TV Box Name: V96 Mini
CPU: H6
Armbian build file name: Armbian_21.02.0-trunk_Aw-h6-tv_focal_current_5.10.17_210218
DTB file used: sun50i-h6-tanix-tx6.dtb
Kernel Version: 5.10.17
Distribution Installed: focal
Working Ethernet: Yes
Max Ethernet Speed that works: 100
Does wifi work: Yes
Does bluetooth work: not tested
Does HDMI audio work: Yes
Additional Comments:
Did you just write the image to an SD card and booted from it or are there other tricks to boot ?
Are you also able to write the image to the onboard storage ?
