SteeMan 78 Posted January 18 Share Posted January 18 The following template should be used to report a working TV Box running Armbian. The purpose of this template is to gather consistent and complete information. To submit a report of a working TV Box start a new topic in this sub-forum with the name of the TV box as the title and copy/paste this template into the post and provide the requested information. Note: Only report status using dtb files that are part of the image and therefore available to all users from a standard source. If you have used another dtb file, please mention that in the comments along with where the source code for the dtb is located and what the custom dtb improved. Note: You will need to install/enable a desktop environment to gather all of the below information (i.e. hdmi audio) TV Box Status Information Template Version 1.0 TV Box Name (example: TX3 mini): CPU (example: amlogic s905w): Armbian build file name: DTB file used: Kernel Version: Distribution Installed (focal, buster, etc): Working Ethernet (Yes/No): Max Ethernet Speed that works (100/1000): Does wifi work (Yes/No): Does bluetooth work (Yes/No): Does HDMI audio work (Yes/No): Additional Comments (provide any additional information you feel is important): Link to post Share on other sites
