PEW Posted May 13, 2021 Posted May 13, 2021 @gprovost I described last year a process to upgrade from omv4 to omv5. (which is doable). I also did a clean install of omv5 after i was having random reboot issues using the newer kernel5. I ended up using the clean built and reconfiguring all the services and dockers. I do not recommend using the newer kernel if you are using dockers. This is where I would have random system reboots. OMV4 was very stable but since omv4 was eol. I decided to upgrade or do a clean install. I did both with the same random reboots using the newer kernel 5. Once i switched back to the older kernel with my config, I was not having the random reboot issues. I understand this would be hard to replica because everyone has different configs. I am just trying to help anyone else that would be in this situation. Thx 1 Quote
