malaga Posted March 15, 2021 Posted March 15, 2021 hi dear community i have a system runningv on banana pi and i want to update this see what is currently running martin@bananapi:~$ l^C martin@bananapi:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.1 LTS Release: 18.04 Codename: bionic martin@bananapi:~$ look forward to hear from you by the way - how to find out which banana pi am on !?
manuti Posted March 16, 2021 Posted March 16, 2021 I updated from Debian Strech to Buster following the instruction from this post, also in a Banana Pi. I suppose you can move from 18.04 to 20.04 with caveats in the way. I perform an image backup from the microSD before doing anything.
malaga Posted March 16, 2021 Author Posted March 16, 2021 martin@bananapi:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.1 LTS Release: 18.04 Codename: bionic martin@bananapi:~$ cat /sys/firmware/devicetree/base/compatible lemaker,bananapiallwinner,sun7i-a20martin@bananapi:~$
malaga Posted March 16, 2021 Author Posted March 16, 2021 hello dear Manuti was reading out board with the usage of devicetree a kernel using this (most arm/arm64) cat /sys/firmware/devicetree/base/compatible in my case it shows lemaker,bananapiallwinner,sun7i-a20martin@bananapi:~$ well what to do if i want to do a fresh os based on Armbian ?!
manuti Posted March 18, 2021 Posted March 18, 2021 I don't understand your question. But you can change the kernel using `armbian-config` tool and after that change repos from Bionic to Focal. With something like this (CAVEATS THAT IS NOT TESTED BY ME) : cp /etc/apt/sources.list /etc/apt/sources.list.backup sed -i 's|bionic|focal|g' /etc/apt/sources.list apt update && apt -y upgrade && apt -y dist-upgrade
