mss Posted March 21, 2021 Share Posted March 21, 2021 I just build the build the driver for my RTL8188FTV that supported by rtl8188fu. It works as wifi hot spot but has some problems with nmcli . I share what is done and I hope it be useful for others. 0. Install dkms , make and git: apt install dkms make git 1. Remove any existing source and dkms config for module : dkms remove rtl8188fu/1.0 --all rm -f /lib/firmware/rtlwifi/rtl8188fufw.bin rm -f /etc/modprobe.d/rtl8188fu.conf rm -r /var/lib/dkms/rtl8188fu 2. Get current kernel version and install matching headers: uname -a My results are: Linux orangepipc 5.10.21-sunxi #21.02.3 SMP Mon Mar 8 00:28:04 UTC 2021 armv7l GNU/Linux so my matching kernel headers package would be `linux-headers-current-sunxi=21.02.3` . You might replace `sunxi` and `21.02.3` depending on your top results. I installed it by specifying version: apt install linux-headers-current-sunxi=21.02.3 3. Make kernels headers scripts: cd /usr/src/linux-headers-$(uname -r) make scripts 4. Clone arm branch from driver repository: git clone -b arm https://github.com/kelebek333/rtl8188fu rtl8188fu-arm 5. Disable power saving in make config. find and replace this variable in `./rtl8188fu-arm/Makefile` and set as below: CONFIG_POWER_SAVING = n CONFIG_WIFI_MONITOR = y 6. Build and install driver: ln -s /lib/modules/$(uname -r)/build/arch/arm /lib/modules/$(uname -r)/build/arch/armv7l dkms add ./rtl8188fu-arm dkms build rtl8188fu/1.0 dkms install rtl8188fu/1.0 cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ # Known problems : - ` nmcli dev wifi list` not works. Refrences: - https://github.com/kelebek333/rtl8188fu/tree/arm#how-to-install-for-arm-devices - https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver - https://forum.armbian.com/topic/13628-help-me-to-setup-a-wifi-ap-via-command-line/?do=findComment&comment=104106 - https://github.com/ulli-kroll/rtl8188fu - https://askubuntu.com/a/1131265/483814 - https://github.com/brektrou/rtl8821CU#arm-architecture-tweak-for-this-driver-this-solves-compilation-problem-of-this-driver 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 21, 2021 Share Posted March 21, 2021 Does the module loads if you modprobe it ? 0 Quote Link to comment Share on other sites More sharing options...
mss Posted March 21, 2021 Author Share Posted March 21, 2021 It should be loaded correctly `modprobe rtl8188fu` doesn't return anything and it works as hotspot. 0 Quote Link to comment Share on other sites More sharing options...
VyacheslavS Posted February 3, 2022 Share Posted February 3, 2022 I tested this method on Orange Pi PC2 (Armbian 21.08 Focal). ~:% uname -a Linux orangepipc2 5.10.60-sunxi64 #21.08.1 SMP Wed Aug 25 18:29:57 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux The instructions have a small clarification for the aarch64 architecture. The symlink must be like this to install the driver: sudo ln -s /lib/modules/$(uname -r)/build/arch/arm64 /lib/modules/$(uname -r)/build/arch/aarch64 The driver is installed and works well. 0 Quote Link to comment Share on other sites More sharing options...
Dave Mullen Posted October 28, 2022 Share Posted October 28, 2022 Note in the last line, it should read cp ./rtl8188fu-arm/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ 0 Quote Link to comment Share on other sites More sharing options...
Nasko Posted November 16, 2023 Share Posted November 16, 2023 Successfully installed on cubietruck: Details are: dmesg snip: [ 12.218407] usb 3-1: New USB device found, idVendor=0bda, idProduct=f179, bcdDevice= 0.00 [ 12.218447] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 12.218461] usb 3-1: Product: 802.11n [ 12.218472] usb 3-1: Manufacturer: Realtek [ 12.218483] usb 3-1: SerialNumber: 00e04c000001 lsusb: Bus 003 Device 002: ID 0bda:f179 Realtek Semiconductor Corp. RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter 0 Quote Link to comment Share on other sites More sharing options...
