TCB13 Posted May 23, 2021 Posted May 23, 2021 Hello, I'm trying to find out how to use a 1.5 Inch RGB OLED Display that uses the SSD1351 IC on a NanoPi M4 however I don't seem to be able to turn on the SPI. I used armbian-config to enable the gpio overlay: [ ] dwc3-0-host [ ] i2c7 [ ] i2c8 [*] pcie-gen2 [ ] rk3328-opp-1.4ghz [ ] rk3328-opp-1.5ghz [ ] rk3399-opp-2ghz [ ] spi-jedec-nor [*] spi-spidev [ ] uart4 [ ] w1-gpio And the SPI isn't showing up on /dev: ls /dev/spi* ls: cannot access '/dev/spi*': No such file or directory Wasn't this enough to be able to use the SPI1 on this board? SBC: NanoPi M4V2 System: 5.10.35-rockchip64 #21.05.1 SMP PREEMPT Fri May 7 13:53:11 UTC 2021 aarch64 GNU/Linux Display: https://www.ebay.com/itm/203101646517 Datasheet: https://www.waveshare.com/w/upload/5/5b/1.5inch_RGB_OLED_Module_User_Manual_EN.pdf Thank you.
tparys Posted May 25, 2021 Posted May 25, 2021 So the M4V2 is a supported board. that the SPI isn't working is probably worth a post by itself in the Rockchip 3399 Subforum. At a glance, I tried turning on the SPI on my M4V2 and didn't see any spidev devices pop up, but might need to pull out the serial console to see if u-boot is throwing any warnings about the overlay. Taking a look at the overlay, I'm not sure it looks correct, as it looks like even if it applies the SPI channel is disabled. fragment@4 { target = <0xffffffff>; __overlay__ { #address-cells = <0x01>; #size-cells = <0x00>; spidev { compatible = "spidev"; status = "disabled"; reg = <0x00>; spi-max-frequency = <0x989680>; }; }; }; 1
TCB13 Posted May 25, 2021 Author Posted May 25, 2021 7 hours ago, tparys said: So the M4V2 is a supported board. that the SPI isn't working is probably worth a post by itself in the Rockchip 3399 Subforum. At a glance, I tried turning on the SPI on my M4V2 and didn't see any spidev devices pop up, but might need to pull out the serial console to see if u-boot is throwing any warnings about the overlay. Taking a look at the overlay, I'm not sure it looks correct, as it looks like even if it applies the SPI channel is disabled. fragment@4 { target = <0xffffffff>; __overlay__ { #address-cells = <0x01>; #size-cells = <0x00>; spidev { compatible = "spidev"; status = "disabled"; reg = <0x00>; spi-max-frequency = <0x989680>; }; }; }; Thank you for your feedback!
TCB13 Posted September 17, 2021 Author Posted September 17, 2021 @piter75, On 6/6/2021 at 9:21 AM, piter75 said: @TCB13 I am a bit late to the party but I figured it may still be needed ;-) spi-spidev is a special / dynamic overlay. Besides enabling it you need to also configure it and armbian-config cannot currently do that. For configuration options have a look here: https://github.com/armbian/build/blob/master/patch/kernel/archive/rockchip64-5.10/general-rockchip-overlays.patch#L98-L126 You can also consult the local README file located in: /boot/dtb/rockchip/overlay/README.rockchip-overlays Your comment was crucial to fix my "issue". I enabled the overlay and then as described on the file edited `/boot/armbianEnv.txt` in order to include: param_spidev_spi_bus=1 param_spidev_max_freq=100000000 Now the SPI shows up: ~# ls -la /dev/spi* crw------- 1 root root 153, 0 Sep 16 18:51 /dev/spidev1.0 Also passes the spidev_test (https://raw.githubusercontent.com/torvalds/linux/master/tools/spi/spidev_test.c) ~# ./spidev_test spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 kHz) (Had to adjust the path) Thank you for the tip!
TCB13 Posted September 17, 2021 Author Posted September 17, 2021 Now unfortunately luma-oled seems to be yet another problem. I wired up my LCD as: MOSI > GPIO1_A7 > SPI1_RXD > M4 Pin 21 > LCD DIN Pin (blue) SCK > GPIO1_B1 > SPI1_CLK > M4 Pin 23 > LCD CLK Pin (yellow) CS > GPIO1_B2 > SPI1_CSn0 > M4 Pin 24 > LCD CS Pin (orange) DC > GPIO1_A0(3V) > M4 Pin 7 > LCD DC Pin (green) RST > GPIO1_A1(3V) > M4 Pin 11 > LCD RST Pin (white) Display: https://www.ebay.com/itm/203101646517 Datasheet: https://www.waveshare.com/w/upload/5/5b/1.5inch_RGB_OLED_Module_User_Manual_EN.pdf From my understanding I had to get GPIO1_A0 and GPIO1_A1 in the system so the lib could use them. According to this https://hev.cc/2927.html GPIO mapping I tried: ls -la /dev/spi* crw------- 1 root root 153, 0 Sep 16 18:51 /dev/spidev1.0 echo 32 > /sys/class/gpio/export echo 33 > /sys/class/gpio/export ls -la /sys/class/gpio/ total 0 drwxr-xr-x 2 root root 0 Jan 18 2013 . drwxr-xr-x 76 root root 0 Jan 18 2013 .. --w--w---- 1 root dialout 4096 Sep 16 20:51 export lrwxrwxrwx 1 root root 0 Sep 16 20:50 gpio32 -> ../../devices/platform/pinctrl/gpiochip1/gpio/gpio32 lrwxrwxrwx 1 root root 0 Sep 16 20:50 gpio33 -> ../../devices/platform/pinctrl/gpiochip1/gpio/gpio33 lrwxrwxrwx 1 root root 0 Jan 18 2013 gpiochip0 -> ../../devices/platform/pinctrl/gpio/gpiochip0 lrwxrwxrwx 1 root root 0 Jan 18 2013 gpiochip128 -> ../../devices/platform/pinctrl/gpio/gpiochip128 lrwxrwxrwx 1 root root 0 Jan 18 2013 gpiochip32 -> ../../devices/platform/pinctrl/gpio/gpiochip32 lrwxrwxrwx 1 root root 0 Jan 18 2013 gpiochip64 -> ../../devices/platform/pinctrl/gpio/gpiochip64 lrwxrwxrwx 1 root root 0 Jan 18 2013 gpiochip96 -> ../../devices/platform/pinctrl/gpio/gpiochip96 --w--w---- 1 root dialout 4096 Sep 16 19:19 unexport Now I tried the luma-oled examples (running as root): python3 3d_box.py --display ssd1351 --interface spi --spi-port 0 --spi-device 1 --gpio-reset 33 --gpio-data-command 32 --width 128 --height 128 usage: 3d_box.py >(....) 3d_box.py: error: GPIO access not available I'm not even sure if this part "--gpio-reset 33 --gpio-data-command 32" is correct. I've tried both the virtual pin number and the hardware number without luck. Also tried to install https://github.com/friendlyarm/RPi.GPIO_NP without much luck: apt-get update apt-get install python-dev git clone https://github.com/friendlyarm/RPi.GPIO_NP cd RPi.GPIO_NP python3 setup.py install python3 setup.py install python3 luma.examples/examples/3d_box.py --display=ssd1351 --interface=spi --width=128 --height=128 --spi-bus-speed=16000000 --bgr --spi-device=1 --spi-port=0 --gpio-reset=33 --gpio-data-command=32 --gpio RPi.GPIO Traceback (most recent call last): (...) RuntimeError: It is not NanoPi based board.
TCB13 Posted September 17, 2021 Author Posted September 17, 2021 Following my lack of knowledge of the subject I found out another GPIO implementation that seems to have mappings for the NanoPi M4 called OPi.GPIO. Rewired the LCD, I was unsure about the GPIO pin I picked for the DC pin: MOSI > GPIO1_A7 > SPI1_RXD > M4 Pin 21 > LCD DIN Pin (blue) SCK > GPIO1_B1 > SPI1_CLK > M4 Pin 23 > LCD CLK Pin (yellow) CS > GPIO1_B2 > SPI1_CSn0 > M4 Pin 24 > LCD CS Pin (orange) RST > GPIO1_A1(3V) > M4 Pin 11 > LCD RST Pin (white) DC > GPIO1_A3(3V) > M4 Pin 13 > LCD DC Pin (green) Installed and run the thing without much success: pip3 install --upgrade OPi.GPIO ls /dev/spi* /dev/spidev1.0 python3 luma.examples/examples/3d_box.py \ --display=ssd1351 \ --interface=spi \ --width=128 --height=128 \ --spi-bus-speed=16000000 \ --bgr \ --spi-device=1 --spi-port=0 \ --gpio-reset=35 \ --gpio-data-command=33 \ --gpio OPi.GPIO \ --gpio-mode nanopi.m4.BOARD Traceback (most recent call last): File "luma.examples/examples/3d_box.py", line 129, in <module> device = get_device() File "/root/luma.examples/examples/demo_opts.py", line 61, in get_device device = cmdline.create_device(args) File "/usr/local/lib/python3.7/dist-packages/luma/core/cmdline.py", line 246, in create_device device = Device(serial_interface=interface(), **params) File "/usr/local/lib/python3.7/dist-packages/luma/core/cmdline.py", line 161, in spi gpio=self.gpio or GPIO) File "/usr/local/lib/python3.7/dist-packages/luma/core/interface/serial.py", line 299, in __init__ bitbang.__init__(self, gpio, transfer_size, reset_hold_time, reset_release_time, DC=gpio_DC, RST=gpio_RST) File "/usr/local/lib/python3.7/dist-packages/luma/core/interface/serial.py", line 187, in __init__ self._DC = self._configure(kwargs.get("DC")) File "/usr/local/lib/python3.7/dist-packages/luma/core/interface/serial.py", line 200, in _configure self._gpio.setup(pin, self._gpio.OUT) File "/usr/local/lib/python3.7/dist-packages/OPi/GPIO.py", line 470, in setup pin = get_gpio_pin(_mode, channel) File "/usr/local/lib/python3.7/dist-packages/OPi/pin_mappings.py", line 80, in get_gpio_pin return _pin_map[mode][channel] KeyError: 33 From what I understand of https://github.com/rm-hull/OPi.GPIO/blob/master/nanopi/m4.py my physical pin 11 maps to GPIO 33 and physical pin 13 to GPIO 35. Is this even correct? Either way it still fails.
Solution TCB13 Posted September 18, 2021 Author Solution Posted September 18, 2021 I finally managed to get this work. Things I was doing wrong: Not using the OPi.GPIO replacement library - others aren't compatible with the NanoPi M4; DIN LCD pin was connected to the SBC RXD instead of TXD; Passed wrong pin numbers to the libraries (should be the real physical pins numers); Mistaking SPI port with device... Here the full guide on how to it properly. Start by installing: apt-get install python3 python3-pip python3-pil libjpeg-dev zlib1g-dev libfreetype6-dev liblcms2-dev libopenjp2-7 libtiff5 -y pip3 install luma.oled apt-get remove python3-rpi.gpio rpi.gpio-common pip3 install --upgrade OPi.GPIO Wire up your LCD as: MISO > GPIO1_B0 > SPI1_TXD > 19 > LCD DIN | Blue SCK > GPIO1_B1 > SPI1_CLK > 23 > LCD CLK | Yellow CS > GPIO1_B2 > SPI1_CSn0 > 24 > LCD CS | Orange RST > GPIO1_A1(3V) > M4 Pin 11 > LCD RST Pin | White DC > GPIO1_A3(3V) > M4 Pin 13 > LCD DC Pin | Green Download an run an example: git clone https://github.com/rm-hull/luma.examples.git python3 luma.examples/examplebounce.py --display=ssd1351 \ --interface=spi \ --width=128 --height=128 \ --spi-bus-speed=50000000 \ --spi-device=0 \ --spi-port=1 \ --gpio-reset=11 \ --gpio-data-command=13 \ --gpio OPi.GPIO \ --gpio-mode nanopi.m4.BOARD And you should get something like this: It seems to be able to drive the display up to around 45fps without noises like I've experienced before in an Arduino. Enjoy.
