1N4148 Posted February 1, 2021 Posted February 1, 2021 Armbianmonitor: http://ix.io/2NXI Hi, I'm getting a random packet loss on the ethernet connection. When pinging, about 6-8% pings are lost, the ssh connection sometimes freezes for a moment. Things I've tried so far: Disabled NetworkManager, added eth0 in /etc/network/interfaces with a static ip4 address Disabled EEE for eth0 Replaced ethernet cable Plugged into different switch None of them made something better. My C1 & C4 with the same Armbian Buster version/release don't have this issue. How to investigate deeper in this issue?
tparys Posted February 2, 2021 Posted February 2, 2021 Might be worth trying to isolate the problem to hardware or software? Maybe try a build from HardKernel and see if you can reproduce the fault? If you're still having the issue, there may be something wrong with your board. If you can't reproduce the fault, maybe try one of the older images and see if there's different behavior? May help to point at something that's changed? https://armbian.hosthatch.com/archive/odroidc2/archive/
