000000 00000040 00000000 00000005 6f010001 [ 2.285691@1] [ 2.285691@1] R6: 0xc0e1e368: [ 2.290284@1] e368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.298605@1] e388 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.306927@1] e3a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.315248@1] e3c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.323570@1] e3e8 00000000 c0e1e3ec c0e1e3ec 00000000 00000000 c0b4e794 00000000 00000001 [ 2.331891@1] e408 00000001 00000000 c08b1078 c0e1e414 c0e1e414 0fd00000 00000020 00000000 [ 2.340213@1] e428 ef2d8cc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.348534@1] e448 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.356858@1] Process kthread_hdmi (pid: 31, stack limit = 0xef36a238) [ 2.363359@1] Stack: (0xef36bea8 to 0xef36c000) [ 2.367869@1] bea0: c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 [ 2.376190@1] bec0: c0e1ecb8 15000013 14001000 00000000 00000001 c06525a0 00000000 00000000 [ 2.384511@1] bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.392833@1] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.401155@1] bf20: 00000000 00000000 c0e1e3e8 c0e1e3e8 c0e1e3e8 c0b7ce34 13000002 c0651dd4 [ 2.409476@1] bf40: ef2d8cc0 ef279df0 00000000 c0e1e3e8 c0651970 00000000 00000000 00000000 [ 2.417798@1] bf60: 00000000 c0049920 ef36bf94 00000000 00000003 c0e1e3e8 00000000 00000000 [ 2.426119@1] bf80: ef36bf80 ef36bf80 00000000 00000000 ef36bf90 ef36bf90 ef36bfac ef279df0 [ 2.434440@1] bfa0: c0049870 00000000 00000000 c000df80 00000000 00000000 00000000 00000000 [ 2.442762@1] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.451083@1] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 2.459420@1] [<c002370c>] (hdmitx_set_audmode+0x330/0x788) from [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) [ 2.469119@1] [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) from [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) [ 2.478656@1] [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) from [<c0049920>] (kthread+0xb0/0xb8) [ 2.487323@1] [<c0049920>] (kthread+0xb0/0xb8) from [<c000df80>] (ret_from_fork+0x14/0x34) [ 2.495552@1] Code: e353000b 1a000000 e1a08108 e3071b20 (e5970000) [ 2.501852@1] ---[ end trace 9745405e462b76ff ]--- [ 2.501865@0] usbcore: registered new device driver usb [ 2.501924@0] pps_core: LinuxPPS API ver. 1 registered [ 2.501926@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.501937@0] PTP clock support registered [ 2.502082@0] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 2.502086@0] TV mode 1080p selected. [ 2.502090@0] already display in uboot [ 2.502092@0] vinfo mode is: 1080p [ 2.504017@0] call aml_pmu_probe_init in [ 2.504061@0] aml_pmus_probe, child name:rn5t618 [ 2.504064@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 2.504324@0] board_has_battery:false [ 2.504329@0] [DVFS]aml_dvfs_register_driver, driver rn5t618-dvfs regist success, mask:7, source id:1 [ 2.504332@0] [RN5T618]ricoh_pmu_probe, 287 [ 2.505126@0] [RN5T618]coulomb_flag:0x20 [ 2.505127@0] [RN5T618]no saved coulomb counter [ 2.505158@0] ricoh_pmu_probe, 302 [ 2.505163@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 2.505360@0] Advanced Linux Sound Architecture Driver Initialized. [ 2.604137@0] Switching to clocksource Timer-E [ 2.608309@0] FS-Cache: Loaded [ 2.615167@0] NET: Registered protocol family 2 [ 2.616158@0] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 2.622943@0] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.629531@0] TCP: Hash tables configured (established 4096 bind 4096) [ 2.636007@0] TCP: reno registered [ 2.639367@0] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.645347@0] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.651886@0] NET: Registered protocol family 1 [ 2.656427@0] RPC: Registered named UNIX socket transport module. [ 2.662337@0] RPC: Registered udp transport module. [ 2.667184@0] RPC: Registered tcp transport module. [ 2.672041@0] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.678681@0] wifi_dev_probe [ 2.681488@0] wifi_dt : interrupt_pin=GPIOX_21 [ 2.685906@0] wifi_dt : irq_num=null [ 2.689467@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 2.694572@0] wifi_dt : power_on_pin=GPIOAO_6 [ 2.698931@0] wifi_dt : power_on_pin2=GPIOX_11 [ 2.703331@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 2.712349@0] Unpacking initramfs... [ 2.838438@0] Freeing initrd memory: 3188K [ 2.839134@0] audit: initializing netlink socket (disabled) [ 2.842488@0] type=2000 audit(2.750:1): initialized [ 2.847881@0] bounce pool size: 64 pages [ 2.855525@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.857337@0] exFAT: Core Version 1.2.4 [ 2.861033@0] exFAT: FS Version 1.2.4 [ 2.865306@0] NFS: Registering the id_resolver key type [ 2.870013@0] Key type id_resolver registered [ 2.874187@0] Key type id_legacy registered [ 2.878680@0] NTFS driver 2.1.30 [Flags: R/O]. [ 2.883051@0] fuse init (API version 7.22) [ 2.887294@0] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.897147@0] SGI XFS with security attributes, large block/inode numbers, no debug enabled [ 2.901262@0] bio: create slab <bio-1> at 1 [ 2.904783@0] Btrfs loaded [ 2.907017@0] msgmni has been set to 723 [ 2.910812@0] SELinux: Registering netfilter hooks [ 2.916811@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.923184@0] io scheduler noop registered [ 2.927237@0] io scheduler deadline registered [ 2.931686@0] io scheduler cfq registered (default) [ 2.936521@0] io scheduler fiops registered [ 2.942854@0] loop: module loaded [ 2.944375@0] tun: Universal TUN/TAP device driver, 1.6 [ 2.949184@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.955811@0] PPP generic driver version 2.4.2 [ 2.959997@0] PPP BSD Compression module registered [ 2.964774@0] PPP Deflate Compression module registered [ 2.969987@0] PPP MPPE Compression module registered [ 2.974913@0] NET: Registered protocol family 24 [ 2.979552@0] usbcore: registered new interface driver asix [ 2.985097@0] usbcore: registered new interface driver ax88179_178a [ 2.991332@0] usbcore: registered new interface driver cdc_ether [ 2.997300@0] usbcore: registered new interface driver dm9601 [ 3.003027@0] usbcore: registered new interface driver net1080 [ 3.008834@0] usbcore: registered new interface driver cdc_subset [ 3.014896@0] usbcore: registered new interface driver zaurus [ 3.020640@0] usbcore: registered new interface driver cdc_ncm [ 3.026421@0] usbcore: registered new interface driver qf9700 [ 3.032163@0] usbcore: registered new interface driver sr9600 [ 3.037928@0] usbcore: registered new interface driver cdc_acm [ 3.043660@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.051840@0] usbcore: registered new interface driver usb-storage [ 3.058114@0] mousedev: PS/2 mouse device common for all mice [ 3.063856@0] usbcore: registered new interface driver xpad [ 3.069262@0] usbcore: registered new interface driver usb_acecad [ 3.075311@0] usbcore: registered new interface driver aiptek [ 3.081046@0] usbcore: registered new interface driver gtco [ 3.086579@0] usbcore: registered new interface driver hanwang [ 3.092396@0] usbcore: registered new interface driver kbtab [ 3.098026@0] usbcore: registered new interface driver wacom [ 3.103716@0] i2c /dev entries driver [ 3.107695@0] device-mapper: uevent: version 1.0.3 [ 3.112220@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 3.120989@0] hidraw: raw HID events driver (C) Jiri Kosina [ 3.126308@0] usbcore: registered new interface driver usbhid [ 3.131908@0] usbhid: USB HID core driver [ 3.136144@0] zram: Created 1 device(s) ... [ 3.140269@0] ashmem: initialized [ 3.143418@0] logger: created 256K log 'log_main' [ 3.148099@0] logger: created 256K log 'log_events' [ 3.152959@0] logger: created 256K log 'log_radio' [ 3.157719@0] logger: created 256K log 'log_system' [ 3.162516@0] vout_init_module [ 3.165560@0] start init vout module [ 3.169111@0] create vout attribute ok [ 3.172952@0] ge2d_init [ 3.175324@0] ge2d_dev major:244 [ 3.178627@0] ge2d start monitor [ 3.181785@0] osd_init [ 3.181791@1] ge2d workqueue monitor start [ 3.188197@0] osd_probe, vinfo:c0855140 [ 3.192131@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 3.200127@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.205661@0] init fbdev bpp is :32 [ 3.209135@0] ---------------clear framebuffer0 memory [ 3.252667@0] Console: switching to colour frame buffer device 240x67 [ 3.279181@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0a00000, size=1024K [ 3.283750@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.289306@0] don't find to display_size_default from mesonfb-dts [ 3.295364@0] init fbdev bpp is :24 [ 3.312436@0] osd probe ok [ 3.312576@0] enter aml_sysled_init [ 3.313268@0] DI: di_init [ 3.315636@0] DI: di_probe [ 3.318536@0] aml_wdt_driver_init,306 [ 3.321946@0] ** disable watchdog [ 3.325357@0] keys=========================================== [ 3.331001@0] keys_devno=f100000 [ 3.334258@0] securitykey: device aml_keys created [ 3.338970@0] amlkeys=0 [ 3.341384@0] platform_driver_register--aml_keys_driver-------------------- [ 3.348514@0] set uart_ao pinmux use pinctrl subsystem [ 3.353412@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.357584@0] start uart_ao_ttyS0:(irq = 122) [ 3.361939@0] register uart_ao ok [ 3.365344@0] set uart_a pinmux use pinctrl subsystem [ 3.370256@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.374400@0] start uart_a_ttyS1:(irq = 58) [ 3.378577@0] register uart_a ok [ 3.381891@0] start uart_d_ttyS4:(irq = 126) [ 3.386005@0] register uart_d ok [ 3.389309@0] dwc_otg: version 3.10a 12-MAY-2014 [ 3.393822@0] dwc_otg_driver_probe NOT match [ 3.398079@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 3.406669@0] USB (1) use clock source: XTAL input [ 3.432466@0] Core Release: 3.10a [ 3.432548@0] Setting default values for core params [ 3.435146@0] curmode: 1, host_only: 1 [ 3.459324@0] Using Buffer DMA mode [ 3.463377@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.467438@0] Working on port type = HOST [ 3.471524@0] dwc_otg lm1: DWC OTG Controller [ 3.475567@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 3.481328@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 3.486236@0] -------hcd->flags.d32 = 0 [ 3.490206@0] Init: Port Power? op_state=1 [ 3.494132@0] Init1: Power Port (0) [ 3.498112@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.504545@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.511910@0] usb usb1: Product: DWC OTG Controller [ 3.516751@0] usb usb1: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.522743@0] usb usb1: SerialNumber: lm1 [ 3.527119@0] hub 1-0:1.0: USB hub found [ 3.531273@0] hub 1-0:1.0: 1 port detected [ 3.535503@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 3.543298@0] USB (0) use clock source: XTAL input [ 3.569085@0] Core Release: 3.10a [ 3.573360@0] Setting default values for core params [ 3.577712@0] curmode: 1, host_only: 0 [ 3.642155@0] Using Buffer DMA mode [ 3.646494@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.650876@0] Working on port type = OTG [ 3.655189@0] Current port type: SLAVE [ 3.659463@0] dwc_otg lm0: DWC OTG Controller [ 3.663696@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 3.669071@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 3.674013@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.680941@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.688303@0] usb usb2: Product: DWC OTG Controller [ 3.693143@0] usb usb2: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.699140@0] usb usb2: SerialNumber: lm0 [ 3.703476@0] hub 2-0:1.0: USB hub found [ 3.707610@0] hub 2-0:1.0: 1 port detected [ 3.711817@0] Dedicated Tx FIFOs mode [ 3.716014@0] using timer detect id change, ef5c1400 [ 3.720309@0] boot_device_flag : 0 [ 3.724494@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 3.728294@2] Indeed it is in host mode hprt0 = 00021501 [ 3.737877@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 3.744734@0] amlnf_phy_init : amlnf init flag 0 [ 3.749390@0] ######STS IRQ mode for nand driver [ 3.753959@0] NAND device id: ad de 14 a7 42 4a ad de [ 3.758952@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 3.805605@0] AML_NAND_NEW_OOB : new oob [ 3.810006@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 3.816758@0] boot_device_flag = 0 [ 3.824092@0] uncorrect ecc here at page:2048, chip:0 [ 3.828698@0] blk check good but read failed at chip 0 page 2048 [ 3.834575@0] hynix nand get default reg value at blk:8, page:2049 [ 3.841829@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 3.853277@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 3.861175@0] nand shipped bbt at block 0 [ 3.868568@0] uncorrect ecc here at page:2048, chip:0 [ 3.873289@0] nand blk check good but read failed at chip 0 page 2048 [ 3.908194@2] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 3.914045@3] Indeed it is in host mode hprt0 = 00001101 [ 3.927782@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 [ 3.935879@0] i=0,register --- nand_key [ 3.940669@0] nand adjust phy offset : block 4 [ 3.945423@0] nand adjust phy offset : block 4 [ 3.950168@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 3.958948@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 3.968485@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 3.979238@0] bad block count = 0 [ 3.979238@0] [ 3.991865@0] bad block count = 0 [ 3.991865@0] [ 4.012409@0] bad block count = 0 [ 4.012409@0] [ 4.021637@0] amlnand_add_nftl: [ 4.026198@0] Creating 1 ntd partitions [ 4.030750@0] block_num 76 [ 4.036423@0] ------init_ntd [ 4.041079@0] ntd: Giving out device 0 to nfcache [ 4.045587@0] Creating 7 ntd partitions [ 4.050128@0] block_num 204 [ 4.057846@0] ntd: Giving out device 1 to nfcode [ 4.062269@0] Creating 1 ntd partitions [ 4.066656@0] block_num 720 [ 4.082317@0] ntd: Giving out device 2 to nfdata [ 4.086914@0] ethernet_driver probe! [ 4.091298@0] Please config phy interface. [ 4.095668@0] Please config savepowermode. [ 4.100024@0] Please config reset_pin_enable. [ 4.104360@0] Please config reset_delay. [ 4.108674@0] Please config reset_pin. [ 4.112920@0] ethernetinit(dbg[c0b77388]=1) [ 4.117174@0] ethernet base addr is fe0c0000 [ 4.119360@3] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.119365@3] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.119368@3] usb 1-1: Product: USB2.0 Hub [ 4.119788@3] hub 1-1:1.0: USB hub found [ 4.120047@3] hub 1-1:1.0: 4 ports detected [ 4.146612@3] write mac add to:ef5f1ac8: 00 01 23 cd ee af |..#...| [ 4.158569@0] libphy: AMLMAC MII Bus: probed [ 4.162840@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 4.167629@0] Amlogic A/V streaming port init [ 4.172547@0] buffersize=262144,0,start=0 [ 4.176757@0] Subtitle stbuf alloced at 0xee6c0000, size = 262144 [ 4.181626@0] changed the (2) buffer size from 0 to 262144 [ 4.187199@0] init vdec memsource 9a00000->199fffff [ 4.192019@0] [tsync_pcr_init]init success. [ 4.196169@0] amvideocap_init_module [ 4.200368@0] regist mpeg12 codec profile [ 4.204458@0] regist mpeg4 codec profile [ 4.208468@0] amvdec_vc1 module init [ 4.212423@0] regist vc1 codec profile [ 4.216268@0] amvdec_h264 module init [ 4.220167@0] regist h264 codec profile [ 4.223960@0] amvdec_h264mvc module init [ 4.227741@0] regist hmvc codec profile [ 4.231436@0] amvdec_h264_4k2k module init [ 4.235189@0] regist h264_4k2k codec profile [ 4.238848@0] amvdec_h265 module init [ 4.242498@0] regist hevc_unsupport codec profile [ 4.246739@0] regist mjpeg codec profile [ 4.250617@0] amvdec_real module init [ 4.254276@0] amvdec_avs module init [ 4.257886@0] amvenc_avc memory resource undefined. [ 4.262670@0] amvenc_avc memory is invaild, probe fail! [ 4.267856@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 4.274335@0] jpegenc module init [ 4.277836@0] alloc_keep_buffer keep_y_addr ee200000 [ 4.282535@0] alloc_keep_buffer keep_u_addr ee800000 [ 4.287447@0] alloc_keep_buffer keep_v_addr ee780000 [ 4.292398@0] yaddr=ee200000,u_addr=ee800000,v_addr=ee780000 [ 4.298243@0] create_ge2d_work_queue video task ok [ 4.303130@0] efuse=========================================== [ 4.308780@0] efuse: device efuse created [ 4.312727@0] efuse-------------------------------------------- [ 4.318576@0] SARADC Driver init. [ 4.322181@0] __saradc_probe__ [ 4.398528@3] usb 1-1.3: new full-speed USB device number 3 using dwc_otg [ 4.468306@0] saradc calibration: ref_val = 508 [ 4.471938@0] saradc calibration: ref_nominal = 512 [ 4.475663@0] saradc calibration: coef = 4064 [ 4.480193@0] ir irblaster probe [ 4.483857@0] Remote Driver [ 4.487454@0] Remote platform_data g_remote_base=fe600580 [ 4.491391@0] set drvdata completed [ 4.494986@0] device_create_file completed [ 4.499454@0] input: aml_keypad as /devices/platform/meson-remote/input/input0 [ 4.501238@3] usb 1-1.3: New USB device found, idVendor=0951, idProduct=16d2 [ 4.501243@3] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.501247@3] usb 1-1.3: Product: HyperX Alloy FPS Pro Mechanical Gaming Keyboard [ 4.501250@3] usb 1-1.3: Manufacturer: Kingston [ 4.503326@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.0/input/input1 [ 4.503508@3] hid-generic 0003:0951:16D2.0001: input,hidraw0: USB HID v1.11 Keyboard [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input0 [ 4.505358@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.1/input/input2 [ 4.505642@3] hid-generic 0003:0951:16D2.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input1 [ 4.512658@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.2/input/input3 [ 4.512824@3] hid-generic 0003:0951:16D2.0003: input,hidraw2: USB HID v1.11 Keyboard [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input2 [ 4.613083@0] input_register_device completed [ 4.618101@0] [0xffffff00] = 0x1dd0190 [ 4.623094@0] [0xffffff04] = 0xf800ca [ 4.627996@0] [0xffffff08] = 0x82006e [ 4.632855@0] [0xffffff0c] = 0x3c0030 [ 4.637632@0] [0xffffff10] = 0x30fa0013 [ 4.642372@0] [0xffffff18] = 0x6f19000 [ 4.647070@0] [0xffffff1c] = 0xbe40 [ 4.651714@0] [0x0] = 0xfa00a0 [ 4.656289@0] [0x4] = 0xfa00a0 [ 4.660819@0] [0x8] = 0xfa00a0 [ 4.665291@0] [0xc] = 0x640030 [ 4.669738@0] [0x10] = 0x30fa0013 [ 4.674160@0] [0x18] = 0x961b800 [ 4.678586@0] [0x1c] = 0x9740 [ 4.682978@0] [0x20] = 0x104 [ 4.687340@0] [0x24] = 0x0 [ 4.691684@0] [0x28] = 0x0 [ 4.695998@0] set_remote_mode[69] [ 4.700343@0] remote config major:237 [ 4.704752@0] physical address:0x2e91e000 [ 4.709138@0] Meson KeyInput init [ 4.713576@0] GPIO Keypad Driver init. [ 4.717969@0] ==gpio_key_probe== [ 4.722317@0] reg:2620,clearmask=400040,setmask=1 [ 4.726668@0] reg:2622,clearmask=ff0000,set pin=3 [ 4.731019@0] reg:2623,clearmask=7000000,setmask=7 [ 4.735411@0] reg:2620,clearmask=800080,setmask=10001 [ 4.740348@0] reg:2622,clearmask=ff000000,set pin=3 [ 4.745201@0] reg:2623,clearmask=70000000,setmask=7 [ 4.750130@0] power key(116) registed. [ 4.754525@0] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input4 [ 4.761253@0] gpio keypad register input device completed. [ 4.766637@0] gpio keypad major:236 [ 4.771216@0] spi_nor_init [ 4.775688@0] amlogic_spi_nor_probe: [ 4.780112@0] amlogic_spi->state_name:default [ 4.784541@0] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 4.790960@0] check_storage_device : spi boot_device_flag : 0 [ 4.796626@0] spi_nor_probe [ 4.801056@0] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 4.806225@0] Creating 2 MTD partitions on "apollospi:32766": [ 4.811361@0] 0x000000000000-0x000000100000 : "bootloader" [ 4.817273@0] 0x000000100000-0x000000110000 : "ubootenv" [ 4.822506@0] amlogic_spi_nor_probe over [ 4.827065@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 4.835611@0] host->base fe108c20 [ 4.840256@0] pdata->caps 7 [ 4.844828@0] pdata->caps2 0 [ 4.849363@0] get property: port, value:0x00000001 [ 4.854808@0] get property: ocr_avail, value:0x00200000 [ 4.861335@0] get property: f_min, value:0x000493e0 [ 4.867830@0] get property: f_max, value:0x02faf080 [ 4.874340@0] get property: max_req_size, value:0x00020000 [ 4.880845@0] get property: irq_in, value:0x00000003 [ 4.887325@0] get property: irq_out, value:0x00000005 [ 4.893844@0] get property: gpio_cd, str:CARD_6 [ 4.899831@0] get property: pinname, str:sd [ 4.905442@0] get property: jtag_pin, str:CARD_0 [ 4.911438@0] get property: card_type, value:0x00000005 [ 4.917932@0] get property: gpio_dat3, str:CARD_4 [ 4.923930@0] normal card in [ 4.958208@3] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 4.958216@0] reg:2620,clearmask=80008,setmask=10001 [ 4.958219@0] reg:2621,clearmask=ff000000,set pin=64 [ 4.958222@0] reg:2623,clearmask=7000,setmask=7 [ 4.958224@0] reg:2620,clearmask=200020,setmask=1 [ 4.958226@0] reg:2622,clearmask=ff00,set pin=64 [ 4.958228@0] reg:2623,clearmask=700000,setmask=7 [ 4.958369@0] pdata->caps 80000507 [ 4.958372@0] pdata->caps2 0 [ 4.958374@0] get property: port, value:0x00000002 [ 4.958377@0] get property: ocr_avail, value:0x00200000 [ 4.958379@0] get property: f_min, value:0x000493e0 [ 4.958381@0] get property: f_max, value:0x02faf080 [ 4.958383@0] get property: f_max_w, value:0x02faf080 [ 4.958385@0] get property: max_req_size, value:0x00020000 [ 4.958392@0] get property: pinname, str:emmc [ 4.958394@0] get property: card_type, value:0x00000001 [ 4.958398@0] get property: gpio_dat3, str:BOOT_3 [ 4.958401@0] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=5 [ 5.096900@2] sd: new high speed SDHC card at address 0001, clock 35416666, 4-bit-bus-width [ 5.103389@2] mmcblk0: sd:0001 SD32G 29.5 GiB [ 5.128251@0] pdata->caps 107 [ 5.131836@0] pdata->caps2 0 [ 5.135368@0] get property: port, value:0x00000000 [ 5.135418@2] mmcblk0: p1 p2 [ 5.135763@2] emmc: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 5.135766@2] aml_emmc_hw_reset 1338 [ 5.153183@0] get property: ocr_avail, value:0x00200000 [ 5.159604@0] get property: f_min, value:0x000493e0 [ 5.166100@0] get property: f_max, value:0x02faf080 [ 5.172604@0] get property: max_req_size, value:0x00020000 [ 5.179116@0] get property: pinname, str:sdio [ 5.184899@0] get property: card_type, value:0x00000003 [ 6.148196@0] [aml_sdio_timeout][0;40;33m time_start_cnt:992 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:998 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[ 9.274101@2] emmc: mmc_rescan_try_freq: trying to init card at 300000 Hz [ 9.318184@2] aml_emmc_hw_reset 1338 [aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:993 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:991 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_probe] aml_sdio_probe() success! [ 13.516587@0] [dsp]DSP start addr 0xc5e00000 [ 13.524852@0] [dsp]register dsp to char divece(257) [ 13.533308@0] amlogic audio spdif interface device init! [ 13.541571@0] name=nand_key nand_key [ 13.550350@0] register_aes_algorithm:488,new way [ 13.559883@0] key name:keyexample, key data:1234567890 [ 13.568793@0] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0 [ 13.578730@0] [AML1216]call aml1216_battery_init, ret = 0 [ 13.587110@0] [AML1218]call aml1218_battery_init, ret = 0 [ 13.595440@0] [RN5T618]call rn5t618_battery_probe in[ 13.603902@0] input: rn5t618_pmu as /devices/i2c-0/0-0032/rn5t618_pmu.0/input/input5 [ 13.614607@0] [RN5T618]use BSP configed battery parameters [ 13.623265@0] [RN5T618] NO BATTERY_PARAMETERS FOUND [ 13.637890@0] [RN5T618]call rn5t618_battery_probe exit, ret:0 [ 13.638041@0] [RN5T618]call rn5t618_battery_init, ret = 0 [ 13.655821@0] amaudio2: device amaudio2 created [ 13.664665@0] Amlogic CEC Driver, (c) 2016 Gerald Dachs, Version: 0.0.1 [ 13.674565@0] Error: Didn't get power valid value --- wifi_power_probe 323 [ 13.684681@0] wifi_power power_gpio is 6 [ 13.693573@0] wifi_power power_gpio2 is 123 [ 13.702534@0] bcmdhd_wlan_init() [ 13.711286@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[0]=ef36a780, size=3760 [ 13.721460@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[1]=ef36a6c0, size=3760 [ 13.731588@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[2]=ef36a600, size=3760 [ 13.741707@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[3]=ef36a540, size=3760 [ 13.751785@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[4]=ef36a480, size=3760 [ 13.761809@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[5]=ef36a3c0, size=3760 [ 13.771779@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[6]=ef36a300, size=3760 [ 13.781674@0] 1 bcmdhd_init_wlan_mem: wlan_static_skb[7]=ef36a240, size=3760 [ 13.791491@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[8]=ef36a180, size=7856 [ 13.801307@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[9]=ef36a0c0, size=7856 [ 13.811113@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[10]=ef36a000, size=7856 [ 13.821021@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[11]=ef36ab40, size=7856 [ 13.830889@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[12]=ef36ac00, size=7856 [ 13.840721@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[13]=ef445f00, size=7856 [ 13.850489@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[14]=ef445e40, size=7856 [ 13.859927@0] 2 bcmdhd_init_wlan_mem: wlan_static_skb[15]=ef445d80, size=7856 [ 13.869056@0] 3 bcmdhd_init_wlan_mem: wlan_static_skb[16]=ef445cc0, size=16048 [ 13.878210@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[0]=ef36a780, size=20504 [ 13.886925@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[1]=ef36a6c0, size=20504 [ 13.895330@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[2]=ef36a600, size=81944 [ 13.903692@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[3]=ef36a540, size=163864 [ 13.911839@0] 4 bcmdhd_init_wlan_mem: wlan_mem_array[4]=ef36a480, size=20504 [ 13.919595@0] 5 bcmdhd_init_wlan_mem: wlan_static_scan_buf0=ee9b0000, size=65536 [ 13.927669@0] 6 bcmdhd_init_wlan_mem: wlan_static_scan_buf1=ee9e0000, size=65536 [ 13.935460@0] bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 13.941258@0] amlogic rfkill init [ 13.946962@0] Error: Driver 'bt-dev' is already registered, aborting... [ 13.954338@0] enter rt5616_modinit [ 13.960173@0] dummy_codec_platform_probe [ 13.965713@0] == ES8323 == es8323_modinit() [ 13.970948@0] *****enter pcm2bt_codec_probe [ 13.976075@0] pcm2bt_codec_probe ok! [ 13.981237@0] enter aml_i2s_dai_probe [ 13.985797@0] i2s get no clk src setting in dts, use the default mpll 0 [ 13.991379@0] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000 [ 13.999362@0] enter aml_pcm_dai_probe [ 14.003534@0] [aml-spdif-dai]enter aml_dai_spdif_init [ 14.007912@0] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4 [ 14.015046@0] audio_set_958_clk, freq=4, [ 14.018942@0] IEC958 16bit [ 14.022549@0] hdmitx: audio: aout notify rate 48000 [ 14.026458@0] hdmitx: audio: aout notify size 16 [ 14.031082@0] hdmitx: audio: aout notify format CT_PCM [ 14.036169@0] hdmitx: audio: audio channel num is 1 [ 14.041042@0] hdmitx: audio: SPDIF [ 14.044543@0] hdmitx: audio: current VIC: 16 [ 14.048672@0] hdmitx: audio: audio sample rate: 3 [ 14.053330@0] hdmitx: audio: set audio N para [ 14.057668@0] hdmitx: audio: PCM out to HDMI [ 14.061927@0] hdmitx: audio: i2s_to_spdif_flag:1 [ 14.066600@0] hdmitx: audio: Enable audio spdif to HDMI [ 14.071812@0] hdmitx: audio: Audio Type: PCM [ 14.076082@0] hdmitx: audio: set audio param [ 14.080364@0] [aml-spdif-dai]aml_spdif_probe [ 14.084624@0] test codec dummy_codec [ 14.088093@0] using external codec, index = 1 [ 14.092441@0] using external dummy codec [ 14.096406@0] enter spdif_dit_probe [ 14.099896@0] aml_spdif_unmute [ 14.103130@0] codec_name = dummy_codec.0 [ 14.107197@0] enter aml_asoc_init [ 14.110323@0] p_aml_audio->hp_disable=1 [ 14.114107@0] falied to get spk event delay time paraments from dts file [ 14.120793@0] spk_event delay_time = 0 [ 14.125455@0] aml-i2s 0:playback preallocate_dma_buffer: area=f0b8e000, addr=2e200000, size=524288 [ 14.133680@0] aml-i2s 1:capture preallocate_dma_buffer: area=f0c10000, addr=2e160000, size=65536 [ 14.142214@0] aml_snd_m8 aml_m8_sound_card.5: dummy_codec <-> aml-i2s-dai.0 mapping ok [ 14.150326@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 0 [ 14.156153@0] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0c31000 buf->addr: 0x2e150000 buf->bytes: 65536 [ 14.166566@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 1 [ 14.172549@0] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0c42000 buf->addr: 0x2e180000 buf->bytes: 65536 [ 14.182947@0] aml_snd_m8 aml_m8_sound_card.5: pcm2bt-pcm <-> aml-pcm-dai.0 mapping ok [ 14.191822@0] aml-i2s 0:playback preallocate_dma_buffer: area=f0c53000, addr=2e300000, size=524288 [ 14.199982@0] aml-i2s 1:capture preallocate_dma_buffer: area=f0cd5000, addr=2e2a0000, size=65536 [ 14.208527@0] aml_snd_m8 aml_m8_sound_card.5: dit-hifi <-> aml-spdif-dai.0 mapping ok [ 14.217068@0] -----ext_codec=1--- [ 14.221434@0] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0 [ 14.226308@0] GACT probability NOT on [ 14.230796@0] Mirror/redirect action on [ 14.235234@0] u32 classifier [ 14.239687@0] Actions configured [ 14.244150@0] Netfilter messages via NETLINK v0.30. [ 14.248752@0] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 14.254419@0] ctnetlink v0.93: registering with nfnetlink. [ 14.259667@0] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 14.266711@0] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 14.272875@0] xt_time: kernel timezone is -0000 [ 14.277644@0] ipip: IPv4 over IPv4 tunneling driver [ 14.282719@0] ip_tables: (C) 2000-2006 Netfilter Core Team [ 14.287607@0] arp_tables: (C) 2002 David S. Miller [ 14.292348@0] TCP: cubic registered [ 14.297016@0] Initializing XFRM netlink socket [ 14.302038@0] NET: Registered protocol family 10 [ 14.307390@0] mip6: Mobile IPv6 [ 14.312114@0] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 14.316995@0] sit: IPv6 over IPv4 tunneling driver [ 14.322273@0] NET: Registered protocol family 17 [ 14.326900@0] NET: Registered protocol family 15 [ 14.331534@0] Bridge firewalling registered [ 14.336098@0] l2tp_core: L2TP core driver, V2.0 [ 14.340596@0] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 14.345205@0] l2tp_netlink: L2TP netlink interface [ 14.349997@0] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 14.356042@0] l2tp_debugfs: L2TP debugfs support [ 14.360663@0] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 14.367253@0] NET: Registered protocol family 35 [ 14.372016@0] Key type dns_resolver registered [ 14.377077@0] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 14.384089@0] Registering SWP/SWPB emulation handler [ 14.388982@0] enter meson_pm_init [ 14.393945@0] enter meson_pm_probe! [ 14.398824@0] ---meson_pm_probe----set output pin success [ 14.403731@0] meson_pm_probe done ! [ 14.408981@0] regulator-dummy: disabling [ 14.414097@0] file system registered [ 14.419559@0] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 14.425953@0] android_usb gadget: Number of LUNs=2 [ 14.430968@0] lun0: LUN: removable file: (no medium) [ 14.435995@0] lun1: LUN: removable file: (no medium) [ 14.441131@0] android_usb gadget: android_usb ready [ 14.446570@0] aml_rtc rtc.0: setting system clock to 2018-05-22 10:06:50 UTC (1526983610) [ 14.454239@0] ### dt-test ### No testcase data in device tree; not running tests [ 14.461668@0] meson_cpufreq: no voltage_control prop [ 14.466888@0] voltage_control = 0 [ 14.473306@0] buf[0]=a7,buf[1]=9b,err=4 [ 14.476920@0] M8:adc=442,TS_C=7,flag=1 [ 14.480491@0] efuse_flag=a [ 14.483984@0] amlogic_thermal_probe, this chip is trimmed, use thermal [ 14.488371@0] amlogic-thermal aml_thermal: amlogic thermal probe start [ 14.494862@0] #thermal-cells=7 [ 14.498272@0] pdata->temp_trip_count=4 [ 14.501623@0] temperature=70000 on trip point=0 [ 14.506128@0] fixing high_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.513251@0] fixing low_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.519883@0] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511 [ 14.525978@0] cpu[0] core num==3 [ 14.529200@0] gpu[0] core num==5 [ 14.532393@0] temperature=80000 on trip point=1 [ 14.536900@0] fixing high_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.543868@0] fixing low_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.550565@0] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435 [ 14.556751@0] cpu[1] core num==2 [ 14.559967@0] gpu[1] core num==4 [ 14.563170@0] temperature=90000 on trip point=2 [ 14.567672@0] fixing high_freq=800001 to 696000 at trip point 2,level=11 [ 14.574585@0] fixing low_freq=800001 to 696000 at trip point 2,level=11 [ 14.581158@0] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328 [ 14.587349@0] cpu[2] core num==2 [ 14.590566@0] gpu[2] core num==3 [ 14.593764@0] temperature=260000 on trip point=3 [ 14.598372@0] fixing high_freq=-1 to -22 at trip point 3,level=-1 [ 14.604860@0] fixing low_freq=-1 to -22 at trip point 3,level=-1 [ 14.610867@0] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1 [ 14.616653@0] cpu[3] core num==-1 [ 14.619964@0] gpu[3] core num==-1 [ 14.623238@0] idle interval=1000 [ 14.626444@0] pdata->name:aml_thermal [ 14.630225@0] tmp_trip[0].cpu_core_upper=1 [ 14.634169@0] tmp_trip[1].cpu_core_upper=2 [ 14.638250@0] tmp_trip[2].cpu_core_upper=2 [ 14.642312@0] tmp_trip[3].cpu_core_upper=-1 [ 14.646479@0] aml_thermal bind thermal-cpucore-0 okay ! [ 14.651698@0] aml_thermal bind thermal-cpufreq-0 okay ! [ 14.656992@0] amlogic: Kernel Thermal management registered [ 14.662436@0] amlogic-thermal aml_thermal: amlogic thermal probe done [ 14.668908@0] ALSA device list: [ 14.671955@0] #0: AML-M8AUDIO [ 14.675286@0] Freeing unused kernel memory: 228K [ 14.685883@3] tvmode set to 720p [ 14.685883@3] [ 14.691554@3] mode is 11,sync_duration_den=1,sync_duration_num=60 [ 14.696776@3] TV mode 720p selected. [ 14.700355@3] tvoutc_setmode[505] [ 14.703617@3] tvoutc_setmode[516] mode is 11 [ 14.707865@3] vinfo mode is: 720p [ 14.711177@3] new mode 720p set ok [ 14.714562@3] hdmitx: video: get current mode: 720p [ 14.719412@3] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.725134@3] hdmitx: video: get current mode: 720p [ 14.730008@3] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.735707@3] hdmitx: system: gate/pwr cmd: 7 [ 14.740113@3] hdmitx: system: already init VIC = 0 Now VIC = 4 [ 14.745929@3] hdmitx: system: 4 (cd0,cs0,pm1,vd0,1) [ 14.750979@3] hdmitx: system: gate/pwr cmd: 0 [ 14.755288@3] hdmitx: system: hw reset [ 14.760110@3] hdmitx: audio: SPDIF [ 14.763648@3] hdmitx: system: reconfig packet setting done [ 14.787866@3] hdmitx: system: set pll [ 14.791391@3] hdmitx: system: param->VIC:4 [ 14.794830@3] mode is: 11 [ 14.798234@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.801597@3] viu chan = 1 [ 14.804938@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.808313@3] config HPLL [ 14.811610@3] set_hpll_clk_out[81] clk = 2970 [ 14.828178@3] config HPLL done [ 14.830729@3] enc_vpu_bridge_reset[292] [ 14.968243@3] hdmitx: system: phy setting done [ 14.983457@3] Sink is HDMI device [ 14.998383@3] No sink attached [ 15.013217@3] hdmitx: audio: audio channel num is 1 [ 15.033217@3] hdmitx: audio: SPDIF [ 15.054976@3] hdmitx: audio: current VIC: 4 [ 15.076525@3] hdmitx: audio: audio sample rate: 3 [ 15.098389@3] hdmitx: audio: set audio N para [ 15.119463@3] hdmitx: audio: PCM out to HDMI [ 15.122347@3] hdmitx: audio: i2s_to_spdif_flag:1 [ 15.127028@3] hdmitx: audio: Enable audio spdif to HDMI [ 15.132257@3] hdmitx: audio: Audio Type: PCM [ 15.150921@3] set_vout_mode[183] [ 15.631345@0] [RN5T618]battery vol change: 0->0 [ 21.724669@3] force enable DISCARD here for ext4 fs [ 21.907828@3] checked enable EXT4 DISCARD here [ 21.921576@3] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard [ 21.929973@3] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 23.056083@2] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 23.128602@2] systemd[1]: Detected architecture arm. [ 23.324383@2] systemd[1]: Set hostname to <vegas812>. [ 23.398355@2] Changing uart_ao_ttyS0: baud from 0 to 115200 [ 24.465160@2] systemd[1]: Listening on udev Kernel Socket. [ 24.472182@2] systemd[1]: Listening on fsck to fsckd communication Socket. [ 24.480596@2] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 24.491857@2] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 24.500861@2] systemd[1]: Created slice User and Session Slice. [ 24.508726@2] systemd[1]: Listening on Journal Socket (/dev/log). [ 24.517038@2] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 24.528247@2] systemd[1]: Created slice System Slice. [ 24.536840@2] systemd[1]: dev-hugepages.mount: Couldn't determine result for ConditionVirtualization=!private-users, assuming failed: No such file or directory [ 24.550070@2] systemd[1]: Reached target Slices. [ 24.559309@2] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 24.569447@2] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 24.581173@2] systemd[1]: Mounting Debug File System... [ 24.591624@2] systemd[1]: Listening on Journal Socket. [ 24.603404@2] systemd[1]: Starting Nameserver information manager... [ 24.631376@2] systemd[1]: Starting Load Kernel Modules... [ 24.651300@2] systemd[1]: Starting Restore / save the current clock... [ 24.662601@2] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 24.674766@2] systemd[1]: Reached target Encrypted Volumes. [ 24.695151@2] systemd[1]: Reached target Remote File Systems. [ 24.706957@2] systemd[1]: Listening on udev Control Socket. [ 24.720445@3] systemd[1]: Starting Set the console keyboard layout... [ 24.733255@3] systemd[1]: Created slice system-getty.slice. [ 24.744484@3] systemd[1]: Listening on Syslog Socket. [ 24.757575@3] systemd[1]: Starting Remount Root and Kernel File Systems... [ 24.773235@3] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 24.795360@3] systemd[1]: Mounted Debug File System. [ 24.811355@3] systemd[1]: Started Restore / save the current clock. [ 24.825115@3] systemd[1]: Time has been changed [ 24.849129@1] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 24.855569@1] boot_device_flag : 0 [ 24.860278@3] systemd[1]: Started Nameserver information manager. [ 24.865972@1] register_ntd_blktrans start [ 24.865978@1] ntd device 250! [ 24.865983@1] ntd->name: nfcache [ 24.865988@1] adjust_block_num : 4,reserved_block_ratio 10 [ 24.865992@1] nftl version 140911a [ 24.866002@1] nftl part attr 0 [ 24.867249@1] nftl start:76,12 [ 24.867570@1] first [ 24.916793@3] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 24.935099@3] systemd[1]: Starting Create Static Device Nodes in /dev... [ 24.940999@1] average_erase_count:0 [ 24.941003@1] second 55,64 [ 24.941004@1] part->max_discard_block = 4 [ 25.000036@1] all block full!! [ 25.004996@1] all discard block full!! [ 25.010282@1] free list: [ 25.015117@1] free block cnt = 61 [ 25.019639@1] new current block is 20 [ 25.023516@1] total discard page count is 0 [ 25.027413@1] create_part_list:1235,current_used_discard_block=19,current_discard_block_used_count=160 [ 25.035419@1] unmappig_pages=15832,discarded_pages=0,mapping_pages=552 [ 25.041724@1] nftl ok! [ 25.046274@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.050415@1] aml_nftl_add_ntd ok [ 25.054233@1] ntd device 250! [ 25.058011@1] ntd->name: nfcode [ 25.061760@1] adjust_block_num : 4,reserved_block_ratio 10 [ 25.065517@1] nftl version 140911a [ 25.069245@1] nftl part attr 0 [ 25.075501@1] size_in_blk 204; total_block 203; [ 25.079180@1] nftl start:203,23 [ 25.083051@1] first [ 25.162136@3] systemd[1]: Started Set the console keyboard layout. [ 25.185057@1] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 25.192602@3] systemd[1]: Started Remount Root and Kernel File Systems. [ 25.205312@3] systemd[1]: Starting Load/Save Random Seed... [ 25.222367@3] systemd[1]: Starting udev Coldplug all Devices... [ 25.226761@2] found discard block:139 [ 25.237586@3] systemd[1]: Activating swap /var/swap... [ 25.248119@3] systemd[1]: Started Create Static Device Nodes in /dev. [ 25.262454@3] systemd[1]: Starting udev Kernel Device Manager... [ 25.271845@3] systemd[1]: Reached target Local File Systems (Pre). [ 25.289747@3] systemd[1]: Mounting /tmp... [ 25.290280@2] average_erase_count:6 [ 25.290290@2] second 202,180 [ 25.290293@2] part->max_discard_block = 4 [ 25.311423@3] systemd[1]: Mounted /tmp. [ 25.320869@3] systemd[1]: Started Load/Save Random Seed. [ 25.371998@1] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 25.378451@3] systemd[1]: Activated swap /var/swap. [ 25.388123@3] systemd[1]: Reached target Swap. [ 25.514543@2] all block full!! [ 25.519380@2] currnet_discard_block1:139 [ 25.546877@3] systemd[1]: Started udev Kernel Device Manager. [ 25.564080@2] reach the last discard page:28 [ 25.565453@1] aml_nftl_open ok! [ 25.573870@2] free list: [ 25.577542@2] free block cnt = 91 [ 25.580990@2] new current block is 39 [ 25.584439@2] total discard page count is 28 [ 25.587862@2] create_part_list:1235,current_used_discard_block=139,current_discard_block_used_count=91 [ 25.596594@2] unmappig_pages=25320,discarded_pages=119,mapping_pages=20641 [ 25.602859@2] nftl ok! [ 25.607128@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.611068@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.614973@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.619293@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.623876@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.628678@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.634206@2] Enable QUEUE_FLAG_DISCARD for NFTL [ 25.637848@2] aml_nftl_add_ntd ok [ 25.641151@2] ntd device 250! [ 25.644424@2] ntd->name: nfdata [ 25.647807@2] adjust_block_num : 4,reserved_block_ratio 10 [ 25.652171@2] nftl version 140911a [ 25.655566@2] nftl part attr 0 [ 25.668713@2] size_in_blk 720; total_block 714; [ 25.672090@2] nftl start:714,69 [ 25.677204@2] first [ 25.702883@1] systemd[1]: Started udev Coldplug all Devices. [ 25.705132@0] aml_nftl_open ok! [ 25.706735@3] aml_nftl_open ok! [ 25.707059@0] aml_nftl_open ok! [ 25.709093@3] aml_nftl_open ok! [ 25.711165@0] aml_nftl_open ok! [ 25.712163@0] aml_nftl_open ok! [ 25.713632@3] aml_nftl_open ok! [ 25.851730@3] aml_nftl_open ok! [ 25.851937@1] aml_nftl_open ok! [ 25.853070@1] aml_nftl_open ok! [ 25.854170@1] aml_nftl_open ok! [ 25.862729@1] systemd[1]: Found device /dev/ttyS0. [ 25.867872@3] aml_nftl_open ok! [ 25.868559@0] aml_nftl_open ok! [ 25.869248@0] aml_nftl_open ok! [ 25.883926@1] systemd[1]: Reached target Sound Card. [ 26.043412@2] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 26.394830@2] found discard block:701 [ 26.410778@2] average_erase_count:2 [ 26.414132@2] second 713,645 [ 26.417505@2] part->max_discard_block = 4 [ 26.529370@0] systemd[1]: Found device /dev/disk/by-label/BOOT. [ 26.577077@0] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT... [ 26.654697@0] systemd[1]: Started File System Check Daemon to report status. [ 26.848323@2] aml_audio_i2s_mute_flag: flag=0 [ 26.851340@2] aml_audio_set_spdif_mute: flag=0 [ 26.854299@2] aml_spdif_unmute [ 26.857508@2] aml_m8_set_spk: aml_m8_spk_enabled=0 [ 27.115266@0] systemd[1]: Started File System Check on /dev/disk/by-label/BOOT. [ 27.144598@0] systemd[1]: Mounting /boot... [ 27.189129@0] systemd[1]: Mounted /boot. [ 27.195974@0] systemd[1]: Reached target Local File Systems. [ 27.204881@0] systemd[1]: Starting Set console font and keymap... [ 27.214518@0] systemd[1]: Starting HDMI init... [ 27.223931@0] systemd[1]: Starting Armbian enhanced Log2Ram... [ 27.228422@1] all block full!! [ 27.229380@1] currnet_discard_block1:701 [ 27.231465@3] tvmode set to 1080p [ 27.231465@3] [ 27.231476@3] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 27.231479@3] TV mode 1080p selected. [ 27.231483@3] tvoutc_setmode[505] [ 27.231485@3] tvoutc_setmode[516] mode is 15 [ 27.231486@3] vinfo mode is: 1080p [ 27.231487@3] new mode 1080p set ok [ 27.231492@3] hdmitx: video: get current mode: 1080p [ 27.231494@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 27.231496@3] hdmitx: video: get current mode: 1080p [ 27.231501@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 27.231504@3] hdmitx: system: gate/pwr cmd: 7 [ 27.231562@3] hdmitx: system: already init VIC = 0 Now VIC = 16 [ 27.231566@3] hdmitx: system: 16 (cd0,cs0,pm1,vd0,1) [ 27.231567@3] hdmitx: system: gate/pwr cmd: 0 [ 27.231570@3] hdmitx: system: hw reset [ 27.232613@3] hdmitx: audio: SPDIF [ 27.232674@3] hdmitx: system: reconfig packet setting done [ 27.252679@3] hdmitx: system: set pll [ 27.252681@3] hdmitx: system: param->VIC:16 [ 27.252685@3] mode is: 15 [ 27.252688@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 27.252688@3] viu chan = 1 [ 27.252689@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 27.252690@3] config HPLL [ 27.252692@3] set_hpll_clk_out[81] clk = 2970 [ 27.263337@1] reach the last discard page:28 [ 27.263855@1] free list: [ 27.263857@1] free block cnt = 23 [ 27.263862@1] new current block is 263 [ 27.263863@1] total discard page count is 28 [ 27.263865@1] create_part_list:1235,current_used_discard_block=701,current_discard_block_used_count=30 [ 27.266062@1] unmappig_pages=116929,discarded_pages=3583,mapping_pages=44608 [ 27.266064@1] nftl ok! [ 27.268946@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 27.270398@1] aml_nftl_add_ntd ok [ 27.270408@1] init_aml_nftl end [ 27.272415@2] aml_nftl_open ok! [ 27.278221@1] config HPLL done [ 27.278232@1] enc_vpu_bridge_reset[292] [ 27.409089@0] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE [ 27.416807@0] systemd[1]: Failed to start Load Kernel Modules. [ 27.418212@1] hdmitx: system: phy setting done [ 27.418215@1] Sink is HDMI device [ 27.418220@1] No sink attached [ 27.418256@1] hdmitx: audio: audio channel num is 1 [ 27.418261@1] hdmitx: audio: SPDIF [ 27.418270@1] hdmitx: audio: current VIC: 16 [ 27.418271@1] hdmitx: audio: audio sample rate: 3 [ 27.418272@1] hdmitx: audio: set audio N para [ 27.418277@1] hdmitx: audio: PCM out to HDMI [ 27.418279@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 27.418280@1] hdmitx: audio: Enable audio spdif to HDMI [ 27.418283@1] hdmitx: audio: Audio Type: PCM [ 27.472835@1] set_vout_mode[183] [ 27.482385@0] systemd[1]: systemd-modules-load.service: Unit entered failed state. [ 27.487256@0] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'. [ 27.495578@0] systemd[1]: Started Set console font and keymap. [ 27.508049@0] systemd[1]: Starting Apply Kernel Variables... [ 27.516972@0] systemd[1]: Mounting FUSE Control File System... Debian GNU/Linux 9 vegas812 ttyS0 vegas812 login: [ 7630.453651@0] Restarting system. [ 7630.458109@0] Restarting Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PRE≈EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102634 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 28 -> 28 DC02 v:1150, 0x[37]: 2c -> 2c DC03 v:1500, 0x[38]: 48 -> 48 LDO01 v:2900, 0x[4c]: 50 -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12103 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489497 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x0d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=normal TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 3 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: ATran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 31715229696 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 1706 bytes read ## Executing script at 11000000 ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** reading uInitrd 3570121 bytes read reading uImage 6006126 bytes read reading dtb.img 18432 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux-3.10.108 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 6006062 Bytes = 5.7 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3570057 Bytes = 3.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 15729591 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5370001 Loading Ramdisk to 05008000, end 0536f989 ... OK Loading Device Tree to 05000000, end 05007786 ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Tue May 22 12:53:17 MSK 2018 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is 1c1fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x1c1fffff, size: 354 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(low) : 0x09a00000 - 0x19a00000 (256 MiB) [ 0.000000@0] ppmgr0(high) : 0x7cf00000 - 0x7df00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x19a00000 - 0x1aa00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x1aa00000 - 0x1c200000 ( 24 MiB) [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 8 pages/cpu @c1de1000 s8512 r8192 d16064 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 415504 [ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootfstype=ext4 rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=AE:9E:BA:9B:60:CB logo=osd1,loaded,0x7900000,1080p,full [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:15 [ 0.000000@0] full:2 [ 0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000@0] Memory: 64MB 16MB 1549MB = 1629MB total [ 0.000000@0] Memory: 1633428k/1633428k available, 34668k reserved, 1266688K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc0aeacc0 (11148 kB) [ 0.000000@0] .init : 0xc0aeb000 - 0xc0b24140 ( 229 kB) [ 0.000000@0] .data : 0xc0b26000 - 0xc0b8c0b8 ( 409 kB) [ 0.000000@0] .bss : 0xc0b8c0b8 - 0xc0e2e1b0 (2697 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [tty0] enabled [ 0.000000@0] console [ttyS0] enabled [ 0.323755@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.334053@0] pid_max: default: 32768 minimum: 301 [ 0.338921@0] Security Framework initialized [ 0.343094@0] SELinux: Initializing. [ 0.346797@0] Mount-cache hash table entries: 512 [ 0.354439@0] Initializing cgroup subsys debug [ 0.355812@0] Initializing cgroup subsys freezer [ 0.360482@0] CPU: Testing write buffer coherency: ok [ 0.365752@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.371301@0] Setting up static identity map for 0xc07f2108 - 0xc07f2160 [ 0.378016@0] L310 cache controller enabled [ 0.382107@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.389613@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.397766@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.480149@0] write pen_release: 1 [ 0.480448@1] CPU1: Booted secondary processor [ 0.480462@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.500141@0] write pen_release: 2 [ 0.508377@2] CPU2: Booted secondary processor [ 0.508390@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.520135@0] write pen_release: 3 [ 0.528369@3] CPU3: Booted secondary processor [ 0.528384@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.528450@0] Brought up 4 CPUs [ 0.541492@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.547722@0] CPU: All CPU(s) started in SVC mode. [ 0.552964@0] devtmpfs: initialized [ 0.560141@0] clkrate [ xtal ] : 24000000 [ 0.560178@0] clkrate [ pll_sys ] : 1200000000 [ 0.564539@0] clkrate [ pll_fixed ] : 2550000000 [ 0.569220@0] clkrate [ pll_vid ] : 366000000 [ 0.573648@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.579794@0] clkrate [ pll_hpll ] : 0 [ 0.583614@0] clkrate [ pll_ddr ] : 0 [ 0.587337@0] clkrate [ a9_clk ] : 1200000000 [ 0.591763@0] clkrate [ clk81 ] : 141666666 [ 0.596232@0] xor: measuring software checksum speed [ 0.700012@0] arm4regs : 1605.200 MB/sec [ 0.800012@0] 8regs : 1256.400 MB/sec [ 0.900013@0] 32regs : 1298.400 MB/sec [ 0.900046@0] xor: using function: arm4regs (1605.200 MB/sec) [ 0.904457@0] pinctrl core: initialized pinctrl subsystem [ 0.909967@0] regulator-dummy: no parameters [ 0.914224@0] NET: Registered protocol family 16 [ 0.924143@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.926488@0] VPU driver version: v03 [ 0.929418@0] vpu driver detect cpu type: m8 [ 0.933694@0] load vpu_clk in dts: 364300000Hz(7) [ 0.938357@0] vpu_probe OK [ 0.942505@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.946665@0] register lm device lm-root [ 0.950513@0] register lm device lm1 [ 0.954061@0] register lm device lm0 [ 0.957695@0] Init pinux probe! [ 0.961098@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.966445@0] tv_init_module [ 0.969296@0] major number 254 for disp [ 0.973114@0] vout_register_server [ 0.976486@0] register tv module server ok [ 0.980607@0] aml_i2c version: 20140813 [ 0.984476@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef334ca8) [ 0.990453@0] aml-i2c i2c-AO: aml i2c bus driver. [ 0.995199@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef3350a8) [ 1.001114@0] aml-i2c i2c-A: aml i2c bus driver. [ 1.005781@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3354a8) [ 1.011689@0] aml-i2c i2c-B: aml i2c bus driver. [ 1.016346@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3358a8) [ 1.022264@0] aml-i2c i2c-C: aml i2c bus driver. [ 1.026898@0] aml_pmu_init, 458 [ 1.029984@0] call aml_dvfs_init in [ 1.033593@0] hdmitx: system: amhdmitx_init [ 1.037597@0] hdmitx: system: Ver: 2014May6 [ 1.041812@0] hdmitx: system: amhdmitx_probe [ 1.046130@0] hdmitx: system: not find ao cec [ 1.050348@0] hdmitx: system: not find vend_init_data [ 1.055408@0] hdmitx: system: gate/pwr cmd: 7 [ 1.059703@0] hdmitx: system: ALREADY init VIC = 16 [ 1.064562@0] hdmitx: system: gate/pwr cmd: 0 [ 1.069281@1] hdmitx: system: reset intr mask [ 1.090487@0] hdmitx: system: irq 1 [ 1.091459@0] bio: create slab <bio-0> at 0 [ 1.200807@1] hdmitx: system: gate/pwr cmd: 4 [ 1.260063@0] raid6: int32x1 196 MB/s [ 1.410729@1] hdmitx: system: gate/pwr cmd: 5 [ 1.410762@1] hdmitx: edid: edid ready [ 1.413176@1] hdmitx: system: gate/pwr cmd: 4 [ 1.430020@0] raid6: int32x2 273 MB/s [ 1.600174@0] raid6: int32x4 342 MB/s [ 1.620731@1] hdmitx: system: gate/pwr cmd: 5 [ 1.620763@1] hdmitx: edid: edid ready [ 1.623180@1] hdmitx: edid: check sum valid [ 1.627338@1] hdmitx: edid: check sum valid [ 1.631507@1] hdmitx: edid: blk0 raw data [ 1.635487@1] 00ffffffffffff001e6dac59010101010516010380331d78ea6275a3554fa027 [ 1.642681@1] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.649875@1] 4500fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.657070@1] 34454135330a202020202020000000ff000a2020202020202020202020200106 [ 1.664265@1] [ 1.665912@1] hdmitx: edid: blk1 raw data [ 1.669899@1] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 1.677094@1] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 1.684288@1] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 1.691483@1] 22110000180000000000000000000000000000000000000000000000000000e6 [ 1.698677@1] [ 1.700711@1] hdmitx: edid: find IEEEOUT [ 1.704253@1] hdmitx: video: cann't get valid mode [ 1.708994@1] hdmitx: audio: audio channel num is 0 [ 1.713859@1] hdmitx: audio: SPDIF [ 1.717237@1] hdmitx: audio: current VIC: 16 [ 1.721482@1] hdmitx: audio: audio sample rate: 0 [ 1.726156@1] hdmitx: audio: set audio N para [ 1.730503@1] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 1.738726@1] pgd = c0004000 [ 1.741592@1] [00000000] *pgd=00000000 [ 1.745316@1] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 1.750775@1] Modules linked in: [ 1.753985@1] CPU: 1 PID: 31 Comm: kthread_hdmi Not tainted 3.10.108-vegas812 #1 [ 1.761351@1] task: ef2d8cc0 ti: ef36a000 task.ti: ef36a000 [ 1.766907@1] PC is at hdmitx_set_audmode+0x330/0x788 [ 1.770100@0] raid6: int32x8 346 MB/s [ 1.770102@0] raid6: using algorithm int32x8 (346 MB/s) [ 1.770104@0] raid6: using intx1 recovery algorithm [ 1.770303@0] SCSI subsystem initialized [ 1.770416@0] usbcore: registered new interface driver usbfs [ 1.770444@0] usbcore: registered new interface driver hub [ 1.800884@1] LR is at _raw_spin_unlock_irqrestore+0x28/0x48 [ 1.806514@1] pc : [<c002370c>] lr : [<c07f1b80>] psr: 80000113 [ 1.806514@1] sp : ef36bea8 ip : ffbf6cff fp : 00000001 [ 1.818300@1] r10: 00000000 r9 : 14001000 r8 : 00003000 [ 1.823675@1] r7 : 00000000 r6 : c0e1e3e8 r5 : c0e1ecb8 r4 : c0b47fb8 [ 1.830349@1] r3 : 00000000 r2 : 00000001 r1 : 00007b20 r0 : 00000000 [ 1.837025@1] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 1.844479@1] Control: 10c5387d Table: 0020404a DAC: 00000015 [ 1.850373@1] [ 1.850373@1] PC: 0xc002368c: [ 1.854966@1] 368c e3a0005d eb000a71 e3c01030 e3a0005d e3811020 eb000a85 ea000011 e3a0005d [ 1.863287@1] 36ac eb000a6a e3c01030 e3a0005d e3811010 eb000a7e ea00000a e3a0005d eb000a63 [ 1.871609@1] 36cc e3801030 e3a0005d eb000a78 ea000004 e3a0005d eb000a5d e3c01030 e3a0005d [ 1.879930@1] 36ec eb000a72 e5953000 e353000a 0a000001 e353000b 1a000000 e1a08108 e3071b20 [ 1.888252@1] 370c e5970000 e3a02009 e34c109c eb0ffb56 e3500000 e6ef1078 030c3808 034c30b8 [ 1.896573@1] 372c e3a0001c 05838404 e3a07a05 eb000a5f e7e71458 e3a0001d eb000a5c e7e31858 [ 1.904895@1] 374c e3a0001e e3811030 e34f7e10 eb000a57 e3a0005d eb000a3d e3801001 e3a0005d [ 1.913216@1] 376c eb000a52 e5d42000 e3a03000 e1520003 03a08002 13a08001 e58734a8 f57ff05f [ 1.921539@1] [ 1.921539@1] LR: 0xc07f1b00: [ 1.926132@1] 1b00 e5930000 e7e000d0 e3500000 1afffff3 e8bd8070 e92d4010 f57ff05f e1d030b0 [ 1.934454@1] 1b20 e2833001 e1c030b0 f57ff04f e320f004 e3a00001 ebe181dc e1a0300d e3c33d7f [ 1.942775@1] 1b40 e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc70 e92d4010 f57ff05f [ 1.951097@1] 1b60 e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e3a00001 ebe181ca [ 1.959418@1] 1b80 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 e8bd4010 eafffc5e [ 1.967739@1] 1ba0 e92d4010 f57ff05f e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080 [ 1.976061@1] 1bc0 e3a00001 ebe181b8 e1a0300d e3c33d7f e3c3303f e5933000 e3130002 08bd8010 [ 1.984383@1] 1be0 e8bd4010 eafffc4c e92d4070 e1a04000 e3a00001 ebe18171 e1943f9f e3a05000 [ 1.992705@1] [ 1.992705@1] SP: 0xef36be28: [ 1.997298@1] be28 00000000 00000000 00000000 00000000 c0b8ef04 0000001f 0000003c 00000000 [ 2.005620@1] be48 c002370c 80000113 ffffffff ef36be94 00003000 c000da58 00000000 00007b20 [ 2.013941@1] be68 00000001 00000000 c0b47fb8 c0e1ecb8 c0e1e3e8 00000000 00003000 14001000 [ 2.022263@1] be88 00000000 00000001 ffbf6cff ef36bea8 c07f1b80 c002370c 80000113 ffffffff [ 2.030584@1] bea8 c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 c0e1ecb8 15000013 [ 2.038906@1] bec8 14001000 00000000 00000001 c06525a0 00000000 00000000 00000000 00000000 [ 2.047227@1] bee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.055549@1] bf08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.063871@1] [ 2.063871@1] IP: 0xffbf6c7f: [ 2.068464@1] 6c7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.076786@1] 6c9c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.085107@1] 6cbc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.093429@1] 6cdc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.101750@1] 6cfc ******** ******** ******** ******** ******** ******** ******** ******** [ 2.110072@1] 6d1c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.118393@1] 6d3c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.126715@1] 6d5c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.135037@1] 6d7c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.143359@1] [ 2.143359@1] R4: 0xc0b47f38: [ 2.147952@1] 7f38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.156274@1] 7f58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 fe1080b0 [ 2.164595@1] 7f78 fe1080b4 fe1080b8 fe1080bc fe1080c0 fe1080c4 fe1080c8 fe1080cc fe1080d0 [ 2.172917@1] 7f98 fe1080d4 fe600014 00000001 00000000 c0b47fa8 c0b47fa8 00000000 00000000 [ 2.181238@1] 7fb8 00004901 00000001 00000101 00000001 00000001 00001b8d 00004040 00001c3a [ 2.189560@1] 7fd8 00000112 00001c3b 00000892 00001c3c 00000029 00001c3d 00000461 00001c30 [ 2.197881@1] 7ff8 00000052 00001c31 0000007e 00001c32 00000000 00001c34 00000005 00001c36 [ 2.206203@1] 8018 00000052 00001c38 00000052 00001c51 00000000 00001b62 0000809d 00000000 [ 2.214525@1] [ 2.214525@1] R5: 0xc0e1ec38: [ 2.219118@1] ec38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.227440@1] ec58 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.235761@1] ec78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.244083@1] ec98 00000000 00000000 00000000 00000000 00000000 00000006 00000000 0000000a [ 2.252404@1] ecb8 00000000 00000000 00000000 00000000 00000000 00001000 00010001 00000000 [ 2.260726@1] ecd8 00000000 00000001 00000001 00000002 00000001 00000001 00003f03 00000000 [ 2.269047@1] ecf8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.277369@1] ed18 00000000 00000000 00000000 00000000 00000040 00000000 00000005 6f010001 [ 2.285691@1] [ 2.285691@1] R6: 0xc0e1e368: [ 2.290285@1] e368 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.298606@1] e388 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.306927@1] e3a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.315249@1] e3c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.323571@1] e3e8 00000000 c0e1e3ec c0e1e3ec 00000000 00000000 c0b4e794 00000000 00000001 [ 2.331892@1] e408 00000001 00000000 c08b1078 c0e1e414 c0e1e414 0fd00000 00000020 00000000 [ 2.340214@1] e428 ef2d8cc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.348535@1] e448 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.356858@1] Process kthread_hdmi (pid: 31, stack limit = 0xef36a238) [ 2.363359@1] Stack: (0xef36bea8 to 0xef36c000) [ 2.367869@1] bea0: c0e1e5d7 00000000 c0b8ef04 00000000 c0e1e3e8 00000001 [ 2.376191@1] bec0: c0e1ecb8 15000013 14001000 00000000 00000001 c06525a0 00000000 00000000 [ 2.384512@1] bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.392833@1] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.401155@1] bf20: 00000000 00000000 c0e1e3e8 c0e1e3e8 c0e1e3e8 c0b7ce34 13000002 c0651dd4 [ 2.409477@1] bf40: ef2d8cc0 ef279df0 00000000 c0e1e3e8 c0651970 00000000 00000000 00000000 [ 2.417798@1] bf60: 00000000 c0049920 ef36bf94 00000000 00000003 c0e1e3e8 00000000 00000000 [ 2.426120@1] bf80: ef36bf80 ef36bf80 00000000 00000000 ef36bf90 ef36bf90 ef36bfac ef279df0 [ 2.434441@1] bfa0: c0049870 00000000 00000000 c000df80 00000000 00000000 00000000 00000000 [ 2.442762@1] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.451084@1] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 2.459420@1] [<c002370c>] (hdmitx_set_audmode+0x330/0x788) from [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) [ 2.469119@1] [<c06525a0>] (hdmitx_set_audio+0x50/0x35c) from [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) [ 2.478656@1] [<c0651dd4>] (hdmi_task_handle+0x464/0x5bc) from [<c0049920>] (kthread+0xb0/0xb8) [ 2.487324@1] [<c0049920>] (kthread+0xb0/0xb8) from [<c000df80>] (ret_from_fork+0x14/0x34) [ 2.495553@1] Code: e353000b 1a000000 e1a08108 e3071b20 (e5970000) [ 2.501852@1] ---[ end trace 12a7b37da2a403ef ]--- [ 2.501865@0] usbcore: registered new device driver usb [ 2.501923@0] pps_core: LinuxPPS API ver. 1 registered [ 2.501925@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.501937@0] PTP clock support registered [ 2.502084@0] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 2.502089@0] TV mode 1080p selected. [ 2.502093@0] already display in uboot [ 2.502095@0] vinfo mode is: 1080p [ 2.504019@0] call aml_pmu_probe_init in [ 2.504063@0] aml_pmus_probe, child name:rn5t618 [ 2.504066@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 2.504328@0] board_has_battery:false [ 2.504332@0] [DVFS]aml_dvfs_register_driver, driver rn5t618-dvfs regist success, mask:7, source id:1 [ 2.504336@0] [RN5T618]ricoh_pmu_probe, 287 [ 2.505127@0] [RN5T618]coulomb_flag:0x20 [ 2.505129@0] [RN5T618]no saved coulomb counter [ 2.505160@0] ricoh_pmu_probe, 302 [ 2.505165@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 2.505357@0] Advanced Linux Sound Architecture Driver Initialized. [ 2.604140@0] Switching to clocksource Timer-E [ 2.608309@0] FS-Cache: Loaded [ 2.615175@0] NET: Registered protocol family 2 [ 2.616152@0] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 2.622945@0] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.629532@0] TCP: Hash tables configured (established 4096 bind 4096) [ 2.636007@0] TCP: reno registered [ 2.639368@0] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.645351@0] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.651887@0] NET: Registered protocol family 1 [ 2.656429@0] RPC: Registered named UNIX socket transport module. [ 2.662341@0] RPC: Registered udp transport module. [ 2.667180@0] RPC: Registered tcp transport module. [ 2.672042@0] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.678685@0] wifi_dev_probe [ 2.681485@0] wifi_dt : interrupt_pin=GPIOX_21 [ 2.685907@0] wifi_dt : irq_num=null [ 2.689468@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 2.694576@0] wifi_dt : power_on_pin=GPIOAO_6 [ 2.698928@0] wifi_dt : power_on_pin2=GPIOX_11 [ 2.703331@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 2.712351@0] Unpacking initramfs... [ 2.848554@0] Freeing initrd memory: 3484K [ 2.849248@0] audit: initializing netlink socket (disabled) [ 2.852604@0] type=2000 audit(2.760:1): initialized [ 2.858003@0] bounce pool size: 64 pages [ 2.865638@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.867454@0] exFAT: Core Version 1.2.4 [ 2.871188@0] exFAT: FS Version 1.2.4 [ 2.875431@0] NFS: Registering the id_resolver key type [ 2.880026@0] Key type id_resolver registered [ 2.884302@0] Key type id_legacy registered [ 2.888775@0] NTFS driver 2.1.30 [Flags: R/O]. [ 2.893154@0] fuse init (API version 7.22) [ 2.897415@0] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.907298@0] SGI XFS with security attributes, large block/inode numbers, no debug enabled [ 2.911351@0] bio: create slab <bio-1> at 1 [ 2.914901@0] Btrfs loaded [ 2.917117@0] msgmni has been set to 723 [ 2.920977@0] SELinux: Registering netfilter hooks [ 2.926983@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.933291@0] io scheduler noop registered [ 2.937352@0] io scheduler deadline registered [ 2.941794@0] io scheduler cfq registered (default) [ 2.946639@0] io scheduler fiops registered [ 2.952967@0] loop: module loaded [ 2.954492@0] tun: Universal TUN/TAP device driver, 1.6 [ 2.959294@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.965928@0] PPP generic driver version 2.4.2 [ 2.970113@0] PPP BSD Compression module registered [ 2.974885@0] PPP Deflate Compression module registered [ 2.980105@0] PPP MPPE Compression module registered [ 2.985028@0] NET: Registered protocol family 24 [ 2.989665@0] usbcore: registered new interface driver asix [ 2.995216@0] usbcore: registered new interface driver ax88179_178a [ 3.001446@0] usbcore: registered new interface driver cdc_ether [ 3.007411@0] usbcore: registered new interface driver dm9601 [ 3.013145@0] usbcore: registered new interface driver net1080 [ 3.018949@0] usbcore: registered new interface driver cdc_subset [ 3.025006@0] usbcore: registered new interface driver zaurus [ 3.030757@0] usbcore: registered new interface driver cdc_ncm [ 3.036536@0] usbcore: registered new interface driver qf9700 [ 3.042276@0] usbcore: registered new interface driver sr9600 [ 3.048043@0] usbcore: registered new interface driver cdc_acm [ 3.053777@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.061955@0] usbcore: registered new interface driver usb-storage [ 3.068242@0] mousedev: PS/2 mouse device common for all mice [ 3.073957@0] usbcore: registered new interface driver xpad [ 3.079382@0] usbcore: registered new interface driver usb_acecad [ 3.085427@0] usbcore: registered new interface driver aiptek [ 3.091159@0] usbcore: registered new interface driver gtco [ 3.096700@0] usbcore: registered new interface driver hanwang [ 3.102510@0] usbcore: registered new interface driver kbtab [ 3.108135@0] usbcore: registered new interface driver wacom [ 3.113836@0] i2c /dev entries driver [ 3.117813@0] device-mapper: uevent: version 1.0.3 [ 3.122343@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 3.131099@0] hidraw: raw HID events driver (C) Jiri Kosina [ 3.136424@0] usbcore: registered new interface driver usbhid [ 3.142020@0] usbhid: USB HID core driver [ 3.146266@0] zram: Created 1 device(s) ... [ 3.150400@0] ashmem: initialized [ 3.153533@0] logger: created 256K log 'log_main' [ 3.158223@0] logger: created 256K log 'log_events' [ 3.163066@0] logger: created 256K log 'log_radio' [ 3.167835@0] logger: created 256K log 'log_system' [ 3.172628@0] vout_init_module [ 3.175675@0] start init vout module [ 3.179229@0] create vout attribute ok [ 3.183072@0] ge2d_init [ 3.185439@0] ge2d_dev major:244 [ 3.188742@0] ge2d start monitor [ 3.191896@0] osd_init [ 3.191902@1] ge2d workqueue monitor start [ 3.198313@0] osd_probe, vinfo:c0855140 [ 3.202245@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 3.210244@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.215777@0] init fbdev bpp is :32 [ 3.219250@0] ---------------clear framebuffer0 memory [ 3.266739@0] Console: switching to colour frame buffer device 240x67 [ 3.293253@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0a00000, size=1024K [ 3.297833@0] osd_probe, mydef_var:c0b71678, vinfo:c0855140 [ 3.303389@0] don't find to display_size_default from mesonfb-dts [ 3.309454@0] init fbdev bpp is :24 [ 3.326508@0] osd probe ok [ 3.326647@0] enter aml_sysled_init [ 3.327340@0] DI: di_init [ 3.329722@0] DI: di_probe [ 3.332597@0] aml_wdt_driver_init,306 [ 3.336018@0] ** disable watchdog [ 3.339464@0] keys=========================================== [ 3.345040@0] keys_devno=f100000 [ 3.348356@0] securitykey: device aml_keys created [ 3.353016@0] amlkeys=0 [ 3.355456@0] platform_driver_register--aml_keys_driver-------------------- [ 3.362591@0] set uart_ao pinmux use pinctrl subsystem [ 3.367485@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.371686@0] start uart_ao_ttyS0:(irq = 122) [ 3.375980@0] register uart_ao ok [ 3.379444@0] set uart_a pinmux use pinctrl subsystem [ 3.384301@0] P_AO_RTI_PIN_MUX_REG:78005861 [ 3.388499@0] start uart_a_ttyS1:(irq = 58) [ 3.392622@0] register uart_a ok [ 3.395961@0] start uart_d_ttyS4:(irq = 126) [ 3.400103@0] register uart_d ok [ 3.403355@0] dwc_otg: version 3.10a 12-MAY-2014 [ 3.407894@0] dwc_otg_driver_probe NOT match [ 3.412178@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 3.420739@0] USB (1) use clock source: XTAL input [ 3.446513@0] Core Release: 3.10a [ 3.446595@0] Setting default values for core params [ 3.449219@0] curmode: 1, host_only: 1 [ 3.473390@0] Using Buffer DMA mode [ 3.477456@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.481543@0] Working on port type = HOST [ 3.485630@0] dwc_otg lm1: DWC OTG Controller [ 3.489703@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 3.495403@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 3.500342@0] -------hcd->flags.d32 = 0 [ 3.504314@0] Init: Port Power? op_state=1 [ 3.508267@0] Init1: Power Port (0) [ 3.512270@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.518636@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.525985@0] usb usb1: Product: DWC OTG Controller [ 3.530857@0] usb usb1: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.536820@0] usb usb1: SerialNumber: lm1 [ 3.541220@0] hub 1-0:1.0: USB hub found [ 3.545370@0] hub 1-0:1.0: 1 port detected [ 3.549623@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 3.557372@0] USB (0) use clock source: XTAL input [ 3.583191@0] Core Release: 3.10a [ 3.587474@0] Setting default values for core params [ 3.591849@0] curmode: 1, host_only: 0 [ 3.656284@0] Using Buffer DMA mode [ 3.660651@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 3.665026@0] Working on port type = OTG [ 3.669354@0] Current port type: SLAVE [ 3.673619@0] dwc_otg lm0: DWC OTG Controller [ 3.677854@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 3.683232@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 3.688195@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.695085@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.702464@0] usb usb2: Product: DWC OTG Controller [ 3.707302@0] usb usb2: Manufacturer: Linux 3.10.108 dwc_otg_hcd [ 3.713301@0] usb usb2: SerialNumber: lm0 [ 3.717641@0] hub 2-0:1.0: USB hub found [ 3.721798@0] hub 2-0:1.0: 1 port detected [ 3.725993@0] Dedicated Tx FIFOs mode [ 3.730211@0] using timer detect id change, ef5c1400 [ 3.734500@0] boot_device_flag : 0 [ 3.738703@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 3.746748@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 3.753611@0] amlnf_phy_init : amlnf init flag 0 [ 3.753636@2] Indeed it is in host mode hprt0 = 00021501 [ 3.763549@0] ######STS IRQ mode for nand driver [ 3.768119@0] NAND device id: ad de 14 a7 42 4a ad de [ 3.773113@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 3.819794@0] AML_NAND_NEW_OOB : new oob [ 3.824156@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 3.830916@0] boot_device_flag = 0 [ 3.838231@0] uncorrect ecc here at page:2048, chip:0 [ 3.842804@0] blk check good but read failed at chip 0 page 2048 [ 3.848706@0] hynix nand get default reg value at blk:8, page:2049 [ 3.855944@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 3.867383@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 3.875276@0] nand shipped bbt at block 0 [ 3.882681@0] uncorrect ecc here at page:2048, chip:0 [ 3.887392@0] nand blk check good but read failed at chip 0 page 2048 [ 3.928193@2] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 3.934036@3] Indeed it is in host mode hprt0 = 00001101 [ 3.941862@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 [ 3.949949@0] i=0,register --- nand_key [ 3.954713@0] nand adjust phy offset : block 4 [ 3.959472@0] nand adjust phy offset : block 4 [ 3.964192@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 3.972959@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 3.982496@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 3.993244@0] bad block count = 0 [ 3.993244@0] [ 4.005849@0] bad block count = 0 [ 4.005849@0] [ 4.026368@0] bad block count = 0 [ 4.026368@0] [ 4.035575@0] amlnand_add_nftl: [ 4.040141@0] Creating 1 ntd partitions [ 4.044670@0] block_num 76 [ 4.050363@0] ------init_ntd [ 4.054985@0] ntd: Giving out device 0 to nfcache [ 4.059508@0] Creating 7 ntd partitions [ 4.064027@0] block_num 204 [ 4.071781@0] ntd: Giving out device 1 to nfcode [ 4.076170@0] Creating 1 ntd partitions [ 4.080565@0] block_num 720 [ 4.096221@0] ntd: Giving out device 2 to nfdata [ 4.100831@0] ethernet_driver probe! [ 4.105196@0] Please config phy interface. [ 4.109575@0] Please config savepowermode. [ 4.113914@0] Please config reset_pin_enable. [ 4.118268@0] Please config reset_delay. [ 4.122563@0] Please config reset_pin. [ 4.126805@0] ethernetinit(dbg[c0b77388]=1) [ 4.129335@3] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.129340@3] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.129344@3] usb 1-1: Product: USB2.0 Hub [ 4.129757@3] hub 1-1:1.0: USB hub found [ 4.130016@3] hub 1-1:1.0: 4 ports detected [ 4.156340@0] ethernet base addr is fe0c0000 [ 4.160546@0] write mac add to:ee660ac8: 00 01 23 cd ee af |..#...| [ 4.172502@0] libphy: AMLMAC MII Bus: probed [ 4.176777@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 4.181601@0] Amlogic A/V streaming port init [ 4.186504@0] buffersize=262144,0,start=0 [ 4.190735@0] Subtitle stbuf alloced at 0xee6c0000, size = 262144 [ 4.195544@0] changed the (2) buffer size from 0 to 262144 [ 4.201148@0] init vdec memsource 9a00000->199fffff [ 4.205938@0] [tsync_pcr_init]init success. [ 4.210124@0] amvideocap_init_module [ 4.214316@0] regist mpeg12 codec profile [ 4.218432@0] regist mpeg4 codec profile [ 4.222436@0] amvdec_vc1 module init [ 4.226396@0] regist vc1 codec profile [ 4.230274@0] amvdec_h264 module init [ 4.234171@0] regist h264 codec profile [ 4.237969@0] amvdec_h264mvc module init [ 4.241778@0] regist hmvc codec profile [ 4.245469@0] amvdec_h264_4k2k module init [ 4.249247@0] regist h264_4k2k codec profile [ 4.252897@0] amvdec_h265 module init [ 4.256554@0] regist hevc_unsupport codec profile [ 4.260694@0] regist mjpeg codec profile [ 4.264539@0] amvdec_real module init [ 4.268231@0] amvdec_avs module init [ 4.271826@0] amvenc_avc memory resource undefined. [ 4.276592@0] amvenc_avc memory is invaild, probe fail! [ 4.281812@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 4.288273@0] jpegenc module init [ 4.291784@0] alloc_keep_buffer keep_y_addr ee200000 [ 4.296456@0] alloc_keep_buffer keep_u_addr ee800000 [ 4.301403@0] alloc_keep_buffer keep_v_addr ee780000 [ 4.306320@0] yaddr=ee200000,u_addr=ee800000,v_addr=ee780000 [ 4.312170@0] create_ge2d_work_queue video task ok [ 4.317068@0] efuse=========================================== [ 4.322721@0] efuse: device efuse created [ 4.326667@0] efuse-------------------------------------------- [ 4.332516@0] SARADC Driver init. [ 4.336133@0] __saradc_probe__ [ 4.408535@3] usb 1-1.2: new full-speed USB device number 3 using dwc_otg [ 4.488302@0] saradc calibration: ref_val = 508 [ 4.491944@0] saradc calibration: ref_nominal = 512 [ 4.495682@0] saradc calibration: coef = 4064 [ 4.500178@0] ir irblaster probe [ 4.503857@0] Remote Driver [ 4.507468@0] Remote platform_data g_remote_base=fe600580 [ 4.509213@3] usb 1-1.2: New USB device found, idVendor=1038, idProduct=1720 [ 4.509222@3] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.509225@3] usb 1-1.2: Product: SteelSeries Rival 310 eSports Mouse [ 4.509228@3] usb 1-1.2: Manufacturer: SteelSeries [ 4.511166@3] hid-generic 0003:1038:1720.0001: hiddev0,hidraw0: USB HID v1.11 Device [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-lm1-1.2/input0 [ 4.512632@3] input: SteelSeries SteelSeries Rival 310 eSports Mouse as /devices/lm1/usb1/1-1/1-1.2/1-1.2:1.1/input/input0 [ 4.512852@3] hid-generic 0003:1038:1720.0002: input,hidraw1: USB HID v1.11 Mouse [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-lm1-1.2/input1 [ 4.514826@3] input: SteelSeries SteelSeries Rival 310 eSports Mouse as /devices/lm1/usb1/1-1/1-1.2/1-1.2:1.2/input/input1 [ 4.515000@3] hid-generic 0003:1038:1720.0003: input,hidraw2: USB HID v1.11 Keyboard [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-lm1-1.2/input2 [ 4.588453@3] usb 1-1.3: new full-speed USB device number 4 using dwc_otg [ 4.607471@0] set drvdata completed [ 4.612203@0] device_create_file completed [ 4.617147@0] input: aml_keypad as /devices/platform/meson-remote/input/input2 [ 4.623656@0] input_register_device completed [ 4.628532@0] [0xffffff00] = 0x1dd0190 [ 4.633317@0] [0xffffff04] = 0xf800ca [ 4.638037@0] [0xffffff08] = 0x82006e [ 4.642705@0] [0xffffff0c] = 0x3c0030 [ 4.647311@0] [0xffffff10] = 0x30fa0013 [ 4.651873@0] [0xffffff18] = 0x6f19000 [ 4.656387@0] [0xffffff1c] = 0xbe40 [ 4.660859@0] [0x0] = 0xfa00a0 [ 4.665259@0] [0x4] = 0xfa00a0 [ 4.669604@0] [0x8] = 0xfa00a0 [ 4.673887@0] [0xc] = 0x640030 [ 4.678151@2] [0x10] = 0x30fa0013 [ 4.682406@2] [0x18] = 0x961b800 [ 4.686631@2] [0x1c] = 0x9740 [ 4.690843@2] [0x20] = 0x104 [ 4.691286@3] usb 1-1.3: New USB device found, idVendor=0951, idProduct=16d2 [ 4.691291@3] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.691294@3] usb 1-1.3: Product: HyperX Alloy FPS Pro Mechanical Gaming Keyboard [ 4.691297@3] usb 1-1.3: Manufacturer: Kingston [ 4.693307@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.0/input/input3 [ 4.693478@3] hid-generic 0003:0951:16D2.0004: input,hidraw3: USB HID v1.11 Keyboard [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input0 [ 4.695455@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.1/input/input4 [ 4.695736@3] hid-generic 0003:0951:16D2.0005: input,hiddev0,hidraw4: USB HID v1.11 Device [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input1 [ 4.702699@3] input: Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard as /devices/lm1/usb1/1-1/1-1.3/1-1.3:1.2/input/input5 [ 4.702888@3] hid-generic 0003:0951:16D2.0006: input,hidraw5: USB HID v1.11 Keyboard [Kingston HyperX Alloy FPS Pro Mechanical Gaming Keyboard] on usb-lm1-1.3/input2 [ 4.800290@2] [0x24] = 0x0 [ 4.805831@2] [0x28] = 0x0 [ 4.811331@2] set_remote_mode[69] [ 4.816856@2] remote config major:237 [ 4.822429@2] physical address:0x2e93e000 [ 4.827930@2] Meson KeyInput init [ 4.833470@2] GPIO Keypad Driver init. [ 4.839002@2] ==gpio_key_probe== [ 4.844509@2] reg:2620,clearmask=400040,setmask=1 [ 4.850012@2] reg:2622,clearmask=ff0000,set pin=3 [ 4.855493@2] reg:2623,clearmask=7000000,setmask=7 [ 4.860938@2] reg:2620,clearmask=800080,setmask=10001 [ 4.866361@2] reg:2622,clearmask=ff000000,set pin=3 [ 4.871766@2] reg:2623,clearmask=70000000,setmask=7 [ 4.877136@2] power key(116) registed. [ 4.877140@0] key 116 up [ 4.887856@2] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input6 [ 4.895041@2] gpio keypad register input device completed. [ 4.900480@2] gpio keypad major:236 [ 4.905985@2] spi_nor_init [ 4.911425@2] amlogic_spi_nor_probe: [ 4.916819@2] amlogic_spi->state_name:default [ 4.922282@2] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 4.929682@2] check_storage_device : spi boot_device_flag : 0 [ 4.935349@2] spi_nor_probe [ 4.940768@2] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 4.946906@2] Creating 2 MTD partitions on "apollospi:32766": [ 4.952326@2] 0x000000000000-0x000000100000 : "bootloader" [ 4.958293@2] 0x000000100000-0x000000110000 : "ubootenv" [ 4.963723@2] amlogic_spi_nor_probe over [ 4.968687@2] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 4.977425@2] host->base fe108c20 [ 4.982123@2] pdata->caps 7 [ 4.986714@2] pdata->caps2 0 [ 4.991297@2] get property: port, value:0x00000001 [ 4.996746@2] get property: ocr_avail, value:0x00200000 [ 5.003260@2] get property: f_min, value:0x000493e0 [ 5.009759@2] get property: f_max, value:0x02faf080 [ 5.016251@2] get property: max_req_size, value:0x00020000 [ 5.022760@2] get property: irq_in, value:0x00000003 [ 5.029265@2] get property: irq_out, value:0x00000005 [ 5.035757@2] get property: gpio_cd, str:CARD_6 [ 5.041744@2] get property: pinname, str:sd [ 5.047370@2] get property: jtag_pin, str:CARD_0 [ 5.053359@2] get property: card_type, value:0x00000005 [ 5.059880@2] get property: gpio_dat3, str:CARD_4 [ 5.065843@2] normal card in [ 5.108204@3] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 5.108211@2] reg:2620,clearmask=80008,setmask=10001 [ 5.108214@2] reg:2621,clearmask=ff000000,set pin=64 [ 5.108216@2] reg:2623,clearmask=7000,setmask=7 [ 5.108219@2] reg:2620,clearmask=200020,setmask=1 [ 5.108221@2] reg:2622,clearmask=ff00,set pin=64 [ 5.108223@2] reg:2623,clearmask=700000,setmask=7 [ 5.118240@1] pdata->caps 80000507 [ 5.118243@1] pdata->caps2 0 [ 5.118246@1] get property: port, value:0x00000002 [ 5.118248@1] get property: ocr_avail, value:0x00200000 [ 5.118250@1] get property: f_min, value:0x000493e0 [ 5.118252@1] get property: f_max, value:0x02faf080 [ 5.118254@1] get property: f_max_w, value:0x02faf080 [ 5.118257@1] get property: max_req_size, value:0x00020000 [ 5.118263@1] get property: pinname, str:emmc [ 5.118266@1] get property: card_type, value:0x00000001 [ 5.118269@1] get property: gpio_dat3, str:BOOT_3 [ 5.118272@1] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=5 [ 5.246886@3] sd: new high speed SDHC card at address 0001, clock 35416666, 4-bit-bus-width [ 5.253424@3] mmcblk0: sd:0001 SD32G 29.5 GiB [ 5.278245@1] pdata->caps 107 [ 5.279311@3] mmcblk0: p1 p2 [ 5.285340@1] pdata->caps2 0 [ 5.288876@1] get property: port, value:0x00000000 [ 5.289108@3] emmc: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 5.289110@3] aml_emmc_hw_reset 1338 [ 5.303673@1] get property: ocr_avail, value:0x00200000 [ 5.310145@1] get property: f_min, value:0x000493e0 [ 5.316637@1] get property: f_max, value:0x02faf080 [ 5.323148@1] get property: max_req_size, value:0x00020000 [ 5.329652@1] get property: pinname, str:sdio [ 5.335448@1] get property: card_type, value:0x00000003 [ 6.288242@1] [aml_sdio_timeout][0;40;33m time_start_cnt:991 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:998 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[ 9.414197@3] emmc: mmc_rescan_try_freq: trying to init card at 300000 Hz [ 9.458185@3] aml_emmc_hw_reset 1338 [aml_sdio_timeout][0;40;33m time_start_cnt:996 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f001f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:993 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:991 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:999 [0m[aml_sdio_print_err][0;40;33m emmc: Timeout error, Cmd1 arg 0x0, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=2, virqs=0x13, virqc=0x1f001f00, conf->cmd_clk_divide=236, pdata->clkc=236, conf->bus_width=0, pdata->width=0, conf=0x416270ec, clock=298874 [0m[aml_sdio_probe] aml_sdio_probe() success! [ 13.656571@1] [dsp]DSP start addr 0xc5e00000 [ 13.664810@1] [dsp]register dsp to char divece(257) [ 13.673196@1] amlogic audio spdif interface device init! [ 13.681433@1] name=nand_key nand_key [ 13.690179@1] register_aes_algorithm:488,new way [ 13.699637@1] key name:keyexample, key data:1234567890 [ 13.708481@1] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0 [ 13.718383@1] [AML1216]call aml1216_battery_init, ret = 0 [ 13.726728@1] [AML1218]call aml1218_battery_init, ret = 0 [ 13.735033@1] [RN5T618]call rn5t618_battery_probe in[ 13.743459@1] input: rn5t618_pmu as /devices/i2c-0/0-0032/rn5t618_pmu.0/input/input7 [ 13.754118@1] [RN5T618]use BSP configed battery parameters [ 13.762743@1] [RN5T618] NO BATTERY_PARAMETERS FOUND [ 13.777301@1] [RN5T618]call rn5t618_battery_probe exit, ret:0 [ 13.777451@1] [RN5T618]call rn5t618_battery_init, ret = 0 [ 13.795174@1] amaudio2: device amaudio2 created [ 13.803984@1] Amlogic CEC Driver, (c) 2016 Gerald Dachs, Version: 0.0.1 [ 13.813864@1] Error: Didn't get power valid value --- wifi_power_probe 323 [ 13.823942@1] wifi_power power_gpio is 6 [ 13.832809@1] wifi_power power_gpio2 is 123 [ 13.841741@1] bcmdhd_wlan_init() [ 13.850469@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[0]=ef2d5780, size=3760 [ 13.860613@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[1]=ef2d5840, size=3760 [ 13.870717@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[2]=ef2d5900, size=3760 [ 13.880798@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[3]=ef2d59c0, size=3760 [ 13.890859@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[4]=ef2d5a80, size=3760 [ 13.900875@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[5]=ef2d5b40, size=3760 [ 13.910823@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[6]=ef2d5c00, size=3760 [ 13.920700@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[7]=ef2d5cc0, size=3760 [ 13.930503@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[8]=ef2d5d80, size=7856 [ 13.940296@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[9]=ef2d5e40, size=7856 [ 13.950084@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[10]=ef2d5f00, size=7856 [ 13.959964@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[11]=ef2d53c0, size=7856 [ 13.969810@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[12]=ef2d5300, size=7856 [ 13.979621@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[13]=ef2d5240, size=7856 [ 13.989352@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[14]=ef2d5180, size=7856 [ 13.998768@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[15]=ef2f7000, size=7856 [ 14.007857@1] 3 bcmdhd_init_wlan_mem: wlan_static_skb[16]=ef2f70c0, size=16048 [ 14.016991@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[0]=ef2d5780, size=20504 [ 14.025700@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[1]=ef2d5840, size=20504 [ 14.034086@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[2]=ef2d5900, size=81944 [ 14.042418@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[3]=ef2d59c0, size=163864 [ 14.050544@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[4]=ef2d5a80, size=20504 [ 14.058272@1] 5 bcmdhd_init_wlan_mem: wlan_static_scan_buf0=edf50000, size=65536 [ 14.066334@1] 6 bcmdhd_init_wlan_mem: wlan_static_scan_buf1=edf60000, size=65536 [ 14.074098@1] bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 14.079874@1] amlogic rfkill init [ 14.085557@1] Error: Driver 'bt-dev' is already registered, aborting... [ 14.092899@1] enter rt5616_modinit [ 14.098701@1] dummy_codec_platform_probe [ 14.104224@1] == ES8323 == es8323_modinit() [ 14.109449@1] *****enter pcm2bt_codec_probe [ 14.114563@1] pcm2bt_codec_probe ok! [ 14.119710@1] enter aml_i2s_dai_probe [ 14.124256@1] i2s get no clk src setting in dts, use the default mpll 0 [ 14.129821@1] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000 [ 14.137793@1] enter aml_pcm_dai_probe [ 14.141968@1] [aml-spdif-dai]enter aml_dai_spdif_init [ 14.146362@1] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4 [ 14.153477@1] audio_set_958_clk, freq=4, [ 14.157374@1] IEC958 16bit [ 14.160975@1] hdmitx: audio: aout notify rate 48000 [ 14.164910@1] hdmitx: audio: aout notify size 16 [ 14.169516@1] hdmitx: audio: aout notify format CT_PCM [ 14.174620@1] hdmitx: audio: audio channel num is 1 [ 14.179484@1] hdmitx: audio: SPDIF [ 14.182968@1] hdmitx: audio: current VIC: 16 [ 14.187100@1] hdmitx: audio: audio sample rate: 3 [ 14.191789@1] hdmitx: audio: set audio N para [ 14.196120@1] hdmitx: audio: PCM out to HDMI [ 14.200371@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 14.205043@1] hdmitx: audio: Enable audio spdif to HDMI [ 14.210255@1] hdmitx: audio: Audio Type: PCM [ 14.214533@1] hdmitx: audio: set audio param [ 14.218799@1] [aml-spdif-dai]aml_spdif_probe [ 14.223074@1] test codec dummy_codec [ 14.226543@1] using external codec, index = 1 [ 14.230885@1] using external dummy codec [ 14.234851@1] enter spdif_dit_probe [ 14.238338@1] aml_spdif_unmute [ 14.241576@1] codec_name = dummy_codec.0 [ 14.245644@1] enter aml_asoc_init [ 14.248758@1] p_aml_audio->hp_disable=1 [ 14.252547@1] falied to get spk event delay time paraments from dts file [ 14.259228@1] spk_event delay_time = 0 [ 14.263880@1] aml-i2s 0:playback preallocate_dma_buffer: area=f0bdc000, addr=2e200000, size=524288 [ 14.272107@1] aml-i2s 1:capture preallocate_dma_buffer: area=f0c5e000, addr=2e1a0000, size=65536 [ 14.280655@1] aml_snd_m8 aml_m8_sound_card.5: dummy_codec <-> aml-i2s-dai.0 mapping ok [ 14.288764@1] enter aml_pcm2bt_preallocate_dma_buffer stream: 0 [ 14.294604@1] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0c7f000 buf->addr: 0x2e1d0000 buf->bytes: 65536 [ 14.304999@1] enter aml_pcm2bt_preallocate_dma_buffer stream: 1 [ 14.310992@1] aml_pcm2bt_preallocate_dma_buffer allcoate buf->area: f0c90000 buf->addr: 0x2e1e0000 buf->bytes: 65536 [ 14.321383@1] aml_snd_m8 aml_m8_sound_card.5: pcm2bt-pcm <-> aml-pcm-dai.0 mapping ok [ 14.330252@1] aml-i2s 0:playback preallocate_dma_buffer: area=f0ca1000, addr=2e300000, size=524288 [ 14.338436@1] aml-i2s 1:capture preallocate_dma_buffer: area=f0d23000, addr=2e2a0000, size=65536 [ 14.346957@1] aml_snd_m8 aml_m8_sound_card.5: dit-hifi <-> aml-spdif-dai.0 mapping ok [ 14.355531@1] -----ext_codec=1--- [ 14.359877@1] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0 [ 14.364752@1] GACT probability NOT on [ 14.369210@1] Mirror/redirect action on [ 14.373637@1] u32 classifier [ 14.378067@1] Actions configured [ 14.382538@1] Netfilter messages via NETLINK v0.30. [ 14.387111@1] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 14.392823@1] ctnetlink v0.93: registering with nfnetlink. [ 14.398029@1] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 14.405095@1] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 14.411246@1] xt_time: kernel timezone is -0000 [ 14.416011@1] ipip: IPv4 over IPv4 tunneling driver [ 14.421067@1] ip_tables: (C) 2000-2006 Netfilter Core Team [ 14.425991@1] arp_tables: (C) 2002 David S. Miller [ 14.430710@1] TCP: cubic registered [ 14.435354@1] Initializing XFRM netlink socket [ 14.440369@1] NET: Registered protocol family 10 [ 14.445705@1] mip6: Mobile IPv6 [ 14.450404@1] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 14.455257@1] sit: IPv6 over IPv4 tunneling driver [ 14.460539@1] NET: Registered protocol family 17 [ 14.465148@1] NET: Registered protocol family 15 [ 14.469744@1] Bridge firewalling registered [ 14.474293@1] l2tp_core: L2TP core driver, V2.0 [ 14.478774@1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 14.483370@1] l2tp_netlink: L2TP netlink interface [ 14.488137@1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 14.494223@1] l2tp_debugfs: L2TP debugfs support [ 14.498829@1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 14.505403@1] NET: Registered protocol family 35 [ 14.510169@1] Key type dns_resolver registered [ 14.515217@1] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 14.522233@1] Registering SWP/SWPB emulation handler [ 14.527130@1] enter meson_pm_init [ 14.532091@1] enter meson_pm_probe! [ 14.536936@1] ---meson_pm_probe----set output pin success [ 14.541843@1] meson_pm_probe done ! [ 14.547046@1] regulator-dummy: disabling [ 14.552159@1] file system registered [ 14.557572@1] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 14.563965@1] android_usb gadget: Number of LUNs=2 [ 14.568951@1] lun0: LUN: removable file: (no medium) [ 14.573967@1] lun1: LUN: removable file: (no medium) [ 14.579074@1] android_usb gadget: android_usb ready [ 14.584487@1] aml_rtc rtc.0: setting system clock to 2021-01-05 09:20:54 UTC (1609838454) [ 14.592139@1] ### dt-test ### No testcase data in device tree; not running tests [ 14.599567@1] meson_cpufreq: no voltage_control prop [ 14.604763@1] voltage_control = 0 [ 14.611140@1] buf[0]=a7,buf[1]=9b,err=4 [ 14.614756@1] M8:adc=442,TS_C=7,flag=1 [ 14.618322@1] efuse_flag=a [ 14.621808@1] amlogic_thermal_probe, this chip is trimmed, use thermal [ 14.626179@1] amlogic-thermal aml_thermal: amlogic thermal probe start [ 14.632687@1] #thermal-cells=7 [ 14.636075@1] pdata->temp_trip_count=4 [ 14.639447@1] temperature=70000 on trip point=0 [ 14.643946@1] fixing high_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.651054@1] fixing low_freq=1608001 to 1608000 at trip point 0,level=2 [ 14.657690@1] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511 [ 14.663802@1] cpu[0] core num==3 [ 14.667004@1] gpu[0] core num==5 [ 14.670217@1] temperature=80000 on trip point=1 [ 14.674718@1] fixing high_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.681673@1] fixing low_freq=1200001 to 1200000 at trip point 1,level=6 [ 14.688374@1] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435 [ 14.694569@1] cpu[1] core num==2 [ 14.697776@1] gpu[1] core num==4 [ 14.700990@1] temperature=90000 on trip point=2 [ 14.705491@1] fixing high_freq=800001 to 696000 at trip point 2,level=11 [ 14.712392@1] fixing low_freq=800001 to 696000 at trip point 2,level=11 [ 14.718977@1] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328 [ 14.725168@1] cpu[2] core num==2 [ 14.728381@1] gpu[2] core num==3 [ 14.731582@1] temperature=260000 on trip point=3 [ 14.736176@1] fixing high_freq=-1 to -22 at trip point 3,level=-1 [ 14.742690@1] fixing low_freq=-1 to -22 at trip point 3,level=-1 [ 14.748677@1] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1 [ 14.754467@1] cpu[3] core num==-1 [ 14.757760@1] gpu[3] core num==-1 [ 14.761061@1] idle interval=1000 [ 14.764262@1] pdata->name:aml_thermal [ 14.768015@1] tmp_trip[0].cpu_core_upper=1 [ 14.771990@1] tmp_trip[1].cpu_core_upper=2 [ 14.776055@1] tmp_trip[2].cpu_core_upper=2 [ 14.780135@1] tmp_trip[3].cpu_core_upper=-1 [ 14.784293@1] aml_thermal bind thermal-cpucore-0 okay ! [ 14.789510@1] aml_thermal bind thermal-cpufreq-0 okay ! [ 14.794809@1] amlogic: Kernel Thermal management registered [ 14.800243@1] amlogic-thermal aml_thermal: amlogic thermal probe done [ 14.806721@1] ALSA device list: [ 14.809778@1] #0: AML-M8AUDIO [ 14.813126@1] Freeing unused kernel memory: 228K [ 14.823451@0] tvmode set to 720p [ 14.823451@0] [ 14.829118@0] mode is 11,sync_duration_den=1,sync_duration_num=60 [ 14.834343@0] TV mode 720p selected. [ 14.837897@0] tvoutc_setmode[505] [ 14.841200@0] tvoutc_setmode[516] mode is 11 [ 14.845435@0] vinfo mode is: 720p [ 14.848740@0] new mode 720p set ok [ 14.852113@0] hdmitx: video: get current mode: 720p [ 14.856965@0] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.862699@0] hdmitx: video: get current mode: 720p [ 14.867543@0] is_similar_hdmi_vic[326] vic_old=16,mode_new=11 [ 14.873278@0] hdmitx: system: gate/pwr cmd: 7 [ 14.877637@0] hdmitx: system: already init VIC = 0 Now VIC = 4 [ 14.883503@0] hdmitx: system: 4 (cd0,cs0,pm1,vd0,1) [ 14.888527@0] hdmitx: system: gate/pwr cmd: 0 [ 14.892844@0] hdmitx: system: hw reset [ 14.897611@0] hdmitx: audio: SPDIF [ 14.900361@0] hdmitx: system: reconfig packet setting done [ 14.926267@3] hdmitx: system: set pll [ 14.929131@3] hdmitx: system: param->VIC:4 [ 14.931885@3] mode is: 11 [ 14.934592@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.937628@3] viu chan = 1 [ 14.940335@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 14.944214@3] config HPLL [ 14.946845@3] set_hpll_clk_out[81] clk = 2970 [ 14.968181@3] config HPLL done [ 14.970798@3] enc_vpu_bridge_reset[292] [ 15.108212@0] hdmitx: system: phy setting done [ 15.113495@0] Sink is HDMI device [ 15.120193@0] No sink attached [ 15.164632@0] hdmitx: audio: audio channel num is 1 [ 15.209037@0] hdmitx: audio: SPDIF [ 15.231020@0] hdmitx: audio: current VIC: 4 [ 15.233440@0] hdmitx: audio: audio sample rate: 3 [ 15.237577@0] hdmitx: audio: set audio N para [ 15.241929@0] hdmitx: audio: PCM out to HDMI [ 15.246152@0] hdmitx: audio: i2s_to_spdif_flag:1 [ 15.250848@0] hdmitx: audio: Enable audio spdif to HDMI [ 15.256035@0] hdmitx: audio: Audio Type: PCM [ 15.274390@0] set_vout_mode[183] [ 15.771231@1] [RN5T618]battery vol change: 0->0 [ 17.224822@3] force enable DISCARD here for ext4 fs [ 17.247244@3] checked enable EXT4 DISCARD here [ 17.249946@3] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard [ 17.258332@3] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 18.489157@1] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 18.561084@1] systemd[1]: Detected architecture arm. [ 18.642434@1] systemd[1]: Set hostname to <vegas812>. [ 18.708204@3] Changing uart_ao_ttyS0: baud from 0 to 115200 [ 20.855364@2] systemd[1]: Reached target Remote File Systems. [ 20.923125@2] systemd[1]: Listening on udev Kernel Socket. [ 20.930012@2] systemd[1]: Listening on Journal Socket (/dev/log). [ 20.937425@2] systemd[1]: Listening on udev Control Socket. [ 20.944557@2] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 20.953622@2] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 20.965200@2] systemd[1]: Listening on Syslog Socket. [ 20.972998@2] systemd[1]: Listening on Journal Socket. [ 20.981063@2] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 20.991353@2] systemd[1]: Created slice System Slice. [ 21.002278@2] systemd[1]: Starting Restore / save the current clock... [ 21.013499@2] systemd[1]: Mounting Debug File System... [ 21.022636@2] systemd[1]: Created slice system-getty.slice. [ 21.031889@2] systemd[1]: dev-hugepages.mount: Couldn't determine result for ConditionVirtualization=!private-users, assuming failed: No such file or directory [ 21.046572@2] systemd[1]: Starting Nameserver information manager... [ 21.058813@2] systemd[1]: Starting Set the console keyboard layout... [ 21.085535@2] systemd[1]: Starting Load Kernel Modules... [ 21.095520@2] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 21.109682@2] systemd[1]: Reached target Encrypted Volumes. [ 21.121411@0] systemd[1]: Listening on fsck to fsckd communication Socket. [ 21.133828@0] systemd[1]: Created slice User and Session Slice. [ 21.145035@0] systemd[1]: Reached target Slices. [ 21.155629@0] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 21.168557@0] systemd[1]: Starting Remount Root and Kernel File Systems... [ 21.180523@0] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 21.195007@0] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 21.211562@0] systemd[1]: Mounted Debug File System. [ 21.222843@0] systemd[1]: Started Restore / save the current clock. [ 21.329509@0] systemd[1]: Started Set the console keyboard layout. [ 21.453223@0] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 21.531326@0] systemd[1]: Started Nameserver information manager. [ 21.621272@0] systemd[1]: Starting Create Static Device Nodes in /dev... [ 21.684167@1] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 21.692994@0] systemd[1]: Started Remount Root and Kernel File Systems. [ 21.714871@0] systemd[1]: Starting udev Coldplug all Devices... [ 21.737436@2] systemd[1]: Activating swap /var/swap... [ 21.765196@2] systemd[1]: Starting Load/Save Random Seed... [ 21.796570@3] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 21.809748@3] boot_device_flag : 0 [ 21.821498@3] register_ntd_blktrans start [ 21.836262@3] ntd device 250! [ 21.850528@3] ntd->name: nfcache [ 21.865671@3] adjust_block_num : 4,reserved_block_ratio 10 [ 21.880146@3] nftl version 140911a [ 21.894605@3] nftl part attr 0 [ 21.911025@3] nftl start:76,12 [ 21.921270@3] first [ 21.951738@2] systemd[1]: Started Load/Save Random Seed. [ 21.999012@3] average_erase_count:0 [ 22.003504@3] second 55,64 [ 22.008029@3] part->max_discard_block = 4 [ 22.017646@0] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 22.024937@2] systemd[1]: Activated swap /var/swap. [ 22.035752@2] systemd[1]: Reached target Swap. [ 22.074878@3] all block full!! [ 22.079142@3] all discard block full!! [ 22.083394@3] free list: [ 22.087640@3] free block cnt = 61 [ 22.091742@3] new current block is 20 [ 22.096059@3] total discard page count is 0 [ 22.100110@3] create_part_list:1235,current_used_discard_block=19,current_discard_block_used_count=160 [ 22.108100@3] unmappig_pages=15832,discarded_pages=0,mapping_pages=552 [ 22.114397@3] nftl ok! [ 22.115681@2] systemd[1]: Started Create Static Device Nodes in /dev. [ 22.125276@3] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.125583@3] aml_nftl_add_ntd ok [ 22.125586@3] ntd device 250! [ 22.125588@3] ntd->name: nfcode [ 22.125591@3] adjust_block_num : 4,reserved_block_ratio 10 [ 22.125595@3] nftl version 140911a [ 22.125619@3] nftl part attr 0 [ 22.129065@3] size_in_blk 204; total_block 203; [ 22.129068@3] nftl start:203,23 [ 22.129723@3] first [ 22.169135@2] systemd[1]: Started udev Coldplug all Devices. [ 22.181330@2] systemd[1]: Starting udev Kernel Device Manager... [ 22.189474@2] systemd[1]: Reached target Local File Systems (Pre). [ 22.207873@2] systemd[1]: Mounting /tmp... [ 22.217810@2] systemd[1]: Mounted /tmp. [ 22.266994@3] found discard block:139 [ 22.327006@2] systemd[1]: Started udev Kernel Device Manager. [ 22.331555@3] average_erase_count:6 [ 22.331562@3] second 202,180 [ 22.331563@3] part->max_discard_block = 4 [ 22.438919@1] aml_nftl_open ok! [ 22.575815@0] systemd[1]: Found device /dev/ttyS0. [ 22.576296@1] all block full!! [ 22.577932@1] currnet_discard_block1:139 [ 22.594478@0] systemd[1]: Reached target Sound Card. [ 22.627929@1] reach the last discard page:28 [ 22.631659@1] free list: [ 22.635000@1] free block cnt = 91 [ 22.637984@1] new current block is 39 [ 22.641202@1] total discard page count is 28 [ 22.644342@1] create_part_list:1235,current_used_discard_block=139,current_discard_block_used_count=91 [ 22.653846@1] unmappig_pages=25320,discarded_pages=119,mapping_pages=20641 [ 22.660146@1] nftl ok! [ 22.664038@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.667900@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.672011@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.676570@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.681157@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.685776@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.690406@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 22.694898@1] aml_nftl_add_ntd ok [ 22.697886@1] ntd device 250! [ 22.700857@1] ntd->name: nfdata [ 22.703963@1] adjust_block_num : 4,reserved_block_ratio 10 [ 22.709437@1] nftl version 140911a [ 22.712852@1] nftl part attr 0 [ 22.725183@1] size_in_blk 720; total_block 714; [ 22.728430@1] nftl start:714,69 [ 22.732047@1] first [ 22.735973@0] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 23.291673@0] systemd[1]: Found device /dev/disk/by-label/BOOT. [ 23.308299@0] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT... [ 23.312277@3] aml_nftl_open ok! [ 23.314695@3] aml_nftl_open ok! [ 23.317054@3] aml_nftl_open ok! [ 23.319422@3] aml_nftl_open ok! [ 23.321926@3] aml_nftl_open ok! [ 23.323633@3] aml_nftl_open ok! [ 23.325226@3] aml_nftl_open ok! [ 23.379262@2] systemd[1]: Started File System Check Daemon to report status. [ 23.413864@0] found discard block:701 [ 23.428083@0] average_erase_count:2 [ 23.432303@0] second 713,645 [ 23.432305@0] part->max_discard_block = 4 [ 23.665654@2] aml_audio_i2s_mute_flag: flag=0 [ 23.668868@2] aml_audio_set_spdif_mute: flag=0 [ 23.672005@2] aml_spdif_unmute [ 23.675203@2] aml_m8_set_spk: aml_m8_spk_enabled=0 [ 23.779273@2] systemd[1]: Started File System Check on /dev/disk/by-label/BOOT. [ 23.792823@2] systemd[1]: Mounting /boot... [ 23.825959@2] systemd[1]: Mounted /boot. [ 23.833631@2] systemd[1]: Reached target Local File Systems. [ 23.848935@2] systemd[1]: Starting HDMI init... [ 23.860600@2] systemd[1]: Starting Set console font and keymap... [ 23.866450@3] tvmode set to 1080p [ 23.866450@3] [ 23.866461@3] mode is 15,sync_duration_den=1,sync_duration_num=60 [ 23.866464@3] TV mode 1080p selected. [ 23.866468@3] tvoutc_setmode[505] [ 23.866470@3] tvoutc_setmode[516] mode is 15 [ 23.866472@3] vinfo mode is: 1080p [ 23.866473@3] new mode 1080p set ok [ 23.866478@3] hdmitx: video: get current mode: 1080p [ 23.866480@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 23.866483@3] hdmitx: video: get current mode: 1080p [ 23.866487@3] is_similar_hdmi_vic[326] vic_old=4,mode_new=15 [ 23.866490@3] hdmitx: system: gate/pwr cmd: 7 [ 23.866543@3] hdmitx: system: already init VIC = 0 Now VIC = 16 [ 23.866546@3] hdmitx: system: 16 (cd0,cs0,pm1,vd0,1) [ 23.866547@3] hdmitx: system: gate/pwr cmd: 0 [ 23.866551@3] hdmitx: system: hw reset [ 23.867595@3] hdmitx: audio: SPDIF [ 23.867653@3] hdmitx: system: reconfig packet setting done [ 23.888434@3] hdmitx: system: set pll [ 23.888437@3] hdmitx: system: param->VIC:16 [ 23.888440@3] mode is: 15 [ 23.888443@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 23.888443@3] viu chan = 1 [ 23.888444@3] VPU_VIU_VENC_MUX_CTRL: 0xa [ 23.888445@3] config HPLL [ 23.888447@3] set_hpll_clk_out[81] clk = 2970 [ 23.909215@3] config HPLL done [ 23.909227@3] enc_vpu_bridge_reset[292] [ 23.990472@3] systemd[1]: Starting Armbian enhanced Log2Ram... [ 23.998597@3] systemd[1]: Started Set console font and keymap. [ 24.048190@3] hdmitx: system: phy setting done [ 24.052129@3] Sink is HDMI device [ 24.055244@3] No sink attached [ 24.058515@3] hdmitx: audio: audio channel num is 1 [ 24.061679@3] hdmitx: audio: SPDIF [ 24.064715@3] hdmitx: audio: current VIC: 16 [ 24.069070@3] hdmitx: audio: audio sample rate: 3 [ 24.073516@3] hdmitx: audio: set audio N para [ 24.078366@3] hdmitx: audio: PCM out to HDMI [ 24.082088@3] hdmitx: audio: i2s_to_spdif_flag:1 [ 24.086776@3] hdmitx: audio: Enable audio spdif to HDMI [ 24.092501@3] hdmitx: audio: Audio Type: PCM [ 24.112416@3] set_vout_mode[183] [ 24.220652@0] all block full!! [ 24.224464@0] currnet_discard_block1:701 [ 24.261433@0] reach the last discard page:28 [ 24.261929@0] free list: [ 24.261930@0] free block cnt = 23 [ 24.261932@0] new current block is 263 [ 24.261933@0] total discard page count is 28 [ 24.261936@0] create_part_list:1235,current_used_discard_block=701,current_discard_block_used_count=30 [ 24.263953@0] unmappig_pages=116929,discarded_pages=3583,mapping_pages=44608 [ 24.263954@0] nftl ok! [ 24.265416@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 24.265781@0] aml_nftl_add_ntd ok [ 24.265791@0] init_aml_nftl end [ 24.267189@3] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE [ 24.267788@3] systemd[1]: Failed to start Load Kernel Modules. [ 24.269755@0] aml_nftl_open ok! [ 24.366300@3] systemd[1]: systemd-modules-load.service: Unit entered failed state. [ 24.372732@3] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'. [ 24.381364@3] systemd[1]: Started HDMI init. [ 24.394572@3] systemd[1]: Starting Apply Kernel Variables... Debian GNU/Linux 9 vegas812 ttyS0 vegas812 login: [ 2816.158365@0] Power down. [ 2816.162544@0] Restarting Linux version 3.10.108-vegas812 (root@CompileServer) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Tue May 22 12:53:17 MSK 2018 [ 2816.162544@0] Psleep ....... old firmware i2c init 04Success. step 1 enter ddr_self_refresh CPU off... CPU off done CEC M8:uboot: P_AO_DEBUG_REG0: 00000000 set dcdc3 to 0x12 dc2 set to PSM dc3 set to PSM enter 32K kern log_addr:0x00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 rx stat:00, tx stat:00 EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102623 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 18 -> 28 DC02 v:1150, 0x[37]: 18 -> 2c DC03 v:1500, 0x[38]: 38 -> 48 LDO01 v:2900, 0x[4c]: 4e -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12104 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489051 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x1d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 88 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=charging TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, SD or TSD: Card did not respond to voltage select! mmc->block_dev.if_type=7 MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 0 ** ** Unable to use mmc 0:1 for fatload ** Unknown command 'ext4load' - try 'help' MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 1 ** ** Unable to use mmc 1:1 for fatload ** Unknown command 'ext4load' - try 'help' Enter USB burn GOTGCTL=0x00010000, asesvld=0, bsesvld=0 Fail in usb_pcd_init current storer:nand_key key save is auto select storer(nand or emmc) write key code version3_flush:709,prov->write:7fed98e0 write key ok!! Booting... not config efuse version ERR(v2_common/optimus_download_key.c)L473:failed to query key state, rc 0, keyIsBurned=0 not config efuse version Saving Environment to SPI Flash... SPI BOOT,spi_saveenv : saveenv 122 Erasing SPI flash...Writing to SPI flash...done ## ANDROID Format IMAGE ## Booting kernel from Legacy Image at 12000000 ... Image Name: Linux-3.10.105 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 4385557 Bytes = 4.2 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK Ramdisk start addr = 0x1242f800, len = 0x18cbb1 Flat device tree start addr = 0x125bc800, len = 0x49f3 magic=0xedfe0dd0 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 14175440 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5195001 Loading Ramdisk to 05008000, end 05194bb1 ... OK Loading Device Tree to 05000000, end 050079f2 ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.105 (dev_user@dev) (gcc version 5.4.0 (Buildroot 2017.02-00100-gc2abd0d-dirty) ) #1 SMP PREEMPT Fri Mar 10 07:36:38 EET 2017 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is d9fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x0d9fffff, size: 122 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(high) : 0x79f00000 - 0x7df00000 ( 64 MiB) [ 0.000000@0] ppmgr0(high) : 0x77f00000 - 0x79f00000 ( 32 MiB) [ 0.000000@0] vdin00(low) : 0x09a00000 - 0x0aa00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x0aa00000 - 0x0ba00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x0ba00000 - 0x0d200000 ( 24 MiB) [ 0.000000@0] amvideocap0(low) : 0x0d200000 - 0x0da00000 ( 8 MiB) [ 0.000000@0] get storage device: storage 4 [ 0.000000@0] value=4 [ 0.000000@0] get_storage_device : get storage device: storage 4 [ 0.000000@0] get_storage_device : value=4 [ 0.000000@0] [get_storage_device] storage_flag=4 [ 0.000000@0] [get_storage_device] the storage device does NOT relate to eMMC, storage_flag=4 [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 7 pages/cpu @c19d6000 s7488 r8192 d12992 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 454416 [ 0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200n8 no_console_suspend earlyprintk ramoops.mem_address=0x04e00000 ramoops.mem_size=0x100000 ramoops.record_size=0x8000 ramoops.console_size=0x4000 storage=4 cvbsdrv=0 vdaccfg=0xa000 logo=osd1,loaded,0x07900000,1080p,full hdmimode=1080p cvbsmode=576cvbs androidboot.firstboot=1 hdmitx= mac=ae:9e:ba:9b:60:cb mac=AE:9E:BA:9B:60:CB [ 0.000000@0] cvbs performance line = 0 [ 0.000000@0] cvbs trimming line = 0xa000 [ 0.000000@0] cvbs trimming.1.v5: 0xa0, 0x0 [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:12 [ 0.000000@0] full:2 [ 0.000000@0] kernel get hdmimode form uboot is 1080p [ 0.000000@0] kernel get cvbsmode form uboot is 576cvbs [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000@0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000@0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Memory: 64MB 16MB 1701MB = 1781MB total [ 0.000000@0] Memory: 1794728k/1794728k available, 29016k reserved, 1184768K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc080c3e8 (8209 kB) [ 0.000000@0] .init : 0xc080d000 - 0xc083ad40 ( 184 kB) [ 0.000000@0] .data : 0xc083c000 - 0xc0891a80 ( 343 kB) [ 0.000000@0] .bss : 0xc0891a80 - 0xc0ac257c (2243 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [ttyS0] enabled [ 0.402665@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.412955@0] pid_max: default: 32768 minimum: 301 [ 0.417849@0] Mount-cache hash table entries: 512 [ 0.425446@0] Initializing cgroup subsys freezer [ 0.427035@0] CPU: Testing write buffer coherency: ok [ 0.432262@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.437861@0] Setting up static identity map for 0xc05d0c08 - 0xc05d0c60 [ 0.444626@0] L310 cache controller enabled [ 0.448668@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.456237@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.464360@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.530117@0] write pen_release: 1 [ 0.530381@1] CPU1: Booted secondary processor [ 0.530395@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.550107@0] write pen_release: 2 [ 0.558334@2] CPU2: Booted secondary processor [ 0.558349@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.570108@0] write pen_release: 3 [ 0.578337@3] CPU3: Booted secondary processor [ 0.578351@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.578408@0] Brought up 4 CPUs [ 0.591458@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.597689@0] CPU: All CPU(s) started in SVC mode. [ 0.602821@0] devtmpfs: initialized [ 0.610466@0] clkrate [ xtal ] : 24000000 [ 0.610494@0] clkrate [ pll_sys ] : 1200000000 [ 0.614506@0] clkrate [ pll_fixed ] : 2550000000 [ 0.619187@0] clkrate [ pll_vid ] : 366000000 [ 0.623613@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.629761@0] clkrate [ pll_hpll ] : 0 [ 0.633580@0] clkrate [ pll_ddr ] : 0 [ 0.637304@0] clkrate [ a9_clk ] : 1200000000 [ 0.641729@0] clkrate [ clk81 ] : 141666666 [ 0.646520@0] pinctrl core: initialized pinctrl subsystem [ 0.651627@0] regulator-dummy: no parameters [ 0.655768@0] NET: Registered protocol family 16 [ 0.665509@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.668874@0] VPU driver version: v03 [ 0.670949@0] vpu driver detect cpu type: m8 [ 0.675185@0] load vpu_clk in dts: 364300000Hz(7) [ 0.679921@0] vpu_probe OK [ 0.686947@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.688294@0] register lm device lm-root [ 0.692084@0] register lm device lm1 [ 0.695624@0] register lm device lm0 [ 0.699319@0] Init pinux probe! [ 0.702564@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.708011@0] tv_init_module [ 0.710823@0] major number 254 for disp [ 0.714623@0] vout_register_server [ 0.718004@0] register tv module server ok [ 0.722148@0] major number 0 for disp [ 0.725719@0] register tv module server ok [ 0.729869@0] aml_i2c version: 20140813 [ 0.733793@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef3388a8) [ 0.739677@0] aml-i2c i2c-AO: aml i2c bus driver. [ 0.744548@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef338ca8) [ 0.750346@0] aml-i2c i2c-A: aml i2c bus driver. [ 0.755117@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3390a8) [ 0.760923@0] aml-i2c i2c-B: aml i2c bus driver. [ 0.765677@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3394a8) [ 0.771496@0] aml-i2c i2c-C: aml i2c bus driver. [ 0.776218@0] call aml_dvfs_init in [ 0.779803@0] hdmitx: system: amhdmitx_init [ 0.783719@0] hdmitx: system: Ver: 2014May6 [ 0.787925@0] hdmitx: system: amhdmitx_probe [ 0.792320@0] hdmitx: system: not find ao cec [ 0.796451@0] hdmitx: system: not find vend_init_data [ 0.801634@0] hdmitx: system: gate/pwr cmd: 7 [ 0.805814@0] hdmitx: system: ALREADY init VIC = 16 [ 0.810675@0] hdmitx: system: gate/pwr cmd: 0 [ 0.815375@1] hdmitx: system: reset intr mask [ 0.830421@0] hdmitx: system: irq 1 [ 0.857652@0] bio: create slab <bio-0> at 0 [ 0.858347@0] SCSI subsystem initialized [ 0.861324@0] usbcore: registered new interface driver usbfs [ 0.865820@0] usbcore: registered new interface driver hub [ 0.871298@0] usbcore: registered new device driver usb [ 0.876582@0] Linux video capture interface: v2.00 [ 0.881691@0] mode is 12,sync_duration_den=1,sync_duration_num=60 [ 0.887232@0] TV mode 1080p selected. [ 0.890883@0] already display in uboot [ 0.894597@0] vinfo mode is: 1080p [ 0.900054@0] call aml_pmu_probe_init in [ 0.901939@0] aml_pmus_probe, child name:rn5t618 [ 0.906474@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 0.911195@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 0.920050@0] Advanced Linux Sound Architecture Driver Initialized. [ 0.926340@0] Bluetooth: Core ver 2.16 [ 0.929689@0] NET: Registered protocol family 31 [ 0.934221@0] Bluetooth: HCI device and connection manager initialized [ 0.940725@0] Bluetooth: HCI socket layer initialized [ 0.945746@0] Bluetooth: L2CAP socket layer initialized [ 0.950791@1] hdmitx: system: gate/pwr cmd: 4 [ 0.955292@0] Bluetooth: SCO socket layer initialized [ 0.960572@0] cfg80211: Calling CRDA to update world regulatory domain [ 0.967906@0] Switching to clocksource Timer-E [ 0.978953@0] NET: Registered protocol family 2 [ 0.979415@0] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.985143@0] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.991712@0] TCP: Hash tables configured (established 8192 bind 8192) [ 0.998164@0] TCP: reno registered [ 1.001521@0] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.007595@0] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.014214@0] NET: Registered protocol family 1 [ 1.018653@0] wifi_dev_probe [ 1.021461@0] wifi_dt : interrupt_pin=GPIOX_21 [ 1.025870@0] wifi_dt : irq_num=null [ 1.029425@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 1.034543@0] wifi_dt : power_on_pin=GPIOAO_6 [ 1.038871@0] wifi_dt : power_on_pin2=GPIOX_11 [ 1.043301@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 1.052273@0] Unpacking initramfs... [ 1.112917@0] Freeing initrd memory: 1584K (c4e08000 - c4f94000) [ 1.114852@0] bounce pool size: 64 pages [ 1.123664@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.124264@0] exFAT: Core Version 1.2.4 [ 1.127844@0] exFAT: FS Version 1.2.4 [ 1.132309@0] NTFS driver 2.1.30 [Flags: R/O]. [ 1.136134@0] fuse init (API version 7.22) [ 1.140446@0] msgmni has been set to 1194 [ 1.144436@0] io scheduler noop registered [ 1.148046@0] io scheduler deadline registered [ 1.151576@1] hdmitx: system: gate/pwr cmd: 5 [ 1.151577@1] hdmitx: edid: edid ready [ 1.151579@1] hdmitx: system: gate/pwr cmd: 4 [ 1.165002@0] io scheduler bfq registered (default) [ 1.169710@0] BFQ I/O-scheduler: v7r8 [ 1.225841@0] loop: module loaded [ 1.226544@0] tun: Universal TUN/TAP device driver, 1.6 [ 1.228898@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 1.235387@0] PPP generic driver version 2.4.2 [ 1.239829@0] PPP BSD Compression module registered [ 1.244502@0] PPP Deflate Compression module registered [ 1.249706@0] PPP MPPE Compression module registered [ 1.254643@0] NET: Registered protocol family 24 [ 1.259317@0] usbcore: registered new interface driver asix [ 1.264907@0] usbcore: registered new interface driver ax88179_178a [ 1.271088@0] usbcore: registered new interface driver cdc_ether [ 1.277075@0] usbcore: registered new interface driver net1080 [ 1.282885@0] usbcore: registered new interface driver cdc_subset [ 1.288937@0] usbcore: registered new interface driver zaurus [ 1.294712@0] usbcore: registered new interface driver cdc_ncm [ 1.300478@0] usbcore: registered new interface driver qf9700 [ 1.306203@0] usbcore: registered new interface driver sr9600 [ 1.312116@0] usbcore: registered new interface driver cdc_acm [ 1.317653@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.325891@0] usbcore: registered new interface driver usb-storage [ 1.332128@0] usbcore: registered new interface driver usbserial [ 1.338002@0] usbcore: registered new interface driver option [ 1.343728@0] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.351035@0] mousedev: PS/2 mouse device common for all mice [ 1.351576@1] hdmitx: system: gate/pwr cmd: 5 [ 1.351578@1] hdmitx: edid: edid ready [ 1.351583@1] hdmitx: edid: check sum valid [ 1.351584@1] hdmitx: edid: check sum valid [ 1.351586@1] hdmitx: edid: blk0 raw data [ 1.351607@1] 00ffffffffffff001e6dac59010101010516010380331d78ea6275a3554fa027 [ 1.351627@1] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.351647@1] 4500fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.351666@1] 34454135330a202020202020000000ff000a2020202020202020202020200106 [ 1.351667@1] [ 1.351668@1] hdmitx: edid: blk1 raw data [ 1.351687@1] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 1.351707@1] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 1.351726@1] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 1.351745@1] 22110000180000000000000000000000000000000000000000000000000000e6 [ 1.351746@1] [ 1.351775@1] hdmitx: edid: find IEEEOUT [ 1.351806@1] hdmitx: video: get current mode: 1080p [ 1.351813@1] hdmitx: system: [set_disp_mode_auto] ALREADY init VIC = 16 [ 1.351815@1] hdmitx: audio: audio channel num is 0 [ 1.351820@1] hdmitx: audio: SPDIF [ 1.351832@1] hdmitx: audio: current VIC: 16 [ 1.351833@1] hdmitx: audio: audio sample rate: 0 [ 1.351834@1] hdmitx: audio: set audio N para [ 1.351842@1] hdmitx: audio: PCM out to HDMI [ 1.372376@1] hdmitx: audio: Time out: AIU_HDMI_CLK_DATA_CTRL [ 1.372378@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 1.372379@1] hdmitx: audio: Enable audio spdif to HDMI [ 1.372435@1] hdmi detect: plug. [ 1.502124@0] i2c /dev entries driver [ 1.506043@0] device-mapper: uevent: version 1.0.3 [ 1.510417@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 1.518897@0] Bluetooth: HCI UART driver ver 2.2 [ 1.523359@0] Bluetooth: HCI H4 protocol initialized [ 1.528822@0] usbcore: registered new interface driver usbhid [ 1.534020@0] usbhid: USB HID core driver [ 1.538161@0] vout_init_module [ 1.541081@0] start init vout module [ 1.544667@0] create vout attribute ok [ 1.548529@0] ge2d_init [ 1.550831@0] ge2d_dev major:249 [ 1.554221@0] ge2d start monitor [ 1.557271@0] osd_init [ 1.557275@1] ge2d workqueue monitor start [ 1.563695@0] osd_probe, vinfo:c06077b8 [ 1.567642@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 1.575629@0] osd_probe, mydef_var:c08786d4, vinfo:c06077b8 [ 1.581172@0] init fbdev bpp is :32 [ 1.584641@0] ---------------clear framebuffer0 memory [ 1.612001@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0600000, size=1024K [ 1.614444@0] osd_probe, mydef_var:c08786d4, vinfo:c06077b8 [ 1.619990@0] don't find to display_size_default from mesonfb-dts [ 1.626068@0] init fbdev bpp is :24 [ 1.645260@0] osd probe ok [ 1.645405@0] vout2_init_module enter [ 1.645999@0] start init vout2 module [ 1.649675@0] create vout2 attribute ok [ 1.653616@0] enter aml_sysled_init [ 1.663069@0] amlvideo-000: V4L2 device registered as video10 [ 1.663347@0] amlvideo2: V4L2 device registered as video11 [ 1.669126@0] aml_wdt_driver_init,301 [ 1.672299@0] ** disable watchdog [ 1.675740@0] keys=========================================== [ 1.681314@0] keys_devno=f600000 [ 1.684669@0] securitykey: device aml_keys created [ 1.689270@0] amlkeys=0 [ 1.691780@0] platform_driver_register--aml_keys_driver-------------------- [ 1.698859@0] set uart_ao pinmux use pinctrl subsystem [ 1.703760@0] P_AO_RTI_PIN_MUX_REG:5860 [ 1.707573@0] start uart_ao_ttyS0:(irq = 122) [ 1.711906@0] register uart_ao ok [ 1.715377@0] set uart_a pinmux use pinctrl subsystem [ 1.720209@0] P_AO_RTI_PIN_MUX_REG:5860 [ 1.724053@0] start uart_a_ttyS1:(irq = 58) [ 1.728184@0] register uart_a ok [ 1.731599@0] start uart_d_ttyS4:(irq = 126) [ 1.735638@0] register uart_d ok [ 1.738966@0] dwc_otg: version 3.10a 12-MAY-2014 [ 1.743493@0] dwc_otg_driver_probe NOT match [ 1.747719@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 1.756295@0] USB (1) use clock source: XTAL input [ 1.782085@0] Core Release: 3.10a [ 1.782108@0] Setting default values for core params [ 1.784705@0] curmode: 1, host_only: 1 [ 1.808531@0] Using Buffer DMA mode [ 1.808555@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.810886@0] Working on port type = HOST [ 1.814936@0] dwc_otg lm1: DWC OTG Controller [ 1.819220@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 1.825915@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 1.830826@0] -------hcd->flags.d32 = 0 [ 1.834671@0] Init: Port Power? op_state=1 [ 1.838710@0] Init1: Power Port (0) [ 1.842279@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.849120@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.856500@0] usb usb1: Product: DWC OTG Controller [ 1.861352@0] usb usb1: Manufacturer: Linux 3.10.105 dwc_otg_hcd [ 1.867321@0] usb usb1: SerialNumber: lm1 [ 1.871672@0] hub 1-0:1.0: USB hub found [ 1.875212@0] hub 1-0:1.0: 1 port detected [ 1.879442@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 1.887889@0] USB (0) use clock source: XTAL input [ 1.913677@0] Core Release: 3.10a [ 1.913701@0] Setting default values for core params [ 1.916295@0] curmode: 1, host_only: 0 [ 1.980095@0] Using Buffer DMA mode [ 1.980120@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.982468@0] Working on port type = OTG [ 1.986351@0] Current port type: SLAVE [ 1.990115@0] dwc_otg lm0: DWC OTG Controller [ 1.994442@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 2.001103@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 2.006075@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.012986@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.020333@0] usb usb2: Product: DWC OTG Controller [ 2.025206@0] usb usb2: Manufacturer: Linux 3.10.105 dwc_otg_hcd [ 2.031170@0] usb usb2: SerialNumber: lm0 [ 2.035496@0] hub 2-0:1.0: USB hub found [ 2.039061@0] hub 2-0:1.0: 1 port detected [ 2.043261@0] Dedicated Tx FIFOs mode [ 2.046855@0] using timer detect id change, ee374000 [ 2.051860@0] boot_device_flag : 0 [ 2.055091@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 2.064656@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 2.071499@0] amlnf_phy_init : amlnf init flag 0 [ 2.071518@1] Indeed it is in host mode hprt0 = 00021501 [ 2.081463@0] ######STS IRQ mode for nand driver [ 2.086000@0] NAND device id: ad de 14 a7 42 4a ad de [ 2.090980@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 2.137384@0] AML_NAND_NEW_OOB : new oob [ 2.137412@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 2.143582@0] boot_device_flag = 0 [ 2.149771@0] uncorrect ecc here at page:2048, chip:0 [ 2.152054@0] blk check good but read failed at chip 0 page 2048 [ 2.158541@0] hynix nand get default reg value at blk:8, page:2049 [ 2.165809@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 2.176507@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 2.181325@0] nand shipped bbt at block 0 [ 2.187498@0] uncorrect ecc here at page:2048, chip:0 [ 2.189829@0] nand blk check good but read failed at chip 0 page 2048 [ 2.245927@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 92 [ 2.249267@0] i=0,register --- nand_key [ 2.252579@0] nand adjust phy offset : block 4 [ 2.256957@0] nand adjust phy offset : block 4 [ 2.261406@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 2.270911@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 2.271272@1] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.287071@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 2.296595@1] Indeed it is in host mode hprt0 = 00001101 [ 2.297833@0] bad block count = 0 [ 2.297833@0] [ 2.301125@0] bad block count = 0 [ 2.301125@0] [ 2.312797@0] bad block count = 0 [ 2.312797@0] [ 2.316675@0] amlnand_add_nftl: [ 2.319796@0] Creating 1 ntd partitions [ 2.323627@0] block_num 76 [ 2.327620@0] ------init_ntd [ 2.329549@0] ntd: Giving out device 0 to nfcache [ 2.333947@0] Creating 7 ntd partitions [ 2.337739@0] block_num 204 [ 2.344144@0] ntd: Giving out device 1 to nfcode [ 2.345194@0] Creating 1 ntd partitions [ 2.349013@0] block_num 720 [ 2.363817@0] ntd: Giving out device 2 to nfdata [ 2.364306@0] ethernet_driver probe! [ 2.366349@0] Please config phy interface. [ 2.370507@0] Please config savepowermode. [ 2.374611@0] Please config reset_pin_enable. [ 2.378918@0] Please config reset_delay. [ 2.382839@0] Please config reset_pin. [ 2.386545@0] ethernetinit(dbg[c087ea28]=1) [ 2.390721@0] ethernet base addr is fe0c0000 [ 2.394970@0] write mac add to:ee341f48: ae 9e ba 9b 60 cb |....`.| [ 2.403735@0] libphy: AMLMAC MII Bus: probed [ 2.405443@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 2.411360@0] Amlogic A/V streaming port init [ 2.416690@0] buffersize=262144,0,start=0 [ 2.419488@0] Subtitle stbuf alloced at 0xee3c0000, size = 262144 [ 2.425577@0] changed the (2) buffer size from 0 to 262144 [ 2.431229@0] init vdec memsource 79f00000->7defffff [ 2.436152@0] [tsync_pcr_init]init success. [ 2.440199@0] amvideocap_init_module [ 2.443803@0] amvideocap_probe,amvideocap [ 2.447747@0] amvideocap_dev_register buf:0d200000,size:800000. [ 2.454021@0] regist mpeg12 codec profile [ 2.457701@0] regist mpeg4 codec profile [ 2.461547@0] amvdec_vc1 module init [ 2.465159@0] regist vc1 codec profile [ 2.468805@0] amvdec_h264 module init [ 2.472563@0] regist h264 codec profile [ 2.476259@0] amvdec_h264mvc module init [ 2.480238@0] regist hmvc codec profile [ 2.483993@0] amvdec_h264_4k2k module init [ 2.488129@0] regist h264_4k2k codec profile [ 2.492328@0] amvdec_h265 module init [ 2.496034@0] regist hevc_unsupport codec profile [ 2.500695@0] regist mjpeg codec profile [ 2.504538@0] amvdec_real module init [ 2.508237@0] amvdec_avs module init [ 2.511904@0] amvenc_avc memory resource undefined. [ 2.516570@0] amvenc_avc memory is invaild, probe fail! [ 2.521805@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 2.528554@0] picdec buffer size is 4000000 [ 2.532550@0] alloc_keep_buffer keep_y_addr ede00000 [ 2.537317@0] alloc_keep_buffer keep_u_addr ee400000 [ 2.542266@0] alloc_keep_buffer keep_v_addr ee500000 [ 2.547188@0] yaddr=ede00000,u_addr=ee400000,v_addr=ee500000 [ 2.547196@1] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 2.547201@1] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.547205@1] usb 1-1: Product: USB2.0 Hub [ 2.571336@1] hub 1-1:1.0: USB hub found [ 2.574990@0] create_ge2d_work_queue video task ok [ 2.579796@1] hub 1-1:1.0: 4 ports detected [ 2.584344@0] efuse=========================================== [ 2.589987@0] efuse: device efuse created [ 2.593865@0] efuse-------------------------------------------- [ 2.599653@0] SARADC Driver init. [ 2.603071@0] __saradc_probe__ [ 2.751379@2] saradc calibration: ref_val = 508 [ 2.751409@2] saradc calibration: ref_nominal = 512 [ 2.755123@2] saradc calibration: coef = 4064 [ 2.759738@2] ir irblaster probe [ 2.762910@2] Remote Driver [ 2.765499@2] Remote platform_data g_remote_base=fe600580 [ 2.770836@2] set drvdata completed [ 2.774399@2] device_create_file completed [ 2.778895@2] input: aml_keypad as /devices/platform/meson-remote/input/input0 [ 2.786046@2] input_register_device completed [ 2.790356@2] [0xffffff00] = 0x1dd0190 [ 2.794054@2] [0xffffff04] = 0xf800ca [ 2.797684@2] [0xffffff08] = 0x82006e [ 2.801347@2] [0xffffff0c] = 0x3c0030 [ 2.804965@2] [0xffffff10] = 0x30fa0013 [ 2.808779@2] [0xffffff18] = 0x6f19000 [ 2.812513@2] [0xffffff1c] = 0xbe40 [ 2.815974@2] [0x0] = 0xfa00a0 [ 2.819007@2] [0x4] = 0xfa00a0 [ 2.822057@2] [0x8] = 0xfa00a0 [ 2.825075@2] [0xc] = 0x640030 [ 2.828109@2] [0x10] = 0x30fa0013 [ 2.831412@2] [0x18] = 0x961b800 [ 2.834610@2] [0x1c] = 0x9740 [ 2.837557@2] [0x20] = 0x104 [ 2.840418@2] [0x24] = 0x0 [ 2.843113@2] [0x28] = 0x0 [ 2.845792@2] set_remote_mode[69] [ 2.849100@2] remote config major:240 [ 2.852984@2] physical address:0x2e41e000 [ 2.856870@2] ADC Keypad Driver init. [ 2.860559@2] Meson KeyInput init [ 2.863865@2] GPIO Keypad Driver init. [ 2.867514@2] ==gpio_key_probe== [ 2.870689@2] reg:2620,clearmask=400040,setmask=1 [ 2.875439@2] reg:2622,clearmask=ff0000,set pin=3 [ 2.880119@2] reg:2623,clearmask=7000000,setmask=7 [ 2.884901@2] reg:2620,clearmask=800080,setmask=10001 [ 2.890001@2] reg:2622,clearmask=ff000000,set pin=3 [ 2.894855@2] reg:2623,clearmask=70000000,setmask=7 [ 2.899734@2] power key(116) registed. [ 2.899736@0] key 116 up [ 2.906098@2] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1 [ 2.913447@2] gpio keypad register input device completed. [ 2.918782@2] gpio keypad major:239 [ 2.922476@2] spi_nor_init [ 2.925037@2] amlogic_spi_nor_probe: [ 2.928491@2] amlogic_spi->state_name:default [ 2.932964@2] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 2.940454@2] check_storage_device : spi boot_device_flag : 0 [ 2.946096@2] spi_nor_probe [ 2.948884@2] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 2.954670@2] Creating 2 MTD partitions on "apollospi:32766": [ 2.960304@2] 0x000000000000-0x000000100000 : "bootloader" [ 2.966457@2] 0x000000100000-0x000000110000 : "ubootenv" [ 2.971651@2] amlogic_spi_nor_probe over [ 2.975092@2] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 2.984538@2] host->base fe108c20 [ 2.987718@2] pdata->caps 7 [ 2.990466@2] pdata->caps2 0 [ 2.993350@2] get property: port, value:0x00000001 [ 2.999828@2] get property: ocr_avail, value:0x00200000 [ 3.006339@2] get property: f_min, value:0x000493e0 [ 3.012840@2] get property: f_max, value:0x02faf080 [ 3.019332@2] get property: max_req_size, value:0x00020000 [ 3.025883@2] get property: irq_in, value:0x00000003 [ 3.032341@2] get property: irq_out, value:0x00000005 [ 3.038838@2] get property: gpio_cd, str:CARD_6 [ 3.044824@2] get property: pinname, str:sd [ 3.050451@2] get property: jtag_pin, str:CARD_0 [ 3.056440@2] get property: card_type, value:0x00000005 [ 3.062940@2] get property: gpio_dat3, str:CARD_4 [ 3.101293@2] reg:2620,clearmask=80008,setmask=10001 [ 3.101331@2] reg:2621,clearmask=ff000000,set pin=64 [ 3.105643@2] reg:2623,clearmask=7000,setmask=7 [ 3.110151@2] reg:2620,clearmask=200020,setmask=1 [ 3.114918@2] reg:2622,clearmask=ff00,set pin=64 [ 3.119512@2] reg:2623,clearmask=700000,setmask=7 [ 3.124316@2] pdata->caps 80000507 [ 3.127574@2] pdata->caps2 0 [ 3.130435@2] get property: port, value:0x00000002 [ 3.136945@2] get property: ocr_avail, value:0x00200000 [ 3.143443@2] get property: f_min, value:0x000493e0 [ 3.149937@2] get property: f_max, value:0x02faf080 [ 3.156450@2] get property: f_max_w, value:0x02faf080 [ 3.162947@2] get property: max_req_size, value:0x00020000 [ 3.169445@2] get property: pinname, str:emmc [ 3.175257@2] get property: card_type, value:0x00000001 [ 3.181759@2] get property: gpio_dat3, str:BOOT_3 [ 3.187732@2] [is_emmc_exist] host->storage_flag=4, POR_BOOT_VALUE=5 [ 3.194065@2] [aml_sdio_probe]: there is not eMMC/tsd, skip sdio_c dts config! [ 3.201273@2] pdata->caps 107 [ 3.204200@2] pdata->caps2 0 [ 3.207061@2] get property: port, value:0x00000000 [ 3.213568@2] get property: ocr_avail, value:0x00200000 [ 3.220063@2] get property: f_min, value:0x000493e0 [ 3.226570@2] get property: f_max, value:0x02faf080 [ 3.233071@2] get property: max_req_size, value:0x00020000 [ 3.239569@2] get property: pinname, str:sdio [ 3.245380@2] get property: card_type, value:0x00000003 [ 3.291276@2] [aml_sdio_probe] aml_sdio_probe() success! [ 3.291545@2] [dsp]DSP start addr 0xc5e00000 [ 3.295214@2] [dsp]register dsp to char divece(257) [ 3.300434@2] amlogic audio spdif interface device init! [ 3.305400@2] name=nand_key nand_key [ 3.309476@2] register_aes_algorithm:488,new way [ 3.313817@2] key name:keyexample, key data:1234567890 [ 3.319211@2] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0 [ 3.328083@2] amaudio2: device amaudio2 created [ 3.329288@2] Amlogic CEC Driver, (c) 2016 Gerald Dachs, Version: 0.0.1 [ 3.335779@2] [amlogic_cec] amlogic_cec_init(): CEC init [ 3.341171@2] [amlogic_cec] amlogic_cec_init(): CEC init finished: 0 [ 3.347436@2] Error: Didn't get power valid value --- wifi_power_probe 376 [ 3.354233@2] Error: Didn't get suspend_power_off value --- wifi_power_probe 393 [ 3.361602@2] wifi_power power_gpio is 6 [ 3.365493@2] wifi_power power_gpio2 is 123 [ 3.369920@2] bcmdhd_wlan_init() [ 3.372874@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[0]=ee928600, size=3760 [ 3.379883@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[1]=ee9286c0, size=3760 [ 3.386913@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[2]=ee928780, size=3760 [ 3.394030@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[3]=ee928d80, size=3760 [ 3.400946@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[4]=ee928cc0, size=3760 [ 3.407975@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[5]=ee928f00, size=3760 [ 3.415006@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[6]=ee928540, size=3760 [ 3.422018@2] 1 bcmdhd_init_wlan_mem: wlan_static_skb[7]=ee928300, size=3760 [ 3.429035@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[8]=ee928240, size=7856 [ 3.436058@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[9]=ee928e40, size=7856 [ 3.443079@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[10]=ee928b40, size=7856 [ 3.450181@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[11]=ee928180, size=7856 [ 3.457297@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[12]=ee9280c0, size=7856 [ 3.464403@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[13]=ee928000, size=7856 [ 3.471510@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[14]=ee928840, size=7856 [ 3.478613@2] 2 bcmdhd_init_wlan_mem: wlan_static_skb[15]=ee928a80, size=7856 [ 3.485740@2] 3 bcmdhd_init_wlan_mem: wlan_static_skb[16]=ee9289c0, size=16048 [ 3.492925@2] 4 bcmdhd_init_wlan_mem: wlan_mem_array[0]=ee928600, size=20504 [ 3.499938@2] 4 bcmdhd_init_wlan_mem: wlan_mem_array[1]=ee9286c0, size=20504 [ 3.506969@2] 4 bcmdhd_init_wlan_mem: wlan_mem_array[2]=ee928780, size=81944 [ 3.513990@2] 4 bcmdhd_init_wlan_mem: wlan_mem_array[3]=ee928d80, size=163864 [ 3.521088@2] 4 bcmdhd_init_wlan_mem: wlan_mem_array[4]=ee928cc0, size=20504 [ 3.528116@2] 5 bcmdhd_init_wlan_mem: wlan_static_scan_buf0=ee850000, size=65536 [ 3.535487@2] 6 bcmdhd_init_wlan_mem: wlan_static_scan_buf1=ee310000, size=65536 [ 3.542849@2] bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 3.547958@2] amlogic rfkill init [ 3.551304@2] not get gpio_en [ 3.554199@2] not get gpio_wake [ 3.581376@2] BT_RADIO going: on [ 3.581398@2] BCM_BT: going ON [ 3.641266@2] wifi_request_32k_clk : OFF-->ON for bt_rfkill [ 3.641302@2] clock_32k_pin(122) : (null) [ 3.645188@2] clock_32k_pin(122) : sdio_wifi [ 3.751551@2] UMP: UMP device driver -2017.02-100-gc2abd0d loaded [ 3.752219@2] aml_aes aml_aes: Aml AES [ 3.756028@2] aml_tdes aml_tdes: Aml TDES [ 3.760076@2] usbcore: registered new interface driver snd-usb-audio [ 3.766454@2] enter rt5616_modinit [ 3.769600@2] dummy_codec_platform_probe [ 3.773530@2] == ES8323 == es8323_modinit() [ 3.777952@2] i2s get no clk src setting in dts, use the default mpll 0 [ 3.784175@2] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000 [ 3.792317@2] [aml-spdif-dai]enter aml_dai_spdif_init [ 3.797076@2] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4 [ 3.804202@2] audio_set_958_clk, freq=4, [ 3.808087@2] IEC958 16bit [ 3.810771@2] hdmitx: audio: aout notify rate 48000 [ 3.815631@2] hdmitx: audio: aout notify size 16 [ 3.820218@2] hdmitx: audio: aout notify format CT_PCM [ 3.825339@2] hdmitx: audio: audio channel num is 1 [ 3.830189@2] hdmitx: audio: SPDIF [ 3.833629@2] hdmitx: audio: current VIC: 16 [ 3.837814@2] hdmitx: audio: audio sample rate: 3 [ 3.842504@2] hdmitx: audio: set audio N para [ 3.846834@2] hdmitx: audio: PCM out to HDMI [ 3.851077@2] hdmitx: audio: i2s_to_spdif_flag:1 [ 3.855765@2] hdmitx: audio: Enable audio spdif to HDMI [ 3.860961@2] hdmitx: audio: Audio Type: PCM [ 3.865253@2] hdmitx: audio: set audio param [ 3.869508@2] [aml-spdif-dai]aml_spdif_probe [ 3.873862@2] test codec dummy_codec [ 3.877256@2] using external codec, index = 1 [ 3.881601@2] using external dummy codec [ 3.885609@2] enter spdif_dit_probe [ 3.889043@2] aml_spdif_unmute [ 3.892356@2] codec_name = dummy_codec.0 [ 3.896269@2] p_aml_audio->hp_disable=1 [ 3.899880@2] falied to get spk event delay time paraments from dts file [ 3.906575@2] spk_event delay_time = 0 [ 3.910479@2] aml-i2s 0:playback preallocate_dma_buffer: area=f044c000, addr=2e7a0000, size=65536 [ 3.919347@2] aml-i2s 1:capture preallocate_dma_buffer: area=f0471000, addr=2dd00000, size=65536 [ 3.927901@2] aml_snd_m8 aml_m8_sound_card.5: dummy_codec <-> aml-i2s-dai.0 mapping ok [ 3.936107@2] aml-i2s 0:playback preallocate_dma_buffer: area=f0492000, addr=2dd20000, size=65536 [ 3.944912@2] aml-i2s 1:capture preallocate_dma_buffer: area=f04a4000, addr=2dd40000, size=65536 [ 3.953470@2] aml_snd_m8 aml_m8_sound_card.5: dit-hifi <-> aml-spdif-dai.0 mapping ok [ 3.962182@2] -----ext_codec=1--- [ 3.964646@2] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0 [ 3.970871@2] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.976118@2] TCP: cubic registered [ 3.979542@2] NET: Registered protocol family 17 [ 3.984159@2] NET: Registered protocol family 15 [ 3.988773@2] Bridge firewalling registered [ 3.992959@2] Bluetooth: RFCOMM TTY layer initialized [ 3.997927@2] Bluetooth: RFCOMM socket layer initialized [ 4.003215@2] Bluetooth: RFCOMM ver 1.11 [ 4.007106@2] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 4.012575@2] Bluetooth: BNEP filters: protocol multicast [ 4.017946@2] Bluetooth: BNEP socket layer initialized [ 4.023063@2] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 4.029126@2] Bluetooth: HIDP socket layer initialized [ 4.034759@2] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 4.042087@2] Registering SWP/SWPB emulation handler [ 4.046980@2] enter meson_pm_init [ 4.050366@2] enter meson_pm_probe! [ 4.053757@2] meson_pm_probe done ! [ 4.057653@2] regulator-dummy: disabling [ 4.061581@2] aml_rtc rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) [ 4.068495@2] ### dt-test ### No testcase data in device tree; not running tests [ 4.075939@2] meson_cpufreq: no voltage_control prop [ 4.080785@2] voltage_control = 0 [ 4.084345@2] buf[0]=a7,buf[1]=9b,err=4 [ 4.087894@2] M8:adc=442,TS_C=7,flag=1 [ 4.091632@2] efuse_flag=a [ 4.094309@2] amlogic_thermal_probe, this chip is trimmed, use thermal [ 4.100811@2] amlogic-thermal aml_thermal: amlogic thermal probe start [ 4.107320@2] #thermal-cells=7 [ 4.110344@2] pdata->temp_trip_count=4 [ 4.114079@2] temperature=70000 on trip point=0 [ 4.118578@2] fixing high_freq=1608001 to 1608000 at trip point 0,level=2 [ 4.125339@2] fixing low_freq=1608001 to 1608000 at trip point 0,level=2 [ 4.132024@2] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511 [ 4.138429@2] cpu[0] core num==3 [ 4.141642@2] gpu[0] core num==5 [ 4.144843@2] temperature=80000 on trip point=1 [ 4.149350@2] fixing high_freq=1200001 to 1200000 at trip point 1,level=6 [ 4.156111@2] fixing low_freq=1200001 to 1200000 at trip point 1,level=6 [ 4.162795@2] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435 [ 4.169201@2] cpu[1] core num==2 [ 4.172413@2] gpu[1] core num==4 [ 4.175615@2] temperature=90000 on trip point=2 [ 4.180122@2] fixing high_freq=800001 to 696000 at trip point 2,level=11 [ 4.186797@2] fixing low_freq=800001 to 696000 at trip point 2,level=11 [ 4.193391@2] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328 [ 4.199800@2] cpu[2] core num==2 [ 4.203012@2] gpu[2] core num==3 [ 4.206214@2] temperature=260000 on trip point=3 [ 4.210808@2] fixing high_freq=-1 to -22 at trip point 3,level=-1 [ 4.216876@2] fixing low_freq=-1 to -22 at trip point 3,level=-1 [ 4.222863@2] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1 [ 4.229098@2] cpu[3] core num==-1 [ 4.232397@2] gpu[3] core num==-1 [ 4.235687@2] idle interval=1000 [ 4.238894@2] pdata->name:aml_thermal [ 4.242942@2] tmp_trip[0].cpu_core_upper=1 [ 4.246616@2] tmp_trip[1].cpu_core_upper=2 [ 4.250688@2] tmp_trip[2].cpu_core_upper=2 [ 4.254777@2] tmp_trip[3].cpu_core_upper=-1 [ 4.258923@2] aml_thermal bind thermal-cpucore-0 okay ! [ 4.264153@2] aml_thermal bind thermal-cpufreq-0 okay ! [ 4.269443@2] amlogic: Kernel Thermal management registered [ 4.274876@2] amlogic-thermal aml_thermal: amlogic thermal probe done [ 4.2814r[ 4.301281@0] Changing uart_ao_ttyS0: baud from 0 to 115200 [ 4.321385@2] Freeing unused kernel memory: 180K (c080d000 - c083a000) [ 4.333534@1] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 4.334508@1] Disabling lock debugging due to kernel taint [ 4.340817@1] boot_device_flag : 0 [ 4.343363@1] register_ntd_blktrans start [ 4.347339@1] ntd device 250! [ 4.350284@1] ntd->name: nfcache [ 4.353501@1] adjust_block_num : 4,reserved_block_ratio 10 [ 4.358959@1] nftl version 140911a [ 4.362487@1] nftl part attr 0 [ 4.366593@1] nftl start:76,12 [ 4.368513@1] first [ 4.442849@1] average_erase_count:0 [ 4.442874@1] second 55,64 [ 4.443384@1] part->max_discard_block = 4 [ 4.506566@1] all block full!! [ 4.506586@1] all discard block full!! [ 4.507720@1] free list: [ 4.510308@1] free block cnt = 61 [ 4.513608@1] new current block is 20 [ 4.517242@1] total discard page count is 0 [ 4.521410@1] create_part_list:1235,current_used_discard_block=19,current_discard_block_used_count=160 [ 4.530949@1] unmappig_pages=15832,discarded_pages=0,mapping_pages=552 [ 4.537193@1] nftl ok! [ 4.540240@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 4.544550@1] aml_nftl_add_ntd ok [ 4.547408@1] ntd device 250! [ 4.550355@1] ntd->name: nfcode [ 4.553487@1] adjust_block_num : 4,reserved_block_ratio 10 [ 4.558939@1] nftl version 140911a [ 4.562343@1] nftl part attr 0 [ 4.568614@1] size_in_blk 204; total_block 203; [ 4.569946@1] nftl start:203,23 [ 4.573350@1] first [ 4.706053@1] found discard block:139 [ 4.766324@1] average_erase_count:6 [ 4.766349@1] second 202,180 [ 4.767032@1] part->max_discard_block = 4 [ 4.988273@1] all block full!! [ 4.989242@1] currnet_discard_block1:139 [ 5.023992@1] reach the last discard page:28 [ 5.024043@1] free list: [ 5.025221@1] free block cnt = 91 [ 5.028515@1] new current block is 39 [ 5.032162@1] total discard page count is 28 [ 5.036404@1] create_part_list:1235,current_used_discard_block=139,current_discard_block_used_count=91 [ 5.046352@1] unmappig_pages=25320,discarded_pages=119,mapping_pages=20641 [ 5.052532@1] nftl ok! [ 5.055660@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.059878@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.064463@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.069063@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.073645@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.078221@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.082850@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 5.087363@1] aml_nftl_add_ntd ok [ 5.090319@1] ntd device 250! [ 5.093275@1] ntd->name: nfdata [ 5.096388@1] adjust_block_num : 4,reserved_block_ratio 10 [ 5.101874@1] nftl version 140911a [ 5.105288@1] nftl part attr 0 [ 5.119778@1] size_in_blk 720; total_block 714; [ 5.119807@1] nftl start:714,69 [ 5.122510@1] first [ 5.784819@1] found discard block:701 [ 5.797229@1] average_erase_count:2 [ 5.797259@1] second 713,645 [ 5.797936@1] part->max_discard_block = 4 [ 6.572185@1] all block full!! [ 6.573158@1] currnet_discard_block1:701 [ 6.606151@1] reach the last discard page:28 [ 6.606846@1] free list: [ 6.607380@1] free block cnt = 23 [ 6.610674@1] new current block is 263 [ 6.614408@1] total discard page count is 28 [ 6.618650@1] create_part_list:1235,current_used_discard_block=701,current_discard_block_used_count=30 [ 6.630482@1] unmappig_pages=116929,discarded_pages=3583,mapping_pages=44608 [ 6.634956@1] nftl ok! [ 6.638120@1] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.642273@1] aml_nftl_add_ntd ok [ 6.645181@1] init_aml_nftl end [ 6.651786@1] aml_nftl_open ok! [ 6.653046@1] force enable DISCARD here for ext4 fs [ 6.723050@1] EXT4-fs (syslinux): recovery complete [ 6.727595@1] checked enable EXT4 DISCARD here [ 6.727627@1] EXT4-fs (syslinux): mounted filesystem with ordered data mode. Opts: (null) mount: proc is already mounted or /proc busy proc is already mounted on /proc [ 7.009946@1] EXT4-fs (syslinux): re-mounted. Opts: (null) Starting logging: OK remotecfg parameter[0] /usr/bin/amremote_config remotecfg parameter[1] /etc/remote.conf curpara:factory[ 8.455473@3] cur_mode = 0 [ 8.458070@3] [0x0] = 0x1dd0190 [ 8.461188@3] [0x4] = 0xf800ca [ 8.464239@3] [0x8] = 0x82006e [ 8.467256@3] [0xc] = 0x3c0030 [ 8.470290@3] [0x10] = 0x30fa0013 [ 8.473693@3] [0x18] = 0x6f19000 [ 8.476791@3] [0x1c] = 0x9f40 [ 8.479738@3] [0x20] = 0x0 [ 8.482434@3] [0x24] = 0x0 [ 8.485113@3] [0x28] = 0x0 [ 8.487800@3] set_remote_mode[69] _code 40400001 curpara:work_mode 00000000 curpara:repeat_enable 00000001 curpara:release_delay 00000096 curpara:debug_enable 00000001 curpara:reg_control 000fbe40 KEYMAP_LEVEL: ircode = 0x2, keycode = 31 KEYMAP_LEVEL: ircode = 0x3, keycode = 23 KEYMAP_LEVEL: ircode = 0xa, keycode = 105 KEYMAP_LEVEL: ircode = 0xb, keycode = 103 KEYMAP_LEVEL: ircode = 0xc, keycode = 106 KEYMAP_LEVEL: ircode = 0xd, keycode[ 8.527968@3] udevd[1718]: starting version 3.2.1 = 108 KEYMAP_LEVEL: ircode = 0xe, keycode = 28 KEYMAP_LEVEL: ircode = 0x4, keycode = 14 KEYMAP_LEVEL: ircode = 0x5, keycode = 15 KEYMAP_LEVEL: ircode = 0x6, keycode = 57 KEYMAP_LEVEL: ir[ 8.550808@0] udevd[1719]: starting eudev-3.2.1 code = 0x7, keycode = 46 KEYMAP_LEVEL: ircode = 0x9, keycode = 66 KEYMAP_LEVEL: ircode = 0x8, keycode = 45 work_mode = 0 repeat_enable = 1 factory_code = 16448 release_delay = 0x96 debug_enable = 0x1 reg_control = 1031744 Populating /dev using udev: [ 8.665249@1] aml_nftl_open ok! [ 8.665335@0] aml_nftl_open ok! [ 8.666300@2] aml_nftl_open ok! [ 8.666405@0] aml_nftl_open ok! [ 8.673043@1] aml_nftl_open ok! [ 8.674766@2] aml_nftl_open ok! [ 8.674903@3] aml_nftl_open ok! [ 8.675869@3] aml_nftl_open ok! [ 8.853852@1] as an end receiver [ 8.853850@1] amlvideo openamlvideo closedone S11setup: start S10setup: remount / rw [ 8.874645@3] EXT4-fs (syslinux): re-mounted. Opts: (null) [ 8.879292@3] aml_nftl_open ok! [ 8.880500@3] force enable DISCARD here for ext4 fs [ 8.965363@3] EXT4-fs (data): recovery complete [ 8.967958@3] checked enable EXT4 DISCARD here [ 8.968679@3] EXT4-fs (data): mounted filesystem with ordered data mode. Opts: (null) S10setup: mount /cache partition [ 8.981419@3] aml_nftl_open ok! [ 8.983709@3] force enable DISCARD here for ext4 fs [ 9.000631@3] EXT4-fs (cache): recovery complete [ 9.000666@3] checked enable EXT4 DISCARD here [ 9.004151@3] EXT4-fs (cache): mounted filesystem with ordered data mode. Opts: (null) /etc/init.d/S11setup: line 71: /sys/block/mmcblk0/queue/read_ahead_kb: No such file or directory /etc/init.d/S11setup: line 72: /sys/block/mmcblk1/queue/read_ahead_kb: No such file or directory S12make_binds: Start S12make_binds: Setting dropbear... Initializing random number generator... done. Starting system message bus: done [ 9.188164@3] dhd_module_init in [ 9.188196@3] wifi_setup_dt [ 9.188534@3] wifi_request_32k_clk : ON-->ON for sdio_wifi [ 9.194199@3] interrupt_pin(133) : (null) [ 9.197993@3] reg:2620,clearmask=100010,setmask=0 [ 9.202749@3] reg:2622,clearmask=ff,set pin=133 [ 9.207257@3] reg:2623,clearmask=70000,setmask=4 [ 9.211865@3] interrupt_pin(133) : sdio_wifi [ 9.216161@3] power_on_pin(6) : (null) [ 9.219830@3] power_on_pin(6) : sdio_wifi [ 9.223824@3] power_on_pin2(123) : (null) [ 9.227844@3] power_on_pin2(123) : sdio_wifi [ 9.232158@3] ======== bcm_wlan_set_plat_data ======== [ 9.237161@3] host_oob_irq: 100 [ 9.240455@3] host_oob_irq_flags=4 [ 9.243848@3] dhd_wifi_platform_load: Enter [ 9.248064@3] Power-up adapter 'DHD generic adapter' [ 9.253013@3] wifi_platform_set_power = 1 [ 9.256925@3] ======== PULL WL_REG_ON HIGH! ======== [ 9.261884@3] WIFI Disable! 6 [ 9.464746@3] WIFI Enable! 6 [ 9.664585@1] sdio: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 9.791499@2] IRQ94 no longer affine to CPU2 [ 9.791746@1] CPU2: shutdown [ 9.961518@3] IRQ95 no longer affine to CPU3 [ 9.961707@1] CPU3: shutdown [ 10.661266@1] [aml_sdio_timeout][0;40;33m time_start_cnt:995 [ 10.661266@1] [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd52 arg 0xc00, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x113, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:993 [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd52 arg 0x80000c08, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x3f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m [ 12.701270@0] [aml_sdio_timeout][0;40;33m time_start_cnt:992 [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd8 arg 0x1aa, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[ 12.734412@1] sdio: queuing unknown CIS tuple 0x80 (2 bytes) [ 12.735775@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 12.741391@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 12.748082@1] sdio: queuing unknown CIS tuple 0x80 (7 bytes) [ 12.765631@1] sdio: new high speed SDIO card at address 0001, clock 35416666, 4-bit-bus-width [ 12.770440@0] [sdio_reinit] finish [ 12.981277@0] wifi_platform_bus_enumerate device present 1 [ 12.981311@0] ======== Card detection to detect SDIO card! ======== [ 13.003435@0] bcmsdh_register: register client driver [ 13.003566@0] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 13.007880@1] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 13.012748@1] bus num (host idx)=2, slot num (rca)=1 [ 13.017668@1] found adapter info 'DHD generic adapter' [ 13.022797@1] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c088382c, size=139264 [ 13.031016@1] success alloc section 3, size 139264 [ 13.035880@1] alloc static buf at ee5c0000! [ 13.039945@1] 1 bcmdhd_mem_prealloc: section=4, wlan_static_skb=c0abd1c4 [ 13.046630@1] success alloc section 4, size 0 [ 13.051585@1] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362 [ 13.058934@1] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9 [ 13.064343@1] DHD: dongle ram size is set to 245760(orig 245760) at 0x0 [ 13.070711@1] dhdsdio_probe: Disable prop_txstatus [ 13.074805@1] 4 bcmdhd_mem_prealloc: section=7, wlan_mem_array[4]=ee8f8000 [ 13.081646@1] success alloc section 7, size 19512 [ 13.086419@1] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c0883814, size=10320 [ 13.094475@1] success alloc section 0, size 10320 [ 13.099592@1] 2 bcmdhd_mem_prealloc: section=5, wlan_static_scan_buf0=ee850000 [ 13.106372@1] success alloc section 5, size 0 [ 13.110740@1] wl_create_event_handler(): thread:wl_event_handler:6ef started [ 13.117722@1] tsk Enter, tsk = 0xf045e66c [ 13.121836@0] dhd_attach(): thread:dhd_watchdog_thread:6f0 started [ 13.127871@0] dhd_attach(): thread:dhd_dpc:6f1 started [ 13.133170@0] dhd_attach(): thread:dhd_rxf:6f2 started [ 13.138081@0] dhd_deferred_work_init: work queue initialized [ 13.143928@0] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c088381c, size=10300 [ 13.152027@0] success alloc section 1, size 10300 [ 13.156630@0] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c0883824, size=65536 [ 13.164821@0] success alloc section 2, size 65536 [ 13.169681@1] Dongle Host Driver, version 1.141.66.1 (r483454) [ 13.169681@1] Compiled in drivers/net/wireless/bcmdhd on Mar 10 2017 at 07:36:50 [ 13.183155@1] Register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 13.183155@1] [ 13.190254@1] dhd_prot_ioctl : bus is down. we have nothing to do [ 13.196374@1] bcmsdh_oob_intr_unregister: Enter [ 13.200827@1] bcmsdh_oob_intr_unregister: irq is not registered [ 13.206744@1] dhd_bus_devreset: WLAN OFF DONE [ 13.211188@1] wifi_platform_set_power = 0 [ 13.215147@1] ======== PULL WL_REG_ON LOW! ======== [ 13.220461@1] dhd_module_init: Exit err=0 Starting bluetooth... [ 13.255134@0] BT_RADIO going: on [ 13.255167@0] BCM_BT: going ON [ 13.341275@1] Changing uart_a_ttyS1: baud from 0 to 115200 [ 13.381266@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 [ 13.601265@1] Changing uart_a_ttyS1: baud from 3000000 to 115200 [ 13.671270@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 [ 13.711276@1] Changing uart_a_ttyS1: baud from 3000000 to 115200 [ 13.751273@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 Device setup complete Starting Mali... [ 13.816546@0] pdata->tmp_trip[0].gpu_lower_level=1 [ 13.816581@0] pdata->tmp_trip[0].gpu_upper_level=1 [ 13.820484@0] pdata->tmp_trip[1].gpu_lower_level=2 [ 13.825300@0] pdata->tmp_trip[1].gpu_upper_level=2 [ 13.830121@0] pdata->tmp_trip[2].gpu_lower_level=3 [ 13.834839@0] pdata->tmp_trip[2].gpu_upper_level=3 [ 13.839550@0] pdata->tmp_trip[3].gpu_lower_level=-1 [ 13.844417@0] pdata->tmp_trip[3].gpu_upper_level=-1 [ 13.849269@0] aml_thermal bind thermal-gpufreq-0 okay ! [ 13.854572@0] gpu cooling register okay with err=0 [ 13.859685@0] tmp_trip[0].gpu_core_upper=1 [ 13.863353@0] tmp_trip[1].gpu_core_upper=2 [ 13.867373@0] tmp_trip[2].gpu_core_upper=3 [ 13.871468@0] tmp_trip[3].gpu_core_upper=-1 [ 13.875607@0] aml_thermal bind thermal-gpucore-0 okay ! [ 13.880811@0] gpu core cooling register okay with err=0 [ 13.886441@0] Mali: Mali device driver loaded Starting network: OK Starting Bluez. Starting connman ... done. Starting ntpd: OK [ 14.283035@0] netdev_open [ 14.283064@0] Ethernet reset [ 14.283087@0] NET MDA descpter start addr=ee33b000 [ 14.288997@0] phy_interface = 1 [ 14.290784@0] aml_phy_init: trying to attach to 0:00 [ 14.296193@0] --1--write mac add to:ee341f48: ae 9e ba 9b 60 cb |....`.| [ 14.296200@0] --2--write mac add to:ee341f48: ae 9e ba 9b 60 cb |....`.| [ 14.296207@0] write mac add to:ee341f48: ae 9e ba 9b 60 cb |....`.| [ 14.296211@0] Current DMA mode=0, set mode=621c100 [ 14.296239@0] ether leave promiscuous mode [ 14.296245@0] ether leave all muticast mode [ 14.296285@0] changed the Multicast,mcount=1 [ 14.296291@0] add mac address:01:00:5e:00:00:01,bit=32 [ 14.296292@0] set hash low=0,high=1 [ 14.296295@0] changed the filter setting to :4 Starting dropbear sshd: OK Starting KODI... [ 14.412340@1] dhd_open: Enter ed2a7000 [ 14.412378@1] [ 14.412378@1] Dongle Host Driver, version 1.141.66.1 (r483454) [ 14.412378@1] Compiled in drivers/net/wireless/bcmdhd on Mar 10 2017 at 07:36:50 [ 14.430321@1] wl_android_wifi_on in 1 [ 14.430355@1] wl_android_wifi_on in 2: g_wifi_on=0 [ 14.439724@1] wifi_platform_set_power = 1 [ 14.439759@1] ======== PULL WL_REG_ON HIGH! ======== [ 14.443072@1] WIFI Disable! 6 [ 14.531386@1] write pen_release: 2 [ 14.531661@2] CPU2: Booted secondary processor Starting SMB services: [ 14.668951@1] WIFI Enable! 6 [ 14.868782@1] sdio_reset_comm(): [ 14.883040@1] sdio: queuing unknown CIS tuple 0x80 (2 bytes) [ 14.884853@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 14.890481@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 14.891775@0] libphy: 0:00 - Link is Up - 100/Full [ 14.902442@1] sdio: queuing unknown CIS tuple 0x80 (7 bytes) [ 14.920457@1] [sdio_reinit] finish [ 15.121788@1] [ 15.121788@1] [ 15.121788@1] dhd_bus_devreset: == WLAN ON == [ 15.124141@1] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362 [ 15.132519@1] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9 [ 15.137237@1] DHD: dongle ram size is set to 245760(orig 245760) at 0x0 [ 15.144039@1] dhd_conf_read_config: Ignore config file /lib/firmware/brcm/config.txt [ 15.150600@1] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/fw_bcm40181a2.bin [ 15.159219@1] nv_path=dhd_conf_set_nv_name_by_chip [ 15.163990@1] Final fw_path=/lib/firmware/brcm/fw_bcm40181a2.bin [ 15.170004@1] Final nv_path=/lib/firmware/brcm/ap6210_nvram.txt [ 15.175871@1] Final conf_path=/lib/firmware/brcm/config.txt [ 15.222898@1] NVRAM version: AP6210_NVRAM_V1.2_03192013 [ 15.223595@1] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. [ 15.230830@1] dhd_bus_init: delay 100ms for BCM43362 [ 15.460417@1] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ 15.460898@1] bcmsdh_oob_intr_register: Enter [ 15.465257@1] bcmsdh_oob_intr_register OOB irq=100 flags=4 [ 15.470609@1] bcmsdh_oob_intr_register: enable_irq_wake [ 15.477262@1] dhd_conf_set_band: Set band 0 [ 15.482035@1] Firmware up: op_mode=0x0005, MAC=6c:fa:a7:6d:0d:1f [ 15.485929@1] dhd_conf_set_country: Set country ALL, revision 0 [ 15.531388@1] write pen_release: 3 [ 15.531672@3] CPU3: Booted secondary processor [ 15.576611@1] Country code: ALL (ALL/0) [ 15.576956@1] dhd_conf_set_roam: Set roam_off 1 [ 15.581755@1] dhd_preinit_ioctls Set ampdu_ba_wsize to 32 failed -2 [ 15.586139@0] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23 [ 15.593349@0] dhd_preinit_ioctls buf_key_b4_m4 set failed -23 [ 15.604923@0] Firmware version = wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13 [ 15.608258@0] Driver: 1.141.66.1 (r483454) [ 15.608258@0] Firmware: wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13 [ 15.624086@0] dhd_preinit_ioctls wl ampdu_hostreorder failed -23 [ 15.627314@0] wl_android_wifi_on: Success [ 15.713842@0] dhd_open: Exit ret=0 OK Starting NMB services: [ 16.011977@1] changed the Multicast,mcount=2 [ 16.012018@1] add mac address:01:00:5e:00:00:01,bit=32 [ 16.015727@1] add mac address:01:00:5e:00:00:fb,bit=48 [ 16.020845@1] set hash low=0,high=10001 [ 16.024694@1] changed the filter setting to :4 OK Welcome to Buildroot dsQuad login: [ 16.603380@0] IEC958 16bit [ 16.603407@0] hdmitx: audio: aout notify rate 48000 [ 16.605311@0] hdmitx: audio: aout notify size 16 [ 16.609903@0] hdmitx: audio: no update [ 16.613702@0] aml_i2s_close device type 8 [ 16.641397@0] IEC958 16bit [ 16.641422@0] hdmitx: audio: aout notify rate 48000 [ 16.643326@0] hdmitx: audio: aout notify size 16 [ 16.647942@0] hdmitx: audio: no update [ 16.651807@0] aml_i2s_close device type 8 [ 16.657658@0] IEC958 16bit [ 16.658411@0] hdmitx: audio: aout notify rate 48000 [ 16.663311@0] hdmitx: audio: aout notify size 16 [ 16.667857@0] hdmitx: audio: no update [ 16.671612@0] aml_i2s_close device type 8 [ 16.678245@0] IEC958 16bit [ 16.678348@0] hdmitx: audio: aout notify rate 48000 [ 16.683258@0] hdmitx: audio: aout notify size 16 [ 16.687807@0] hdmitx: audio: no update [ 16.691827@0] aml_i2s_close device type 8 [ 16.697285@0] IEC958 16bit [ 16.698284@0] hdmitx: audio: aout notify rate 48000 [ 16.703176@0] hdmitx: audio: aout notify size 16 [ 16.707732@0] hdmitx: audio: no update [ 16.711481@0] aml_i2s_close device type 2 [ 17.182246@2] buf=0 [ 17.182269@2] IEC958_mode_raw=0 [ 17.187992@2] IEC958 16bit [ 17.188019@2] hdmitx: audio: aout notify rate 48000 [ 17.189919@2] hdmitx: audio: aout notify size 16 [ 17.194554@2] hdmitx: audio: no update [ 17.198244@2] aml_i2s_close device type 8 [ 17.204247@2] IEC958 16bit [ 17.205003@2] hdmitx: audio: aout notify rate 48000 [ 17.209856@2] hdmitx: audio: aout notify size 16 [ 17.214473@2] hdmitx: audio: no update [ 17.218179@2] aml_i2s_close device type 8 [ 17.226390@2] [aml-i2s-dai]enterd aml_dai_i2s_prepare,old_samplerate:48000,sample_rate=44100 [ 17.230668@2] [aml-i2s-dai]i2s dma f044c000,phy addr 2e7a0000,mode 0,ch 2 [ 17.237541@2] ----aml_hw_iec958_init,runtime->rate=44100-- [ 17.242987@2] [aml-spdif-dai]enterd aml_hw_iec958_init,set_clock:4,sample_rate=5 [ 17.250337@2] audio_set_958_clk, freq=5, [ 17.254369@2] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 17.260912@2] iec958 mode PCM16 [ 17.264051@2] IEC958 16bit [ 17.266721@2] hdmitx: audio: aout notify rate 44100 [ 17.271588@2] hdmitx: audio: aout notify size 16 [ 17.276169@2] hdmitx: audio: audio channel num is 1 [ 17.281025@2] hdmitx: audio: SPDIF [ 17.284424@2] hdmitx: audio: current VIC: 16 [ 17.288649@2] hdmitx: audio: audio sample rate: 2 [ 17.293356@2] hdmitx: audio: set audio N para [ 17.297670@2] hdmitx: audio: PCM out to HDMI [ 17.301931@2] hdmitx: audio: i2s_to_spdif_flag:1 [ 17.306592@2] hdmitx: audio: Enable audio spdif to HDMI [ 17.311860@3] IRQ95 no longer affine to CPU3 [ 17.312098@2] hdmitx: audio: Audio Type: PCM [ 17.312110@1] CPU3: shutdown [ 17.323211@2] hdmitx: audio: set audio param [ 17.327398@2] [aml-spdif-dai]spdif dma f044c000,phy addr 2e7a0000 [ 17.333549@2] speaker_events--mute =1 [ 17.341720@1] [aml-i2s-dai]i2s dma f044c000,phy addr 2e7a0000,mode 0,ch 2 [ 17.343954@1] ----aml_hw_iec958_init,runtime->rate=44100-- [ 17.349415@1] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 17.356118@1] iec958 mode PCM16 [ 17.359280@1] IEC958 16bit [ 17.361920@1] hdmitx: audio: aout notify rate 44100 [ 17.366781@1] hdmitx: audio: aout notify size 16 [ 17.371794@1] hdmitx: audio: no update [ 17.375074@1] [aml-spdif-dai]spdif dma f044c000,phy addr 2e7a0000 [ 17.388308@1] [aml-i2s-dai]aiu i2s playback enable [ 17.388308@1] [ 17.389113@1] [aml-i2s-dai]audio_hw_958_enable 1 [ 17.453274@1] amlvideo openamlvideo close[ 17.541543@2] IRQ94 no longer affine to CPU2 [ 17.541799@1] CPU2: shutdown changed the Multicast,mcount=3 [ 19.572063@0] add mac address:01:00:5e:00:00:01,bit=32 [ 19.574315@0] add mac address:01:00:5e:00:00:fb,bit=48 [ 19.579457@0] add mac address:01:00:5e:7f:ff:fa,bit=20 [ 19.584575@0] set hash low=100000,high=10001 [ 19.588794@0] changed the filter setting to :4 [ 20.431395@1] write pen_release: 2 [ 20.431670@2] CPU2: Booted secondary processor [ 22.081626@2] IRQ94 no longer affine to CPU2 [ 22.081899@1] CPU2: shutdown [ 24.846905@1] normal card in [ 25.243294@0] card out [ 26.425916@1] normal card in [ 26.921273@1] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 27.213626@1] sd: new high speed SDXC card at address aaaa, clock 35416666, 4-bit-bus-width [ 27.216599@1] mmcblk0: sd:aaaa SL64G 59.4 GiB [ 27.225580@1] mmcblk0: p1 p2 [ 27.706138@0] force enable DISCARD here for ext4 fs [ 27.745514@0] checked enable EXT4 DISCARD here [ 27.745549@0] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard [ 27.754100@0] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null) [ 77.576187@1] [aml-i2s-dai]aiu i2s playback disable [ 77.576187@1] [ 77.577076@1] [aml-i2s-dai]audio_hw_958_enable 0 [ 77.581796@1] [aml-i2s-dai]i2s dma f044c000,phy addr 2e7a0000,mode 0,ch 2 [ 77.588618@1] ----aml_hw_iec958_init,runtime->rate=44100-- [ 77.594089@1] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 77.600754@1] iec958 mode PCM16 [ 77.603862@1] IEC958 16bit [ 77.606561@1] hdmitx: audio: aout notify rate 44100 [ 77.611506@1] hdmitx: audio: aout notify size 16 [ 77.616914@1] hdmitx: audio: no update [ 77.619726@1] [aml-spdif-dai]spdif dma f044c000,phy addr 2e7a0000 [ 87.626225@1] [aml-spdif-dai]enterd aml_spdif_play,set_clock:5,sample_rate=4 [ 87.626232@1] audio_set_958_clk, freq=4, [ 87.626240@1] IEC958 16bit [ 87.626245@1] hdmitx: audio: aout notify rate 48000 [ 87.626247@1] hdmitx: audio: aout notify size 16 [ 87.626249@1] hdmitx: audio: audio channel num is 1 [ 87.626255@1] hdmitx: audio: SPDIF [ 87.626265@1] hdmitx: audio: current VIC: 16 [ 87.626267@1] hdmitx: audio: audio sample rate: 3 [ 87.626268@1] hdmitx: audio: set audio N para [ 87.626275@1] hdmitx: audio: PCM out to HDMI [ 87.626277@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 87.626278@1] hdmitx: audio: Enable audio spdif to HDMI [ 87.626283@1] hdmitx: audio: Audio Type: PCM [ 87.626330@1] hdmitx: audio: set audio param [ 87.626335@1] aml_i2s_close device type 8 [ 92.636289@1] speaker_events--mute =0 [ 214.447780@0] aml_keys_notify_reboot:1717 [ 214.492766@0] i2c 0-0032: Bus i2c calling i2c_device_shutdown shutdown [ 214.493843@0] i2c i2c-3: Bus i2c calling i2c_device_shutdown shutdown [ 214.500435@0] i2c i2c-2: Bus i2c calling i2c_device_shutdown shutdown [ 214.506763@0] i2c i2c-1: Bus i2c calling i2c_device_shutdown shutdown [ 214.513090@0] i2c i2c-0: Bus i2c calling i2c_device_shutdown shutdown [ 214.519608@0] amlnfdev nand: Driver amlnfdev calling platform_drv_shutdown shutdown [ 214.527205@0] boot_device_flag : 0 [ 214.530601@0] aml_rtc rtc.0: Driver aml_rtc calling platform_drv_shutdown shutdown [ 214.538810@0] Restarting system. [ 214.541269@0] [ 214.542884@0] Restarting Linux version 3.10.105 (dev_user@dev) (gcc version 5.4.0 (Buildroot 2017.02-00100-gc2abd0d-dirty) ) #1 SMP PREEMPT Fri Mar 10 07:36:38 EET 2017 [ 214.542884@0] [ EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102621 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 28 -> 28 DC02 v:1150, 0x[37]: 2c -> 2c DC03 v:1500, 0x[38]: 48 -> 48 LDO01 v:2900, 0x[4c]: 50 -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12095 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489217 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x0d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 92 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=normal TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: Tran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 63864569856 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 894 bytes read ## Executing script at 11000000 ** Invalid boot device ** reading uEnv.txt 243 bytes read TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done reading /uImage 11341056 bytes read reading /uInitrd 6634592 bytes read reading /dtb.img 18432 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 11340992 Bytes = 10.8 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 6634528 Bytes = 6.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Loading Kernel Image ... OK OK uboot time: 12903930 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x565c001 Loading Ramdisk to 05008000, end 0565bc20 ... OK Loading Device Tree to 05000000, end 05007786 ... OK Starting kernel ... EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102623 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 18 -> 28 DC02 v:1150, 0x[37]: 18 -> 2c DC03 v:1500, 0x[38]: 38 -> 48 LDO01 v:2900, 0x[4c]: 4e -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12098 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489391 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x1d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 92 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=charging TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, SD or TSD: Card did not respond to voltage select! mmc->block_dev.if_type=7 MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 0 ** ** Unable to use mmc 0:1 for fatload ** Unknown command 'ext4load' - try 'help' MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 1 ** ** Unable to use mmc 1:1 for fatload ** Unknown command 'ext4load' - try 'help' Enter USB burn GOTGCTL=0x00010000, asesvld=0, bsesvld=0 Fail in usb_pcd_init current storer:nand_key key save is auto select storer(nand or emmc) write key code version3_flush:709,prov->write:7fed98e0 write key ok!! Booting... not config efuse version ERR(v2_common/optimus_download_key.c)L473:failed to query key state, rc 0, keyIsBurned=0 not config efuse version Saving Environment to SPI Flash... SPI BOOT,spi_saveenv : saveenv 122 Erasing SPI flash...Writing to SPI flash...done ## ANDROID Format IMAGE ## Booting kernel from Legacy Image at 12000000 ... Image Name: Linux-3.10.105 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 4385557 Bytes = 4.2 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK Ramdisk start addr = 0x1242f800, len = 0x18cbb1 Flat device tree start addr = 0x125bc800, len = 0x49f3 magic=0xedfe0dd0 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: 14286697 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5195001 Loading Ramdisk to 05008000, end 05194bb1 ... OK Loading Device Tree to 05000000, end 050079f2 ... OK Starting kernel ... [ 0.000000@0] Booting Linux on physical CPU 0x200 [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.10.105 (dev_user@dev) (gcc version 5.4.0 (Buildroot 2017.02-00100-gc2abd0d-dirty) ) #1 SMP PREEMPT Fri Mar 10 07:36:38 EET 2017 [ 0.000000@0] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000@0] Machine: Amlogic Meson8, model: AMLOGIC [ 0.000000@0] physical memory start address is 0x200000 [ 0.000000@0] reserved_end is d9fffff [ 0.000000@0] [ 0.000000@0] Total memory is 2046 MiB [ 0.000000@0] Reserved low memory from 0x06000000 to 0x0d9fffff, size: 122 MiB [ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x07900000 ( 24 MiB) [ 0.000000@0] mesonfb1(low) : 0x07900000 - 0x07a00000 ( 1 MiB) [ 0.000000@0] deinterlace0(high) : 0x7df00000 - 0x80000000 ( 33 MiB) [ 0.000000@0] mesonstream0(low) : 0x07a00000 - 0x09a00000 ( 32 MiB) [ 0.000000@0] vdec0(high) : 0x79f00000 - 0x7df00000 ( 64 MiB) [ 0.000000@0] ppmgr0(high) : 0x77f00000 - 0x79f00000 ( 32 MiB) [ 0.000000@0] vdin00(low) : 0x09a00000 - 0x0aa00000 ( 16 MiB) [ 0.000000@0] vdin10(low) : 0x0aa00000 - 0x0ba00000 ( 16 MiB) [ 0.000000@0] amlvideo20(low) : 0x0ba00000 - 0x0d200000 ( 24 MiB) [ 0.000000@0] amvideocap0(low) : 0x0d200000 - 0x0da00000 ( 8 MiB) [ 0.000000@0] get storage device: storage 4 [ 0.000000@0] value=4 [ 0.000000@0] get_storage_device : get storage device: storage 4 [ 0.000000@0] get_storage_device : value=4 [ 0.000000@0] [get_storage_device] storage_flag=4 [ 0.000000@0] [get_storage_device] the storage device does NOT relate to eMMC, storage_flag=4 [ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc [ 0.000000@0] Meson chip version = RevC (19:C - 0:27ED) [ 0.000000@0] PERCPU: Embedded 7 pages/cpu @c19d6000 s7488 r8192 d12992 u32768 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 454416 [ 0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200n8 no_console_suspend earlyprintk ramoops.mem_address=0x04e00000 ramoops.mem_size=0x100000 ramoops.record_size=0x8000 ramoops.console_size=0x4000 storage=4 cvbsdrv=0 vdaccfg=0xa000 logo=osd1,loaded,0x07900000,1080p,full hdmimode=1080p cvbsmode=576cvbs androidboot.firstboot=1 hdmitx= mac=ae:9e:ba:9b:60:cb mac=AE:9E:BA:9B:60:CB [ 0.000000@0] cvbs performance line = 0 [ 0.000000@0] cvbs trimming line = 0xa000 [ 0.000000@0] cvbs trimming.1.v5: 0xa0, 0x0 [ 0.000000@0] osd1:1 [ 0.000000@0] loaded:268435459 [ 0.000000@0] logo has been loaded [ 0.000000@0] 1080p:12 [ 0.000000@0] full:2 [ 0.000000@0] kernel get hdmimode form uboot is 1080p [ 0.000000@0] kernel get cvbsmode form uboot is 576cvbs [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] ******** uboot setup mac-addr: ae:9e:ba:9b:60:cb [ 0.000000@0] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000@0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000@0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000@0] Memory: 64MB 16MB 1701MB = 1781MB total [ 0.000000@0] Memory: 1794728k/1794728k available, 29016k reserved, 1184768K highmem [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000@0] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000@0] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000@0] .text : 0xc0008000 - 0xc080c3e8 (8209 kB) [ 0.000000@0] .init : 0xc080d000 - 0xc083ad40 ( 184 kB) [ 0.000000@0] .data : 0xc083c000 - 0xc0891a80 ( 343 kB) [ 0.000000@0] .bss : 0xc0891a80 - 0xc0ac257c (2243 kB) [ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] NR_IRQS:256 [ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000@0] Switching to timer-based delay loop [ 0.000000@0] Console: colour dummy device 80x30 [ 0.000000@0] console [ttyS0] enabled [ 0.402663@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.412951@0] pid_max: default: 32768 minimum: 301 [ 0.417851@0] Mount-cache hash table entries: 512 [ 0.425411@0] Initializing cgroup subsys freezer [ 0.427031@0] CPU: Testing write buffer coherency: ok [ 0.432264@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.437858@0] Setting up static identity map for 0xc05d0c08 - 0xc05d0c60 [ 0.444620@0] L310 cache controller enabled [ 0.448664@0] l2x0: 8 ways, 4096 sets, CACHE_ID 0x4100a0c9, Cache size: 1048576 B [ 0.456234@0] AUX_CTRL 0x7ec80001, PERFETCH_CTRL 0x71000007, POWER_CTRL 0x00000000 [ 0.464356@0] TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222 [ 0.530116@0] write pen_release: 1 [ 0.530380@1] CPU1: Booted secondary processor [ 0.530394@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.550107@0] write pen_release: 2 [ 0.558333@2] CPU2: Booted secondary processor [ 0.558349@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.570108@0] write pen_release: 3 [ 0.578336@3] CPU3: Booted secondary processor [ 0.578350@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.578407@0] Brought up 4 CPUs [ 0.591456@0] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.597688@0] CPU: All CPU(s) started in SVC mode. [ 0.602815@0] devtmpfs: initialized [ 0.610439@0] clkrate [ xtal ] : 24000000 [ 0.610467@0] clkrate [ pll_sys ] : 1200000000 [ 0.614506@0] clkrate [ pll_fixed ] : 2550000000 [ 0.619186@0] clkrate [ pll_vid ] : 366000000 [ 0.623612@0] TODO: clk_get_rate_hpll() is not implement in M8 now [ 0.629760@0] clkrate [ pll_hpll ] : 0 [ 0.633579@0] clkrate [ pll_ddr ] : 0 [ 0.637303@0] clkrate [ a9_clk ] : 1200000000 [ 0.641728@0] clkrate [ clk81 ] : 141666666 [ 0.646526@0] pinctrl core: initialized pinctrl subsystem [ 0.651623@0] regulator-dummy: no parameters [ 0.655768@0] NET: Registered protocol family 16 [ 0.665670@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.668867@0] VPU driver version: v03 [ 0.670949@0] vpu driver detect cpu type: m8 [ 0.675184@0] load vpu_clk in dts: 364300000Hz(7) [ 0.679920@0] vpu_probe OK [ 0.686938@0] amlogic_gpio gpio: Probed amlogic GPIO driver [ 0.688291@0] register lm device lm-root [ 0.692084@0] register lm device lm1 [ 0.695623@0] register lm device lm0 [ 0.699319@0] Init pinux probe! [ 0.702563@0] pinmux-m8 pinmux: Probed amlogic pinctrl driver [ 0.708008@0] tv_init_module [ 0.710821@0] major number 254 for disp [ 0.714622@0] vout_register_server [ 0.718003@0] register tv module server ok [ 0.722149@0] major number 0 for disp [ 0.725718@0] register tv module server ok [ 0.729867@0] aml_i2c version: 20140813 [ 0.733785@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(ef3388a8) [ 0.739676@0] aml-i2c i2c-AO: aml i2c bus driver. [ 0.744544@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(ef338ca8) [ 0.750345@0] aml-i2c i2c-A: aml i2c bus driver. [ 0.755118@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(ef3390a8) [ 0.760921@0] aml-i2c i2c-B: aml i2c bus driver. [ 0.765672@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(ef3394a8) [ 0.771495@0] aml-i2c i2c-C: aml i2c bus driver. [ 0.776220@0] call aml_dvfs_init in [ 0.779804@0] hdmitx: system: amhdmitx_init [ 0.783717@0] hdmitx: system: Ver: 2014May6 [ 0.787925@0] hdmitx: system: amhdmitx_probe [ 0.792320@0] hdmitx: system: not find ao cec [ 0.796450@0] hdmitx: system: not find vend_init_data [ 0.801630@0] hdmitx: system: gate/pwr cmd: 7 [ 0.805814@0] hdmitx: system: ALREADY init VIC = 16 [ 0.810674@0] hdmitx: system: gate/pwr cmd: 0 [ 0.815374@1] hdmitx: system: reset intr mask [ 0.830427@0] hdmitx: system: irq 1 [ 0.857580@0] bio: create slab <bio-0> at 0 [ 0.858268@0] SCSI subsystem initialized [ 0.860379@0] usbcore: registered new interface driver usbfs [ 0.865731@0] usbcore: registered new interface driver hub [ 0.871247@0] usbcore: registered new device driver usb [ 0.876503@0] Linux video capture interface: v2.00 [ 0.881627@0] mode is 12,sync_duration_den=1,sync_duration_num=60 [ 0.887159@0] TV mode 1080p selected. [ 0.890807@0] already display in uboot [ 0.894524@0] vinfo mode is: 1080p [ 0.899956@0] call aml_pmu_probe_init in [ 0.901890@0] aml_pmus_probe, child name:rn5t618 [ 0.906402@0] aml_pmus_probe, i2c_bus:i2c_bus_ao [ 0.911129@0] Allocate new i2c device: adapter:0, addr:0x32, node name:rn5t618, type:ricoh_pmu [ 0.919982@0] Advanced Linux Sound Architecture Driver Initialized. [ 0.926275@0] Bluetooth: Core ver 2.16 [ 0.929616@0] NET: Registered protocol family 31 [ 0.934153@0] Bluetooth: HCI device and connection manager initialized [ 0.940652@0] Bluetooth: HCI socket layer initialized [ 0.945670@0] Bluetooth: L2CAP socket layer initialized [ 0.950785@1] hdmitx: system: gate/pwr cmd: 4 [ 0.955222@0] Bluetooth: SCO socket layer initialized [ 0.960549@0] cfg80211: Calling CRDA to update world regulatory domain [ 0.967824@0] Switching to clocksource Timer-E [ 0.978859@0] NET: Registered protocol family 2 [ 0.979320@0] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.985052@0] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.991617@0] TCP: Hash tables configured (established 8192 bind 8192) [ 0.998068@0] TCP: reno registered [ 1.001427@0] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.007501@0] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.014114@0] NET: Registered protocol family 1 [ 1.018562@0] wifi_dev_probe [ 1.021364@0] wifi_dt : interrupt_pin=GPIOX_21 [ 1.025775@0] wifi_dt : irq_num=null [ 1.029326@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 1.034451@0] wifi_dt : power_on_pin=GPIOAO_6 [ 1.038776@0] wifi_dt : power_on_pin2=GPIOX_11 [ 1.043205@0] interrupt_pin=133, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=122 [ 1.052178@0] Unpacking initramfs... [ 1.112989@0] Freeing initrd memory: 1584K (c4e08000 - c4f94000) [ 1.114922@0] bounce pool size: 64 pages [ 1.123697@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.124295@0] exFAT: Core Version 1.2.4 [ 1.127876@0] exFAT: FS Version 1.2.4 [ 1.132341@0] NTFS driver 2.1.30 [Flags: R/O]. [ 1.136166@0] fuse init (API version 7.22) [ 1.140479@0] msgmni has been set to 1194 [ 1.141510@1] hdmitx: system: gate/pwr cmd: 5 [ 1.141511@1] hdmitx: edid: edid ready [ 1.141513@1] hdmitx: system: gate/pwr cmd: 4 [ 1.156886@0] io scheduler noop registered [ 1.160468@0] io scheduler deadline registered [ 1.165065@0] io scheduler bfq registered (default) [ 1.169742@0] BFQ I/O-scheduler: v7r8 [ 1.226003@0] loop: module loaded [ 1.226702@0] tun: Universal TUN/TAP device driver, 1.6 [ 1.229052@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 1.235523@0] PPP generic driver version 2.4.2 [ 1.239978@0] PPP BSD Compression module registered [ 1.244665@0] PPP Deflate Compression module registered [ 1.249867@0] PPP MPPE Compression module registered [ 1.254813@0] NET: Registered protocol family 24 [ 1.259503@0] usbcore: registered new interface driver asix [ 1.265045@0] usbcore: registered new interface driver ax88179_178a [ 1.271257@0] usbcore: registered new interface driver cdc_ether [ 1.277226@0] usbcore: registered new interface driver net1080 [ 1.283078@0] usbcore: registered new interface driver cdc_subset [ 1.289106@0] usbcore: registered new interface driver zaurus [ 1.294856@0] usbcore: registered new interface driver cdc_ncm [ 1.300635@0] usbcore: registered new interface driver qf9700 [ 1.306362@0] usbcore: registered new interface driver sr9600 [ 1.312281@0] usbcore: registered new interface driver cdc_acm [ 1.317819@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.326056@0] usbcore: registered new interface driver usb-storage [ 1.332281@0] usbcore: registered new interface driver usbserial [ 1.338163@0] usbcore: registered new interface driver option [ 1.343891@0] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.351443@1] hdmitx: system: gate/pwr cmd: 5 [ 1.355261@1] hdmitx: edid: edid ready [ 1.358992@1] hdmitx: edid: check sum valid [ 1.363167@1] hdmitx: edid: check sum valid [ 1.363174@0] mousedev: PS/2 mouse device common for all mice [ 1.373060@1] hdmitx: edid: blk0 raw data [ 1.377026@1] 00ffffffffff[ 1.379371@0] i2c /dev entries driver ff001e6d[ 1.383808@0] device-mapper: uevent: version 1.0.3 [ 1.384053@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 1.384177@0] Bluetooth: HCI UART driver ver 2.2 [ 1.384180@0] Bluetooth: HCI H4 protocol initialized [ 1.384706@0] usbcore: registered new interface driver usbhid [ 1.384707@0] usbhid: USB HID core driver [ 1.384867@0] vout_init_module [ 1.384910@0] start init vout module [ 1.384979@0] create vout attribute ok [ 1.385103@0] ge2d_init [ 1.385108@0] ge2d_dev major:249 [ 1.385284@0] ge2d start monitor [ 1.385311@0] osd_init [ 1.385314@1] ge2d workqueue monitor start [ 1.385346@0] osd_probe, vinfo:c06077b8 [ 1.385519@0] Frame buffer memory assigned at phy:0x06100000, vir:0xf1000000, size=24576K [ 1.385521@0] osd_probe, mydef_var:c08786d4, vinfo:c06077b8 [ 1.385525@0] init fbdev bpp is :32 [ 1.385527@0] ---------------clear framebuffer0 memory ac59010101010516010380331d78ea6275a3554fa027 [ 1.472195@0] 125054210800714081c08100818095009040a9c0b300023a801871382d40582c [ 1.479390@0] 45[ 1.480962@0] Frame buffer memory assigned at phy:0x07900000, vir:0xf0600000, size=1024K [ 1.480965@0] osd_probe, mydef_var:c08786d4, vinfo:c06077b8 [ 1.480966@0] don't find to display_size_default from mesonfb-dts [ 1.480968@0] init fbdev bpp is :24 00fe221100001e000000fd00383d1e530f000a202020202020000000fc0032 [ 1.509728@0] 34454135330a202020202020000000ff000a[ 1.514221@0] osd probe ok [ 1.514349@0] vout2_init_module enter [ 1.514383@0] start init vout2 module [ 1.514447@0] create vout2 attribute ok [ 1.514539@0] enter aml_sysled_init [ 1.520499@0] amlvideo-000: V4L2 device registered as video10 [ 1.520667@0] amlvideo2: V4L2 device registered as video11 [ 1.521129@0] aml_wdt_driver_init,301 [ 1.521131@0] ** disable watchdog [ 1.521386@0] keys=========================================== [ 1.521389@0] keys_devno=f600000 [ 1.521561@0] securitykey: device aml_keys created [ 1.521570@0] amlkeys=0 [ 1.521635@0] platform_driver_register--aml_keys_driver-------------------- [ 1.521875@0] set uart_ao pinmux use pinctrl subsystem [ 1.521877@0] P_AO_RTI_PIN_MUX_REG:5860 [ 1.521890@0] start uart_ao_ttyS0:(irq = 122) [ 1.521891@0] register uart_ao ok [ 1.522077@0] set uart_a pinmux use pinctrl subsystem [ 1.522079@0] P_AO_RTI_PIN_MUX_REG:5860 [ 1.522091@0] start uart_a_ttyS1:(irq = 58) [ 1.522092@0] register uart_a ok [ 1.522268@0] start uart_d_ttyS4:(irq = 126) [ 1.522269@0] register uart_d ok [ 1.522389@0] dwc_otg: version 3.10a 12-MAY-2014 [ 1.522419@0] dwc_otg_driver_probe NOT match [ 1.522446@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000 [ 1.522456@0] USB (1) use clock source: XTAL input [ 1.543492@0] Core Release: 3.10a [ 1.543495@0] Setting default values for core params [ 1.543502@0] curmode: 1, host_only: 1 [ 1.563610@0] Using Buffer DMA mode [ 1.563614@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.563616@0] Working on port type = HOST [ 1.563680@0] dwc_otg lm1: DWC OTG Controller [ 1.563696@0] dwc_otg lm1: new USB bus registered, assigned bus number 1 [ 1.563713@0] dwc_otg lm1: irq 63, io mem 0x00000000 [ 1.563715@0] -------hcd->flags.d32 = 0 [ 1.563735@0] Init: Port Power? op_state=1 [ 1.563737@0] Init1: Power Port (0) [ 1.563825@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.563830@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.563834@0] usb usb1: Product: DWC OTG Controller [ 1.563837@0] usb usb1: Manufacturer: Linux 3.10.105 dwc_otg_hcd [ 1.563840@0] usb usb1: SerialNumber: lm1 [ 1.564192@0] hub 1-0:1.0: USB hub found [ 1.564201@0] hub 1-0:1.0: 1 port detected [ 1.564365@0] usb0: type: 0, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000 [ 1.564372@0] USB (0) use clock source: XTAL input [ 1.585404@0] Core Release: 3.10a [ 1.585407@0] Setting default values for core params [ 1.585411@0] curmode: 1, host_only: 0 [ 1.645485@0] Using Buffer DMA mode [ 1.645488@0] OTG VER PARAM: 1, OTG VER FLAG: 1 [ 1.645491@0] Working on port type = OTG [ 1.645492@0] Current port type: SLAVE [ 1.645552@0] dwc_otg lm0: DWC OTG Controller [ 1.645565@0] dwc_otg lm0: new USB bus registered, assigned bus number 2 [ 1.645579@0] dwc_otg lm0: irq 62, io mem 0x00000000 [ 1.645614@0] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.645618@0] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.645621@0] usb usb2: Product: DWC OTG Controller [ 1.645625@0] usb usb2: Manufacturer: Linux 3.10.105 dwc_otg_hcd [ 1.645628@0] usb usb2: SerialNumber: lm0 [ 1.645952@0] hub 2-0:1.0: USB hub found [ 1.645961@0] hub 2-0:1.0: 1 port detected [ 1.646069@0] Dedicated Tx FIFOs mode [ 1.646201@0] using timer detect id change, ee784000 [ 1.646333@0] boot_device_flag : 0 [ 1.646336@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand [ 1.646344@0] Nand PHY driver Version: 1.01.001.0006 (c) 2013 Amlogic Inc. [ 1.646347@0] amlnf_phy_init : amlnf init flag 0 [ 1.646414@0] ######STS IRQ mode for nand driver [ 1.646467@0] NAND device id: ad de 14 a7 42 4a ad de [ 1.646472@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E [ 1.691099@0] AML_NAND_NEW_OOB : new oob [ 1.691103@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 [ 1.691106@0] boot_device_flag = 0 [ 1.693977@0] uncorrect ecc here at page:2048, chip:0 [ 1.694051@0] blk check good but read failed at chip 0 page 2048 [ 1.694647@0] hynix nand get default reg value at blk:8, page:2049 [ 1.696340@0] NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 [ 1.700425@0] NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 [ 1.700982@0] nand shipped bbt at block 0 [ 1.703757@0] uncorrect ecc here at page:2048, chip:0 [ 1.703825@0] nand blk check good but read failed at chip 0 page 2048 [ 1.754785@0] NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 96 [ 1.755341@0] i=0,register --- nand_key [ 1.755376@0] nand adjust phy offset : block 4 [ 1.755383@0] nand adjust phy offset : block 4 [ 1.755401@0] nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane [ 1.755404@0] nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane [ 1.755407@0] nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane [ 1.756636@0] bad block count = 0 [ 1.756636@0] [ 1.759927@0] bad block count = 0 [ 1.759927@0] [ 1.761218@1] Indeed it is in host mode hprt0 = 00021501 [ 1.772602@0] bad block count = 0 [ 1.772602@0] [ 1.772604@0] amlnand_add_nftl: [ 1.772606@0] Creating 1 ntd partitions [ 1.772609@0] block_num 76 [ 1.773959@0] ------init_ntd [ 1.774265@0] ntd: Giving out device 0 to nfcache [ 1.774267@0] Creating 7 ntd partitions [ 1.774269@0] block_num 204 [ 1.778073@0] ntd: Giving out device 1 to nfcode [ 1.778076@0] Creating 1 ntd partitions [ 1.778078@0] block_num 720 [ 1.791061@0] ntd: Giving out device 2 to nfdata [ 1.791575@0] ethernet_driver probe! [ 1.791580@0] Please config phy interface. [ 1.791581@0] Please config savepowermode. [ 1.791583@0] Please config reset_pin_enable. [ 1.791584@0] Please config reset_delay. [ 1.791586@0] Please config reset_pin. [ 1.791589@0] ethernetinit(dbg[c087ea28]=1) [ 1.791607@0] ethernet base addr is fe0c0000 [ 1.791610@0] write mac add to:ee82e2c8: ae 9e ba 9b 60 cb |....`.| [ 1.794134@0] libphy: AMLMAC MII Bus: probed [ 1.794139@0] eth0: PHY ID 0007c0f1 at 0 IRQ -1 (0:00) active [ 1.794288@0] Amlogic A/V streaming port init [ 1.795474@0] buffersize=262144,0,start=0 [ 1.795482@0] Subtitle stbuf alloced at 0xee380000, size = 262144 [ 1.795485@0] changed the (2) buffer size from 0 to 262144 [ 1.795691@0] init vdec memsource 79f00000->7defffff [ 1.795856@0] [tsync_pcr_init]init success. [ 1.795858@0] amvideocap_init_module [ 1.795888@0] amvideocap_probe,amvideocap [ 1.795892@0] amvideocap_dev_register buf:0d200000,size:800000. [ 1.796223@0] regist mpeg12 codec profile [ 1.796297@0] regist mpeg4 codec profile [ 1.796298@0] amvdec_vc1 module init [ 1.796374@0] regist vc1 codec profile [ 1.796375@0] amvdec_h264 module init [ 1.796475@0] regist h264 codec profile [ 1.796477@0] amvdec_h264mvc module init [ 1.796556@0] regist hmvc codec profile [ 1.796558@0] amvdec_h264_4k2k module init [ 1.796635@0] regist h264_4k2k codec profile [ 1.796637@0] amvdec_h265 module init [ 1.796711@0] regist hevc_unsupport codec profile [ 1.796786@0] regist mjpeg codec profile [ 1.796787@0] amvdec_real module init [ 1.796860@0] amvdec_avs module init [ 1.797030@0] amvenc_avc memory resource undefined. [ 1.797031@0] amvenc_avc memory is invaild, probe fail! [ 1.797039@0] amvenc_avc: probe of amvenc_avc.0 failed with error -14 [ 1.797322@0] picdec buffer size is 4000000 [ 1.797466@0] alloc_keep_buffer keep_y_addr ede00000 [ 1.797478@0] alloc_keep_buffer keep_u_addr ee400000 [ 1.797486@0] alloc_keep_buffer keep_v_addr ee500000 [ 1.797488@0] yaddr=ede00000,u_addr=ee400000,v_addr=ee500000 [ 1.797769@0] create_ge2d_work_queue video task ok [ 1.798126@0] efuse=========================================== [ 1.798301@0] efuse: device efuse created [ 1.798385@0] efuse-------------------------------------------- [ 1.798387@0] SARADC Driver init. [ 1.798505@0] __saradc_probe__ [ 1.941215@0] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 1.941305@1] saradc calibration: ref_val = 508 [ 1.941307@1] saradc calibration: ref_nominal = 512 [ 1.941309@1] saradc calibration: coef = 4064 [ 1.941438@0] Indeed it is in host mode hprt0 = 00001101 [ 1.941578@1] ir irblaster probe [ 1.941812@1] Remote Driver [ 1.941874@1] Remote platform_data g_remote_base=fe600580 [ 1.941897@1] set drvdata completed [ 1.941904@1] device_create_file completed [ 1.942189@1] input: aml_keypad as /devices/platform/meson-remote/input/input0 [ 1.942416@1] input_register_device completed [ 1.942456@1] [0xffffff00] = 0x1dd0190 [ 1.942458@1] [0xffffff04] = 0xf800ca [ 1.942459@1] [0xffffff08] = 0x82006e [ 1.942461@1] [0xffffff0c] = 0x3c0030 [ 1.942463@1] [0xffffff10] = 0x30fa0013 [ 1.942464@1] [0xffffff18] = 0x6f19000 [ 1.942466@1] [0xffffff1c] = 0xbe40 [ 1.942467@1] [0x0] = 0xfa00a0 [ 1.942469@1] [0x4] = 0xfa00a0 [ 1.942470@1] [0x8] = 0xfa00a0 [ 1.942471@1] [0xc] = 0x640030 [ 1.942473@1] [0x10] = 0x30fa0013 [ 1.942475@1] [0x18] = 0x961b800 [ 1.942476@1] [0x1c] = 0x9740 [ 1.942477@1] [0x20] = 0x104 [ 1.942479@1] [0x24] = 0x0 [ 1.942480@1] [0x28] = 0x0 [ 1.942482@1] set_remote_mode[69] [ 1.942502@1] remote config major:240 [ 1.942664@1] physical address:0x2e94a000 [ 1.942733@1] ADC Keypad Driver init. [ 1.942851@1] Meson KeyInput init [ 1.942961@1] GPIO Keypad Driver init. [ 1.943013@1] ==gpio_key_probe== [ 1.943034@1] reg:2620,clearmask=400040,setmask=1 [ 1.943037@1] reg:2622,clearmask=ff0000,set pin=3 [ 1.943040@1] reg:2623,clearmask=7000000,setmask=7 [ 1.943043@1] reg:2620,clearmask=800080,setmask=10001 [ 1.943045@1] reg:2622,clearmask=ff000000,set pin=3 [ 1.943048@1] reg:2623,clearmask=70000000,setmask=7 [ 1.943067@1] power key(116) registed. [ 1.943206@1] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1 [ 1.943323@1] gpio keypad register input device completed. [ 1.943328@1] gpio keypad major:239 [ 1.943548@1] spi_nor_init [ 1.943653@1] amlogic_spi_nor_probe: [ 1.943658@1] amlogic_spi->state_name:default [ 1.943774@1] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated [ 1.943864@1] check_storage_device : spi boot_device_flag : 0 [ 1.943866@1] spi_nor_probe [ 1.943895@1] spi_nor apollospi:32766: mx25l160 (2048 Kbytes) [ 1.943989@1] Creating 2 MTD partitions on "apollospi:32766": [ 1.943995@1] 0x000000000000-0x000000100000 : "bootloader" [ 1.944644@1] 0x000000100000-0x000000110000 : "ubootenv" [ 1.945226@1] amlogic_spi_nor_probe over [ 1.945365@1] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 1.945491@1] host->base fe108c20 [ 1.945520@1] pdata->caps 7 [ 1.945523@1] pdata->caps2 0 [ 1.945526@1] get property: port, value:0x00000001 [ 1.945529@1] get property: ocr_avail, value:0x00200000 [ 1.945531@1] get property: f_min, value:0x000493e0 [ 1.945533@1] get property: f_max, value:0x02faf080 [ 1.945536@1] get property: max_req_size, value:0x00020000 [ 1.945539@1] get property: irq_in, value:0x00000003 [ 1.945542@1] get property: irq_out, value:0x00000005 [ 1.945547@1] get property: gpio_cd, str:CARD_6 [ 1.945551@1] get property: pinname, str:sd [ 1.945554@1] get property: jtag_pin, str:CARD_0 [ 1.945556@1] get property: card_type, value:0x00000005 [ 1.945559@1] get property: gpio_dat3, str:CARD_4 [ 1.981213@1] reg:2620,clearmask=80008,setmask=10001 [ 1.981216@1] reg:2621,clearmask=ff000000,set pin=64 [ 1.981219@1] reg:2623,clearmask=7000,setmask=7 [ 1.981222@1] reg:2620,clearmask=200020,setmask=1 [ 1.981225@1] reg:2622,clearmask=ff00,set pin=64 [ 1.981227@1] reg:2623,clearmask=700000,setmask=7 [ 1.982273@2] pdata->caps 80000507 [ 1.982276@2] pdata->caps2 0 [ 1.982279@2] get property: port, value:0x00000002 [ 1.982282@2] get property: ocr_avail, value:0x00200000 [ 1.982284@2] get property: f_min, value:0x000493e0 [ 1.982287@2] get property: f_max, value:0x02faf080 [ 1.982289@2] get property: f_max_w, value:0x02faf080 [ 1.982292@2] get property: max_req_size, value:0x00020000 [ 1.982298@2] get property: pinname, str:emmc [ 1.982301@2] get property: card_type, value:0x00000001 [ 1.982305@2] get property: gpio_dat3, str:BOOT_3 [ 1.982308@2] [is_emmc_exist] host->storage_flag=4, POR_BOOT_VALUE=5 [ 1.982310@2] [aml_sdio_probe]: there is not eMMC/tsd, skip sdio_c dts config! [ 1.982327@2] pdata->caps 107 [ 1.982329@2] pdata->caps2 0 [ 1.982332@2] get property: port, value:0x00000000 [ 1.982334@2] get property: ocr_avail, value:0x00200000 [ 1.982336@2] get property: f_min, value:0x000493e0 [ 1.982338@2] get property: f_max, value:0x02faf080 [ 1.982341@2] get property: max_req_size, value:0x00020000 [ 1.982346@2] get property: pinname, str:sdio [ 1.982349@2] get property: card_type, value:0x00000003 [ 2.041217@1] [aml_sdio_probe] aml_sdio_probe() success! [ 2.041471@1] [dsp]DSP start addr 0xc5e00000 [ 2.041490@1] [dsp]register dsp to char divece(257) [ 2.041861@1] amlogic audio spdif interface device init! [ 2.041913@1] name=nand_key nand_key [ 2.042506@1] register_aes_algorithm:488,new way [ 2.042844@1] key name:keyexample, key data:1234567890 [ 2.043456@1] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0 [ 2.046867@1] amaudio2: device amaudio2 created [ 2.046975@1] Amlogic CEC Driver, (c) 2016 Gerald Dachs, Version: 0.0.1 [ 2.046977@1] [amlogic_cec] amlogic_cec_init(): CEC init [ 2.047093@1] [amlogic_cec] amlogic_cec_init(): CEC init finished: 0 [ 2.047146@1] Error: Didn't get power valid value --- wifi_power_probe 376 [ 2.047149@1] Error: Didn't get suspend_power_off value --- wifi_power_probe 393 [ 2.047153@1] wifi_power power_gpio is 6 [ 2.047156@1] wifi_power power_gpio2 is 123 [ 2.047415@1] bcmdhd_wlan_init() [ 2.047422@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[0]=ee6a1540, size=3760 [ 2.047425@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[1]=ee6a1600, size=3760 [ 2.047428@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[2]=ee6a1cc0, size=3760 [ 2.047431@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[3]=ee6a1c00, size=3760 [ 2.047434@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[4]=ee6a1b40, size=3760 [ 2.047436@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[5]=ee6a1a80, size=3760 [ 2.047439@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[6]=ee6a19c0, size=3760 [ 2.047442@1] 1 bcmdhd_init_wlan_mem: wlan_static_skb[7]=ee6a1900, size=3760 [ 2.047448@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[8]=ee6a1840, size=7856 [ 2.047451@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[9]=ee6a1780, size=7856 [ 2.047454@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[10]=ee6a16c0, size=7856 [ 2.047456@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[11]=ee6a1f00, size=7856 [ 2.047462@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[12]=ef3eef00, size=7856 [ 2.047465@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[13]=ef3eee40, size=7856 [ 2.047468@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[14]=ef3eed80, size=7856 [ 2.047470@1] 2 bcmdhd_init_wlan_mem: wlan_static_skb[15]=ef3eecc0, size=7856 [ 2.047474@1] 3 bcmdhd_init_wlan_mem: wlan_static_skb[16]=ef3eec00, size=16048 [ 2.047477@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[0]=ee6a1540, size=20504 [ 2.047481@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[1]=ee6a1600, size=20504 [ 2.047485@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[2]=ee6a1cc0, size=81944 [ 2.047491@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[3]=ee6a1c00, size=163864 [ 2.047494@1] 4 bcmdhd_init_wlan_mem: wlan_mem_array[4]=ee6a1b40, size=20504 [ 2.047498@1] 5 bcmdhd_init_wlan_mem: wlan_static_scan_buf0=ee8d0000, size=65536 [ 2.047502@1] 6 bcmdhd_init_wlan_mem: wlan_static_scan_buf1=ee830000, size=65536 [ 2.047503@1] bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 2.047505@1] amlogic rfkill init [ 2.047547@1] not get gpio_en [ 2.047549@1] not get gpio_wake [ 2.071314@1] BT_RADIO going: on [ 2.071315@1] BCM_BT: going ON [ 2.131212@0] wifi_request_32k_clk : OFF-->ON for bt_rfkill [ 2.131215@0] clock_32k_pin(122) : (null) [ 2.131224@0] clock_32k_pin(122) : sdio_wifi [ 2.142359@0] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 [ 2.142364@0] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.142368@0] usb 1-1: Product: USB2.0 Hub [ 2.142910@0] hub 1-1:1.0: USB hub found [ 2.143167@0] hub 1-1:1.0: 4 ports detected [ 2.241495@1] UMP: UMP device driver -2017.02-100-gc2abd0d loaded [ 2.241798@1] aml_aes aml_aes: Aml AES [ 2.242162@1] aml_tdes aml_tdes: Aml TDES [ 2.242538@1] usbcore: registered new interface driver snd-usb-audio [ 2.242938@1] enter rt5616_modinit [ 2.243116@1] dummy_codec_platform_probe [ 2.243321@1] == ES8323 == es8323_modinit() [ 2.243698@1] i2s get no clk src setting in dts, use the default mpll 0 [ 2.243706@1] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000 [ 2.243919@1] [aml-spdif-dai]enter aml_dai_spdif_init [ 2.243923@1] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4 [ 2.243925@1] audio_set_958_clk, freq=4, [ 2.243931@1] IEC958 16bit [ 2.243935@1] hdmitx: audio: aout notify rate 48000 [ 2.243937@1] hdmitx: audio: aout notify size 16 [ 2.243939@1] hdmitx: audio: aout notify format CT_PCM [ 2.243941@1] hdmitx: audio: audio channel num is 1 [ 2.243947@1] hdmitx: audio: SPDIF [ 2.243959@1] hdmitx: audio: current VIC: 16 [ 2.243960@1] hdmitx: audio: audio sample rate: 3 [ 2.243961@1] hdmitx: audio: set audio N para [ 2.243969@1] hdmitx: audio: PCM out to HDMI [ 2.243971@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 2.243972@1] hdmitx: audio: Enable audio spdif to HDMI [ 2.243977@1] hdmitx: audio: Audio Type: PCM [ 2.244025@1] hdmitx: audio: set audio param [ 2.244083@1] [aml-spdif-dai]aml_spdif_probe [ 2.244221@1] test codec dummy_codec [ 2.244224@1] using external codec, index = 1 [ 2.244226@1] using external dummy codec [ 2.244347@1] enter spdif_dit_probe [ 2.244348@1] aml_spdif_unmute [ 2.244520@1] codec_name = dummy_codec.0 [ 2.244740@1] p_aml_audio->hp_disable=1 [ 2.244742@1] falied to get spk event delay time paraments from dts file [ 2.244744@1] spk_event delay_time = 0 [ 2.245306@1] aml-i2s 0:playback preallocate_dma_buffer: area=f044c000, addr=2e560000, size=65536 [ 2.246200@1] aml-i2s 1:capture preallocate_dma_buffer: area=f0471000, addr=2e780000, size=65536 [ 2.246218@1] aml_snd_m8 aml_m8_sound_card.5: dummy_codec <-> aml-i2s-dai.0 mapping ok [ 2.246830@1] aml-i2s 0:playback preallocate_dma_buffer: area=f0492000, addr=2e7a0000, size=65536 [ 2.247767@1] aml-i2s 1:capture preallocate_dma_buffer: area=f04a4000, addr=2e7c0000, size=65536 [ 2.247782@1] aml_snd_m8 aml_m8_sound_card.5: dit-hifi <-> aml-spdif-dai.0 mapping ok [ 2.248595@1] -----ext_codec=1--- [ 2.248608@1] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0 [ 2.248859@1] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.248890@1] TCP: cubic registered [ 2.248895@1] NET: Registered protocol family 17 [ 2.248911@1] NET: Registered protocol family 15 [ 2.248956@1] Bridge firewalling registered [ 2.249019@1] Bluetooth: RFCOMM TTY layer initialized [ 2.249031@1] Bluetooth: RFCOMM socket layer initialized [ 2.249033@1] Bluetooth: RFCOMM ver 1.11 [ 2.249035@1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.249037@1] Bluetooth: BNEP filters: protocol multicast [ 2.249043@1] Bluetooth: BNEP socket layer initialized [ 2.249044@1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.249049@1] Bluetooth: HIDP socket layer initialized [ 3.352438@0] VFP support v0.3: 2020202020202020202020200106 [ 3.352493@3] [ 3.352495@3] hdmitx: edid: blk1 raw data [ 3.352515@3] 02031df14a900403011412051f1013230907078301000065030c001000023a80 [ 3.352533@3] 1871382d40582c4500fe221100001e011d8018711c1620582c2500fe22110000 [ 3.352552@3] 9e011d007251d01e206e285500fe221100001e8c0ad08a20e02d10103e9600fe [ 3.352571@3] 22110000180000000000000000000000000000000000000000000000000000e6 [ 3.352572@3] [ 3.352606@3] hdmitx: edid: find IEEEOUT [ 3.352637@3] hdmitx: video: get current mode: 1080p [ 3.352644@3] hdmitx: system: [set_disp_mode_auto] ALREADY init VIC = 16 [ 3.352645@3] hdmitx: audio: audio channel num is 1 [ 3.352650@3] hdmitx: audio: SPDIF [ 3.352662@3] hdmitx: audio: current VIC: 16 [ 3.352663@3] hdmitx: audio: audio sample rate: 3 [ 3.352664@3] hdmitx: audio: set audio N para [ 3.352672@3] hdmitx: audio: PCM out to HDMI [ 3.352674@3] hdmitx: audio: i2s_to_spdif_flag:1 [ 3.352675@3] hdmitx: audio: Enable audio spdif to HDMI [ 3.352679@3] hdmitx: audio: Audio Type: PCM [ 3.352728@3] hdmi detect: plug. [ 3.452957@0] implementor 41 architecture 3 part 30 variant 9 rev 4 [ 3.459145@0] Registering SWP/SWPB emulation handler [ 3.464095@0] enter meson_pm_init [ 3.467481@0] enter meson_pm_probe! [ 3.470840@0] meson_pm_probe done ! [ 3.474827@0] regulator-dummy: disabling [ 3.478675@0] aml_rtc rtc.0: setting system clock to 1970-01-01 00:00:02 UTC (2) [ 3.485626@0] ### dt-test ### No testcase data in device tree; not running tests [ 3.493053@0] meson_cpufreq: no voltage_control prop [ 3.497894@0] voltage_control = 0 [ 3.501465@0] buf[0]=a7,buf[1]=9b,err=4 [ 3.504990@0] M8:adc=442,TS_C=7,flag=1 [ 3.508714@0] efuse_flag=a [ 3.511486@0] amlogic_thermal_probe, this chip is trimmed, use thermal [ 3.517923@0] amlogic-thermal aml_thermal: amlogic thermal probe start [ 3.524426@0] #thermal-cells=7 [ 3.527438@0] pdata->temp_trip_count=4 [ 3.531195@0] temperature=70000 on trip point=0 [ 3.535673@0] fixing high_freq=1608001 to 1608000 at trip point 0,level=2 [ 3.542456@0] fixing low_freq=1608001 to 1608000 at trip point 0,level=2 [ 3.549123@0] gpu[0].gpu_high_freq=511,tmp_level[0].gpu_high_freq=511 [ 3.555552@0] cpu[0] core num==3 [ 3.558730@0] gpu[0] core num==5 [ 3.561956@0] temperature=80000 on trip point=1 [ 3.566450@0] fixing high_freq=1200001 to 1200000 at trip point 1,level=6 [ 3.573222@0] fixing low_freq=1200001 to 1200000 at trip point 1,level=6 [ 3.579881@0] gpu[1].gpu_high_freq=435,tmp_level[1].gpu_high_freq=435 [ 3.586316@0] cpu[1] core num==2 [ 3.589502@0] gpu[1] core num==4 [ 3.592725@0] temperature=90000 on trip point=2 [ 3.597217@0] fixing high_freq=800001 to 696000 at trip point 2,level=11 [ 3.603908@0] fixing low_freq=800001 to 696000 at trip point 2,level=11 [ 3.610481@0] gpu[2].gpu_high_freq=328,tmp_level[2].gpu_high_freq=328 [ 3.616916@0] cpu[2] core num==2 [ 3.620101@0] gpu[2] core num==3 [ 3.623324@0] temperature=260000 on trip point=3 [ 3.627902@0] fixing high_freq=-1 to -22 at trip point 3,level=-1 [ 3.633970@0] fixing low_freq=-1 to -22 at trip point 3,level=-1 [ 3.639952@0] gpu[3].gpu_high_freq=-1,tmp_level[3].gpu_high_freq=-1 [ 3.646208@0] cpu[3] core num==-1 [ 3.649492@0] gpu[3] core num==-1 [ 3.652799@0] idle interval=1000 [ 3.655989@0] pdata->name:aml_thermal [ 3.660048@0] tmp_trip[0].cpu_core_upper=1 [ 3.663734@0] tmp_trip[1].cpu_core_upper=2 [ 3.667792@0] tmp_trip[2].cpu_core_upper=2 [ 3.671876@0] tmp_trip[3].cpu_core_upper=-1 [ 3.676018@0] aml_thermal bind thermal-cpucore-0 okay ! [ 3.681260@0] aml_thermal bind thermal-cpufreq-0 okay ! [ 3.686542@0] amlogic: Kernel Thermal management registered [ 3.691980@0] amlogic-thermal aml_thermal: amlogic thermal probe done [ 3.69853[ 3.721202@3] Changing uart_ao_ttyS0: baud from 0 to 115200 [ 3.741310@3] Freeing unused kernel memory: 180K (c080d000 - c083a000) [ 3.753407@2] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 3.754381@2] Disabling lock debugging due to kernel taint [ 3.760682@2] boot_device_flag : 0 [ 3.763239@2] register_ntd_blktrans start [ 3.767212@2] ntd device 250! [ 3.770157@2] ntd->name: nfcache [ 3.773374@2] adjust_block_num : 4,reserved_block_ratio 10 [ 3.778827@2] nftl version 140911a [ 3.782218@2] nftl part attr 0 [ 3.786464@2] nftl start:76,12 [ 3.788387@2] first [ 3.862749@2] average_erase_count:0 [ 3.862773@2] second 56,64 [ 3.863284@2] part->max_discard_block = 4 [ 3.927412@2] current_block1:20 [ 3.929541@2] recover_current_block_mapping invalid page data!! [ 3.931881@2] recover_current_block_mapping invalid page data!! [ 3.937758@2] recover_current_block_mapping invalid page data!! [ 3.943680@2] recover_current_block_mapping invalid page data!! [ 3.949561@2] recover_current_block_mapping invalid page data!! [ 3.957029@2] recover_current_block_mapping invalid page data!! [ 3.961253@2] all discard block full!! [ 3.964018@2] free list: [ 3.966606@2] free block cnt = 61 [ 3.969901@2] new current block is 19 [ 4.230937@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 4.860406@0] recover_current_block_mapping : fill the current block, from page 255 [ 4.862440@0] total discard page count is 0 [ 4.866592@0] create_part_list:1235,current_used_discard_block=18,current_discard_block_used_count=161 [ 4.876155@0] unmappig_pages=15832,discarded_pages=0,mapping_pages=552 [ 4.882391@0] nftl ok! [ 4.885437@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 4.889735@0] aml_nftl_add_ntd ok [ 4.892609@0] ntd device 250! [ 4.895532@0] ntd->name: nfcode [ 4.898664@0] adjust_block_num : 4,reserved_block_ratio 10 [ 4.904133@0] nftl version 140911a [ 4.907518@0] nftl part attr 0 [ 4.913914@0] size_in_blk 204; total_block 203; [ 4.915129@0] nftl start:203,23 [ 4.918531@0] first [ 5.051297@0] found discard block:139 [ 5.111579@0] average_erase_count:6 [ 5.111604@0] second 203,180 [ 5.112290@0] part->max_discard_block = 4 [ 5.335413@0] current_block1:39 [ 5.410903@0] recover_current_block_mapping invalid page data!! [ 5.412249@0] recover_current_block_mapping invalid page data!! [ 5.418160@0] recover_current_block_mapping invalid page data!! [ 5.424063@0] recover_current_block_mapping invalid page data!! [ 5.429945@0] recover_current_block_mapping invalid page data!! [ 5.435863@0] recover_current_block_mapping invalid page data!! [ 5.442554@0] currnet_discard_block1:139 [ 5.481247@0] reach the last discard page:28 [ 5.481303@0] free list: [ 5.482480@0] free block cnt = 90 [ 5.485774@0] new current block is 24 [ 5.787261@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 6.372261@0] recover_current_block_mapping : fill the current block, from page 255 [ 6.374275@0] total discard page count is 28 [ 6.378523@0] create_part_list:1235,current_used_discard_block=139,current_discard_block_used_count=91 [ 6.388520@0] unmappig_pages=25320,discarded_pages=119,mapping_pages=20641 [ 6.394676@0] nftl ok! [ 6.397822@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.402050@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.406577@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.411168@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.415818@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.420374@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.424992@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 6.429487@0] aml_nftl_add_ntd ok [ 6.432471@0] ntd device 250! [ 6.435386@0] ntd->name: nfdata [ 6.438508@0] adjust_block_num : 4,reserved_block_ratio 10 [ 6.443992@0] nftl version 140911a [ 6.447407@0] nftl part attr 0 [ 6.462283@0] size_in_blk 720; total_block 714; [ 6.462315@0] nftl start:714,69 [ 6.465027@0] first [ 7.127801@0] found discard block:701 [ 7.140253@0] average_erase_count:2 [ 7.140283@0] second 714,645 [ 7.140965@0] part->max_discard_block = 4 [ 7.918095@0] current_block1:263 [ 8.027606@0] recover_current_block_mapping invalid page data!! [ 8.028933@0] recover_current_block_mapping invalid page data!! [ 8.034876@0] recover_current_block_mapping invalid page data!! [ 8.040745@0] recover_current_block_mapping invalid page data!! [ 8.046660@0] recover_current_block_mapping invalid page data!! [ 8.052566@0] recover_current_block_mapping invalid page data!! [ 8.059251@0] currnet_discard_block1:701 [ 8.095717@0] reach the last discard page:28 [ 8.096442@0] free list: [ 8.096949@0] free block cnt = 24 [ 8.100251@0] new current block is 364 [ 8.432211@0] prio_garbage_collect_no_last_page_in_create_list put_phy_block_to_free_list! [ 8.984281@0] recover_current_block_mapping : fill the current block, from page 255 [ 8.986295@0] total discard page count is 28 [ 8.990542@0] create_part_list:1235,current_used_discard_block=701,current_discard_block_used_count=30 [ 9.002501@0] unmappig_pages=116929,discarded_pages=3583,mapping_pages=44608 [ 9.006838@0] nftl ok! [ 9.010036@0] Enable QUEUE_FLAG_DISCARD for NFTL [ 9.014186@0] aml_nftl_add_ntd ok [ 9.017089@0] init_aml_nftl end [ 9.023665@2] aml_nftl_open ok! [ 9.024924@2] force enable DISCARD here for ext4 fs [ 9.092633@2] EXT4-fs (syslinux): recovery complete [ 9.097193@2] checked enable EXT4 DISCARD here [ 9.097225@2] EXT4-fs (syslinux): mounted filesystem with ordered data mode. Opts: (null) mount: proc is already mounted or /proc busy proc is already mounted on /proc [ 9.370134@0] EXT4-fs (syslinux): re-mounted. Opts: (null) Starting logging: OK remotecfg parameter[0] /usr/bin/amremote_config remotecfg parameter[1] /etc/remote.conf curpara:factory_c[ 10.855358@1] cur_mode = 0 [ 10.857960@1] [0x0] = 0x1dd0190 [ 10.861078@1] [0x4] = 0xf800ca [ 10.864129@1] [0x8] = 0x82006e [ 10.867146@1] [0xc] = 0x3c0030 [ 10.870179@1] [0x10] = 0x30fa0013 [ 10.873486@1] [0x18] = 0x6f19000 [ 10.876681@1] [0x1c] = 0x9f40 [ 10.879627@1] [0x20] = 0x0 [ 10.882395@1] [0x24] = 0x0 [ 10.885002@1] [0x28] = 0x0 [ 10.887690@1] set_remote_mode[69] ode 40400001 curpara:work_mode 00000000 curpara:repeat_enable 00000001 curpara:release_delay 00000096 curpara:debug_enable 00000001 curpara:reg_control 000fbe40 KEYMAP_LEVEL: ircode = 0x2, keycode = 31 KEYMAP_LEVEL: ircode = 0x3, keycode = 23 KEYMAP_LEVEL: ircode = 0xa, keycode = 105 KEYMAP_LEVEL: ircode = 0xb, keycode = 103 KEYMAP_LEVEL: ircode = 0xc, keycode = 106 KEYMAP_LEVEL: ircode = 0xd, keycode =[ 10.927875@1] udevd[1721]: starting version 3.2.1 108 KEYMAP_LEVEL: ircode = 0xe, keycode = 28 KEYMAP_LEVEL: ircode = 0x4, keycode = 14 KEYMAP_LEVEL: ircode = 0x5, keycode = 15 KEYMAP_LEVEL: ircode = 0x6, keycode = 57 KEYMAP_LEVEL: irco[ 10.950755@2] udevd[1723]: starting eudev-3.2.1 de = 0x7, keycode = 46 KEYMAP_LEVEL: ircode = 0x9, keycode = 66 KEYMAP_LEVEL: ircode = 0x8, keycode = 45 work_mode = 0 repeat_enable = 1 factory_code = 16448 release_delay = 0x96 debug_enable = 0x1 reg_control = 1031744 Populating /dev using udev: [ 11.067924@2] aml_nftl_open ok! [ 11.068028@3] aml_nftl_open ok! [ 11.068106@0] aml_nftl_open ok! [ 11.068511@2] aml_nftl_open ok! [ 11.069744@1] aml_nftl_open ok! [ 11.075177@1] aml_nftl_open ok! [ 11.078805@1] aml_nftl_open ok! [ 11.085692@0] aml_nftl_open ok! [ 11.279656@2] as an end receiver [ 11.280205@2] amlvideo openamlvideo closedone S11setup: start S10setup: remount / rw [ 11.300240@1] EXT4-fs (syslinux): re-mounted. Opts: (null) [ 11.305495@1] aml_nftl_open ok! [ 11.306713@1] force enable DISCARD here for ext4 fs [ 11.391856@3] EXT4-fs (data): recovery complete [ 11.394429@3] checked enable EXT4 DISCARD here [ 11.395173@3] EXT4-fs (data): mounted filesystem with ordered data mode. Opts: (null) S10setup: mount /cache partition [ 11.407745@1] aml_nftl_open ok! [ 11.410199@1] force enable DISCARD here for ext4 fs [ 11.427631@1] EXT4-fs (cache): recovery complete [ 11.427668@1] checked enable EXT4 DISCARD here [ 11.431033@1] EXT4-fs (cache): mounted filesystem with ordered data mode. Opts: (null) /etc/init.d/S11setup: line 71: /sys/block/mmcblk0/queue/read_ahead_kb: No such file or directory /etc/init.d/S11setup: line 72: /sys/block/mmcblk1/queue/read_ahead_kb: No such file or directory S12make_binds: Start S12make_binds: Setting dropbear... Initializing random number generator... done. Starting system message bus: done [ 11.621353@1] dhd_module_init in [ 11.621385@1] wifi_setup_dt [ 11.621723@1] wifi_request_32k_clk : ON-->ON for sdio_wifi [ 11.627183@1] interrupt_pin(133) : (null) [ 11.631263@1] reg:2620,clearmask=100010,setmask=0 [ 11.635938@1] reg:2622,clearmask=ff,set pin=133 [ 11.640445@1] reg:2623,clearmask=70000,setmask=4 [ 11.645053@1] interrupt_pin(133) : sdio_wifi [ 11.649287@1] power_on_pin(6) : (null) [ 11.653044@1] power_on_pin(6) : sdio_wifi [ 11.657001@1] power_on_pin2(123) : (null) [ 11.660993@1] power_on_pin2(123) : sdio_wifi [ 11.665306@1] ======== bcm_wlan_set_plat_data ======== [ 11.670350@1] host_oob_irq: 100 [ 11.673654@1] host_oob_irq_flags=4 [ 11.677025@1] dhd_wifi_platform_load: Enter [ 11.681197@1] Power-up adapter 'DHD generic adapter' [ 11.686162@1] wifi_platform_set_power = 1 [ 11.690113@1] ======== PULL WL_REG_ON HIGH! ======== [ 11.695068@1] WIFI Disable! 6 [ 11.897890@1] WIFI Enable! 6 [ 12.097730@2] sdio: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 12.191430@2] IRQ94 no longer affine to CPU2 [ 12.191682@1] CPU2: shutdown [ 12.331384@3] IRQ95 no longer affine to CPU3 [ 12.331571@1] CPU3: shutdown [ 13.091198@1] [aml_sdio_timeout][0;40;33m time_start_cnt:992 [ 13.091198@1] [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd52 arg 0xc00, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x113, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:993 [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd52 arg 0x80000c08, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x1f003f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[aml_sdio_timeout][0;40;33m time_start_cnt:992 [0m[aml_sdio_print_err][0;40;33m sdio: Timeout error, Cmd8 arg 0x1aa, Xfer 0 Bytes, host->xfer_step=12, host->cmd_is_stop=0, pdata->port=0, virqs=0x13, virqc=0x3f001f00, conf->cmd_clk_divide=177, pdata->clkc=177, conf->bus_width=0, pdata->width=0, conf=0x416270b1, clock=397940 [0m[ 15.162814@1] sdio: queuing unknown CIS tuple 0x80 (2 bytes) [ 15.164177@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 15.169790@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 15.176518@1] sdio: queuing unknown CIS tuple 0x80 (7 bytes) [ 15.194005@1] sdio: new high speed SDIO card at address 0001, clock 35416666, 4-bit-bus-width [ 15.198096@1] [sdio_reinit] finish [ 15.401197@1] wifi_platform_bus_enumerate device present 1 [ 15.401232@1] ======== Card detection to detect SDIO card! ======== [ 15.423344@1] bcmsdh_register: register client driver [ 15.423467@1] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 15.427781@1] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 15.432745@1] bus num (host idx)=2, slot num (rca)=1 [ 15.437577@1] found adapter info 'DHD generic adapter' [ 15.442748@1] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c088382c, size=139264 [ 15.450925@1] success alloc section 3, size 139264 [ 15.455823@1] alloc static buf at ee3c0000! [ 15.459855@1] 1 bcmdhd_mem_prealloc: section=4, wlan_static_skb=c0abd1c4 [ 15.466577@1] success alloc section 4, size 0 [ 15.471553@1] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362 [ 15.478847@1] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9 [ 15.484215@1] DHD: dongle ram size is set to 245760(orig 245760) at 0x0 [ 15.490627@1] dhdsdio_probe: Disable prop_txstatus [ 15.494764@1] 4 bcmdhd_mem_prealloc: section=7, wlan_mem_array[4]=ee8c8000 [ 15.501583@1] success alloc section 7, size 19512 [ 15.506328@1] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c0883814, size=10320 [ 15.514431@1] success alloc section 0, size 10320 [ 15.519284@1] 2 bcmdhd_mem_prealloc: section=5, wlan_static_scan_buf0=ee8d0000 [ 15.526318@1] success alloc section 5, size 0 [ 15.530649@1] wl_create_event_handler(): thread:wl_event_handler:6f0 started [ 15.537681@1] tsk Enter, tsk = 0xf045e66c [ 15.541890@0] dhd_attach(): thread:dhd_watchdog_thread:6f1 started [ 15.547797@0] dhd_attach(): thread:dhd_dpc:6f2 started [ 15.552983@0] dhd_attach(): thread:dhd_rxf:6f3 started [ 15.557987@0] dhd_deferred_work_init: work queue initialized [ 15.563778@0] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c088381c, size=10300 [ 15.571890@0] success alloc section 1, size 10300 [ 15.576567@0] 7 bcmdhd_mem_prealloc: wlan_mem_array[section].mem_ptr=c0883824, size=65536 [ 15.584718@0] success alloc section 2, size 65536 [ 15.589585@1] Dongle Host Driver, version 1.141.66.1 (r483454) [ 15.589585@1] Compiled in drivers/net/wireless/bcmdhd on Mar 10 2017 at 07:36:50 [ 15.602828@1] Register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 15.602828@1] [ 15.610163@1] dhd_prot_ioctl : bus is down. we have nothing to do [ 15.616288@1] bcmsdh_oob_intr_unregister: Enter [ 15.620736@1] bcmsdh_oob_intr_unregister: irq is not registered [ 15.626644@1] dhd_bus_devreset: WLAN OFF DONE [ 15.631098@1] wifi_platform_set_power = 0 [ 15.635053@1] ======== PULL WL_REG_ON LOW! ======== [ 15.639932@1] dhd_module_init: Exit err=0 Starting bluetooth... [ 15.675104@1] BT_RADIO going: on [ 15.675137@1] BCM_BT: going ON [ 15.761202@1] Changing uart_a_ttyS1: baud from 0 to 115200 [ 15.801201@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 [ 16.021199@1] Changing uart_a_ttyS1: baud from 3000000 to 115200 [ 16.091194@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 [ 16.131241@1] Changing uart_a_ttyS1: baud from 3000000 to 115200 [ 16.171192@1] Changing uart_a_ttyS1: baud from 115200 to 3000000 Device setup complete Starting Mali... [ 16.235244@1] pdata->tmp_trip[0].gpu_lower_level=1 [ 16.235285@1] pdata->tmp_trip[0].gpu_upper_level=1 [ 16.239181@1] pdata->tmp_trip[1].gpu_lower_level=2 [ 16.243957@1] pdata->tmp_trip[1].gpu_upper_level=2 [ 16.248710@1] pdata->tmp_trip[2].gpu_lower_level=3 [ 16.253559@1] pdata->tmp_trip[2].gpu_upper_level=3 [ 16.258243@1] pdata->tmp_trip[3].gpu_lower_level=-1 [ 16.263113@1] pdata->tmp_trip[3].gpu_upper_level=-1 [ 16.267951@1] aml_thermal bind thermal-gpufreq-0 okay ! [ 16.273156@1] gpu cooling register okay with err=0 [ 16.277970@1] tmp_trip[0].gpu_core_upper=1 [ 16.282007@1] tmp_trip[1].gpu_core_upper=2 [ 16.286067@1] tmp_trip[2].gpu_core_upper=3 [ 16.290145@1] tmp_trip[3].gpu_core_upper=-1 [ 16.294316@1] aml_thermal bind thermal-gpucore-0 okay ! [ 16.299496@1] gpu core cooling register okay with err=0 [ 16.304940@1] Mali: Mali device driver loaded Starting network: OK Starting Bluez. Starting connman ... done. Starting ntpd: OK [ 16.695920@1] netdev_open [ 16.695946@1] Ethernet reset [ 16.695968@1] NET MDA descpter start addr=ee355000 [ 16.703184@1] phy_interface = 1 [ 16.703661@1] aml_phy_init: trying to attach to 0:00 [ 16.708786@1] --1--write mac add to:ee82e2c8: ae 9e ba 9b 60 cb |....`.| [ 16.715359@1] --2--write mac add to:ee82e2c8: ae 9e ba 9b 60 cb |....`.| [ 16.725005@1] write mac add to:ee82e2c8: ae 9e ba 9b 60 cb |....`.| [ 16.728276@1] Current DMA mode=0, set mode=621c100 [ 16.733346@1] ether leave promiscuous mode [ 16.737119@1] ether leave all muticast mode [ 16.742433@1] changed the Multicast,mcount=1 [ 16.745535@1] add mac address:01:00:5e:00:00:01,bit=32 [ 16.750641@1] set hash low=0,high=1 [ 16.754124@1] changed the filter setting to :4 Starting dropbear sshd: [ 16.800938@1] dhd_open: Enter ee283800 [ 16.800977@1] [ 16.800977@1] Dongle Host Driver, version 1.141.66.1 (r483454) [ 16.800977@1] Compiled in drivers/net/wireless/bcmdhd on Mar 10 2017 at 07:36:50 [ 16.814131@1] wl_android_wifi_on in 1 [ 16.817515@1] wl_android_wifi_on in 2: g_wifi_on=0 [ 16.822298@1] wifi_platform_set_power = 1 [ 16.826269@1] ======== PULL WL_REG_ON HIGH! ======== [ 16.831325@1] write pen_release: 2 [ 16.834832@2] CPU2: Booted secondary processor [ 16.835061@2] WIFI Disable! 6 [ 17.034865@2] WIFI Enable! 6 [ 17.234688@2] sdio_reset_comm(): [ 17.248611@1] sdio: queuing unknown CIS tuple 0x80 (2 bytes) [ 17.250388@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 17.256045@1] sdio: queuing unknown CIS tuple 0x80 (3 bytes) [ 17.263054@1] sdio: queuing unknown CIS tuple 0x80 (7 bytes) [ 17.280937@1] [sdio_reinit] finish [ 17.311361@1] libphy: 0:00 - Link is Up - 100/Full [ 17.481616@1] [ 17.481616@1] [ 17.481616@1] dhd_bus_devreset: == WLAN ON == [ 17.483925@1] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362 [ 17.491782@1] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9 [ 17.496916@1] DHD: dongle ram size is set to 245760(orig 245760) at 0x0 [ 17.503697@1] dhd_conf_read_config: Ignore config file /lib/firmware/brcm/config.txt [ 17.510419@1] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/fw_bcm40181a2.bin [ 17.519012@1] nv_path=dhd_conf_set_nv_name_by_chip [ 17.523776@1] Final fw_path=/lib/firmware/brcm/fw_bcm40181a2.bin [ 17.529744@1] Final nv_path=/lib/firmware/brcm/ap6210_nvram.txt [ 17.535650@1] Final conf_path=/lib/firmware/brcm/config.txt [ 17.577585@1] NVRAM version: AP6210_NVRAM_V1.2_03192013 [ 17.578138@1] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. [ 17.585544@1] dhd_bus_init: delay 100ms for BCM43362 [ 17.791411@2] IRQ94 no longer affine to CPU2 [ 17.791662@1] CPU2: shutdown [ 17.818588@0] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ 17.819043@0] bcmsdh_oob_intr_register: Enter [ 17.823402@0] bcmsdh_oob_intr_register OOB irq=100 flags=4 [ 17.828779@0] bcmsdh_oob_intr_register: enable_irq_wake [ 17.835172@0] dhd_conf_set_band: Set band 0 [ 17.840002@0] Firmware up: op_mode=0x0005, MAC=6c:fa:a7:6d:0d:1f [ 17.844206@0] dhd_conf_set_country: Set country ALL, revision 0 [ 17.937105@0] Country code: ALL (ALL/0) [ 17.937431@0] dhd_conf_set_roam: Set roam_off 1 [ 17.942012@0] dhd_preinit_ioctls Set ampdu_ba_wsize to 32 failed -2 [ 17.946558@0] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23 [ 17.953619@0] dhd_preinit_ioctls buf_key_b4_m4 set failed -23 [ 17.964545@0] Firmware version = wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13 [ 17.967863@0] Driver: 1.141.66.1 (r483454) [ 17.967863@0] Firmware: wl0: Jul 5 2013 17:55:22 version 5.90.195.89.10 FWID 01-f4d31c13 [ 17.983342@0] dhd_preinit_ioctls wl ampdu_hostreorder failed -23 [ 17.986900@0] wl_android_wifi_on: Success [ 18.072867@0] dhd_open: Exit ret=0 OK Starting KODI... Starting SMB services: [ 18.251916@1] changed the Multicast,mcount=2 [ 18.251956@1] add mac address:01:00:5e:00:00:01,bit=32 [ 18.255665@1] add mac address:01:00:5e:00:00:fb,bit=48 [ 18.260778@1] set hash low=0,high=10001 [ 18.264624@1] changed the filter setting to :4 [ 18.931292@1] write pen_release: 2 [ 18.931568@2] CPU2: Booted secondary processor OK Starting NMB services: OK Welcome to Buildroot dsQuad login: [ 19.891470@2] IRQ94 no longer affine to CPU2 [ 19.891732@1] CPU2: shutdown [ 20.281922@1] IEC958 16bit [ 20.281950@1] hdmitx: audio: aout notify rate 48000 [ 20.283849@1] hdmitx: audio: aout notify size 16 [ 20.288443@1] hdmitx: audio: no update [ 20.292321@1] aml_i2s_close device type 8 [ 20.318738@1] IEC958 16bit [ 20.318765@1] hdmitx: audio: aout notify rate 48000 [ 20.320663@1] hdmitx: audio: aout notify size 16 [ 20.325366@1] hdmitx: audio: no update [ 20.328988@1] aml_i2s_close device type 8 [ 20.335043@1] IEC958 16bit [ 20.335749@1] hdmitx: audio: aout notify rate 48000 [ 20.340600@1] hdmitx: audio: aout notify size 16 [ 20.345292@1] hdmitx: audio: no update [ 20.348924@1] aml_i2s_close device type 8 [ 20.355537@1] IEC958 16bit [ 20.355687@1] hdmitx: audio: aout notify rate 48000 [ 20.360537@1] hdmitx: audio: aout notify size 16 [ 20.365524@1] hdmitx: audio: no update [ 20.368862@1] aml_i2s_close device type 8 [ 20.374544@1] IEC958 16bit [ 20.375623@1] hdmitx: audio: aout notify rate 48000 [ 20.380474@1] hdmitx: audio: aout notify size 16 [ 20.385174@1] hdmitx: audio: no update [ 20.388798@1] aml_i2s_close device type 2 [ 20.877997@0] buf=0 [ 20.878026@0] IEC958_mode_raw=0 [ 20.884250@0] IEC958 16bit [ 20.884282@0] hdmitx: audio: aout notify rate 48000 [ 20.886179@0] hdmitx: audio: aout notify size 16 [ 20.890772@0] hdmitx: audio: no update [ 20.894548@0] aml_i2s_close device type 8 [ 20.900606@0] IEC958 16bit [ 20.901306@0] hdmitx: audio: aout notify rate 48000 [ 20.906292@0] hdmitx: audio: aout notify size 16 [ 20.910711@0] hdmitx: audio: no update [ 20.914476@0] aml_i2s_close device type 8 [ 20.923030@0] [aml-i2s-dai]enterd aml_dai_i2s_prepare,old_samplerate:48000,sample_rate=44100 [ 20.926930@0] [aml-i2s-dai]i2s dma f044c000,phy addr 2e560000,mode 0,ch 2 [ 20.933957@0] ----aml_hw_iec958_init,runtime->rate=44100-- [ 20.939232@0] [aml-spdif-dai]enterd aml_hw_iec958_init,set_clock:4,sample_rate=5 [ 20.946625@0] audio_set_958_clk, freq=5, [ 20.950556@0] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 20.957207@0] iec958 mode PCM16 [ 20.960334@0] IEC958 16bit [ 20.963125@0] hdmitx: audio: aout notify rate 44100 [ 20.967844@0] hdmitx: audio: aout notify size 16 [ 20.972454@0] hdmitx: audio: audio channel num is 1 [ 20.977290@0] hdmitx: audio: SPDIF [ 20.980674@0] hdmitx: audio: current VIC: 16 [ 20.984939@0] hdmitx: audio: audio sample rate: 2 [ 20.989591@0] hdmitx: audio: set audio N para [ 20.993964@0] hdmitx: audio: PCM out to HDMI [ 20.998180@0] hdmitx: audio: i2s_to_spdif_flag:1 [ 21.002881@0] hdmitx: audio: Enable audio spdif to HDMI [ 21.008058@0] hdmitx: audio: Audio Type: PCM [ 21.012366@0] hdmitx: audio: set audio param [ 21.016560@0] [aml-spdif-dai]spdif dma f044c000,phy addr 2e560000 [ 21.022715@0] speaker_events--mute =1 [ 21.031638@1] [aml-i2s-dai]i2s dma f044c000,phy addr 2e560000,mode 0,ch 2 [ 21.033103@1] ----aml_hw_iec958_init,runtime->rate=44100-- [ 21.038564@1] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 21.045265@1] iec958 mode PCM16 [ 21.048361@1] IEC958 16bit [ 21.051046@1] hdmitx: audio: aout notify rate 44100 [ 21.055918@1] hdmitx: audio: aout notify size 16 [ 21.060494@1] hdmitx: audio: no update [ 21.064235@1] [aml-spdif-dai]spdif dma f044c000,phy addr 2e560000 [ 21.076804@1] [aml-i2s-dai]aiu i2s playback enable [ 21.076804@1] [ 21.077610@1] [aml-i2s-dai]audio_hw_958_enable 1 [ 21.139535@1] amlvideo openamlvideo closechanged the Multicast,mcount=3 [ 23.295006@0] add mac address:01:00:5e:00:00:01,bit=32 [ 23.297273@0] add mac address:01:00:5e:00:00:fb,bit=48 [ 23.302417@0] add mac address:01:00:5e:7f:ff:fa,bit=20 [ 23.307486@0] set hash low=100000,high=10001 [ 23.311761@0] changed the filter setting to :4 [ 24.131312@1] write pen_release: 2 [ 24.131611@2] CPU2: Booted secondary processor [ 25.971469@2] IRQ94 no longer affine to CPU2 [ 25.971731@1] CPU2: shutdown [ 81.271335@1] [aml-i2s-dai]aiu i2s playback disable [ 81.271335@1] [ 81.272222@1] [aml-i2s-dai]audio_hw_958_enable 0 [ 81.276935@1] [aml-i2s-dai]i2s dma f044c000,phy addr 2e560000,mode 0,ch 2 [ 81.283931@1] ----aml_hw_iec958_init,runtime->rate=44100-- [ 81.289213@1] ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5-- [ 81.295997@1] iec958 mode PCM16 [ 81.299009@1] IEC958 16bit [ 81.301789@1] hdmitx: audio: aout notify rate 44100 [ 81.306548@1] hdmitx: audio: aout notify size 16 [ 81.311198@1] hdmitx: audio: no update [ 81.314982@1] [aml-spdif-dai]spdif dma f044c000,phy addr 2e560000 [ 88.531137@1] normal card in [ 89.021342@1] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 89.313743@1] sd: new high speed SDXC card at address aaaa, clock 35416666, 4-bit-bus-width [ 89.316725@1] mmcblk0: sd:aaaa SL64G 59.4 GiB [ 89.326353@0] mmcblk0: p1 p2 [ 89.736293@1] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 91.321300@1] [aml-spdif-dai]enterd aml_spdif_play,set_clock:5,sample_rate=4 [ 91.322727@1] audio_set_958_clk, freq=4, [ 91.326612@1] IEC958 16bit [ 91.329297@1] hdmitx: audio: aout notify rate 48000 [ 91.334202@1] hdmitx: audio: aout notify size 16 [ 91.338774@1] hdmitx: audio: audio channel num is 1 [ 91.343750@1] hdmitx: audio: SPDIF [ 91.346986@1] hdmitx: audio: current VIC: 16 [ 91.351253@1] hdmitx: audio: audio sample rate: 3 [ 91.355919@1] hdmitx: audio: set audio N para [ 91.360331@1] hdmitx: audio: PCM out to HDMI [ 91.364501@1] hdmitx: audio: i2s_to_spdif_flag:1 [ 91.369192@1] hdmitx: audio: Enable audio spdif to HDMI [ 91.374402@1] hdmitx: audio: Audio Type: PCM [ 91.378658@1] hdmitx: audio: set audio param [ 91.382893@1] aml_i2s_close device type 8 [ 94.726027@1] force enable DISCARD here for ext4 fs [ 94.765942@1] EXT4-fs (mmcblk0p2): recovery complete [ 94.765982@1] checked enable EXT4 DISCARD here [ 94.769793@1] EXT4-fs (mmcblk0p2): mounting with "discard" option, but the device does not support discard [ 94.779399@1] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null) [ 96.391393@1] speaker_events--mute =0 [ 198.031469@1] aml_keys_notify_reboot:1717 [ 198.076820@0] i2c 0-0032: Bus i2c calling i2c_device_shutdown shutdown [ 198.077901@0] i2c i2c-3: Bus i2c calling i2c_device_shutdown shutdown [ 198.084362@0] i2c i2c-2: Bus i2c calling i2c_device_shutdown shutdown [ 198.090841@0] i2c i2c-1: Bus i2c calling i2c_device_shutdown shutdown [ 198.097162@0] i2c i2c-0: Bus i2c calling i2c_device_shutdown shutdown [ 198.103727@0] amlnfdev nand: Driver amlnfdev calling platform_drv_shutdown shutdown [ 198.111201@0] boot_device_flag : 0 [ 198.114715@0] aml_rtc rtc.0: Driver aml_rtc calling platform_drv_shutdown shutdown [ 198.122853@0] Restarting system. [ 198.125296@0] [ 198.126939@0] Restarting Linux version 3.10.105 (dev_user@dev) (gcc version 5.4.0 (Buildroot 2017.02-00100-gc2abd0d-dirty) ) #1 SMP PREEMPT Fri Mar 10 07:36:38 EET 2017 [ 198.126939@0] [ ‡EEEE I3000000032940xf100110003877500EEEE I400000004294_M8_BL1_10221D113B323EEEE I3000000032940xbbbb000026A22525 no sdio debug board detected TE : 102621 BT : 23:37:31 Feb 20 2016 PMU:rn5t618 DC01 v:1100, 0x[36]: 28 -> 28 DC02 v:1150, 0x[37]: 2c -> 2c DC03 v:1500, 0x[38]: 48 -> 48 LDO01 v:2900, 0x[4c]: 50 -> 50 LDO02 v:1800, 0x[4d]: 24 -> 24 LDO03 v:1800, 0x[4e]: 30 -> 30 LDO04 v:2850, 0x[4f]: 4e -> 4e LDO05 v:1800, 0x[50]: 24 -> 24 LDO0a v:2700, 0x[56]: 28 -> 28 LDO0b v:900, 0x[57]: 00 -> 00 CPU clock is 1200MHz CPU type: M8 DDR info: 2GB(auto) @ 792MHz(1T) DDR channel: DDR 0 + DDR 1 DDR init use : 12089 us HHH Boot From SPI ucl decompress...pass 0x12345678 Boot from internal device 1st SPI TE : 489379 System Started U-boot-00000-g4a876d1-dirty(m8_dotsmart@amlogic-lp-511) (Feb 20 2016 - 23:37:11) clr h-ram DRAM: 2 GiB relocation Offset is: 6feb0000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : linux, size : 2000000 part: 5, name : system, size : 40000000 part: 6, name : syslinux, size : 10000000 part: 7, name : cache, size : 20000000 part: 8, name : data, size : end aml_card_type=0x200 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 PMU fault status: reg[0x9A] = 0x0d LSI version:04, OTP version:0c PMU type:RN5T618 register usb cfg[0][1] = 7ff68528 register usb cfg[2][0] = 7ff6c0b0 mcli -- wifi_power_init in uboot -- enter spi boot SF: Detected MX25L1605D with page size 256, total 2 MiB SPI NOR Flash have write protect!!! spi success get_storage_device_flag: store 4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 5 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 device_boot_flag=4 boot_device_flag 0 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: ad de 14 a7 42 4a ad de detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E nand chip ce mask 1 AML_NAND_NEW_OOB : new oob bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 uncorrect ecc here at page:2048, chip:0 blk check good but read failed at chip 0 page 2048 hynix nand get default reg value at blk:8, page:2049 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 96 i=0,register --- nand_key uncorrect ecc here at page:2048, chip:0 nand blk check good but read failed at chip 0 page 2048 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 2 amlnand_phydev_init,1171,phydev->offset=c000000,phydev->size=26000000 amlnand_phydev_init,1171,phydev->offset=32000000,phydev->size=66000000 amlnand_phydev_init,1171,phydev->offset=98000000,phydev->size=168000000 nfcache : offset: 0x00000c000000 -0x000026000000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000032000000 -0x000066000000 : partitons 7 : single_chip multi_plane nfdata : offset: 0x000098000000 -0x000168000000 : partitons 1 : single_chip multi_plane amlnf_logic_init: START amlnf_logic_init: COMPLETE SPI BOOT,spi_env_relocate_spec : env_relocate_spec 64 spi env have been init already, just retun here set_storage_device_flag: store 4 vpu driver detect cpu type: m8 vpu clk_level in dts: 7 set vpu clk: 364300000Hz, readback: 364300000Hz(0x700) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 wipe_data=successful wipe_cache=successful reboot_mode=normal TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done efuse version is not selected. Hit Enter key to stop autoboot -- : 1 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** ** Invalid boot device ** sdio_detect return 1 [mmc_init] SDIO Port B:0, if_type=7, initialized OK! Device: SDIO Port B Manufacturer ID: 0 OEM: 0 Name: Tran Speed: 20000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 63864569856 Boot Part Size: 0 Bus Width: 4-bit reading s805_autoscript 894 bytes read ## Executing script at 11000000 ** Invalid boot device ** reading uEnv.txt 263 bytes read TV mode 1080p selected. mode = 8 vic = 16 set HDMI vic: 16 config HPLL config HPLL done reconfig packet setting done reading /uImage 11341056 bytes read reading /uInitrd 6634592 bytes read reading /dtb/meson8-minix-neo-x8.dtb 20539 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 11340992 Bytes = 10.8 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 6634528 Bytes = 6.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Loading Kernel Image ... OK OK uboot time: 12897174 us. EFUSE machid is not set. Using machid 0xf81 from environment faild to get aml_reserved_end address the default relocate ramdisk and fdt address-relocate_addr: 0x20000000 Loading Ramdisk to 1f9ac000, end 1ffffc20 ... OK Loading Device Tree to 1f9a3000, end 1f9ab03a ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x200 [ 0.000000] Linux version 5.10.0-aml-s812 (root@vbox) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP Sat Dec 26 17:05:01 MSK 2020 [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: MINIX NEO-X8 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 64 MiB at 0x7c000000 [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000200000-0x000000002fffffff] [ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x0000000004efffff] [ 0.000000] node 0: [mem 0x0000000005000000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] percpu: Embedded 16 pages/cpu s35272 r8192 d22072 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521796 [ 0.000000] Kernel command line: root=LABEL=ROOTFS rootfstype=ext4 rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1976468K/2094080K available (17408K kernel code, 1490K rwdata, 4348K rodata, 1024K init, 951K bss, 52076K reserved, 65536K cma-reserved, 1245184K highmem) [ 0.000000] random: get_random_u32 called from cache_random_seq_create+0x7c/0x154 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] irq_meson_gpio: 134 to 8 gpio interrupt mux initialized [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.000000] L2C-310 ID prefetch enabled, offset 8 lines [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 8 ways, 1024 kB [ 0.000000] L2C-310: CACHE_ID 0x4100a0c9, AUX_CTRL 0x7ec80001 [ 0.000003] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000052] Switching to timer-based delay loop, resolution 1000ns [ 0.000371] Console: colour dummy device 80x30 [ 0.000724] printk: console [tty0] enabled [ 0.000760] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000) [ 0.000785] pid_max: default: 32768 minimum: 301 [ 0.000939] LSM: Security Framework initializing [ 0.001084] Smack: Initializing. [ 0.001094] Smack: IPv6 port labeling enabled. [ 0.001219] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.001242] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.001916] CPU: Testing write buffer coherency: ok [ 0.001949] CPU0: Spectre v2: using BPIALL workaround [ 0.002109] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200 [ 0.002635] Setting up static identity map for 0x300000 - 0x300060 [ 0.002752] rcu: Hierarchical SRCU implementation. [ 0.003224] smp: Bringing up secondary CPUs ... [ 0.003756] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201 [ 0.003765] CPU1: Spectre v2: using BPIALL workaround [ 0.004396] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202 [ 0.004405] CPU2: Spectre v2: using BPIALL workaround [ 0.004996] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203 [ 0.005005] CPU3: Spectre v2: using BPIALL workaround [ 0.005097] smp: Brought up 1 node, 4 CPUs [ 0.005115] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.005130] CPU: All CPU(s) started in SVC mode. [ 0.005593] devtmpfs: initialized [ 0.008849] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.009033] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.009063] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.010705] pinctrl core: initialized pinctrl subsystem [ 0.011424] NET: Registered protocol family 16 [ 0.013113] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.013761] thermal_sys: Registered thermal governor 'fair_share' [ 0.013768] thermal_sys: Registered thermal governor 'bang_bang' [ 0.013784] thermal_sys: Registered thermal governor 'step_wise' [ 0.013796] thermal_sys: Registered thermal governor 'user_space' [ 0.014057] cpuidle: using governor menu [ 0.014340] No ATAGs? [ 0.014431] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.014452] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.031709] cryptd: max_cpu_qlen set to 1000 [ 0.104160] raid6: neonx8 gen() 1227 MB/s [ 0.172158] raid6: neonx8 xor() 817 MB/s [ 0.240164] raid6: neonx4 gen() 1482 MB/s [ 0.308159] raid6: neonx4 xor() 1039 MB/s [ 0.376165] raid6: neonx2 gen() 1847 MB/s [ 0.444160] raid6: neonx2 xor() 1235 MB/s [ 0.512162] raid6: neonx1 gen() 1444 MB/s [ 0.580164] raid6: neonx1 xor() 1009 MB/s [ 0.648204] raid6: int32x8 gen() 402 MB/s [ 0.716190] raid6: int32x8 xor() 250 MB/s [ 0.784159] raid6: int32x4 gen() 443 MB/s [ 0.852201] raid6: int32x4 xor() 268 MB/s [ 0.920170] raid6: int32x2 gen() 561 MB/s [ 0.988183] raid6: int32x2 xor() 268 MB/s [ 1.056192] raid6: int32x1 gen() 521 MB/s [ 1.124160] raid6: int32x1 xor() 232 MB/s [ 1.124172] raid6: using algorithm neonx2 gen() 1847 MB/s [ 1.124184] raid6: .... xor() 1235 MB/s, rmw enabled [ 1.124195] raid6: using neon recovery algorithm [ 1.124774] iommu: Default domain type: Translated [ 1.125128] SCSI subsystem initialized [ 1.125404] usbcore: registered new interface driver usbfs [ 1.125445] usbcore: registered new interface driver hub [ 1.125486] usbcore: registered new device driver usb [ 1.125734] pps_core: LinuxPPS API ver. 1 registered [ 1.125749] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.125774] PTP clock support registered [ 1.125806] EDAC MC: Ver: 3.0.0 [ 1.126249] Advanced Linux Sound Architecture Driver Initialized. [ 1.126625] NetLabel: Initializing [ 1.126641] NetLabel: domain hash size = 128 [ 1.126652] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.126710] NetLabel: unlabeled traffic allowed by default [ 1.127122] clocksource: Switched to clocksource timer [ 1.127372] VFS: Disk quotas dquot_6.6.0 [ 1.127428] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.127534] FS-Cache: Loaded [ 1.127692] CacheFiles: Loaded [ 1.133053] NET: Registered protocol family 2 [ 1.133604] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 1.133699] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 1.133765] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.133860] TCP: Hash tables configured (established 8192 bind 8192) [ 1.133940] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.133978] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.134128] NET: Registered protocol family 1 [ 1.134471] RPC: Registered named UNIX socket transport module. [ 1.134489] RPC: Registered udp transport module. [ 1.134500] RPC: Registered tcp transport module. [ 1.134510] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.134653] Trying to unpack rootfs image as initramfs... [ 1.389227] Freeing initrd memory: 6480K [ 1.390127] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available [ 1.392730] Initialise system trusted keyrings [ 1.392855] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 1.396792] DLM installed [ 1.397582] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.398723] NFS: Registering the id_resolver key type [ 1.398763] Key type id_resolver registered [ 1.398776] Key type id_legacy registered [ 1.398854] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.398870] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.399757] FS-Cache: Netfs 'cifs' registered for caching [ 1.400052] Key type cifs.spnego registered [ 1.400074] Key type cifs.idmap registered [ 1.400384] jffs2: version 2.2. (NAND) ¬© 2001-2006 Red Hat, Inc. [ 1.400705] fuse: init (API version 7.33) [ 1.401191] JFS: nTxBlock = 8192, nTxLock = 65536 [ 1.408963] SGI XFS with security attributes, no debug enabled [ 1.410003] NILFS version 2 loaded [ 1.410817] gfs2: GFS2 installed [ 1.475517] NET: Registered protocol family 38 [ 1.475546] xor: measuring software checksum speed [ 1.480665] arm4regs : 1933 MB/sec [ 1.487303] 8regs : 1489 MB/sec [ 1.493432] 32regs : 1610 MB/sec [ 1.500441] neon : 1406 MB/sec [ 1.500453] xor: using function: arm4regs (1933 MB/sec) [ 1.500470] Key type asymmetric registered [ 1.500481] Asymmetric key parser 'x509' registered [ 1.500523] bounce: pool size: 64 pages [ 1.500562] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 1.500579] io scheduler mq-deadline registered [ 1.500590] io scheduler kyber registered [ 1.505312] soc soc0: Amlogic Meson8 (S802) RevC (19 - 0:27ED) detected [ 1.508084] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled [ 1.509663] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 31, base_baud = 8854166) is a meson_uart [ 2.443468] printk: console [ttyAML0] enabled [ 2.449093] usbcore: registered new interface driver udl [ 2.454326] 8<--- cut here --- [ 2.456110] Unhandled fault: imprecise external abort (0x1406) at 0xb6e95d70 [ 2.463130] pgd = (ptrval) [ 2.465817] [b6e95d70] *pgd=00000000 [ 2.469374] Internal error: : 1406 [#1] SMP ARM [ 2.473880] Modules linked in: [ 2.476914] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.0-aml-s812 #trunk [ 2.483934] Hardware name: Amlogic Meson platform [ 2.488615] PC is at lima_pmu_hw_init+0x38/0x64 [ 2.493122] LR is at arm_heavy_mb+0x1c/0x38 [ 2.497283] pc : [<c0bd554c>] lr : [<c0316a40>] psr: 60000013 [ 2.503524] sp : c0277dd8 ip : c20006ac fp : 00000000 [ 2.508725] r10: c2bbb86c r9 : c1b27548 r8 : 00000000 [ 2.513926] r7 : c1b27548 r6 : c2bbb840 r5 : 00000000 r4 : c2bbb86c [ 2.520427] r3 : f0e02000 r2 : 0000ffff r1 : 00000000 r0 : c2bbb86c [ 2.526929] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [ 2.534037] Control: 10c5387d Table: 0020404a DAC: 00000051 [ 2.539757] Process swapper/0 (pid: 1, stack limit = 0x(ptrval)) [ 2.545739] Stack: (0xc0277dd8 to 0xc0278000) [ 2.550074] 7dc0: c2bbb840 00000000 [ 2.558225] 7de0: c2bbb840 c0bd4d08 00000104 c0b7e510 c2f08400 c2bbb86c 00000000 c0b7e838 [ 2.566372] 7e00: c2f08400 00000000 c2bbb840 c291b010 c2f08400 00000000 c1b274f0 00000000 [ 2.574520] 7e20: c1b75000 c0bd4498 c291b010 00000000 c1b274f0 00000000 00000000 c0befadc [ 2.582669] 7e40: c291b010 c1c4d4a4 c1c4d4ac 00000000 00000000 c0bed924 c291b010 c1b274f0 [ 2.590817] 7e60: c1b274f0 c0bede64 00000000 c196dd54 c196dd34 c0bedb58 c291b010 00000000 [ 2.598965] 7e80: c1b274f0 c0bede5c 00000000 c1b274f0 c291b010 c0bedebc c28dd634 c1a12c08 [ 2.607113] 7ea0: c1b274f0 c0bebc3c c196dd54 c2836e58 c28dd634 d8dd3351 c1b281e8 c1b274f0 [ 2.615261] 7ec0: c28dd000 c1b281e8 00000000 c0becc64 c1755a08 ffffe000 c1b274f0 c1b274f0 [ 2.623409] 7ee0: c1a12c08 ffffe000 c192c4c0 c0bee6f8 c1b75000 c1a12c08 ffffe000 c0301734 [ 2.631557] 7f00: c0240823 c03546a8 c183b8dc c1792200 00000000 00000006 00000006 c17ac7cc [ 2.639706] 7f20: 00000000 c1a12c08 c16cecec c16bdbf0 00000000 c0240816 c0240822 d8dd3351 [ 2.647854] 7f40: c1901590 00000007 c183b8dc d8dd3351 c19802a0 c183b8dc 00000007 c0240780 [ 2.656002] 7f60: 000001f4 c1901644 00000006 00000006 00000000 c19003ec c13025d8 c19003ec [ 2.664149] 7f80: 00000000 00000000 c13025d8 00000000 00000000 00000000 00000000 00000000 [ 2.672298] 7fa0: 00000000 c13025e0 00000000 c0300150 00000000 00000000 00000000 00000000 [ 2.680446] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.688594] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 2.696746] [<c0bd554c>] (lima_pmu_hw_init) from [<c0bd4d08>] (lima_device_init+0x208/0x61c) [ 2.705149] [<c0bd4d08>] (lima_device_init) from [<c0bd4498>] (lima_pdev_probe+0x78/0x164) [ 2.713383] [<c0bd4498>] (lima_pdev_probe) from [<c0befadc>] (platform_probe+0x5c/0xb8) [ 2.721358] [<c0befadc>] (platform_probe) from [<c0bed924>] (really_probe+0x1e0/0x3b8) [ 2.729246] [<c0bed924>] (really_probe) from [<c0bedb58>] (driver_probe_device+0x5c/0xb4) [ 2.737394] [<c0bedb58>] (driver_probe_device) from [<c0bede5c>] (device_driver_attach+0x58/0x60) [ 2.746235] [<c0bede5c>] (device_driver_attach) from [<c0bedebc>] (__driver_attach+0x58/0xcc) [ 2.754730] [<c0bedebc>] (__driver_attach) from [<c0bebc3c>] (bus_for_each_dev+0x74/0xb4) [ 2.762879] [<c0bebc3c>] (bus_for_each_dev) from [<c0becc64>] (bus_add_driver+0x1b4/0x1d4) [ 2.771113] [<c0becc64>] (bus_add_driver) from [<c0bee6f8>] (driver_register+0x74/0x108) [ 2.779174] [<c0bee6f8>] (driver_register) from [<c0301734>] (do_one_initcall+0x7c/0x1cc) [ 2.787324] [<c0301734>] (do_one_initcall) from [<c1901644>] (kernel_init_freeable+0x200/0x260) [ 2.795992] [<c1901644>] (kernel_init_freeable) from [<c13025e0>] (kernel_init+0x8/0x11c) [ 2.804140] [<c13025e0>] (kernel_init) from [<c0300150>] (ret_from_fork+0x14/0x24) [ 2.811680] Exception stack(0xc0277fb0 to 0xc0277ff8) [ 2.816709] 7fa0: 00000000 00000000 00000000 00000000 [ 2.824858] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.833006] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 2.839596] Code: e30f2fff e583201c e5935008 f57ff04f (e3550000) [ 2.845669] ---[ end trace 9c7eedcff441c0c6 ]--- [ 2.850259] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 2.857887] CPU3: stopping [ 2.860571] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 5.10.0-aml-s812 #trunk [ 2.868977] Hardware name: Amlogic Meson platform [ 2.873661] [<c030eea0>] (unwind_backtrace) from [<c030a5e0>] (show_stack+0x10/0x14) [ 2.881373] [<c030a5e0>] (show_stack) from [<c12f973c>] (dump_stack+0xc8/0xdc) [ 2.888568] [<c12f973c>] (dump_stack) from [<c030c484>] (do_handle_IPI+0x124/0x158) [ 2.896196] [<c030c484>] (do_handle_IPI) from [<c030c4d0>] (ipi_handler+0x18/0x20) [ 2.903737] [<c030c4d0>] (ipi_handler) from [<c039c25c>] (handle_percpu_devid_irq+0x78/0x138) [ 2.912233] [<c039c25c>] (handle_percpu_devid_irq) from [<c039612c>] (generic_handle_irq+0x34/0x44) [ 2.921247] [<c039612c>] (generic_handle_irq) from [<c03967fc>] (__handle_domain_irq+0x5c/0xb4) [ 2.929915] [<c03967fc>] (__handle_domain_irq) from [<c0ab6780>] (gic_handle_irq+0x70/0x84) [ 2.938238] [<c0ab6780>] (gic_handle_irq) from [<c0300b0c>] (__irq_svc+0x6c/0x90) [ 2.945691] Exception stack(0xc02b3f50 to 0xc02b3f98) [ 2.950721] 3f40: 00000000 00001c40 00000003 c0319b40 [ 2.958870] 3f60: ffffe000 c1a12c54 c1a12c9c 00000008 c1a12c08 00000000 c1988b70 00000000 [ 2.967018] 3f80: c1a12d78 c02b3fa0 c0307648 c030764c 60000013 ffffffff [ 2.973604] [<c0300b0c>] (__irq_svc) from [<c030764c>] (arch_cpu_idle+0x4c/0x50) [ 2.980971] [<c030764c>] (arch_cpu_idle) from [<c1308dd4>] (default_idle_call+0x2c/0x3c) [ 2.989033] [<c1308dd4>] (default_idle_call) from [<c03664f8>] (do_idle+0x1f8/0x284) [ 2.996748] [<c03664f8>] (do_idle) from [<c0366894>] (cpu_startup_entry+0x18/0x1c) [ 3.004289] [<c0366894>] (cpu_startup_entry) from [<00301550>] (0x301550) [ 3.011051] CPU2: stopping [ 3.013737] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 5.10.0-aml-s812 #trunk [ 3.022145] Hardware name: Amlogic Meson platform [ 3.026827] [<c030eea0>] (unwind_backtrace) from [<c030a5e0>] (show_stack+0x10/0x14) [ 3.034541] [<c030a5e0>] (show_stack) from [<c12f973c>] (dump_stack+0xc8/0xdc) [ 3.041735] [<c12f973c>] (dump_stack) from [<c030c484>] (do_handle_IPI+0x124/0x158) [ 3.049364] [<c030c484>] (do_handle_IPI) from [<c030c4d0>] (ipi_handler+0x18/0x20) [ 3.056905] [<c030c4d0>] (ipi_handler) from [<c039c25c>] (handle_percpu_devid_irq+0x78/0x138) [ 3.065400] [<c039c25c>] (handle_percpu_devid_irq) from [<c039612c>] (generic_handle_irq+0x34/0x44) [ 3.074415] [<c039612c>] (generic_handle_irq) from [<c03967fc>] (__handle_domain_irq+0x5c/0xb4) [ 3.083083] [<c03967fc>] (__handle_domain_irq) from [<c0ab6780>] (gic_handle_irq+0x70/0x84) [ 3.091405] [<c0ab6780>] (gic_handle_irq) from [<c0300b0c>] (__irq_svc+0x6c/0x90) [ 3.098859] Exception stack(0xc02b1f50 to 0xc02b1f98) [ 3.103888] 1f40: 00000000 00002260 00000002 c0319b40 [ 3.112038] 1f60: ffffe000 c1a12c54 c1a12c9c 00000004 c1a12c08 00000000 c1988b70 00000000 [ 3.120185] 1f80: 00000001 c02b1fa0 c0307648 c030764c 60000013 ffffffff [ 3.126771] [<c0300b0c>] (__irq_svc) from [<c030764c>] (arch_cpu_idle+0x4c/0x50) [ 3.134139] [<c030764c>] (arch_cpu_idle) from [<c1308dd4>] (default_idle_call+0x2c/0x3c) [ 3.142200] [<c1308dd4>] (default_idle_call) from [<c03664f8>] (do_idle+0x1f8/0x284) [ 3.149915] [<c03664f8>] (do_idle) from [<c0366894>] (cpu_startup_entry+0x18/0x1c) [ 3.157456] [<c0366894>] (cpu_startup_entry) from [<00301550>] (0x301550) [ 3.164218] CPU0: stopping [ 3.166905] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 5.10.0-aml-s812 #trunk [ 3.175312] Hardware name: Amlogic Meson platform [ 3.179995] [<c030eea0>] (unwind_backtrace) from [<c030a5e0>] (show_stack+0x10/0x14) [ 3.187709] [<c030a5e0>] (show_stack) from [<c12f973c>] (dump_stack+0xc8/0xdc) [ 3.194903] [<c12f973c>] (dump_stack) from [<c030c484>] (do_handle_IPI+0x124/0x158) [ 3.202531] [<c030c484>] (do_handle_IPI) from [<c030c4d0>] (ipi_handler+0x18/0x20) [ 3.210073] [<c030c4d0>] (ipi_handler) from [<c039c25c>] (handle_percpu_devid_irq+0x78/0x138) [ 3.218567] [<c039c25c>] (handle_percpu_devid_irq) from [<c039612c>] (generic_handle_irq+0x34/0x44) [ 3.227582] [<c039612c>] (generic_handle_irq) from [<c03967fc>] (__handle_domain_irq+0x5c/0xb4) [ 3.236251] [<c03967fc>] (__handle_domain_irq) from [<c0ab6780>] (gic_handle_irq+0x70/0x84) [ 3.244572] [<c0ab6780>] (gic_handle_irq) from [<c0300b0c>] (__irq_svc+0x6c/0x90) [ 3.252026] Exception stack(0xc1a01ef8 to 0xc1a01f40) [ 3.257055] 1ee0: 00000000 00001ddc [ 3.265206] 1f00: 00000000 c0319b40 ffffe000 c1a12c54 c1a12c9c 00000001 c1a12c08 00000000 [ 3.269042] SMP: failed to stop secondary CPUs [ 3.277773] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b 3- 85833] [<c0300b0c>] (__irq_svc) from [<c030764c>] (arch_cpu_idle+0x4c/0x50) i've tried to update but i've got errors Spoiler root@vegas812:/# sudo apt update Get:1 http://security.debian.org stretch/updates InRelease [53.0 kB] Ign:2 http://httpredir.debian.org/debian stretch InRelease Get:3 http://httpredir.debian.org/debian stretch-updates InRelease [93.6 kB] Get:4 http://httpredir.debian.org/debian stretch-backports InRelease [91.8 kB] Hit:5 http://httpredir.debian.org/debian stretch Release Get:7 http://security.debian.org stretch/updates/main armhf Packages [784 kB] Err:6 https://uk.mirrors.fossho.st/armbian/apt stretch InRelease Connection timed out after 120001 milliseconds Fetched 1023 kB in 2min 0s (8483 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://apt.armbian.com/dists/stretch/InRelease Connection timed out after 120001 milliseconds W: Some index files failed to download. They have been ignored, or old ones used instead. root@vegas812:/# cat /etc/apt/sources.list deb http://httpredir.debian.org/debian stretch main contrib non-free #deb-src http://httpredir.debian.org/debian stretch main contrib non-free deb http://httpredir.debian.org/debian stretch-updates main contrib non-free #deb-src http://httpredir.debian.org/debian stretch-updates main contrib non-free deb http://httpredir.debian.org/debian stretch-backports main contrib non-free #deb-src http://httpredir.debian.org/debian stretch-backports main contrib non-free deb http://security.debian.org/ stretch/updates main contrib non-free #deb-src http://security.debian.org/ stretch/updates main contrib non-free # add test repo #deb http://ftp.de.debian.org/debian testing main contrib non-free
