Trongle S3 no signal, no anything
Joe Foster
Anyone else ever get just a blank screen? I’m trying to install onto a Trongle S3 box. I’ve tried a number of dtb’s but as it’s a relatively rear box nothing is definite. Tried to match them by spec but hoped it would at least register an output on my monitor.
I get a no signal notification.
I will be trying to tty the com port but this includes soldering so wanted to see if anyone else knew of a possible solution before I spent time doing this.
Link to comment
Share on other sites
Moved post to the correct forum.  If you want help, please provide information on what exactly you have tried, what build you are working with, what dtb's you have tried, what installation steps you are following, etc.  Also please read the following post to set proper expectations: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
Link to comment
***APOLOGIES FOR DELAY, LIMIT ON HOW MANY TIMES I CAN POST PER 24 HOURS***
I've managed to connect via TTL EEPROM connection and am getting the below. I'm using the meson-gxl-s905x-p212.dtb dtb file. With the "Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img" image.
Is "fdt_instaboot: no instaboot image" causing the issue?
Any advice is much appreciated.
Courtesy note: any one else using this the ttl speed is 115200.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.02.19 22:27:47 =~=~=~=~=~=~=~=~=~=~=~=
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 150401
BL2 Built : 13:48:56, Sep 23 2016.
gxl g7459bd4 - jianxin.pan@droid06
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 1
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 912MHz - PASS
Rank0: 1024MB(auto)-2T-13
Rank1: 1024MB(auto)-2T-13
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00015400
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x000a9a00
NOTICE:  BL3-1: v1.0(debug):2e39a99
NOTICE:  BL3-1: Built : 16:36:21, Sep 20 2016
aml log : bl31 normal boot !
[Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05]
OPS=0x82
e0 64 25 87 a7 56 28 f 21 20 68 3f [0.390607 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-gdd4a4de (Mar 03 2017 - 18:35:08)
DRAM:  2 GiB
Relocation Offset is: 76ec9000
register usb cfg[0][1] = 0000000077f5f500
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000073ec96b0
aml_priv->desc_buf = 0x0000000073ecb9d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 2 dtbs.
        aml_dt soc: gxl platform: p212 variant: 2g
        dtb 0 soc: gxl   plat: p212   vari: 1g
        dtb 1 soc: gxl   plat: p212   vari: 2g
      Find match dtb: 1
start dts,buffer=0000000073ece270,dt_addr=0000000073ed8270
parts: 11
00:      logo    0000000002000000 1
01:  recovery    0000000002000000 1
02:       rsv    0000000000800000 1
03:       tee    0000000000800000 1
04:     crypt    0000000002000000 1
05:      misc    0000000002000000 1
06: instaboot    0000000020000000 1
07:      boot    0000000002000000 1
08:    system    0000000080000000 1
09:     cache    0000000020000000 2
10:      data    ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          20000000                  2
   3: env                         27400000            800000                  0
   4: logo                        28400000           2000000                  1
   5: recovery                    2ac00000           2000000                  1
   6: rsv                         2d400000            800000                  1
   7: tee                         2e400000            800000                  1
   8: crypt                       2f400000           2000000                  1
   9: misc                        31c00000           2000000                  1
  10: instaboot                   34400000          20000000                  1
  11: boot                        54c00000           2000000                  1
  12: system                      57400000          80000000                  1
  13: data                        d7c00000         2c5400000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x27400000
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
hpd_state=0
cvbs performance type = 6, table = 0
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
Net:   dwmac.c9410000
wipe_data=successful
wipe_cache=successful
upgrade_step=2
[OSD]load fb addr from dts
[OSD]failed to get fb addr for logo
[OSD]use default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=5760, height=2160
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
get_cpu_id flag_12bit=1
SARADC open channel(0).
SARADC channel(0) is 0x3ef, Out of range(0x0~0x50)!
saradc - saradc sub-system
Usage:
saradc saradc open <channel>        - open a SARADC channel
saradc close    - close the SARADC
saradc getval    - get the value in current channel
saradc get_in_range <min> <max>    - return 0 if current value in the range of current channel
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  1 0
card in
Device: SDIO Port B
Manufacturer ID: 3
OEM: 3456
Name: ASTCTran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.5 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading s905_autoscript
1351 bytes read in 5 ms (263.7 KiB/s)
## Executing script at 01020000
start amlogic old u-boot
reading boot_android
** Unable to read file boot_android **
** Bad device usb 0 **
reading u-boot.ext
** Unable to read file u-boot.ext **
reading uEnv.txt
1157 bytes read in 4 ms (282.2 KiB/s)
mac=42:f2:9e:a9:91:c3
reading /zImage
23357952 bytes read in 1295 ms (17.2 MiB/s)
reading /uInitrd
11037395 bytes read in 615 ms (17.1 MiB/s)
reading /dtb/amlogic/meson-g12b-odroid-n2.dtb
47774 bytes read in 9 ms (5.1 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
[rsvmem] bl31 reserved memory set addr error.
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    11037331 Bytes = 10.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
      Single dtb detected
load dtb from 0x1000000 ......
## Flattened Device Tree blob at 01000000
   Booting using the fdt blob at 0x1000000
   Loading Ramdisk to 7342f000, end 73eb5a93 ... OK
   Loading Device Tree to 000000001fff1000, end 000000001ffffa9d ... OK
signature:
Starting kernel ...
uboot time: 4530887 us
Link to comment
