[Info] create SSH-Login for a serial device (here Z80-MBC2) using ser2net and a local User
The Z80-MBC2 is a 4-chip Z80-computer which can run CP/M and has a 5V TTL-serial-port.
The Z80-MBC2 is powered and accessable via a USB-TTL-serial-adapter (configured to 5V - not 3.3V) type CP2102 seen as /dev/ttyUSB0
The easy way would be to connect the USB-adapter to a Pi-style computer wth armbian, login via SSH and start minicom for the port.
But that way doenst look as good - to me - as the following way ;)
First we need to install ser2net and telnet (telnet doesnt seem to be installed as standard) in armbian via
apt install ser2net telnet
Then we have to edit /etc/ser2net.conf (delete all lines after the comments and insert these):
BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
BANNER:z80mbc2:\r\nZ80-MBC2 via Telnet on Port [\p]\r\nDevice connected to         [\d]\r\nConnection Speed            [\s]\r\n
# 2000:telnet:600:/dev/ttyS0:9600 8DATABITS NONE 1STOPBIT banner
# 2001:telnet:600:/dev/ttyS1:9600 8DATABITS NONE 1STOPBIT banner
# 3000:telnet:600:/dev/ttyS0:19200 8DATABITS NONE 1STOPBIT banner
# 3001:telnet:600:/dev/ttyS1:19200 8DATABITS NONE 1STOPBIT banner
127.0.0.1,2023:telnet:0:/dev/ttyUSB0:115200 8DATABITS NONE 1STOPBIT z80mbc2
Now create a login "shell"/pogram for the new local user z80mbc2 as /usr/local/bin/z80mbc2 :
#!/bin/sh
/usr/bin/telnet 127.0.0.1 2023
exit
Do a chmod 755  /usr/local/bin/z80mbc2
Now we can create the new local user z80mbc2 as seen on
http://www.lug-wr.de/wiki/index.php/Howto:Network:SerialConsoleServer
adduser --shell /usr/local/bin/z80mbc2.sh -q z80mbc2
If you havent done - connect your TTL-USB-Dongle to your SBC - and it should show up as /dev/ttyUSB0 :
[354660.047087] usb 7-1: Product: CP2102 USB to UART Bridge Controller
[354660.047099] usb 7-1: Manufacturer: Silicon Labs
[354660.047109] usb 7-1: SerialNumber: 0001
[354660.112318] usbcore: registered new interface driver usbserial_generic
[354660.112414] usbserial: USB Serial support registered for generic
[354660.131499] usbcore: registered new interface driver cp210x
[354660.131617] usbserial: USB Serial support registered for cp210x
[354660.131902] cp210x 7-1:1.0: cp210x converter detected
[354660.141405] usb 7-1: cp210x converter now attached to ttyUSB0
Now its time to reboot your SBC (I used my NanoPi K1 Plus) via
reboot
to automatically let start ser2net-service while booting
Now when you connect to your SBC via SSH and use the z80mbc2 User to login, you should generate a automatic and local (127.0.0.1) telnet-login to Port 2023 where /dev/ttyUSB0 a.k.a the Z80-MBC2 device is configured.
PS: other (german) interesting Page about ser2net:
http://www.nwlab.net/tutorials/ser2net/konsolenserver-linux.html
Z80-MBC2_SSH_Ser2Net.zipFetching info...
Edited by guidol
added 127.0.0.1 - only localhost - to port 2023
If you want to use a "real" Terminal - instead of SSH / Ser2Net- like the TTGO VGA32 FabGL ANSI-Terminal and you dont have a 3.3V <-> 5.0V logic level converter available then using the NanoPi K1 Plus (or any other armbian device with 2 USB-ports) as a "mediator" may be possible using the "socat"-command ;)
To use socat we should disable (disable for every boot or stop until the next boot) the ser2net service:
Usage: /etc/init.d/ser2net {start|stop|restart|reload|force-reload|status}
sudo service ser2net restart
sudo service ser2net stop
sudo service ser2net start
sudo systemctl disable ser2net
sudo systemctl enable ser2net
We do connect 2 USB-TTL-serial-Adapters to the SBC (one for 3.3V TTL-Level and one for 5V TTL-Level).
Via software (socat = apt install socat) we tie them together:
socat /dev/ttyUSB0,raw,echo=0,crnl,b115200 /dev/ttyUSB1,raw,echo=0,crnl,b115200
For the correct backspace-function the FabGL-ANSI-Terminal has to be in "ANSI Legacy"-Mode, because in normal "ANSI"-Mode the backspace-key doenst work right with the output of the Z80-MBC2 ;)
Expand
In the newer version of ser2net (like v4.3.3-1) the /etc/ser2net.conf is replaced
by the /etc/ser2net.yaml which has the yaml-format :(
OK - here is a working version in yaml-format:
# A fully featured configuration file is in
# /usr/share/doc/ser2net/examples/ser2net.yaml
define: &banner \r\nZ80-MBC2 via Telnet on Port [\p]\r\nDevice connected to         [\d]\r\n
connection: &z80mbc2
    accepter: telnet(rfc2217),tcp,2023
    enable: on
    options:
      banner: *banner
      kickolduser: true
      telnet-brk-on-sync: true
    connector: serialdev,
              /dev/ttyUSB0,
              115200n81,local
