vmiceli Posted April 2, 2021 Posted April 2, 2021 Hello folks, I have completed my Armbian NTP server based on the wonderful little NanoPi Neo3. However something bothers me a bit, i.e. how much delay or latency is in eth0 (It is a 1Gbs port). By checking the default eth0 settings (ethtool -c eth0) I have the parameters below. In particular rx-usec = 327usec means that when a packet is received, the IRQ to alert the CPU can be delayed up to 327usec. With these settings on the nanopi (NTP server) I get about 1msec delay on the NTP client (Windows PC). By cutting the rx-usecs to 35 usecs I get a delay on the client of about 450usec, so a massive improvement and 30% faster than rpi 4. At the moment, in order to change this parameter after boot, I have the two lines below into /etc/rc.local, the delay is needed as the command may be issued before eth0 is ready to accept it (I found this the hard way): sleep 10 sudo ethtool -C eth0 rx-usecs 35 The question: Is there a place where those eth0 defaults are saved? If there is a config file somewhere or even in the Kernel (I can re-build it) I could change them to a new default and avoid the rc.local hassle and delay. I guess I like a leaner approach :-) Thanks! Enzo root@nanopineo3:~# ethtool -c eth0 Coalesce parameters for eth0: Adaptive RX: off TX: off stats-block-usecs: 0 sample-interval: 0 pkt-rate-low: 0 pkt-rate-high: 0 rx-usecs: 327 rx-frames: 0 rx-usecs-irq: 0 rx-frames-irq: 0 tx-usecs: 100 tx-frames: 25 tx-usecs-irq: 0 tx-frames-irq: 0 1
lanefu Posted April 2, 2021 Posted April 2, 2021 great find.... not sure if that's sysctl setting or a module parameter... would be interesting to find the origin of the default value.. or whether that's dynamically adjusted otherwise. if you do figure it out.. we do keep various optimizations here https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization
