Arne Hübner Posted April 16, 2021 Posted April 16, 2021 Armbianmonitor: http://ix.io/2WJG 1 2 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 3 4 ### Activated Armbian ramlog partition with zstd compression 5 6 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 7 8 ### Activated Armbian ramlog partition with zstd compression 9 10 Sun 28 Mar 2021 04:42:10 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 11 12 ### dmesg: 13 14 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 15 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 16 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 17 [ 0.000000] efi: UEFI not found. 18 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 19 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 20 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 21 [ 0.000000] NUMA: No NUMA configuration found 22 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 23 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 24 [ 0.000000] Zone ranges: 25 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 26 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 27 [ 0.000000] Normal empty 28 [ 0.000000] Movable zone start for each node 29 [ 0.000000] Early memory node ranges 30 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 31 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 32 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 33 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 34 [ 0.000000] On node 0 totalpages: 972800 35 [ 0.000000] DMA zone: 4096 pages used for memmap 36 [ 0.000000] DMA zone: 0 pages reserved 37 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 38 [ 0.000000] DMA32 zone: 11104 pages used for memmap 39 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 40 [ 0.000000] psci: probing for conduit method from DT. 41 [ 0.000000] psci: PSCIv1.0 detected in firmware. 42 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 43 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 44 [ 0.000000] psci: SMC Calling Convention v1.1 45 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 46 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 47 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 48 [ 0.000000] Detected VIPT I-cache on CPU0 49 [ 0.000000] CPU features: detected: ARM erratum 845719 50 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 51 [ 0.000000] Policy zone: DMA32 52 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 53 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 54 Please use sysfs to set IO scheduler for individual devices. 55 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 56 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 57 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 58 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 59 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 60 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 61 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 62 [ 0.000000] rcu: RCU event tracing is enabled. 63 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 64 [ 0.000000] Trampoline variant of Tasks RCU enabled. 65 [ 0.000000] Rude variant of Tasks RCU enabled. 66 [ 0.000000] Tracing variant of Tasks RCU enabled. 67 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 68 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 69 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 70 [ 0.000000] GIC: Using split EOI/Deactivate mode 71 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 72 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 73 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 74 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 75 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 76 [ 0.000251] Console: colour dummy device 80x25 77 [ 0.000285] printk: console [tty1] enabled 78 [ 0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 79 [ 0.000387] pid_max: default: 32768 minimum: 301 80 [ 0.000470] LSM: Security Framework initializing 81 [ 0.000496] Yama: becoming mindful. 82 [ 0.000587] AppArmor: AppArmor initialized 83 [ 0.000637] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 84 [ 0.000656] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 85 [ 0.002650] rcu: Hierarchical SRCU implementation. 86 [ 0.005148] EFI services will not be available. 87 [ 0.005570] smp: Bringing up secondary CPUs ... 88 [ 0.006243] Detected VIPT I-cache on CPU1 89 [ 0.006304] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 90 [ 0.007500] CPU features: detected: ARM erratum 858921 91 [ 0.007510] CPU features: detected: Spectre-v2 92 [ 0.007513] CPU features: detected: Spectre-v4 93 [ 0.007520] Detected VIPT I-cache on CPU2 94 [ 0.007544] arch_timer: Enabling local workaround for ARM erratum 858921 95 [ 0.007559] arch_timer: CPU2: Trapping CNTVCT access 96 [ 0.007572] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 97 [ 0.008280] Detected VIPT I-cache on CPU3 98 [ 0.008296] arch_timer: Enabling local workaround for ARM erratum 858921 99 [ 0.008303] arch_timer: CPU3: Trapping CNTVCT access 100 [ 0.008311] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 101 [ 0.008936] Detected VIPT I-cache on CPU4 102 [ 0.008952] arch_timer: Enabling local workaround for ARM erratum 858921 103 [ 0.008960] arch_timer: CPU4: Trapping CNTVCT access 104 [ 0.008967] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 105 [ 0.009581] Detected VIPT I-cache on CPU5 106 [ 0.009598] arch_timer: Enabling local workaround for ARM erratum 858921 107 [ 0.009605] arch_timer: CPU5: Trapping CNTVCT access 108 [ 0.009614] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 109 [ 0.009696] smp: Brought up 1 node, 6 CPUs 110 [ 0.009713] SMP: Total of 6 processors activated. 111 [ 0.009721] CPU features: detected: 32-bit EL0 Support 112 [ 0.009727] CPU features: detected: CRC32 instructions 113 [ 0.009733] CPU features: detected: 32-bit EL1 Support 114 [ 0.020996] CPU: All CPU(s) started at EL2 115 [ 0.021045] alternatives: patching kernel code 116 [ 0.023048] devtmpfs: initialized 117 [ 0.030738] Registered cp15_barrier emulation handler 118 [ 0.030752] Registered setend emulation handler 119 [ 0.030892] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 120 [ 0.030931] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 121 [ 0.046222] pinctrl core: initialized pinctrl subsystem 122 [ 0.046949] DMI not present or invalid. 123 [ 0.047318] NET: Registered protocol family 16 124 [ 0.048878] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 125 [ 0.049153] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 126 [ 0.049384] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 127 [ 0.049428] audit: initializing netlink subsys (disabled) 128 [ 0.049548] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 129 [ 0.050799] thermal_sys: Registered thermal governor 'fair_share' 130 [ 0.050806] thermal_sys: Registered thermal governor 'bang_bang' 131 [ 0.050810] thermal_sys: Registered thermal governor 'step_wise' 132 [ 0.050814] thermal_sys: Registered thermal governor 'user_space' 133 [ 0.051255] cpuidle: using governor menu 134 [ 0.051603] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 135 [ 0.051724] ASID allocator initialised with 65536 entries 136 [ 0.052767] Serial: AMBA PL011 UART driver 137 [ 0.088041] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 138 [ 0.088051] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 139 [ 0.088055] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 140 [ 0.088059] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 141 [ 0.090039] cryptd: max_cpu_qlen set to 1000 142 [ 0.160228] raid6: neonx8 gen() 2780 MB/s 143 [ 0.228281] raid6: neonx8 xor() 2042 MB/s 144 [ 0.296330] raid6: neonx4 gen() 3153 MB/s 145 [ 0.364387] raid6: neonx4 xor() 2399 MB/s 146 [ 0.432465] raid6: neonx2 gen() 2538 MB/s 147 [ 0.500517] raid6: neonx2 xor() 2136 MB/s 148 [ 0.568591] raid6: neonx1 gen() 1964 MB/s 149 [ 0.636642] raid6: neonx1 xor() 1722 MB/s 150 [ 0.704712] raid6: int64x8 gen() 1374 MB/s 151 [ 0.772778] raid6: int64x8 xor() 735 MB/s 152 [ 0.840851] raid6: int64x4 gen() 1463 MB/s 153 [ 0.908895] raid6: int64x4 xor() 733 MB/s 154 [ 0.976972] raid6: int64x2 gen() 1363 MB/s 155 [ 1.045026] raid6: int64x2 xor() 619 MB/s 156 [ 1.113093] raid6: int64x1 gen() 1127 MB/s 157 [ 1.181148] raid6: int64x1 xor() 462 MB/s 158 [ 1.181151] raid6: using algorithm neonx4 gen() 3153 MB/s 159 [ 1.181155] raid6: .... xor() 2399 MB/s, rmw enabled 160 [ 1.181159] raid6: using neon recovery algorithm 161 [ 1.181616] ACPI: Interpreter disabled. 162 [ 1.182395] 5V: supplied by 12V 163 [ 1.183289] VDDAO_3V3: supplied by 12V 164 [ 1.183755] iommu: Default domain type: Translated 165 [ 1.183886] vgaarb: loaded 166 [ 1.184648] SCSI subsystem initialized 167 [ 1.184841] usbcore: registered new interface driver usbfs 168 [ 1.184881] usbcore: registered new interface driver hub 169 [ 1.184913] usbcore: registered new device driver usb 170 [ 1.185163] pps_core: LinuxPPS API ver. 1 registered 171 [ 1.185167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 172 [ 1.185191] PTP clock support registered 173 [ 1.185380] EDAC MC: Ver: 3.0.0 174 [ 1.186826] NetLabel: Initializing 175 [ 1.186833] NetLabel: domain hash size = 128 176 [ 1.186836] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 177 [ 1.186877] NetLabel: unlabeled traffic allowed by default 178 [ 1.187315] clocksource: Switched to clocksource arch_sys_counter 179 [ 1.187529] VFS: Disk quotas dquot_6.6.0 180 [ 1.187576] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 181 [ 1.187926] AppArmor: AppArmor Filesystem Enabled 182 [ 1.187971] pnp: PnP ACPI: disabled 183 [ 1.193741] NET: Registered protocol family 2 184 [ 1.194188] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 185 [ 1.194291] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 186 [ 1.194548] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 187 [ 1.194735] TCP: Hash tables configured (established 32768 bind 32768) 188 [ 1.194886] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 189 [ 1.194955] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 190 [ 1.195001] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 191 [ 1.195146] NET: Registered protocol family 1 192 [ 1.195170] PCI: CLS 0 bytes, default 64 193 [ 1.195296] Trying to unpack rootfs image as initramfs... 194 [ 1.762407] Freeing initrd memory: 14920K 195 [ 1.763393] kvm [1]: IPA Size Limit: 40 bits 196 [ 1.764103] kvm [1]: vgic interrupt IRQ9 197 [ 1.764245] kvm [1]: Hyp mode initialized successfully 198 [ 1.769377] Initialise system trusted keyrings 199 [ 1.769414] Key type blacklist registered 200 [ 1.769536] workingset: timestamp_bits=44 max_order=20 bucket_order=0 201 [ 1.772714] zbud: loaded 202 [ 1.773709] squashfs: version 4.0 (2009/01/31) Phillip Lougher 203 [ 1.774164] fuse: init (API version 7.32) 204 [ 1.774908] integrity: Platform Keyring initialized 205 [ 1.802702] xor: measuring software checksum speed 206 [ 1.805549] 8regs : 3476 MB/sec 207 [ 1.808030] 32regs : 4022 MB/sec 208 [ 1.810676] arm64_neon : 3722 MB/sec 209 [ 1.810680] xor: using function: 32regs (4022 MB/sec) 210 [ 1.810687] Key type asymmetric registered 211 [ 1.810690] Asymmetric key parser 'x509' registered 212 [ 1.810722] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 213 [ 1.810801] io scheduler mq-deadline registered 214 [ 1.810805] io scheduler kyber registered 215 [ 1.810879] io scheduler bfq registered 216 [ 1.813446] gpio-447 (usb-hub-reset): hogged as output/high 217 [ 1.816440] EINJ: ACPI disabled. 218 [ 1.822682] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 219 [ 1.824108] VCC_3V3: supplied by VDDAO_3V3 220 [ 1.824145] FLASH_1V8: supplied by VCC_3V3 221 [ 1.824188] VCC_1V8: supplied by VCC_3V3 222 [ 1.824214] VDDAO_1V8: supplied by VDDAO_3V3 223 [ 1.824245] VDDCPU_A: supplied by regulator-dummy 224 [ 1.824602] VDDCPU_B: supplied by regulator-dummy 225 [ 1.825265] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 226 [ 1.827570] Serial: AMBA driver 227 [ 1.827867] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 228 [ 1.827957] printk: console [ttyAML0] enabled 229 [ 1.828469] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 230 [ 1.833884] loop: module loaded 231 [ 1.835856] libphy: Fixed MDIO Bus: probed 232 [ 1.836921] tun: Universal TUN/TAP device driver, 1.6 233 [ 1.837555] thunder_xcv, ver 1.0 234 [ 1.837584] thunder_bgx, ver 1.0 235 [ 1.837609] nicpf, ver 1.0 236 [ 1.838055] e1000e: Intel(R) PRO/1000 Network Driver 237 [ 1.838058] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 238 [ 1.838096] igb: Intel(R) Gigabit Ethernet Network Driver 239 [ 1.838099] igb: Copyright (c) 2007-2014 Intel Corporation. 240 [ 1.838127] igbvf: Intel(R) Gigabit Virtual Function Network Driver 241 [ 1.838130] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 242 [ 1.838252] sky2: driver version 1.30 243 [ 1.838584] VFIO - User Level meta-driver version: 0.3 244 [ 1.839991] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 245 [ 1.840009] ehci-pci: EHCI PCI platform driver 246 [ 1.840040] ehci-platform: EHCI generic platform driver 247 [ 1.840175] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 248 [ 1.840185] ohci-pci: OHCI PCI platform driver 249 [ 1.840217] ohci-platform: OHCI generic platform driver 250 [ 1.840646] usbcore: registered new interface driver usb-storage 251 [ 1.841943] mousedev: PS/2 mouse device common for all mice 252 [ 1.842321] i2c /dev entries driver 253 [ 1.847877] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 254 [ 1.848749] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 255 [ 1.849666] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 256 [ 1.850249] sdhci: Secure Digital Host Controller Interface driver 257 [ 1.850253] sdhci: Copyright(c) Pierre Ossman 258 [ 1.850343] Synopsys Designware Multimedia Card Interface Driver 259 [ 1.850702] sdhci-pltfm: SDHCI platform and OF driver helper 260 [ 1.851105] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 261 [ 1.851484] ledtrig-cpu: registered to indicate activity on CPUs 262 [ 1.851758] meson-sm: secure-monitor enabled 263 [ 1.851998] hid: raw HID events driver (C) Jiri Kosina 264 [ 1.852088] usbcore: registered new interface driver usbhid 265 [ 1.852091] usbhid: USB HID core driver 266 [ 1.852967] NET: Registered protocol family 10 267 [ 1.853335] Segment Routing with IPv6 268 [ 1.853357] NET: Registered protocol family 17 269 [ 1.853401] 8021q: 802.1Q VLAN Support v1.8 270 [ 1.853422] Key type dns_resolver registered 271 [ 1.853660] registered taskstats version 1 272 [ 1.853666] Loading compiled-in X.509 certificates 273 [ 1.855090] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 274 [ 1.856972] zswap: loaded using pool zstd/z3fold 275 [ 1.857150] Key type ._fscrypt registered 276 [ 1.857152] Key type .fscrypt registered 277 [ 1.857154] Key type fscrypt-provisioning registered 278 [ 1.858171] Btrfs loaded, crc32c=crc32c-generic 279 [ 1.863850] Key type encrypted registered 280 [ 1.863873] AppArmor: AppArmor sha1 policy hashing enabled 281 [ 1.871188] HUB_5V: supplied by 5V 282 [ 1.871445] USB_PWR_EN: supplied by 5V 283 [ 1.872914] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 284 [ 1.872921] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 285 [ 1.875866] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 286 [ 1.875913] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 287 [ 1.876005] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 288 [ 1.876510] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 289 [ 1.876520] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 290 [ 1.876643] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 291 [ 1.876662] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 292 [ 1.876812] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 293 [ 1.876814] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 294 [ 1.876816] usb usb1: Product: xHCI Host Controller 295 [ 1.876818] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 296 [ 1.876820] usb usb1: SerialNumber: xhci-hcd.0.auto 297 [ 1.876985] hub 1-0:1.0: USB hub found 298 [ 1.876996] hub 1-0:1.0: 2 ports detected 299 [ 1.877101] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 300 [ 1.877106] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 301 [ 1.877110] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 302 [ 1.877130] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 303 [ 1.877157] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 304 [ 1.877159] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 305 [ 1.877161] usb usb2: Product: xHCI Host Controller 306 [ 1.877163] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 307 [ 1.877164] usb usb2: SerialNumber: xhci-hcd.0.auto 308 [ 1.877284] hub 2-0:1.0: USB hub found 309 [ 1.877293] hub 2-0:1.0: 1 port detected 310 [ 1.877619] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 311 [ 1.878380] meson-gx-mmc ffe05000.sd: Got CD GPIO 312 [ 1.904659] Freeing unused kernel memory: 3328K 313 [ 1.943428] Run /init as init process 314 [ 1.943432] with arguments: 315 [ 1.943434] /init 316 [ 1.943435] with environment: 317 [ 1.943437] HOME=/ 318 [ 1.943438] TERM=linux 319 [ 1.943440] hdmimode=custombuilt 320 [ 1.943441] cvbsmode=576cvbs 321 [ 1.943442] max_freq_a53=1908 322 [ 1.943443] max_freq_a73=2208 323 [ 1.943445] voutmode=hdmi 324 [ 1.943446] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 325 [ 1.943448] disablehpd=false 326 [ 1.943449] cvbscable= 327 [ 1.943450] overscan=100 328 [ 2.056504] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 329 [ 2.056515] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 330 [ 2.056664] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 331 [ 2.062705] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 332 [ 2.062713] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 333 [ 2.062716] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 334 [ 2.062718] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 335 [ 2.062721] meson8b-dwmac ff3f0000.ethernet: COE Type 2 336 [ 2.062723] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 337 [ 2.062724] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 338 [ 2.066921] meson-vrtc ff8000a8.rtc: registered as rtc1 339 [ 2.069181] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 340 [ 2.069189] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 341 [ 2.069191] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 342 [ 2.070275] libphy: stmmac: probed 343 [ 2.070991] libphy: mdio_mux: probed 344 [ 2.071771] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 345 [ 2.071863] rtc-pcf8563 1-0051: registered as rtc0 346 [ 2.075109] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 347 [ 2.075118] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 348 [ 2.117608] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 349 [ 2.118089] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 350 [ 2.120063] mmcblk0: p1 351 [ 2.176745] random: fast init done 352 [ 2.190027] mmc1: new HS200 MMC card at address 0001 353 [ 2.190554] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 354 [ 2.190906] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 355 [ 2.191155] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 356 [ 2.191321] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 357 [ 2.192541] mmcblk1: p1 358 [ 2.211346] usb 1-1: new high-speed USB device number 2 using xhci-hcd 359 [ 2.279772] libphy: mdio_mux: probed 360 [ 2.349463] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 361 [ 2.365917] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 362 [ 2.365925] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 363 [ 2.365929] usb 1-1: Product: USB2.1 Hub 364 [ 2.365932] usb 1-1: Manufacturer: GenesysLogic 365 [ 2.421473] hub 1-1:1.0: USB hub found 366 [ 2.421729] hub 1-1:1.0: 4 ports detected 367 [ 2.491450] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 368 [ 2.517942] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 369 [ 2.517950] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 370 [ 2.517954] usb 2-1: Product: USB3.1 Hub 371 [ 2.517957] usb 2-1: Manufacturer: GenesysLogic 372 [ 2.523179] systemd[1]: System time before build time, advancing clock. 373 [ 2.526734] systemd[1]: Inserted module 'autofs4' 374 [ 2.544252] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 375 [ 2.544434] systemd[1]: Detected architecture arm64. 376 [ 2.549426] hub 2-1:1.0: USB hub found 377 [ 2.549723] hub 2-1:1.0: 4 ports detected 378 [ 2.568870] systemd[1]: Set hostname to <odroidn2>. 379 [ 2.712262] random: systemd: uninitialized urandom read (16 bytes read) 380 [ 2.714829] random: systemd: uninitialized urandom read (16 bytes read) 381 [ 2.715679] systemd[1]: Created slice User and Session Slice. 382 [ 2.715879] random: systemd: uninitialized urandom read (16 bytes read) 383 [ 2.715951] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 384 [ 2.716050] systemd[1]: Reached target Swap. 385 [ 2.716191] systemd[1]: Listening on initctl Compatibility Named Pipe. 386 [ 2.716469] systemd[1]: Listening on Journal Socket. 387 [ 2.718191] systemd[1]: Starting Create list of required static device nodes for the current kernel... 388 [ 2.719975] systemd[1]: Mounting Huge Pages File System... 389 [ 2.754256] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 390 [ 2.799391] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 391 [ 2.930745] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 392 [ 2.930756] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 393 [ 2.930760] usb 1-1.1: Product: USB OPTICAL MOUSE 394 [ 2.969459] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 395 [ 2.974783] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 396 [ 2.977906] pwm-gpio pwmgpio: 1 gpio pwms loaded 397 [ 3.021227] zram: Added device: zram0 398 [ 3.021501] zram: Added device: zram1 399 [ 3.021674] zram: Added device: zram2 400 [ 3.067164] mc: Linux media interface: v0.10 401 [ 3.069847] zram0: detected capacity change from 0 to 1904500736 402 [ 3.078574] videodev: Linux video capture interface: v2.00 403 [ 3.079395] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 404 [ 3.091823] meson-drm ff900000.vpu: Queued 2 outputs on vpu 405 [ 3.110094] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 406 [ 3.110148] meson-drm ff900000.vpu: CVBS Output connector not available 407 [ 3.125599] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 408 [ 3.137257] panfrost ffe40000.gpu: clock rate = 24000000 409 [ 3.137316] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 410 [ 3.138166] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 411 [ 3.138172] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 412 [ 3.138175] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 413 [ 3.138178] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 414 [ 3.143691] Registered IR keymap rc-odroid 415 [ 3.147649] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 416 [ 3.148170] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 417 [ 3.148457] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 418 [ 3.148696] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 419 [ 3.159817] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 420 [ 3.168555] IR NEC protocol handler initialized 421 [ 3.195410] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 422 [ 3.195546] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 423 [ 3.195600] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input1 424 [ 3.197470] meson-ir ff808000.ir: receiver initialized 425 [ 3.208807] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 426 [ 3.208824] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 427 [ 3.208827] usb 1-1.3: Product: USB Keyboard 428 [ 3.208831] usb 1-1.3: Manufacturer: Logitech 429 [ 3.290370] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input2 430 [ 3.347743] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 431 [ 3.353616] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 432 [ 3.411510] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input4 433 [ 3.411645] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 434 [ 3.436135] Console: switching to colour frame buffer device 240x67 435 [ 3.457977] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 436 [ 3.485611] axg-sound-card sound: ASoC: no DMI vendor name! 437 [ 3.667327] usb 1-1.2: new high-speed USB device number 5 using xhci-hcd 438 [ 3.791613] usb 1-1.2: New USB device found, idVendor=0781, idProduct=55a1, bcdDevice= 1.00 439 [ 3.791619] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 440 [ 3.791623] usb 1-1.2: Product: Cruzer Spark 441 [ 3.791626] usb 1-1.2: Manufacturer: SanDisk 442 [ 3.791630] usb 1-1.2: SerialNumber: 4C530001231009114503 443 [ 3.792360] usb-storage 1-1.2:1.0: USB Mass Storage device detected 444 [ 3.792611] scsi host0: usb-storage 1-1.2:1.0 445 [ 3.808003] usbcore: registered new interface driver uas 446 [ 4.111330] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 447 [ 4.152238] zram1: detected capacity change from 0 to 52428800 448 [ 4.800245] scsi 0:0:0:0: Direct-Access SanDisk Cruzer Spark 1.00 PQ: 0 ANSI: 6 449 [ 4.801346] sd 0:0:0:0: [sda] 240451584 512-byte logical blocks: (123 GB/115 GiB) 450 [ 4.802523] sd 0:0:0:0: [sda] Write Protect is off 451 [ 4.802527] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 452 [ 4.802739] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA 453 [ 4.809956] sd 0:0:0:0: Attached scsi generic sg0 type 0 454 [ 4.830757] sda: sda1 455 [ 4.833222] sd 0:0:0:0: [sda] Attached SCSI removable disk 456 [ 6.195805] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 457 [ 6.195823] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 458 [ 7.027455] systemd-journald[1868]: Received request to flush runtime journal from PID 1 459 460 ### armbian-release: 461 462 # PLEASE DO NOT EDIT THIS FILE 463 BOARD=odroidn2 464 BOARD_NAME="Odroid N2" 465 BOARDFAMILY=meson-g12b 466 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 467 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 468 DISTRIBUTION_CODENAME=buster 469 DISTRIBUTION_STATUS=supported 470 VERSION=21.02.3 471 LINUXFAMILY=meson64 472 BRANCH=current 473 ARCH=arm64 474 IMAGE_TYPE=stable 475 BOARD_TYPE=conf 476 INITRD_ARCH=arm64 477 KERNEL_IMAGE_TYPE=Image 478 479 ### boot environment: 480 481 verbosity=1 482 console=both 483 overlay_prefix=meson 484 bootlogo=true 485 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 486 rootfstype=ext4 487 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 488 489 ### lsusb: 490 491 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 492 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 493 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 494 Bus 001 Device 005: ID 0781:55a1 SanDisk Corp. 495 Bus 001 Device 003: ID 275d:0ba6 496 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 497 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 498 499 ### lscpu: 500 501 Architecture: aarch64 502 Byte Order: Little Endian 503 CPU(s): 6 504 On-line CPU(s) list: 0-5 505 Thread(s) per core: 1 506 Core(s) per socket: 3 507 Socket(s): 2 508 NUMA node(s): 1 509 Vendor ID: ARM 510 Model: 4 511 Model name: Cortex-A53 512 Stepping: r0p4 513 CPU max MHz: 2400.0000 514 CPU min MHz: 100.0000 515 BogoMIPS: 48.00 516 L1d cache: unknown size 517 L1i cache: unknown size 518 L2 cache: unknown size 519 NUMA node0 CPU(s): 0-5 520 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 521 522 ### cpuinfo: 523 524 processor : 0 525 BogoMIPS : 48.00 526 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 527 CPU implementer : 0x41 528 CPU architecture: 8 529 CPU variant : 0x0 530 CPU part : 0xd03 531 CPU revision : 4 532 533 processor : 1 534 BogoMIPS : 48.00 535 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 536 CPU implementer : 0x41 537 CPU architecture: 8 538 CPU variant : 0x0 539 CPU part : 0xd03 540 CPU revision : 4 541 542 processor : 2 543 BogoMIPS : 48.00 544 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 545 CPU implementer : 0x41 546 CPU architecture: 8 547 CPU variant : 0x0 548 CPU part : 0xd09 549 CPU revision : 2 550 551 processor : 3 552 BogoMIPS : 48.00 553 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 554 CPU implementer : 0x41 555 CPU architecture: 8 556 CPU variant : 0x0 557 CPU part : 0xd09 558 CPU revision : 2 559 560 processor : 4 561 BogoMIPS : 48.00 562 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 563 CPU implementer : 0x41 564 CPU architecture: 8 565 CPU variant : 0x0 566 CPU part : 0xd09 567 CPU revision : 2 568 569 processor : 5 570 BogoMIPS : 48.00 571 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 572 CPU implementer : 0x41 573 CPU architecture: 8 574 CPU variant : 0x0 575 CPU part : 0xd09 576 CPU revision : 2 577 578 579 ### meminfo: 580 581 MemTotal: 3719724 kB 582 MemFree: 3387000 kB 583 MemAvailable: 3343456 kB 584 Buffers: 12552 kB 585 Cached: 48656 kB 586 SwapCached: 0 kB 587 Active: 33328 kB 588 Inactive: 180956 kB 589 Active(anon): 136 kB 590 Inactive(anon): 157888 kB 591 Active(file): 33192 kB 592 Inactive(file): 23068 kB 593 Unevictable: 0 kB 594 Mlocked: 0 kB 595 SwapTotal: 1859860 kB 596 SwapFree: 1859860 kB 597 Dirty: 1700 kB 598 Writeback: 0 kB 599 AnonPages: 153128 kB 600 Mapped: 14496 kB 601 Shmem: 4952 kB 602 KReclaimable: 13872 kB 603 Slab: 46352 kB 604 SReclaimable: 13872 kB 605 SUnreclaim: 32480 kB 606 KernelStack: 2688 kB 607 PageTables: 7104 kB 608 NFS_Unstable: 0 kB 609 Bounce: 0 kB 610 WritebackTmp: 0 kB 611 CommitLimit: 3719720 kB 612 Committed_AS: 4249144 kB 613 VmallocTotal: 135290159040 kB 614 VmallocUsed: 31620 kB 615 VmallocChunk: 0 kB 616 Percpu: 1416 kB 617 HardwareCorrupted: 0 kB 618 AnonHugePages: 40960 kB 619 ShmemHugePages: 0 kB 620 ShmemPmdMapped: 0 kB 621 FileHugePages: 0 kB 622 FilePmdMapped: 0 kB 623 CmaTotal: 917504 kB 624 CmaFree: 901724 kB 625 HugePages_Total: 0 626 HugePages_Free: 0 627 HugePages_Rsvd: 0 628 HugePages_Surp: 0 629 Hugepagesize: 2048 kB 630 Hugetlb: 0 kB 631 632 ### virtual memory: 633 634 vm.admin_reserve_kbytes = 8192 635 vm.block_dump = 0 636 vm.compaction_proactiveness = 20 637 vm.compact_unevictable_allowed = 1 638 vm.dirty_background_bytes = 0 639 vm.dirty_background_ratio = 10 640 vm.dirty_bytes = 0 641 vm.dirty_expire_centisecs = 3000 642 vm.dirty_ratio = 20 643 vm.dirtytime_expire_seconds = 43200 644 vm.dirty_writeback_centisecs = 500 645 vm.extfrag_threshold = 500 646 vm.hugetlb_shm_group = 0 647 vm.laptop_mode = 0 648 vm.legacy_va_layout = 0 649 vm.lowmem_reserve_ratio = 256 256 32 0 650 vm.max_map_count = 65530 651 vm.memory_failure_early_kill = 0 652 vm.memory_failure_recovery = 1 653 vm.min_free_kbytes = 45056 654 vm.min_slab_ratio = 5 655 vm.min_unmapped_ratio = 1 656 vm.mmap_min_addr = 4096 657 vm.mmap_rnd_bits = 18 658 vm.mmap_rnd_compat_bits = 11 659 vm.nr_hugepages = 0 660 vm.nr_hugepages_mempolicy = 0 661 vm.nr_overcommit_hugepages = 0 662 vm.numa_stat = 1 663 vm.numa_zonelist_order = Node 664 vm.oom_dump_tasks = 1 665 vm.oom_kill_allocating_task = 0 666 vm.overcommit_kbytes = 0 667 vm.overcommit_memory = 0 668 vm.overcommit_ratio = 50 669 vm.page-cluster = 0 670 vm.page_lock_unfairness = 5 671 vm.panic_on_oom = 0 672 vm.percpu_pagelist_fraction = 0 673 vm.stat_interval = 1 674 vm.swappiness = 100 675 vm.user_reserve_kbytes = 114983 676 vm.vfs_cache_pressure = 100 677 vm.watermark_boost_factor = 15000 678 vm.watermark_scale_factor = 10 679 vm.zone_reclaim_mode = 0 680 681 ### ip addr: 682 683 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 684 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 685 inet XXX.XXX.0.1/8 scope host lo 686 valid_lft forever preferred_lft forever 687 inet6 ::1/128 scope host 688 valid_lft forever preferred_lft forever 689 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 690 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 691 692 ### partitions: 693 694 major minor #blocks name 695 696 179 0 62367744 mmcblk0 697 179 1 62366720 mmcblk0p1 698 179 32 61071360 mmcblk1 699 179 33 60456544 mmcblk1p1 700 252 0 1859864 zram0 701 252 1 51200 zram1 702 8 0 120225792 sda 703 8 1 120225760 sda1 704 705 ### df: 706 707 udev 1.4G 0 1.4G 0% /dev 708 tmpfs 364M 5.0M 359M 2% /run 709 /dev/mmcblk1p1 57G 20G 37G 36% / 710 tmpfs 1.8G 0 1.8G 0% /dev/shm 711 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 712 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 713 tmpfs 1.8G 0 1.8G 0% /tmp 714 /dev/zram1 49M 1.7M 44M 4% /var/log 715 716 ### lsblk: 717 718 NAME FSTYPE SIZE MOUNTPOINT UUID 719 sda 114.7G 720 └─sda1 ntfs 114.7G 1CB8167CB816549C 721 mmcblk0 59.5G 722 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 723 mmcblk1 58.2G 724 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 725 mmcblk1boot0 4M 726 mmcblk1boot1 4M 727 zram1 50M /var/log 728 729 ### zramctl: 730 731 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 732 /dev/zram1 zstd 50M 132K 697B 36K 6 /var/log 733 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 734 735 ### mtab: 736 737 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 738 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 739 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 740 741 ### mmc0:aaaa info: 742 743 fwrev: 0x0 744 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 745 cid: 035344534836344780559b2001014a00 746 rca: 0xaaaa 747 csd: 400e0032db790001dbd37f800a404000 748 manfid: 0x000003 749 ocr: 0x00200000 750 preferred_erase_size: 4194304 751 type: SD 752 hwrev: 0x8 753 date: 10/2020 754 dsr: 0x404 755 erase_size: 512 756 oemid: 0x5344 757 serial: 0x559b2001 758 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 759 scr: 0245848300000000 760 name: SH64G 761 762 ### mmc1:0001 info: 763 764 fwrev: 0x0400000000000000 765 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 766 cid: 150100434a54443452042559facb7700 767 rel_sectors: 0x1 768 enhanced_rpmb_supported: 0x1 769 rca: 0x0001 770 pre_eol_info: 0x01 771 csd: d02701320f5903fff6dbffef8e404000 772 manfid: 0x000015 773 ocr: 0x00200000 774 preferred_erase_size: 4194304 775 enhanced_area_offset: 18446744073709551594 776 raw_rpmb_size_mult: 0x20 777 type: MMC 778 hwrev: 0x0 779 date: 07/2020 780 prv: 0x4 781 ffu_capable: 1 782 dsr: 0x404 783 erase_size: 524288 784 life_time: 0x01 0x01 785 enhanced_area_size: 4294967274 786 oemid: 0x0100 787 serial: 0x2559facb 788 cmdq_en: 0 789 rev: 0x8 790 name: CJTD4R 791 792 ### Boot system health: 793 794 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 795 16:42:11: 2400/2016MHz 0.16 23% 15% 6% 0% 1% 0% 28.4°C 0/12 796 16:42:11: 2400/2016MHz 0.16 29% 19% 8% 0% 0% 0% 26.3°C 0/12 797 16:42:12: 2400/2016MHz 0.16 19% 8% 9% 0% 0% 0% 25.1°C 0/12 798 16:42:12: 2400/2016MHz 0.16 48% 26% 13% 0% 6% 0% 26.1°C 0/12 799 16:42:12: 2400/2016MHz 0.16 85% 36% 30% 0% 15% 3% 28.4°C 0/12 800 801 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 802 803 ### Activated Armbian ramlog partition with zstd compression 804 805 Sun 28 Mar 2021 06:36:30 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 806 807 ### dmesg: 808 809 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 810 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 811 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 812 [ 0.000000] efi: UEFI not found. 813 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 814 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 815 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 816 [ 0.000000] NUMA: No NUMA configuration found 817 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 818 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 819 [ 0.000000] Zone ranges: 820 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 821 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 822 [ 0.000000] Normal empty 823 [ 0.000000] Movable zone start for each node 824 [ 0.000000] Early memory node ranges 825 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 826 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 827 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 828 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 829 [ 0.000000] On node 0 totalpages: 972800 830 [ 0.000000] DMA zone: 4096 pages used for memmap 831 [ 0.000000] DMA zone: 0 pages reserved 832 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 833 [ 0.000000] DMA32 zone: 11104 pages used for memmap 834 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 835 [ 0.000000] psci: probing for conduit method from DT. 836 [ 0.000000] psci: PSCIv1.0 detected in firmware. 837 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 838 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 839 [ 0.000000] psci: SMC Calling Convention v1.1 840 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 841 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 842 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 843 [ 0.000000] Detected VIPT I-cache on CPU0 844 [ 0.000000] CPU features: detected: ARM erratum 845719 845 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 846 [ 0.000000] Policy zone: DMA32 847 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 848 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 849 Please use sysfs to set IO scheduler for individual devices. 850 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 851 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 852 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 853 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 854 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 855 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 856 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 857 [ 0.000000] rcu: RCU event tracing is enabled. 858 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 859 [ 0.000000] Trampoline variant of Tasks RCU enabled. 860 [ 0.000000] Rude variant of Tasks RCU enabled. 861 [ 0.000000] Tracing variant of Tasks RCU enabled. 862 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 863 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 864 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 865 [ 0.000000] GIC: Using split EOI/Deactivate mode 866 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 867 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 868 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 869 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 870 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 871 [ 0.000252] Console: colour dummy device 80x25 872 [ 0.000286] printk: console [tty1] enabled 873 [ 0.000375] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 874 [ 0.000386] pid_max: default: 32768 minimum: 301 875 [ 0.000470] LSM: Security Framework initializing 876 [ 0.000496] Yama: becoming mindful. 877 [ 0.000587] AppArmor: AppArmor initialized 878 [ 0.000638] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 879 [ 0.000656] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 880 [ 0.002660] rcu: Hierarchical SRCU implementation. 881 [ 0.005133] EFI services will not be available. 882 [ 0.005555] smp: Bringing up secondary CPUs ... 883 [ 0.006230] Detected VIPT I-cache on CPU1 884 [ 0.006293] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 885 [ 0.007489] CPU features: detected: ARM erratum 858921 886 [ 0.007497] CPU features: detected: Spectre-v2 887 [ 0.007501] CPU features: detected: Spectre-v4 888 [ 0.007507] Detected VIPT I-cache on CPU2 889 [ 0.007531] arch_timer: Enabling local workaround for ARM erratum 858921 890 [ 0.007546] arch_timer: CPU2: Trapping CNTVCT access 891 [ 0.007561] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 892 [ 0.008269] Detected VIPT I-cache on CPU3 893 [ 0.008285] arch_timer: Enabling local workaround for ARM erratum 858921 894 [ 0.008292] arch_timer: CPU3: Trapping CNTVCT access 895 [ 0.008300] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 896 [ 0.008928] Detected VIPT I-cache on CPU4 897 [ 0.008944] arch_timer: Enabling local workaround for ARM erratum 858921 898 [ 0.008951] arch_timer: CPU4: Trapping CNTVCT access 899 [ 0.008959] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 900 [ 0.009571] Detected VIPT I-cache on CPU5 901 [ 0.009587] arch_timer: Enabling local workaround for ARM erratum 858921 902 [ 0.009594] arch_timer: CPU5: Trapping CNTVCT access 903 [ 0.009602] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 904 [ 0.009683] smp: Brought up 1 node, 6 CPUs 905 [ 0.009700] SMP: Total of 6 processors activated. 906 [ 0.009708] CPU features: detected: 32-bit EL0 Support 907 [ 0.009714] CPU features: detected: CRC32 instructions 908 [ 0.009720] CPU features: detected: 32-bit EL1 Support 909 [ 0.020948] CPU: All CPU(s) started at EL2 910 [ 0.020999] alternatives: patching kernel code 911 [ 0.022996] devtmpfs: initialized 912 [ 0.030698] Registered cp15_barrier emulation handler 913 [ 0.030712] Registered setend emulation handler 914 [ 0.030849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 915 [ 0.030887] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 916 [ 0.046165] pinctrl core: initialized pinctrl subsystem 917 [ 0.046874] DMI not present or invalid. 918 [ 0.047245] NET: Registered protocol family 16 919 [ 0.048774] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 920 [ 0.049065] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 921 [ 0.049294] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 922 [ 0.049336] audit: initializing netlink subsys (disabled) 923 [ 0.049445] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 924 [ 0.050851] thermal_sys: Registered thermal governor 'fair_share' 925 [ 0.050859] thermal_sys: Registered thermal governor 'bang_bang' 926 [ 0.050863] thermal_sys: Registered thermal governor 'step_wise' 927 [ 0.050866] thermal_sys: Registered thermal governor 'user_space' 928 [ 0.051288] cpuidle: using governor menu 929 [ 0.051632] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 930 [ 0.051753] ASID allocator initialised with 65536 entries 931 [ 0.052719] Serial: AMBA PL011 UART driver 932 [ 0.087742] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 933 [ 0.087755] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 934 [ 0.087761] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 935 [ 0.087766] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 936 [ 0.089343] cryptd: max_cpu_qlen set to 1000 937 [ 0.160211] raid6: neonx8 gen() 2785 MB/s 938 [ 0.228271] raid6: neonx8 xor() 2042 MB/s 939 [ 0.296365] raid6: neonx4 gen() 2998 MB/s 940 [ 0.364406] raid6: neonx4 xor() 2399 MB/s 941 [ 0.432474] raid6: neonx2 gen() 2552 MB/s 942 [ 0.500536] raid6: neonx2 xor() 2202 MB/s 943 [ 0.568605] raid6: neonx1 gen() 1924 MB/s 944 [ 0.636668] raid6: neonx1 xor() 1728 MB/s 945 [ 0.704738] raid6: int64x8 gen() 1374 MB/s 946 [ 0.772806] raid6: int64x8 xor() 735 MB/s 947 [ 0.840883] raid6: int64x4 gen() 1463 MB/s 948 [ 0.908943] raid6: int64x4 xor() 733 MB/s 949 [ 0.976994] raid6: int64x2 gen() 1362 MB/s 950 [ 1.045070] raid6: int64x2 xor() 619 MB/s 951 [ 1.113129] raid6: int64x1 gen() 1127 MB/s 952 [ 1.181191] raid6: int64x1 xor() 462 MB/s 953 [ 1.181194] raid6: using algorithm neonx4 gen() 2998 MB/s 954 [ 1.181197] raid6: .... xor() 2399 MB/s, rmw enabled 955 [ 1.181201] raid6: using neon recovery algorithm 956 [ 1.181673] ACPI: Interpreter disabled. 957 [ 1.182473] 5V: supplied by 12V 958 [ 1.183376] VDDAO_3V3: supplied by 12V 959 [ 1.183855] iommu: Default domain type: Translated 960 [ 1.183984] vgaarb: loaded 961 [ 1.184772] SCSI subsystem initialized 962 [ 1.185100] usbcore: registered new interface driver usbfs 963 [ 1.185149] usbcore: registered new interface driver hub 964 [ 1.185187] usbcore: registered new device driver usb 965 [ 1.185562] pps_core: LinuxPPS API ver. 1 registered 966 [ 1.185568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 967 [ 1.185592] PTP clock support registered 968 [ 1.185783] EDAC MC: Ver: 3.0.0 969 [ 1.187140] NetLabel: Initializing 970 [ 1.187148] NetLabel: domain hash size = 128 971 [ 1.187151] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 972 [ 1.187191] NetLabel: unlabeled traffic allowed by default 973 [ 1.187669] clocksource: Switched to clocksource arch_sys_counter 974 [ 1.187880] VFS: Disk quotas dquot_6.6.0 975 [ 1.187925] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 976 [ 1.188298] AppArmor: AppArmor Filesystem Enabled 977 [ 1.188347] pnp: PnP ACPI: disabled 978 [ 1.193856] NET: Registered protocol family 2 979 [ 1.194318] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 980 [ 1.194421] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 981 [ 1.194678] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 982 [ 1.194865] TCP: Hash tables configured (established 32768 bind 32768) 983 [ 1.195016] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 984 [ 1.195079] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 985 [ 1.195125] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 986 [ 1.195270] NET: Registered protocol family 1 987 [ 1.195290] PCI: CLS 0 bytes, default 64 988 [ 1.195415] Trying to unpack rootfs image as initramfs... 989 [ 1.762842] Freeing initrd memory: 14920K 990 [ 1.763822] kvm [1]: IPA Size Limit: 40 bits 991 [ 1.764543] kvm [1]: vgic interrupt IRQ9 992 [ 1.764676] kvm [1]: Hyp mode initialized successfully 993 [ 1.769798] Initialise system trusted keyrings 994 [ 1.769827] Key type blacklist registered 995 [ 1.769927] workingset: timestamp_bits=44 max_order=20 bucket_order=0 996 [ 1.773093] zbud: loaded 997 [ 1.774106] squashfs: version 4.0 (2009/01/31) Phillip Lougher 998 [ 1.774566] fuse: init (API version 7.32) 999 [ 1.775314] integrity: Platform Keyring initialized 1000 [ 1.803129] xor: measuring software checksum speed 1001 [ 1.805973] 8regs : 3476 MB/sec 1002 [ 1.808426] 32regs : 4021 MB/sec 1003 [ 1.811073] arm64_neon : 3721 MB/sec 1004 [ 1.811076] xor: using function: 32regs (4021 MB/sec) 1005 [ 1.811085] Key type asymmetric registered 1006 [ 1.811088] Asymmetric key parser 'x509' registered 1007 [ 1.811119] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 1008 [ 1.811238] io scheduler mq-deadline registered 1009 [ 1.811242] io scheduler kyber registered 1010 [ 1.811313] io scheduler bfq registered 1011 [ 1.813839] gpio-447 (usb-hub-reset): hogged as output/high 1012 [ 1.816859] EINJ: ACPI disabled. 1013 [ 1.823011] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 1014 [ 1.824400] VCC_3V3: supplied by VDDAO_3V3 1015 [ 1.824432] FLASH_1V8: supplied by VCC_3V3 1016 [ 1.824465] VCC_1V8: supplied by VCC_3V3 1017 [ 1.824491] VDDAO_1V8: supplied by VDDAO_3V3 1018 [ 1.824518] VDDCPU_A: supplied by regulator-dummy 1019 [ 1.824853] VDDCPU_B: supplied by regulator-dummy 1020 [ 1.825479] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 1021 [ 1.827820] Serial: AMBA driver 1022 [ 1.828103] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 1023 [ 1.828195] printk: console [ttyAML0] enabled 1024 [ 1.828736] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 1025 [ 1.834024] loop: module loaded 1026 [ 1.835907] libphy: Fixed MDIO Bus: probed 1027 [ 1.837037] tun: Universal TUN/TAP device driver, 1.6 1028 [ 1.837667] thunder_xcv, ver 1.0 1029 [ 1.837696] thunder_bgx, ver 1.0 1030 [ 1.837725] nicpf, ver 1.0 1031 [ 1.838169] e1000e: Intel(R) PRO/1000 Network Driver 1032 [ 1.838172] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 1033 [ 1.838210] igb: Intel(R) Gigabit Ethernet Network Driver 1034 [ 1.838214] igb: Copyright (c) 2007-2014 Intel Corporation. 1035 [ 1.838242] igbvf: Intel(R) Gigabit Virtual Function Network Driver 1036 [ 1.838245] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 1037 [ 1.838365] sky2: driver version 1.30 1038 [ 1.838702] VFIO - User Level meta-driver version: 0.3 1039 [ 1.840110] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 1040 [ 1.840127] ehci-pci: EHCI PCI platform driver 1041 [ 1.840157] ehci-platform: EHCI generic platform driver 1042 [ 1.840292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 1043 [ 1.840301] ohci-pci: OHCI PCI platform driver 1044 [ 1.840333] ohci-platform: OHCI generic platform driver 1045 [ 1.840760] usbcore: registered new interface driver usb-storage 1046 [ 1.842086] mousedev: PS/2 mouse device common for all mice 1047 [ 1.842470] i2c /dev entries driver 1048 [ 1.847832] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 1049 [ 1.848733] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 1050 [ 1.849656] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 1051 [ 1.850234] sdhci: Secure Digital Host Controller Interface driver 1052 [ 1.850238] sdhci: Copyright(c) Pierre Ossman 1053 [ 1.850319] Synopsys Designware Multimedia Card Interface Driver 1054 [ 1.850681] sdhci-pltfm: SDHCI platform and OF driver helper 1055 [ 1.851073] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 1056 [ 1.851379] ledtrig-cpu: registered to indicate activity on CPUs 1057 [ 1.851787] meson-sm: secure-monitor enabled 1058 [ 1.851929] hid: raw HID events driver (C) Jiri Kosina 1059 [ 1.852067] usbcore: registered new interface driver usbhid 1060 [ 1.852071] usbhid: USB HID core driver 1061 [ 1.852913] NET: Registered protocol family 10 1062 [ 1.853252] Segment Routing with IPv6 1063 [ 1.853274] NET: Registered protocol family 17 1064 [ 1.853317] 8021q: 802.1Q VLAN Support v1.8 1065 [ 1.853337] Key type dns_resolver registered 1066 [ 1.853569] registered taskstats version 1 1067 [ 1.853573] Loading compiled-in X.509 certificates 1068 [ 1.854987] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 1069 [ 1.856629] zswap: loaded using pool zstd/z3fold 1070 [ 1.856885] Key type ._fscrypt registered 1071 [ 1.856887] Key type .fscrypt registered 1072 [ 1.856889] Key type fscrypt-provisioning registered 1073 [ 1.857898] Btrfs loaded, crc32c=crc32c-generic 1074 [ 1.863431] Key type encrypted registered 1075 [ 1.863441] AppArmor: AppArmor sha1 policy hashing enabled 1076 [ 1.869052] HUB_5V: supplied by 5V 1077 [ 1.869246] USB_PWR_EN: supplied by 5V 1078 [ 1.870683] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 1079 [ 1.870689] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 1080 [ 1.873376] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 1081 [ 1.873420] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 1082 [ 1.873504] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 1083 [ 1.874018] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 1084 [ 1.874028] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 1085 [ 1.874107] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 1086 [ 1.874125] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 1087 [ 1.874235] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 1088 [ 1.874238] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1089 [ 1.874240] usb usb1: Product: xHCI Host Controller 1090 [ 1.874242] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 1091 [ 1.874244] usb usb1: SerialNumber: xhci-hcd.0.auto 1092 [ 1.874412] hub 1-0:1.0: USB hub found 1093 [ 1.874423] hub 1-0:1.0: 2 ports detected 1094 [ 1.874531] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 1095 [ 1.874536] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 1096 [ 1.874540] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 1097 [ 1.874557] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 1098 [ 1.874582] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 1099 [ 1.874584] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1100 [ 1.874586] usb usb2: Product: xHCI Host Controller 1101 [ 1.874588] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 1102 [ 1.874589] usb usb2: SerialNumber: xhci-hcd.0.auto 1103 [ 1.874708] hub 2-0:1.0: USB hub found 1104 [ 1.874717] hub 2-0:1.0: 1 port detected 1105 [ 1.874965] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 1106 [ 1.875880] meson-gx-mmc ffe05000.sd: Got CD GPIO 1107 [ 1.900732] Freeing unused kernel memory: 3328K 1108 [ 1.943705] Run /init as init process 1109 [ 1.943708] with arguments: 1110 [ 1.943710] /init 1111 [ 1.943712] with environment: 1112 [ 1.943714] HOME=/ 1113 [ 1.943715] TERM=linux 1114 [ 1.943717] hdmimode=custombuilt 1115 [ 1.943718] cvbsmode=576cvbs 1116 [ 1.943719] max_freq_a53=1908 1117 [ 1.943720] max_freq_a73=2208 1118 [ 1.943721] voutmode=hdmi 1119 [ 1.943723] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 1120 [ 1.943724] disablehpd=false 1121 [ 1.943725] cvbscable= 1122 [ 1.943726] overscan=100 1123 [ 2.045422] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 1124 [ 2.045429] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 1125 [ 2.045514] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 1126 [ 2.045904] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 1127 [ 2.045912] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 1128 [ 2.045915] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 1129 [ 2.045917] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 1130 [ 2.045919] meson8b-dwmac ff3f0000.ethernet: COE Type 2 1131 [ 2.045920] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 1132 [ 2.045922] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 1133 [ 2.045975] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 1134 [ 2.045977] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 1135 [ 2.045979] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 1136 [ 2.046146] libphy: stmmac: probed 1137 [ 2.048331] libphy: mdio_mux: probed 1138 [ 2.058504] meson-vrtc ff8000a8.rtc: registered as rtc1 1139 [ 2.068029] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 1140 [ 2.068522] rtc-pcf8563 1-0051: registered as rtc0 1141 [ 2.070528] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 1142 [ 2.070540] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 1143 [ 2.113770] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 1144 [ 2.114320] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 1145 [ 2.116482] mmcblk0: p1 1146 [ 2.130432] mmc1: new HS200 MMC card at address 0001 1147 [ 2.130953] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 1148 [ 2.131210] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 1149 [ 2.131469] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 1150 [ 2.131641] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 1151 [ 2.132790] mmcblk1: p1 1152 [ 2.139423] random: fast init done 1153 [ 2.207791] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 1154 [ 2.232430] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 1155 [ 2.232435] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1156 [ 2.232438] usb 2-1: Product: USB3.1 Hub 1157 [ 2.232439] usb 2-1: Manufacturer: GenesysLogic 1158 [ 2.254421] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 1159 [ 2.258843] hub 2-1:1.0: USB hub found 1160 [ 2.259130] hub 2-1:1.0: 4 ports detected 1161 [ 2.260102] libphy: mdio_mux: probed 1162 [ 2.355678] usb 1-1: new high-speed USB device number 2 using xhci-hcd 1163 [ 2.427320] systemd[1]: System time before build time, advancing clock. 1164 [ 2.430837] systemd[1]: Inserted module 'autofs4' 1165 [ 2.448091] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 1166 [ 2.448283] systemd[1]: Detected architecture arm64. 1167 [ 2.473691] systemd[1]: Set hostname to <odroidn2>. 1168 [ 2.506275] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 1169 [ 2.506283] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1170 [ 2.506286] usb 1-1: Product: USB2.1 Hub 1171 [ 2.506288] usb 1-1: Manufacturer: GenesysLogic 1172 [ 2.546871] hub 1-1:1.0: USB hub found 1173 [ 2.547100] hub 1-1:1.0: 4 ports detected 1174 [ 2.630136] random: systemd: uninitialized urandom read (16 bytes read) 1175 [ 2.632761] random: systemd: uninitialized urandom read (16 bytes read) 1176 [ 2.633537] systemd[1]: Created slice User and Session Slice. 1177 [ 2.633733] random: systemd: uninitialized urandom read (16 bytes read) 1178 [ 2.633749] systemd[1]: Reached target System Time Synchronized. 1179 [ 2.634074] systemd[1]: Listening on Journal Audit Socket. 1180 [ 2.634274] systemd[1]: Listening on Journal Socket (/dev/log). 1181 [ 2.634984] systemd[1]: Created slice system-getty.slice. 1182 [ 2.635196] systemd[1]: Listening on Syslog Socket. 1183 [ 2.635275] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 1184 [ 2.672878] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 1185 [ 2.901176] pwm-gpio pwmgpio: 1 gpio pwms loaded 1186 [ 2.923211] zram: Added device: zram0 1187 [ 2.923533] zram: Added device: zram1 1188 [ 2.923699] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 1189 [ 2.924611] zram: Added device: zram2 1190 [ 2.974166] zram0: detected capacity change from 0 to 1904500736 1191 [ 2.991146] meson-drm ff900000.vpu: Queued 2 outputs on vpu 1192 [ 2.992256] mc: Linux media interface: v0.10 1193 [ 3.002672] meson-drm ff900000.vpu: CVBS Output connector not available 1194 [ 3.003568] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 1195 [ 3.005342] videodev: Linux video capture interface: v2.00 1196 [ 3.031940] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 1197 [ 3.035977] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 1198 [ 3.036231] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 1199 [ 3.038732] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 1200 [ 3.050761] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 1201 [ 3.050768] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 1202 [ 3.050771] usb 1-1.1: Product: USB OPTICAL MOUSE 1203 [ 3.052486] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 1204 [ 3.063307] panfrost ffe40000.gpu: clock rate = 24000000 1205 [ 3.063365] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 1206 [ 3.064188] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 1207 [ 3.064198] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 1208 [ 3.064202] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 1209 [ 3.064205] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 1210 [ 3.079765] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 1211 [ 3.093258] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input1 1212 [ 3.093419] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 1213 [ 3.095901] Registered IR keymap rc-odroid 1214 [ 3.102418] IR NEC protocol handler initialized 1215 [ 3.132144] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 1216 [ 3.132243] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 1217 [ 3.132296] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0 1218 [ 3.132549] meson-ir ff808000.ir: receiver initialized 1219 [ 3.199693] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 1220 [ 3.328488] Console: switching to colour frame buffer device 240x67 1221 [ 3.328844] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 1222 [ 3.328847] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1223 [ 3.328849] usb 1-1.3: Product: USB Keyboard 1224 [ 3.328850] usb 1-1.3: Manufacturer: Logitech 1225 [ 3.350347] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 1226 [ 3.378054] axg-sound-card sound: ASoC: no DMI vendor name! 1227 [ 3.415502] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input2 1228 [ 3.471954] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 1229 [ 3.477887] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 1230 [ 3.535745] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input4 1231 [ 3.535815] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 1232 [ 3.783660] usb 1-1.2: new high-speed USB device number 5 using xhci-hcd 1233 [ 3.907952] usb 1-1.2: New USB device found, idVendor=0781, idProduct=55a1, bcdDevice= 1.00 1234 [ 3.907954] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 1235 [ 3.907957] usb 1-1.2: Product: Cruzer Spark 1236 [ 3.907958] usb 1-1.2: Manufacturer: SanDisk 1237 [ 3.907960] usb 1-1.2: SerialNumber: 4C530001231009114503 1238 [ 3.908367] usb-storage 1-1.2:1.0: USB Mass Storage device detected 1239 [ 3.908629] scsi host0: usb-storage 1-1.2:1.0 1240 [ 3.919734] usbcore: registered new interface driver uas 1241 [ 4.003688] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 1242 [ 4.048359] zram1: detected capacity change from 0 to 52428800 1243 [ 4.928493] scsi 0:0:0:0: Direct-Access SanDisk Cruzer Spark 1.00 PQ: 0 ANSI: 6 1244 [ 4.929397] sd 0:0:0:0: [sda] 240451584 512-byte logical blocks: (123 GB/115 GiB) 1245 [ 4.930584] sd 0:0:0:0: [sda] Write Protect is off 1246 [ 4.930589] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 1247 [ 4.930820] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA 1248 [ 4.934204] sd 0:0:0:0: Attached scsi generic sg0 type 0 1249 [ 4.955190] sda: sda1 1250 [ 4.957663] sd 0:0:0:0: [sda] Attached SCSI removable disk 1251 [ 6.091970] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 1252 [ 6.091986] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 1253 [ 6.936168] systemd-journald[1862]: Received request to flush runtime journal from PID 1 1254 1255 ### armbian-release: 1256 1257 # PLEASE DO NOT EDIT THIS FILE 1258 BOARD=odroidn2 1259 BOARD_NAME="Odroid N2" 1260 BOARDFAMILY=meson-g12b 1261 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 1262 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 1263 DISTRIBUTION_CODENAME=buster 1264 DISTRIBUTION_STATUS=supported 1265 VERSION=21.02.3 1266 LINUXFAMILY=meson64 1267 BRANCH=current 1268 ARCH=arm64 1269 IMAGE_TYPE=stable 1270 BOARD_TYPE=conf 1271 INITRD_ARCH=arm64 1272 KERNEL_IMAGE_TYPE=Image 1273 1274 ### boot environment: 1275 1276 verbosity=1 1277 console=both 1278 overlay_prefix=meson 1279 bootlogo=true 1280 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 1281 rootfstype=ext4 1282 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 1283 1284 ### lsusb: 1285 1286 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 1287 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 1288 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 1289 Bus 001 Device 005: ID 0781:55a1 SanDisk Corp. 1290 Bus 001 Device 003: ID 275d:0ba6 1291 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 1292 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1293 1294 ### lscpu: 1295 1296 Architecture: aarch64 1297 Byte Order: Little Endian 1298 CPU(s): 6 1299 On-line CPU(s) list: 0-5 1300 Thread(s) per core: 1 1301 Core(s) per socket: 3 1302 Socket(s): 2 1303 NUMA node(s): 1 1304 Vendor ID: ARM 1305 Model: 4 1306 Model name: Cortex-A53 1307 Stepping: r0p4 1308 CPU max MHz: 2400.0000 1309 CPU min MHz: 100.0000 1310 BogoMIPS: 48.00 1311 L1d cache: unknown size 1312 L1i cache: unknown size 1313 L2 cache: unknown size 1314 NUMA node0 CPU(s): 0-5 1315 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1316 1317 ### cpuinfo: 1318 1319 processor : 0 1320 BogoMIPS : 48.00 1321 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1322 CPU implementer : 0x41 1323 CPU architecture: 8 1324 CPU variant : 0x0 1325 CPU part : 0xd03 1326 CPU revision : 4 1327 1328 processor : 1 1329 BogoMIPS : 48.00 1330 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1331 CPU implementer : 0x41 1332 CPU architecture: 8 1333 CPU variant : 0x0 1334 CPU part : 0xd03 1335 CPU revision : 4 1336 1337 processor : 2 1338 BogoMIPS : 48.00 1339 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1340 CPU implementer : 0x41 1341 CPU architecture: 8 1342 CPU variant : 0x0 1343 CPU part : 0xd09 1344 CPU revision : 2 1345 1346 processor : 3 1347 BogoMIPS : 48.00 1348 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1349 CPU implementer : 0x41 1350 CPU architecture: 8 1351 CPU variant : 0x0 1352 CPU part : 0xd09 1353 CPU revision : 2 1354 1355 processor : 4 1356 BogoMIPS : 48.00 1357 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1358 CPU implementer : 0x41 1359 CPU architecture: 8 1360 CPU variant : 0x0 1361 CPU part : 0xd09 1362 CPU revision : 2 1363 1364 processor : 5 1365 BogoMIPS : 48.00 1366 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 1367 CPU implementer : 0x41 1368 CPU architecture: 8 1369 CPU variant : 0x0 1370 CPU part : 0xd09 1371 CPU revision : 2 1372 1373 1374 ### meminfo: 1375 1376 MemTotal: 3719724 kB 1377 MemFree: 3401804 kB 1378 MemAvailable: 3358912 kB 1379 Buffers: 12544 kB 1380 Cached: 49840 kB 1381 SwapCached: 0 kB 1382 Active: 33620 kB 1383 Inactive: 166504 kB 1384 Active(anon): 164 kB 1385 Inactive(anon): 142776 kB 1386 Active(file): 33456 kB 1387 Inactive(file): 23728 kB 1388 Unevictable: 0 kB 1389 Mlocked: 0 kB 1390 SwapTotal: 1859860 kB 1391 SwapFree: 1859860 kB 1392 Dirty: 2832 kB 1393 Writeback: 0 kB 1394 AnonPages: 137908 kB 1395 Mapped: 15200 kB 1396 Shmem: 5028 kB 1397 KReclaimable: 13748 kB 1398 Slab: 46248 kB 1399 SReclaimable: 13748 kB 1400 SUnreclaim: 32500 kB 1401 KernelStack: 2592 kB 1402 PageTables: 6580 kB 1403 NFS_Unstable: 0 kB 1404 Bounce: 0 kB 1405 WritebackTmp: 0 kB 1406 CommitLimit: 3719720 kB 1407 Committed_AS: 4249524 kB 1408 VmallocTotal: 135290159040 kB 1409 VmallocUsed: 31524 kB 1410 VmallocChunk: 0 kB 1411 Percpu: 1416 kB 1412 HardwareCorrupted: 0 kB 1413 AnonHugePages: 0 kB 1414 ShmemHugePages: 0 kB 1415 ShmemPmdMapped: 0 kB 1416 FileHugePages: 0 kB 1417 FilePmdMapped: 0 kB 1418 CmaTotal: 917504 kB 1419 CmaFree: 901724 kB 1420 HugePages_Total: 0 1421 HugePages_Free: 0 1422 HugePages_Rsvd: 0 1423 HugePages_Surp: 0 1424 Hugepagesize: 2048 kB 1425 Hugetlb: 0 kB 1426 1427 ### virtual memory: 1428 1429 vm.admin_reserve_kbytes = 8192 1430 vm.block_dump = 0 1431 vm.compaction_proactiveness = 20 1432 vm.compact_unevictable_allowed = 1 1433 vm.dirty_background_bytes = 0 1434 vm.dirty_background_ratio = 10 1435 vm.dirty_bytes = 0 1436 vm.dirty_expire_centisecs = 3000 1437 vm.dirty_ratio = 20 1438 vm.dirtytime_expire_seconds = 43200 1439 vm.dirty_writeback_centisecs = 500 1440 vm.extfrag_threshold = 500 1441 vm.hugetlb_shm_group = 0 1442 vm.laptop_mode = 0 1443 vm.legacy_va_layout = 0 1444 vm.lowmem_reserve_ratio = 256 256 32 0 1445 vm.max_map_count = 65530 1446 vm.memory_failure_early_kill = 0 1447 vm.memory_failure_recovery = 1 1448 vm.min_free_kbytes = 45056 1449 vm.min_slab_ratio = 5 1450 vm.min_unmapped_ratio = 1 1451 vm.mmap_min_addr = 4096 1452 vm.mmap_rnd_bits = 18 1453 vm.mmap_rnd_compat_bits = 11 1454 vm.nr_hugepages = 0 1455 vm.nr_hugepages_mempolicy = 0 1456 vm.nr_overcommit_hugepages = 0 1457 vm.numa_stat = 1 1458 vm.numa_zonelist_order = Node 1459 vm.oom_dump_tasks = 1 1460 vm.oom_kill_allocating_task = 0 1461 vm.overcommit_kbytes = 0 1462 vm.overcommit_memory = 0 1463 vm.overcommit_ratio = 50 1464 vm.page-cluster = 0 1465 vm.page_lock_unfairness = 5 1466 vm.panic_on_oom = 0 1467 vm.percpu_pagelist_fraction = 0 1468 vm.stat_interval = 1 1469 vm.swappiness = 100 1470 vm.user_reserve_kbytes = 115015 1471 vm.vfs_cache_pressure = 100 1472 vm.watermark_boost_factor = 15000 1473 vm.watermark_scale_factor = 10 1474 vm.zone_reclaim_mode = 0 1475 1476 ### ip addr: 1477 1478 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 1479 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 1480 inet XXX.XXX.0.1/8 scope host lo 1481 valid_lft forever preferred_lft forever 1482 inet6 ::1/128 scope host 1483 valid_lft forever preferred_lft forever 1484 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 1485 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 1486 1487 ### partitions: 1488 1489 major minor #blocks name 1490 1491 179 0 62367744 mmcblk0 1492 179 1 62366720 mmcblk0p1 1493 179 32 61071360 mmcblk1 1494 179 33 60456544 mmcblk1p1 1495 252 0 1859864 zram0 1496 252 1 51200 zram1 1497 8 0 120225792 sda 1498 8 1 120225760 sda1 1499 1500 ### df: 1501 1502 udev 1.4G 0 1.4G 0% /dev 1503 tmpfs 364M 5.0M 359M 2% /run 1504 /dev/mmcblk1p1 57G 20G 37G 36% / 1505 tmpfs 1.8G 0 1.8G 0% /dev/shm 1506 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 1507 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 1508 tmpfs 1.8G 0 1.8G 0% /tmp 1509 /dev/zram1 49M 2.9M 43M 7% /var/log 1510 1511 ### lsblk: 1512 1513 NAME FSTYPE SIZE MOUNTPOINT UUID 1514 sda 114.7G 1515 └─sda1 ntfs 114.7G 1CB8167CB816549C 1516 mmcblk0 59.5G 1517 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 1518 mmcblk1 58.2G 1519 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 1520 mmcblk1boot0 4M 1521 mmcblk1boot1 4M 1522 zram1 50M /var/log 1523 1524 ### zramctl: 1525 1526 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 1527 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 1528 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 1529 1530 ### mtab: 1531 1532 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 1533 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 1534 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 1535 1536 ### mmc0:aaaa info: 1537 1538 fwrev: 0x0 1539 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 1540 cid: 035344534836344780559b2001014a00 1541 rca: 0xaaaa 1542 csd: 400e0032db790001dbd37f800a404000 1543 manfid: 0x000003 1544 ocr: 0x00200000 1545 preferred_erase_size: 4194304 1546 type: SD 1547 hwrev: 0x8 1548 date: 10/2020 1549 dsr: 0x404 1550 erase_size: 512 1551 oemid: 0x5344 1552 serial: 0x559b2001 1553 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 1554 scr: 0245848300000000 1555 name: SH64G 1556 1557 ### mmc1:0001 info: 1558 1559 fwrev: 0x0400000000000000 1560 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 1561 cid: 150100434a54443452042559facb7700 1562 rel_sectors: 0x1 1563 enhanced_rpmb_supported: 0x1 1564 rca: 0x0001 1565 pre_eol_info: 0x01 1566 csd: d02701320f5903fff6dbffef8e404000 1567 manfid: 0x000015 1568 ocr: 0x00200000 1569 preferred_erase_size: 4194304 1570 enhanced_area_offset: 18446744073709551594 1571 raw_rpmb_size_mult: 0x20 1572 type: MMC 1573 hwrev: 0x0 1574 date: 07/2020 1575 prv: 0x4 1576 ffu_capable: 1 1577 dsr: 0x404 1578 erase_size: 524288 1579 life_time: 0x01 0x01 1580 enhanced_area_size: 4294967274 1581 oemid: 0x0100 1582 serial: 0x2559facb 1583 cmdq_en: 0 1584 rev: 0x8 1585 name: CJTD4R 1586 1587 ### Boot system health: 1588 1589 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 1590 18:36:31: 2400/2016MHz 0.16 23% 14% 7% 0% 1% 0% 24.3°C 0/12 1591 18:36:31: 2400/2016MHz 0.16 32% 22% 8% 1% 0% 0% 23.0°C 0/12 1592 18:36:32: 2400/2016MHz 0.16 18% 8% 9% 0% 0% 0% 22.1°C 0/12 1593 18:36:32: 2400/2016MHz 0.16 31% 16% 12% 0% 0% 0% 23.9°C 0/12 1594 18:36:32: 2400/2016MHz 0.16 89% 36% 31% 0% 17% 3% 25.4°C 0/12 1595 1596 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 1597 1598 ### Activated Armbian ramlog partition with zstd compression 1599 1600 Tue 30 Mar 2021 07:19:37 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 1601 1602 ### dmesg: 1603 1604 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 1605 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 1606 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 1607 [ 0.000000] efi: UEFI not found. 1608 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 1609 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 1610 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 1611 [ 0.000000] NUMA: No NUMA configuration found 1612 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 1613 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 1614 [ 0.000000] Zone ranges: 1615 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 1616 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 1617 [ 0.000000] Normal empty 1618 [ 0.000000] Movable zone start for each node 1619 [ 0.000000] Early memory node ranges 1620 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 1621 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 1622 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 1623 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 1624 [ 0.000000] On node 0 totalpages: 972800 1625 [ 0.000000] DMA zone: 4096 pages used for memmap 1626 [ 0.000000] DMA zone: 0 pages reserved 1627 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 1628 [ 0.000000] DMA32 zone: 11104 pages used for memmap 1629 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 1630 [ 0.000000] psci: probing for conduit method from DT. 1631 [ 0.000000] psci: PSCIv1.0 detected in firmware. 1632 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 1633 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 1634 [ 0.000000] psci: SMC Calling Convention v1.1 1635 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 1636 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 1637 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 1638 [ 0.000000] Detected VIPT I-cache on CPU0 1639 [ 0.000000] CPU features: detected: ARM erratum 845719 1640 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 1641 [ 0.000000] Policy zone: DMA32 1642 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 1643 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 1644 Please use sysfs to set IO scheduler for individual devices. 1645 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 1646 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 1647 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 1648 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 1649 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 1650 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 1651 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 1652 [ 0.000000] rcu: RCU event tracing is enabled. 1653 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 1654 [ 0.000000] Trampoline variant of Tasks RCU enabled. 1655 [ 0.000000] Rude variant of Tasks RCU enabled. 1656 [ 0.000000] Tracing variant of Tasks RCU enabled. 1657 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 1658 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 1659 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 1660 [ 0.000000] GIC: Using split EOI/Deactivate mode 1661 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 1662 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 1663 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 1664 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 1665 [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 1666 [ 0.000254] Console: colour dummy device 80x25 1667 [ 0.000288] printk: console [tty1] enabled 1668 [ 0.000376] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 1669 [ 0.000389] pid_max: default: 32768 minimum: 301 1670 [ 0.000473] LSM: Security Framework initializing 1671 [ 0.000499] Yama: becoming mindful. 1672 [ 0.000590] AppArmor: AppArmor initialized 1673 [ 0.000641] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 1674 [ 0.000660] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 1675 [ 0.002661] rcu: Hierarchical SRCU implementation. 1676 [ 0.005120] EFI services will not be available. 1677 [ 0.005543] smp: Bringing up secondary CPUs ... 1678 [ 0.006215] Detected VIPT I-cache on CPU1 1679 [ 0.006277] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 1680 [ 0.007468] CPU features: detected: ARM erratum 858921 1681 [ 0.007477] CPU features: detected: Spectre-v2 1682 [ 0.007481] CPU features: detected: Spectre-v4 1683 [ 0.007487] Detected VIPT I-cache on CPU2 1684 [ 0.007513] arch_timer: Enabling local workaround for ARM erratum 858921 1685 [ 0.007527] arch_timer: CPU2: Trapping CNTVCT access 1686 [ 0.007542] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 1687 [ 0.008253] Detected VIPT I-cache on CPU3 1688 [ 0.008269] arch_timer: Enabling local workaround for ARM erratum 858921 1689 [ 0.008276] arch_timer: CPU3: Trapping CNTVCT access 1690 [ 0.008284] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 1691 [ 0.008912] Detected VIPT I-cache on CPU4 1692 [ 0.008929] arch_timer: Enabling local workaround for ARM erratum 858921 1693 [ 0.008936] arch_timer: CPU4: Trapping CNTVCT access 1694 [ 0.008944] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 1695 [ 0.009557] Detected VIPT I-cache on CPU5 1696 [ 0.009574] arch_timer: Enabling local workaround for ARM erratum 858921 1697 [ 0.009580] arch_timer: CPU5: Trapping CNTVCT access 1698 [ 0.009589] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 1699 [ 0.009670] smp: Brought up 1 node, 6 CPUs 1700 [ 0.009687] SMP: Total of 6 processors activated. 1701 [ 0.009695] CPU features: detected: 32-bit EL0 Support 1702 [ 0.009700] CPU features: detected: CRC32 instructions 1703 [ 0.009706] CPU features: detected: 32-bit EL1 Support 1704 [ 0.020967] CPU: All CPU(s) started at EL2 1705 [ 0.021018] alternatives: patching kernel code 1706 [ 0.023019] devtmpfs: initialized 1707 [ 0.030692] Registered cp15_barrier emulation handler 1708 [ 0.030705] Registered setend emulation handler 1709 [ 0.030872] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 1710 [ 0.030916] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 1711 [ 0.046165] pinctrl core: initialized pinctrl subsystem 1712 [ 0.046911] DMI not present or invalid. 1713 [ 0.047281] NET: Registered protocol family 16 1714 [ 0.048877] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 1715 [ 0.049150] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 1716 [ 0.049384] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 1717 [ 0.049425] audit: initializing netlink subsys (disabled) 1718 [ 0.049519] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 1719 [ 0.050793] thermal_sys: Registered thermal governor 'fair_share' 1720 [ 0.050800] thermal_sys: Registered thermal governor 'bang_bang' 1721 [ 0.050804] thermal_sys: Registered thermal governor 'step_wise' 1722 [ 0.050807] thermal_sys: Registered thermal governor 'user_space' 1723 [ 0.051239] cpuidle: using governor menu 1724 [ 0.051584] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 1725 [ 0.051707] ASID allocator initialised with 65536 entries 1726 [ 0.052705] Serial: AMBA PL011 UART driver 1727 [ 0.086561] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 1728 [ 0.086572] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 1729 [ 0.086577] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 1730 [ 0.086581] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 1731 [ 0.089033] cryptd: max_cpu_qlen set to 1000 1732 [ 0.156247] raid6: neonx8 gen() 2780 MB/s 1733 [ 0.224285] raid6: neonx8 xor() 2041 MB/s 1734 [ 0.292351] raid6: neonx4 gen() 2996 MB/s 1735 [ 0.360413] raid6: neonx4 xor() 2346 MB/s 1736 [ 0.428477] raid6: neonx2 gen() 2581 MB/s 1737 [ 0.496540] raid6: neonx2 xor() 2131 MB/s 1738 [ 0.564603] raid6: neonx1 gen() 1965 MB/s 1739 [ 0.632669] raid6: neonx1 xor() 1721 MB/s 1740 [ 0.700737] raid6: int64x8 gen() 1376 MB/s 1741 [ 0.768802] raid6: int64x8 xor() 735 MB/s 1742 [ 0.836884] raid6: int64x4 gen() 1463 MB/s 1743 [ 0.904930] raid6: int64x4 xor() 733 MB/s 1744 [ 0.972995] raid6: int64x2 gen() 1363 MB/s 1745 [ 1.041047] raid6: int64x2 xor() 619 MB/s 1746 [ 1.109109] raid6: int64x1 gen() 1127 MB/s 1747 [ 1.177172] raid6: int64x1 xor() 462 MB/s 1748 [ 1.177176] raid6: using algorithm neonx4 gen() 2996 MB/s 1749 [ 1.177179] raid6: .... xor() 2346 MB/s, rmw enabled 1750 [ 1.177183] raid6: using neon recovery algorithm 1751 [ 1.177662] ACPI: Interpreter disabled. 1752 [ 1.178444] 5V: supplied by 12V 1753 [ 1.179346] VDDAO_3V3: supplied by 12V 1754 [ 1.179821] iommu: Default domain type: Translated 1755 [ 1.179954] vgaarb: loaded 1756 [ 1.181008] SCSI subsystem initialized 1757 [ 1.181310] usbcore: registered new interface driver usbfs 1758 [ 1.181348] usbcore: registered new interface driver hub 1759 [ 1.181389] usbcore: registered new device driver usb 1760 [ 1.181640] pps_core: LinuxPPS API ver. 1 registered 1761 [ 1.181643] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 1762 [ 1.181670] PTP clock support registered 1763 [ 1.181859] EDAC MC: Ver: 3.0.0 1764 [ 1.183187] NetLabel: Initializing 1765 [ 1.183195] NetLabel: domain hash size = 128 1766 [ 1.183197] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 1767 [ 1.183237] NetLabel: unlabeled traffic allowed by default 1768 [ 1.183696] clocksource: Switched to clocksource arch_sys_counter 1769 [ 1.183906] VFS: Disk quotas dquot_6.6.0 1770 [ 1.183949] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 1771 [ 1.184375] AppArmor: AppArmor Filesystem Enabled 1772 [ 1.184424] pnp: PnP ACPI: disabled 1773 [ 1.189882] NET: Registered protocol family 2 1774 [ 1.190317] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 1775 [ 1.190421] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 1776 [ 1.190677] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 1777 [ 1.190865] TCP: Hash tables configured (established 32768 bind 32768) 1778 [ 1.191018] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 1779 [ 1.191082] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 1780 [ 1.191128] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 1781 [ 1.191272] NET: Registered protocol family 1 1782 [ 1.191291] PCI: CLS 0 bytes, default 64 1783 [ 1.191414] Trying to unpack rootfs image as initramfs... 1784 [ 1.758556] Freeing initrd memory: 14920K 1785 [ 1.759490] kvm [1]: IPA Size Limit: 40 bits 1786 [ 1.760229] kvm [1]: vgic interrupt IRQ9 1787 [ 1.760362] kvm [1]: Hyp mode initialized successfully 1788 [ 1.765564] Initialise system trusted keyrings 1789 [ 1.765600] Key type blacklist registered 1790 [ 1.765739] workingset: timestamp_bits=44 max_order=20 bucket_order=0 1791 [ 1.768922] zbud: loaded 1792 [ 1.769905] squashfs: version 4.0 (2009/01/31) Phillip Lougher 1793 [ 1.770374] fuse: init (API version 7.32) 1794 [ 1.771123] integrity: Platform Keyring initialized 1795 [ 1.798598] xor: measuring software checksum speed 1796 [ 1.801544] 8regs : 3476 MB/sec 1797 [ 1.804000] 32regs : 4019 MB/sec 1798 [ 1.806648] arm64_neon : 3720 MB/sec 1799 [ 1.806651] xor: using function: 32regs (4019 MB/sec) 1800 [ 1.806659] Key type asymmetric registered 1801 [ 1.806663] Asymmetric key parser 'x509' registered 1802 [ 1.806701] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 1803 [ 1.806813] io scheduler mq-deadline registered 1804 [ 1.806817] io scheduler kyber registered 1805 [ 1.806905] io scheduler bfq registered 1806 [ 1.809470] gpio-447 (usb-hub-reset): hogged as output/high 1807 [ 1.812475] EINJ: ACPI disabled. 1808 [ 1.818686] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 1809 [ 1.820149] VCC_3V3: supplied by VDDAO_3V3 1810 [ 1.820182] FLASH_1V8: supplied by VCC_3V3 1811 [ 1.820228] VCC_1V8: supplied by VCC_3V3 1812 [ 1.820254] VDDAO_1V8: supplied by VDDAO_3V3 1813 [ 1.820285] VDDCPU_A: supplied by regulator-dummy 1814 [ 1.820640] VDDCPU_B: supplied by regulator-dummy 1815 [ 1.821364] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 1816 [ 1.823744] Serial: AMBA driver 1817 [ 1.824064] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 1818 [ 1.824155] printk: console [ttyAML0] enabled 1819 [ 1.824668] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 1820 [ 1.829914] loop: module loaded 1821 [ 1.831806] libphy: Fixed MDIO Bus: probed 1822 [ 1.832759] tun: Universal TUN/TAP device driver, 1.6 1823 [ 1.833454] thunder_xcv, ver 1.0 1824 [ 1.833484] thunder_bgx, ver 1.0 1825 [ 1.833510] nicpf, ver 1.0 1826 [ 1.833960] e1000e: Intel(R) PRO/1000 Network Driver 1827 [ 1.833963] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 1828 [ 1.833998] igb: Intel(R) Gigabit Ethernet Network Driver 1829 [ 1.834001] igb: Copyright (c) 2007-2014 Intel Corporation. 1830 [ 1.834035] igbvf: Intel(R) Gigabit Virtual Function Network Driver 1831 [ 1.834038] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 1832 [ 1.834159] sky2: driver version 1.30 1833 [ 1.834502] VFIO - User Level meta-driver version: 0.3 1834 [ 1.835929] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 1835 [ 1.835947] ehci-pci: EHCI PCI platform driver 1836 [ 1.835980] ehci-platform: EHCI generic platform driver 1837 [ 1.836114] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 1838 [ 1.836124] ohci-pci: OHCI PCI platform driver 1839 [ 1.836156] ohci-platform: OHCI generic platform driver 1840 [ 1.836577] usbcore: registered new interface driver usb-storage 1841 [ 1.837903] mousedev: PS/2 mouse device common for all mice 1842 [ 1.838279] i2c /dev entries driver 1843 [ 1.843598] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 1844 [ 1.844512] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 1845 [ 1.845180] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 1846 [ 1.845750] sdhci: Secure Digital Host Controller Interface driver 1847 [ 1.845754] sdhci: Copyright(c) Pierre Ossman 1848 [ 1.845835] Synopsys Designware Multimedia Card Interface Driver 1849 [ 1.846184] sdhci-pltfm: SDHCI platform and OF driver helper 1850 [ 1.846560] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 1851 [ 1.846901] ledtrig-cpu: registered to indicate activity on CPUs 1852 [ 1.847112] meson-sm: secure-monitor enabled 1853 [ 1.847487] hid: raw HID events driver (C) Jiri Kosina 1854 [ 1.847564] usbcore: registered new interface driver usbhid 1855 [ 1.847565] usbhid: USB HID core driver 1856 [ 1.848535] NET: Registered protocol family 10 1857 [ 1.848936] Segment Routing with IPv6 1858 [ 1.848961] NET: Registered protocol family 17 1859 [ 1.849020] 8021q: 802.1Q VLAN Support v1.8 1860 [ 1.849044] Key type dns_resolver registered 1861 [ 1.849280] registered taskstats version 1 1862 [ 1.849284] Loading compiled-in X.509 certificates 1863 [ 1.850697] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 1864 [ 1.852180] zswap: loaded using pool zstd/z3fold 1865 [ 1.852356] Key type ._fscrypt registered 1866 [ 1.852358] Key type .fscrypt registered 1867 [ 1.852359] Key type fscrypt-provisioning registered 1868 [ 1.853372] Btrfs loaded, crc32c=crc32c-generic 1869 [ 1.858569] Key type encrypted registered 1870 [ 1.858580] AppArmor: AppArmor sha1 policy hashing enabled 1871 [ 1.864196] HUB_5V: supplied by 5V 1872 [ 1.864374] USB_PWR_EN: supplied by 5V 1873 [ 1.865796] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 1874 [ 1.865803] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 1875 [ 1.868467] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 1876 [ 1.868519] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 1877 [ 1.868603] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 1878 [ 1.869106] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 1879 [ 1.869116] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 1880 [ 1.869195] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 1881 [ 1.869214] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 1882 [ 1.869326] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 1883 [ 1.869329] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1884 [ 1.869331] usb usb1: Product: xHCI Host Controller 1885 [ 1.869333] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 1886 [ 1.869335] usb usb1: SerialNumber: xhci-hcd.0.auto 1887 [ 1.869499] hub 1-0:1.0: USB hub found 1888 [ 1.869510] hub 1-0:1.0: 2 ports detected 1889 [ 1.869617] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 1890 [ 1.869622] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 1891 [ 1.869627] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 1892 [ 1.869644] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 1893 [ 1.869676] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 1894 [ 1.869678] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1895 [ 1.869680] usb usb2: Product: xHCI Host Controller 1896 [ 1.869682] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 1897 [ 1.869683] usb usb2: SerialNumber: xhci-hcd.0.auto 1898 [ 1.869799] hub 2-0:1.0: USB hub found 1899 [ 1.869807] hub 2-0:1.0: 1 port detected 1900 [ 1.870074] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 1901 [ 1.870830] meson-gx-mmc ffe05000.sd: Got CD GPIO 1902 [ 1.896882] Freeing unused kernel memory: 3328K 1903 [ 1.935848] Run /init as init process 1904 [ 1.935851] with arguments: 1905 [ 1.935852] /init 1906 [ 1.935854] with environment: 1907 [ 1.935855] HOME=/ 1908 [ 1.935857] TERM=linux 1909 [ 1.935858] hdmimode=custombuilt 1910 [ 1.935859] cvbsmode=576cvbs 1911 [ 1.935860] max_freq_a53=1908 1912 [ 1.935862] max_freq_a73=2208 1913 [ 1.935863] voutmode=hdmi 1914 [ 1.935864] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 1915 [ 1.935865] disablehpd=false 1916 [ 1.935866] cvbscable= 1917 [ 1.935867] overscan=100 1918 [ 2.065855] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 1919 [ 2.065863] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 1920 [ 2.065959] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 1921 [ 2.067807] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 1922 [ 2.067824] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 1923 [ 2.067829] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 1924 [ 2.067832] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 1925 [ 2.067836] meson8b-dwmac ff3f0000.ethernet: COE Type 2 1926 [ 2.067839] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 1927 [ 2.067841] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 1928 [ 2.067933] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 1929 [ 2.067937] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 1930 [ 2.067940] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 1931 [ 2.068441] libphy: stmmac: probed 1932 [ 2.070641] libphy: mdio_mux: probed 1933 [ 2.081196] meson-vrtc ff8000a8.rtc: registered as rtc1 1934 [ 2.088255] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 1935 [ 2.090511] rtc-pcf8563 1-0051: registered as rtc0 1936 [ 2.091897] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 1937 [ 2.091905] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 1938 [ 2.095558] mmc1: new HS200 MMC card at address 0001 1939 [ 2.096527] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 1940 [ 2.097121] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 1941 [ 2.097674] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 1942 [ 2.097857] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 1943 [ 2.100224] mmcblk1: p1 1944 [ 2.122847] random: fast init done 1945 [ 2.133754] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 1946 [ 2.134296] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 1947 [ 2.136148] mmcblk0: p1 1948 [ 2.203716] usb 1-1: new high-speed USB device number 2 using xhci-hcd 1949 [ 2.276294] libphy: mdio_mux: probed 1950 [ 2.354056] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 1951 [ 2.354062] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1952 [ 2.354065] usb 1-1: Product: USB2.1 Hub 1953 [ 2.354067] usb 1-1: Manufacturer: GenesysLogic 1954 [ 2.413843] hub 1-1:1.0: USB hub found 1955 [ 2.414073] hub 1-1:1.0: 4 ports detected 1956 [ 2.479812] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 1957 [ 2.502290] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 1958 [ 2.502295] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1959 [ 2.502297] usb 2-1: Product: USB3.1 Hub 1960 [ 2.502299] usb 2-1: Manufacturer: GenesysLogic 1961 [ 2.525819] hub 2-1:1.0: USB hub found 1962 [ 2.526101] hub 2-1:1.0: 4 ports detected 1963 [ 2.669515] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 1964 [ 2.787714] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 1965 [ 2.842583] systemd[1]: System time before build time, advancing clock. 1966 [ 2.846160] systemd[1]: Inserted module 'autofs4' 1967 [ 2.862923] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 1968 [ 2.863111] systemd[1]: Detected architecture arm64. 1969 [ 2.885873] systemd[1]: Set hostname to <odroidn2>. 1970 [ 2.919284] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 1971 [ 2.919298] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 1972 [ 2.919301] usb 1-1.1: Product: USB OPTICAL MOUSE 1973 [ 2.960301] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 1974 [ 2.960514] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 1975 [ 3.030590] random: systemd: uninitialized urandom read (16 bytes read) 1976 [ 3.033164] random: systemd: uninitialized urandom read (16 bytes read) 1977 [ 3.034274] systemd[1]: Created slice system-serial\x2dgetty.slice. 1978 [ 3.034476] random: systemd: uninitialized urandom read (16 bytes read) 1979 [ 3.034547] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 1980 [ 3.034884] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. 1981 [ 3.035144] systemd[1]: Listening on Journal Socket (/dev/log). 1982 [ 3.035324] systemd[1]: Listening on fsck to fsckd communication Socket. 1983 [ 3.035395] systemd[1]: Reached target Remote File Systems. 1984 [ 3.035454] systemd[1]: Reached target Swap. 1985 [ 3.063751] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 1986 [ 3.077893] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 1987 [ 3.192970] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 1988 [ 3.192981] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 1989 [ 3.192985] usb 1-1.3: Product: USB Keyboard 1990 [ 3.192989] usb 1-1.3: Manufacturer: Logitech 1991 [ 3.250707] zram: Added device: zram0 1992 [ 3.251422] zram: Added device: zram1 1993 [ 3.251721] zram: Added device: zram2 1994 [ 3.292846] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 1995 [ 3.303839] zram0: detected capacity change from 0 to 1904500736 1996 [ 3.341790] pwm-gpio pwmgpio: 1 gpio pwms loaded 1997 [ 3.352438] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 1998 [ 3.361738] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 1999 [ 3.397180] mc: Linux media interface: v0.10 2000 [ 3.409332] videodev: Linux video capture interface: v2.00 2001 [ 3.420128] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 2002 [ 3.420340] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 2003 [ 3.433897] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 2004 [ 3.453855] meson-drm ff900000.vpu: Queued 2 outputs on vpu 2005 [ 3.455917] panfrost ffe40000.gpu: clock rate = 24000000 2006 [ 3.456075] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 2007 [ 3.457243] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 2008 [ 3.457255] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 2009 [ 3.457260] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 2010 [ 3.457264] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 2011 [ 3.462370] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 2012 [ 3.462517] meson-drm ff900000.vpu: CVBS Output connector not available 2013 [ 3.483729] Registered IR keymap rc-odroid 2014 [ 3.489276] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0 2015 [ 3.491922] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 2016 [ 3.493144] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 2017 [ 3.493371] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 2018 [ 3.493553] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1 2019 [ 3.495229] IR NEC protocol handler initialized 2020 [ 3.523989] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 2021 [ 3.524198] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 2022 [ 3.524342] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 2023 [ 3.525432] meson-ir ff808000.ir: receiver initialized 2024 [ 3.667713] usb 1-1.2: new high-speed USB device number 5 using xhci-hcd 2025 [ 3.776516] Console: switching to colour frame buffer device 240x67 2026 [ 3.792004] usb 1-1.2: New USB device found, idVendor=0781, idProduct=55a1, bcdDevice= 1.00 2027 [ 3.792009] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 2028 [ 3.792012] usb 1-1.2: Product: Cruzer Spark 2029 [ 3.792015] usb 1-1.2: Manufacturer: SanDisk 2030 [ 3.792017] usb 1-1.2: SerialNumber: 4C530001231009114503 2031 [ 3.792733] usb-storage 1-1.2:1.0: USB Mass Storage device detected 2032 [ 3.792989] scsi host0: usb-storage 1-1.2:1.0 2033 [ 3.798444] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 2034 [ 3.812455] usbcore: registered new interface driver uas 2035 [ 3.848746] axg-sound-card sound: ASoC: no DMI vendor name! 2036 [ 4.335710] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 2037 [ 4.374989] zram1: detected capacity change from 0 to 52428800 2038 [ 4.800599] scsi 0:0:0:0: Direct-Access SanDisk Cruzer Spark 1.00 PQ: 0 ANSI: 6 2039 [ 4.801626] sd 0:0:0:0: [sda] 240451584 512-byte logical blocks: (123 GB/115 GiB) 2040 [ 4.802834] sd 0:0:0:0: [sda] Write Protect is off 2041 [ 4.802838] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 2042 [ 4.803115] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA 2043 [ 4.806739] sd 0:0:0:0: Attached scsi generic sg0 type 0 2044 [ 4.827149] sda: sda1 2045 [ 4.829583] sd 0:0:0:0: [sda] Attached SCSI removable disk 2046 [ 6.420264] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 2047 [ 6.420286] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 2048 [ 7.311846] systemd-journald[1865]: Received request to flush runtime journal from PID 1 2049 2050 ### armbian-release: 2051 2052 # PLEASE DO NOT EDIT THIS FILE 2053 BOARD=odroidn2 2054 BOARD_NAME="Odroid N2" 2055 BOARDFAMILY=meson-g12b 2056 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 2057 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 2058 DISTRIBUTION_CODENAME=buster 2059 DISTRIBUTION_STATUS=supported 2060 VERSION=21.02.3 2061 LINUXFAMILY=meson64 2062 BRANCH=current 2063 ARCH=arm64 2064 IMAGE_TYPE=stable 2065 BOARD_TYPE=conf 2066 INITRD_ARCH=arm64 2067 KERNEL_IMAGE_TYPE=Image 2068 2069 ### boot environment: 2070 2071 verbosity=1 2072 console=both 2073 overlay_prefix=meson 2074 bootlogo=true 2075 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 2076 rootfstype=ext4 2077 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 2078 2079 ### lsusb: 2080 2081 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 2082 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 2083 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 2084 Bus 001 Device 005: ID 0781:55a1 SanDisk Corp. 2085 Bus 001 Device 003: ID 275d:0ba6 2086 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 2087 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2088 2089 ### lscpu: 2090 2091 Architecture: aarch64 2092 Byte Order: Little Endian 2093 CPU(s): 6 2094 On-line CPU(s) list: 0-5 2095 Thread(s) per core: 1 2096 Core(s) per socket: 3 2097 Socket(s): 2 2098 NUMA node(s): 1 2099 Vendor ID: ARM 2100 Model: 4 2101 Model name: Cortex-A53 2102 Stepping: r0p4 2103 CPU max MHz: 2400.0000 2104 CPU min MHz: 100.0000 2105 BogoMIPS: 48.00 2106 L1d cache: unknown size 2107 L1i cache: unknown size 2108 L2 cache: unknown size 2109 NUMA node0 CPU(s): 0-5 2110 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2111 2112 ### cpuinfo: 2113 2114 processor : 0 2115 BogoMIPS : 48.00 2116 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2117 CPU implementer : 0x41 2118 CPU architecture: 8 2119 CPU variant : 0x0 2120 CPU part : 0xd03 2121 CPU revision : 4 2122 2123 processor : 1 2124 BogoMIPS : 48.00 2125 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2126 CPU implementer : 0x41 2127 CPU architecture: 8 2128 CPU variant : 0x0 2129 CPU part : 0xd03 2130 CPU revision : 4 2131 2132 processor : 2 2133 BogoMIPS : 48.00 2134 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2135 CPU implementer : 0x41 2136 CPU architecture: 8 2137 CPU variant : 0x0 2138 CPU part : 0xd09 2139 CPU revision : 2 2140 2141 processor : 3 2142 BogoMIPS : 48.00 2143 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2144 CPU implementer : 0x41 2145 CPU architecture: 8 2146 CPU variant : 0x0 2147 CPU part : 0xd09 2148 CPU revision : 2 2149 2150 processor : 4 2151 BogoMIPS : 48.00 2152 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2153 CPU implementer : 0x41 2154 CPU architecture: 8 2155 CPU variant : 0x0 2156 CPU part : 0xd09 2157 CPU revision : 2 2158 2159 processor : 5 2160 BogoMIPS : 48.00 2161 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2162 CPU implementer : 0x41 2163 CPU architecture: 8 2164 CPU variant : 0x0 2165 CPU part : 0xd09 2166 CPU revision : 2 2167 2168 2169 ### meminfo: 2170 2171 MemTotal: 3719724 kB 2172 MemFree: 3393612 kB 2173 MemAvailable: 3353612 kB 2174 Buffers: 12544 kB 2175 Cached: 55512 kB 2176 SwapCached: 0 kB 2177 Active: 33408 kB 2178 Inactive: 174352 kB 2179 Active(anon): 128 kB 2180 Inactive(anon): 144816 kB 2181 Active(file): 33280 kB 2182 Inactive(file): 29536 kB 2183 Unevictable: 0 kB 2184 Mlocked: 0 kB 2185 SwapTotal: 1859860 kB 2186 SwapFree: 1859860 kB 2187 Dirty: 8304 kB 2188 Writeback: 0 kB 2189 AnonPages: 140204 kB 2190 Mapped: 14460 kB 2191 Shmem: 4948 kB 2192 KReclaimable: 13904 kB 2193 Slab: 46248 kB 2194 SReclaimable: 13904 kB 2195 SUnreclaim: 32344 kB 2196 KernelStack: 2704 kB 2197 PageTables: 5368 kB 2198 NFS_Unstable: 0 kB 2199 Bounce: 0 kB 2200 WritebackTmp: 0 kB 2201 CommitLimit: 3719720 kB 2202 Committed_AS: 4249992 kB 2203 VmallocTotal: 135290159040 kB 2204 VmallocUsed: 31572 kB 2205 VmallocChunk: 0 kB 2206 Percpu: 1464 kB 2207 HardwareCorrupted: 0 kB 2208 AnonHugePages: 0 kB 2209 ShmemHugePages: 0 kB 2210 ShmemPmdMapped: 0 kB 2211 FileHugePages: 0 kB 2212 FilePmdMapped: 0 kB 2213 CmaTotal: 917504 kB 2214 CmaFree: 901724 kB 2215 HugePages_Total: 0 2216 HugePages_Free: 0 2217 HugePages_Rsvd: 0 2218 HugePages_Surp: 0 2219 Hugepagesize: 2048 kB 2220 Hugetlb: 0 kB 2221 2222 ### virtual memory: 2223 2224 vm.admin_reserve_kbytes = 8192 2225 vm.block_dump = 0 2226 vm.compaction_proactiveness = 20 2227 vm.compact_unevictable_allowed = 1 2228 vm.dirty_background_bytes = 0 2229 vm.dirty_background_ratio = 10 2230 vm.dirty_bytes = 0 2231 vm.dirty_expire_centisecs = 3000 2232 vm.dirty_ratio = 20 2233 vm.dirtytime_expire_seconds = 43200 2234 vm.dirty_writeback_centisecs = 500 2235 vm.extfrag_threshold = 500 2236 vm.hugetlb_shm_group = 0 2237 vm.laptop_mode = 0 2238 vm.legacy_va_layout = 0 2239 vm.lowmem_reserve_ratio = 256 256 32 0 2240 vm.max_map_count = 65530 2241 vm.memory_failure_early_kill = 0 2242 vm.memory_failure_recovery = 1 2243 vm.min_free_kbytes = 45056 2244 vm.min_slab_ratio = 5 2245 vm.min_unmapped_ratio = 1 2246 vm.mmap_min_addr = 4096 2247 vm.mmap_rnd_bits = 18 2248 vm.mmap_rnd_compat_bits = 11 2249 vm.nr_hugepages = 0 2250 vm.nr_hugepages_mempolicy = 0 2251 vm.nr_overcommit_hugepages = 0 2252 vm.numa_stat = 1 2253 vm.numa_zonelist_order = Node 2254 vm.oom_dump_tasks = 1 2255 vm.oom_kill_allocating_task = 0 2256 vm.overcommit_kbytes = 0 2257 vm.overcommit_memory = 0 2258 vm.overcommit_ratio = 50 2259 vm.page-cluster = 0 2260 vm.page_lock_unfairness = 5 2261 vm.panic_on_oom = 0 2262 vm.percpu_pagelist_fraction = 0 2263 vm.stat_interval = 1 2264 vm.swappiness = 100 2265 vm.user_reserve_kbytes = 114935 2266 vm.vfs_cache_pressure = 100 2267 vm.watermark_boost_factor = 15000 2268 vm.watermark_scale_factor = 10 2269 vm.zone_reclaim_mode = 0 2270 2271 ### ip addr: 2272 2273 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 2274 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2275 inet XXX.XXX.0.1/8 scope host lo 2276 valid_lft forever preferred_lft forever 2277 inet6 ::1/128 scope host 2278 valid_lft forever preferred_lft forever 2279 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 2280 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 2281 2282 ### partitions: 2283 2284 major minor #blocks name 2285 2286 179 0 61071360 mmcblk1 2287 179 1 60456544 mmcblk1p1 2288 179 96 62367744 mmcblk0 2289 179 97 62366720 mmcblk0p1 2290 252 0 1859864 zram0 2291 252 1 51200 zram1 2292 8 0 120225792 sda 2293 8 1 120225760 sda1 2294 2295 ### df: 2296 2297 udev 1.4G 0 1.4G 0% /dev 2298 tmpfs 364M 5.0M 359M 2% /run 2299 /dev/mmcblk1p1 57G 20G 37G 36% / 2300 tmpfs 1.8G 0 1.8G 0% /dev/shm 2301 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 2302 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 2303 tmpfs 1.8G 0 1.8G 0% /tmp 2304 /dev/zram1 49M 8.3M 37M 19% /var/log 2305 2306 ### lsblk: 2307 2308 NAME FSTYPE SIZE MOUNTPOINT UUID 2309 sda 114.7G 2310 └─sda1 ntfs 114.7G 1CB8167CB816549C 2311 mmcblk1 58.2G 2312 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 2313 mmcblk1boot0 4M 2314 mmcblk1boot1 4M 2315 mmcblk0 59.5G 2316 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 2317 zram1 50M /var/log 2318 2319 ### zramctl: 2320 2321 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2322 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 2323 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 2324 2325 ### mtab: 2326 2327 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2328 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 2329 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 2330 2331 ### mmc0:aaaa info: 2332 2333 fwrev: 0x0 2334 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 2335 cid: 035344534836344780559b2001014a00 2336 rca: 0xaaaa 2337 csd: 400e0032db790001dbd37f800a404000 2338 manfid: 0x000003 2339 ocr: 0x00200000 2340 preferred_erase_size: 4194304 2341 type: SD 2342 hwrev: 0x8 2343 date: 10/2020 2344 dsr: 0x404 2345 erase_size: 512 2346 oemid: 0x5344 2347 serial: 0x559b2001 2348 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 2349 scr: 0245848300000000 2350 name: SH64G 2351 2352 ### mmc1:0001 info: 2353 2354 fwrev: 0x0400000000000000 2355 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 2356 cid: 150100434a54443452042559facb7700 2357 rel_sectors: 0x1 2358 enhanced_rpmb_supported: 0x1 2359 rca: 0x0001 2360 pre_eol_info: 0x01 2361 csd: d02701320f5903fff6dbffef8e404000 2362 manfid: 0x000015 2363 ocr: 0x00200000 2364 preferred_erase_size: 4194304 2365 enhanced_area_offset: 18446744073709551594 2366 raw_rpmb_size_mult: 0x20 2367 type: MMC 2368 hwrev: 0x0 2369 date: 07/2020 2370 prv: 0x4 2371 ffu_capable: 1 2372 dsr: 0x404 2373 erase_size: 524288 2374 life_time: 0x01 0x01 2375 enhanced_area_size: 4294967274 2376 oemid: 0x0100 2377 serial: 0x2559facb 2378 cmdq_en: 0 2379 rev: 0x8 2380 name: CJTD4R 2381 2382 ### Boot system health: 2383 2384 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 2385 19:19:38: 2400/2016MHz 0.16 22% 14% 6% 0% 1% 0% 24.9°C 0/12 2386 19:19:38: 2400/2016MHz 0.16 36% 24% 10% 0% 0% 0% 24.9°C 0/12 2387 19:19:39: 2400/2016MHz 0.16 18% 7% 10% 0% 0% 0% 22.2°C 0/12 2388 19:19:39: 2400/2016MHz 0.16 19% 8% 10% 0% 0% 1% 21.8°C 0/12 2389 19:19:39: 2400/2016MHz 0.16 76% 41% 18% 0% 14% 1% 24.1°C 0/12 2390 2391 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 2392 2393 ### Activated Armbian ramlog partition with zstd compression 2394 2395 Tue 30 Mar 2021 07:19:37 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 2396 2397 ### dmesg: 2398 2399 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 2400 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 2401 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 2402 [ 0.000000] efi: UEFI not found. 2403 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 2404 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 2405 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 2406 [ 0.000000] NUMA: No NUMA configuration found 2407 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 2408 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 2409 [ 0.000000] Zone ranges: 2410 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 2411 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 2412 [ 0.000000] Normal empty 2413 [ 0.000000] Movable zone start for each node 2414 [ 0.000000] Early memory node ranges 2415 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 2416 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 2417 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 2418 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 2419 [ 0.000000] On node 0 totalpages: 972800 2420 [ 0.000000] DMA zone: 4096 pages used for memmap 2421 [ 0.000000] DMA zone: 0 pages reserved 2422 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 2423 [ 0.000000] DMA32 zone: 11104 pages used for memmap 2424 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 2425 [ 0.000000] psci: probing for conduit method from DT. 2426 [ 0.000000] psci: PSCIv1.0 detected in firmware. 2427 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 2428 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 2429 [ 0.000000] psci: SMC Calling Convention v1.1 2430 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 2431 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 2432 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 2433 [ 0.000000] Detected VIPT I-cache on CPU0 2434 [ 0.000000] CPU features: detected: ARM erratum 845719 2435 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 2436 [ 0.000000] Policy zone: DMA32 2437 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 2438 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 2439 Please use sysfs to set IO scheduler for individual devices. 2440 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 2441 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 2442 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 2443 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 2444 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 2445 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 2446 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 2447 [ 0.000000] rcu: RCU event tracing is enabled. 2448 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 2449 [ 0.000000] Trampoline variant of Tasks RCU enabled. 2450 [ 0.000000] Rude variant of Tasks RCU enabled. 2451 [ 0.000000] Tracing variant of Tasks RCU enabled. 2452 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 2453 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 2454 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 2455 [ 0.000000] GIC: Using split EOI/Deactivate mode 2456 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 2457 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 2458 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 2459 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 2460 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 2461 [ 0.000253] Console: colour dummy device 80x25 2462 [ 0.000288] printk: console [tty1] enabled 2463 [ 0.000373] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 2464 [ 0.000386] pid_max: default: 32768 minimum: 301 2465 [ 0.000467] LSM: Security Framework initializing 2466 [ 0.000492] Yama: becoming mindful. 2467 [ 0.000582] AppArmor: AppArmor initialized 2468 [ 0.000632] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 2469 [ 0.000651] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 2470 [ 0.002657] rcu: Hierarchical SRCU implementation. 2471 [ 0.005133] EFI services will not be available. 2472 [ 0.005556] smp: Bringing up secondary CPUs ... 2473 [ 0.006232] Detected VIPT I-cache on CPU1 2474 [ 0.006293] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 2475 [ 0.007486] CPU features: detected: ARM erratum 858921 2476 [ 0.007494] CPU features: detected: Spectre-v2 2477 [ 0.007498] CPU features: detected: Spectre-v4 2478 [ 0.007504] Detected VIPT I-cache on CPU2 2479 [ 0.007528] arch_timer: Enabling local workaround for ARM erratum 858921 2480 [ 0.007543] arch_timer: CPU2: Trapping CNTVCT access 2481 [ 0.007557] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 2482 [ 0.008267] Detected VIPT I-cache on CPU3 2483 [ 0.008283] arch_timer: Enabling local workaround for ARM erratum 858921 2484 [ 0.008290] arch_timer: CPU3: Trapping CNTVCT access 2485 [ 0.008298] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 2486 [ 0.008925] Detected VIPT I-cache on CPU4 2487 [ 0.008941] arch_timer: Enabling local workaround for ARM erratum 858921 2488 [ 0.008948] arch_timer: CPU4: Trapping CNTVCT access 2489 [ 0.008956] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 2490 [ 0.009575] Detected VIPT I-cache on CPU5 2491 [ 0.009591] arch_timer: Enabling local workaround for ARM erratum 858921 2492 [ 0.009598] arch_timer: CPU5: Trapping CNTVCT access 2493 [ 0.009606] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 2494 [ 0.009686] smp: Brought up 1 node, 6 CPUs 2495 [ 0.009704] SMP: Total of 6 processors activated. 2496 [ 0.009712] CPU features: detected: 32-bit EL0 Support 2497 [ 0.009718] CPU features: detected: CRC32 instructions 2498 [ 0.009723] CPU features: detected: 32-bit EL1 Support 2499 [ 0.020997] CPU: All CPU(s) started at EL2 2500 [ 0.021047] alternatives: patching kernel code 2501 [ 0.023051] devtmpfs: initialized 2502 [ 0.030728] Registered cp15_barrier emulation handler 2503 [ 0.030742] Registered setend emulation handler 2504 [ 0.030906] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 2505 [ 0.030951] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 2506 [ 0.046226] pinctrl core: initialized pinctrl subsystem 2507 [ 0.046961] DMI not present or invalid. 2508 [ 0.047334] NET: Registered protocol family 16 2509 [ 0.048926] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 2510 [ 0.049198] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 2511 [ 0.049434] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 2512 [ 0.049476] audit: initializing netlink subsys (disabled) 2513 [ 0.049570] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 2514 [ 0.050789] thermal_sys: Registered thermal governor 'fair_share' 2515 [ 0.050796] thermal_sys: Registered thermal governor 'bang_bang' 2516 [ 0.050800] thermal_sys: Registered thermal governor 'step_wise' 2517 [ 0.050803] thermal_sys: Registered thermal governor 'user_space' 2518 [ 0.051249] cpuidle: using governor menu 2519 [ 0.051593] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 2520 [ 0.051726] ASID allocator initialised with 65536 entries 2521 [ 0.052725] Serial: AMBA PL011 UART driver 2522 [ 0.085537] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 2523 [ 0.085550] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 2524 [ 0.085555] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 2525 [ 0.085561] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 2526 [ 0.088339] cryptd: max_cpu_qlen set to 1000 2527 [ 0.156245] raid6: neonx8 gen() 2779 MB/s 2528 [ 0.224325] raid6: neonx8 xor() 2041 MB/s 2529 [ 0.292359] raid6: neonx4 gen() 3151 MB/s 2530 [ 0.360431] raid6: neonx4 xor() 2399 MB/s 2531 [ 0.428507] raid6: neonx2 gen() 2562 MB/s 2532 [ 0.496573] raid6: neonx2 xor() 2189 MB/s 2533 [ 0.564639] raid6: neonx1 gen() 1925 MB/s 2534 [ 0.632702] raid6: neonx1 xor() 1728 MB/s 2535 [ 0.700768] raid6: int64x8 gen() 1374 MB/s 2536 [ 0.768825] raid6: int64x8 xor() 735 MB/s 2537 [ 0.836906] raid6: int64x4 gen() 1463 MB/s 2538 [ 0.904949] raid6: int64x4 xor() 733 MB/s 2539 [ 0.973018] raid6: int64x2 gen() 1363 MB/s 2540 [ 1.041092] raid6: int64x2 xor() 619 MB/s 2541 [ 1.109144] raid6: int64x1 gen() 1127 MB/s 2542 [ 1.177213] raid6: int64x1 xor() 462 MB/s 2543 [ 1.177217] raid6: using algorithm neonx4 gen() 3151 MB/s 2544 [ 1.177220] raid6: .... xor() 2399 MB/s, rmw enabled 2545 [ 1.177224] raid6: using neon recovery algorithm 2546 [ 1.177684] ACPI: Interpreter disabled. 2547 [ 1.178483] 5V: supplied by 12V 2548 [ 1.179370] VDDAO_3V3: supplied by 12V 2549 [ 1.179878] iommu: Default domain type: Translated 2550 [ 1.179991] vgaarb: loaded 2551 [ 1.180643] SCSI subsystem initialized 2552 [ 1.180834] usbcore: registered new interface driver usbfs 2553 [ 1.180865] usbcore: registered new interface driver hub 2554 [ 1.180896] usbcore: registered new device driver usb 2555 [ 1.181140] pps_core: LinuxPPS API ver. 1 registered 2556 [ 1.181144] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 2557 [ 1.181157] PTP clock support registered 2558 [ 1.181325] EDAC MC: Ver: 3.0.0 2559 [ 1.183108] NetLabel: Initializing 2560 [ 1.183116] NetLabel: domain hash size = 128 2561 [ 1.183119] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 2562 [ 1.183173] NetLabel: unlabeled traffic allowed by default 2563 [ 1.183670] clocksource: Switched to clocksource arch_sys_counter 2564 [ 1.183898] VFS: Disk quotas dquot_6.6.0 2565 [ 1.183942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 2566 [ 1.184293] AppArmor: AppArmor Filesystem Enabled 2567 [ 1.184341] pnp: PnP ACPI: disabled 2568 [ 1.189791] NET: Registered protocol family 2 2569 [ 1.190270] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 2570 [ 1.190373] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 2571 [ 1.190630] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 2572 [ 1.190817] TCP: Hash tables configured (established 32768 bind 32768) 2573 [ 1.190966] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 2574 [ 1.191032] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 2575 [ 1.191079] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 2576 [ 1.191222] NET: Registered protocol family 1 2577 [ 1.191241] PCI: CLS 0 bytes, default 64 2578 [ 1.191363] Trying to unpack rootfs image as initramfs... 2579 [ 1.759864] Freeing initrd memory: 14920K 2580 [ 1.760803] kvm [1]: IPA Size Limit: 40 bits 2581 [ 1.761517] kvm [1]: vgic interrupt IRQ9 2582 [ 1.761656] kvm [1]: Hyp mode initialized successfully 2583 [ 1.766818] Initialise system trusted keyrings 2584 [ 1.766852] Key type blacklist registered 2585 [ 1.766960] workingset: timestamp_bits=44 max_order=20 bucket_order=0 2586 [ 1.770192] zbud: loaded 2587 [ 1.771176] squashfs: version 4.0 (2009/01/31) Phillip Lougher 2588 [ 1.771635] fuse: init (API version 7.32) 2589 [ 1.772417] integrity: Platform Keyring initialized 2590 [ 1.800655] xor: measuring software checksum speed 2591 [ 1.803491] 8regs : 3476 MB/sec 2592 [ 1.805947] 32regs : 4023 MB/sec 2593 [ 1.808598] arm64_neon : 3722 MB/sec 2594 [ 1.808601] xor: using function: 32regs (4023 MB/sec) 2595 [ 1.808607] Key type asymmetric registered 2596 [ 1.808611] Asymmetric key parser 'x509' registered 2597 [ 1.808645] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 2598 [ 1.808743] io scheduler mq-deadline registered 2599 [ 1.808748] io scheduler kyber registered 2600 [ 1.808833] io scheduler bfq registered 2601 [ 1.811373] gpio-447 (usb-hub-reset): hogged as output/high 2602 [ 1.814372] EINJ: ACPI disabled. 2603 [ 1.820688] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 2604 [ 1.822107] VCC_3V3: supplied by VDDAO_3V3 2605 [ 1.822143] FLASH_1V8: supplied by VCC_3V3 2606 [ 1.822173] VCC_1V8: supplied by VCC_3V3 2607 [ 1.822200] VDDAO_1V8: supplied by VDDAO_3V3 2608 [ 1.822240] VDDCPU_A: supplied by regulator-dummy 2609 [ 1.822608] VDDCPU_B: supplied by regulator-dummy 2610 [ 1.823302] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 2611 [ 1.825618] Serial: AMBA driver 2612 [ 1.825914] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 2613 [ 1.826011] printk: console [ttyAML0] enabled 2614 [ 1.826549] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 2615 [ 1.831962] loop: module loaded 2616 [ 1.833938] libphy: Fixed MDIO Bus: probed 2617 [ 1.834896] tun: Universal TUN/TAP device driver, 1.6 2618 [ 1.835550] thunder_xcv, ver 1.0 2619 [ 1.835580] thunder_bgx, ver 1.0 2620 [ 1.835609] nicpf, ver 1.0 2621 [ 1.836311] e1000e: Intel(R) PRO/1000 Network Driver 2622 [ 1.836316] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 2623 [ 1.836365] igb: Intel(R) Gigabit Ethernet Network Driver 2624 [ 1.836368] igb: Copyright (c) 2007-2014 Intel Corporation. 2625 [ 1.836399] igbvf: Intel(R) Gigabit Virtual Function Network Driver 2626 [ 1.836401] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 2627 [ 1.836529] sky2: driver version 1.30 2628 [ 1.836902] VFIO - User Level meta-driver version: 0.3 2629 [ 1.838278] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 2630 [ 1.838296] ehci-pci: EHCI PCI platform driver 2631 [ 1.838331] ehci-platform: EHCI generic platform driver 2632 [ 1.838463] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 2633 [ 1.838474] ohci-pci: OHCI PCI platform driver 2634 [ 1.838506] ohci-platform: OHCI generic platform driver 2635 [ 1.838925] usbcore: registered new interface driver usb-storage 2636 [ 1.840260] mousedev: PS/2 mouse device common for all mice 2637 [ 1.840641] i2c /dev entries driver 2638 [ 1.845815] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 2639 [ 1.846684] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 2640 [ 1.847328] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 2641 [ 1.847935] sdhci: Secure Digital Host Controller Interface driver 2642 [ 1.847940] sdhci: Copyright(c) Pierre Ossman 2643 [ 1.848028] Synopsys Designware Multimedia Card Interface Driver 2644 [ 1.848386] sdhci-pltfm: SDHCI platform and OF driver helper 2645 [ 1.848843] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 2646 [ 1.849988] ledtrig-cpu: registered to indicate activity on CPUs 2647 [ 1.850221] meson-sm: secure-monitor enabled 2648 [ 1.850354] hid: raw HID events driver (C) Jiri Kosina 2649 [ 1.850425] usbcore: registered new interface driver usbhid 2650 [ 1.850427] usbhid: USB HID core driver 2651 [ 1.851263] NET: Registered protocol family 10 2652 [ 1.851594] Segment Routing with IPv6 2653 [ 1.851620] NET: Registered protocol family 17 2654 [ 1.851682] 8021q: 802.1Q VLAN Support v1.8 2655 [ 1.851705] Key type dns_resolver registered 2656 [ 1.851951] registered taskstats version 1 2657 [ 1.851955] Loading compiled-in X.509 certificates 2658 [ 1.853399] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 2659 [ 1.854838] zswap: loaded using pool zstd/z3fold 2660 [ 1.855012] Key type ._fscrypt registered 2661 [ 1.855014] Key type .fscrypt registered 2662 [ 1.855016] Key type fscrypt-provisioning registered 2663 [ 1.856086] Btrfs loaded, crc32c=crc32c-generic 2664 [ 1.861334] Key type encrypted registered 2665 [ 1.861346] AppArmor: AppArmor sha1 policy hashing enabled 2666 [ 1.866736] HUB_5V: supplied by 5V 2667 [ 1.866908] USB_PWR_EN: supplied by 5V 2668 [ 1.868394] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 2669 [ 1.868400] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 2670 [ 1.871076] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 2671 [ 1.871120] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 2672 [ 1.871210] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 2673 [ 1.871690] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 2674 [ 1.871699] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 2675 [ 1.871796] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 2676 [ 1.871815] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 2677 [ 1.871927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 2678 [ 1.871930] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2679 [ 1.871933] usb usb1: Product: xHCI Host Controller 2680 [ 1.871935] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 2681 [ 1.871936] usb usb1: SerialNumber: xhci-hcd.0.auto 2682 [ 1.872113] hub 1-0:1.0: USB hub found 2683 [ 1.872126] hub 1-0:1.0: 2 ports detected 2684 [ 1.872237] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 2685 [ 1.872242] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 2686 [ 1.872248] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 2687 [ 1.872267] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 2688 [ 1.872295] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 2689 [ 1.872297] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2690 [ 1.872299] usb usb2: Product: xHCI Host Controller 2691 [ 1.872301] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 2692 [ 1.872302] usb usb2: SerialNumber: xhci-hcd.0.auto 2693 [ 1.872412] hub 2-0:1.0: USB hub found 2694 [ 1.872421] hub 2-0:1.0: 1 port detected 2695 [ 1.872689] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 2696 [ 1.873451] meson-gx-mmc ffe05000.sd: Got CD GPIO 2697 [ 1.900654] Freeing unused kernel memory: 3328K 2698 [ 1.943716] Run /init as init process 2699 [ 1.943720] with arguments: 2700 [ 1.943722] /init 2701 [ 1.943723] with environment: 2702 [ 1.943725] HOME=/ 2703 [ 1.943726] TERM=linux 2704 [ 1.943727] hdmimode=custombuilt 2705 [ 1.943728] cvbsmode=576cvbs 2706 [ 1.943730] max_freq_a53=1908 2707 [ 1.943731] max_freq_a73=2208 2708 [ 1.943732] voutmode=hdmi 2709 [ 1.943734] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 2710 [ 1.943735] disablehpd=false 2711 [ 1.943736] cvbscable= 2712 [ 1.943737] overscan=100 2713 [ 2.046027] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 2714 [ 2.046034] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 2715 [ 2.046135] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 2716 [ 2.055033] meson-vrtc ff8000a8.rtc: registered as rtc1 2717 [ 2.056502] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 2718 [ 2.056512] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 2719 [ 2.056514] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 2720 [ 2.056517] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 2721 [ 2.056519] meson8b-dwmac ff3f0000.ethernet: COE Type 2 2722 [ 2.056521] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 2723 [ 2.056523] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 2724 [ 2.056567] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 2725 [ 2.056570] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 2726 [ 2.056572] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 2727 [ 2.056743] libphy: stmmac: probed 2728 [ 2.057875] libphy: mdio_mux: probed 2729 [ 2.067370] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 2730 [ 2.067681] rtc-pcf8563 1-0051: registered as rtc0 2731 [ 2.070011] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 2732 [ 2.070019] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 2733 [ 2.129385] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 2734 [ 2.130223] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 2735 [ 2.132546] mmcblk0: p1 2736 [ 2.135910] mmc1: new HS200 MMC card at address 0001 2737 [ 2.136610] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 2738 [ 2.136970] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 2739 [ 2.137324] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 2740 [ 2.137474] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 2741 [ 2.138676] mmcblk1: p1 2742 [ 2.147767] random: fast init done 2743 [ 2.211689] usb 1-1: new high-speed USB device number 2 using xhci-hcd 2744 [ 2.260128] libphy: mdio_mux: probed 2745 [ 2.366031] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 2746 [ 2.366037] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2747 [ 2.366039] usb 1-1: Product: USB2.1 Hub 2748 [ 2.366041] usb 1-1: Manufacturer: GenesysLogic 2749 [ 2.396694] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 2750 [ 2.416528] hub 1-1:1.0: USB hub found 2751 [ 2.416771] hub 1-1:1.0: 4 ports detected 2752 [ 2.491813] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 2753 [ 2.518317] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 2754 [ 2.518327] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2755 [ 2.518331] usb 2-1: Product: USB3.1 Hub 2756 [ 2.518335] usb 2-1: Manufacturer: GenesysLogic 2757 [ 2.544557] hub 2-1:1.0: USB hub found 2758 [ 2.544857] hub 2-1:1.0: 4 ports detected 2759 [ 2.639914] systemd[1]: System time before build time, advancing clock. 2760 [ 2.643461] systemd[1]: Inserted module 'autofs4' 2761 [ 2.661647] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 2762 [ 2.661829] systemd[1]: Detected architecture arm64. 2763 [ 2.701281] systemd[1]: Set hostname to <odroidn2>. 2764 [ 2.791735] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 2765 [ 2.918987] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 2766 [ 2.918996] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 2767 [ 2.919000] usb 1-1.1: Product: USB OPTICAL MOUSE 2768 [ 2.929956] random: systemd: uninitialized urandom read (16 bytes read) 2769 [ 2.932507] random: systemd: uninitialized urandom read (16 bytes read) 2770 [ 2.932797] systemd[1]: Listening on Journal Socket. 2771 [ 2.933002] random: systemd: uninitialized urandom read (16 bytes read) 2772 [ 2.934019] systemd[1]: Created slice system-getty.slice. 2773 [ 2.937056] systemd[1]: Starting Set the console keyboard layout... 2774 [ 2.938651] systemd[1]: Mounting Kernel Debug File System... 2775 [ 2.938912] systemd[1]: Reached target Remote File Systems. 2776 [ 2.939356] systemd[1]: Listening on fsck to fsckd communication Socket. 2777 [ 2.939684] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 2778 [ 2.963756] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 2779 [ 2.964380] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 2780 [ 2.972763] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 2781 [ 3.067738] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 2782 [ 3.174013] zram: Added device: zram0 2783 [ 3.174546] zram: Added device: zram1 2784 [ 3.174956] zram: Added device: zram2 2785 [ 3.197167] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 2786 [ 3.197176] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 2787 [ 3.197181] usb 1-1.3: Product: USB Keyboard 2788 [ 3.197184] usb 1-1.3: Manufacturer: Logitech 2789 [ 3.212972] pwm-gpio pwmgpio: 1 gpio pwms loaded 2790 [ 3.227862] zram0: detected capacity change from 0 to 1904500736 2791 [ 3.286277] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 2792 [ 3.344303] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 2793 [ 3.348334] mc: Linux media interface: v0.10 2794 [ 3.351618] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 2795 [ 3.358897] videodev: Linux video capture interface: v2.00 2796 [ 3.363231] meson-drm ff900000.vpu: Queued 2 outputs on vpu 2797 [ 3.368586] panfrost ffe40000.gpu: clock rate = 24000000 2798 [ 3.368675] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 2799 [ 3.369907] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 2800 [ 3.369920] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 2801 [ 3.369925] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 2802 [ 3.369929] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 2803 [ 3.380764] meson-drm ff900000.vpu: CVBS Output connector not available 2804 [ 3.397830] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0 2805 [ 3.398871] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 2806 [ 3.405897] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 2807 [ 3.407890] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 2808 [ 3.408683] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 2809 [ 3.409366] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 2810 [ 3.413068] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 2811 [ 3.413481] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1 2812 [ 3.413510] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 2813 [ 3.415804] Registered IR keymap rc-odroid 2814 [ 3.438977] IR NEC protocol handler initialized 2815 [ 3.476067] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 2816 [ 3.476197] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 2817 [ 3.476292] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 2818 [ 3.476788] meson-ir ff808000.ir: receiver initialized 2819 [ 3.700494] Console: switching to colour frame buffer device 240x67 2820 [ 3.722355] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 2821 [ 3.763305] axg-sound-card sound: ASoC: no DMI vendor name! 2822 [ 4.259685] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 2823 [ 4.300559] zram1: detected capacity change from 0 to 52428800 2824 [ 6.344004] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 2825 [ 6.344021] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 2826 [ 7.235961] systemd-journald[1855]: Received request to flush runtime journal from PID 1 2827 2828 ### armbian-release: 2829 2830 # PLEASE DO NOT EDIT THIS FILE 2831 BOARD=odroidn2 2832 BOARD_NAME="Odroid N2" 2833 BOARDFAMILY=meson-g12b 2834 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 2835 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 2836 DISTRIBUTION_CODENAME=buster 2837 DISTRIBUTION_STATUS=supported 2838 VERSION=21.02.3 2839 LINUXFAMILY=meson64 2840 BRANCH=current 2841 ARCH=arm64 2842 IMAGE_TYPE=stable 2843 BOARD_TYPE=conf 2844 INITRD_ARCH=arm64 2845 KERNEL_IMAGE_TYPE=Image 2846 2847 ### boot environment: 2848 2849 verbosity=1 2850 console=both 2851 overlay_prefix=meson 2852 bootlogo=true 2853 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 2854 rootfstype=ext4 2855 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 2856 2857 ### lsusb: 2858 2859 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 2860 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 2861 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 2862 Bus 001 Device 003: ID 275d:0ba6 2863 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 2864 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 2865 2866 ### lscpu: 2867 2868 Architecture: aarch64 2869 Byte Order: Little Endian 2870 CPU(s): 6 2871 On-line CPU(s) list: 0-5 2872 Thread(s) per core: 1 2873 Core(s) per socket: 3 2874 Socket(s): 2 2875 NUMA node(s): 1 2876 Vendor ID: ARM 2877 Model: 4 2878 Model name: Cortex-A53 2879 Stepping: r0p4 2880 CPU max MHz: 2400.0000 2881 CPU min MHz: 100.0000 2882 BogoMIPS: 48.00 2883 L1d cache: unknown size 2884 L1i cache: unknown size 2885 L2 cache: unknown size 2886 NUMA node0 CPU(s): 0-5 2887 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2888 2889 ### cpuinfo: 2890 2891 processor : 0 2892 BogoMIPS : 48.00 2893 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2894 CPU implementer : 0x41 2895 CPU architecture: 8 2896 CPU variant : 0x0 2897 CPU part : 0xd03 2898 CPU revision : 4 2899 2900 processor : 1 2901 BogoMIPS : 48.00 2902 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2903 CPU implementer : 0x41 2904 CPU architecture: 8 2905 CPU variant : 0x0 2906 CPU part : 0xd03 2907 CPU revision : 4 2908 2909 processor : 2 2910 BogoMIPS : 48.00 2911 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2912 CPU implementer : 0x41 2913 CPU architecture: 8 2914 CPU variant : 0x0 2915 CPU part : 0xd09 2916 CPU revision : 2 2917 2918 processor : 3 2919 BogoMIPS : 48.00 2920 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2921 CPU implementer : 0x41 2922 CPU architecture: 8 2923 CPU variant : 0x0 2924 CPU part : 0xd09 2925 CPU revision : 2 2926 2927 processor : 4 2928 BogoMIPS : 48.00 2929 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2930 CPU implementer : 0x41 2931 CPU architecture: 8 2932 CPU variant : 0x0 2933 CPU part : 0xd09 2934 CPU revision : 2 2935 2936 processor : 5 2937 BogoMIPS : 48.00 2938 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 2939 CPU implementer : 0x41 2940 CPU architecture: 8 2941 CPU variant : 0x0 2942 CPU part : 0xd09 2943 CPU revision : 2 2944 2945 2946 ### meminfo: 2947 2948 MemTotal: 3719724 kB 2949 MemFree: 3373572 kB 2950 MemAvailable: 3333452 kB 2951 Buffers: 12536 kB 2952 Cached: 55232 kB 2953 SwapCached: 0 kB 2954 Active: 32596 kB 2955 Inactive: 196124 kB 2956 Active(anon): 132 kB 2957 Inactive(anon): 165900 kB 2958 Active(file): 32464 kB 2959 Inactive(file): 30224 kB 2960 Unevictable: 0 kB 2961 Mlocked: 0 kB 2962 SwapTotal: 1859860 kB 2963 SwapFree: 1859860 kB 2964 Dirty: 8700 kB 2965 Writeback: 0 kB 2966 AnonPages: 161428 kB 2967 Mapped: 16416 kB 2968 Shmem: 4936 kB 2969 KReclaimable: 13788 kB 2970 Slab: 45376 kB 2971 SReclaimable: 13788 kB 2972 SUnreclaim: 31588 kB 2973 KernelStack: 2640 kB 2974 PageTables: 5552 kB 2975 NFS_Unstable: 0 kB 2976 Bounce: 0 kB 2977 WritebackTmp: 0 kB 2978 CommitLimit: 3719720 kB 2979 Committed_AS: 4251204 kB 2980 VmallocTotal: 135290159040 kB 2981 VmallocUsed: 31508 kB 2982 VmallocChunk: 0 kB 2983 Percpu: 1416 kB 2984 HardwareCorrupted: 0 kB 2985 AnonHugePages: 0 kB 2986 ShmemHugePages: 0 kB 2987 ShmemPmdMapped: 0 kB 2988 FileHugePages: 0 kB 2989 FilePmdMapped: 0 kB 2990 CmaTotal: 917504 kB 2991 CmaFree: 901724 kB 2992 HugePages_Total: 0 2993 HugePages_Free: 0 2994 HugePages_Rsvd: 0 2995 HugePages_Surp: 0 2996 Hugepagesize: 2048 kB 2997 Hugetlb: 0 kB 2998 2999 ### virtual memory: 3000 3001 vm.admin_reserve_kbytes = 8192 3002 vm.block_dump = 0 3003 vm.compaction_proactiveness = 20 3004 vm.compact_unevictable_allowed = 1 3005 vm.dirty_background_bytes = 0 3006 vm.dirty_background_ratio = 10 3007 vm.dirty_bytes = 0 3008 vm.dirty_expire_centisecs = 3000 3009 vm.dirty_ratio = 20 3010 vm.dirtytime_expire_seconds = 43200 3011 vm.dirty_writeback_centisecs = 500 3012 vm.extfrag_threshold = 500 3013 vm.hugetlb_shm_group = 0 3014 vm.laptop_mode = 0 3015 vm.legacy_va_layout = 0 3016 vm.lowmem_reserve_ratio = 256 256 32 0 3017 vm.max_map_count = 65530 3018 vm.memory_failure_early_kill = 0 3019 vm.memory_failure_recovery = 1 3020 vm.min_free_kbytes = 45056 3021 vm.min_slab_ratio = 5 3022 vm.min_unmapped_ratio = 1 3023 vm.mmap_min_addr = 4096 3024 vm.mmap_rnd_bits = 18 3025 vm.mmap_rnd_compat_bits = 11 3026 vm.nr_hugepages = 0 3027 vm.nr_hugepages_mempolicy = 0 3028 vm.nr_overcommit_hugepages = 0 3029 vm.numa_stat = 1 3030 vm.numa_zonelist_order = Node 3031 vm.oom_dump_tasks = 1 3032 vm.oom_kill_allocating_task = 0 3033 vm.overcommit_kbytes = 0 3034 vm.overcommit_memory = 0 3035 vm.overcommit_ratio = 50 3036 vm.page-cluster = 0 3037 vm.page_lock_unfairness = 5 3038 vm.panic_on_oom = 0 3039 vm.percpu_pagelist_fraction = 0 3040 vm.stat_interval = 1 3041 vm.swappiness = 100 3042 vm.user_reserve_kbytes = 114996 3043 vm.vfs_cache_pressure = 100 3044 vm.watermark_boost_factor = 15000 3045 vm.watermark_scale_factor = 10 3046 vm.zone_reclaim_mode = 0 3047 3048 ### ip addr: 3049 3050 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 3051 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 3052 inet XXX.XXX.0.1/8 scope host lo 3053 valid_lft forever preferred_lft forever 3054 inet6 ::1/128 scope host 3055 valid_lft forever preferred_lft forever 3056 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 3057 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 3058 3059 ### partitions: 3060 3061 major minor #blocks name 3062 3063 179 0 62367744 mmcblk0 3064 179 1 62366720 mmcblk0p1 3065 179 32 61071360 mmcblk1 3066 179 33 60456544 mmcblk1p1 3067 252 0 1859864 zram0 3068 252 1 51200 zram1 3069 3070 ### df: 3071 3072 udev 1.4G 0 1.4G 0% /dev 3073 tmpfs 364M 5.0M 359M 2% /run 3074 /dev/mmcblk1p1 57G 20G 37G 36% / 3075 tmpfs 1.8G 0 1.8G 0% /dev/shm 3076 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 3077 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 3078 tmpfs 1.8G 0 1.8G 0% /tmp 3079 /dev/zram1 49M 8.5M 37M 19% /var/log 3080 3081 ### lsblk: 3082 3083 NAME FSTYPE SIZE MOUNTPOINT UUID 3084 mmcblk0 59.5G 3085 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 3086 mmcblk1 58.2G 3087 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 3088 mmcblk1boot0 4M 3089 mmcblk1boot1 4M 3090 zram1 50M /var/log 3091 3092 ### zramctl: 3093 3094 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 3095 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 3096 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 3097 3098 ### mtab: 3099 3100 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 3101 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 3102 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 3103 3104 ### mmc0:aaaa info: 3105 3106 fwrev: 0x0 3107 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 3108 cid: 035344534836344780559b2001014a00 3109 rca: 0xaaaa 3110 csd: 400e0032db790001dbd37f800a404000 3111 manfid: 0x000003 3112 ocr: 0x00200000 3113 preferred_erase_size: 4194304 3114 type: SD 3115 hwrev: 0x8 3116 date: 10/2020 3117 dsr: 0x404 3118 erase_size: 512 3119 oemid: 0x5344 3120 serial: 0x559b2001 3121 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 3122 scr: 0245848300000000 3123 name: SH64G 3124 3125 ### mmc1:0001 info: 3126 3127 fwrev: 0x0400000000000000 3128 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 3129 cid: 150100434a54443452042559facb7700 3130 rel_sectors: 0x1 3131 enhanced_rpmb_supported: 0x1 3132 rca: 0x0001 3133 pre_eol_info: 0x01 3134 csd: d02701320f5903fff6dbffef8e404000 3135 manfid: 0x000015 3136 ocr: 0x00200000 3137 preferred_erase_size: 4194304 3138 enhanced_area_offset: 18446744073709551594 3139 raw_rpmb_size_mult: 0x20 3140 type: MMC 3141 hwrev: 0x0 3142 date: 07/2020 3143 prv: 0x4 3144 ffu_capable: 1 3145 dsr: 0x404 3146 erase_size: 524288 3147 life_time: 0x01 0x01 3148 enhanced_area_size: 4294967274 3149 oemid: 0x0100 3150 serial: 0x2559facb 3151 cmdq_en: 0 3152 rev: 0x8 3153 name: CJTD4R 3154 3155 ### Boot system health: 3156 3157 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 3158 19:19:38: 2400/2016MHz 0.00 23% 14% 6% 0% 1% 0% 27.6°C 0/12 3159 19:19:38: 2400/2016MHz 0.00 27% 17% 10% 0% 0% 0% 27.1°C 0/12 3160 19:19:39: 2400/2016MHz 0.00 19% 9% 8% 0% 0% 0% 25.8°C 0/12 3161 19:19:39: 2400/2016MHz 0.00 55% 34% 14% 0% 3% 1% 27.0°C 0/12 3162 19:19:39: 2400/2016MHz 0.00 89% 34% 37% 0% 12% 4% 28.0°C 0/12 3163 3164 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 3165 3166 ### Activated Armbian ramlog partition with zstd compression 3167 3168 Tue 30 Mar 2021 07:19:37 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 3169 3170 ### dmesg: 3171 3172 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 3173 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 3174 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 3175 [ 0.000000] efi: UEFI not found. 3176 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 3177 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 3178 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 3179 [ 0.000000] NUMA: No NUMA configuration found 3180 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 3181 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 3182 [ 0.000000] Zone ranges: 3183 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 3184 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 3185 [ 0.000000] Normal empty 3186 [ 0.000000] Movable zone start for each node 3187 [ 0.000000] Early memory node ranges 3188 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 3189 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 3190 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 3191 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 3192 [ 0.000000] On node 0 totalpages: 972800 3193 [ 0.000000] DMA zone: 4096 pages used for memmap 3194 [ 0.000000] DMA zone: 0 pages reserved 3195 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 3196 [ 0.000000] DMA32 zone: 11104 pages used for memmap 3197 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 3198 [ 0.000000] psci: probing for conduit method from DT. 3199 [ 0.000000] psci: PSCIv1.0 detected in firmware. 3200 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 3201 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 3202 [ 0.000000] psci: SMC Calling Convention v1.1 3203 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 3204 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 3205 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 3206 [ 0.000000] Detected VIPT I-cache on CPU0 3207 [ 0.000000] CPU features: detected: ARM erratum 845719 3208 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 3209 [ 0.000000] Policy zone: DMA32 3210 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 3211 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 3212 Please use sysfs to set IO scheduler for individual devices. 3213 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 3214 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 3215 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 3216 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 3217 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 3218 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 3219 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 3220 [ 0.000000] rcu: RCU event tracing is enabled. 3221 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 3222 [ 0.000000] Trampoline variant of Tasks RCU enabled. 3223 [ 0.000000] Rude variant of Tasks RCU enabled. 3224 [ 0.000000] Tracing variant of Tasks RCU enabled. 3225 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 3226 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 3227 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 3228 [ 0.000000] GIC: Using split EOI/Deactivate mode 3229 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 3230 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 3231 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 3232 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 3233 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 3234 [ 0.000254] Console: colour dummy device 80x25 3235 [ 0.000289] printk: console [tty1] enabled 3236 [ 0.000376] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 3237 [ 0.000388] pid_max: default: 32768 minimum: 301 3238 [ 0.000472] LSM: Security Framework initializing 3239 [ 0.000497] Yama: becoming mindful. 3240 [ 0.000585] AppArmor: AppArmor initialized 3241 [ 0.000636] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 3242 [ 0.000655] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 3243 [ 0.002658] rcu: Hierarchical SRCU implementation. 3244 [ 0.005156] EFI services will not be available. 3245 [ 0.005577] smp: Bringing up secondary CPUs ... 3246 [ 0.006248] Detected VIPT I-cache on CPU1 3247 [ 0.006310] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 3248 [ 0.007505] CPU features: detected: ARM erratum 858921 3249 [ 0.007514] CPU features: detected: Spectre-v2 3250 [ 0.007517] CPU features: detected: Spectre-v4 3251 [ 0.007523] Detected VIPT I-cache on CPU2 3252 [ 0.007549] arch_timer: Enabling local workaround for ARM erratum 858921 3253 [ 0.007563] arch_timer: CPU2: Trapping CNTVCT access 3254 [ 0.007577] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 3255 [ 0.008289] Detected VIPT I-cache on CPU3 3256 [ 0.008305] arch_timer: Enabling local workaround for ARM erratum 858921 3257 [ 0.008312] arch_timer: CPU3: Trapping CNTVCT access 3258 [ 0.008320] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 3259 [ 0.008950] Detected VIPT I-cache on CPU4 3260 [ 0.008966] arch_timer: Enabling local workaround for ARM erratum 858921 3261 [ 0.008974] arch_timer: CPU4: Trapping CNTVCT access 3262 [ 0.008981] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 3263 [ 0.009599] Detected VIPT I-cache on CPU5 3264 [ 0.009616] arch_timer: Enabling local workaround for ARM erratum 858921 3265 [ 0.009622] arch_timer: CPU5: Trapping CNTVCT access 3266 [ 0.009630] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 3267 [ 0.009712] smp: Brought up 1 node, 6 CPUs 3268 [ 0.009730] SMP: Total of 6 processors activated. 3269 [ 0.009737] CPU features: detected: 32-bit EL0 Support 3270 [ 0.009743] CPU features: detected: CRC32 instructions 3271 [ 0.009749] CPU features: detected: 32-bit EL1 Support 3272 [ 0.021007] CPU: All CPU(s) started at EL2 3273 [ 0.021056] alternatives: patching kernel code 3274 [ 0.023056] devtmpfs: initialized 3275 [ 0.030712] Registered cp15_barrier emulation handler 3276 [ 0.030726] Registered setend emulation handler 3277 [ 0.030895] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 3278 [ 0.030938] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 3279 [ 0.046201] pinctrl core: initialized pinctrl subsystem 3280 [ 0.046792] DMI not present or invalid. 3281 [ 0.047170] NET: Registered protocol family 16 3282 [ 0.048776] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 3283 [ 0.049062] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 3284 [ 0.049292] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 3285 [ 0.049336] audit: initializing netlink subsys (disabled) 3286 [ 0.049448] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 3287 [ 0.050778] thermal_sys: Registered thermal governor 'fair_share' 3288 [ 0.050785] thermal_sys: Registered thermal governor 'bang_bang' 3289 [ 0.050789] thermal_sys: Registered thermal governor 'step_wise' 3290 [ 0.050793] thermal_sys: Registered thermal governor 'user_space' 3291 [ 0.051213] cpuidle: using governor menu 3292 [ 0.051554] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 3293 [ 0.051696] ASID allocator initialised with 65536 entries 3294 [ 0.052706] Serial: AMBA PL011 UART driver 3295 [ 0.087601] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 3296 [ 0.087611] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 3297 [ 0.087615] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 3298 [ 0.087620] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 3299 [ 0.089055] cryptd: max_cpu_qlen set to 1000 3300 [ 0.156235] raid6: neonx8 gen() 2783 MB/s 3301 [ 0.224296] raid6: neonx8 xor() 2042 MB/s 3302 [ 0.292362] raid6: neonx4 gen() 3002 MB/s 3303 [ 0.360426] raid6: neonx4 xor() 2348 MB/s 3304 [ 0.428492] raid6: neonx2 gen() 2577 MB/s 3305 [ 0.496553] raid6: neonx2 xor() 2134 MB/s 3306 [ 0.564618] raid6: neonx1 gen() 1964 MB/s 3307 [ 0.632684] raid6: neonx1 xor() 1721 MB/s 3308 [ 0.700742] raid6: int64x8 gen() 1373 MB/s 3309 [ 0.768812] raid6: int64x8 xor() 735 MB/s 3310 [ 0.836897] raid6: int64x4 gen() 1463 MB/s 3311 [ 0.904946] raid6: int64x4 xor() 733 MB/s 3312 [ 0.972999] raid6: int64x2 gen() 1362 MB/s 3313 [ 1.041073] raid6: int64x2 xor() 619 MB/s 3314 [ 1.109130] raid6: int64x1 gen() 1127 MB/s 3315 [ 1.177198] raid6: int64x1 xor() 462 MB/s 3316 [ 1.177201] raid6: using algorithm neonx4 gen() 3002 MB/s 3317 [ 1.177204] raid6: .... xor() 2348 MB/s, rmw enabled 3318 [ 1.177208] raid6: using neon recovery algorithm 3319 [ 1.177660] ACPI: Interpreter disabled. 3320 [ 1.178442] 5V: supplied by 12V 3321 [ 1.179338] VDDAO_3V3: supplied by 12V 3322 [ 1.179817] iommu: Default domain type: Translated 3323 [ 1.179985] vgaarb: loaded 3324 [ 1.180739] SCSI subsystem initialized 3325 [ 1.181065] usbcore: registered new interface driver usbfs 3326 [ 1.181099] usbcore: registered new interface driver hub 3327 [ 1.181140] usbcore: registered new device driver usb 3328 [ 1.181404] pps_core: LinuxPPS API ver. 1 registered 3329 [ 1.181408] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 3330 [ 1.181426] PTP clock support registered 3331 [ 1.181629] EDAC MC: Ver: 3.0.0 3332 [ 1.183007] NetLabel: Initializing 3333 [ 1.183014] NetLabel: domain hash size = 128 3334 [ 1.183017] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 3335 [ 1.183058] NetLabel: unlabeled traffic allowed by default 3336 [ 1.183489] clocksource: Switched to clocksource arch_sys_counter 3337 [ 1.183704] VFS: Disk quotas dquot_6.6.0 3338 [ 1.183747] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 3339 [ 1.184099] AppArmor: AppArmor Filesystem Enabled 3340 [ 1.184148] pnp: PnP ACPI: disabled 3341 [ 1.189767] NET: Registered protocol family 2 3342 [ 1.190233] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 3343 [ 1.190335] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 3344 [ 1.190592] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 3345 [ 1.190779] TCP: Hash tables configured (established 32768 bind 32768) 3346 [ 1.190929] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 3347 [ 1.190994] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 3348 [ 1.191041] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 3349 [ 1.191189] NET: Registered protocol family 1 3350 [ 1.191207] PCI: CLS 0 bytes, default 64 3351 [ 1.191340] Trying to unpack rootfs image as initramfs... 3352 [ 1.758206] Freeing initrd memory: 14920K 3353 [ 1.759135] kvm [1]: IPA Size Limit: 40 bits 3354 [ 1.759876] kvm [1]: vgic interrupt IRQ9 3355 [ 1.760010] kvm [1]: Hyp mode initialized successfully 3356 [ 1.765159] Initialise system trusted keyrings 3357 [ 1.765194] Key type blacklist registered 3358 [ 1.765295] workingset: timestamp_bits=44 max_order=20 bucket_order=0 3359 [ 1.768486] zbud: loaded 3360 [ 1.769467] squashfs: version 4.0 (2009/01/31) Phillip Lougher 3361 [ 1.769936] fuse: init (API version 7.32) 3362 [ 1.770684] integrity: Platform Keyring initialized 3363 [ 1.799233] xor: measuring software checksum speed 3364 [ 1.802087] 8regs : 3476 MB/sec 3365 [ 1.804543] 32regs : 4020 MB/sec 3366 [ 1.807191] arm64_neon : 3720 MB/sec 3367 [ 1.807195] xor: using function: 32regs (4020 MB/sec) 3368 [ 1.807202] Key type asymmetric registered 3369 [ 1.807205] Asymmetric key parser 'x509' registered 3370 [ 1.807241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 3371 [ 1.807321] io scheduler mq-deadline registered 3372 [ 1.807325] io scheduler kyber registered 3373 [ 1.807402] io scheduler bfq registered 3374 [ 1.809969] gpio-447 (usb-hub-reset): hogged as output/high 3375 [ 1.812981] EINJ: ACPI disabled. 3376 [ 1.819260] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 3377 [ 1.820747] VCC_3V3: supplied by VDDAO_3V3 3378 [ 1.820782] FLASH_1V8: supplied by VCC_3V3 3379 [ 1.820813] VCC_1V8: supplied by VCC_3V3 3380 [ 1.820857] VDDAO_1V8: supplied by VDDAO_3V3 3381 [ 1.820885] VDDCPU_A: supplied by regulator-dummy 3382 [ 1.821235] VDDCPU_B: supplied by regulator-dummy 3383 [ 1.821934] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 3384 [ 1.824353] Serial: AMBA driver 3385 [ 1.824638] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 3386 [ 1.824728] printk: console [ttyAML0] enabled 3387 [ 1.825254] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 3388 [ 1.830536] loop: module loaded 3389 [ 1.832464] libphy: Fixed MDIO Bus: probed 3390 [ 1.833441] tun: Universal TUN/TAP device driver, 1.6 3391 [ 1.834107] thunder_xcv, ver 1.0 3392 [ 1.834143] thunder_bgx, ver 1.0 3393 [ 1.834170] nicpf, ver 1.0 3394 [ 1.834639] e1000e: Intel(R) PRO/1000 Network Driver 3395 [ 1.834642] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 3396 [ 1.834682] igb: Intel(R) Gigabit Ethernet Network Driver 3397 [ 1.834686] igb: Copyright (c) 2007-2014 Intel Corporation. 3398 [ 1.834716] igbvf: Intel(R) Gigabit Virtual Function Network Driver 3399 [ 1.834720] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 3400 [ 1.834859] sky2: driver version 1.30 3401 [ 1.835237] VFIO - User Level meta-driver version: 0.3 3402 [ 1.836678] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 3403 [ 1.836699] ehci-pci: EHCI PCI platform driver 3404 [ 1.836734] ehci-platform: EHCI generic platform driver 3405 [ 1.836873] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 3406 [ 1.836897] ohci-pci: OHCI PCI platform driver 3407 [ 1.836932] ohci-platform: OHCI generic platform driver 3408 [ 1.837369] usbcore: registered new interface driver usb-storage 3409 [ 1.838716] mousedev: PS/2 mouse device common for all mice 3410 [ 1.839106] i2c /dev entries driver 3411 [ 1.844692] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 3412 [ 1.845592] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 3413 [ 1.846503] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 3414 [ 1.847103] sdhci: Secure Digital Host Controller Interface driver 3415 [ 1.847108] sdhci: Copyright(c) Pierre Ossman 3416 [ 1.847214] Synopsys Designware Multimedia Card Interface Driver 3417 [ 1.847702] sdhci-pltfm: SDHCI platform and OF driver helper 3418 [ 1.848581] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 3419 [ 1.849007] ledtrig-cpu: registered to indicate activity on CPUs 3420 [ 1.849224] meson-sm: secure-monitor enabled 3421 [ 1.849366] hid: raw HID events driver (C) Jiri Kosina 3422 [ 1.849448] usbcore: registered new interface driver usbhid 3423 [ 1.849452] usbhid: USB HID core driver 3424 [ 1.850301] NET: Registered protocol family 10 3425 [ 1.850782] Segment Routing with IPv6 3426 [ 1.850804] NET: Registered protocol family 17 3427 [ 1.850893] 8021q: 802.1Q VLAN Support v1.8 3428 [ 1.850916] Key type dns_resolver registered 3429 [ 1.851160] registered taskstats version 1 3430 [ 1.851165] Loading compiled-in X.509 certificates 3431 [ 1.852748] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 3432 [ 1.854148] zswap: loaded using pool zstd/z3fold 3433 [ 1.854291] Key type ._fscrypt registered 3434 [ 1.854293] Key type .fscrypt registered 3435 [ 1.854295] Key type fscrypt-provisioning registered 3436 [ 1.855312] Btrfs loaded, crc32c=crc32c-generic 3437 [ 1.860819] Key type encrypted registered 3438 [ 1.860830] AppArmor: AppArmor sha1 policy hashing enabled 3439 [ 1.866104] HUB_5V: supplied by 5V 3440 [ 1.866264] USB_PWR_EN: supplied by 5V 3441 [ 1.867757] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 3442 [ 1.867764] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 3443 [ 1.870417] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 3444 [ 1.870467] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 3445 [ 1.870548] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 3446 [ 1.871042] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 3447 [ 1.871051] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 3448 [ 1.871130] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 3449 [ 1.871150] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 3450 [ 1.871259] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 3451 [ 1.871262] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 3452 [ 1.871264] usb usb1: Product: xHCI Host Controller 3453 [ 1.871266] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 3454 [ 1.871268] usb usb1: SerialNumber: xhci-hcd.0.auto 3455 [ 1.871433] hub 1-0:1.0: USB hub found 3456 [ 1.871443] hub 1-0:1.0: 2 ports detected 3457 [ 1.871567] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 3458 [ 1.871573] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 3459 [ 1.871577] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 3460 [ 1.871595] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 3461 [ 1.871622] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 3462 [ 1.871624] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 3463 [ 1.871626] usb usb2: Product: xHCI Host Controller 3464 [ 1.871628] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 3465 [ 1.871630] usb usb2: SerialNumber: xhci-hcd.0.auto 3466 [ 1.871767] hub 2-0:1.0: USB hub found 3467 [ 1.871776] hub 2-0:1.0: 1 port detected 3468 [ 1.872018] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 3469 [ 1.872779] meson-gx-mmc ffe05000.sd: Got CD GPIO 3470 [ 1.900057] Freeing unused kernel memory: 3328K 3471 [ 1.939618] Run /init as init process 3472 [ 1.939621] with arguments: 3473 [ 1.939623] /init 3474 [ 1.939625] with environment: 3475 [ 1.939627] HOME=/ 3476 [ 1.939628] TERM=linux 3477 [ 1.939629] hdmimode=custombuilt 3478 [ 1.939631] cvbsmode=576cvbs 3479 [ 1.939632] max_freq_a53=1908 3480 [ 1.939633] max_freq_a73=2208 3481 [ 1.939634] voutmode=hdmi 3482 [ 1.939635] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 3483 [ 1.939637] disablehpd=false 3484 [ 1.939638] cvbscable= 3485 [ 1.939639] overscan=100 3486 [ 2.071384] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 3487 [ 2.071390] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 3488 [ 2.071514] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 3489 [ 2.073500] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 3490 [ 2.073508] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 3491 [ 2.073510] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 3492 [ 2.073512] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 3493 [ 2.073515] meson8b-dwmac ff3f0000.ethernet: COE Type 2 3494 [ 2.073516] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 3495 [ 2.073518] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 3496 [ 2.073557] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 3497 [ 2.073559] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 3498 [ 2.073561] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 3499 [ 2.073704] libphy: stmmac: probed 3500 [ 2.077199] libphy: mdio_mux: probed 3501 [ 2.086168] meson-vrtc ff8000a8.rtc: registered as rtc1 3502 [ 2.096916] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 3503 [ 2.097222] rtc-pcf8563 1-0051: registered as rtc0 3504 [ 2.098687] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 3505 [ 2.098699] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 3506 [ 2.102799] mmc0: new HS200 MMC card at address 0001 3507 [ 2.103631] mmcblk0: mmc0:0001 CJTD4R 58.2 GiB 3508 [ 2.104066] mmcblk0boot0: mmc0:0001 CJTD4R partition 1 4.00 MiB 3509 [ 2.104476] mmcblk0boot1: mmc0:0001 CJTD4R partition 2 4.00 MiB 3510 [ 2.104699] mmcblk0rpmb: mmc0:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 3511 [ 2.106850] mmcblk0: p1 3512 [ 2.125101] random: fast init done 3513 [ 2.133357] mmc1: new ultra high speed SDR104 SDXC card at address aaaa 3514 [ 2.133963] mmcblk1: mmc1:aaaa SH64G 59.5 GiB 3515 [ 2.135694] mmcblk1: p1 3516 [ 2.211506] usb 1-1: new high-speed USB device number 2 using xhci-hcd 3517 [ 2.283906] libphy: mdio_mux: probed 3518 [ 2.361856] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 3519 [ 2.361862] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 3520 [ 2.361864] usb 1-1: Product: USB2.1 Hub 3521 [ 2.361866] usb 1-1: Manufacturer: GenesysLogic 3522 [ 2.415790] hub 1-1:1.0: USB hub found 3523 [ 2.416022] hub 1-1:1.0: 4 ports detected 3524 [ 2.491601] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 3525 [ 2.518074] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 3526 [ 2.518077] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 3527 [ 2.518080] usb 2-1: Product: USB3.1 Hub 3528 [ 2.518082] usb 2-1: Manufacturer: GenesysLogic 3529 [ 2.543772] hub 2-1:1.0: USB hub found 3530 [ 2.544053] hub 2-1:1.0: 4 ports detected 3531 [ 2.774721] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 3532 [ 2.791514] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 3533 [ 2.922531] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 3534 [ 2.922537] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 3535 [ 2.922539] usb 1-1.1: Product: USB OPTICAL MOUSE 3536 [ 2.939494] systemd[1]: System time before build time, advancing clock. 3537 [ 2.943069] systemd[1]: Inserted module 'autofs4' 3538 [ 2.960125] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 3539 [ 2.960332] systemd[1]: Detected architecture arm64. 3540 [ 2.961788] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 3541 [ 2.961900] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 3542 [ 2.993894] systemd[1]: Set hostname to <odroidn2>. 3543 [ 3.067504] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 3544 [ 3.135975] random: systemd: uninitialized urandom read (16 bytes read) 3545 [ 3.138571] random: systemd: uninitialized urandom read (16 bytes read) 3546 [ 3.139732] systemd[1]: Created slice system-getty.slice. 3547 [ 3.139937] random: systemd: uninitialized urandom read (16 bytes read) 3548 [ 3.140028] systemd[1]: Listening on initctl Compatibility Named Pipe. 3549 [ 3.140402] systemd[1]: Created slice system-serial\x2dgetty.slice. 3550 [ 3.140698] systemd[1]: Listening on Journal Socket. 3551 [ 3.142081] systemd[1]: Starting Create list of required static device nodes for the current kernel... 3552 [ 3.142534] systemd[1]: Listening on udev Kernel Socket. 3553 [ 3.142839] systemd[1]: Listening on Journal Socket (/dev/log). 3554 [ 3.187310] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 3555 [ 3.200929] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 3556 [ 3.200938] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 3557 [ 3.200940] usb 1-1.3: Product: USB Keyboard 3558 [ 3.200942] usb 1-1.3: Manufacturer: Logitech 3559 [ 3.284705] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 3560 [ 3.343845] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 3561 [ 3.349779] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 3562 [ 3.373759] zram: Added device: zram0 3563 [ 3.373963] zram: Added device: zram1 3564 [ 3.374126] zram: Added device: zram2 3565 [ 3.407686] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 3566 [ 3.407779] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 3567 [ 3.412943] pwm-gpio pwmgpio: 1 gpio pwms loaded 3568 [ 3.438411] zram0: detected capacity change from 0 to 1904500736 3569 [ 3.480810] mc: Linux media interface: v0.10 3570 [ 3.481825] panfrost ffe40000.gpu: clock rate = 24000000 3571 [ 3.481875] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 3572 [ 3.483379] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 3573 [ 3.483386] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 3574 [ 3.483390] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 3575 [ 3.483392] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 3576 [ 3.496328] videodev: Linux video capture interface: v2.00 3577 [ 3.522467] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0 3578 [ 3.531227] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 3579 [ 3.534715] meson-drm ff900000.vpu: Queued 2 outputs on vpu 3580 [ 3.575878] meson-drm ff900000.vpu: CVBS Output connector not available 3581 [ 3.586666] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 3582 [ 3.603602] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 3583 [ 3.615733] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 3584 [ 3.615980] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 3585 [ 3.616242] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1 3586 [ 3.631555] Registered IR keymap rc-odroid 3587 [ 3.636472] IR NEC protocol handler initialized 3588 [ 3.663870] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 3589 [ 3.664645] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 3590 [ 3.664754] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 3591 [ 3.665689] meson-ir ff808000.ir: receiver initialized 3592 [ 3.904318] Console: switching to colour frame buffer device 240x67 3593 [ 3.926163] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 3594 [ 3.966804] axg-sound-card sound: ASoC: no DMI vendor name! 3595 [ 4.479513] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 3596 [ 4.521491] zram1: detected capacity change from 0 to 52428800 3597 [ 6.564743] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 3598 [ 6.564761] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 3599 [ 7.455362] systemd-journald[1849]: Received request to flush runtime journal from PID 1 3600 3601 ### armbian-release: 3602 3603 # PLEASE DO NOT EDIT THIS FILE 3604 BOARD=odroidn2 3605 BOARD_NAME="Odroid N2" 3606 BOARDFAMILY=meson-g12b 3607 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 3608 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 3609 DISTRIBUTION_CODENAME=buster 3610 DISTRIBUTION_STATUS=supported 3611 VERSION=21.02.3 3612 LINUXFAMILY=meson64 3613 BRANCH=current 3614 ARCH=arm64 3615 IMAGE_TYPE=stable 3616 BOARD_TYPE=conf 3617 INITRD_ARCH=arm64 3618 KERNEL_IMAGE_TYPE=Image 3619 3620 ### boot environment: 3621 3622 verbosity=1 3623 console=both 3624 overlay_prefix=meson 3625 bootlogo=true 3626 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 3627 rootfstype=ext4 3628 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 3629 3630 ### lsusb: 3631 3632 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 3633 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 3634 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 3635 Bus 001 Device 003: ID 275d:0ba6 3636 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 3637 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3638 3639 ### lscpu: 3640 3641 Architecture: aarch64 3642 Byte Order: Little Endian 3643 CPU(s): 6 3644 On-line CPU(s) list: 0-5 3645 Thread(s) per core: 1 3646 Core(s) per socket: 3 3647 Socket(s): 2 3648 NUMA node(s): 1 3649 Vendor ID: ARM 3650 Model: 4 3651 Model name: Cortex-A53 3652 Stepping: r0p4 3653 CPU max MHz: 2400.0000 3654 CPU min MHz: 100.0000 3655 BogoMIPS: 48.00 3656 L1d cache: unknown size 3657 L1i cache: unknown size 3658 L2 cache: unknown size 3659 NUMA node0 CPU(s): 0-5 3660 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3661 3662 ### cpuinfo: 3663 3664 processor : 0 3665 BogoMIPS : 48.00 3666 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3667 CPU implementer : 0x41 3668 CPU architecture: 8 3669 CPU variant : 0x0 3670 CPU part : 0xd03 3671 CPU revision : 4 3672 3673 processor : 1 3674 BogoMIPS : 48.00 3675 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3676 CPU implementer : 0x41 3677 CPU architecture: 8 3678 CPU variant : 0x0 3679 CPU part : 0xd03 3680 CPU revision : 4 3681 3682 processor : 2 3683 BogoMIPS : 48.00 3684 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3685 CPU implementer : 0x41 3686 CPU architecture: 8 3687 CPU variant : 0x0 3688 CPU part : 0xd09 3689 CPU revision : 2 3690 3691 processor : 3 3692 BogoMIPS : 48.00 3693 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3694 CPU implementer : 0x41 3695 CPU architecture: 8 3696 CPU variant : 0x0 3697 CPU part : 0xd09 3698 CPU revision : 2 3699 3700 processor : 4 3701 BogoMIPS : 48.00 3702 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3703 CPU implementer : 0x41 3704 CPU architecture: 8 3705 CPU variant : 0x0 3706 CPU part : 0xd09 3707 CPU revision : 2 3708 3709 processor : 5 3710 BogoMIPS : 48.00 3711 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 3712 CPU implementer : 0x41 3713 CPU architecture: 8 3714 CPU variant : 0x0 3715 CPU part : 0xd09 3716 CPU revision : 2 3717 3718 3719 ### meminfo: 3720 3721 MemTotal: 3719724 kB 3722 MemFree: 3412608 kB 3723 MemAvailable: 3372708 kB 3724 Buffers: 12536 kB 3725 Cached: 55444 kB 3726 SwapCached: 0 kB 3727 Active: 33220 kB 3728 Inactive: 156220 kB 3729 Active(anon): 128 kB 3730 Inactive(anon): 126268 kB 3731 Active(file): 33092 kB 3732 Inactive(file): 29952 kB 3733 Unevictable: 0 kB 3734 Mlocked: 0 kB 3735 SwapTotal: 1859860 kB 3736 SwapFree: 1859860 kB 3737 Dirty: 8896 kB 3738 Writeback: 0 kB 3739 AnonPages: 121512 kB 3740 Mapped: 14996 kB 3741 Shmem: 4936 kB 3742 KReclaimable: 13868 kB 3743 Slab: 45700 kB 3744 SReclaimable: 13868 kB 3745 SUnreclaim: 31832 kB 3746 KernelStack: 2624 kB 3747 PageTables: 5436 kB 3748 NFS_Unstable: 0 kB 3749 Bounce: 0 kB 3750 WritebackTmp: 0 kB 3751 CommitLimit: 3719720 kB 3752 Committed_AS: 4249712 kB 3753 VmallocTotal: 135290159040 kB 3754 VmallocUsed: 31444 kB 3755 VmallocChunk: 0 kB 3756 Percpu: 1392 kB 3757 HardwareCorrupted: 0 kB 3758 AnonHugePages: 40960 kB 3759 ShmemHugePages: 0 kB 3760 ShmemPmdMapped: 0 kB 3761 FileHugePages: 0 kB 3762 FilePmdMapped: 0 kB 3763 CmaTotal: 917504 kB 3764 CmaFree: 901724 kB 3765 HugePages_Total: 0 3766 HugePages_Free: 0 3767 HugePages_Rsvd: 0 3768 HugePages_Surp: 0 3769 Hugepagesize: 2048 kB 3770 Hugetlb: 0 kB 3771 3772 ### virtual memory: 3773 3774 vm.admin_reserve_kbytes = 8192 3775 vm.block_dump = 0 3776 vm.compaction_proactiveness = 20 3777 vm.compact_unevictable_allowed = 1 3778 vm.dirty_background_bytes = 0 3779 vm.dirty_background_ratio = 10 3780 vm.dirty_bytes = 0 3781 vm.dirty_expire_centisecs = 3000 3782 vm.dirty_ratio = 20 3783 vm.dirtytime_expire_seconds = 43200 3784 vm.dirty_writeback_centisecs = 500 3785 vm.extfrag_threshold = 500 3786 vm.hugetlb_shm_group = 0 3787 vm.laptop_mode = 0 3788 vm.legacy_va_layout = 0 3789 vm.lowmem_reserve_ratio = 256 256 32 0 3790 vm.max_map_count = 65530 3791 vm.memory_failure_early_kill = 0 3792 vm.memory_failure_recovery = 1 3793 vm.min_free_kbytes = 45056 3794 vm.min_slab_ratio = 5 3795 vm.min_unmapped_ratio = 1 3796 vm.mmap_min_addr = 4096 3797 vm.mmap_rnd_bits = 18 3798 vm.mmap_rnd_compat_bits = 11 3799 vm.nr_hugepages = 0 3800 vm.nr_hugepages_mempolicy = 0 3801 vm.nr_overcommit_hugepages = 0 3802 vm.numa_stat = 1 3803 vm.numa_zonelist_order = Node 3804 vm.oom_dump_tasks = 1 3805 vm.oom_kill_allocating_task = 0 3806 vm.overcommit_kbytes = 0 3807 vm.overcommit_memory = 0 3808 vm.overcommit_ratio = 50 3809 vm.page-cluster = 0 3810 vm.page_lock_unfairness = 5 3811 vm.panic_on_oom = 0 3812 vm.percpu_pagelist_fraction = 0 3813 vm.stat_interval = 1 3814 vm.swappiness = 100 3815 vm.user_reserve_kbytes = 115003 3816 vm.vfs_cache_pressure = 100 3817 vm.watermark_boost_factor = 15000 3818 vm.watermark_scale_factor = 10 3819 vm.zone_reclaim_mode = 0 3820 3821 ### ip addr: 3822 3823 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 3824 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 3825 inet XXX.XXX.0.1/8 scope host lo 3826 valid_lft forever preferred_lft forever 3827 inet6 ::1/128 scope host 3828 valid_lft forever preferred_lft forever 3829 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 3830 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 3831 3832 ### partitions: 3833 3834 major minor #blocks name 3835 3836 179 0 61071360 mmcblk0 3837 179 1 60456544 mmcblk0p1 3838 179 96 62367744 mmcblk1 3839 179 97 62366720 mmcblk1p1 3840 252 0 1859864 zram0 3841 252 1 51200 zram1 3842 3843 ### df: 3844 3845 udev 1.4G 0 1.4G 0% /dev 3846 tmpfs 364M 5.0M 359M 2% /run 3847 /dev/mmcblk0p1 57G 20G 37G 36% / 3848 tmpfs 1.8G 0 1.8G 0% /dev/shm 3849 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 3850 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 3851 tmpfs 1.8G 0 1.8G 0% /tmp 3852 /dev/zram1 49M 8.8M 37M 20% /var/log 3853 3854 ### lsblk: 3855 3856 NAME FSTYPE SIZE MOUNTPOINT UUID 3857 mmcblk0 58.2G 3858 └─mmcblk0p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 3859 mmcblk0boot0 4M 3860 mmcblk0boot1 4M 3861 mmcblk1 59.5G 3862 └─mmcblk1p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 3863 zram1 50M /var/log 3864 3865 ### zramctl: 3866 3867 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 3868 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 3869 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 3870 3871 ### mtab: 3872 3873 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 3874 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 3875 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 3876 3877 ### mmc1:aaaa info: 3878 3879 fwrev: 0x0 3880 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 3881 cid: 035344534836344780559b2001014a00 3882 rca: 0xaaaa 3883 csd: 400e0032db790001dbd37f800a404000 3884 manfid: 0x000003 3885 ocr: 0x00200000 3886 preferred_erase_size: 4194304 3887 type: SD 3888 hwrev: 0x8 3889 date: 10/2020 3890 dsr: 0x404 3891 erase_size: 512 3892 oemid: 0x5344 3893 serial: 0x559b2001 3894 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 3895 scr: 0245848300000000 3896 name: SH64G 3897 3898 ### mmc0:0001 info: 3899 3900 fwrev: 0x0400000000000000 3901 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 3902 cid: 150100434a54443452042559facb7700 3903 rel_sectors: 0x1 3904 enhanced_rpmb_supported: 0x1 3905 rca: 0x0001 3906 pre_eol_info: 0x01 3907 csd: d02701320f5903fff6dbffef8e404000 3908 manfid: 0x000015 3909 ocr: 0x00200000 3910 preferred_erase_size: 4194304 3911 enhanced_area_offset: 18446744073709551594 3912 raw_rpmb_size_mult: 0x20 3913 type: MMC 3914 hwrev: 0x0 3915 date: 07/2020 3916 prv: 0x4 3917 ffu_capable: 1 3918 dsr: 0x404 3919 erase_size: 524288 3920 life_time: 0x01 0x01 3921 enhanced_area_size: 4294967274 3922 oemid: 0x0100 3923 serial: 0x2559facb 3924 cmdq_en: 0 3925 rev: 0x8 3926 name: CJTD4R 3927 3928 ### Boot system health: 3929 3930 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 3931 19:19:38: 2400/2016MHz 0.00 22% 14% 6% 0% 1% 0% 30.3°C 0/12 3932 19:19:38: 2400/2016MHz 0.00 28% 17% 9% 0% 0% 0% 27.4°C 0/12 3933 19:19:39: 2400/2016MHz 0.00 18% 7% 10% 0% 0% 0% 27.1°C 0/12 3934 19:19:39: 2400/2016MHz 0.00 34% 19% 10% 0% 1% 1% 28.4°C 0/12 3935 19:19:39: 2400/2016MHz 0.00 90% 43% 28% 0% 14% 4% 30.4°C 0/12 3936 3937 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 3938 3939 ### Activated Armbian ramlog partition with zstd compression 3940 3941 Tue 30 Mar 2021 07:19:37 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 3942 3943 ### dmesg: 3944 3945 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 3946 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 3947 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 3948 [ 0.000000] efi: UEFI not found. 3949 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 3950 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 3951 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 3952 [ 0.000000] NUMA: No NUMA configuration found 3953 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 3954 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 3955 [ 0.000000] Zone ranges: 3956 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 3957 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 3958 [ 0.000000] Normal empty 3959 [ 0.000000] Movable zone start for each node 3960 [ 0.000000] Early memory node ranges 3961 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 3962 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 3963 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 3964 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 3965 [ 0.000000] On node 0 totalpages: 972800 3966 [ 0.000000] DMA zone: 4096 pages used for memmap 3967 [ 0.000000] DMA zone: 0 pages reserved 3968 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 3969 [ 0.000000] DMA32 zone: 11104 pages used for memmap 3970 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 3971 [ 0.000000] psci: probing for conduit method from DT. 3972 [ 0.000000] psci: PSCIv1.0 detected in firmware. 3973 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 3974 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 3975 [ 0.000000] psci: SMC Calling Convention v1.1 3976 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 3977 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 3978 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 3979 [ 0.000000] Detected VIPT I-cache on CPU0 3980 [ 0.000000] CPU features: detected: ARM erratum 845719 3981 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 3982 [ 0.000000] Policy zone: DMA32 3983 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 3984 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 3985 Please use sysfs to set IO scheduler for individual devices. 3986 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 3987 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 3988 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 3989 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 3990 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 3991 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 3992 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 3993 [ 0.000000] rcu: RCU event tracing is enabled. 3994 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 3995 [ 0.000000] Trampoline variant of Tasks RCU enabled. 3996 [ 0.000000] Rude variant of Tasks RCU enabled. 3997 [ 0.000000] Tracing variant of Tasks RCU enabled. 3998 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 3999 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 4000 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 4001 [ 0.000000] GIC: Using split EOI/Deactivate mode 4002 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 4003 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 4004 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 4005 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 4006 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 4007 [ 0.000254] Console: colour dummy device 80x25 4008 [ 0.000288] printk: console [tty1] enabled 4009 [ 0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 4010 [ 0.000387] pid_max: default: 32768 minimum: 301 4011 [ 0.000470] LSM: Security Framework initializing 4012 [ 0.000496] Yama: becoming mindful. 4013 [ 0.000585] AppArmor: AppArmor initialized 4014 [ 0.000636] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 4015 [ 0.000655] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 4016 [ 0.002660] rcu: Hierarchical SRCU implementation. 4017 [ 0.005155] EFI services will not be available. 4018 [ 0.005575] smp: Bringing up secondary CPUs ... 4019 [ 0.006251] Detected VIPT I-cache on CPU1 4020 [ 0.006311] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 4021 [ 0.007504] CPU features: detected: ARM erratum 858921 4022 [ 0.007512] CPU features: detected: Spectre-v2 4023 [ 0.007515] CPU features: detected: Spectre-v4 4024 [ 0.007522] Detected VIPT I-cache on CPU2 4025 [ 0.007546] arch_timer: Enabling local workaround for ARM erratum 858921 4026 [ 0.007560] arch_timer: CPU2: Trapping CNTVCT access 4027 [ 0.007574] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 4028 [ 0.008282] Detected VIPT I-cache on CPU3 4029 [ 0.008298] arch_timer: Enabling local workaround for ARM erratum 858921 4030 [ 0.008306] arch_timer: CPU3: Trapping CNTVCT access 4031 [ 0.008314] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 4032 [ 0.008940] Detected VIPT I-cache on CPU4 4033 [ 0.008957] arch_timer: Enabling local workaround for ARM erratum 858921 4034 [ 0.008964] arch_timer: CPU4: Trapping CNTVCT access 4035 [ 0.008972] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 4036 [ 0.009584] Detected VIPT I-cache on CPU5 4037 [ 0.009600] arch_timer: Enabling local workaround for ARM erratum 858921 4038 [ 0.009607] arch_timer: CPU5: Trapping CNTVCT access 4039 [ 0.009615] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 4040 [ 0.009698] smp: Brought up 1 node, 6 CPUs 4041 [ 0.009716] SMP: Total of 6 processors activated. 4042 [ 0.009723] CPU features: detected: 32-bit EL0 Support 4043 [ 0.009729] CPU features: detected: CRC32 instructions 4044 [ 0.009735] CPU features: detected: 32-bit EL1 Support 4045 [ 0.021012] CPU: All CPU(s) started at EL2 4046 [ 0.021062] alternatives: patching kernel code 4047 [ 0.023062] devtmpfs: initialized 4048 [ 0.030746] Registered cp15_barrier emulation handler 4049 [ 0.030760] Registered setend emulation handler 4050 [ 0.030898] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 4051 [ 0.030939] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 4052 [ 0.046202] pinctrl core: initialized pinctrl subsystem 4053 [ 0.046943] DMI not present or invalid. 4054 [ 0.047314] NET: Registered protocol family 16 4055 [ 0.048845] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 4056 [ 0.049119] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 4057 [ 0.049363] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 4058 [ 0.049410] audit: initializing netlink subsys (disabled) 4059 [ 0.049528] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 4060 [ 0.050795] thermal_sys: Registered thermal governor 'fair_share' 4061 [ 0.050803] thermal_sys: Registered thermal governor 'bang_bang' 4062 [ 0.050809] thermal_sys: Registered thermal governor 'step_wise' 4063 [ 0.050812] thermal_sys: Registered thermal governor 'user_space' 4064 [ 0.051258] cpuidle: using governor menu 4065 [ 0.051603] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 4066 [ 0.051727] ASID allocator initialised with 65536 entries 4067 [ 0.052793] Serial: AMBA PL011 UART driver 4068 [ 0.085133] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 4069 [ 0.085143] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 4070 [ 0.085148] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 4071 [ 0.085152] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 4072 [ 0.090804] cryptd: max_cpu_qlen set to 1000 4073 [ 0.160291] raid6: neonx8 gen() 2781 MB/s 4074 [ 0.228334] raid6: neonx8 xor() 2042 MB/s 4075 [ 0.296397] raid6: neonx4 gen() 2996 MB/s 4076 [ 0.364462] raid6: neonx4 xor() 2348 MB/s 4077 [ 0.432527] raid6: neonx2 gen() 2582 MB/s 4078 [ 0.500588] raid6: neonx2 xor() 2136 MB/s 4079 [ 0.568652] raid6: neonx1 gen() 1966 MB/s 4080 [ 0.636713] raid6: neonx1 xor() 1720 MB/s 4081 [ 0.704777] raid6: int64x8 gen() 1374 MB/s 4082 [ 0.772847] raid6: int64x8 xor() 735 MB/s 4083 [ 0.840931] raid6: int64x4 gen() 1463 MB/s 4084 [ 0.908976] raid6: int64x4 xor() 733 MB/s 4085 [ 0.977036] raid6: int64x2 gen() 1362 MB/s 4086 [ 1.045107] raid6: int64x2 xor() 619 MB/s 4087 [ 1.113173] raid6: int64x1 gen() 1127 MB/s 4088 [ 1.181234] raid6: int64x1 xor() 462 MB/s 4089 [ 1.181238] raid6: using algorithm neonx4 gen() 2996 MB/s 4090 [ 1.181241] raid6: .... xor() 2348 MB/s, rmw enabled 4091 [ 1.181245] raid6: using neon recovery algorithm 4092 [ 1.181714] ACPI: Interpreter disabled. 4093 [ 1.182558] 5V: supplied by 12V 4094 [ 1.183461] VDDAO_3V3: supplied by 12V 4095 [ 1.183940] iommu: Default domain type: Translated 4096 [ 1.184064] vgaarb: loaded 4097 [ 1.184974] SCSI subsystem initialized 4098 [ 1.185223] usbcore: registered new interface driver usbfs 4099 [ 1.185256] usbcore: registered new interface driver hub 4100 [ 1.185292] usbcore: registered new device driver usb 4101 [ 1.185646] pps_core: LinuxPPS API ver. 1 registered 4102 [ 1.185650] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 4103 [ 1.185668] PTP clock support registered 4104 [ 1.185855] EDAC MC: Ver: 3.0.0 4105 [ 1.187185] NetLabel: Initializing 4106 [ 1.187192] NetLabel: domain hash size = 128 4107 [ 1.187194] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 4108 [ 1.187238] NetLabel: unlabeled traffic allowed by default 4109 [ 1.187667] clocksource: Switched to clocksource arch_sys_counter 4110 [ 1.187882] VFS: Disk quotas dquot_6.6.0 4111 [ 1.187929] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 4112 [ 1.188288] AppArmor: AppArmor Filesystem Enabled 4113 [ 1.188334] pnp: PnP ACPI: disabled 4114 [ 1.193563] NET: Registered protocol family 2 4115 [ 1.194011] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 4116 [ 1.194117] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 4117 [ 1.194374] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 4118 [ 1.194561] TCP: Hash tables configured (established 32768 bind 32768) 4119 [ 1.194713] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 4120 [ 1.194777] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 4121 [ 1.194823] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 4122 [ 1.194972] NET: Registered protocol family 1 4123 [ 1.194991] PCI: CLS 0 bytes, default 64 4124 [ 1.195118] Trying to unpack rootfs image as initramfs... 4125 [ 1.762573] Freeing initrd memory: 14920K 4126 [ 1.763521] kvm [1]: IPA Size Limit: 40 bits 4127 [ 1.764287] kvm [1]: vgic interrupt IRQ9 4128 [ 1.764419] kvm [1]: Hyp mode initialized successfully 4129 [ 1.769450] Initialise system trusted keyrings 4130 [ 1.769486] Key type blacklist registered 4131 [ 1.769619] workingset: timestamp_bits=44 max_order=20 bucket_order=0 4132 [ 1.772804] zbud: loaded 4133 [ 1.773789] squashfs: version 4.0 (2009/01/31) Phillip Lougher 4134 [ 1.774232] fuse: init (API version 7.32) 4135 [ 1.774981] integrity: Platform Keyring initialized 4136 [ 1.802702] xor: measuring software checksum speed 4137 [ 1.805552] 8regs : 3476 MB/sec 4138 [ 1.808008] 32regs : 4024 MB/sec 4139 [ 1.810654] arm64_neon : 3723 MB/sec 4140 [ 1.810657] xor: using function: 32regs (4024 MB/sec) 4141 [ 1.810664] Key type asymmetric registered 4142 [ 1.810668] Asymmetric key parser 'x509' registered 4143 [ 1.810703] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 4144 [ 1.810817] io scheduler mq-deadline registered 4145 [ 1.810822] io scheduler kyber registered 4146 [ 1.810901] io scheduler bfq registered 4147 [ 1.813463] gpio-447 (usb-hub-reset): hogged as output/high 4148 [ 1.816447] EINJ: ACPI disabled. 4149 [ 1.822715] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 4150 [ 1.824152] VCC_3V3: supplied by VDDAO_3V3 4151 [ 1.824187] FLASH_1V8: supplied by VCC_3V3 4152 [ 1.824217] VCC_1V8: supplied by VCC_3V3 4153 [ 1.824242] VDDAO_1V8: supplied by VDDAO_3V3 4154 [ 1.824286] VDDCPU_A: supplied by regulator-dummy 4155 [ 1.824639] VDDCPU_B: supplied by regulator-dummy 4156 [ 1.825315] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 4157 [ 1.827625] Serial: AMBA driver 4158 [ 1.827951] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 4159 [ 1.828043] printk: console [ttyAML0] enabled 4160 [ 1.828600] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 4161 [ 1.833903] loop: module loaded 4162 [ 1.835917] libphy: Fixed MDIO Bus: probed 4163 [ 1.836995] tun: Universal TUN/TAP device driver, 1.6 4164 [ 1.837638] thunder_xcv, ver 1.0 4165 [ 1.837667] thunder_bgx, ver 1.0 4166 [ 1.837692] nicpf, ver 1.0 4167 [ 1.838149] e1000e: Intel(R) PRO/1000 Network Driver 4168 [ 1.838152] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 4169 [ 1.838188] igb: Intel(R) Gigabit Ethernet Network Driver 4170 [ 1.838191] igb: Copyright (c) 2007-2014 Intel Corporation. 4171 [ 1.838219] igbvf: Intel(R) Gigabit Virtual Function Network Driver 4172 [ 1.838222] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 4173 [ 1.838349] sky2: driver version 1.30 4174 [ 1.838704] VFIO - User Level meta-driver version: 0.3 4175 [ 1.840147] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 4176 [ 1.840166] ehci-pci: EHCI PCI platform driver 4177 [ 1.840196] ehci-platform: EHCI generic platform driver 4178 [ 1.840336] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 4179 [ 1.840346] ohci-pci: OHCI PCI platform driver 4180 [ 1.840382] ohci-platform: OHCI generic platform driver 4181 [ 1.840806] usbcore: registered new interface driver usb-storage 4182 [ 1.842161] mousedev: PS/2 mouse device common for all mice 4183 [ 1.842554] i2c /dev entries driver 4184 [ 1.847881] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 4185 [ 1.848771] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 4186 [ 1.849672] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 4187 [ 1.850273] sdhci: Secure Digital Host Controller Interface driver 4188 [ 1.850278] sdhci: Copyright(c) Pierre Ossman 4189 [ 1.850382] Synopsys Designware Multimedia Card Interface Driver 4190 [ 1.850835] sdhci-pltfm: SDHCI platform and OF driver helper 4191 [ 1.851648] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 4192 [ 1.852136] ledtrig-cpu: registered to indicate activity on CPUs 4193 [ 1.852394] meson-sm: secure-monitor enabled 4194 [ 1.852571] hid: raw HID events driver (C) Jiri Kosina 4195 [ 1.852644] usbcore: registered new interface driver usbhid 4196 [ 1.852646] usbhid: USB HID core driver 4197 [ 1.853516] NET: Registered protocol family 10 4198 [ 1.853904] Segment Routing with IPv6 4199 [ 1.853930] NET: Registered protocol family 17 4200 [ 1.853987] 8021q: 802.1Q VLAN Support v1.8 4201 [ 1.854014] Key type dns_resolver registered 4202 [ 1.854280] registered taskstats version 1 4203 [ 1.854285] Loading compiled-in X.509 certificates 4204 [ 1.855822] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 4205 [ 1.857265] zswap: loaded using pool zstd/z3fold 4206 [ 1.857448] Key type ._fscrypt registered 4207 [ 1.857450] Key type .fscrypt registered 4208 [ 1.857452] Key type fscrypt-provisioning registered 4209 [ 1.858466] Btrfs loaded, crc32c=crc32c-generic 4210 [ 1.863512] Key type encrypted registered 4211 [ 1.863524] AppArmor: AppArmor sha1 policy hashing enabled 4212 [ 1.868868] HUB_5V: supplied by 5V 4213 [ 1.869087] USB_PWR_EN: supplied by 5V 4214 [ 1.870525] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 4215 [ 1.870533] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 4216 [ 1.873221] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 4217 [ 1.873267] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 4218 [ 1.873354] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 4219 [ 1.873864] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 4220 [ 1.873874] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 4221 [ 1.873955] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 4222 [ 1.873973] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 4223 [ 1.874084] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 4224 [ 1.874086] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 4225 [ 1.874089] usb usb1: Product: xHCI Host Controller 4226 [ 1.874090] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 4227 [ 1.874092] usb usb1: SerialNumber: xhci-hcd.0.auto 4228 [ 1.874263] hub 1-0:1.0: USB hub found 4229 [ 1.874274] hub 1-0:1.0: 2 ports detected 4230 [ 1.874380] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 4231 [ 1.874385] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 4232 [ 1.874390] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 4233 [ 1.874408] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 4234 [ 1.874436] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 4235 [ 1.874438] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 4236 [ 1.874440] usb usb2: Product: xHCI Host Controller 4237 [ 1.874442] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 4238 [ 1.874443] usb usb2: SerialNumber: xhci-hcd.0.auto 4239 [ 1.874556] hub 2-0:1.0: USB hub found 4240 [ 1.874565] hub 2-0:1.0: 1 port detected 4241 [ 1.874812] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 4242 [ 1.875557] meson-gx-mmc ffe05000.sd: Got CD GPIO 4243 [ 1.900944] Freeing unused kernel memory: 3328K 4244 [ 1.943716] Run /init as init process 4245 [ 1.943720] with arguments: 4246 [ 1.943722] /init 4247 [ 1.943723] with environment: 4248 [ 1.943725] HOME=/ 4249 [ 1.943726] TERM=linux 4250 [ 1.943728] hdmimode=custombuilt 4251 [ 1.943729] cvbsmode=576cvbs 4252 [ 1.943730] max_freq_a53=1908 4253 [ 1.943731] max_freq_a73=2208 4254 [ 1.943732] voutmode=hdmi 4255 [ 1.943734] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 4256 [ 1.943735] disablehpd=false 4257 [ 1.943736] cvbscable= 4258 [ 1.943738] overscan=100 4259 [ 2.078648] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 4260 [ 2.078666] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 4261 [ 2.078850] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 4262 [ 2.080218] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 4263 [ 2.080226] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 4264 [ 2.080229] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 4265 [ 2.080232] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 4266 [ 2.080234] meson8b-dwmac ff3f0000.ethernet: COE Type 2 4267 [ 2.080235] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 4268 [ 2.080237] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 4269 [ 2.080273] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 4270 [ 2.080275] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 4271 [ 2.080277] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 4272 [ 2.080442] libphy: stmmac: probed 4273 [ 2.081352] libphy: mdio_mux: probed 4274 [ 2.083802] meson-vrtc ff8000a8.rtc: registered as rtc1 4275 [ 2.102508] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 4276 [ 2.102630] rtc-pcf8563 1-0051: registered as rtc0 4277 [ 2.103963] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 4278 [ 2.103975] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 4279 [ 2.133745] mmc1: new ultra high speed SDR104 SDXC card at address aaaa 4280 [ 2.134299] mmcblk1: mmc1:aaaa SH64G 59.5 GiB 4281 [ 2.136127] mmcblk1: p1 4282 [ 2.174534] mmc0: new HS200 MMC card at address 0001 4283 [ 2.175307] mmcblk0: mmc0:0001 CJTD4R 58.2 GiB 4284 [ 2.175876] mmcblk0boot0: mmc0:0001 CJTD4R partition 1 4.00 MiB 4285 [ 2.176316] mmcblk0boot1: mmc0:0001 CJTD4R partition 2 4.00 MiB 4286 [ 2.176500] mmcblk0rpmb: mmc0:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 4287 [ 2.177782] mmcblk0: p1 4288 [ 2.181580] random: fast init done 4289 [ 2.211707] usb 1-1: new high-speed USB device number 2 using xhci-hcd 4290 [ 2.280096] libphy: mdio_mux: probed 4291 [ 2.362025] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 4292 [ 2.362034] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 4293 [ 2.362038] usb 1-1: Product: USB2.1 Hub 4294 [ 2.362042] usb 1-1: Manufacturer: GenesysLogic 4295 [ 2.418672] hub 1-1:1.0: USB hub found 4296 [ 2.418916] hub 1-1:1.0: 4 ports detected 4297 [ 2.487791] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 4298 [ 2.510251] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 4299 [ 2.510253] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 4300 [ 2.510256] usb 2-1: Product: USB3.1 Hub 4301 [ 2.510258] usb 2-1: Manufacturer: GenesysLogic 4302 [ 2.530585] hub 2-1:1.0: USB hub found 4303 [ 2.530865] hub 2-1:1.0: 4 ports detected 4304 [ 2.791689] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 4305 [ 2.918727] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 4306 [ 2.918735] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 4307 [ 2.918739] usb 1-1.1: Product: USB OPTICAL MOUSE 4308 [ 2.948627] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 4309 [ 2.965104] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 4310 [ 2.965326] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 4311 [ 3.067686] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 4312 [ 3.123690] systemd[1]: System time before build time, advancing clock. 4313 [ 3.127278] systemd[1]: Inserted module 'autofs4' 4314 [ 3.144215] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 4315 [ 3.144393] systemd[1]: Detected architecture arm64. 4316 [ 3.165130] systemd[1]: Set hostname to <odroidn2>. 4317 [ 3.201569] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 4318 [ 3.201584] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 4319 [ 3.201588] usb 1-1.3: Product: USB Keyboard 4320 [ 3.201592] usb 1-1.3: Manufacturer: Logitech 4321 [ 3.287720] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 4322 [ 3.348117] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 4323 [ 3.354538] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 4324 [ 3.411901] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 4325 [ 3.412063] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 4326 [ 3.422495] random: systemd: uninitialized urandom read (16 bytes read) 4327 [ 3.427893] random: systemd: uninitialized urandom read (16 bytes read) 4328 [ 3.430330] systemd[1]: Created slice system-serial\x2dgetty.slice. 4329 [ 3.430752] random: systemd: uninitialized urandom read (16 bytes read) 4330 [ 3.431642] systemd[1]: Created slice system-getty.slice. 4331 [ 3.432196] systemd[1]: Listening on Journal Socket (/dev/log). 4332 [ 3.432296] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 4333 [ 3.432454] systemd[1]: Listening on udev Control Socket. 4334 [ 3.432525] systemd[1]: Reached target Remote File Systems. 4335 [ 3.432668] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 4336 [ 3.478533] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 4337 [ 3.689664] pwm-gpio pwmgpio: 1 gpio pwms loaded 4338 [ 3.751325] zram: Added device: zram0 4339 [ 3.751716] zram: Added device: zram1 4340 [ 3.752952] zram: Added device: zram2 4341 [ 3.772112] meson-drm ff900000.vpu: Queued 2 outputs on vpu 4342 [ 3.775890] meson-drm ff900000.vpu: CVBS Output connector not available 4343 [ 3.811392] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 4344 [ 3.811451] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 4345 [ 3.812062] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 4346 [ 3.812111] mc: Linux media interface: v0.10 4347 [ 3.812286] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 4348 [ 3.812493] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 4349 [ 3.825394] videodev: Linux video capture interface: v2.00 4350 [ 3.825714] zram0: detected capacity change from 0 to 1904500736 4351 [ 3.855705] Registered IR keymap rc-odroid 4352 [ 3.858219] panfrost ffe40000.gpu: clock rate = 24000000 4353 [ 3.858280] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 4354 [ 3.861876] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 4355 [ 3.861884] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 4356 [ 3.861888] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 4357 [ 3.861890] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 4358 [ 3.876846] IR NEC protocol handler initialized 4359 [ 3.892987] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 4360 [ 3.899360] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 4361 [ 3.907763] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 4362 [ 3.908023] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 4363 [ 3.908088] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 4364 [ 3.910031] meson-ir ff808000.ir: receiver initialized 4365 [ 4.152555] Console: switching to colour frame buffer device 240x67 4366 [ 4.183762] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 4367 [ 4.224183] axg-sound-card sound: ASoC: no DMI vendor name! 4368 [ 4.855686] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 4369 [ 4.896742] zram1: detected capacity change from 0 to 52428800 4370 [ 6.940517] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 4371 [ 6.940536] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 4372 [ 7.828560] systemd-journald[1852]: Received request to flush runtime journal from PID 1 4373 4374 ### armbian-release: 4375 4376 # PLEASE DO NOT EDIT THIS FILE 4377 BOARD=odroidn2 4378 BOARD_NAME="Odroid N2" 4379 BOARDFAMILY=meson-g12b 4380 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 4381 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 4382 DISTRIBUTION_CODENAME=buster 4383 DISTRIBUTION_STATUS=supported 4384 VERSION=21.02.3 4385 LINUXFAMILY=meson64 4386 BRANCH=current 4387 ARCH=arm64 4388 IMAGE_TYPE=stable 4389 BOARD_TYPE=conf 4390 INITRD_ARCH=arm64 4391 KERNEL_IMAGE_TYPE=Image 4392 4393 ### boot environment: 4394 4395 verbosity=1 4396 console=both 4397 overlay_prefix=meson 4398 bootlogo=true 4399 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 4400 rootfstype=ext4 4401 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 4402 4403 ### lsusb: 4404 4405 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 4406 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 4407 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 4408 Bus 001 Device 003: ID 275d:0ba6 4409 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 4410 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 4411 4412 ### lscpu: 4413 4414 Architecture: aarch64 4415 Byte Order: Little Endian 4416 CPU(s): 6 4417 On-line CPU(s) list: 0-5 4418 Thread(s) per core: 1 4419 Core(s) per socket: 3 4420 Socket(s): 2 4421 NUMA node(s): 1 4422 Vendor ID: ARM 4423 Model: 4 4424 Model name: Cortex-A53 4425 Stepping: r0p4 4426 CPU max MHz: 2400.0000 4427 CPU min MHz: 100.0000 4428 BogoMIPS: 48.00 4429 L1d cache: unknown size 4430 L1i cache: unknown size 4431 L2 cache: unknown size 4432 NUMA node0 CPU(s): 0-5 4433 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4434 4435 ### cpuinfo: 4436 4437 processor : 0 4438 BogoMIPS : 48.00 4439 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4440 CPU implementer : 0x41 4441 CPU architecture: 8 4442 CPU variant : 0x0 4443 CPU part : 0xd03 4444 CPU revision : 4 4445 4446 processor : 1 4447 BogoMIPS : 48.00 4448 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4449 CPU implementer : 0x41 4450 CPU architecture: 8 4451 CPU variant : 0x0 4452 CPU part : 0xd03 4453 CPU revision : 4 4454 4455 processor : 2 4456 BogoMIPS : 48.00 4457 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4458 CPU implementer : 0x41 4459 CPU architecture: 8 4460 CPU variant : 0x0 4461 CPU part : 0xd09 4462 CPU revision : 2 4463 4464 processor : 3 4465 BogoMIPS : 48.00 4466 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4467 CPU implementer : 0x41 4468 CPU architecture: 8 4469 CPU variant : 0x0 4470 CPU part : 0xd09 4471 CPU revision : 2 4472 4473 processor : 4 4474 BogoMIPS : 48.00 4475 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4476 CPU implementer : 0x41 4477 CPU architecture: 8 4478 CPU variant : 0x0 4479 CPU part : 0xd09 4480 CPU revision : 2 4481 4482 processor : 5 4483 BogoMIPS : 48.00 4484 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 4485 CPU implementer : 0x41 4486 CPU architecture: 8 4487 CPU variant : 0x0 4488 CPU part : 0xd09 4489 CPU revision : 2 4490 4491 4492 ### meminfo: 4493 4494 MemTotal: 3719724 kB 4495 MemFree: 3394208 kB 4496 MemAvailable: 3354456 kB 4497 Buffers: 12676 kB 4498 Cached: 55724 kB 4499 SwapCached: 0 kB 4500 Active: 33160 kB 4501 Inactive: 174436 kB 4502 Active(anon): 144 kB 4503 Inactive(anon): 143836 kB 4504 Active(file): 33016 kB 4505 Inactive(file): 30600 kB 4506 Unevictable: 0 kB 4507 Mlocked: 0 kB 4508 SwapTotal: 1859860 kB 4509 SwapFree: 1859860 kB 4510 Dirty: 9200 kB 4511 Writeback: 0 kB 4512 AnonPages: 138940 kB 4513 Mapped: 16252 kB 4514 Shmem: 4936 kB 4515 KReclaimable: 14104 kB 4516 Slab: 46440 kB 4517 SReclaimable: 14104 kB 4518 SUnreclaim: 32336 kB 4519 KernelStack: 2592 kB 4520 PageTables: 5380 kB 4521 NFS_Unstable: 0 kB 4522 Bounce: 0 kB 4523 WritebackTmp: 0 kB 4524 CommitLimit: 3719720 kB 4525 Committed_AS: 4249880 kB 4526 VmallocTotal: 135290159040 kB 4527 VmallocUsed: 31460 kB 4528 VmallocChunk: 0 kB 4529 Percpu: 1416 kB 4530 HardwareCorrupted: 0 kB 4531 AnonHugePages: 0 kB 4532 ShmemHugePages: 0 kB 4533 ShmemPmdMapped: 0 kB 4534 FileHugePages: 0 kB 4535 FilePmdMapped: 0 kB 4536 CmaTotal: 917504 kB 4537 CmaFree: 901724 kB 4538 HugePages_Total: 0 4539 HugePages_Free: 0 4540 HugePages_Rsvd: 0 4541 HugePages_Surp: 0 4542 Hugepagesize: 2048 kB 4543 Hugetlb: 0 kB 4544 4545 ### virtual memory: 4546 4547 vm.admin_reserve_kbytes = 8192 4548 vm.block_dump = 0 4549 vm.compaction_proactiveness = 20 4550 vm.compact_unevictable_allowed = 1 4551 vm.dirty_background_bytes = 0 4552 vm.dirty_background_ratio = 10 4553 vm.dirty_bytes = 0 4554 vm.dirty_expire_centisecs = 3000 4555 vm.dirty_ratio = 20 4556 vm.dirtytime_expire_seconds = 43200 4557 vm.dirty_writeback_centisecs = 500 4558 vm.extfrag_threshold = 500 4559 vm.hugetlb_shm_group = 0 4560 vm.laptop_mode = 0 4561 vm.legacy_va_layout = 0 4562 vm.lowmem_reserve_ratio = 256 256 32 0 4563 vm.max_map_count = 65530 4564 vm.memory_failure_early_kill = 0 4565 vm.memory_failure_recovery = 1 4566 vm.min_free_kbytes = 45056 4567 vm.min_slab_ratio = 5 4568 vm.min_unmapped_ratio = 1 4569 vm.mmap_min_addr = 4096 4570 vm.mmap_rnd_bits = 18 4571 vm.mmap_rnd_compat_bits = 11 4572 vm.nr_hugepages = 0 4573 vm.nr_hugepages_mempolicy = 0 4574 vm.nr_overcommit_hugepages = 0 4575 vm.numa_stat = 1 4576 vm.numa_zonelist_order = Node 4577 vm.oom_dump_tasks = 1 4578 vm.oom_kill_allocating_task = 0 4579 vm.overcommit_kbytes = 0 4580 vm.overcommit_memory = 0 4581 vm.overcommit_ratio = 50 4582 vm.page-cluster = 0 4583 vm.page_lock_unfairness = 5 4584 vm.panic_on_oom = 0 4585 vm.percpu_pagelist_fraction = 0 4586 vm.stat_interval = 1 4587 vm.swappiness = 100 4588 vm.user_reserve_kbytes = 115071 4589 vm.vfs_cache_pressure = 100 4590 vm.watermark_boost_factor = 15000 4591 vm.watermark_scale_factor = 10 4592 vm.zone_reclaim_mode = 0 4593 4594 ### ip addr: 4595 4596 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 4597 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 4598 inet XXX.XXX.0.1/8 scope host lo 4599 valid_lft forever preferred_lft forever 4600 inet6 ::1/128 scope host 4601 valid_lft forever preferred_lft forever 4602 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 4603 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 4604 4605 ### partitions: 4606 4607 major minor #blocks name 4608 4609 179 0 62367744 mmcblk1 4610 179 1 62366720 mmcblk1p1 4611 179 32 61071360 mmcblk0 4612 179 33 60456544 mmcblk0p1 4613 252 0 1859864 zram0 4614 252 1 51200 zram1 4615 4616 ### df: 4617 4618 udev 1.4G 0 1.4G 0% /dev 4619 tmpfs 364M 5.0M 359M 2% /run 4620 /dev/mmcblk0p1 57G 20G 37G 36% / 4621 tmpfs 1.8G 0 1.8G 0% /dev/shm 4622 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 4623 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 4624 tmpfs 1.8G 0 1.8G 0% /tmp 4625 /dev/zram1 49M 9.0M 36M 20% /var/log 4626 4627 ### lsblk: 4628 4629 NAME FSTYPE SIZE MOUNTPOINT UUID 4630 mmcblk1 59.5G 4631 └─mmcblk1p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 4632 mmcblk0 58.2G 4633 └─mmcblk0p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 4634 mmcblk0boot0 4M 4635 mmcblk0boot1 4M 4636 zram1 50M /var/log 4637 4638 ### zramctl: 4639 4640 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 4641 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 4642 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 4643 4644 ### mtab: 4645 4646 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 4647 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 4648 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 4649 4650 ### mmc1:aaaa info: 4651 4652 fwrev: 0x0 4653 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 4654 cid: 035344534836344780559b2001014a00 4655 rca: 0xaaaa 4656 csd: 400e0032db790001dbd37f800a404000 4657 manfid: 0x000003 4658 ocr: 0x00200000 4659 preferred_erase_size: 4194304 4660 type: SD 4661 hwrev: 0x8 4662 date: 10/2020 4663 dsr: 0x404 4664 erase_size: 512 4665 oemid: 0x5344 4666 serial: 0x559b2001 4667 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 4668 scr: 0245848300000000 4669 name: SH64G 4670 4671 ### mmc0:0001 info: 4672 4673 fwrev: 0x0400000000000000 4674 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 4675 cid: 150100434a54443452042559facb7700 4676 rel_sectors: 0x1 4677 enhanced_rpmb_supported: 0x1 4678 rca: 0x0001 4679 pre_eol_info: 0x01 4680 csd: d02701320f5903fff6dbffef8e404000 4681 manfid: 0x000015 4682 ocr: 0x00200000 4683 preferred_erase_size: 4194304 4684 enhanced_area_offset: 18446744073709551594 4685 raw_rpmb_size_mult: 0x20 4686 type: MMC 4687 hwrev: 0x0 4688 date: 07/2020 4689 prv: 0x4 4690 ffu_capable: 1 4691 dsr: 0x404 4692 erase_size: 524288 4693 life_time: 0x01 0x01 4694 enhanced_area_size: 4294967274 4695 oemid: 0x0100 4696 serial: 0x2559facb 4697 cmdq_en: 0 4698 rev: 0x8 4699 name: CJTD4R 4700 4701 ### Boot system health: 4702 4703 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 4704 19:19:38: 2400/2016MHz 0.00 21% 13% 6% 0% 1% 0% 31.1°C 0/12 4705 19:19:38: 2400/2016MHz 0.00 35% 23% 11% 0% 0% 0% 31.4°C 0/12 4706 19:19:39: 2400/2016MHz 0.00 19% 8% 9% 0% 0% 0% 28.6°C 0/12 4707 19:19:39: 2400/2016MHz 0.00 18% 9% 9% 0% 0% 0% 28.8°C 0/12 4708 19:19:39: 2400/2016MHz 1.04 87% 45% 23% 0% 14% 3% 31.8°C 0/12 4709 4710 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 4711 4712 ### Activated Armbian ramlog partition with zstd compression 4713 4714 Sun 04 Apr 2021 06:28:06 AM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 4715 4716 ### dmesg: 4717 4718 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 4719 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 4720 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 4721 [ 0.000000] efi: UEFI not found. 4722 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 4723 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 4724 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 4725 [ 0.000000] NUMA: No NUMA configuration found 4726 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 4727 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 4728 [ 0.000000] Zone ranges: 4729 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 4730 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 4731 [ 0.000000] Normal empty 4732 [ 0.000000] Movable zone start for each node 4733 [ 0.000000] Early memory node ranges 4734 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 4735 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 4736 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 4737 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 4738 [ 0.000000] On node 0 totalpages: 972800 4739 [ 0.000000] DMA zone: 4096 pages used for memmap 4740 [ 0.000000] DMA zone: 0 pages reserved 4741 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 4742 [ 0.000000] DMA32 zone: 11104 pages used for memmap 4743 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 4744 [ 0.000000] psci: probing for conduit method from DT. 4745 [ 0.000000] psci: PSCIv1.0 detected in firmware. 4746 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 4747 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 4748 [ 0.000000] psci: SMC Calling Convention v1.1 4749 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 4750 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 4751 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 4752 [ 0.000000] Detected VIPT I-cache on CPU0 4753 [ 0.000000] CPU features: detected: ARM erratum 845719 4754 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 4755 [ 0.000000] Policy zone: DMA32 4756 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 4757 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 4758 Please use sysfs to set IO scheduler for individual devices. 4759 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 4760 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 4761 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 4762 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 4763 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 4764 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 4765 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 4766 [ 0.000000] rcu: RCU event tracing is enabled. 4767 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 4768 [ 0.000000] Trampoline variant of Tasks RCU enabled. 4769 [ 0.000000] Rude variant of Tasks RCU enabled. 4770 [ 0.000000] Tracing variant of Tasks RCU enabled. 4771 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 4772 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 4773 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 4774 [ 0.000000] GIC: Using split EOI/Deactivate mode 4775 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 4776 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 4777 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 4778 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 4779 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 4780 [ 0.000253] Console: colour dummy device 80x25 4781 [ 0.000289] printk: console [tty1] enabled 4782 [ 0.000375] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 4783 [ 0.000388] pid_max: default: 32768 minimum: 301 4784 [ 0.000470] LSM: Security Framework initializing 4785 [ 0.000496] Yama: becoming mindful. 4786 [ 0.000586] AppArmor: AppArmor initialized 4787 [ 0.000636] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 4788 [ 0.000655] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 4789 [ 0.002666] rcu: Hierarchical SRCU implementation. 4790 [ 0.005143] EFI services will not be available. 4791 [ 0.005563] smp: Bringing up secondary CPUs ... 4792 [ 0.006243] Detected VIPT I-cache on CPU1 4793 [ 0.006304] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 4794 [ 0.007501] CPU features: detected: ARM erratum 858921 4795 [ 0.007509] CPU features: detected: Spectre-v2 4796 [ 0.007513] CPU features: detected: Spectre-v4 4797 [ 0.007519] Detected VIPT I-cache on CPU2 4798 [ 0.007544] arch_timer: Enabling local workaround for ARM erratum 858921 4799 [ 0.007558] arch_timer: CPU2: Trapping CNTVCT access 4800 [ 0.007572] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 4801 [ 0.008282] Detected VIPT I-cache on CPU3 4802 [ 0.008299] arch_timer: Enabling local workaround for ARM erratum 858921 4803 [ 0.008306] arch_timer: CPU3: Trapping CNTVCT access 4804 [ 0.008314] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 4805 [ 0.008945] Detected VIPT I-cache on CPU4 4806 [ 0.008962] arch_timer: Enabling local workaround for ARM erratum 858921 4807 [ 0.008968] arch_timer: CPU4: Trapping CNTVCT access 4808 [ 0.008976] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 4809 [ 0.009590] Detected VIPT I-cache on CPU5 4810 [ 0.009606] arch_timer: Enabling local workaround for ARM erratum 858921 4811 [ 0.009613] arch_timer: CPU5: Trapping CNTVCT access 4812 [ 0.009621] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 4813 [ 0.009703] smp: Brought up 1 node, 6 CPUs 4814 [ 0.009720] SMP: Total of 6 processors activated. 4815 [ 0.009728] CPU features: detected: 32-bit EL0 Support 4816 [ 0.009734] CPU features: detected: CRC32 instructions 4817 [ 0.009740] CPU features: detected: 32-bit EL1 Support 4818 [ 0.020949] CPU: All CPU(s) started at EL2 4819 [ 0.020999] alternatives: patching kernel code 4820 [ 0.022995] devtmpfs: initialized 4821 [ 0.030686] Registered cp15_barrier emulation handler 4822 [ 0.030701] Registered setend emulation handler 4823 [ 0.030841] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 4824 [ 0.030883] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 4825 [ 0.046157] pinctrl core: initialized pinctrl subsystem 4826 [ 0.046697] DMI not present or invalid. 4827 [ 0.047092] NET: Registered protocol family 16 4828 [ 0.048709] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 4829 [ 0.048983] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 4830 [ 0.049213] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 4831 [ 0.049255] audit: initializing netlink subsys (disabled) 4832 [ 0.049354] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 4833 [ 0.050587] thermal_sys: Registered thermal governor 'fair_share' 4834 [ 0.050595] thermal_sys: Registered thermal governor 'bang_bang' 4835 [ 0.050598] thermal_sys: Registered thermal governor 'step_wise' 4836 [ 0.050601] thermal_sys: Registered thermal governor 'user_space' 4837 [ 0.051052] cpuidle: using governor menu 4838 [ 0.051396] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 4839 [ 0.051517] ASID allocator initialised with 65536 entries 4840 [ 0.052545] Serial: AMBA PL011 UART driver 4841 [ 0.086283] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 4842 [ 0.086296] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 4843 [ 0.086301] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 4844 [ 0.086307] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 4845 [ 0.088418] cryptd: max_cpu_qlen set to 1000 4846 [ 0.156296] raid6: neonx8 gen() 2786 MB/s 4847 [ 0.224351] raid6: neonx8 xor() 2041 MB/s 4848 [ 0.292442] raid6: neonx4 gen() 2994 MB/s 4849 [ 0.360504] raid6: neonx4 xor() 2354 MB/s 4850 [ 0.428548] raid6: neonx2 gen() 2528 MB/s 4851 [ 0.496614] raid6: neonx2 xor() 2205 MB/s 4852 [ 0.564701] raid6: neonx1 gen() 1937 MB/s 4853 [ 0.632742] raid6: neonx1 xor() 1716 MB/s 4854 [ 0.700806] raid6: int64x8 gen() 1376 MB/s 4855 [ 0.768878] raid6: int64x8 xor() 735 MB/s 4856 [ 0.836968] raid6: int64x4 gen() 1463 MB/s 4857 [ 0.904998] raid6: int64x4 xor() 733 MB/s 4858 [ 0.973067] raid6: int64x2 gen() 1362 MB/s 4859 [ 1.041128] raid6: int64x2 xor() 619 MB/s 4860 [ 1.109205] raid6: int64x1 gen() 1127 MB/s 4861 [ 1.177256] raid6: int64x1 xor() 462 MB/s 4862 [ 1.177259] raid6: using algorithm neonx4 gen() 2994 MB/s 4863 [ 1.177262] raid6: .... xor() 2354 MB/s, rmw enabled 4864 [ 1.177265] raid6: using neon recovery algorithm 4865 [ 1.177709] ACPI: Interpreter disabled. 4866 [ 1.178492] 5V: supplied by 12V 4867 [ 1.179402] VDDAO_3V3: supplied by 12V 4868 [ 1.179887] iommu: Default domain type: Translated 4869 [ 1.180070] vgaarb: loaded 4870 [ 1.180902] SCSI subsystem initialized 4871 [ 1.181117] usbcore: registered new interface driver usbfs 4872 [ 1.181160] usbcore: registered new interface driver hub 4873 [ 1.181202] usbcore: registered new device driver usb 4874 [ 1.181562] pps_core: LinuxPPS API ver. 1 registered 4875 [ 1.181568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 4876 [ 1.181587] PTP clock support registered 4877 [ 1.181773] EDAC MC: Ver: 3.0.0 4878 [ 1.183055] NetLabel: Initializing 4879 [ 1.183061] NetLabel: domain hash size = 128 4880 [ 1.183064] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 4881 [ 1.183106] NetLabel: unlabeled traffic allowed by default 4882 [ 1.183540] clocksource: Switched to clocksource arch_sys_counter 4883 [ 1.183766] VFS: Disk quotas dquot_6.6.0 4884 [ 1.183809] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 4885 [ 1.184173] AppArmor: AppArmor Filesystem Enabled 4886 [ 1.184220] pnp: PnP ACPI: disabled 4887 [ 1.189765] NET: Registered protocol family 2 4888 [ 1.190227] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 4889 [ 1.190331] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 4890 [ 1.190591] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 4891 [ 1.190779] TCP: Hash tables configured (established 32768 bind 32768) 4892 [ 1.190927] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 4893 [ 1.190991] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 4894 [ 1.191037] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 4895 [ 1.191181] NET: Registered protocol family 1 4896 [ 1.191206] PCI: CLS 0 bytes, default 64 4897 [ 1.191338] Trying to unpack rootfs image as initramfs... 4898 [ 1.759384] Freeing initrd memory: 14920K 4899 [ 1.760332] kvm [1]: IPA Size Limit: 40 bits 4900 [ 1.761054] kvm [1]: vgic interrupt IRQ9 4901 [ 1.761195] kvm [1]: Hyp mode initialized successfully 4902 [ 1.766276] Initialise system trusted keyrings 4903 [ 1.766307] Key type blacklist registered 4904 [ 1.766405] workingset: timestamp_bits=44 max_order=20 bucket_order=0 4905 [ 1.769640] zbud: loaded 4906 [ 1.770611] squashfs: version 4.0 (2009/01/31) Phillip Lougher 4907 [ 1.771060] fuse: init (API version 7.32) 4908 [ 1.771835] integrity: Platform Keyring initialized 4909 [ 1.799884] xor: measuring software checksum speed 4910 [ 1.802719] 8regs : 3476 MB/sec 4911 [ 1.805174] 32regs : 4026 MB/sec 4912 [ 1.807823] arm64_neon : 3725 MB/sec 4913 [ 1.807827] xor: using function: 32regs (4026 MB/sec) 4914 [ 1.807834] Key type asymmetric registered 4915 [ 1.807837] Asymmetric key parser 'x509' registered 4916 [ 1.807872] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 4917 [ 1.807953] io scheduler mq-deadline registered 4918 [ 1.807957] io scheduler kyber registered 4919 [ 1.808038] io scheduler bfq registered 4920 [ 1.810572] gpio-447 (usb-hub-reset): hogged as output/high 4921 [ 1.813578] EINJ: ACPI disabled. 4922 [ 1.819853] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 4923 [ 1.821282] VCC_3V3: supplied by VDDAO_3V3 4924 [ 1.821316] FLASH_1V8: supplied by VCC_3V3 4925 [ 1.821346] VCC_1V8: supplied by VCC_3V3 4926 [ 1.821392] VDDAO_1V8: supplied by VDDAO_3V3 4927 [ 1.821423] VDDCPU_A: supplied by regulator-dummy 4928 [ 1.821777] VDDCPU_B: supplied by regulator-dummy 4929 [ 1.822481] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 4930 [ 1.824742] Serial: AMBA driver 4931 [ 1.825028] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 4932 [ 1.825122] printk: console [ttyAML0] enabled 4933 [ 1.825631] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 4934 [ 1.830956] loop: module loaded 4935 [ 1.833015] libphy: Fixed MDIO Bus: probed 4936 [ 1.834088] tun: Universal TUN/TAP device driver, 1.6 4937 [ 1.834744] thunder_xcv, ver 1.0 4938 [ 1.834777] thunder_bgx, ver 1.0 4939 [ 1.834807] nicpf, ver 1.0 4940 [ 1.835272] e1000e: Intel(R) PRO/1000 Network Driver 4941 [ 1.835275] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 4942 [ 1.835315] igb: Intel(R) Gigabit Ethernet Network Driver 4943 [ 1.835318] igb: Copyright (c) 2007-2014 Intel Corporation. 4944 [ 1.835349] igbvf: Intel(R) Gigabit Virtual Function Network Driver 4945 [ 1.835352] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 4946 [ 1.835480] sky2: driver version 1.30 4947 [ 1.835935] VFIO - User Level meta-driver version: 0.3 4948 [ 1.837516] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 4949 [ 1.837535] ehci-pci: EHCI PCI platform driver 4950 [ 1.837564] ehci-platform: EHCI generic platform driver 4951 [ 1.837694] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 4952 [ 1.837719] ohci-pci: OHCI PCI platform driver 4953 [ 1.837751] ohci-platform: OHCI generic platform driver 4954 [ 1.838167] usbcore: registered new interface driver usb-storage 4955 [ 1.839457] mousedev: PS/2 mouse device common for all mice 4956 [ 1.839871] i2c /dev entries driver 4957 [ 1.845081] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 4958 [ 1.845948] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 4959 [ 1.846598] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 4960 [ 1.847148] sdhci: Secure Digital Host Controller Interface driver 4961 [ 1.847154] sdhci: Copyright(c) Pierre Ossman 4962 [ 1.847244] Synopsys Designware Multimedia Card Interface Driver 4963 [ 1.847604] sdhci-pltfm: SDHCI platform and OF driver helper 4964 [ 1.848030] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 4965 [ 1.849154] ledtrig-cpu: registered to indicate activity on CPUs 4966 [ 1.849405] meson-sm: secure-monitor enabled 4967 [ 1.849544] hid: raw HID events driver (C) Jiri Kosina 4968 [ 1.849609] usbcore: registered new interface driver usbhid 4969 [ 1.849611] usbhid: USB HID core driver 4970 [ 1.850453] NET: Registered protocol family 10 4971 [ 1.850781] Segment Routing with IPv6 4972 [ 1.850808] NET: Registered protocol family 17 4973 [ 1.850844] 8021q: 802.1Q VLAN Support v1.8 4974 [ 1.850867] Key type dns_resolver registered 4975 [ 1.851103] registered taskstats version 1 4976 [ 1.851107] Loading compiled-in X.509 certificates 4977 [ 1.852479] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 4978 [ 1.853905] zswap: loaded using pool zstd/z3fold 4979 [ 1.854049] Key type ._fscrypt registered 4980 [ 1.854051] Key type .fscrypt registered 4981 [ 1.854052] Key type fscrypt-provisioning registered 4982 [ 1.855073] Btrfs loaded, crc32c=crc32c-generic 4983 [ 1.860513] Key type encrypted registered 4984 [ 1.860524] AppArmor: AppArmor sha1 policy hashing enabled 4985 [ 1.865835] HUB_5V: supplied by 5V 4986 [ 1.865991] USB_PWR_EN: supplied by 5V 4987 [ 1.867468] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 4988 [ 1.867477] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 4989 [ 1.870156] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 4990 [ 1.870202] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 4991 [ 1.870296] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 4992 [ 1.870784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 4993 [ 1.870794] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 4994 [ 1.870873] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 4995 [ 1.870890] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 4996 [ 1.871000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 4997 [ 1.871003] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 4998 [ 1.871006] usb usb1: Product: xHCI Host Controller 4999 [ 1.871008] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 5000 [ 1.871009] usb usb1: SerialNumber: xhci-hcd.0.auto 5001 [ 1.871171] hub 1-0:1.0: USB hub found 5002 [ 1.871182] hub 1-0:1.0: 2 ports detected 5003 [ 1.871289] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 5004 [ 1.871296] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 5005 [ 1.871301] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 5006 [ 1.871319] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 5007 [ 1.871345] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 5008 [ 1.871348] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 5009 [ 1.871350] usb usb2: Product: xHCI Host Controller 5010 [ 1.871352] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 5011 [ 1.871354] usb usb2: SerialNumber: xhci-hcd.0.auto 5012 [ 1.871474] hub 2-0:1.0: USB hub found 5013 [ 1.871483] hub 2-0:1.0: 1 port detected 5014 [ 1.872244] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 5015 [ 1.873566] meson-gx-mmc ffe05000.sd: Got CD GPIO 5016 [ 1.900679] Freeing unused kernel memory: 3328K 5017 [ 1.943594] Run /init as init process 5018 [ 1.943597] with arguments: 5019 [ 1.943599] /init 5020 [ 1.943601] with environment: 5021 [ 1.943603] HOME=/ 5022 [ 1.943604] TERM=linux 5023 [ 1.943605] hdmimode=custombuilt 5024 [ 1.943606] cvbsmode=576cvbs 5025 [ 1.943608] max_freq_a53=1908 5026 [ 1.943609] max_freq_a73=2208 5027 [ 1.943610] voutmode=hdmi 5028 [ 1.943611] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 5029 [ 1.943613] disablehpd=false 5030 [ 1.943614] cvbscable= 5031 [ 1.943615] overscan=100 5032 [ 2.048043] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 5033 [ 2.048051] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 5034 [ 2.048146] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 5035 [ 2.049487] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 5036 [ 2.049500] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 5037 [ 2.049504] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 5038 [ 2.049507] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 5039 [ 2.049510] meson8b-dwmac ff3f0000.ethernet: COE Type 2 5040 [ 2.049511] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 5041 [ 2.049513] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 5042 [ 2.049572] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 5043 [ 2.049574] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 5044 [ 2.049577] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 5045 [ 2.049833] libphy: stmmac: probed 5046 [ 2.050927] libphy: mdio_mux: probed 5047 [ 2.065553] meson-vrtc ff8000a8.rtc: registered as rtc1 5048 [ 2.080116] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 5049 [ 2.080227] rtc-pcf8563 1-0051: registered as rtc0 5050 [ 2.081820] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 5051 [ 2.081831] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 5052 [ 2.114315] mmc0: new HS200 MMC card at address 0001 5053 [ 2.114775] mmcblk0: mmc0:0001 CJTD4R 58.2 GiB 5054 [ 2.115028] mmcblk0boot0: mmc0:0001 CJTD4R partition 1 4.00 MiB 5055 [ 2.115272] mmcblk0boot1: mmc0:0001 CJTD4R partition 2 4.00 MiB 5056 [ 2.115421] mmcblk0rpmb: mmc0:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 5057 [ 2.116688] mmcblk0: p1 5058 [ 2.131333] random: fast init done 5059 [ 2.141539] mmc1: new ultra high speed SDR104 SDXC card at address aaaa 5060 [ 2.142548] mmcblk1: mmc1:aaaa SH64G 59.5 GiB 5061 [ 2.150228] mmcblk1: p1 5062 [ 2.211555] usb 1-1: new high-speed USB device number 2 using xhci-hcd 5063 [ 2.252008] libphy: mdio_mux: probed 5064 [ 2.273213] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 5065 [ 2.369911] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 5066 [ 2.369917] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5067 [ 2.369920] usb 1-1: Product: USB2.1 Hub 5068 [ 2.369922] usb 1-1: Manufacturer: GenesysLogic 5069 [ 2.415597] hub 1-1:1.0: USB hub found 5070 [ 2.415837] hub 1-1:1.0: 4 ports detected 5071 [ 2.450614] systemd[1]: System time before build time, advancing clock. 5072 [ 2.454230] systemd[1]: Inserted module 'autofs4' 5073 [ 2.477014] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 5074 [ 2.477382] systemd[1]: Detected architecture arm64. 5075 [ 2.499651] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 5076 [ 2.522116] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 5077 [ 2.522119] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5078 [ 2.522122] usb 2-1: Product: USB3.1 Hub 5079 [ 2.522124] usb 2-1: Manufacturer: GenesysLogic 5080 [ 2.527043] systemd[1]: Set hostname to <odroidn2>. 5081 [ 2.543544] hub 2-1:1.0: USB hub found 5082 [ 2.543833] hub 2-1:1.0: 4 ports detected 5083 [ 2.771009] random: systemd: uninitialized urandom read (16 bytes read) 5084 [ 2.776536] random: systemd: uninitialized urandom read (16 bytes read) 5085 [ 2.778244] systemd[1]: Created slice User and Session Slice. 5086 [ 2.778864] random: systemd: uninitialized urandom read (16 bytes read) 5087 [ 2.779192] systemd[1]: Listening on Journal Audit Socket. 5088 [ 2.779875] systemd[1]: Listening on Journal Socket. 5089 [ 2.782136] systemd[1]: Starting Restore / save the current clock... 5090 [ 2.785268] systemd[1]: Starting Set the console keyboard layout... 5091 [ 2.786201] systemd[1]: Created slice system-getty.slice. 5092 [ 2.786546] systemd[1]: Listening on udev Kernel Socket. 5093 [ 2.799572] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 5094 [ 2.829579] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 5095 [ 2.934772] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 5096 [ 2.934777] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 5097 [ 2.934779] usb 1-1.1: Product: USB OPTICAL MOUSE 5098 [ 2.996172] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 5099 [ 2.996692] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 5100 [ 3.029015] zram: Added device: zram0 5101 [ 3.029661] zram: Added device: zram1 5102 [ 3.031042] zram: Added device: zram2 5103 [ 3.070581] pwm-gpio pwmgpio: 1 gpio pwms loaded 5104 [ 3.073652] zram0: detected capacity change from 0 to 1904500736 5105 [ 3.100991] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 5106 [ 3.111154] mc: Linux media interface: v0.10 5107 [ 3.122613] videodev: Linux video capture interface: v2.00 5108 [ 3.146469] meson-drm ff900000.vpu: Queued 2 outputs on vpu 5109 [ 3.154650] meson-drm ff900000.vpu: CVBS Output connector not available 5110 [ 3.175986] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 5111 [ 3.179821] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 5112 [ 3.181255] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 5113 [ 3.181850] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 5114 [ 3.182435] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 5115 [ 3.187095] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 5116 [ 3.187341] panfrost ffe40000.gpu: clock rate = 24000000 5117 [ 3.187410] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 5118 [ 3.188341] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 5119 [ 3.188351] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 5120 [ 3.188355] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 5121 [ 3.188359] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 5122 [ 3.204034] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 5123 [ 3.215578] Registered IR keymap rc-odroid 5124 [ 3.221354] IR NEC protocol handler initialized 5125 [ 3.237010] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 5126 [ 3.237017] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5127 [ 3.237020] usb 1-1.3: Product: USB Keyboard 5128 [ 3.237021] usb 1-1.3: Manufacturer: Logitech 5129 [ 3.247643] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 5130 [ 3.247751] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 5131 [ 3.247821] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input1 5132 [ 3.248234] meson-ir ff808000.ir: receiver initialized 5133 [ 3.316335] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input2 5134 [ 3.379841] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 5135 [ 3.385654] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 5136 [ 3.443626] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input4 5137 [ 3.443715] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 5138 [ 3.492408] Console: switching to colour frame buffer device 240x67 5139 [ 3.514284] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 5140 [ 3.571440] axg-sound-card sound: ASoC: no DMI vendor name! 5141 [ 4.103558] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 5142 [ 4.144311] zram1: detected capacity change from 0 to 52428800 5143 [ 6.187780] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 5144 [ 6.187798] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 5145 [ 7.162749] systemd-journald[1854]: Received request to flush runtime journal from PID 1 5146 5147 ### armbian-release: 5148 5149 # PLEASE DO NOT EDIT THIS FILE 5150 BOARD=odroidn2 5151 BOARD_NAME="Odroid N2" 5152 BOARDFAMILY=meson-g12b 5153 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 5154 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 5155 DISTRIBUTION_CODENAME=buster 5156 DISTRIBUTION_STATUS=supported 5157 VERSION=21.02.3 5158 LINUXFAMILY=meson64 5159 BRANCH=current 5160 ARCH=arm64 5161 IMAGE_TYPE=stable 5162 BOARD_TYPE=conf 5163 INITRD_ARCH=arm64 5164 KERNEL_IMAGE_TYPE=Image 5165 5166 ### boot environment: 5167 5168 verbosity=1 5169 console=both 5170 overlay_prefix=meson 5171 bootlogo=true 5172 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 5173 rootfstype=ext4 5174 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 5175 5176 ### lsusb: 5177 5178 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 5179 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 5180 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 5181 Bus 001 Device 003: ID 275d:0ba6 5182 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 5183 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 5184 5185 ### lscpu: 5186 5187 Architecture: aarch64 5188 Byte Order: Little Endian 5189 CPU(s): 6 5190 On-line CPU(s) list: 0-5 5191 Thread(s) per core: 1 5192 Core(s) per socket: 3 5193 Socket(s): 2 5194 NUMA node(s): 1 5195 Vendor ID: ARM 5196 Model: 4 5197 Model name: Cortex-A53 5198 Stepping: r0p4 5199 CPU max MHz: 2400.0000 5200 CPU min MHz: 100.0000 5201 BogoMIPS: 48.00 5202 L1d cache: unknown size 5203 L1i cache: unknown size 5204 L2 cache: unknown size 5205 NUMA node0 CPU(s): 0-5 5206 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5207 5208 ### cpuinfo: 5209 5210 processor : 0 5211 BogoMIPS : 48.00 5212 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5213 CPU implementer : 0x41 5214 CPU architecture: 8 5215 CPU variant : 0x0 5216 CPU part : 0xd03 5217 CPU revision : 4 5218 5219 processor : 1 5220 BogoMIPS : 48.00 5221 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5222 CPU implementer : 0x41 5223 CPU architecture: 8 5224 CPU variant : 0x0 5225 CPU part : 0xd03 5226 CPU revision : 4 5227 5228 processor : 2 5229 BogoMIPS : 48.00 5230 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5231 CPU implementer : 0x41 5232 CPU architecture: 8 5233 CPU variant : 0x0 5234 CPU part : 0xd09 5235 CPU revision : 2 5236 5237 processor : 3 5238 BogoMIPS : 48.00 5239 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5240 CPU implementer : 0x41 5241 CPU architecture: 8 5242 CPU variant : 0x0 5243 CPU part : 0xd09 5244 CPU revision : 2 5245 5246 processor : 4 5247 BogoMIPS : 48.00 5248 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5249 CPU implementer : 0x41 5250 CPU architecture: 8 5251 CPU variant : 0x0 5252 CPU part : 0xd09 5253 CPU revision : 2 5254 5255 processor : 5 5256 BogoMIPS : 48.00 5257 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5258 CPU implementer : 0x41 5259 CPU architecture: 8 5260 CPU variant : 0x0 5261 CPU part : 0xd09 5262 CPU revision : 2 5263 5264 5265 ### meminfo: 5266 5267 MemTotal: 3719724 kB 5268 MemFree: 3408404 kB 5269 MemAvailable: 3372812 kB 5270 Buffers: 13060 kB 5271 Cached: 63452 kB 5272 SwapCached: 0 kB 5273 Active: 33316 kB 5274 Inactive: 161744 kB 5275 Active(anon): 132 kB 5276 Inactive(anon): 123500 kB 5277 Active(file): 33184 kB 5278 Inactive(file): 38244 kB 5279 Unevictable: 0 kB 5280 Mlocked: 0 kB 5281 SwapTotal: 1859860 kB 5282 SwapFree: 1859860 kB 5283 Dirty: 16744 kB 5284 Writeback: 0 kB 5285 AnonPages: 118772 kB 5286 Mapped: 16004 kB 5287 Shmem: 4940 kB 5288 KReclaimable: 14104 kB 5289 Slab: 46440 kB 5290 SReclaimable: 14104 kB 5291 SUnreclaim: 32336 kB 5292 KernelStack: 2672 kB 5293 PageTables: 4992 kB 5294 NFS_Unstable: 0 kB 5295 Bounce: 0 kB 5296 WritebackTmp: 0 kB 5297 CommitLimit: 3719720 kB 5298 Committed_AS: 4249976 kB 5299 VmallocTotal: 135290159040 kB 5300 VmallocUsed: 31556 kB 5301 VmallocChunk: 0 kB 5302 Percpu: 1392 kB 5303 HardwareCorrupted: 0 kB 5304 AnonHugePages: 0 kB 5305 ShmemHugePages: 0 kB 5306 ShmemPmdMapped: 0 kB 5307 FileHugePages: 0 kB 5308 FilePmdMapped: 0 kB 5309 CmaTotal: 917504 kB 5310 CmaFree: 901724 kB 5311 HugePages_Total: 0 5312 HugePages_Free: 0 5313 HugePages_Rsvd: 0 5314 HugePages_Surp: 0 5315 Hugepagesize: 2048 kB 5316 Hugetlb: 0 kB 5317 5318 ### virtual memory: 5319 5320 vm.admin_reserve_kbytes = 8192 5321 vm.block_dump = 0 5322 vm.compaction_proactiveness = 20 5323 vm.compact_unevictable_allowed = 1 5324 vm.dirty_background_bytes = 0 5325 vm.dirty_background_ratio = 10 5326 vm.dirty_bytes = 0 5327 vm.dirty_expire_centisecs = 3000 5328 vm.dirty_ratio = 20 5329 vm.dirtytime_expire_seconds = 43200 5330 vm.dirty_writeback_centisecs = 500 5331 vm.extfrag_threshold = 500 5332 vm.hugetlb_shm_group = 0 5333 vm.laptop_mode = 0 5334 vm.legacy_va_layout = 0 5335 vm.lowmem_reserve_ratio = 256 256 32 0 5336 vm.max_map_count = 65530 5337 vm.memory_failure_early_kill = 0 5338 vm.memory_failure_recovery = 1 5339 vm.min_free_kbytes = 45056 5340 vm.min_slab_ratio = 5 5341 vm.min_unmapped_ratio = 1 5342 vm.mmap_min_addr = 4096 5343 vm.mmap_rnd_bits = 18 5344 vm.mmap_rnd_compat_bits = 11 5345 vm.nr_hugepages = 0 5346 vm.nr_hugepages_mempolicy = 0 5347 vm.nr_overcommit_hugepages = 0 5348 vm.numa_stat = 1 5349 vm.numa_zonelist_order = Node 5350 vm.oom_dump_tasks = 1 5351 vm.oom_kill_allocating_task = 0 5352 vm.overcommit_kbytes = 0 5353 vm.overcommit_memory = 0 5354 vm.overcommit_ratio = 50 5355 vm.page-cluster = 0 5356 vm.page_lock_unfairness = 5 5357 vm.panic_on_oom = 0 5358 vm.percpu_pagelist_fraction = 0 5359 vm.stat_interval = 1 5360 vm.swappiness = 100 5361 vm.user_reserve_kbytes = 114921 5362 vm.vfs_cache_pressure = 100 5363 vm.watermark_boost_factor = 15000 5364 vm.watermark_scale_factor = 10 5365 vm.zone_reclaim_mode = 0 5366 5367 ### ip addr: 5368 5369 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 5370 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 5371 inet XXX.XXX.0.1/8 scope host lo 5372 valid_lft forever preferred_lft forever 5373 inet6 ::1/128 scope host 5374 valid_lft forever preferred_lft forever 5375 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 5376 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 5377 5378 ### partitions: 5379 5380 major minor #blocks name 5381 5382 179 0 61071360 mmcblk0 5383 179 1 60456544 mmcblk0p1 5384 179 96 62367744 mmcblk1 5385 179 97 62366720 mmcblk1p1 5386 252 0 1859864 zram0 5387 252 1 51200 zram1 5388 5389 ### df: 5390 5391 udev 1.4G 0 1.4G 0% /dev 5392 tmpfs 364M 5.0M 359M 2% /run 5393 /dev/mmcblk0p1 57G 21G 36G 37% / 5394 tmpfs 1.8G 0 1.8G 0% /dev/shm 5395 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 5396 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 5397 tmpfs 1.8G 0 1.8G 0% /tmp 5398 /dev/zram1 49M 17M 29M 37% /var/log 5399 5400 ### lsblk: 5401 5402 NAME FSTYPE SIZE MOUNTPOINT UUID 5403 mmcblk0 58.2G 5404 └─mmcblk0p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 5405 mmcblk0boot0 4M 5406 mmcblk0boot1 4M 5407 mmcblk1 59.5G 5408 └─mmcblk1p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 5409 zram1 50M /var/log 5410 5411 ### zramctl: 5412 5413 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 5414 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 5415 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 5416 5417 ### mtab: 5418 5419 /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 5420 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 5421 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 5422 5423 ### mmc1:aaaa info: 5424 5425 fwrev: 0x0 5426 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 5427 cid: 035344534836344780559b2001014a00 5428 rca: 0xaaaa 5429 csd: 400e0032db790001dbd37f800a404000 5430 manfid: 0x000003 5431 ocr: 0x00200000 5432 preferred_erase_size: 4194304 5433 type: SD 5434 hwrev: 0x8 5435 date: 10/2020 5436 dsr: 0x404 5437 erase_size: 512 5438 oemid: 0x5344 5439 serial: 0x559b2001 5440 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 5441 scr: 0245848300000000 5442 name: SH64G 5443 5444 ### mmc0:0001 info: 5445 5446 fwrev: 0x0400000000000000 5447 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 5448 cid: 150100434a54443452042559facb7700 5449 rel_sectors: 0x1 5450 enhanced_rpmb_supported: 0x1 5451 rca: 0x0001 5452 pre_eol_info: 0x01 5453 csd: d02701320f5903fff6dbffef8e404000 5454 manfid: 0x000015 5455 ocr: 0x00200000 5456 preferred_erase_size: 4194304 5457 enhanced_area_offset: 18446744073709551594 5458 raw_rpmb_size_mult: 0x20 5459 type: MMC 5460 hwrev: 0x0 5461 date: 07/2020 5462 prv: 0x4 5463 ffu_capable: 1 5464 dsr: 0x404 5465 erase_size: 524288 5466 life_time: 0x01 0x01 5467 enhanced_area_size: 4294967274 5468 oemid: 0x0100 5469 serial: 0x2559facb 5470 cmdq_en: 0 5471 rev: 0x8 5472 name: CJTD4R 5473 5474 ### Boot system health: 5475 5476 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 5477 06:28:07: 2400/2016MHz 0.00 23% 15% 6% 0% 1% 0% 24.5°C 0/12 5478 06:28:07: 2400/2016MHz 0.00 27% 17% 9% 0% 0% 0% 22.8°C 0/12 5479 06:28:08: 2400/2016MHz 0.00 18% 8% 9% 0% 0% 0% 21.5°C 0/12 5480 06:28:08: 2400/2016MHz 0.00 44% 28% 11% 0% 2% 1% 22.7°C 0/12 5481 06:28:09: 2400/2016MHz 0.00 89% 38% 31% 0% 15% 2% 24.7°C 0/12 5482 5483 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 5484 5485 ### Activated Armbian ramlog partition with zstd compression 5486 5487 Sun 04 Apr 2021 09:26:34 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 5488 5489 ### dmesg: 5490 5491 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 5492 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 5493 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 5494 [ 0.000000] efi: UEFI not found. 5495 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 5496 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 5497 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 5498 [ 0.000000] NUMA: No NUMA configuration found 5499 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 5500 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 5501 [ 0.000000] Zone ranges: 5502 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 5503 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 5504 [ 0.000000] Normal empty 5505 [ 0.000000] Movable zone start for each node 5506 [ 0.000000] Early memory node ranges 5507 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 5508 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 5509 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 5510 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 5511 [ 0.000000] On node 0 totalpages: 972800 5512 [ 0.000000] DMA zone: 4096 pages used for memmap 5513 [ 0.000000] DMA zone: 0 pages reserved 5514 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 5515 [ 0.000000] DMA32 zone: 11104 pages used for memmap 5516 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 5517 [ 0.000000] psci: probing for conduit method from DT. 5518 [ 0.000000] psci: PSCIv1.0 detected in firmware. 5519 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 5520 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 5521 [ 0.000000] psci: SMC Calling Convention v1.1 5522 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 5523 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 5524 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 5525 [ 0.000000] Detected VIPT I-cache on CPU0 5526 [ 0.000000] CPU features: detected: ARM erratum 845719 5527 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 5528 [ 0.000000] Policy zone: DMA32 5529 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 5530 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 5531 Please use sysfs to set IO scheduler for individual devices. 5532 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 5533 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 5534 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 5535 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 5536 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 5537 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 5538 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 5539 [ 0.000000] rcu: RCU event tracing is enabled. 5540 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 5541 [ 0.000000] Trampoline variant of Tasks RCU enabled. 5542 [ 0.000000] Rude variant of Tasks RCU enabled. 5543 [ 0.000000] Tracing variant of Tasks RCU enabled. 5544 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 5545 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 5546 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 5547 [ 0.000000] GIC: Using split EOI/Deactivate mode 5548 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 5549 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 5550 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 5551 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 5552 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 5553 [ 0.000256] Console: colour dummy device 80x25 5554 [ 0.000291] printk: console [tty1] enabled 5555 [ 0.000378] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 5556 [ 0.000391] pid_max: default: 32768 minimum: 301 5557 [ 0.000474] LSM: Security Framework initializing 5558 [ 0.000499] Yama: becoming mindful. 5559 [ 0.000591] AppArmor: AppArmor initialized 5560 [ 0.000641] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 5561 [ 0.000660] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 5562 [ 0.002662] rcu: Hierarchical SRCU implementation. 5563 [ 0.005142] EFI services will not be available. 5564 [ 0.005567] smp: Bringing up secondary CPUs ... 5565 [ 0.006242] Detected VIPT I-cache on CPU1 5566 [ 0.006303] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 5567 [ 0.007499] CPU features: detected: ARM erratum 858921 5568 [ 0.007507] CPU features: detected: Spectre-v2 5569 [ 0.007511] CPU features: detected: Spectre-v4 5570 [ 0.007517] Detected VIPT I-cache on CPU2 5571 [ 0.007541] arch_timer: Enabling local workaround for ARM erratum 858921 5572 [ 0.007556] arch_timer: CPU2: Trapping CNTVCT access 5573 [ 0.007570] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 5574 [ 0.008281] Detected VIPT I-cache on CPU3 5575 [ 0.008297] arch_timer: Enabling local workaround for ARM erratum 858921 5576 [ 0.008305] arch_timer: CPU3: Trapping CNTVCT access 5577 [ 0.008312] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 5578 [ 0.008937] Detected VIPT I-cache on CPU4 5579 [ 0.008954] arch_timer: Enabling local workaround for ARM erratum 858921 5580 [ 0.008961] arch_timer: CPU4: Trapping CNTVCT access 5581 [ 0.008969] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 5582 [ 0.009587] Detected VIPT I-cache on CPU5 5583 [ 0.009604] arch_timer: Enabling local workaround for ARM erratum 858921 5584 [ 0.009610] arch_timer: CPU5: Trapping CNTVCT access 5585 [ 0.009618] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 5586 [ 0.009699] smp: Brought up 1 node, 6 CPUs 5587 [ 0.009716] SMP: Total of 6 processors activated. 5588 [ 0.009724] CPU features: detected: 32-bit EL0 Support 5589 [ 0.009730] CPU features: detected: CRC32 instructions 5590 [ 0.009736] CPU features: detected: 32-bit EL1 Support 5591 [ 0.021010] CPU: All CPU(s) started at EL2 5592 [ 0.021059] alternatives: patching kernel code 5593 [ 0.023059] devtmpfs: initialized 5594 [ 0.030750] Registered cp15_barrier emulation handler 5595 [ 0.030764] Registered setend emulation handler 5596 [ 0.030902] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 5597 [ 0.030943] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 5598 [ 0.046220] pinctrl core: initialized pinctrl subsystem 5599 [ 0.046957] DMI not present or invalid. 5600 [ 0.047328] NET: Registered protocol family 16 5601 [ 0.048887] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 5602 [ 0.049161] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 5603 [ 0.049392] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 5604 [ 0.049436] audit: initializing netlink subsys (disabled) 5605 [ 0.049556] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 5606 [ 0.050794] thermal_sys: Registered thermal governor 'fair_share' 5607 [ 0.050801] thermal_sys: Registered thermal governor 'bang_bang' 5608 [ 0.050805] thermal_sys: Registered thermal governor 'step_wise' 5609 [ 0.050809] thermal_sys: Registered thermal governor 'user_space' 5610 [ 0.051244] cpuidle: using governor menu 5611 [ 0.051586] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 5612 [ 0.051715] ASID allocator initialised with 65536 entries 5613 [ 0.052776] Serial: AMBA PL011 UART driver 5614 [ 0.086857] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 5615 [ 0.086868] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 5616 [ 0.086873] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 5617 [ 0.086878] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 5618 [ 0.088652] cryptd: max_cpu_qlen set to 1000 5619 [ 0.156227] raid6: neonx8 gen() 2779 MB/s 5620 [ 0.224291] raid6: neonx8 xor() 2041 MB/s 5621 [ 0.292365] raid6: neonx4 gen() 3154 MB/s 5622 [ 0.360451] raid6: neonx4 xor() 1585 MB/s 5623 [ 0.428502] raid6: neonx2 gen() 2528 MB/s 5624 [ 0.496567] raid6: neonx2 xor() 2205 MB/s 5625 [ 0.564644] raid6: neonx1 gen() 1938 MB/s 5626 [ 0.632711] raid6: neonx1 xor() 1729 MB/s 5627 [ 0.700771] raid6: int64x8 gen() 1376 MB/s 5628 [ 0.768836] raid6: int64x8 xor() 735 MB/s 5629 [ 0.836925] raid6: int64x4 gen() 1463 MB/s 5630 [ 0.904972] raid6: int64x4 xor() 733 MB/s 5631 [ 0.973031] raid6: int64x2 gen() 1363 MB/s 5632 [ 1.041106] raid6: int64x2 xor() 619 MB/s 5633 [ 1.109170] raid6: int64x1 gen() 1127 MB/s 5634 [ 1.177234] raid6: int64x1 xor() 462 MB/s 5635 [ 1.177238] raid6: using algorithm neonx4 gen() 3154 MB/s 5636 [ 1.177241] raid6: .... xor() 1585 MB/s, rmw enabled 5637 [ 1.177244] raid6: using neon recovery algorithm 5638 [ 1.177702] ACPI: Interpreter disabled. 5639 [ 1.178542] 5V: supplied by 12V 5640 [ 1.179461] VDDAO_3V3: supplied by 12V 5641 [ 1.179912] iommu: Default domain type: Translated 5642 [ 1.180036] vgaarb: loaded 5643 [ 1.180883] SCSI subsystem initialized 5644 [ 1.181084] usbcore: registered new interface driver usbfs 5645 [ 1.181126] usbcore: registered new interface driver hub 5646 [ 1.181175] usbcore: registered new device driver usb 5647 [ 1.181455] pps_core: LinuxPPS API ver. 1 registered 5648 [ 1.181459] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 5649 [ 1.181482] PTP clock support registered 5650 [ 1.181693] EDAC MC: Ver: 3.0.0 5651 [ 1.183082] NetLabel: Initializing 5652 [ 1.183090] NetLabel: domain hash size = 128 5653 [ 1.183092] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 5654 [ 1.183134] NetLabel: unlabeled traffic allowed by default 5655 [ 1.183607] clocksource: Switched to clocksource arch_sys_counter 5656 [ 1.183816] VFS: Disk quotas dquot_6.6.0 5657 [ 1.183859] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 5658 [ 1.184228] AppArmor: AppArmor Filesystem Enabled 5659 [ 1.184332] pnp: PnP ACPI: disabled 5660 [ 1.190019] NET: Registered protocol family 2 5661 [ 1.190480] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 5662 [ 1.190585] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 5663 [ 1.190842] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 5664 [ 1.191030] TCP: Hash tables configured (established 32768 bind 32768) 5665 [ 1.191180] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 5666 [ 1.191245] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 5667 [ 1.191291] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 5668 [ 1.191435] NET: Registered protocol family 1 5669 [ 1.191459] PCI: CLS 0 bytes, default 64 5670 [ 1.191582] Trying to unpack rootfs image as initramfs... 5671 [ 1.760011] Freeing initrd memory: 14920K 5672 [ 1.760944] kvm [1]: IPA Size Limit: 40 bits 5673 [ 1.761653] kvm [1]: vgic interrupt IRQ9 5674 [ 1.761789] kvm [1]: Hyp mode initialized successfully 5675 [ 1.766945] Initialise system trusted keyrings 5676 [ 1.766976] Key type blacklist registered 5677 [ 1.767072] workingset: timestamp_bits=44 max_order=20 bucket_order=0 5678 [ 1.770257] zbud: loaded 5679 [ 1.771236] squashfs: version 4.0 (2009/01/31) Phillip Lougher 5680 [ 1.771726] fuse: init (API version 7.32) 5681 [ 1.772485] integrity: Platform Keyring initialized 5682 [ 1.800127] xor: measuring software checksum speed 5683 [ 1.802963] 8regs : 3476 MB/sec 5684 [ 1.805421] 32regs : 4023 MB/sec 5685 [ 1.808073] arm64_neon : 3720 MB/sec 5686 [ 1.808076] xor: using function: 32regs (4023 MB/sec) 5687 [ 1.808083] Key type asymmetric registered 5688 [ 1.808087] Asymmetric key parser 'x509' registered 5689 [ 1.808120] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 5690 [ 1.808201] io scheduler mq-deadline registered 5691 [ 1.808205] io scheduler kyber registered 5692 [ 1.808285] io scheduler bfq registered 5693 [ 1.810838] gpio-447 (usb-hub-reset): hogged as output/high 5694 [ 1.813865] EINJ: ACPI disabled. 5695 [ 1.820174] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 5696 [ 1.821593] VCC_3V3: supplied by VDDAO_3V3 5697 [ 1.821632] FLASH_1V8: supplied by VCC_3V3 5698 [ 1.821667] VCC_1V8: supplied by VCC_3V3 5699 [ 1.821693] VDDAO_1V8: supplied by VDDAO_3V3 5700 [ 1.821732] VDDCPU_A: supplied by regulator-dummy 5701 [ 1.822096] VDDCPU_B: supplied by regulator-dummy 5702 [ 1.822779] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 5703 [ 1.824980] Serial: AMBA driver 5704 [ 1.825265] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 5705 [ 1.825358] printk: console [ttyAML0] enabled 5706 [ 1.825866] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 5707 [ 1.831368] loop: module loaded 5708 [ 1.833402] libphy: Fixed MDIO Bus: probed 5709 [ 1.834519] tun: Universal TUN/TAP device driver, 1.6 5710 [ 1.835179] thunder_xcv, ver 1.0 5711 [ 1.835210] thunder_bgx, ver 1.0 5712 [ 1.835250] nicpf, ver 1.0 5713 [ 1.835804] e1000e: Intel(R) PRO/1000 Network Driver 5714 [ 1.835808] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 5715 [ 1.835860] igb: Intel(R) Gigabit Ethernet Network Driver 5716 [ 1.835863] igb: Copyright (c) 2007-2014 Intel Corporation. 5717 [ 1.835894] igbvf: Intel(R) Gigabit Virtual Function Network Driver 5718 [ 1.835897] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 5719 [ 1.836027] sky2: driver version 1.30 5720 [ 1.836391] VFIO - User Level meta-driver version: 0.3 5721 [ 1.837788] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 5722 [ 1.837805] ehci-pci: EHCI PCI platform driver 5723 [ 1.837835] ehci-platform: EHCI generic platform driver 5724 [ 1.837964] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 5725 [ 1.837973] ohci-pci: OHCI PCI platform driver 5726 [ 1.838002] ohci-platform: OHCI generic platform driver 5727 [ 1.838417] usbcore: registered new interface driver usb-storage 5728 [ 1.839897] mousedev: PS/2 mouse device common for all mice 5729 [ 1.840409] i2c /dev entries driver 5730 [ 1.845506] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 5731 [ 1.846369] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 5732 [ 1.847016] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 5733 [ 1.847537] sdhci: Secure Digital Host Controller Interface driver 5734 [ 1.847540] sdhci: Copyright(c) Pierre Ossman 5735 [ 1.847652] Synopsys Designware Multimedia Card Interface Driver 5736 [ 1.848016] sdhci-pltfm: SDHCI platform and OF driver helper 5737 [ 1.848422] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 5738 [ 1.849424] ledtrig-cpu: registered to indicate activity on CPUs 5739 [ 1.849673] meson-sm: secure-monitor enabled 5740 [ 1.849811] hid: raw HID events driver (C) Jiri Kosina 5741 [ 1.849877] usbcore: registered new interface driver usbhid 5742 [ 1.849878] usbhid: USB HID core driver 5743 [ 1.850710] NET: Registered protocol family 10 5744 [ 1.851043] Segment Routing with IPv6 5745 [ 1.851071] NET: Registered protocol family 17 5746 [ 1.851105] 8021q: 802.1Q VLAN Support v1.8 5747 [ 1.851126] Key type dns_resolver registered 5748 [ 1.851362] registered taskstats version 1 5749 [ 1.851366] Loading compiled-in X.509 certificates 5750 [ 1.852779] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 5751 [ 1.854192] zswap: loaded using pool zstd/z3fold 5752 [ 1.854344] Key type ._fscrypt registered 5753 [ 1.854346] Key type .fscrypt registered 5754 [ 1.854348] Key type fscrypt-provisioning registered 5755 [ 1.855371] Btrfs loaded, crc32c=crc32c-generic 5756 [ 1.860652] Key type encrypted registered 5757 [ 1.860662] AppArmor: AppArmor sha1 policy hashing enabled 5758 [ 1.865927] HUB_5V: supplied by 5V 5759 [ 1.866086] USB_PWR_EN: supplied by 5V 5760 [ 1.867557] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 5761 [ 1.867564] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 5762 [ 1.870281] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 5763 [ 1.870330] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 5764 [ 1.870413] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 5765 [ 1.870907] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 5766 [ 1.870917] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 5767 [ 1.870998] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 5768 [ 1.871019] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 5769 [ 1.871130] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 5770 [ 1.871133] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 5771 [ 1.871135] usb usb1: Product: xHCI Host Controller 5772 [ 1.871137] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 5773 [ 1.871139] usb usb1: SerialNumber: xhci-hcd.0.auto 5774 [ 1.871303] hub 1-0:1.0: USB hub found 5775 [ 1.871314] hub 1-0:1.0: 2 ports detected 5776 [ 1.871425] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 5777 [ 1.871431] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 5778 [ 1.871436] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 5779 [ 1.871452] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 5780 [ 1.871481] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 5781 [ 1.871484] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 5782 [ 1.871486] usb usb2: Product: xHCI Host Controller 5783 [ 1.871488] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 5784 [ 1.871489] usb usb2: SerialNumber: xhci-hcd.0.auto 5785 [ 1.871633] hub 2-0:1.0: USB hub found 5786 [ 1.871642] hub 2-0:1.0: 1 port detected 5787 [ 1.872000] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 5788 [ 1.872768] meson-gx-mmc ffe05000.sd: Got CD GPIO 5789 [ 1.900335] Freeing unused kernel memory: 3328K 5790 [ 1.923728] Run /init as init process 5791 [ 1.923732] with arguments: 5792 [ 1.923734] /init 5793 [ 1.923735] with environment: 5794 [ 1.923737] HOME=/ 5795 [ 1.923738] TERM=linux 5796 [ 1.923740] hdmimode=custombuilt 5797 [ 1.923741] cvbsmode=576cvbs 5798 [ 1.923742] max_freq_a53=1908 5799 [ 1.923743] max_freq_a73=2208 5800 [ 1.923744] voutmode=hdmi 5801 [ 1.923746] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 5802 [ 1.923747] disablehpd=false 5803 [ 1.923748] cvbscable= 5804 [ 1.923749] overscan=100 5805 [ 2.042112] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 5806 [ 2.042119] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 5807 [ 2.042193] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 5808 [ 2.042537] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 5809 [ 2.042542] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 5810 [ 2.042545] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 5811 [ 2.042547] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 5812 [ 2.042549] meson8b-dwmac ff3f0000.ethernet: COE Type 2 5813 [ 2.042551] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 5814 [ 2.042552] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 5815 [ 2.042591] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 5816 [ 2.042594] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 5817 [ 2.042595] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 5818 [ 2.042792] libphy: stmmac: probed 5819 [ 2.043705] libphy: mdio_mux: probed 5820 [ 2.056499] meson-vrtc ff8000a8.rtc: registered as rtc1 5821 [ 2.066019] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 5822 [ 2.066223] rtc-pcf8563 1-0051: registered as rtc0 5823 [ 2.067406] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 5824 [ 2.067413] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 5825 [ 2.137415] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 5826 [ 2.137877] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 5827 [ 2.141183] mmcblk0: p1 5828 [ 2.166342] mmc1: new HS200 MMC card at address 0001 5829 [ 2.166813] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 5830 [ 2.167064] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 5831 [ 2.167336] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 5832 [ 2.167486] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 5833 [ 2.168639] mmcblk1: p1 5834 [ 2.173942] random: fast init done 5835 [ 2.215742] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 5836 [ 2.240327] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 5837 [ 2.240332] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5838 [ 2.240335] usb 2-1: Product: USB3.1 Hub 5839 [ 2.240337] usb 2-1: Manufacturer: GenesysLogic 5840 [ 2.252018] libphy: mdio_mux: probed 5841 [ 2.271693] hub 2-1:1.0: USB hub found 5842 [ 2.271982] hub 2-1:1.0: 4 ports detected 5843 [ 2.363608] usb 1-1: new high-speed USB device number 2 using xhci-hcd 5844 [ 2.513874] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 5845 [ 2.513877] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5846 [ 2.513879] usb 1-1: Product: USB2.1 Hub 5847 [ 2.513881] usb 1-1: Manufacturer: GenesysLogic 5848 [ 2.575658] hub 1-1:1.0: USB hub found 5849 [ 2.575891] hub 1-1:1.0: 4 ports detected 5850 [ 2.951604] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 5851 [ 3.078631] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 5852 [ 3.078634] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 5853 [ 3.078636] usb 1-1.1: Product: USB OPTICAL MOUSE 5854 [ 3.121617] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 5855 [ 3.121894] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 5856 [ 3.181452] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 5857 [ 3.227657] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 5858 [ 3.354008] systemd[1]: System time before build time, advancing clock. 5859 [ 3.356743] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 5860 [ 3.356747] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 5861 [ 3.356750] usb 1-1.3: Product: USB Keyboard 5862 [ 3.356752] usb 1-1.3: Manufacturer: Logitech 5863 [ 3.357825] systemd[1]: Inserted module 'autofs4' 5864 [ 3.380055] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 5865 [ 3.380427] systemd[1]: Detected architecture arm64. 5866 [ 3.398396] systemd[1]: Set hostname to <odroidn2>. 5867 [ 3.444540] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 5868 [ 3.503861] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 5869 [ 3.509649] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 5870 [ 3.567669] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 5871 [ 3.567730] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 5872 [ 3.643277] random: systemd: uninitialized urandom read (16 bytes read) 5873 [ 3.649114] random: systemd: uninitialized urandom read (16 bytes read) 5874 [ 3.649611] systemd[1]: Listening on Journal Audit Socket. 5875 [ 3.650001] random: systemd: uninitialized urandom read (16 bytes read) 5876 [ 3.650396] systemd[1]: Listening on Journal Socket (/dev/log). 5877 [ 3.650653] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 5878 [ 3.650723] systemd[1]: Reached target System Time Synchronized. 5879 [ 3.650913] systemd[1]: Reached target Swap. 5880 [ 3.651282] systemd[1]: Listening on initctl Compatibility Named Pipe. 5881 [ 3.651912] systemd[1]: Listening on Syslog Socket. 5882 [ 3.707916] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 5883 [ 3.892017] zram: Added device: zram0 5884 [ 3.892298] zram: Added device: zram1 5885 [ 3.892506] zram: Added device: zram2 5886 [ 3.945570] zram0: detected capacity change from 0 to 1904500736 5887 [ 3.947536] pwm-gpio pwmgpio: 1 gpio pwms loaded 5888 [ 3.988844] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 5889 [ 4.009446] mc: Linux media interface: v0.10 5890 [ 4.021256] videodev: Linux video capture interface: v2.00 5891 [ 4.025132] meson-drm ff900000.vpu: Queued 2 outputs on vpu 5892 [ 4.039640] Registered IR keymap rc-odroid 5893 [ 4.049177] IR NEC protocol handler initialized 5894 [ 4.061613] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 5895 [ 4.073537] meson-drm ff900000.vpu: CVBS Output connector not available 5896 [ 4.079866] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 5897 [ 4.079967] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 5898 [ 4.080023] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 5899 [ 4.083096] meson-ir ff808000.ir: receiver initialized 5900 [ 4.099730] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 5901 [ 4.101991] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 5902 [ 4.102263] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 5903 [ 4.102498] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 5904 [ 4.107296] panfrost ffe40000.gpu: clock rate = 24000000 5905 [ 4.107354] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 5906 [ 4.109230] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 5907 [ 4.109237] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 5908 [ 4.109240] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 5909 [ 4.109243] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 5910 [ 4.136857] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 5911 [ 4.408430] Console: switching to colour frame buffer device 240x67 5912 [ 4.430294] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 5913 [ 4.458098] axg-sound-card sound: ASoC: no DMI vendor name! 5914 [ 4.979626] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 5915 [ 5.021767] zram1: detected capacity change from 0 to 52428800 5916 [ 7.066442] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 5917 [ 7.066461] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 5918 [ 8.072699] systemd-journald[1848]: Received request to flush runtime journal from PID 1 5919 5920 ### armbian-release: 5921 5922 # PLEASE DO NOT EDIT THIS FILE 5923 BOARD=odroidn2 5924 BOARD_NAME="Odroid N2" 5925 BOARDFAMILY=meson-g12b 5926 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 5927 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 5928 DISTRIBUTION_CODENAME=buster 5929 DISTRIBUTION_STATUS=supported 5930 VERSION=21.02.3 5931 LINUXFAMILY=meson64 5932 BRANCH=current 5933 ARCH=arm64 5934 IMAGE_TYPE=stable 5935 BOARD_TYPE=conf 5936 INITRD_ARCH=arm64 5937 KERNEL_IMAGE_TYPE=Image 5938 5939 ### boot environment: 5940 5941 verbosity=1 5942 console=both 5943 overlay_prefix=meson 5944 bootlogo=true 5945 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 5946 rootfstype=ext4 5947 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 5948 5949 ### lsusb: 5950 5951 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 5952 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 5953 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 5954 Bus 001 Device 003: ID 275d:0ba6 5955 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 5956 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 5957 5958 ### lscpu: 5959 5960 Architecture: aarch64 5961 Byte Order: Little Endian 5962 CPU(s): 6 5963 On-line CPU(s) list: 0-5 5964 Thread(s) per core: 1 5965 Core(s) per socket: 3 5966 Socket(s): 2 5967 NUMA node(s): 1 5968 Vendor ID: ARM 5969 Model: 4 5970 Model name: Cortex-A53 5971 Stepping: r0p4 5972 CPU max MHz: 2400.0000 5973 CPU min MHz: 100.0000 5974 BogoMIPS: 48.00 5975 L1d cache: unknown size 5976 L1i cache: unknown size 5977 L2 cache: unknown size 5978 NUMA node0 CPU(s): 0-5 5979 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5980 5981 ### cpuinfo: 5982 5983 processor : 0 5984 BogoMIPS : 48.00 5985 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5986 CPU implementer : 0x41 5987 CPU architecture: 8 5988 CPU variant : 0x0 5989 CPU part : 0xd03 5990 CPU revision : 4 5991 5992 processor : 1 5993 BogoMIPS : 48.00 5994 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 5995 CPU implementer : 0x41 5996 CPU architecture: 8 5997 CPU variant : 0x0 5998 CPU part : 0xd03 5999 CPU revision : 4 6000 6001 processor : 2 6002 BogoMIPS : 48.00 6003 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6004 CPU implementer : 0x41 6005 CPU architecture: 8 6006 CPU variant : 0x0 6007 CPU part : 0xd09 6008 CPU revision : 2 6009 6010 processor : 3 6011 BogoMIPS : 48.00 6012 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6013 CPU implementer : 0x41 6014 CPU architecture: 8 6015 CPU variant : 0x0 6016 CPU part : 0xd09 6017 CPU revision : 2 6018 6019 processor : 4 6020 BogoMIPS : 48.00 6021 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6022 CPU implementer : 0x41 6023 CPU architecture: 8 6024 CPU variant : 0x0 6025 CPU part : 0xd09 6026 CPU revision : 2 6027 6028 processor : 5 6029 BogoMIPS : 48.00 6030 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6031 CPU implementer : 0x41 6032 CPU architecture: 8 6033 CPU variant : 0x0 6034 CPU part : 0xd09 6035 CPU revision : 2 6036 6037 6038 ### meminfo: 6039 6040 MemTotal: 3719724 kB 6041 MemFree: 3401664 kB 6042 MemAvailable: 3368272 kB 6043 Buffers: 13060 kB 6044 Cached: 67664 kB 6045 SwapCached: 0 kB 6046 Active: 33872 kB 6047 Inactive: 167316 kB 6048 Active(anon): 144 kB 6049 Inactive(anon): 125400 kB 6050 Active(file): 33728 kB 6051 Inactive(file): 41916 kB 6052 Unevictable: 0 kB 6053 Mlocked: 0 kB 6054 SwapTotal: 1859860 kB 6055 SwapFree: 1859860 kB 6056 Dirty: 20776 kB 6057 Writeback: 0 kB 6058 AnonPages: 120632 kB 6059 Mapped: 15912 kB 6060 Shmem: 4936 kB 6061 KReclaimable: 14288 kB 6062 Slab: 46568 kB 6063 SReclaimable: 14288 kB 6064 SUnreclaim: 32280 kB 6065 KernelStack: 2736 kB 6066 PageTables: 5944 kB 6067 NFS_Unstable: 0 kB 6068 Bounce: 0 kB 6069 WritebackTmp: 0 kB 6070 CommitLimit: 3719720 kB 6071 Committed_AS: 4250048 kB 6072 VmallocTotal: 135290159040 kB 6073 VmallocUsed: 31508 kB 6074 VmallocChunk: 0 kB 6075 Percpu: 1416 kB 6076 HardwareCorrupted: 0 kB 6077 AnonHugePages: 0 kB 6078 ShmemHugePages: 0 kB 6079 ShmemPmdMapped: 0 kB 6080 FileHugePages: 0 kB 6081 FilePmdMapped: 0 kB 6082 CmaTotal: 917504 kB 6083 CmaFree: 901724 kB 6084 HugePages_Total: 0 6085 HugePages_Free: 0 6086 HugePages_Rsvd: 0 6087 HugePages_Surp: 0 6088 Hugepagesize: 2048 kB 6089 Hugetlb: 0 kB 6090 6091 ### virtual memory: 6092 6093 vm.admin_reserve_kbytes = 8192 6094 vm.block_dump = 0 6095 vm.compaction_proactiveness = 20 6096 vm.compact_unevictable_allowed = 1 6097 vm.dirty_background_bytes = 0 6098 vm.dirty_background_ratio = 10 6099 vm.dirty_bytes = 0 6100 vm.dirty_expire_centisecs = 3000 6101 vm.dirty_ratio = 20 6102 vm.dirtytime_expire_seconds = 43200 6103 vm.dirty_writeback_centisecs = 500 6104 vm.extfrag_threshold = 500 6105 vm.hugetlb_shm_group = 0 6106 vm.laptop_mode = 0 6107 vm.legacy_va_layout = 0 6108 vm.lowmem_reserve_ratio = 256 256 32 0 6109 vm.max_map_count = 65530 6110 vm.memory_failure_early_kill = 0 6111 vm.memory_failure_recovery = 1 6112 vm.min_free_kbytes = 45056 6113 vm.min_slab_ratio = 5 6114 vm.min_unmapped_ratio = 1 6115 vm.mmap_min_addr = 4096 6116 vm.mmap_rnd_bits = 18 6117 vm.mmap_rnd_compat_bits = 11 6118 vm.nr_hugepages = 0 6119 vm.nr_hugepages_mempolicy = 0 6120 vm.nr_overcommit_hugepages = 0 6121 vm.numa_stat = 1 6122 vm.numa_zonelist_order = Node 6123 vm.oom_dump_tasks = 1 6124 vm.oom_kill_allocating_task = 0 6125 vm.overcommit_kbytes = 0 6126 vm.overcommit_memory = 0 6127 vm.overcommit_ratio = 50 6128 vm.page-cluster = 0 6129 vm.page_lock_unfairness = 5 6130 vm.panic_on_oom = 0 6131 vm.percpu_pagelist_fraction = 0 6132 vm.stat_interval = 1 6133 vm.swappiness = 100 6134 vm.user_reserve_kbytes = 114995 6135 vm.vfs_cache_pressure = 100 6136 vm.watermark_boost_factor = 15000 6137 vm.watermark_scale_factor = 10 6138 vm.zone_reclaim_mode = 0 6139 6140 ### ip addr: 6141 6142 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 6143 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 6144 inet XXX.XXX.0.1/8 scope host lo 6145 valid_lft forever preferred_lft forever 6146 inet6 ::1/128 scope host 6147 valid_lft forever preferred_lft forever 6148 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 6149 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 6150 6151 ### partitions: 6152 6153 major minor #blocks name 6154 6155 179 0 62367744 mmcblk0 6156 179 1 62366720 mmcblk0p1 6157 179 32 61071360 mmcblk1 6158 179 33 60456544 mmcblk1p1 6159 252 0 1859864 zram0 6160 252 1 51200 zram1 6161 6162 ### df: 6163 6164 udev 1.4G 0 1.4G 0% /dev 6165 tmpfs 364M 5.0M 359M 2% /run 6166 /dev/mmcblk1p1 57G 21G 36G 37% / 6167 tmpfs 1.8G 0 1.8G 0% /dev/shm 6168 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 6169 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 6170 tmpfs 1.8G 0 1.8G 0% /tmp 6171 /dev/zram1 49M 21M 25M 46% /var/log 6172 6173 ### lsblk: 6174 6175 NAME FSTYPE SIZE MOUNTPOINT UUID 6176 mmcblk0 59.5G 6177 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 6178 mmcblk1 58.2G 6179 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 6180 mmcblk1boot0 4M 6181 mmcblk1boot1 4M 6182 zram1 50M /var/log 6183 6184 ### zramctl: 6185 6186 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 6187 /dev/zram1 zstd 50M 132K 695B 36K 6 /var/log 6188 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 6189 6190 ### mtab: 6191 6192 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 6193 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 6194 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 6195 6196 ### mmc0:aaaa info: 6197 6198 fwrev: 0x0 6199 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 6200 cid: 035344534836344780559b2001014a00 6201 rca: 0xaaaa 6202 csd: 400e0032db790001dbd37f800a404000 6203 manfid: 0x000003 6204 ocr: 0x00200000 6205 preferred_erase_size: 4194304 6206 type: SD 6207 hwrev: 0x8 6208 date: 10/2020 6209 dsr: 0x404 6210 erase_size: 512 6211 oemid: 0x5344 6212 serial: 0x559b2001 6213 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 6214 scr: 0245848300000000 6215 name: SH64G 6216 6217 ### mmc1:0001 info: 6218 6219 fwrev: 0x0400000000000000 6220 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 6221 cid: 150100434a54443452042559facb7700 6222 rel_sectors: 0x1 6223 enhanced_rpmb_supported: 0x1 6224 rca: 0x0001 6225 pre_eol_info: 0x01 6226 csd: d02701320f5903fff6dbffef8e404000 6227 manfid: 0x000015 6228 ocr: 0x00200000 6229 preferred_erase_size: 4194304 6230 enhanced_area_offset: 18446744073709551594 6231 raw_rpmb_size_mult: 0x20 6232 type: MMC 6233 hwrev: 0x0 6234 date: 07/2020 6235 prv: 0x4 6236 ffu_capable: 1 6237 dsr: 0x404 6238 erase_size: 524288 6239 life_time: 0x01 0x01 6240 enhanced_area_size: 4294967274 6241 oemid: 0x0100 6242 serial: 0x2559facb 6243 cmdq_en: 0 6244 rev: 0x8 6245 name: CJTD4R 6246 6247 ### Boot system health: 6248 6249 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 6250 21:26:35: 2400/2016MHz 0.16 20% 12% 6% 0% 1% 0% 21.8°C 0/12 6251 21:26:35: 2400/2016MHz 0.16 33% 22% 10% 0% 0% 0% 20.1°C 0/12 6252 21:26:36: 2400/2016MHz 0.16 18% 7% 10% 0% 0% 0% 19.4°C 0/12 6253 21:26:36: 2400/2016MHz 0.31 18% 8% 10% 0% 0% 0% 17.9°C 0/12 6254 21:26:36: 2400/2016MHz 0.31 89% 51% 24% 0% 10% 2% 21.9°C 0/12 6255 6256 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 6257 6258 ### Activated Armbian ramlog partition with zstd compression 6259 6260 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 6261 6262 ### Activated Armbian ramlog partition with zstd compression 6263 6264 ### Activated 1 lzo-rle zram swap devices with 1816 MB each 6265 6266 ### Activated Armbian ramlog partition with zstd compression 6267 6268 Mon 05 Apr 2021 02:56:51 PM CEST | Odroid N2 | 21.02.3 | arm64 | aarch64 | 5.10.21-meson64 6269 6270 ### dmesg: 6271 6272 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] 6273 [ 0.000000] Linux version 5.10.21-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 6274 [ 0.000000] Machine model: Hardkernel ODROID-N2Plus 6275 [ 0.000000] efi: UEFI not found. 6276 [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! 6277 [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB 6278 [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool 6279 [ 0.000000] NUMA: No NUMA configuration found 6280 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff] 6281 [ 0.000000] NUMA: NODE_DATA [mem 0xb502e100-0xb502ffff] 6282 [ 0.000000] Zone ranges: 6283 [ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff] 6284 [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ed7fffff] 6285 [ 0.000000] Normal empty 6286 [ 0.000000] Movable zone start for each node 6287 [ 0.000000] Early memory node ranges 6288 [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff] 6289 [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000052fffff] 6290 [ 0.000000] node 0: [mem 0x0000000005300000-0x00000000ed7fffff] 6291 [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff] 6292 [ 0.000000] On node 0 totalpages: 972800 6293 [ 0.000000] DMA zone: 4096 pages used for memmap 6294 [ 0.000000] DMA zone: 0 pages reserved 6295 [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 6296 [ 0.000000] DMA32 zone: 11104 pages used for memmap 6297 [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 6298 [ 0.000000] psci: probing for conduit method from DT. 6299 [ 0.000000] psci: PSCIv1.0 detected in firmware. 6300 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 6301 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 6302 [ 0.000000] psci: SMC Calling Convention v1.1 6303 [ 0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208 6304 [ 0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096 6305 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 6306 [ 0.000000] Detected VIPT I-cache on CPU0 6307 [ 0.000000] CPU features: detected: ARM erratum 845719 6308 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 6309 [ 0.000000] Policy zone: DMA32 6310 [ 0.000000] Kernel command line: root=UUID=51c33730-20c8-4007-8dc5-c3478d176211 rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 consoleblank=0 6311 [ 0.000000] Kernel parameter elevator= does not have any effect anymore. 6312 Please use sysfs to set IO scheduler for individual devices. 6313 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) 6314 [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) 6315 [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off 6316 [ 0.000000] software IO TLB: mapped [mem 0x000000003896d000-0x000000003c96d000] (64MB) 6317 [ 0.000000] Memory: 2783972K/3891200K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 189724K reserved, 917504K cma-reserved) 6318 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 6319 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. 6320 [ 0.000000] rcu: RCU event tracing is enabled. 6321 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. 6322 [ 0.000000] Trampoline variant of Tasks RCU enabled. 6323 [ 0.000000] Rude variant of Tasks RCU enabled. 6324 [ 0.000000] Tracing variant of Tasks RCU enabled. 6325 [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. 6326 [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 6327 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 6328 [ 0.000000] GIC: Using split EOI/Deactivate mode 6329 [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized 6330 [ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0 6331 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). 6332 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 6333 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 6334 [ 0.000252] Console: colour dummy device 80x25 6335 [ 0.000287] printk: console [tty1] enabled 6336 [ 0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 6337 [ 0.000387] pid_max: default: 32768 minimum: 301 6338 [ 0.000470] LSM: Security Framework initializing 6339 [ 0.000495] Yama: becoming mindful. 6340 [ 0.000584] AppArmor: AppArmor initialized 6341 [ 0.000634] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 6342 [ 0.000653] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) 6343 [ 0.002649] rcu: Hierarchical SRCU implementation. 6344 [ 0.005146] EFI services will not be available. 6345 [ 0.005569] smp: Bringing up secondary CPUs ... 6346 [ 0.006240] Detected VIPT I-cache on CPU1 6347 [ 0.006300] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] 6348 [ 0.007494] CPU features: detected: ARM erratum 858921 6349 [ 0.007502] CPU features: detected: Spectre-v2 6350 [ 0.007506] CPU features: detected: Spectre-v4 6351 [ 0.007512] Detected VIPT I-cache on CPU2 6352 [ 0.007537] arch_timer: Enabling local workaround for ARM erratum 858921 6353 [ 0.007552] arch_timer: CPU2: Trapping CNTVCT access 6354 [ 0.007567] CPU2: Booted secondary processor 0x0000000100 [0x410fd092] 6355 [ 0.008278] Detected VIPT I-cache on CPU3 6356 [ 0.008294] arch_timer: Enabling local workaround for ARM erratum 858921 6357 [ 0.008302] arch_timer: CPU3: Trapping CNTVCT access 6358 [ 0.008310] CPU3: Booted secondary processor 0x0000000101 [0x410fd092] 6359 [ 0.008936] Detected VIPT I-cache on CPU4 6360 [ 0.008952] arch_timer: Enabling local workaround for ARM erratum 858921 6361 [ 0.008959] arch_timer: CPU4: Trapping CNTVCT access 6362 [ 0.008967] CPU4: Booted secondary processor 0x0000000102 [0x410fd092] 6363 [ 0.009585] Detected VIPT I-cache on CPU5 6364 [ 0.009602] arch_timer: Enabling local workaround for ARM erratum 858921 6365 [ 0.009609] arch_timer: CPU5: Trapping CNTVCT access 6366 [ 0.009617] CPU5: Booted secondary processor 0x0000000103 [0x410fd092] 6367 [ 0.009699] smp: Brought up 1 node, 6 CPUs 6368 [ 0.009716] SMP: Total of 6 processors activated. 6369 [ 0.009724] CPU features: detected: 32-bit EL0 Support 6370 [ 0.009730] CPU features: detected: CRC32 instructions 6371 [ 0.009736] CPU features: detected: 32-bit EL1 Support 6372 [ 0.021001] CPU: All CPU(s) started at EL2 6373 [ 0.021051] alternatives: patching kernel code 6374 [ 0.023051] devtmpfs: initialized 6375 [ 0.030728] Registered cp15_barrier emulation handler 6376 [ 0.030742] Registered setend emulation handler 6377 [ 0.030881] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 6378 [ 0.030922] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) 6379 [ 0.046178] pinctrl core: initialized pinctrl subsystem 6380 [ 0.046902] DMI not present or invalid. 6381 [ 0.047277] NET: Registered protocol family 16 6382 [ 0.048820] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations 6383 [ 0.049093] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations 6384 [ 0.049324] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations 6385 [ 0.049365] audit: initializing netlink subsys (disabled) 6386 [ 0.049462] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1 6387 [ 0.050826] thermal_sys: Registered thermal governor 'fair_share' 6388 [ 0.050833] thermal_sys: Registered thermal governor 'bang_bang' 6389 [ 0.050837] thermal_sys: Registered thermal governor 'step_wise' 6390 [ 0.050841] thermal_sys: Registered thermal governor 'user_space' 6391 [ 0.051259] cpuidle: using governor menu 6392 [ 0.051597] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. 6393 [ 0.051735] ASID allocator initialised with 65536 entries 6394 [ 0.052736] Serial: AMBA PL011 UART driver 6395 [ 0.088111] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages 6396 [ 0.088121] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages 6397 [ 0.088126] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages 6398 [ 0.088130] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages 6399 [ 0.090180] cryptd: max_cpu_qlen set to 1000 6400 [ 0.160230] raid6: neonx8 gen() 2780 MB/s 6401 [ 0.228272] raid6: neonx8 xor() 2041 MB/s 6402 [ 0.296343] raid6: neonx4 gen() 3001 MB/s 6403 [ 0.364408] raid6: neonx4 xor() 2349 MB/s 6404 [ 0.432482] raid6: neonx2 gen() 2576 MB/s 6405 [ 0.500549] raid6: neonx2 xor() 2143 MB/s 6406 [ 0.568629] raid6: neonx1 gen() 1964 MB/s 6407 [ 0.636697] raid6: neonx1 xor() 1724 MB/s 6408 [ 0.704762] raid6: int64x8 gen() 1373 MB/s 6409 [ 0.772829] raid6: int64x8 xor() 735 MB/s 6410 [ 0.840914] raid6: int64x4 gen() 1463 MB/s 6411 [ 0.908959] raid6: int64x4 xor() 733 MB/s 6412 [ 0.977026] raid6: int64x2 gen() 1362 MB/s 6413 [ 1.045080] raid6: int64x2 xor() 619 MB/s 6414 [ 1.113162] raid6: int64x1 gen() 1127 MB/s 6415 [ 1.181228] raid6: int64x1 xor() 462 MB/s 6416 [ 1.181232] raid6: using algorithm neonx4 gen() 3001 MB/s 6417 [ 1.181235] raid6: .... xor() 2349 MB/s, rmw enabled 6418 [ 1.181238] raid6: using neon recovery algorithm 6419 [ 1.181678] ACPI: Interpreter disabled. 6420 [ 1.182463] 5V: supplied by 12V 6421 [ 1.183359] VDDAO_3V3: supplied by 12V 6422 [ 1.183846] iommu: Default domain type: Translated 6423 [ 1.183964] vgaarb: loaded 6424 [ 1.184867] SCSI subsystem initialized 6425 [ 1.185172] usbcore: registered new interface driver usbfs 6426 [ 1.185211] usbcore: registered new interface driver hub 6427 [ 1.185251] usbcore: registered new device driver usb 6428 [ 1.185522] pps_core: LinuxPPS API ver. 1 registered 6429 [ 1.185527] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 6430 [ 1.185543] PTP clock support registered 6431 [ 1.185735] EDAC MC: Ver: 3.0.0 6432 [ 1.187106] NetLabel: Initializing 6433 [ 1.187113] NetLabel: domain hash size = 128 6434 [ 1.187116] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO 6435 [ 1.187157] NetLabel: unlabeled traffic allowed by default 6436 [ 1.187639] clocksource: Switched to clocksource arch_sys_counter 6437 [ 1.187853] VFS: Disk quotas dquot_6.6.0 6438 [ 1.187896] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) 6439 [ 1.188255] AppArmor: AppArmor Filesystem Enabled 6440 [ 1.188302] pnp: PnP ACPI: disabled 6441 [ 1.193898] NET: Registered protocol family 2 6442 [ 1.194346] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) 6443 [ 1.194451] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) 6444 [ 1.194708] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) 6445 [ 1.194896] TCP: Hash tables configured (established 32768 bind 32768) 6446 [ 1.195050] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear) 6447 [ 1.195115] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) 6448 [ 1.195162] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) 6449 [ 1.195308] NET: Registered protocol family 1 6450 [ 1.195327] PCI: CLS 0 bytes, default 64 6451 [ 1.195447] Trying to unpack rootfs image as initramfs... 6452 [ 1.763940] Freeing initrd memory: 14920K 6453 [ 1.764880] kvm [1]: IPA Size Limit: 40 bits 6454 [ 1.765592] kvm [1]: vgic interrupt IRQ9 6455 [ 1.765727] kvm [1]: Hyp mode initialized successfully 6456 [ 1.770833] Initialise system trusted keyrings 6457 [ 1.770867] Key type blacklist registered 6458 [ 1.770988] workingset: timestamp_bits=44 max_order=20 bucket_order=0 6459 [ 1.774223] zbud: loaded 6460 [ 1.775197] squashfs: version 4.0 (2009/01/31) Phillip Lougher 6461 [ 1.775695] fuse: init (API version 7.32) 6462 [ 1.776492] integrity: Platform Keyring initialized 6463 [ 1.804290] xor: measuring software checksum speed 6464 [ 1.807124] 8regs : 3476 MB/sec 6465 [ 1.809582] 32regs : 4024 MB/sec 6466 [ 1.812237] arm64_neon : 3719 MB/sec 6467 [ 1.812240] xor: using function: 32regs (4024 MB/sec) 6468 [ 1.812247] Key type asymmetric registered 6469 [ 1.812251] Asymmetric key parser 'x509' registered 6470 [ 1.812285] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 6471 [ 1.812393] io scheduler mq-deadline registered 6472 [ 1.812397] io scheduler kyber registered 6473 [ 1.812473] io scheduler bfq registered 6474 [ 1.815003] gpio-447 (usb-hub-reset): hogged as output/high 6475 [ 1.818011] EINJ: ACPI disabled. 6476 [ 1.824336] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 6477 [ 1.825741] VCC_3V3: supplied by VDDAO_3V3 6478 [ 1.825775] FLASH_1V8: supplied by VCC_3V3 6479 [ 1.825811] VCC_1V8: supplied by VCC_3V3 6480 [ 1.825849] VDDAO_1V8: supplied by VDDAO_3V3 6481 [ 1.825877] VDDCPU_A: supplied by regulator-dummy 6482 [ 1.826234] VDDCPU_B: supplied by regulator-dummy 6483 [ 1.826945] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 6484 [ 1.829373] Serial: AMBA driver 6485 [ 1.829666] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 6486 [ 1.829759] printk: console [ttyAML0] enabled 6487 [ 1.830271] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 6488 [ 1.835627] loop: module loaded 6489 [ 1.837548] libphy: Fixed MDIO Bus: probed 6490 [ 1.838620] tun: Universal TUN/TAP device driver, 1.6 6491 [ 1.839290] thunder_xcv, ver 1.0 6492 [ 1.839320] thunder_bgx, ver 1.0 6493 [ 1.839349] nicpf, ver 1.0 6494 [ 1.839923] e1000e: Intel(R) PRO/1000 Network Driver 6495 [ 1.839928] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 6496 [ 1.839978] igb: Intel(R) Gigabit Ethernet Network Driver 6497 [ 1.839982] igb: Copyright (c) 2007-2014 Intel Corporation. 6498 [ 1.840015] igbvf: Intel(R) Gigabit Virtual Function Network Driver 6499 [ 1.840019] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 6500 [ 1.840147] sky2: driver version 1.30 6501 [ 1.840525] VFIO - User Level meta-driver version: 0.3 6502 [ 1.841909] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 6503 [ 1.841925] ehci-pci: EHCI PCI platform driver 6504 [ 1.841953] ehci-platform: EHCI generic platform driver 6505 [ 1.842083] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 6506 [ 1.842093] ohci-pci: OHCI PCI platform driver 6507 [ 1.842123] ohci-platform: OHCI generic platform driver 6508 [ 1.842536] usbcore: registered new interface driver usb-storage 6509 [ 1.843834] mousedev: PS/2 mouse device common for all mice 6510 [ 1.844288] i2c /dev entries driver 6511 [ 1.849523] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 6512 [ 1.850386] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 6513 [ 1.851033] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 6514 [ 1.851595] sdhci: Secure Digital Host Controller Interface driver 6515 [ 1.851601] sdhci: Copyright(c) Pierre Ossman 6516 [ 1.851767] Synopsys Designware Multimedia Card Interface Driver 6517 [ 1.852140] sdhci-pltfm: SDHCI platform and OF driver helper 6518 [ 1.852499] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 6519 [ 1.852882] ledtrig-cpu: registered to indicate activity on CPUs 6520 [ 1.853148] meson-sm: secure-monitor enabled 6521 [ 1.853570] hid: raw HID events driver (C) Jiri Kosina 6522 [ 1.853669] usbcore: registered new interface driver usbhid 6523 [ 1.853672] usbhid: USB HID core driver 6524 [ 1.854647] NET: Registered protocol family 10 6525 [ 1.854995] Segment Routing with IPv6 6526 [ 1.855022] NET: Registered protocol family 17 6527 [ 1.855058] 8021q: 802.1Q VLAN Support v1.8 6528 [ 1.855078] Key type dns_resolver registered 6529 [ 1.855328] registered taskstats version 1 6530 [ 1.855334] Loading compiled-in X.509 certificates 6531 [ 1.856692] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 6532 [ 1.858093] zswap: loaded using pool zstd/z3fold 6533 [ 1.858238] Key type ._fscrypt registered 6534 [ 1.858240] Key type .fscrypt registered 6535 [ 1.858242] Key type fscrypt-provisioning registered 6536 [ 1.859256] Btrfs loaded, crc32c=crc32c-generic 6537 [ 1.864389] Key type encrypted registered 6538 [ 1.864400] AppArmor: AppArmor sha1 policy hashing enabled 6539 [ 1.869677] HUB_5V: supplied by 5V 6540 [ 1.869828] USB_PWR_EN: supplied by 5V 6541 [ 1.871272] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 6542 [ 1.871279] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 6543 [ 1.873927] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 6544 [ 1.873970] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 6545 [ 1.874053] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 6546 [ 1.874549] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 6547 [ 1.874559] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 6548 [ 1.874647] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 6549 [ 1.874668] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 6550 [ 1.874782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 6551 [ 1.874785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 6552 [ 1.874787] usb usb1: Product: xHCI Host Controller 6553 [ 1.874789] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 6554 [ 1.874791] usb usb1: SerialNumber: xhci-hcd.0.auto 6555 [ 1.874952] hub 1-0:1.0: USB hub found 6556 [ 1.874963] hub 1-0:1.0: 2 ports detected 6557 [ 1.875073] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 6558 [ 1.875077] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 6559 [ 1.875082] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 6560 [ 1.875100] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 6561 [ 1.875126] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 6562 [ 1.875129] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 6563 [ 1.875130] usb usb2: Product: xHCI Host Controller 6564 [ 1.875132] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 6565 [ 1.875134] usb usb2: SerialNumber: xhci-hcd.0.auto 6566 [ 1.875250] hub 2-0:1.0: USB hub found 6567 [ 1.875257] hub 2-0:1.0: 1 port detected 6568 [ 1.875482] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 6569 [ 1.876734] meson-gx-mmc ffe05000.sd: Got CD GPIO 6570 [ 1.904168] Freeing unused kernel memory: 3328K 6571 [ 1.943678] Run /init as init process 6572 [ 1.943681] with arguments: 6573 [ 1.943684] /init 6574 [ 1.943685] with environment: 6575 [ 1.943687] HOME=/ 6576 [ 1.943688] TERM=linux 6577 [ 1.943689] hdmimode=custombuilt 6578 [ 1.943690] cvbsmode=576cvbs 6579 [ 1.943692] max_freq_a53=1908 6580 [ 1.943693] max_freq_a73=2208 6581 [ 1.943694] voutmode=hdmi 6582 [ 1.943695] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 6583 [ 1.943696] disablehpd=false 6584 [ 1.943697] cvbscable= 6585 [ 1.943698] overscan=100 6586 [ 2.047772] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 6587 [ 2.047778] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 6588 [ 2.047865] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 6589 [ 2.048304] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 6590 [ 2.048310] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 6591 [ 2.048313] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 6592 [ 2.048315] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 6593 [ 2.048317] meson8b-dwmac ff3f0000.ethernet: COE Type 2 6594 [ 2.048319] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 6595 [ 2.048320] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 6596 [ 2.048357] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 6597 [ 2.048359] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 6598 [ 2.048361] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 6599 [ 2.048509] libphy: stmmac: probed 6600 [ 2.051551] libphy: mdio_mux: probed 6601 [ 2.070205] meson-vrtc ff8000a8.rtc: registered as rtc1 6602 [ 2.070657] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 6603 [ 2.070880] rtc-pcf8563 1-0051: registered as rtc0 6604 [ 2.072170] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 6605 [ 2.072182] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 6606 [ 2.145543] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 6607 [ 2.146046] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 6608 [ 2.150430] mmc1: new HS200 MMC card at address 0001 6609 [ 2.150775] mmcblk0: p1 6610 [ 2.151198] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 6611 [ 2.151572] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 6612 [ 2.151971] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 6613 [ 2.152093] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 6614 [ 2.153452] mmcblk1: p1 6615 [ 2.163614] random: fast init done 6616 [ 2.211772] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 6617 [ 2.236365] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 6618 [ 2.236371] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 6619 [ 2.236374] usb 2-1: Product: USB3.1 Hub 6620 [ 2.236376] usb 2-1: Manufacturer: GenesysLogic 6621 [ 2.256053] libphy: mdio_mux: probed 6622 [ 2.259390] hub 2-1:1.0: USB hub found 6623 [ 2.259679] hub 2-1:1.0: 4 ports detected 6624 [ 2.359659] usb 1-1: new high-speed USB device number 2 using xhci-hcd 6625 [ 2.509980] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 6626 [ 2.509985] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 6627 [ 2.509989] usb 1-1: Product: USB2.1 Hub 6628 [ 2.509993] usb 1-1: Manufacturer: GenesysLogic 6629 [ 2.547356] hub 1-1:1.0: USB hub found 6630 [ 2.547579] hub 1-1:1.0: 4 ports detected 6631 [ 2.923650] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 6632 [ 3.050656] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 6633 [ 3.050661] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 6634 [ 3.050664] usb 1-1.1: Product: USB OPTICAL MOUSE 6635 [ 3.093486] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 6636 [ 3.093702] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 6637 [ 3.195651] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 6638 [ 3.234735] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 6639 [ 3.332996] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 6640 [ 3.333006] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 6641 [ 3.333010] usb 1-1.3: Product: USB Keyboard 6642 [ 3.333013] usb 1-1.3: Manufacturer: Logitech 6643 [ 3.408041] systemd[1]: System time before build time, advancing clock. 6644 [ 3.411728] systemd[1]: Inserted module 'autofs4' 6645 [ 3.416471] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 6646 [ 3.429690] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 6647 [ 3.429871] systemd[1]: Detected architecture arm64. 6648 [ 3.457278] systemd[1]: Set hostname to <odroidn2>. 6649 [ 3.476298] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 6650 [ 3.483299] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 6651 [ 3.539916] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 6652 [ 3.540055] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 6653 [ 3.612625] random: systemd: uninitialized urandom read (16 bytes read) 6654 [ 3.615211] random: systemd: uninitialized urandom read (16 bytes read) 6655 [ 3.615408] systemd[1]: Listening on udev Kernel Socket. 6656 [ 3.615744] random: systemd: uninitialized urandom read (16 bytes read) 6657 [ 3.615916] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. 6658 [ 3.616155] systemd[1]: Listening on udev Control Socket. 6659 [ 3.616278] systemd[1]: Listening on initctl Compatibility Named Pipe. 6660 [ 3.616514] systemd[1]: Listening on Journal Audit Socket. 6661 [ 3.616584] systemd[1]: Reached target Remote File Systems. 6662 [ 3.616663] systemd[1]: Reached target System Time Synchronized. 6663 [ 3.664329] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 6664 [ 3.884092] zram: Added device: zram0 6665 [ 3.884257] zram: Added device: zram1 6666 [ 3.884381] zram: Added device: zram2 6667 [ 3.915701] pwm-gpio pwmgpio: 1 gpio pwms loaded 6668 [ 3.944938] zram0: detected capacity change from 0 to 1904500736 6669 [ 3.978061] meson-drm ff900000.vpu: Queued 2 outputs on vpu 6670 [ 3.981860] mc: Linux media interface: v0.10 6671 [ 3.983557] meson-drm ff900000.vpu: CVBS Output connector not available 6672 [ 3.989190] videodev: Linux video capture interface: v2.00 6673 [ 4.007364] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 6674 [ 4.011714] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 6675 [ 4.012343] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 6676 [ 4.012570] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 6677 [ 4.012805] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 6678 [ 4.060191] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 6679 [ 4.078183] panfrost ffe40000.gpu: clock rate = 24000000 6680 [ 4.078231] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 6681 [ 4.078752] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 6682 [ 4.078757] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 6683 [ 4.078760] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 6684 [ 4.078763] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 6685 [ 4.093952] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 6686 [ 4.095686] Registered IR keymap rc-odroid 6687 [ 4.108886] IR NEC protocol handler initialized 6688 [ 4.135744] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 6689 [ 4.135823] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 6690 [ 4.135870] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 6691 [ 4.136511] meson-ir ff808000.ir: receiver initialized 6692 [ 4.304522] Console: switching to colour frame buffer device 240x67 6693 [ 4.335736] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 6694 [ 4.369310] axg-sound-card sound: ASoC: no DMI vendor name! 6695 [ 4.979657] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 6696 [ 5.022600] zram1: detected capacity change from 0 to 52428800 6697 [ 7.067679] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 6698 [ 7.067700] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 6699 [ 8.081399] systemd-journald[1877]: Received request to flush runtime journal from PID 1 6700 6701 ### armbian-release: 6702 6703 # PLEASE DO NOT EDIT THIS FILE 6704 BOARD=odroidn2 6705 BOARD_NAME="Odroid N2" 6706 BOARDFAMILY=meson-g12b 6707 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 6708 BUILD_REPOSITORY_COMMIT=e846ef656-dirty 6709 DISTRIBUTION_CODENAME=buster 6710 DISTRIBUTION_STATUS=supported 6711 VERSION=21.02.3 6712 LINUXFAMILY=meson64 6713 BRANCH=current 6714 ARCH=arm64 6715 IMAGE_TYPE=stable 6716 BOARD_TYPE=conf 6717 INITRD_ARCH=arm64 6718 KERNEL_IMAGE_TYPE=Image 6719 6720 ### boot environment: 6721 6722 verbosity=1 6723 console=both 6724 overlay_prefix=meson 6725 bootlogo=true 6726 rootdev=UUID=51c33730-20c8-4007-8dc5-c3478d176211 6727 rootfstype=ext4 6728 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 6729 6730 ### lsusb: 6731 6732 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 6733 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 6734 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 6735 Bus 001 Device 003: ID 275d:0ba6 6736 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 6737 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 6738 6739 ### lscpu: 6740 6741 Architecture: aarch64 6742 Byte Order: Little Endian 6743 CPU(s): 6 6744 On-line CPU(s) list: 0-5 6745 Thread(s) per core: 1 6746 Core(s) per socket: 3 6747 Socket(s): 2 6748 NUMA node(s): 1 6749 Vendor ID: ARM 6750 Model: 4 6751 Model name: Cortex-A53 6752 Stepping: r0p4 6753 CPU max MHz: 2400.0000 6754 CPU min MHz: 100.0000 6755 BogoMIPS: 48.00 6756 L1d cache: unknown size 6757 L1i cache: unknown size 6758 L2 cache: unknown size 6759 NUMA node0 CPU(s): 0-5 6760 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6761 6762 ### cpuinfo: 6763 6764 processor : 0 6765 BogoMIPS : 48.00 6766 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6767 CPU implementer : 0x41 6768 CPU architecture: 8 6769 CPU variant : 0x0 6770 CPU part : 0xd03 6771 CPU revision : 4 6772 6773 processor : 1 6774 BogoMIPS : 48.00 6775 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6776 CPU implementer : 0x41 6777 CPU architecture: 8 6778 CPU variant : 0x0 6779 CPU part : 0xd03 6780 CPU revision : 4 6781 6782 processor : 2 6783 BogoMIPS : 48.00 6784 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6785 CPU implementer : 0x41 6786 CPU architecture: 8 6787 CPU variant : 0x0 6788 CPU part : 0xd09 6789 CPU revision : 2 6790 6791 processor : 3 6792 BogoMIPS : 48.00 6793 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6794 CPU implementer : 0x41 6795 CPU architecture: 8 6796 CPU variant : 0x0 6797 CPU part : 0xd09 6798 CPU revision : 2 6799 6800 processor : 4 6801 BogoMIPS : 48.00 6802 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6803 CPU implementer : 0x41 6804 CPU architecture: 8 6805 CPU variant : 0x0 6806 CPU part : 0xd09 6807 CPU revision : 2 6808 6809 processor : 5 6810 BogoMIPS : 48.00 6811 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid 6812 CPU implementer : 0x41 6813 CPU architecture: 8 6814 CPU variant : 0x0 6815 CPU part : 0xd09 6816 CPU revision : 2 6817 6818 6819 ### meminfo: 6820 6821 MemTotal: 3719724 kB 6822 MemFree: 3373276 kB 6823 MemAvailable: 3340472 kB 6824 Buffers: 13344 kB 6825 Cached: 68160 kB 6826 SwapCached: 0 kB 6827 Active: 34136 kB 6828 Inactive: 194072 kB 6829 Active(anon): 156 kB 6830 Inactive(anon): 151560 kB 6831 Active(file): 33980 kB 6832 Inactive(file): 42512 kB 6833 Unevictable: 0 kB 6834 Mlocked: 0 kB 6835 SwapTotal: 1859860 kB 6836 SwapFree: 1859860 kB 6837 Dirty: 21228 kB 6838 Writeback: 0 kB 6839 AnonPages: 146732 kB 6840 Mapped: 14972 kB 6841 Shmem: 5016 kB 6842 KReclaimable: 14616 kB 6843 Slab: 46764 kB 6844 SReclaimable: 14616 kB 6845 SUnreclaim: 32148 kB 6846 KernelStack: 2640 kB 6847 PageTables: 6848 kB 6848 NFS_Unstable: 0 kB 6849 Bounce: 0 kB 6850 WritebackTmp: 0 kB 6851 CommitLimit: 3719720 kB 6852 Committed_AS: 4249748 kB 6853 VmallocTotal: 135290159040 kB 6854 VmallocUsed: 31524 kB 6855 VmallocChunk: 0 kB 6856 Percpu: 1416 kB 6857 HardwareCorrupted: 0 kB 6858 AnonHugePages: 0 kB 6859 ShmemHugePages: 0 kB 6860 ShmemPmdMapped: 0 kB 6861 FileHugePages: 0 kB 6862 FilePmdMapped: 0 kB 6863 CmaTotal: 917504 kB 6864 CmaFree: 901724 kB 6865 HugePages_Total: 0 6866 HugePages_Free: 0 6867 HugePages_Rsvd: 0 6868 HugePages_Surp: 0 6869 Hugepagesize: 2048 kB 6870 Hugetlb: 0 kB 6871 6872 ### virtual memory: 6873 6874 vm.admin_reserve_kbytes = 8192 6875 vm.block_dump = 0 6876 vm.compaction_proactiveness = 20 6877 vm.compact_unevictable_allowed = 1 6878 vm.dirty_background_bytes = 0 6879 vm.dirty_background_ratio = 10 6880 vm.dirty_bytes = 0 6881 vm.dirty_expire_centisecs = 3000 6882 vm.dirty_ratio = 20 6883 vm.dirtytime_expire_seconds = 43200 6884 vm.dirty_writeback_centisecs = 500 6885 vm.extfrag_threshold = 500 6886 vm.hugetlb_shm_group = 0 6887 vm.laptop_mode = 0 6888 vm.legacy_va_layout = 0 6889 vm.lowmem_reserve_ratio = 256 256 32 0 6890 vm.max_map_count = 65530 6891 vm.memory_failure_early_kill = 0 6892 vm.memory_failure_recovery = 1 6893 vm.min_free_kbytes = 45056 6894 vm.min_slab_ratio = 5 6895 vm.min_unmapped_ratio = 1 6896 vm.mmap_min_addr = 4096 6897 vm.mmap_rnd_bits = 18 6898 vm.mmap_rnd_compat_bits = 11 6899 vm.nr_hugepages = 0 6900 vm.nr_hugepages_mempolicy = 0 6901 vm.nr_overcommit_hugepages = 0 6902 vm.numa_stat = 1 6903 vm.numa_zonelist_order = Node 6904 vm.oom_dump_tasks = 1 6905 vm.oom_kill_allocating_task = 0 6906 vm.overcommit_kbytes = 0 6907 vm.overcommit_memory = 0 6908 vm.overcommit_ratio = 50 6909 vm.page-cluster = 0 6910 vm.page_lock_unfairness = 5 6911 vm.panic_on_oom = 0 6912 vm.percpu_pagelist_fraction = 0 6913 vm.stat_interval = 1 6914 vm.swappiness = 100 6915 vm.user_reserve_kbytes = 114979 6916 vm.vfs_cache_pressure = 100 6917 vm.watermark_boost_factor = 15000 6918 vm.watermark_scale_factor = 10 6919 vm.zone_reclaim_mode = 0 6920 6921 ### ip addr: 6922 6923 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 6924 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 6925 inet XXX.XXX.0.1/8 scope host lo 6926 valid_lft forever preferred_lft forever 6927 inet6 ::1/128 scope host 6928 valid_lft forever preferred_lft forever 6929 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 6930 link/ether 00:1e:06:42:52:64 brd ff:ff:ff:ff:ff:ff 6931 6932 ### partitions: 6933 6934 major minor #blocks name 6935 6936 179 0 62367744 mmcblk0 6937 179 1 62366720 mmcblk0p1 6938 179 32 61071360 mmcblk1 6939 179 33 60456544 mmcblk1p1 6940 252 0 1859864 zram0 6941 252 1 51200 zram1 6942 6943 ### df: 6944 6945 udev 1.4G 0 1.4G 0% /dev 6946 tmpfs 364M 5.0M 359M 2% /run 6947 /dev/mmcblk1p1 57G 21G 36G 37% / 6948 tmpfs 1.8G 0 1.8G 0% /dev/shm 6949 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 6950 tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup 6951 tmpfs 1.8G 0 1.8G 0% /tmp 6952 /dev/zram1 49M 21M 25M 47% /var/log 6953 6954 ### lsblk: 6955 6956 NAME FSTYPE SIZE MOUNTPOINT UUID 6957 mmcblk0 59.5G 6958 └─mmcblk0p1 ext4 59.5G 83574bbb-e4ac-4398-8436-9962a3c61cdf 6959 mmcblk1 58.2G 6960 └─mmcblk1p1 ext4 57.7G / 51c33730-20c8-4007-8dc5-c3478d176211 6961 mmcblk1boot0 4M 6962 mmcblk1boot1 4M 6963 zram1 50M /var/log 6964 6965 ### zramctl: 6966 6967 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 6968 /dev/zram1 zstd 50M 132K 698B 36K 6 /var/log 6969 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 6970 6971 ### mtab: 6972 6973 /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 6974 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 6975 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 6976 6977 ### mmc0:aaaa info: 6978 6979 fwrev: 0x0 6980 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SH64G MODALIAS=mmc:block 6981 cid: 035344534836344780559b2001014a00 6982 rca: 0xaaaa 6983 csd: 400e0032db790001dbd37f800a404000 6984 manfid: 0x000003 6985 ocr: 0x00200000 6986 preferred_erase_size: 4194304 6987 type: SD 6988 hwrev: 0x8 6989 date: 10/2020 6990 dsr: 0x404 6991 erase_size: 512 6992 oemid: 0x5344 6993 serial: 0x559b2001 6994 ssr: 0000000008000000040090000f05391e000800000001000003000000000000000000000000000000000000000000000000000000000000000000000000000000 6995 scr: 0245848300000000 6996 name: SH64G 6997 6998 ### mmc1:0001 info: 6999 7000 fwrev: 0x0400000000000000 7001 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=CJTD4R MODALIAS=mmc:block 7002 cid: 150100434a54443452042559facb7700 7003 rel_sectors: 0x1 7004 enhanced_rpmb_supported: 0x1 7005 rca: 0x0001 7006 pre_eol_info: 0x01 7007 csd: d02701320f5903fff6dbffef8e404000 7008 manfid: 0x000015 7009 ocr: 0x00200000 7010 preferred_erase_size: 4194304 7011 enhanced_area_offset: 18446744073709551594 7012 raw_rpmb_size_mult: 0x20 7013 type: MMC 7014 hwrev: 0x0 7015 date: 07/2020 7016 prv: 0x4 7017 ffu_capable: 1 7018 dsr: 0x404 7019 erase_size: 524288 7020 life_time: 0x01 0x01 7021 enhanced_area_size: 4294967274 7022 oemid: 0x0100 7023 serial: 0x2559facb 7024 cmdq_en: 0 7025 rev: 0x8 7026 name: CJTD4R 7027 7028 ### Boot system health: 7029 7030 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 7031 14:56:52: 2400/2016MHz 0.16 20% 13% 6% 0% 1% 0% 23.7°C 0/12 7032 14:56:52: 2400/2016MHz 0.16 33% 22% 10% 0% 0% 0% 22.8°C 0/12 7033 14:56:53: 2400/2016MHz 0.16 18% 9% 8% 0% 0% 0% 22.2°C 0/12 7034 14:56:53: 2400/2016MHz 0.23 31% 19% 9% 0% 0% 0% 21.8°C 0/12 7035 14:56:53: 2400/2016MHz 0.23 67% 34% 13% 0% 15% 1% 22.7°C 0/12 7036 7037 ### lsusb: 7038 7039 Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. 7040 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub 7041 Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120 7042 Bus 001 Device 003: ID 275d:0ba6 7043 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub 7044 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 7045 7046 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M 7047 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M 7048 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M 7049 |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M 7050 |__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 7051 |__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M 7052 |__ Port 3: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M 7053 7054 ### lspci: 7055 7056 7057 ### Installed packages: 7058 7059 ii armbian-buster-desktop 21.02.2 all Armbian desktop for Debian buster 7060 ii armbian-config 21.02.3 all Armbian configuration utility 7061 ii armbian-firmware-full 21.02.3 all Linux firmware-full 7062 ii hostapd 3:2.9-102~armbian20.05.2+1 arm64 IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 7063 ii htop 3.1.0-0~armbian20.08.2+1 arm64 interactive processes viewer 7064 ii linux-base 4.6 all Linux image base package 7065 ii linux-buster-root-current-odroidn2 21.02.3 arm64 Armbian tweaks for buster on odroidn2 (current branch) 7066 ii linux-dtb-current-meson64 21.02.3 arm64 Linux DTB, version 5.10.21-meson64 7067 ii linux-image-current-meson64 21.02.3 arm64 Linux kernel, version 5.10.21-meson64 7068 ii linux-libc-dev:arm64 4.19.171-2 arm64 Linux support headers for userspace development 7069 ii linux-u-boot-odroidn2-current 21.02.3 arm64 Uboot loader 2015.01 7070 7071 ### Loaded modules: 7072 7073 Module Size Used by 7074 rfkill 36864 1 7075 cpufreq_powersave 20480 0 7076 cpufreq_conservative 16384 0 7077 snd_soc_hdmi_codec 20480 1 7078 dw_hdmi_i2s_audio 16384 0 7079 joydev 32768 0 7080 ir_nec_decoder 20480 0 7081 panfrost 65536 0 7082 gpu_sched 32768 1 panfrost 7083 rc_odroid 16384 0 7084 meson_ir 16384 0 7085 meson_saradc 24576 0 7086 rc_core 57344 4 ir_nec_decoder,meson_ir,rc_odroid 7087 snd_soc_meson_axg_sound_card 16384 0 7088 snd_soc_meson_card_utils 16384 3 snd_soc_meson_axg_sound_card 7089 snd_soc_meson_g12a_tohdmitx 20480 1 7090 reset_meson_audio_arb 16384 6 7091 snd_soc_meson_axg_frddr 36864 3 7092 snd_soc_meson_axg_toddr 28672 3 7093 meson_gxbb_wdt 20480 0 7094 snd_soc_meson_axg_fifo 20480 2 snd_soc_meson_axg_toddr,snd_soc_meson_axg_frddr 7095 snd_soc_meson_axg_tdmout 24576 2 7096 meson_vdec 73728 0 7097 v4l2_mem2mem 40960 1 meson_vdec 7098 videobuf2_dma_contig 24576 1 meson_vdec 7099 snd_soc_meson_axg_tdmin 24576 4 7100 videobuf2_memops 20480 1 videobuf2_dma_contig 7101 videobuf2_v4l2 32768 2 meson_vdec,v4l2_mem2mem 7102 videobuf2_common 57344 3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem 7103 videodev 278528 4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem 7104 snd_soc_meson_g12a_toacodec 16384 1 7105 snd_soc_meson_codec_glue 16384 2 snd_soc_meson_g12a_toacodec,snd_soc_meson_g12a_tohdmitx 7106 meson_dw_hdmi 24576 0 7107 mc 61440 4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem 7108 meson_drm 61440 3 meson_dw_hdmi 7109 meson_canvas 16384 2 meson_drm,meson_vdec 7110 dw_hdmi 53248 2 meson_dw_hdmi,dw_hdmi_i2s_audio 7111 drm_kms_helper 245760 5 meson_dw_hdmi,meson_drm,dw_hdmi 7112 display_connector 20480 0 7113 snd_soc_meson_t9015 24576 1 7114 meson_rng 16384 0 7115 snd_soc_meson_axg_tdm_interface 16384 3 snd_soc_meson_axg_sound_card 7116 snd_soc_simple_amplifier 16384 1 7117 cec 73728 2 drm_kms_helper,dw_hdmi 7118 snd_soc_meson_axg_tdm_formatter 16384 3 snd_soc_meson_axg_tdmin,snd_soc_meson_axg_tdm_interface,snd_soc_meson_axg_tdmout 7119 snd_soc_core 221184 15 snd_soc_meson_axg_tdm_formatter,snd_soc_meson_t9015,snd_soc_meson_g12a_toacodec,snd_soc_meson_axg_sound_card,snd_soc_hdmi_codec,snd_soc_meson_g12a_tohdmitx,snd_soc_meson_axg_tdmin,snd_soc_simple_amplifier,snd_soc_meson_axg_tdm_interface,snd_soc_meson_axg_fifo,snd_soc_meson_axg_tdmout,snd_soc_meson_axg_toddr,snd_soc_meson_axg_frddr,snd_soc_meson_card_utils,snd_soc_meson_codec_glue 7120 ac97_bus 16384 1 snd_soc_core 7121 snd_pcm_dmaengine 20480 1 snd_soc_core 7122 drm 561152 10 gpu_sched,meson_dw_hdmi,meson_drm,drm_kms_helper,display_connector,dw_hdmi,panfrost 7123 snd_pcm 122880 7 snd_soc_hdmi_codec,snd_soc_meson_axg_tdm_interface,snd_soc_core,snd_soc_meson_axg_fifo,snd_soc_meson_axg_toddr,snd_soc_meson_codec_glue,snd_pcm_dmaengine 7124 snd_timer 40960 1 snd_pcm 7125 snd 90112 8 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm 7126 pwm_fan 20480 0 7127 pwm_gpio 16384 1 7128 drm_panel_orientation_quirks 20480 1 drm 7129 soundcore 16384 1 snd 7130 zram 36864 2 7131 ip_tables 32768 0 7132 x_tables 45056 1 ip_tables 7133 autofs4 45056 2 7134 meson_gxl 20480 0 7135 rtc_meson_vrtc 20480 1 7136 rtc_pcf8563 24576 0 7137 realtek 24576 1 7138 axg_audio 77824 49 7139 sclk_div 16384 1 axg_audio 7140 clk_phase 16384 1 axg_audio 7141 dwmac_generic 16384 0 7142 dwmac_meson8b 16384 0 7143 7144 ### Current system health: 7145 7146 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU C.St. 7147 15:08:25: 1000/1000MHz 0.08 1% 0% 0% 0% 0% 0% 23.0°C 0/12 7148 15:08:25: 2400/1000MHz 0.08 1% 1% 0% 0% 0% 0% 22.8°C 0/12 7149 15:08:26: 2400/1000MHz 0.08 1% 1% 0% 0% 0% 0% 23.0°C 0/12 7150 15:08:26: 2400/1000MHz 0.08 2% 1% 1% 0% 0% 0% 23.0°C 0/12 7151 15:08:26: 2400/1000MHz 0.08 1% 1% 0% 0% 0% 0% 23.0°C 0/12 7152 15:08:28: 2400/2016MHz 0.08 1% 0% 1% 0% 0% 0% 38.3°C 0/12 7153 15:08:29: 2400/2016MHz 0.55 100% 0% 99% 0% 0% 0% 39.9°C 0/12 7154 15:08:30: 2400/2016MHz 0.55 63% 0% 62% 0% 0% 0% 27.5°C 0/12 7155 15:08:30: 2400/2016MHz 0.55 2% 1% 0% 0% 0% 0% 26.5°C 0/12 7156 15:08:30: 2400/2016MHz 0.55 1% 1% 0% 0% 0% 0% 25.4°C 0/12 7157 7158 ### resolv.conf 7159 7160 -rw-r--r-- 1 root root 53 Apr 4 21:27 /etc/resolv.conf 7161 # Generated by NetworkManager 7162 nameserver XXX.XXX.1.1 7163 7164 ### Current sysinfo: 7165 7166 Linux 5.10.21-meson64 (odroidn2) 04/05/2021 _aarch64_ (6 CPU) 7167 7168 avg-cpu: %user %nice %system %iowait %steal %idle 7169 1.40 0.00 0.68 0.07 0.00 97.85 7170 7171 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn 7172 mmcblk0 0.25 6.58 0.00 4660 0 7173 mmcblk0p1 0.20 5.11 0.00 3616 0 7174 mmcblk1 12.86 585.39 20.20 414433 14300 7175 mmcblk1p1 12.70 582.43 20.20 412337 14300 7176 mmcblk1boot1 0.08 0.33 0.00 232 0 7177 mmcblk1boot0 0.08 0.33 0.00 232 0 7178 zram0 0.79 3.15 0.01 2232 4 7179 zram1 0.68 0.62 32.13 440 22744 7180 zram2 0.00 0.00 0.00 0 0 7181 7182 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 7183 r b swpd free buff cache si so bi bo in cs us sy id wa st 7184 0 0 0 2770620 31652 541772 0 0 99 9 114 89 1 1 98 0 0 7185 7186 total used free shared buff/cache available 7187 Mem: 3.5Gi 367Mi 2.6Gi 111Mi 559Mi 2.9Gi 7188 Swap: 1.8Gi 0B 1.8Gi 7189 7190 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 7191 /dev/zram1 zstd 50M 21.1M 2.3M 2.7M 6 /var/log 7192 /dev/zram0 lzo-rle 1.8G 4K 74B 12K 6 [SWAP] 7193 7194 15:08:31 up 11 min, 2 users, load average: 0.55, 0.21, 0.08 7195 7196 [ 1.775695] fuse: init (API version 7.32) 7197 [ 1.776492] integrity: Platform Keyring initialized 7198 [ 1.804290] xor: measuring software checksum speed 7199 [ 1.807124] 8regs : 3476 MB/sec 7200 [ 1.809582] 32regs : 4024 MB/sec 7201 [ 1.812237] arm64_neon : 3719 MB/sec 7202 [ 1.812240] xor: using function: 32regs (4024 MB/sec) 7203 [ 1.812247] Key type asymmetric registered 7204 [ 1.812251] Asymmetric key parser 'x509' registered 7205 [ 1.812285] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) 7206 [ 1.812393] io scheduler mq-deadline registered 7207 [ 1.812397] io scheduler kyber registered 7208 [ 1.812473] io scheduler bfq registered 7209 [ 1.815003] gpio-447 (usb-hub-reset): hogged as output/high 7210 [ 1.818011] EINJ: ACPI disabled. 7211 [ 1.824336] soc soc0: Amlogic Meson G12B (S922X) Revision 29:c (40:2) Detected 7212 [ 1.825741] VCC_3V3: supplied by VDDAO_3V3 7213 [ 1.825775] FLASH_1V8: supplied by VCC_3V3 7214 [ 1.825811] VCC_1V8: supplied by VCC_3V3 7215 [ 1.825849] VDDAO_1V8: supplied by VDDAO_3V3 7216 [ 1.825877] VDDCPU_A: supplied by regulator-dummy 7217 [ 1.826234] VDDCPU_B: supplied by regulator-dummy 7218 [ 1.826945] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled 7219 [ 1.829373] Serial: AMBA driver 7220 [ 1.829666] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart 7221 [ 1.829759] printk: console [ttyAML0] enabled 7222 [ 1.830271] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart 7223 [ 1.835627] loop: module loaded 7224 [ 1.837548] libphy: Fixed MDIO Bus: probed 7225 [ 1.838620] tun: Universal TUN/TAP device driver, 1.6 7226 [ 1.839290] thunder_xcv, ver 1.0 7227 [ 1.839320] thunder_bgx, ver 1.0 7228 [ 1.839349] nicpf, ver 1.0 7229 [ 1.839923] e1000e: Intel(R) PRO/1000 Network Driver 7230 [ 1.839928] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. 7231 [ 1.839978] igb: Intel(R) Gigabit Ethernet Network Driver 7232 [ 1.839982] igb: Copyright (c) 2007-2014 Intel Corporation. 7233 [ 1.840015] igbvf: Intel(R) Gigabit Virtual Function Network Driver 7234 [ 1.840019] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. 7235 [ 1.840147] sky2: driver version 1.30 7236 [ 1.840525] VFIO - User Level meta-driver version: 0.3 7237 [ 1.841909] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 7238 [ 1.841925] ehci-pci: EHCI PCI platform driver 7239 [ 1.841953] ehci-platform: EHCI generic platform driver 7240 [ 1.842083] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 7241 [ 1.842093] ohci-pci: OHCI PCI platform driver 7242 [ 1.842123] ohci-platform: OHCI generic platform driver 7243 [ 1.842536] usbcore: registered new interface driver usb-storage 7244 [ 1.843834] mousedev: PS/2 mouse device common for all mice 7245 [ 1.844288] i2c /dev entries driver 7246 [ 1.849523] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 7247 [ 1.850386] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz 7248 [ 1.851033] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17 7249 [ 1.851595] sdhci: Secure Digital Host Controller Interface driver 7250 [ 1.851601] sdhci: Copyright(c) Pierre Ossman 7251 [ 1.851767] Synopsys Designware Multimedia Card Interface Driver 7252 [ 1.852140] sdhci-pltfm: SDHCI platform and OF driver helper 7253 [ 1.852499] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq 7254 [ 1.852882] ledtrig-cpu: registered to indicate activity on CPUs 7255 [ 1.853148] meson-sm: secure-monitor enabled 7256 [ 1.853570] hid: raw HID events driver (C) Jiri Kosina 7257 [ 1.853669] usbcore: registered new interface driver usbhid 7258 [ 1.853672] usbhid: USB HID core driver 7259 [ 1.854647] NET: Registered protocol family 10 7260 [ 1.854995] Segment Routing with IPv6 7261 [ 1.855022] NET: Registered protocol family 17 7262 [ 1.855058] 8021q: 802.1Q VLAN Support v1.8 7263 [ 1.855078] Key type dns_resolver registered 7264 [ 1.855328] registered taskstats version 1 7265 [ 1.855334] Loading compiled-in X.509 certificates 7266 [ 1.856692] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' 7267 [ 1.858093] zswap: loaded using pool zstd/z3fold 7268 [ 1.858238] Key type ._fscrypt registered 7269 [ 1.858240] Key type .fscrypt registered 7270 [ 1.858242] Key type fscrypt-provisioning registered 7271 [ 1.859256] Btrfs loaded, crc32c=crc32c-generic 7272 [ 1.864389] Key type encrypted registered 7273 [ 1.864400] AppArmor: AppArmor sha1 policy hashing enabled 7274 [ 1.869677] HUB_5V: supplied by 5V 7275 [ 1.869828] USB_PWR_EN: supplied by 5V 7276 [ 1.871272] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 7277 [ 1.871279] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 7278 [ 1.873927] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator 7279 [ 1.873970] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator 7280 [ 1.874053] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM 7281 [ 1.874549] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 7282 [ 1.874559] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 7283 [ 1.874647] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 7284 [ 1.874668] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000 7285 [ 1.874782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 7286 [ 1.874785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 7287 [ 1.874787] usb usb1: Product: xHCI Host Controller 7288 [ 1.874789] usb usb1: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 7289 [ 1.874791] usb usb1: SerialNumber: xhci-hcd.0.auto 7290 [ 1.874952] hub 1-0:1.0: USB hub found 7291 [ 1.874963] hub 1-0:1.0: 2 ports detected 7292 [ 1.875073] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller 7293 [ 1.875077] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 7294 [ 1.875082] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed 7295 [ 1.875100] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. 7296 [ 1.875126] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 7297 [ 1.875129] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 7298 [ 1.875130] usb usb2: Product: xHCI Host Controller 7299 [ 1.875132] usb usb2: Manufacturer: Linux 5.10.21-meson64 xhci-hcd 7300 [ 1.875134] usb usb2: SerialNumber: xhci-hcd.0.auto 7301 [ 1.875250] hub 2-0:1.0: USB hub found 7302 [ 1.875257] hub 2-0:1.0: 1 port detected 7303 [ 1.875482] dwc3-meson-g12a ffe09000.usb: switching to Device Mode 7304 [ 1.876734] meson-gx-mmc ffe05000.sd: Got CD GPIO 7305 [ 1.904168] Freeing unused kernel memory: 3328K 7306 [ 1.943678] Run /init as init process 7307 [ 1.943681] with arguments: 7308 [ 1.943684] /init 7309 [ 1.943685] with environment: 7310 [ 1.943687] HOME=/ 7311 [ 1.943688] TERM=linux 7312 [ 1.943689] hdmimode=custombuilt 7313 [ 1.943690] cvbsmode=576cvbs 7314 [ 1.943692] max_freq_a53=1908 7315 [ 1.943693] max_freq_a73=2208 7316 [ 1.943694] voutmode=hdmi 7317 [ 1.943695] modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 7318 [ 1.943696] disablehpd=false 7319 [ 1.943697] cvbscable= 7320 [ 1.943698] overscan=100 7321 [ 2.047772] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found 7322 [ 2.047778] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found 7323 [ 2.047865] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock 7324 [ 2.048304] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 7325 [ 2.048310] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 7326 [ 2.048313] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported 7327 [ 2.048315] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported 7328 [ 2.048317] meson8b-dwmac ff3f0000.ethernet: COE Type 2 7329 [ 2.048319] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported 7330 [ 2.048320] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported 7331 [ 2.048357] meson8b-dwmac ff3f0000.ethernet: Normal descriptors 7332 [ 2.048359] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled 7333 [ 2.048361] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer 7334 [ 2.048509] libphy: stmmac: probed 7335 [ 2.051551] libphy: mdio_mux: probed 7336 [ 2.070205] meson-vrtc ff8000a8.rtc: registered as rtc1 7337 [ 2.070657] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 7338 [ 2.070880] rtc-pcf8563 1-0051: registered as rtc0 7339 [ 2.072170] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable. 7340 [ 2.072182] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock 7341 [ 2.145543] mmc0: new ultra high speed SDR104 SDXC card at address aaaa 7342 [ 2.146046] mmcblk0: mmc0:aaaa SH64G 59.5 GiB 7343 [ 2.150430] mmc1: new HS200 MMC card at address 0001 7344 [ 2.150775] mmcblk0: p1 7345 [ 2.151198] mmcblk1: mmc1:0001 CJTD4R 58.2 GiB 7346 [ 2.151572] mmcblk1boot0: mmc1:0001 CJTD4R partition 1 4.00 MiB 7347 [ 2.151971] mmcblk1boot1: mmc1:0001 CJTD4R partition 2 4.00 MiB 7348 [ 2.152093] mmcblk1rpmb: mmc1:0001 CJTD4R partition 3 4.00 MiB, chardev (242:0) 7349 [ 2.153452] mmcblk1: p1 7350 [ 2.163614] random: fast init done 7351 [ 2.211772] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd 7352 [ 2.236365] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04 7353 [ 2.236371] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 7354 [ 2.236374] usb 2-1: Product: USB3.1 Hub 7355 [ 2.236376] usb 2-1: Manufacturer: GenesysLogic 7356 [ 2.256053] libphy: mdio_mux: probed 7357 [ 2.259390] hub 2-1:1.0: USB hub found 7358 [ 2.259679] hub 2-1:1.0: 4 ports detected 7359 [ 2.359659] usb 1-1: new high-speed USB device number 2 using xhci-hcd 7360 [ 2.509980] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04 7361 [ 2.509985] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 7362 [ 2.509989] usb 1-1: Product: USB2.1 Hub 7363 [ 2.509993] usb 1-1: Manufacturer: GenesysLogic 7364 [ 2.547356] hub 1-1:1.0: USB hub found 7365 [ 2.547579] hub 1-1:1.0: 4 ports detected 7366 [ 2.923650] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd 7367 [ 3.050656] usb 1-1.1: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00 7368 [ 3.050661] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 7369 [ 3.050664] usb 1-1.1: Product: USB OPTICAL MOUSE 7370 [ 3.093486] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:275D:0BA6.0001/input/input0 7371 [ 3.093702] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.0.auto-1.1/input0 7372 [ 3.195651] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd 7373 [ 3.234735] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) 7374 [ 3.332996] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00 7375 [ 3.333006] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 7376 [ 3.333010] usb 1-1.3: Product: USB Keyboard 7377 [ 3.333013] usb 1-1.3: Manufacturer: Logitech 7378 [ 3.408041] systemd[1]: System time before build time, advancing clock. 7379 [ 3.411728] systemd[1]: Inserted module 'autofs4' 7380 [ 3.416471] input: Logitech USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1 7381 [ 3.429690] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 7382 [ 3.429871] systemd[1]: Detected architecture arm64. 7383 [ 3.457278] systemd[1]: Set hostname to <odroidn2>. 7384 [ 3.476298] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 7385 [ 3.483299] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2 7386 [ 3.539916] input: Logitech USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input3 7387 [ 3.540055] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 7388 [ 3.612625] random: systemd: uninitialized urandom read (16 bytes read) 7389 [ 3.615211] random: systemd: uninitialized urandom read (16 bytes read) 7390 [ 3.615408] systemd[1]: Listening on udev Kernel Socket. 7391 [ 3.615744] random: systemd: uninitialized urandom read (16 bytes read) 7392 [ 3.615916] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. 7393 [ 3.616155] systemd[1]: Listening on udev Control Socket. 7394 [ 3.616278] systemd[1]: Listening on initctl Compatibility Named Pipe. 7395 [ 3.616514] systemd[1]: Listening on Journal Audit Socket. 7396 [ 3.616584] systemd[1]: Reached target Remote File Systems. 7397 [ 3.616663] systemd[1]: Reached target System Time Synchronized. 7398 [ 3.664329] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro 7399 [ 3.884092] zram: Added device: zram0 7400 [ 3.884257] zram: Added device: zram1 7401 [ 3.884381] zram: Added device: zram2 7402 [ 3.915701] pwm-gpio pwmgpio: 1 gpio pwms loaded 7403 [ 3.944938] zram0: detected capacity change from 0 to 1904500736 7404 [ 3.978061] meson-drm ff900000.vpu: Queued 2 outputs on vpu 7405 [ 3.981860] mc: Linux media interface: v0.10 7406 [ 3.983557] meson-drm ff900000.vpu: CVBS Output connector not available 7407 [ 3.989190] videodev: Linux video capture interface: v2.00 7408 [ 4.007364] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. 7409 [ 4.011714] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) 7410 [ 4.012343] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver 7411 [ 4.012570] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi]) 7412 [ 4.012805] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 7413 [ 4.060191] meson-saradc ff809000.adc: supply vref not found, using dummy regulator 7414 [ 4.078183] panfrost ffe40000.gpu: clock rate = 24000000 7415 [ 4.078231] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 7416 [ 4.078752] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0 7417 [ 4.078757] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400 7418 [ 4.078760] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 7419 [ 4.078763] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1 7420 [ 4.093952] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 7421 [ 4.095686] Registered IR keymap rc-odroid 7422 [ 4.108886] IR NEC protocol handler initialized 7423 [ 4.135744] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 7424 [ 4.135823] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter 7425 [ 4.135870] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4 7426 [ 4.136511] meson-ir ff808000.ir: receiver initialized 7427 [ 4.304522] Console: switching to colour frame buffer device 240x67 7428 [ 4.335736] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device 7429 [ 4.369310] axg-sound-card sound: ASoC: no DMI vendor name! 7430 [ 4.979657] Adding 1859860k swap on /dev/zram0. Priority:5 extents:1 across:1859860k SSFS 7431 [ 5.022600] zram1: detected capacity change from 0 to 52428800 7432 [ 7.067679] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 7433 [ 7.067700] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) 7434 [ 8.081399] systemd-journald[1877]: Received request to flush runtime journal from PID 1 7435 [ 10.219838] random: crng init done 7436 [ 10.219850] random: 7 urandom warning(s) missed due to ratelimiting 7437 [ 11.234265] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=42) 7438 [ 11.247426] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found 7439 [ 11.247438] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW 7440 [ 11.247748] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rgmii link mode 7441 [ 11.761947] broken atomic modeset userspace detected, disabling atomic 7442 [ 13.835681] hdmi-audio-codec hdmi-audio-codec.4.auto: Not able to map channels to speakers (-22) 7443 [ 13.835693] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC: error at snd_soc_dai_hw_params on i2s-hifi: -22 7444 [ 13.835698] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-8-playback event failed: -22 7445 [ 33.758786] USB_PWR_EN: disabling 7446 7447 7448 vm.admin_reserve_kbytes = 8192 7449 vm.block_dump = 0 7450 vm.compaction_proactiveness = 20 7451 vm.compact_unevictable_allowed = 1 7452 vm.dirty_background_bytes = 0 7453 vm.dirty_background_ratio = 10 7454 vm.dirty_bytes = 0 7455 vm.dirty_expire_centisecs = 3000 7456 vm.dirty_ratio = 20 7457 vm.dirtytime_expire_seconds = 43200 7458 vm.dirty_writeback_centisecs = 500 7459 vm.extfrag_threshold = 500 7460 vm.hugetlb_shm_group = 0 7461 vm.laptop_mode = 0 7462 vm.legacy_va_layout = 0 7463 vm.lowmem_reserve_ratio = 256 256 32 0 7464 vm.max_map_count = 65530 7465 vm.memory_failure_early_kill = 0 7466 vm.memory_failure_recovery = 1 7467 vm.min_free_kbytes = 45056 7468 vm.min_slab_ratio = 5 7469 vm.min_unmapped_ratio = 1 7470 vm.mmap_min_addr = 4096 7471 vm.mmap_rnd_bits = 18 7472 vm.mmap_rnd_compat_bits = 11 7473 vm.nr_hugepages = 0 7474 vm.nr_hugepages_mempolicy = 0 7475 vm.nr_overcommit_hugepages = 0 7476 vm.numa_stat = 1 7477 vm.numa_zonelist_order = Node 7478 vm.oom_dump_tasks = 1 7479 vm.oom_kill_allocating_task = 0 7480 vm.overcommit_kbytes = 0 7481 vm.overcommit_memory = 0 7482 vm.overcommit_ratio = 50 7483 vm.page-cluster = 0 7484 vm.page_lock_unfairness = 5 7485 vm.panic_on_oom = 0 7486 vm.percpu_pagelist_fraction = 0 7487 vm.stat_interval = 1 7488 vm.swappiness = 100 7489 vm.user_reserve_kbytes = 114979 7490 vm.vfs_cache_pressure = 100 7491 vm.watermark_boost_factor = 15000 7492 vm.watermark_scale_factor = 10 7493 vm.zone_reclaim_mode = 0 7494 7495 ### interrupts: 7496 CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 7497 9: 0 0 0 0 0 0 GICv2 25 Level vgic 7498 11: 15660 15077 31213 34430 276211 26408 GICv2 30 Level arch_timer 7499 12: 0 0 0 0 0 0 GICv2 27 Level kvm guest vtimer 7500 14: 0 0 0 0 0 0 GICv2 40 Level eth0 7501 15: 1548 0 0 0 0 0 GICv2 89 Edge dw_hdmi_top_irq, ff600000.hdmi-tx 7502 21: 204 0 0 0 0 0 GICv2 184 Edge 7503 25: 1 0 0 0 0 0 GICv2 225 Edge ttyAML0 7504 26: 0 0 0 0 0 0 GICv2 228 Edge ff808000.ir 7505 27: 7 0 0 0 0 0 GICv2 232 Edge ff809000.adc 7506 28: 0 0 0 0 0 0 GICv2 76 Edge vdec 7507 29: 0 0 0 0 0 0 GICv2 64 Edge esparserirq 7508 30: 2889 0 0 0 0 0 GICv2 35 Edge meson 7509 31: 11 0 0 0 0 0 GICv2 71 Edge ffd1c000.i2c 7510 32: 0 0 0 0 0 0 GICv2 247 Edge ffd1d000.i2c 7511 34: 1108 0 0 0 0 0 GICv2 222 Edge ffe05000.sd 7512 35: 5624 13564 0 0 0 0 GICv2 223 Edge ffe07000.mmc 7513 36: 1 0 0 0 0 0 GICv2 48 Level ffe09000.usb 7514 37: 0 0 0 0 0 0 GICv2 194 Level panfrost-job 7515 38: 0 0 0 0 0 0 GICv2 193 Level panfrost-mmu 7516 39: 12 0 0 0 0 0 GICv2 192 Level panfrost-gpu 7517 40: 0 0 0 0 0 0 GICv2 63 Level ff400000.usb, ff400000.usb 7518 41: 150 0 863 0 0 0 GICv2 62 Level xhci-hcd:usb1 7519 42: 0 0 0 0 0 0 meson-gpio-irqchip 26 Level 0.0:00 7520 IPI0: 1261 2748 5424 6328 6644 5635 Rescheduling interrupts 7521 IPI1: 3955 3553 4969 6435 3719 3902 Function call interrupts 7522 IPI2: 0 0 0 0 0 0 CPU stop interrupts 7523 IPI3: 0 0 0 0 0 0 CPU stop (for crash dump) interrupts 7524 IPI4: 0 0 0 0 0 0 Timer broadcast interrupts 7525 IPI5: 726 487 1408 842 488 584 IRQ work interrupts 7526 IPI6: 0 0 0 0 0 0 CPU wake-up interrupts 7527 Err: 0 Please upload the whole output above to an online pasteboard service and provide the URL in the forum where you have been asked for this.
tparys Posted April 16, 2021 Posted April 16, 2021 Unless someone else can confirm this behavior on another N2, you might just have a bad power supply. https://forum.armbian.com/forum/31-sd-card-and-psu-issues/ It may also be worth trying the HardKernel images and see if you can reproduce that fault there, to narrow down whether it's a fault with the image, or with your hardware. Without further information, there's not much here to go on.
Solution Arne Hübner Posted April 18, 2021 Author Solution Posted April 18, 2021 The problem woz the PSU. Since I got turned it on it rans constantly.... 2 hours until I shutdown... something was wrong with my power socket.. the problem did not remains bcz I plug it out and in an another socket in. *eg*
