H96 Pro Plus (Green PCB version)
mazdlc
TV Box Name : H96 Pro Plus (Green PCB version)
CPU : Amlogic S912
Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0.img
DTB file used: meson-gxm-q200.dtb (no wifi/bluetooth/hdmi audio with distributed one, need modification, see below)
Kernel Version: 5.9.0-arm-64
Distribution Installed: focal
Working Ethernet: Yes
Max Ethernet Speed that works: 1000
Does wifi work: Yes
Does bluetooth work: Yes
Does HDMI audio work: Yes
Additional Comments:
modified dtbhttps://github.com/maz-1/h96-pro-plus-armbian-stuff
almost everything works except buggy gpu support. The kernel crashes when opengl programs (like glxgears) terminates, and low fps.
Link to comment
Share on other sites
@mazdlc  Thanks.  Would it be possible to create a patch/diff between your dts modifications and those in the mainline kernel source tree?  And then post that either here or in your github?  That way as the code evolves others could easily pick up your work and port it to newer kernels if necessary in the future.
Link to comment
Sure, I have updated patch and Readme.
Link to comment
Update: I managed to get hdmi audio working.
Link to comment
Thank you for this modification. I tried to install it in two TV Boxes with s912 (H96 Pro plus , Beelink GT1) but on both i got the a halt on the kernel with message
random: crng init done
I read in this post https://forums.raspberrypi.com/viewtopic.php?t=255371#p1558598 that replacing the root with dev/sda2 in the cmdline.txt  file should do the trick.
Unfortunately this file does not seem to exist in the armbian images . Any ideas ?
Edited by Alarm
Link to comment
