Armbianmonitor:
first post here, so sorry if did not provide enough information. I need to change spi buffer length to 8192. So far tried:
1) modprobe spidev bufsiz=8192
creating the file /etc/modprobe.d/spidev.conf and adding to it the line "options spidev bufsiz=8192"
When I do "cat /sys/module/spidev/parameters/bufsiz", it gives me "4096".
2) Add to /boot/cmdline.txt:
spidev.bufsiz=8192
3) cd /sys/module/spidev/parameters
chmod 666 bufsiz
echo 65536  > bufsiz
did nothing.
4) /boot/armbianEnv.txt
added options spidev bufsiz=8192
I don't know anything else what to try. Is it possible.
Also facing SPI issues.  Trying to flash my laptop using a soic clip connected to spidev1.0 as well as Mizy on spidev0.0. Unlike some others in the forum I was able to activate both successfully. After using flashrom, however, my flashed laptop or orange pi zero won't boot from the SPI chip yet.
My armbianEnv.txt:
verbosity=1
bootlogo=false
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=spi-jedec-nor spi-spidev usbhost2 usbhost3
param_spidev_spi_bus=0
param_spidev_spi_cs=0
param_spidev_max_freq=1000000
rootdev=UUID=9f347494-581e-4ce3-8848-05016ce8b9c9
rootfstype=ext4
user_overlays=spi-double-spidev-cs
My report from flashrom:
$ sudo flashrom -p linux_spi:dev=/dev/spidev1.0,spispeed=512 -w /home/hardheid/Lenovo_T460_backup.bin
flashrom on Linux 5.10.12-sunxi (armv7l)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on linux_spi.
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Verifying flash... VERIFIED.
Same with the Mizy images, write but not working in the end. Could this be the result of a bad buffer? Am I doing something wrong?
Hi.
Have you found a solution for you spidedv buffer size issue? I am facing the same problem with nothing to be found online...
Thanks
