Paweł Janowski Posted August 14, 2016 Posted August 14, 2016 hello, when i initial start the Armbian @ Orange Pi PC I was prompted for new user. I put new username as 'ch0mik' but the Armbian make a user and group 'chmik' - without zero. Im ham radio operator with callsing sq7mru and i want to make a user with ma correct callsign (alphanumeric username) Regards Pawel
tkaiser Posted August 14, 2016 Posted August 14, 2016 when i initial start the Armbian @ Orange Pi PC I was prompted for new user. I put new username as 'ch0mik' but the Armbian make a user and group 'chmik' - without zero. This has been fixed in the meantime and digits can be used with new OS images (not yet released for NanoPi M1). In the meantime simply create a new user starting with username=ch0mik and then following the steps that happen normally (adduser + adding to necessary groups): https://github.com/igorpecovnik/lib/blob/master/scripts/check_first_login.sh#L8-L12 Alternatively it might work to upgrade your installation and then let the automatic user creation happen again: sudo su - apt-get update ; apt-get upgrade ; touch /root/.not_logged_in_yet ; reboot (not tested)
Paweł Janowski Posted August 14, 2016 Author Posted August 14, 2016 This has been fixed in the meantime and digits can be used with new OS images (not yet released for NanoPi M1). In the meantime simply create a new user starting with username=ch0mik and then following the steps that happen normally (adduser + adding to necessary groups): https://github.com/igorpecovnik/lib/blob/master/scripts/check_first_login.sh#L8-L12 Alternatively it might work to upgrade your installation and then let the automatic user creation happen again: sudo su - apt-get update ; apt-get upgrade ; touch /root/.not_logged_in_yet ; reboot (not tested) ThX : it works !
