Beelink GT1 Mini TV Box - DTB file?
MoA
Hello all,
I need some help.
I have a Beelink GT1 Mini TV Box 64GB Gigabit Lan 4 GB Ram.
I use this stock firmware: v007P0 stock firmware LPDDR4 version (SN: 95X2) for Beelink GT1 Mini TV Box from here.
https://beelink-my.sharepoint.com/:u:/g/personal/firmwareservice_beelink_onmicrosoft_com/EQ8GFfRPJopFoKLfJt71qyMB7ZuofgTb_L3_VW3CHO2g2g?e=Hq70yf
https://chinagadgetsreviews.com/download-android-pie-9-v007p0-stock-firmware-for-beelink-gt1-mini-tv-box.html
I am trying to flash Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz using the meson-g12a-gt1-mini-a but I get the error here-below:
I have tried all other meson-g12a with same result
Is it because it has LPDDR4 instead of DDR4 ?
Anything I can do to make it work??
Supported API: 3
charge_status 2, charged 1, status SUCCAESS, capacity 100
Finding update package
Opening update package
E: Block map file too short: 3
E: Map of '@/cache/recovery/block.map' failed
E: failed to map file
Installation aborted
Thanks a lot in advance for your help,
MoA,
Cheers,
Link to comment
Share on other sites
Order Armbian Linux merch!
Thanks!
I followed a different guide which told me to use the "update software" to load the autoscript.sh (this method actually works for my Vorke S912 Z6 Plus).
For the S905x2 Beelink GT1 Mini --> It seems that we have to use the toothpick method!
Cheers and thanks again.
Link to comment
I'm trying to flash a GT1 Ultimate and i seam to be getting stuck at a flashing beelink logo.
Changed the extlinux.conf to use the gt1 instead and copyed the gt1 file to the root and renamed it.
But the only thing i keep getting is the logo as i plug the power on and then goes away and then some times shows up again in the screen.
But that's mainly it...
Any tips?
Using
Armbian_20.10_Arm-64_bullseye_current_5.9.0.img.xz
Link to comment
On 8/3/2021 at 7:54 PM, SteeMan said:
@RicardoSA What instructions are you following?  No current instructions have a step that requires you to copy any file to root.  Look at the instructions in the FAQ section of the TV box forum.
Was doing a mix of the old way and the way of that method you mentioned :D read properly and it worked just fine thank you
Link to comment
