i have orange pi mini 2 board that fails to go past uboot. i used buster and focal images from here. here is the uboot snippet:
U-Boot SPL 2021.04-armbian (May 06 2021 - 18:16:10 +0000)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2021.04-armbian (May 06 2021 - 18:16:10 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi 2
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... Card did not respond to voltage select! : -110
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1b000:
nothing happens after this. i have tried with different sd cards with same results.  so i have a few quesions: is the board damaged? or i have used the wrong image or is there  some wrong configurations as the image and boards aren't exactly identical.
Board: Orangepi Zero+ 2 H3
