alexparser Posted August 8, 2016 Posted August 8, 2016 Hi all! I'm try connect the USB DAC Audeze Deckard to Lime2 (A20) via USB 2.0 Installed OS is Armbian 5.14 Ubuntu I can see this DAC in system and can to start playback, but absolutely no sound.What is the problem and how to solve? root@lime2:~# lsusb Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 20b1:3054 XMOS Ltd Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@lime2:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 1: Audio [Audeze Audio], device 0: USB Audio [USB Audio] Subdevices: 0/1 Subdevice #0: subdevice #0 mpd.conf follow_outside_symlinks "yes" follow_inside_symlinks "yes" db_file "/var/lib/mpd/mpd.db" log_file "/var/log/mpd.log" pid_file "/var/run/mpd/pid" music_directory "/media" playlist_directory "/var/lib/mpd/playlists" state_file "/var/lib/mpd/mpdstate" user "mpd" bind_to_address "any" port "6600" log_level "default" volume_normalization "no" audio_buffer_size "2048" buffer_before_play "20%" filesystem_charset "UTF-8" id3v1_encoding "UTF-8" gapless_mp3_playback "yes" auto_update "no" mixer_type "disabled" group "audio" max_connections "20" restore_paused "yes" decoder { plugin "ffmpeg" enabled "no" } input { plugin "curl" } audio_output { enabled "yes" type "alsa" name "USB DAC" mixer_control "Digital" #mixer_device "hw:0" mixer_index "0" device "hw:1,0" auto_resample "no" auto_channels "no" }
zador.blood.stained Posted August 9, 2016 Posted August 9, 2016 On 8/8/2016 at 9:45 PM, alexparser said: log_file "/var/log/mpd.log" Is there anything that looks like audio device errors?
alexparser Posted August 9, 2016 Author Posted August 9, 2016 On 8/9/2016 at 9:22 AM, zador.blood.stained said: Is there anything that looks like audio device errors? No errors in mpd.log I see only records like "player: played patch/song name..." I'll test with other DAC
zador.blood.stained Posted August 9, 2016 Posted August 9, 2016 Also please check alsamixer in case sound is disabled or muted by default.
