Board won't boot after enabling SPI interface
Go to solution Solved by thc013,
Hello !
i'm trying to enable the SPI interface on a OrangePi4B board using Focal latest stable build, so I edit `/boot/armbianEnv.txt` to add these lines :
overlays=spi-spidev
param_spidev_spi_bus=0
But after rebooting, I'm unable to access to the board anymore (No IP address is assigned to the board by the DHCP server).
What's wrong ?
Is there any additionnal steps ?
FYI, I also tried to enable SPI using armbian-config tool but it doesn't work neither. As this tool doesn't even specify the `param_spidev_spi_bus` parameters which is required according to the overlay README.
Edited by Falcounet
add build info
  • Solution
overlays=spi-spidev
param_spidev_spi_bus=1
or
overlays=spi-spidev spi-add-cs1
param_spidev_spi_cs=0
spidev is 1
installed wiringop ?
 19 mosi
 21 miso                        22 ce  (my configuration) (gpio pin 56 with wiringop)
 23 clk                           24 cs
so for example my spidev setting in nrf24
radio = RF24(56, 10)
and for exampe mysensors
 ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=rf24 --my-rf24-ce-pin=56 --my-rf24-cs-pin=42 --my-rf24-irq-pin=55
but there indeed a error in the dmesg for spi in 5.10.10 but it works tested with a nrf24 module
