I compiled mali kernel driver with debug settings, and now test application crashes the kernel on Opi+2E (on purpose, due to failed ASSERT) and works fine on OPi PC
Loading mali on Opi+2E:
 Mali<2>:
 Mali<2>: Inserting Mali v14 device driver.
 Mali<2>: Compiled: Aug 22 2016, time: 20:25:42.
 Mali<2>: Driver revision:
 mali clk: 252 MHz
 Mali<2>: Memory system initializing
 Mali<2>: Mali OS memory allocator created with max allocation size of 0xC000000 bytes, cpu_usage_adjust 0x40000000
 Mali<2>: Mali PMU: Creating Mali PMU core
 Mali<4>: Mali PMU: Power mask is 0x0000000F (2 + 1)
 Mali<6>: register_write for core Mali-400 PMU, relative addr=0x000C, val=0x00000000
 mali clk: 252 MHz
 Mali<3>: Mali PM: Setting GPU power mode to MALI_POWER_MODE_ON
 Mali<4>: Mali PM: Getting device PM reference (=> requesting MALI_POWER_MODE_ON)
 Mali<3>: mali_runtime_resume() called
 Mali<3>: Mali PM: OS runtime resumed
 Mali<3>: group: POWER ON
 Mali PM: Always on scheme; Changing Mali GPU power state from MALI_PM_LEVEL_1_ON to: MALI_PM_LEVEL_1_ON
 Mali<2>: Mali PP: Creating Mali PP core: Mali-400 PP0
 Mali<2>: Mali PP: Base address of PP core: 0x1c48000
 Mali<5>: Mali group: Group lock taken 0xEE52B580
 Mali<4>: Mali PP: Reset of core Mali-400 PP0
 Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000000
 Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001000
 Mali<6>: register_write for core Mali-400 PP0, relative addr=0x100C, val=0x00000080
 Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00001000
 Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001FFF
 Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000F3D
 Mali<5>: Mali group: Releasing group lock 0xEE52B580
 Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1000, val=0xCD070101
 Mali<2>: Found Mali GPU Mali-400 MP r1p1
 Mali<3>: Page table virt: 0xf0f47000 = dma_alloc_coherent(size:262144, phys:0xee71dda4, )
 Mali<5>: os_allocator_allocate_page_table_block: Allocation of order 6 succeeded
 Mali<3>: New page table cache expansion, 64 pages in new cache allocation
 Mali<4>: Page table allocated: VA=0xF0F47000, MaliPA=0x70D15000
 Mali<6>: Partial page table allocation found, using page offset 1
 Mali<4>: Page table allocated for VA=0xF0F48000, MaliPA=0x70D16000
 Mali<6>: Partial page table allocation found, using page offset 2
 Mali<4>: Page table allocated for VA=0xF0F49000, MaliPA=0x70D17000
 Mali<6>: Partial page table allocation found, using page offset 3
 Mali<4>: Page table allocated for VA=0xF0F4A000, MaliPA=0x70D18000
 Mali<3>: Found L2 cache Mali-400 L2 cache, starting new cluster
 Mali<2>: Mali L2 cache: Creating Mali L2 cache: Mali-400 L2 cache
 Mali<6>: register_read for core Mali-400 L2 cache, relative addr=0x0008, val=0x00000000
 Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0010, val=0x00000001
 Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x001C, val=0x00000003
 Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0018, val=0x0000001C
 Mali<3>: Created cluster object
 Mali<3>: Starting new group for MMU Mali-400 MMU for GP
 Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for GP
 Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000018
 Mali<4>: MMU stall is implicit when Paging is not enebled.
 Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for GP
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0xCAFEBABE
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000006
 Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0000, val=0x00000000
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x001C, val=0x00000003
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x70D15000
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000000
 Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000003
 Mali<2>: Mali GP: Creating Mali GP core: Mali-400 GP
 Mali<5>: Mali group: Group lock taken 0xEE52B3C0
 Mali<4>: Mali GP: Reset of core Mali-400 GP
 Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00000000
 Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00080000
 Mali<6>: register_write for core Mali-400 GP, relative addr=0x0020, val=0x00000400
 Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00000000
 Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00080000
 Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00787FFF
 Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00706E67
 Mali<5>: Mali group: Releasing group lock 0xEE52B3C0
 Mali<4>: Mali GP: set global gp core from 0x00000000 to 0xEE52B340
 Mali<3>: Adding GP Mali-400 GP to group
 Mali<3>: Starting new group for MMU Mali-400 MMU for PP0
 Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for PP0
 Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000018
 Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP0
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0xCAFEBABE
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000006
 Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x00000000
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x001C, val=0x00000003
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x70D15000
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000000
 Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000003
 Mali<5>: Mali group: Group lock taken 0xEE52B240
 Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00000000
 Mali<5>: Mali group: Releasing group lock 0xEE52B240
 Mali<3>: Adding PP Mali-400 PP0 to group
 Mali<3>: Starting new group for MMU Mali-400 MMU for PP1
 Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for PP1
 Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000018
 Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP1
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0xCAFEBABE
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000006
 Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x00000000
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x001C, val=0x00000003
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x70D15000
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000000
 Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000003
 Mali<2>: Mali PP: Creating Mali PP core: Mali-400 PP1
 Mali<2>: Mali PP: Base address of PP core: 0x1c4a000
 Mali<5>: Mali group: Group lock taken 0xEE65EF80
 Mali<4>: Mali PP: Reset of core Mali-400 PP1
 Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000000
 Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001000
 Mali<6>: register_write for core Mali-400 PP1, relative addr=0x100C, val=0x00000080
 Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00000000
 Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00001000
 Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001FFF
 Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000F3D
 Mali<5>: Mali group: Releasing group lock 0xEE65EF80
 Mali<3>: Adding PP Mali-400 PP1 to group
 Mali<6>: register_read for core Mali-400 GP, relative addr=0x006C, val=0x0B070101
 Mali<4>: Mali PM: Dynamic scheme; Changing Mali GPU power state from MALI_PM_LEVEL_1_ON to: MALI_PM_LEVEL_2_STANDBY
 Mali: Mali device driver loaded
 Mali<4>: Mali PM: Dynamic scheme; Changing Mali GPU power state from MALI_PM_LEVEL_2_STANDBY to: MALI_PM_LEVEL_3_LIGHT_SLEEP
 Mali<3>: group: POWER OFF
 Mali<3>: mali_runtime_suspend() called
 Mali<2>: Mali PM: OS runtime suspended
Loading Mali on OPi PC:
 Mali<2>:
 mali clk: 252 MHz
 mali clk: 252 MHz
 Mali<4>: Mali PM: Always on scheme; Changing Mali GPU power state from MALI_PM_LEVEL_1_ON to: MALI_PM_LEVEL_1_ON
 Mali<5>: Mali group: Group lock taken 0xED5C8B40
 Mali<5>: Mali group: Releasing group lock 0xED5C8B40
 Mali<3>: Page table virt: 0xd0d14000 = dma_alloc_coherent(size:262144, phys:0xed413da4, )
 Mali<4>: Page table allocated: VA=0xD0D14000, MaliPA=0x10D14000
 Mali<4>: Page table allocated for VA=0xD0D15000, MaliPA=0x10D15000
 Mali<4>: Page table allocated for VA=0xD0D16000, MaliPA=0x10D16000
 Mali<4>: Page table allocated for VA=0xD0D17000, MaliPA=0x10D17000
 Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x10D14000
 Mali<5>: Mali group: Group lock taken 0xED5C8900
 Mali<5>: Mali group: Releasing group lock 0xED5C8900
 Mali<4>: Mali GP: set global gp core from 0x00000000 to 0xED5C8C80
 Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x10D14000
 Mali<5>: Mali group: Group lock taken 0xED5C8340
 Mali<5>: Mali group: Releasing group lock 0xED5C8340
 Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x10D14000
 Mali<5>: Mali group: Group lock taken 0xED5E2B80
 Mali<5>: Mali group: Releasing group lock 0xED5E2B80
Edit: Full log of loading mali kernel module (compiled with debug messages enabled) and running test/test:
[ 1815.555203] Mali<2>:
[ 1815.557784] Mali<2>: Inserting Mali v14 device driver.
[ 1815.563761] Mali<2>: Compiled: Aug 22 2016, time: 20:25:42.
[ 1815.570098] Mali<2>: Driver revision:
[ 1815.574993] mali clk: 252 MHz
[ 1815.578342] Mali<2>: Memory system initializing
[ 1815.583587] Mali<2>: Mali OS memory allocator created with max allocation size of 0xC000000 bytes, cpu_usage_adjust 0x40000000
[ 1815.596388] Mali<2>: Mali PMU: Creating Mali PMU core
[ 1815.602029] Mali<4>: Mali PMU: Power mask is 0x0000000F (2 + 1)
[ 1815.608622] Mali<6>: register_write for core Mali-400 PMU, relative addr=0x000C, val=0x00000000
[ 1815.618480] mali clk: 252 MHz
[ 1815.621802] Mali<3>: Mali PM: Setting GPU power mode to MALI_POWER_MODE_ON
[ 1815.629435] Mali<4>: Mali PM: Getting device PM reference (=> requesting MALI_POWER_MODE_ON)
[ 1815.638845] Mali<3>: mali_runtime_resume() called
[ 1815.644091] Mali<3>: Mali PM: OS runtime resumed
[ 1815.649218] Mali<3>: group: POWER ON
[ 1815.653214] Mali<4>: Mali PM: Always on scheme; Changing Mali GPU power state from MALI_PM_LEVEL_1_ON to: MALI_PM_LEVEL_1_ON
[ 1815.665695] Mali<2>: Mali PP: Creating Mali PP core: Mali-400 PP0
[ 1815.672484] Mali<2>: Mali PP: Base address of PP core: 0x1c48000
[ 1815.679164] Mali<5>: Mali group: Group lock taken 0xED463DC0
[ 1815.682473] Mali<4>: Mali PP: Reset of core Mali-400 PP0
[ 1815.682473] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000000
[ 1815.682473] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001000
[ 1815.682473] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x100C, val=0x00000080
[ 1815.682473] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00001000
[ 1815.682473] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001FFF
[ 1815.682473] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000F3D
[ 1815.682473] Mali<5>: Mali group: Releasing group lock 0xED463DC0
[ 1815.755926] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1000, val=0xCD070101
[ 1815.765547] Mali<2>: Found Mali GPU Mali-400 MP r1p1
[ 1815.771973] Mali<3>: Page table virt: 0xf219c000 = dma_alloc_coherent(size:262144, phys:0xee3a9da4, )
[ 1815.782259] Mali<5>: os_allocator_allocate_page_table_block: Allocation of order 6 succeeded
[ 1815.791651] Mali<3>: New page table cache expansion, 64 pages in new cache allocation
[ 1815.800381] Mali<4>: Page table allocated: VA=0xF219C000, MaliPA=0x70D15000
[ 1815.808138] Mali<6>: Partial page table allocation found, using page offset 1
[ 1815.816087] Mali<4>: Page table allocated for VA=0xF219D000, MaliPA=0x70D16000
[ 1815.824125] Mali<6>: Partial page table allocation found, using page offset 2
[ 1815.832066] Mali<4>: Page table allocated for VA=0xF219E000, MaliPA=0x70D17000
[ 1815.840106] Mali<6>: Partial page table allocation found, using page offset 3
[ 1815.848025] Mali<4>: Page table allocated for VA=0xF219F000, MaliPA=0x70D18000
[ 1815.856144] Mali<3>: Found L2 cache Mali-400 L2 cache, starting new cluster
[ 1815.863897] Mali<2>: Mali L2 cache: Creating Mali L2 cache: Mali-400 L2 cache
[ 1815.871840] Mali<6>: register_read for core Mali-400 L2 cache, relative addr=0x0008, val=0x00000000
[ 1815.881902] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0010, val=0x00000001
[ 1815.892064] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x001C, val=0x00000003
[ 1815.902223] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0018, val=0x0000001C
[ 1815.912384] Mali<3>: Created cluster object
[ 1815.917029] Mali<3>: Starting new group for MMU Mali-400 MMU for GP
[ 1815.924009] Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for GP
[ 1815.931184] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000018
[ 1815.941586] Mali<4>: MMU stall is implicit when Paging is not enebled.
[ 1815.948832] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for GP
[ 1815.956391] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0xCAFEBABE
[ 1815.966744] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000006
[ 1815.977092] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0000, val=0x00000000
[ 1815.987347] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x001C, val=0x00000003
[ 1815.997696] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x70D15000
[ 1816.008050] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000000
[ 1816.018421] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
[ 1816.028687] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
[ 1816.038940] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000003
[ 1816.049310] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
[ 1816.059602] Mali<2>: Mali GP: Creating Mali GP core: Mali-400 GP
[ 1816.066310] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1816.071938] Mali<4>: Mali GP: Reset of core Mali-400 GP
[ 1816.071938] Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00000000
[ 1816.071938] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00080000
[ 1816.071938] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0020, val=0x00000400
[ 1816.071938] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00000000
[ 1816.071938] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00080000
[ 1816.071938] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00787FFF
[ 1816.071938] Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00706E67
[ 1816.071938] Mali<5>: Mali group: Releasing group lock 0xED463D80
[ 1816.151778] Mali<4>: Mali GP: set global gp core from 0x00000000 to 0xED463BC0
[ 1816.159794] Mali<3>: Adding GP Mali-400 GP to group
[ 1816.165232] Mali<3>: Starting new group for MMU Mali-400 MMU for PP0
[ 1816.172300] Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for PP0
[ 1816.179552] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000018
[ 1816.189902] Mali<4>: MMU stall is implicit when Paging is not enebled.
[ 1816.197166] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP0
[ 1816.204813] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0xCAFEBABE
[ 1816.215257] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000006
[ 1816.225700] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x00000000
[ 1816.236048] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x001C, val=0x00000003
[ 1816.246494] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x70D15000
[ 1816.256938] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000000
[ 1816.267383] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
[ 1816.277729] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
[ 1816.288079] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000003
[ 1816.298523] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
[ 1816.308888] Mali<2>: Mali PP: Creating Mali PP core: Mali-400 PP0
[ 1816.315671] Mali<2>: Mali PP: Base address of PP core: 0x1c48000
[ 1816.322365] Mali<5>: Mali group: Group lock taken 0xED463D00
[ 1816.328644] Mali<4>: Mali PP: Reset of core Mali-400 PP0
[ 1816.332344] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000000
[ 1816.332344] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001000
[ 1816.332344] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x100C, val=0x00000080
[ 1816.332344] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00000000
[ 1816.332344] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00001000
[ 1816.332344] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001FFF
[ 1816.332344] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000F3D
[ 1816.332344] Mali<5>: Mali group: Releasing group lock 0xED463D00
[ 1816.408614] Mali<3>: Adding PP Mali-400 PP0 to group
[ 1816.414146] Mali<3>: Starting new group for MMU Mali-400 MMU for PP1
[ 1816.421214] Mali<2>: Mali MMU: Creating Mali MMU: Mali-400 MMU for PP1
[ 1816.428462] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000018
[ 1816.438814] Mali<4>: MMU stall is implicit when Paging is not enebled.
[ 1816.446077] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP1
[ 1816.453723] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0xCAFEBABE
[ 1816.464168] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000006
[ 1816.474610] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x00000000
[ 1816.484958] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x001C, val=0x00000003
[ 1816.495402] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x70D15000
[ 1816.505844] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000000
[ 1816.516288] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
[ 1816.526634] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
[ 1816.536982] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000003
[ 1816.547427] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
[ 1816.557791] Mali<2>: Mali PP: Creating Mali PP core: Mali-400 PP1
[ 1816.564574] Mali<2>: Mali PP: Base address of PP core: 0x1c4a000
[ 1816.571260] Mali<5>: Mali group: Group lock taken 0xED463B00
[ 1816.577539] Mali<4>: Mali PP: Reset of core Mali-400 PP1
[ 1816.581248] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000000
[ 1816.581248] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001000
[ 1816.581248] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x100C, val=0x00000080
[ 1816.581248] Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00000000
[ 1816.581248] Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00001000
[ 1816.581248] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001FFF
[ 1816.581248] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000F3D
[ 1816.581248] Mali<5>: Mali group: Releasing group lock 0xED463B00
[ 1816.657500] Mali<3>: Adding PP Mali-400 PP1 to group
[ 1816.663035] Mali<6>: register_read for core Mali-400 GP, relative addr=0x006C, val=0x0B070101
[ 1816.672517] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1000, val=0xCD070101
[ 1816.682100] Mali<4>: Mali PM: Dynamic scheme; Changing Mali GPU power state from MALI_PM_LEVEL_1_ON to: MALI_PM_LEVEL_2_STANDBY
[ 1816.695355] Mali: Mali device driver loaded
[ 1817.690123] Mali<4>: Mali PM: Dynamic scheme; Changing Mali GPU power state from MALI_PM_LEVEL_2_STANDBY to: MALI_PM_LEVEL_3_LIGHT_SLEEP
[ 1817.704022] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1817.710406] Mali<5>: Mali group: Releasing group lock 0xED463D80
[ 1817.717231] Mali<5>: Mali group: Group lock taken 0xED463D00
[ 1817.723611] Mali<5>: Mali group: Releasing group lock 0xED463D00
[ 1817.730432] Mali<5>: Mali group: Group lock taken 0xED463B00
[ 1817.736811] Mali<5>: Mali group: Releasing group lock 0xED463B00
[ 1817.743693] Mali<3>: group: POWER OFF
[ 1817.747838] Mali<3>: mali_runtime_suspend() called
[ 1817.753265] Mali<2>: Mali PM: OS runtime suspended
[ 1840.365306] Mali<2>: Session starting
[ 1840.369419] Mali<6>: Partial page table allocation found, using page offset 4
[ 1840.377450] Mali<4>: Page table allocated for VA=0xF21A0000, MaliPA=0x70D19000
[ 1840.385628] Mali<6>: Partial page table allocation found, using page offset 5
[ 1840.393623] Mali<4>: Page table allocated for VA=0xF21A1000, MaliPA=0x70D1A000
[ 1840.401681] Mali<5>: Memory session begin
[ 1840.406142] Mali<5>: MMU session begin: success
[ 1840.411213] Mali<3>: Session started
[ 1840.415230] Mali<7>: Ioctl received 0xC0048205 0xBEC9CA2C
[ 1840.421259] Mali<7>: Ioctl received 0x80048202 0xBEC9CA2C
[ 1840.427260] Mali<7>: Ioctl received 0x80048203 0xBEC9CA1C
[ 1840.433499] Mali<7>: Mali<7>: Ioctl received 0xC0048204 0xB5A40DF8
[ 1840.440395] Ioctl received 0xC0048208 0xBEC9C9D8
[ 1840.445541] Mali<7>: Ioctl received 0x80048300 0xBEC9CA18
[ 1840.452032] Mali<4>: MMap() handler: start=0xB5202000, phys=0x40000000, size=0x00040000
[ 1840.460976] Mali<6>: Partial page table allocation found, using page offset 6
[ 1840.468901] Mali<4>: Page table allocated for VA=0xF21A2000, MaliPA=0x70D1B000
[ 1840.476959] Mali<6>: Allocating page array of size 256 bytes
[ 1840.483269] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00000000
[ 1840.491803] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5202000 length 0x00001000
[ 1840.501999] Mali<7>: Mapping phys 0x6FD47000 length 0x00001000 at offset 0x00000000 to CPUVA 0xB5202000
[ 1840.512482] Mali<7>: Mali map: mapping 0x6FD47000 to Mali address 0x40000000 length 0x00001000
[ 1840.522075] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00001000
[ 1840.530604] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5203000 length 0x00001000
[ 1840.540783] Mali<7>: Mapping phys 0x6FDFF000 length 0x00001000 at offset 0x00001000 to CPUVA 0xB5203000
[ 1840.551251] Mali<7>: Mali map: mapping 0x6FDFF000 to Mali address 0x40001000 length 0x00001000
[ 1840.560845] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00002000
[ 1840.569345] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5204000 length 0x00001000
[ 1840.579520] Mali<7>: Mapping phys 0x6FCFA000 length 0x00001000 at offset 0x00002000 to CPUVA 0xB5204000
[ 1840.589973] Mali<7>: Mali map: mapping 0x6FCFA000 to Mali address 0x40002000 length 0x00001000
[ 1840.599555] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00003000
[ 1840.608078] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5205000 length 0x00001000
[ 1840.618264] Mali<7>: Mapping phys 0x6FD79000 length 0x00001000 at offset 0x00003000 to CPUVA 0xB5205000
[ 1840.628719] Mali<7>: Mali map: mapping 0x6FD79000 to Mali address 0x40003000 length 0x00001000
[ 1840.638298] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00004000
[ 1840.646816] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5206000 length 0x00001000
[ 1840.656980] Mali<7>: Mapping phys 0x6FC78000 length 0x00001000 at offset 0x00004000 to CPUVA 0xB5206000
[ 1840.667431] Mali<7>: Mali map: mapping 0x6FC78000 to Mali address 0x40004000 length 0x00001000
[ 1840.677007] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00005000
[ 1840.685528] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5207000 length 0x00001000
[ 1840.695706] Mali<7>: Mapping phys 0x6FD78000 length 0x00001000 at offset 0x00005000 to CPUVA 0xB5207000
[ 1840.706155] Mali<7>: Mali map: mapping 0x6FD78000 to Mali address 0x40005000 length 0x00001000
[ 1840.715733] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00006000
[ 1840.724248] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5208000 length 0x00001000
[ 1840.734417] Mali<7>: Mapping phys 0x6FDD2000 length 0x00001000 at offset 0x00006000 to CPUVA 0xB5208000
[ 1840.744868] Mali<7>: Mali map: mapping 0x6FDD2000 to Mali address 0x40006000 length 0x00001000
[ 1840.754447] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00007000
[ 1840.762965] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5209000 length 0x00001000
[ 1840.773134] Mali<7>: Mapping phys 0x6FD95000 length 0x00001000 at offset 0x00007000 to CPUVA 0xB5209000
[ 1840.783589] Mali<7>: Mali map: mapping 0x6FD95000 to Mali address 0x40007000 length 0x00001000
[ 1840.793169] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00008000
[ 1840.801687] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520A000 length 0x00001000
[ 1840.811865] Mali<7>: Mapping phys 0x6FD45000 length 0x00001000 at offset 0x00008000 to CPUVA 0xB520A000
[ 1840.822315] Mali<7>: Mali map: mapping 0x6FD45000 to Mali address 0x40008000 length 0x00001000
[ 1840.831892] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00009000
[ 1840.840410] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520B000 length 0x00001000
[ 1840.850578] Mali<7>: Mapping phys 0x6FD87000 length 0x00001000 at offset 0x00009000 to CPUVA 0xB520B000
[ 1840.861029] Mali<7>: Mali map: mapping 0x6FD87000 to Mali address 0x40009000 length 0x00001000
[ 1840.870605] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000A000
[ 1840.879104] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520C000 length 0x00001000
[ 1840.889274] Mali<7>: Mapping phys 0x6FA7F000 length 0x00001000 at offset 0x0000A000 to CPUVA 0xB520C000
[ 1840.899730] Mali<7>: Mali map: mapping 0x6FA7F000 to Mali address 0x4000A000 length 0x00001000
[ 1840.909308] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000B000
[ 1840.917826] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520D000 length 0x00001000
[ 1840.927994] Mali<7>: Mapping phys 0x6FC3F000 length 0x00001000 at offset 0x0000B000 to CPUVA 0xB520D000
[ 1840.938448] Mali<7>: Mali map: mapping 0x6FC3F000 to Mali address 0x4000B000 length 0x00001000
[ 1840.948026] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000C000
[ 1840.956541] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520E000 length 0x00001000
[ 1840.966710] Mali<7>: Mapping phys 0x6FDF1000 length 0x00001000 at offset 0x0000C000 to CPUVA 0xB520E000
[ 1840.977159] Mali<7>: Mali map: mapping 0x6FDF1000 to Mali address 0x4000C000 length 0x00001000
[ 1840.986737] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000D000
[ 1840.995253] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB520F000 length 0x00001000
[ 1841.005424] Mali<7>: Mapping phys 0x6FAE5000 length 0x00001000 at offset 0x0000D000 to CPUVA 0xB520F000
[ 1841.015876] Mali<7>: Mali map: mapping 0x6FAE5000 to Mali address 0x4000D000 length 0x00001000
[ 1841.025451] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000E000
[ 1841.033967] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5210000 length 0x00001000
[ 1841.044137] Mali<7>: Mapping phys 0x6FD46000 length 0x00001000 at offset 0x0000E000 to CPUVA 0xB5210000
[ 1841.054586] Mali<7>: Mali map: mapping 0x6FD46000 to Mali address 0x4000E000 length 0x00001000
[ 1841.064163] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000F000
[ 1841.072685] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5211000 length 0x00001000
[ 1841.082856] Mali<7>: Mapping phys 0x6FD2F000 length 0x00001000 at offset 0x0000F000 to CPUVA 0xB5211000
[ 1841.093307] Mali<7>: Mali map: mapping 0x6FD2F000 to Mali address 0x4000F000 length 0x00001000
[ 1841.102892] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00010000
[ 1841.111420] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5212000 length 0x00001000
[ 1841.121601] Mali<7>: Mapping phys 0x6FCAC000 length 0x00001000 at offset 0x00010000 to CPUVA 0xB5212000
[ 1841.132056] Mali<7>: Mali map: mapping 0x6FCAC000 to Mali address 0x40010000 length 0x00001000
[ 1841.141638] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00011000
[ 1841.150157] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5213000 length 0x00001000
[ 1841.160327] Mali<7>: Mapping phys 0x6FAA2000 length 0x00001000 at offset 0x00011000 to CPUVA 0xB5213000
[ 1841.170778] Mali<7>: Mali map: mapping 0x6FAA2000 to Mali address 0x40011000 length 0x00001000
[ 1841.180362] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00012000
[ 1841.188860] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5214000 length 0x00001000
[ 1841.199030] Mali<7>: Mapping phys 0x6FD9F000 length 0x00001000 at offset 0x00012000 to CPUVA 0xB5214000
[ 1841.209484] Mali<7>: Mali map: mapping 0x6FD9F000 to Mali address 0x40012000 length 0x00001000
[ 1841.219062] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00013000
[ 1841.227577] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5215000 length 0x00001000
[ 1841.237742] Mali<7>: Mapping phys 0x6FDFE000 length 0x00001000 at offset 0x00013000 to CPUVA 0xB5215000
[ 1841.248194] Mali<7>: Mali map: mapping 0x6FDFE000 to Mali address 0x40013000 length 0x00001000
[ 1841.257769] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00014000
[ 1841.266287] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5216000 length 0x00001000
[ 1841.276451] Mali<7>: Mapping phys 0x6FA04000 length 0x00001000 at offset 0x00014000 to CPUVA 0xB5216000
[ 1841.286901] Mali<7>: Mali map: mapping 0x6FA04000 to Mali address 0x40014000 length 0x00001000
[ 1841.296479] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00015000
[ 1841.304993] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5217000 length 0x00001000
[ 1841.315161] Mali<7>: Mapping phys 0x6FA91000 length 0x00001000 at offset 0x00015000 to CPUVA 0xB5217000
[ 1841.325610] Mali<7>: Mali map: mapping 0x6FA91000 to Mali address 0x40015000 length 0x00001000
[ 1841.335193] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00016000
[ 1841.343719] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5218000 length 0x00001000
[ 1841.353889] Mali<7>: Mapping phys 0x6FDEE000 length 0x00001000 at offset 0x00016000 to CPUVA 0xB5218000
[ 1841.364344] Mali<7>: Mali map: mapping 0x6FDEE000 to Mali address 0x40016000 length 0x00001000
[ 1841.373923] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00017000
[ 1841.382441] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5219000 length 0x00001000
[ 1841.392610] Mali<7>: Mapping phys 0x6FDEF000 length 0x00001000 at offset 0x00017000 to CPUVA 0xB5219000
[ 1841.403060] Mali<7>: Mali map: mapping 0x6FDEF000 to Mali address 0x40017000 length 0x00001000
[ 1841.412639] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00018000
[ 1841.421154] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521A000 length 0x00001000
[ 1841.431322] Mali<7>: Mapping phys 0x6FAE2000 length 0x00001000 at offset 0x00018000 to CPUVA 0xB521A000
[ 1841.441776] Mali<7>: Mali map: mapping 0x6FAE2000 to Mali address 0x40018000 length 0x00001000
[ 1841.451352] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00019000
[ 1841.459850] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521B000 length 0x00001000
[ 1841.470031] Mali<7>: Mapping phys 0x6FAE3000 length 0x00001000 at offset 0x00019000 to CPUVA 0xB521B000
[ 1841.480482] Mali<7>: Mali map: mapping 0x6FAE3000 to Mali address 0x40019000 length 0x00001000
[ 1841.490059] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001A000
[ 1841.498557] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521C000 length 0x00001000
[ 1841.508728] Mali<7>: Mapping phys 0x6FAB0000 length 0x00001000 at offset 0x0001A000 to CPUVA 0xB521C000
[ 1841.519181] Mali<7>: Mali map: mapping 0x6FAB0000 to Mali address 0x4001A000 length 0x00001000
[ 1841.528758] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001B000
[ 1841.537275] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521D000 length 0x00001000
[ 1841.547442] Mali<7>: Mapping phys 0x6FAB1000 length 0x00001000 at offset 0x0001B000 to CPUVA 0xB521D000
[ 1841.557894] Mali<7>: Mali map: mapping 0x6FAB1000 to Mali address 0x4001B000 length 0x00001000
[ 1841.567472] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001C000
[ 1841.575986] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521E000 length 0x00001000
[ 1841.586156] Mali<7>: Mapping phys 0x6FC44000 length 0x00001000 at offset 0x0001C000 to CPUVA 0xB521E000
[ 1841.596613] Mali<7>: Mali map: mapping 0x6FC44000 to Mali address 0x4001C000 length 0x00001000
[ 1841.606190] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001D000
[ 1841.614708] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB521F000 length 0x00001000
[ 1841.624874] Mali<7>: Mapping phys 0x6FC45000 length 0x00001000 at offset 0x0001D000 to CPUVA 0xB521F000
[ 1841.635326] Mali<7>: Mali map: mapping 0x6FC45000 to Mali address 0x4001D000 length 0x00001000
[ 1841.644904] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001E000
[ 1841.653418] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5220000 length 0x00001000
[ 1841.663587] Mali<7>: Mapping phys 0x6FD9A000 length 0x00001000 at offset 0x0001E000 to CPUVA 0xB5220000
[ 1841.674037] Mali<7>: Mali map: mapping 0x6FD9A000 to Mali address 0x4001E000 length 0x00001000
[ 1841.683615] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001F000
[ 1841.692131] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5221000 length 0x00001000
[ 1841.702300] Mali<7>: Mapping phys 0x6FD9B000 length 0x00001000 at offset 0x0001F000 to CPUVA 0xB5221000
[ 1841.712751] Mali<7>: Mali map: mapping 0x6FD9B000 to Mali address 0x4001F000 length 0x00001000
[ 1841.722326] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00020000
[ 1841.730843] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5222000 length 0x00001000
[ 1841.741021] Mali<7>: Mapping phys 0x6FD48000 length 0x00001000 at offset 0x00020000 to CPUVA 0xB5222000
[ 1841.751473] Mali<7>: Mali map: mapping 0x6FD48000 to Mali address 0x40020000 length 0x00001000
[ 1841.761053] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00021000
[ 1841.769552] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5223000 length 0x00001000
[ 1841.779721] Mali<7>: Mapping phys 0x6FD49000 length 0x00001000 at offset 0x00021000 to CPUVA 0xB5223000
[ 1841.790198] Mali<7>: Mali map: mapping 0x6FD49000 to Mali address 0x40021000 length 0x00001000
[ 1841.799757] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00022000
[ 1841.808273] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5224000 length 0x00001000
[ 1841.818443] Mali<7>: Mapping phys 0x6FA06000 length 0x00001000 at offset 0x00022000 to CPUVA 0xB5224000
[ 1841.828892] Mali<7>: Mali map: mapping 0x6FA06000 to Mali address 0x40022000 length 0x00001000
[ 1841.838470] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00023000
[ 1841.846987] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5225000 length 0x00001000
[ 1841.857157] Mali<7>: Mapping phys 0x6FA07000 length 0x00001000 at offset 0x00023000 to CPUVA 0xB5225000
[ 1841.867611] Mali<7>: Mali map: mapping 0x6FA07000 to Mali address 0x40023000 length 0x00001000
[ 1841.877187] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00024000
[ 1841.885704] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5226000 length 0x00001000
[ 1841.895886] Mali<7>: Mapping phys 0x6FD30000 length 0x00001000 at offset 0x00024000 to CPUVA 0xB5226000
[ 1841.906337] Mali<7>: Mali map: mapping 0x6FD30000 to Mali address 0x40024000 length 0x00001000
[ 1841.915917] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00025000
[ 1841.924432] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5227000 length 0x00001000
[ 1841.934603] Mali<7>: Mapping phys 0x6FD31000 length 0x00001000 at offset 0x00025000 to CPUVA 0xB5227000
[ 1841.945056] Mali<7>: Mali map: mapping 0x6FD31000 to Mali address 0x40025000 length 0x00001000
[ 1841.954631] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00026000
[ 1841.963152] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5228000 length 0x00001000
[ 1841.973349] Mali<7>: Mapping phys 0x6FA92000 length 0x00001000 at offset 0x00026000 to CPUVA 0xB5228000
[ 1841.983804] Mali<7>: Mali map: mapping 0x6FA92000 to Mali address 0x40026000 length 0x00001000
[ 1841.993384] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00027000
[ 1842.001902] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5229000 length 0x00001000
[ 1842.012071] Mali<7>: Mapping phys 0x6FA93000 length 0x00001000 at offset 0x00027000 to CPUVA 0xB5229000
[ 1842.022527] Mali<7>: Mali map: mapping 0x6FA93000 to Mali address 0x40027000 length 0x00001000
[ 1842.032108] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00028000
[ 1842.040627] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522A000 length 0x00001000
[ 1842.050795] Mali<7>: Mapping phys 0x6FDB8000 length 0x00001000 at offset 0x00028000 to CPUVA 0xB522A000
[ 1842.061248] Mali<7>: Mali map: mapping 0x6FDB8000 to Mali address 0x40028000 length 0x00001000
[ 1842.070826] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00029000
[ 1842.079325] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522B000 length 0x00001000
[ 1842.089494] Mali<7>: Mapping phys 0x6FDB9000 length 0x00001000 at offset 0x00029000 to CPUVA 0xB522B000
[ 1842.099949] Mali<7>: Mali map: mapping 0x6FDB9000 to Mali address 0x40029000 length 0x00001000
[ 1842.109526] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002A000
[ 1842.118050] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522C000 length 0x00001000
[ 1842.128220] Mali<7>: Mapping phys 0x6FDE6000 length 0x00001000 at offset 0x0002A000 to CPUVA 0xB522C000
[ 1842.138673] Mali<7>: Mali map: mapping 0x6FDE6000 to Mali address 0x4002A000 length 0x00001000
[ 1842.148252] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002B000
[ 1842.156766] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522D000 length 0x00001000
[ 1842.166933] Mali<7>: Mapping phys 0x6FDE7000 length 0x00001000 at offset 0x0002B000 to CPUVA 0xB522D000
[ 1842.177383] Mali<7>: Mali map: mapping 0x6FDE7000 to Mali address 0x4002B000 length 0x00001000
[ 1842.186960] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002C000
[ 1842.195475] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522E000 length 0x00001000
[ 1842.205640] Mali<7>: Mapping phys 0x6FAD4000 length 0x00001000 at offset 0x0002C000 to CPUVA 0xB522E000
[ 1842.216091] Mali<7>: Mali map: mapping 0x6FAD4000 to Mali address 0x4002C000 length 0x00001000
[ 1842.225667] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002D000
[ 1842.234183] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB522F000 length 0x00001000
[ 1842.244352] Mali<7>: Mapping phys 0x6FAD5000 length 0x00001000 at offset 0x0002D000 to CPUVA 0xB522F000
[ 1842.254800] Mali<7>: Mali map: mapping 0x6FAD5000 to Mali address 0x4002D000 length 0x00001000
[ 1842.264378] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002E000
[ 1842.272895] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5230000 length 0x00001000
[ 1842.283063] Mali<7>: Mapping phys 0x6FD96000 length 0x00001000 at offset 0x0002E000 to CPUVA 0xB5230000
[ 1842.293514] Mali<7>: Mali map: mapping 0x6FD96000 to Mali address 0x4002E000 length 0x00001000
[ 1842.303091] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002F000
[ 1842.311609] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5231000 length 0x00001000
[ 1842.321777] Mali<7>: Mapping phys 0x6FD97000 length 0x00001000 at offset 0x0002F000 to CPUVA 0xB5231000
[ 1842.332228] Mali<7>: Mali map: mapping 0x6FD97000 to Mali address 0x4002F000 length 0x00001000
[ 1842.341806] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00030000
[ 1842.350322] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5232000 length 0x00001000
[ 1842.360495] Mali<7>: Mapping phys 0x6FAA0000 length 0x00001000 at offset 0x00030000 to CPUVA 0xB5232000
[ 1842.370956] Mali<7>: Mali map: mapping 0x6FAA0000 to Mali address 0x40030000 length 0x00001000
[ 1842.380534] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00031000
[ 1842.389033] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5233000 length 0x00001000
[ 1842.399206] Mali<7>: Mapping phys 0x6FAA1000 length 0x00001000 at offset 0x00031000 to CPUVA 0xB5233000
[ 1842.409656] Mali<7>: Mali map: mapping 0x6FAA1000 to Mali address 0x40031000 length 0x00001000
[ 1842.419234] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00032000
[ 1842.427751] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5234000 length 0x00001000
[ 1842.437923] Mali<7>: Mapping phys 0x6FDB6000 length 0x00001000 at offset 0x00032000 to CPUVA 0xB5234000
[ 1842.448374] Mali<7>: Mali map: mapping 0x6FDB6000 to Mali address 0x40032000 length 0x00001000
[ 1842.457950] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00033000
[ 1842.466468] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5235000 length 0x00001000
[ 1842.476636] Mali<7>: Mapping phys 0x6FDB7000 length 0x00001000 at offset 0x00033000 to CPUVA 0xB5235000
[ 1842.487085] Mali<7>: Mali map: mapping 0x6FDB7000 to Mali address 0x40033000 length 0x00001000
[ 1842.496663] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00034000
[ 1842.505178] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5236000 length 0x00001000
[ 1842.515345] Mali<7>: Mapping phys 0x6FAF4000 length 0x00001000 at offset 0x00034000 to CPUVA 0xB5236000
[ 1842.525795] Mali<7>: Mali map: mapping 0x6FAF4000 to Mali address 0x40034000 length 0x00001000
[ 1842.535375] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00035000
[ 1842.543893] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5237000 length 0x00001000
[ 1842.554058] Mali<7>: Mapping phys 0x6FAF5000 length 0x00001000 at offset 0x00035000 to CPUVA 0xB5237000
[ 1842.564510] Mali<7>: Mali map: mapping 0x6FAF5000 to Mali address 0x40035000 length 0x00001000
[ 1842.574089] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00036000
[ 1842.582607] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5238000 length 0x00001000
[ 1842.592776] Mali<7>: Mapping phys 0x6FDA4000 length 0x00001000 at offset 0x00036000 to CPUVA 0xB5238000
[ 1842.603227] Mali<7>: Mali map: mapping 0x6FDA4000 to Mali address 0x40036000 length 0x00001000
[ 1842.612805] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00037000
[ 1842.621322] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5239000 length 0x00001000
[ 1842.631497] Mali<7>: Mapping phys 0x6FDA5000 length 0x00001000 at offset 0x00037000 to CPUVA 0xB5239000
[ 1842.641947] Mali<7>: Mali map: mapping 0x6FDA5000 to Mali address 0x40037000 length 0x00001000
[ 1842.651522] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00038000
[ 1842.660040] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523A000 length 0x00001000
[ 1842.670208] Mali<7>: Mapping phys 0x6FDA6000 length 0x00001000 at offset 0x00038000 to CPUVA 0xB523A000
[ 1842.680661] Mali<7>: Mali map: mapping 0x6FDA6000 to Mali address 0x40038000 length 0x00001000
[ 1842.690239] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00039000
[ 1842.698737] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523B000 length 0x00001000
[ 1842.708911] Mali<7>: Mapping phys 0x6FDA7000 length 0x00001000 at offset 0x00039000 to CPUVA 0xB523B000
[ 1842.719363] Mali<7>: Mali map: mapping 0x6FDA7000 to Mali address 0x40039000 length 0x00001000
[ 1842.728940] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003A000
[ 1842.737457] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523C000 length 0x00001000
[ 1842.747623] Mali<7>: Mapping phys 0x6FA94000 length 0x00001000 at offset 0x0003A000 to CPUVA 0xB523C000
[ 1842.758071] Mali<7>: Mali map: mapping 0x6FA94000 to Mali address 0x4003A000 length 0x00001000
[ 1842.767651] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003B000
[ 1842.776167] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523D000 length 0x00001000
[ 1842.786334] Mali<7>: Mapping phys 0x6FA95000 length 0x00001000 at offset 0x0003B000 to CPUVA 0xB523D000
[ 1842.796786] Mali<7>: Mali map: mapping 0x6FA95000 to Mali address 0x4003B000 length 0x00001000
[ 1842.806361] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003C000
[ 1842.814878] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523E000 length 0x00001000
[ 1842.825045] Mali<7>: Mapping phys 0x6FA96000 length 0x00001000 at offset 0x0003C000 to CPUVA 0xB523E000
[ 1842.835498] Mali<7>: Mali map: mapping 0x6FA96000 to Mali address 0x4003C000 length 0x00001000
[ 1842.845075] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003D000
[ 1842.853589] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB523F000 length 0x00001000
[ 1842.863759] Mali<7>: Mapping phys 0x6FA97000 length 0x00001000 at offset 0x0003D000 to CPUVA 0xB523F000
[ 1842.874210] Mali<7>: Mali map: mapping 0x6FA97000 to Mali address 0x4003D000 length 0x00001000
[ 1842.883787] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003E000
[ 1842.892312] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5240000 length 0x00001000
[ 1842.902490] Mali<7>: Mapping phys 0x6FAEC000 length 0x00001000 at offset 0x0003E000 to CPUVA 0xB5240000
[ 1842.912949] Mali<7>: Mali map: mapping 0x6FAEC000 to Mali address 0x4003E000 length 0x00001000
[ 1842.922529] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003F000
[ 1842.931050] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5241000 length 0x00001000
[ 1842.941226] Mali<7>: Mapping phys 0x6FAED000 length 0x00001000 at offset 0x0003F000 to CPUVA 0xB5241000
[ 1842.951681] Mali<7>: Mali map: mapping 0x6FAED000 to Mali address 0x4003F000 length 0x00001000
[ 1842.961266] Mali<6>: Allocated 64 pages
[ 1842.965520] Mali<6>: 128 out of 49152 pages now allocated
[ 1842.971556] Mali<7>: MMAP OK
[ 1842.974818] Mali<7>: Ioctl received 0x80048402 0xBEC9CA78
[ 1842.985736] Mali<7>: Ioctl received 0x80048402 0xBEC9CA68
[ 1842.996438] Mali<7>: Ioctl received 0xC0048308 0xBEC9C914
[ 1843.002484] Mali<3>: Requested to map ump memory with secure id 3 into virtual memory 0x40100000, size 0x000E1000
[ 1843.013909] Mali<4>: In ump_memory_commit
[ 1843.018355] Mali<4>: Have 225 blocks
[ 1843.022348] Mali<4>: Mapping in 0xafd9d000 size 4096
[ 1843.027848] Mali<7>: Mapping phys 0x6FD9D000 length 0x00001000 at offset 0x00000000
[ 1843.036372] Mali<7>: Mapping phys 0x6FD9D000 length 0x00001000 at offset 0x00000000 to CPUVA 0x00000000
[ 1843.046819] Mali<7>: Mali map: mapping 0x6FD9D000 to Mali address 0x40100000 length 0x00001000
[ 1843.056396] Mali<4>: Mapping in 0xafaf6000 size 4096
[ 1843.061929] Mali<7>: Mapping phys 0x6FAF6000 length 0x00001000 at offset 0x00001000
[ 1843.070446] Mali<7>: Mapping phys 0x6FAF6000 length 0x00001000 at offset 0x00001000 to CPUVA 0x00001000
[ 1843.080893] Mali<7>: Mali map: mapping 0x6FAF6000 to Mali address 0x40101000 length 0x00001000
[ 1843.090471] Mali<4>: Mapping in 0xafdb1000 size 4096
[ 1843.095978] Mali<7>: Mapping phys 0x6FDB1000 length 0x00001000 at offset 0x00002000
[ 1843.104493] Mali<7>: Mapping phys 0x6FDB1000 length 0x00001000 at offset 0x00002000 to CPUVA 0x00002000
[ 1843.114940] Mali<7>: Mali map: mapping 0x6FDB1000 to Mali address 0x40102000 length 0x00001000
[ 1843.124518] Mali<4>: Mapping in 0xafdb2000 size 4096
[ 1843.130045] Mali<7>: Mapping phys 0x6FDB2000 length 0x00001000 at offset 0x00003000
[ 1843.138543] Mali<7>: Mapping phys 0x6FDB2000 length 0x00001000 at offset 0x00003000 to CPUVA 0x00003000
[ 1843.149003] Mali<7>: Mali map: mapping 0x6FDB2000 to Mali address 0x40103000 length 0x00001000
[ 1843.158591] Mali<4>: Mapping in 0xafdb3000 size 4096
[ 1843.164119] Mali<7>: Mapping phys 0x6FDB3000 length 0x00001000 at offset 0x00004000
[ 1843.172629] Mali<7>: Mapping phys 0x6FDB3000 length 0x00001000 at offset 0x00004000 to CPUVA 0x00004000
[ 1843.183075] Mali<7>: Mali map: mapping 0x6FDB3000 to Mali address 0x40104000 length 0x00001000
[ 1843.192653] Mali<4>: Mapping in 0xafd90000 size 4096
[ 1843.198161] Mali<7>: Mapping phys 0x6FD90000 length 0x00001000 at offset 0x00005000
[ 1843.206678] Mali<7>: Mapping phys 0x6FD90000 length 0x00001000 at offset 0x00005000 to CPUVA 0x00005000
[ 1843.217122] Mali<7>: Mali map: mapping 0x6FD90000 to Mali address 0x40105000 length 0x00001000
[ 1843.226700] Mali<4>: Mapping in 0xafd91000 size 4096
[ 1843.232227] Mali<7>: Mapping phys 0x6FD91000 length 0x00001000 at offset 0x00006000
[ 1843.240744] Mali<7>: Mapping phys 0x6FD91000 length 0x00001000 at offset 0x00006000 to CPUVA 0x00006000
[ 1843.251189] Mali<7>: Mali map: mapping 0x6FD91000 to Mali address 0x40106000 length 0x00001000
[ 1843.260768] Mali<4>: Mapping in 0xafd92000 size 4096
[ 1843.266276] Mali<7>: Mapping phys 0x6FD92000 length 0x00001000 at offset 0x00007000
[ 1843.274792] Mali<7>: Mapping phys 0x6FD92000 length 0x00001000 at offset 0x00007000 to CPUVA 0x00007000
[ 1843.285237] Mali<7>: Mali map: mapping 0x6FD92000 to Mali address 0x40107000 length 0x00001000
[ 1843.294815] Mali<4>: Mapping in 0xafd93000 size 4096
[ 1843.300342] Mali<7>: Mapping phys 0x6FD93000 length 0x00001000 at offset 0x00008000
[ 1843.308840] Mali<7>: Mapping phys 0x6FD93000 length 0x00001000 at offset 0x00008000 to CPUVA 0x00008000
[ 1843.319284] Mali<7>: Mali map: mapping 0x6FD93000 to Mali address 0x40108000 length 0x00001000
[ 1843.328865] Mali<4>: Mapping in 0xafad0000 size 4096
[ 1843.334394] Mali<7>: Mapping phys 0x6FAD0000 length 0x00001000 at offset 0x00009000
[ 1843.342911] Mali<7>: Mapping phys 0x6FAD0000 length 0x00001000 at offset 0x00009000 to CPUVA 0x00009000
[ 1843.353356] Mali<7>: Mali map: mapping 0x6FAD0000 to Mali address 0x40109000 length 0x00001000
[ 1843.362936] Mali<4>: Mapping in 0xafad1000 size 4096
[ 1843.368444] Mali<7>: Mapping phys 0x6FAD1000 length 0x00001000 at offset 0x0000A000
[ 1843.376962] Mali<7>: Mapping phys 0x6FAD1000 length 0x00001000 at offset 0x0000A000 to CPUVA 0x0000A000
[ 1843.387403] Mali<7>: Mali map: mapping 0x6FAD1000 to Mali address 0x4010A000 length 0x00001000
[ 1843.396984] Mali<4>: Mapping in 0xafad2000 size 4096
[ 1843.402510] Mali<7>: Mapping phys 0x6FAD2000 length 0x00001000 at offset 0x0000B000
[ 1843.411034] Mali<7>: Mapping phys 0x6FAD2000 length 0x00001000 at offset 0x0000B000 to CPUVA 0x0000B000
[ 1843.421482] Mali<7>: Mali map: mapping 0x6FAD2000 to Mali address 0x4010B000 length 0x00001000
[ 1843.431059] Mali<4>: Mapping in 0xafad3000 size 4096
[ 1843.436567] Mali<7>: Mapping phys 0x6FAD3000 length 0x00001000 at offset 0x0000C000
[ 1843.445082] Mali<7>: Mapping phys 0x6FAD3000 length 0x00001000 at offset 0x0000C000 to CPUVA 0x0000C000
[ 1843.455525] Mali<7>: Mali map: mapping 0x6FAD3000 to Mali address 0x4010C000 length 0x00001000
[ 1843.465103] Mali<4>: Mapping in 0xafaa4000 size 4096
[ 1843.470630] Mali<7>: Mapping phys 0x6FAA4000 length 0x00001000 at offset 0x0000D000
[ 1843.479128] Mali<7>: Mapping phys 0x6FAA4000 length 0x00001000 at offset 0x0000D000 to CPUVA 0x0000D000
[ 1843.489573] Mali<7>: Mali map: mapping 0x6FAA4000 to Mali address 0x4010D000 length 0x00001000
[ 1843.499151] Mali<4>: Mapping in 0xafaa5000 size 4096
[ 1843.504677] Mali<7>: Mapping phys 0x6FAA5000 length 0x00001000 at offset 0x0000E000
[ 1843.513193] Mali<7>: Mapping phys 0x6FAA5000 length 0x00001000 at offset 0x0000E000 to CPUVA 0x0000E000
[ 1843.523639] Mali<7>: Mali map: mapping 0x6FAA5000 to Mali address 0x4010E000 length 0x00001000
[ 1843.533217] Mali<4>: Mapping in 0xafaa6000 size 4096
[ 1843.538725] Mali<7>: Mapping phys 0x6FAA6000 length 0x00001000 at offset 0x0000F000
[ 1843.547243] Mali<7>: Mapping phys 0x6FAA6000 length 0x00001000 at offset 0x0000F000 to CPUVA 0x0000F000
[ 1843.557684] Mali<7>: Mali map: mapping 0x6FAA6000 to Mali address 0x4010F000 length 0x00001000
[ 1843.567264] Mali<4>: Mapping in 0xafaa7000 size 4096
[ 1843.572790] Mali<7>: Mapping phys 0x6FAA7000 length 0x00001000 at offset 0x00010000
[ 1843.581307] Mali<7>: Mapping phys 0x6FAA7000 length 0x00001000 at offset 0x00010000 to CPUVA 0x00010000
[ 1843.591753] Mali<7>: Mali map: mapping 0x6FAA7000 to Mali address 0x40110000 length 0x00001000
[ 1843.601330] Mali<4>: Mapping in 0xafaf0000 size 4096
[ 1843.606838] Mali<7>: Mapping phys 0x6FAF0000 length 0x00001000 at offset 0x00011000
[ 1843.615353] Mali<7>: Mapping phys 0x6FAF0000 length 0x00001000 at offset 0x00011000 to CPUVA 0x00011000
[ 1843.625798] Mali<7>: Mali map: mapping 0x6FAF0000 to Mali address 0x40111000 length 0x00001000
[ 1843.635374] Mali<4>: Mapping in 0xafaf1000 size 4096
[ 1843.640901] Mali<7>: Mapping phys 0x6FAF1000 length 0x00001000 at offset 0x00012000
[ 1843.649398] Mali<7>: Mapping phys 0x6FAF1000 length 0x00001000 at offset 0x00012000 to CPUVA 0x00012000
[ 1843.659841] Mali<7>: Mali map: mapping 0x6FAF1000 to Mali address 0x40112000 length 0x00001000
[ 1843.669418] Mali<4>: Mapping in 0xafaf2000 size 4096
[ 1843.674951] Mali<7>: Mapping phys 0x6FAF2000 length 0x00001000 at offset 0x00013000
[ 1843.683467] Mali<7>: Mapping phys 0x6FAF2000 length 0x00001000 at offset 0x00013000 to CPUVA 0x00013000
[ 1843.693914] Mali<7>: Mali map: mapping 0x6FAF2000 to Mali address 0x40113000 length 0x00001000
[ 1843.703489] Mali<4>: Mapping in 0xafaf3000 size 4096
[ 1843.708997] Mali<7>: Mapping phys 0x6FAF3000 length 0x00001000 at offset 0x00014000
[ 1843.717513] Mali<7>: Mapping phys 0x6FAF3000 length 0x00001000 at offset 0x00014000 to CPUVA 0x00014000
[ 1843.727957] Mali<7>: Mali map: mapping 0x6FAF3000 to Mali address 0x40114000 length 0x00001000
[ 1843.737534] Mali<4>: Mapping in 0xafaa8000 size 4096
[ 1843.743059] Mali<7>: Mapping phys 0x6FAA8000 length 0x00001000 at offset 0x00015000
[ 1843.751573] Mali<7>: Mapping phys 0x6FAA8000 length 0x00001000 at offset 0x00015000 to CPUVA 0x00015000
[ 1843.762020] Mali<7>: Mali map: mapping 0x6FAA8000 to Mali address 0x40115000 length 0x00001000
[ 1843.771598] Mali<4>: Mapping in 0xafaa9000 size 4096
[ 1843.777106] Mali<7>: Mapping phys 0x6FAA9000 length 0x00001000 at offset 0x00016000
[ 1843.785621] Mali<7>: Mapping phys 0x6FAA9000 length 0x00001000 at offset 0x00016000 to CPUVA 0x00016000
[ 1843.796067] Mali<7>: Mali map: mapping 0x6FAA9000 to Mali address 0x40116000 length 0x00001000
[ 1843.805643] Mali<4>: Mapping in 0xafaaa000 size 4096
[ 1843.811170] Mali<7>: Mapping phys 0x6FAAA000 length 0x00001000 at offset 0x00017000
[ 1843.819667] Mali<7>: Mapping phys 0x6FAAA000 length 0x00001000 at offset 0x00017000 to CPUVA 0x00017000
[ 1843.830134] Mali<7>: Mali map: mapping 0x6FAAA000 to Mali address 0x40117000 length 0x00001000
[ 1843.839692] Mali<4>: Mapping in 0xafaab000 size 4096
[ 1843.845219] Mali<7>: Mapping phys 0x6FAAB000 length 0x00001000 at offset 0x00018000
[ 1843.853732] Mali<7>: Mapping phys 0x6FAAB000 length 0x00001000 at offset 0x00018000 to CPUVA 0x00018000
[ 1843.864179] Mali<7>: Mali map: mapping 0x6FAAB000 to Mali address 0x40118000 length 0x00001000
[ 1843.873757] Mali<4>: Mapping in 0xafaac000 size 4096
[ 1843.879264] Mali<7>: Mapping phys 0x6FAAC000 length 0x00001000 at offset 0x00019000
[ 1843.887781] Mali<7>: Mapping phys 0x6FAAC000 length 0x00001000 at offset 0x00019000 to CPUVA 0x00019000
[ 1843.898229] Mali<7>: Mali map: mapping 0x6FAAC000 to Mali address 0x40119000 length 0x00001000
[ 1843.907804] Mali<4>: Mapping in 0xafaad000 size 4096
[ 1843.913333] Mali<7>: Mapping phys 0x6FAAD000 length 0x00001000 at offset 0x0001A000
[ 1843.921849] Mali<7>: Mapping phys 0x6FAAD000 length 0x00001000 at offset 0x0001A000 to CPUVA 0x0001A000
[ 1843.932301] Mali<7>: Mali map: mapping 0x6FAAD000 to Mali address 0x4011A000 length 0x00001000
[ 1843.941880] Mali<4>: Mapping in 0xafaae000 size 4096
[ 1843.947389] Mali<7>: Mapping phys 0x6FAAE000 length 0x00001000 at offset 0x0001B000
[ 1843.955903] Mali<7>: Mapping phys 0x6FAAE000 length 0x00001000 at offset 0x0001B000 to CPUVA 0x0001B000
[ 1843.966352] Mali<7>: Mali map: mapping 0x6FAAE000 to Mali address 0x4011B000 length 0x00001000
[ 1843.975957] Mali<4>: Mapping in 0xafaaf000 size 4096
[ 1843.981487] Mali<7>: Mapping phys 0x6FAAF000 length 0x00001000 at offset 0x0001C000
[ 1843.989985] Mali<7>: Mapping phys 0x6FAAF000 length 0x00001000 at offset 0x0001C000 to CPUVA 0x0001C000
[ 1844.000451] Mali<7>: Mali map: mapping 0x6FAAF000 to Mali address 0x4011C000 length 0x00001000
[ 1844.010041] Mali<4>: Mapping in 0xafda8000 size 4096
[ 1844.015551] Mali<7>: Mapping phys 0x6FDA8000 length 0x00001000 at offset 0x0001D000
[ 1844.024069] Mali<7>: Mapping phys 0x6FDA8000 length 0x00001000 at offset 0x0001D000 to CPUVA 0x0001D000
[ 1844.034557] Mali<7>: Mali map: mapping 0x6FDA8000 to Mali address 0x4011D000 length 0x00001000
[ 1844.044139] Mali<4>: Mapping in 0xafda9000 size 4096
[ 1844.049647] Mali<7>: Mapping phys 0x6FDA9000 length 0x00001000 at offset 0x0001E000
[ 1844.058169] Mali<7>: Mapping phys 0x6FDA9000 length 0x00001000 at offset 0x0001E000 to CPUVA 0x0001E000
[ 1844.068620] Mali<7>: Mali map: mapping 0x6FDA9000 to Mali address 0x4011E000 length 0x00001000
[ 1844.078201] Mali<4>: Mapping in 0xafdaa000 size 4096
[ 1844.083728] Mali<7>: Mapping phys 0x6FDAA000 length 0x00001000 at offset 0x0001F000
[ 1844.092246] Mali<7>: Mapping phys 0x6FDAA000 length 0x00001000 at offset 0x0001F000 to CPUVA 0x0001F000
[ 1844.102692] Mali<7>: Mali map: mapping 0x6FDAA000 to Mali address 0x4011F000 length 0x00001000
[ 1844.112271] Mali<4>: Mapping in 0xafdab000 size 4096
[ 1844.117779] Mali<7>: Mapping phys 0x6FDAB000 length 0x00001000 at offset 0x00020000
[ 1844.126295] Mali<7>: Mapping phys 0x6FDAB000 length 0x00001000 at offset 0x00020000 to CPUVA 0x00020000
[ 1844.136737] Mali<7>: Mali map: mapping 0x6FDAB000 to Mali address 0x40120000 length 0x00001000
[ 1844.146316] Mali<4>: Mapping in 0xafdac000 size 4096
[ 1844.151841] Mali<7>: Mapping phys 0x6FDAC000 length 0x00001000 at offset 0x00021000
[ 1844.160358] Mali<7>: Mapping phys 0x6FDAC000 length 0x00001000 at offset 0x00021000 to CPUVA 0x00021000
[ 1844.170804] Mali<7>: Mali map: mapping 0x6FDAC000 to Mali address 0x40121000 length 0x00001000
[ 1844.180383] Mali<4>: Mapping in 0xafdad000 size 4096
[ 1844.185890] Mali<7>: Mapping phys 0x6FDAD000 length 0x00001000 at offset 0x00022000
[ 1844.194411] Mali<7>: Mapping phys 0x6FDAD000 length 0x00001000 at offset 0x00022000 to CPUVA 0x00022000
[ 1844.204856] Mali<7>: Mali map: mapping 0x6FDAD000 to Mali address 0x40122000 length 0x00001000
[ 1844.214434] Mali<4>: Mapping in 0xafdae000 size 4096
[ 1844.219942] Mali<7>: Mapping phys 0x6FDAE000 length 0x00001000 at offset 0x00023000
[ 1844.228459] Mali<7>: Mapping phys 0x6FDAE000 length 0x00001000 at offset 0x00023000 to CPUVA 0x00023000
[ 1844.238905] Mali<7>: Mali map: mapping 0x6FDAE000 to Mali address 0x40123000 length 0x00001000
[ 1844.248482] Mali<4>: Mapping in 0xafdaf000 size 4096
[ 1844.254006] Mali<7>: Mapping phys 0x6FDAF000 length 0x00001000 at offset 0x00024000
[ 1844.262521] Mali<7>: Mapping phys 0x6FDAF000 length 0x00001000 at offset 0x00024000 to CPUVA 0x00024000
[ 1844.272966] Mali<7>: Mali map: mapping 0x6FDAF000 to Mali address 0x40124000 length 0x00001000
[ 1844.282543] Mali<4>: Mapping in 0xafd88000 size 4096
[ 1844.288051] Mali<7>: Mapping phys 0x6FD88000 length 0x00001000 at offset 0x00025000
[ 1844.296567] Mali<7>: Mapping phys 0x6FD88000 length 0x00001000 at offset 0x00025000 to CPUVA 0x00025000
[ 1844.307009] Mali<7>: Mali map: mapping 0x6FD88000 to Mali address 0x40125000 length 0x00001000
[ 1844.316587] Mali<4>: Mapping in 0xafd89000 size 4096
[ 1844.322112] Mali<7>: Mapping phys 0x6FD89000 length 0x00001000 at offset 0x00026000
[ 1844.330629] Mali<7>: Mapping phys 0x6FD89000 length 0x00001000 at offset 0x00026000 to CPUVA 0x00026000
[ 1844.341074] Mali<7>: Mali map: mapping 0x6FD89000 to Mali address 0x40126000 length 0x00001000
[ 1844.350649] Mali<4>: Mapping in 0xafd8a000 size 4096
[ 1844.356157] Mali<7>: Mapping phys 0x6FD8A000 length 0x00001000 at offset 0x00027000
[ 1844.364673] Mali<7>: Mapping phys 0x6FD8A000 length 0x00001000 at offset 0x00027000 to CPUVA 0x00027000
[ 1844.375121] Mali<7>: Mali map: mapping 0x6FD8A000 to Mali address 0x40127000 length 0x00001000
[ 1844.384701] Mali<4>: Mapping in 0xafd8b000 size 4096
[ 1844.390228] Mali<7>: Mapping phys 0x6FD8B000 length 0x00001000 at offset 0x00028000
[ 1844.398727] Mali<7>: Mapping phys 0x6FD8B000 length 0x00001000 at offset 0x00028000 to CPUVA 0x00028000
[ 1844.409170] Mali<7>: Mali map: mapping 0x6FD8B000 to Mali address 0x40128000 length 0x00001000
[ 1844.418748] Mali<4>: Mapping in 0xafd8c000 size 4096
[ 1844.424276] Mali<7>: Mapping phys 0x6FD8C000 length 0x00001000 at offset 0x00029000
[ 1844.432790] Mali<7>: Mapping phys 0x6FD8C000 length 0x00001000 at offset 0x00029000 to CPUVA 0x00029000
[ 1844.443236] Mali<7>: Mali map: mapping 0x6FD8C000 to Mali address 0x40129000 length 0x00001000
[ 1844.452819] Mali<4>: Mapping in 0xafd8d000 size 4096
[ 1844.458326] Mali<7>: Mapping phys 0x6FD8D000 length 0x00001000 at offset 0x0002A000
[ 1844.466844] Mali<7>: Mapping phys 0x6FD8D000 length 0x00001000 at offset 0x0002A000 to CPUVA 0x0002A000
[ 1844.477289] Mali<7>: Mali map: mapping 0x6FD8D000 to Mali address 0x4012A000 length 0x00001000
[ 1844.486864] Mali<4>: Mapping in 0xafd8e000 size 4096
[ 1844.492389] Mali<7>: Mapping phys 0x6FD8E000 length 0x00001000 at offset 0x0002B000
[ 1844.500907] Mali<7>: Mapping phys 0x6FD8E000 length 0x00001000 at offset 0x0002B000 to CPUVA 0x0002B000
[ 1844.511353] Mali<7>: Mali map: mapping 0x6FD8E000 to Mali address 0x4012B000 length 0x00001000
[ 1844.520931] Mali<4>: Mapping in 0xafd8f000 size 4096
[ 1844.526439] Mali<7>: Mapping phys 0x6FD8F000 length 0x00001000 at offset 0x0002C000
[ 1844.534954] Mali<7>: Mapping phys 0x6FD8F000 length 0x00001000 at offset 0x0002C000 to CPUVA 0x0002C000
[ 1844.545401] Mali<7>: Mali map: mapping 0x6FD8F000 to Mali address 0x4012C000 length 0x00001000
[ 1844.554977] Mali<4>: Mapping in 0xafdd8000 size 4096
[ 1844.560504] Mali<7>: Mapping phys 0x6FDD8000 length 0x00001000 at offset 0x0002D000
[ 1844.569002] Mali<7>: Mapping phys 0x6FDD8000 length 0x00001000 at offset 0x0002D000 to CPUVA 0x0002D000
[ 1844.579450] Mali<7>: Mali map: mapping 0x6FDD8000 to Mali address 0x4012D000 length 0x00001000
[ 1844.589055] Mali<4>: Mapping in 0xafdd9000 size 4096
[ 1844.594593] Mali<7>: Mapping phys 0x6FDD9000 length 0x00001000 at offset 0x0002E000
[ 1844.603110] Mali<7>: Mapping phys 0x6FDD9000 length 0x00001000 at offset 0x0002E000 to CPUVA 0x0002E000
[ 1844.613562] Mali<7>: Mali map: mapping 0x6FDD9000 to Mali address 0x4012E000 length 0x00001000
[ 1844.623141] Mali<4>: Mapping in 0xafdda000 size 4096
[ 1844.628650] Mali<7>: Mapping phys 0x6FDDA000 length 0x00001000 at offset 0x0002F000
[ 1844.637166] Mali<7>: Mapping phys 0x6FDDA000 length 0x00001000 at offset 0x0002F000 to CPUVA 0x0002F000
[ 1844.647611] Mali<7>: Mali map: mapping 0x6FDDA000 to Mali address 0x4012F000 length 0x00001000
[ 1844.657190] Mali<4>: Mapping in 0xafddb000 size 4096
[ 1844.662719] Mali<7>: Mapping phys 0x6FDDB000 length 0x00001000 at offset 0x00030000
[ 1844.671235] Mali<7>: Mapping phys 0x6FDDB000 length 0x00001000 at offset 0x00030000 to CPUVA 0x00030000
[ 1844.681680] Mali<7>: Mali map: mapping 0x6FDDB000 to Mali address 0x40130000 length 0x00001000
[ 1844.691257] Mali<4>: Mapping in 0xafddc000 size 4096
[ 1844.696765] Mali<7>: Mapping phys 0x6FDDC000 length 0x00001000 at offset 0x00031000
[ 1844.705277] Mali<7>: Mapping phys 0x6FDDC000 length 0x00001000 at offset 0x00031000 to CPUVA 0x00031000
[ 1844.715728] Mali<7>: Mali map: mapping 0x6FDDC000 to Mali address 0x40131000 length 0x00001000
[ 1844.725305] Mali<4>: Mapping in 0xafddd000 size 4096
[ 1844.730832] Mali<7>: Mapping phys 0x6FDDD000 length 0x00001000 at offset 0x00032000
[ 1844.739329] Mali<7>: Mapping phys 0x6FDDD000 length 0x00001000 at offset 0x00032000 to CPUVA 0x00032000
[ 1844.749778] Mali<7>: Mali map: mapping 0x6FDDD000 to Mali address 0x40132000 length 0x00001000
[ 1844.759353] Mali<4>: Mapping in 0xafdde000 size 4096
[ 1844.764880] Mali<7>: Mapping phys 0x6FDDE000 length 0x00001000 at offset 0x00033000
[ 1844.773396] Mali<7>: Mapping phys 0x6FDDE000 length 0x00001000 at offset 0x00033000 to CPUVA 0x00033000
[ 1844.783841] Mali<7>: Mali map: mapping 0x6FDDE000 to Mali address 0x40133000 length 0x00001000
[ 1844.793418] Mali<4>: Mapping in 0xafddf000 size 4096
[ 1844.798925] Mali<7>: Mapping phys 0x6FDDF000 length 0x00001000 at offset 0x00034000
[ 1844.807441] Mali<7>: Mapping phys 0x6FDDF000 length 0x00001000 at offset 0x00034000 to CPUVA 0x00034000
[ 1844.817884] Mali<7>: Mali map: mapping 0x6FDDF000 to Mali address 0x40134000 length 0x00001000
[ 1844.827461] Mali<4>: Mapping in 0xafaf8000 size 4096
[ 1844.832986] Mali<7>: Mapping phys 0x6FAF8000 length 0x00001000 at offset 0x00035000
[ 1844.841502] Mali<7>: Mapping phys 0x6FAF8000 length 0x00001000 at offset 0x00035000 to CPUVA 0x00035000
[ 1844.851944] Mali<7>: Mali map: mapping 0x6FAF8000 to Mali address 0x40135000 length 0x00001000
[ 1844.861521] Mali<4>: Mapping in 0xafaf9000 size 4096
[ 1844.867034] Mali<7>: Mapping phys 0x6FAF9000 length 0x00001000 at offset 0x00036000
[ 1844.875554] Mali<7>: Mapping phys 0x6FAF9000 length 0x00001000 at offset 0x00036000 to CPUVA 0x00036000
[ 1844.886001] Mali<7>: Mali map: mapping 0x6FAF9000 to Mali address 0x40136000 length 0x00001000
[ 1844.895581] Mali<4>: Mapping in 0xafafa000 size 4096
[ 1844.901108] Mali<7>: Mapping phys 0x6FAFA000 length 0x00001000 at offset 0x00037000
[ 1844.909606] Mali<7>: Mapping phys 0x6FAFA000 length 0x00001000 at offset 0x00037000 to CPUVA 0x00037000
[ 1844.920070] Mali<7>: Mali map: mapping 0x6FAFA000 to Mali address 0x40137000 length 0x00001000
[ 1844.929629] Mali<4>: Mapping in 0xafafb000 size 4096
[ 1844.935154] Mali<7>: Mapping phys 0x6FAFB000 length 0x00001000 at offset 0x00038000
[ 1844.943669] Mali<7>: Mapping phys 0x6FAFB000 length 0x00001000 at offset 0x00038000 to CPUVA 0x00038000
[ 1844.954116] Mali<7>: Mali map: mapping 0x6FAFB000 to Mali address 0x40138000 length 0x00001000
[ 1844.963697] Mali<4>: Mapping in 0xafafc000 size 4096
[ 1844.969207] Mali<7>: Mapping phys 0x6FAFC000 length 0x00001000 at offset 0x00039000
[ 1844.977849] Mali<7>: Mapping phys 0x6FAFC000 length 0x00001000 at offset 0x00039000 to CPUVA 0x00039000
[ 1844.988308] Mali<7>: Mali map: mapping 0x6FAFC000 to Mali address 0x40139000 length 0x00001000
[ 1844.997889] Mali<4>: Mapping in 0xafafd000 size 4096
[ 1845.003417] Mali<7>: Mapping phys 0x6FAFD000 length 0x00001000 at offset 0x0003A000
[ 1845.011933] Mali<7>: Mapping phys 0x6FAFD000 length 0x00001000 at offset 0x0003A000 to CPUVA 0x0003A000
[ 1845.022378] Mali<7>: Mali map: mapping 0x6FAFD000 to Mali address 0x4013A000 length 0x00001000
[ 1845.031955] Mali<4>: Mapping in 0xafafe000 size 4096
[ 1845.037462] Mali<7>: Mapping phys 0x6FAFE000 length 0x00001000 at offset 0x0003B000
[ 1845.045977] Mali<7>: Mapping phys 0x6FAFE000 length 0x00001000 at offset 0x0003B000 to CPUVA 0x0003B000
[ 1845.056420] Mali<7>: Mali map: mapping 0x6FAFE000 to Mali address 0x4013B000 length 0x00001000
[ 1845.065997] Mali<4>: Mapping in 0xafaff000 size 4096
[ 1845.071521] Mali<7>: Mapping phys 0x6FAFF000 length 0x00001000 at offset 0x0003C000
[ 1845.080037] Mali<7>: Mapping phys 0x6FAFF000 length 0x00001000 at offset 0x0003C000 to CPUVA 0x0003C000
[ 1845.090482] Mali<7>: Mali map: mapping 0x6FAFF000 to Mali address 0x4013C000 length 0x00001000
[ 1845.100058] Mali<4>: Mapping in 0xafdc8000 size 4096
[ 1845.105566] Mali<7>: Mapping phys 0x6FDC8000 length 0x00001000 at offset 0x0003D000
[ 1845.114081] Mali<7>: Mapping phys 0x6FDC8000 length 0x00001000 at offset 0x0003D000 to CPUVA 0x0003D000
[ 1845.124525] Mali<7>: Mali map: mapping 0x6FDC8000 to Mali address 0x4013D000 length 0x00001000
[ 1845.134102] Mali<4>: Mapping in 0xafdc9000 size 4096
[ 1845.139610] Mali<7>: Mapping phys 0x6FDC9000 length 0x00001000 at offset 0x0003E000
[ 1845.148125] Mali<7>: Mapping phys 0x6FDC9000 length 0x00001000 at offset 0x0003E000 to CPUVA 0x0003E000
[ 1845.158568] Mali<7>: Mali map: mapping 0x6FDC9000 to Mali address 0x4013E000 length 0x00001000
[ 1845.168146] Mali<4>: Mapping in 0xafdca000 size 4096
[ 1845.173672] Mali<7>: Mapping phys 0x6FDCA000 length 0x00001000 at offset 0x0003F000
[ 1845.182187] Mali<7>: Mapping phys 0x6FDCA000 length 0x00001000 at offset 0x0003F000 to CPUVA 0x0003F000
[ 1845.192631] Mali<7>: Mali map: mapping 0x6FDCA000 to Mali address 0x4013F000 length 0x00001000
[ 1845.202208] Mali<4>: Mapping in 0xafdcb000 size 4096
[ 1845.207715] Mali<7>: Mapping phys 0x6FDCB000 length 0x00001000 at offset 0x00040000
[ 1845.216231] Mali<7>: Mapping phys 0x6FDCB000 length 0x00001000 at offset 0x00040000 to CPUVA 0x00040000
[ 1845.226674] Mali<7>: Mali map: mapping 0x6FDCB000 to Mali address 0x40140000 length 0x00001000
[ 1845.236257] Mali<4>: Mapping in 0xafdcc000 size 4096
[ 1845.241782] Mali<7>: Mapping phys 0x6FDCC000 length 0x00001000 at offset 0x00041000
[ 1845.250296] Mali<7>: Mapping phys 0x6FDCC000 length 0x00001000 at offset 0x00041000 to CPUVA 0x00041000
[ 1845.260741] Mali<7>: Mali map: mapping 0x6FDCC000 to Mali address 0x40141000 length 0x00001000
[ 1845.270318] Mali<4>: Mapping in 0xafdcd000 size 4096
[ 1845.275825] Mali<7>: Mapping phys 0x6FDCD000 length 0x00001000 at offset 0x00042000
[ 1845.284339] Mali<7>: Mapping phys 0x6FDCD000 length 0x00001000 at offset 0x00042000 to CPUVA 0x00042000
[ 1845.294784] Mali<7>: Mali map: mapping 0x6FDCD000 to Mali address 0x40142000 length 0x00001000
[ 1845.304358] Mali<4>: Mapping in 0xafdce000 size 4096
[ 1845.309866] Mali<7>: Mapping phys 0x6FDCE000 length 0x00001000 at offset 0x00043000
[ 1845.318381] Mali<7>: Mapping phys 0x6FDCE000 length 0x00001000 at offset 0x00043000 to CPUVA 0x00043000
[ 1845.328826] Mali<7>: Mali map: mapping 0x6FDCE000 to Mali address 0x40143000 length 0x00001000
[ 1845.338404] Mali<4>: Mapping in 0xafdcf000 size 4096
[ 1845.343933] Mali<7>: Mapping phys 0x6FDCF000 length 0x00001000 at offset 0x00044000
[ 1845.352441] Mali<7>: Mapping phys 0x6FDCF000 length 0x00001000 at offset 0x00044000 to CPUVA 0x00044000
[ 1845.362887] Mali<7>: Mali map: mapping 0x6FDCF000 to Mali address 0x40144000 length 0x00001000
[ 1845.372468] Mali<4>: Mapping in 0xafa98000 size 4096
[ 1845.377977] Mali<7>: Mapping phys 0x6FA98000 length 0x00001000 at offset 0x00045000
[ 1845.386499] Mali<7>: Mapping phys 0x6FA98000 length 0x00001000 at offset 0x00045000 to CPUVA 0x00045000
[ 1845.396944] Mali<7>: Mali map: mapping 0x6FA98000 to Mali address 0x40145000 length 0x00001000
[ 1845.406519] Mali<4>: Mapping in 0xafa99000 size 4096
[ 1845.412045] Mali<7>: Mapping phys 0x6FA99000 length 0x00001000 at offset 0x00046000
[ 1845.420562] Mali<7>: Mapping phys 0x6FA99000 length 0x00001000 at offset 0x00046000 to CPUVA 0x00046000
[ 1845.431008] Mali<7>: Mali map: mapping 0x6FA99000 to Mali address 0x40146000 length 0x00001000
[ 1845.440585] Mali<4>: Mapping in 0xafa9a000 size 4096
[ 1845.446092] Mali<7>: Mapping phys 0x6FA9A000 length 0x00001000 at offset 0x00047000
[ 1845.454605] Mali<7>: Mapping phys 0x6FA9A000 length 0x00001000 at offset 0x00047000 to CPUVA 0x00047000
[ 1845.465050] Mali<7>: Mali map: mapping 0x6FA9A000 to Mali address 0x40147000 length 0x00001000
[ 1845.474627] Mali<4>: Mapping in 0xafa9b000 size 4096
[ 1845.480153] Mali<7>: Mapping phys 0x6FA9B000 length 0x00001000 at offset 0x00048000
[ 1845.488650] Mali<7>: Mapping phys 0x6FA9B000 length 0x00001000 at offset 0x00048000 to CPUVA 0x00048000
[ 1845.499101] Mali<7>: Mali map: mapping 0x6FA9B000 to Mali address 0x40148000 length 0x00001000
[ 1845.508678] Mali<4>: Mapping in 0xafa9c000 size 4096
[ 1845.514204] Mali<7>: Mapping phys 0x6FA9C000 length 0x00001000 at offset 0x00049000
[ 1845.522719] Mali<7>: Mapping phys 0x6FA9C000 length 0x00001000 at offset 0x00049000 to CPUVA 0x00049000
[ 1845.533164] Mali<7>: Mali map: mapping 0x6FA9C000 to Mali address 0x40149000 length 0x00001000
[ 1845.542741] Mali<4>: Mapping in 0xafa9d000 size 4096
[ 1845.548248] Mali<7>: Mapping phys 0x6FA9D000 length 0x00001000 at offset 0x0004A000
[ 1845.556762] Mali<7>: Mapping phys 0x6FA9D000 length 0x00001000 at offset 0x0004A000 to CPUVA 0x0004A000
[ 1845.567206] Mali<7>: Mali map: mapping 0x6FA9D000 to Mali address 0x4014A000 length 0x00001000
[ 1845.576783] Mali<4>: Mapping in 0xafa9e000 size 4096
[ 1845.582308] Mali<7>: Mapping phys 0x6FA9E000 length 0x00001000 at offset 0x0004B000
[ 1845.590825] Mali<7>: Mapping phys 0x6FA9E000 length 0x00001000 at offset 0x0004B000 to CPUVA 0x0004B000
[ 1845.601270] Mali<7>: Mali map: mapping 0x6FA9E000 to Mali address 0x4014B000 length 0x00001000
[ 1845.610846] Mali<4>: Mapping in 0xafa9f000 size 4096
[ 1845.616353] Mali<7>: Mapping phys 0x6FA9F000 length 0x00001000 at offset 0x0004C000
[ 1845.624867] Mali<7>: Mapping phys 0x6FA9F000 length 0x00001000 at offset 0x0004C000 to CPUVA 0x0004C000
[ 1845.635312] Mali<7>: Mali map: mapping 0x6FA9F000 to Mali address 0x4014C000 length 0x00001000
[ 1845.644888] Mali<4>: Mapping in 0xafac0000 size 4096
[ 1845.650412] Mali<7>: Mapping phys 0x6FAC0000 length 0x00001000 at offset 0x0004D000
[ 1845.658910] Mali<7>: Mapping phys 0x6FAC0000 length 0x00001000 at offset 0x0004D000 to CPUVA 0x0004D000
[ 1845.669354] Mali<7>: Mali map: mapping 0x6FAC0000 to Mali address 0x4014D000 length 0x00001000
[ 1845.678930] Mali<4>: Mapping in 0xafac1000 size 4096
[ 1845.684456] Mali<7>: Mapping phys 0x6FAC1000 length 0x00001000 at offset 0x0004E000
[ 1845.692970] Mali<7>: Mapping phys 0x6FAC1000 length 0x00001000 at offset 0x0004E000 to CPUVA 0x0004E000
[ 1845.703412] Mali<7>: Mali map: mapping 0x6FAC1000 to Mali address 0x4014E000 length 0x00001000
[ 1845.712989] Mali<4>: Mapping in 0xafac2000 size 4096
[ 1845.718497] Mali<7>: Mapping phys 0x6FAC2000 length 0x00001000 at offset 0x0004F000
[ 1845.727013] Mali<7>: Mapping phys 0x6FAC2000 length 0x00001000 at offset 0x0004F000 to CPUVA 0x0004F000
[ 1845.737480] Mali<7>: Mali map: mapping 0x6FAC2000 to Mali address 0x4014F000 length 0x00001000
[ 1845.747085] Mali<4>: Mapping in 0xafac3000 size 4096
[ 1845.752622] Mali<7>: Mapping phys 0x6FAC3000 length 0x00001000 at offset 0x00050000
[ 1845.761146] Mali<7>: Mapping phys 0x6FAC3000 length 0x00001000 at offset 0x00050000 to CPUVA 0x00050000
[ 1845.771635] Mali<7>: Mali map: mapping 0x6FAC3000 to Mali address 0x40150000 length 0x00001000
[ 1845.781230] Mali<4>: Mapping in 0xafac4000 size 4096
[ 1845.786740] Mali<7>: Mapping phys 0x6FAC4000 length 0x00001000 at offset 0x00051000
[ 1845.795259] Mali<7>: Mapping phys 0x6FAC4000 length 0x00001000 at offset 0x00051000 to CPUVA 0x00051000
[ 1845.805705] Mali<7>: Mali map: mapping 0x6FAC4000 to Mali address 0x40151000 length 0x00001000
[ 1845.815286] Mali<4>: Mapping in 0xafac5000 size 4096
[ 1845.820814] Mali<7>: Mapping phys 0x6FAC5000 length 0x00001000 at offset 0x00052000
[ 1845.829312] Mali<7>: Mapping phys 0x6FAC5000 length 0x00001000 at offset 0x00052000 to CPUVA 0x00052000
[ 1845.839757] Mali<7>: Mali map: mapping 0x6FAC5000 to Mali address 0x40152000 length 0x00001000
[ 1845.849337] Mali<4>: Mapping in 0xafac6000 size 4096
[ 1845.854862] Mali<7>: Mapping phys 0x6FAC6000 length 0x00001000 at offset 0x00053000
[ 1845.863378] Mali<7>: Mapping phys 0x6FAC6000 length 0x00001000 at offset 0x00053000 to CPUVA 0x00053000
[ 1845.873824] Mali<7>: Mali map: mapping 0x6FAC6000 to Mali address 0x40153000 length 0x00001000
[ 1845.883402] Mali<4>: Mapping in 0xafac7000 size 4096
[ 1845.888911] Mali<7>: Mapping phys 0x6FAC7000 length 0x00001000 at offset 0x00054000
[ 1845.897430] Mali<7>: Mapping phys 0x6FAC7000 length 0x00001000 at offset 0x00054000 to CPUVA 0x00054000
[ 1845.907874] Mali<7>: Mali map: mapping 0x6FAC7000 to Mali address 0x40154000 length 0x00001000
[ 1845.917454] Mali<4>: Mapping in 0xafac8000 size 4096
[ 1845.922980] Mali<7>: Mapping phys 0x6FAC8000 length 0x00001000 at offset 0x00055000
[ 1845.931498] Mali<7>: Mapping phys 0x6FAC8000 length 0x00001000 at offset 0x00055000 to CPUVA 0x00055000
[ 1845.941944] Mali<7>: Mali map: mapping 0x6FAC8000 to Mali address 0x40155000 length 0x00001000
[ 1845.951519] Mali<4>: Mapping in 0xafac9000 size 4096
[ 1845.957026] Mali<7>: Mapping phys 0x6FAC9000 length 0x00001000 at offset 0x00056000
[ 1845.965542] Mali<7>: Mapping phys 0x6FAC9000 length 0x00001000 at offset 0x00056000 to CPUVA 0x00056000
[ 1845.976037] Mali<7>: Mali map: mapping 0x6FAC9000 to Mali address 0x40156000 length 0x00001000
[ 1845.985619] Mali<4>: Mapping in 0xafaca000 size 4096
[ 1845.991146] Mali<7>: Mapping phys 0x6FACA000 length 0x00001000 at offset 0x00057000
[ 1845.999644] Mali<7>: Mapping phys 0x6FACA000 length 0x00001000 at offset 0x00057000 to CPUVA 0x00057000
[ 1846.010114] Mali<7>: Mali map: mapping 0x6FACA000 to Mali address 0x40157000 length 0x00001000
[ 1846.019673] Mali<4>: Mapping in 0xafacb000 size 4096
[ 1846.025201] Mali<7>: Mapping phys 0x6FACB000 length 0x00001000 at offset 0x00058000
[ 1846.033716] Mali<7>: Mapping phys 0x6FACB000 length 0x00001000 at offset 0x00058000 to CPUVA 0x00058000
[ 1846.044163] Mali<7>: Mali map: mapping 0x6FACB000 to Mali address 0x40158000 length 0x00001000
[ 1846.053739] Mali<4>: Mapping in 0xafacc000 size 4096
[ 1846.059248] Mali<7>: Mapping phys 0x6FACC000 length 0x00001000 at offset 0x00059000
[ 1846.067766] Mali<7>: Mapping phys 0x6FACC000 length 0x00001000 at offset 0x00059000 to CPUVA 0x00059000
[ 1846.078214] Mali<7>: Mali map: mapping 0x6FACC000 to Mali address 0x40159000 length 0x00001000
[ 1846.087792] Mali<4>: Mapping in 0xafacd000 size 4096
[ 1846.093321] Mali<7>: Mapping phys 0x6FACD000 length 0x00001000 at offset 0x0005A000
[ 1846.101838] Mali<7>: Mapping phys 0x6FACD000 length 0x00001000 at offset 0x0005A000 to CPUVA 0x0005A000
[ 1846.112285] Mali<7>: Mali map: mapping 0x6FACD000 to Mali address 0x4015A000 length 0x00001000
[ 1846.121862] Mali<4>: Mapping in 0xaface000 size 4096
[ 1846.127370] Mali<7>: Mapping phys 0x6FACE000 length 0x00001000 at offset 0x0005B000
[ 1846.135884] Mali<7>: Mapping phys 0x6FACE000 length 0x00001000 at offset 0x0005B000 to CPUVA 0x0005B000
[ 1846.146330] Mali<7>: Mali map: mapping 0x6FACE000 to Mali address 0x4015B000 length 0x00001000
[ 1846.155906] Mali<4>: Mapping in 0xafacf000 size 4096
[ 1846.161435] Mali<7>: Mapping phys 0x6FACF000 length 0x00001000 at offset 0x0005C000
[ 1846.169933] Mali<7>: Mapping phys 0x6FACF000 length 0x00001000 at offset 0x0005C000 to CPUVA 0x0005C000
[ 1846.180398] Mali<7>: Mali map: mapping 0x6FACF000 to Mali address 0x4015C000 length 0x00001000
[ 1846.189957] Mali<4>: Mapping in 0xafa80000 size 4096
[ 1846.195483] Mali<7>: Mapping phys 0x6FA80000 length 0x00001000 at offset 0x0005D000
[ 1846.203996] Mali<7>: Mapping phys 0x6FA80000 length 0x00001000 at offset 0x0005D000 to CPUVA 0x0005D000
[ 1846.214442] Mali<7>: Mali map: mapping 0x6FA80000 to Mali address 0x4015D000 length 0x00001000
[ 1846.224019] Mali<4>: Mapping in 0xafa81000 size 4096
[ 1846.229527] Mali<7>: Mapping phys 0x6FA81000 length 0x00001000 at offset 0x0005E000
[ 1846.238043] Mali<7>: Mapping phys 0x6FA81000 length 0x00001000 at offset 0x0005E000 to CPUVA 0x0005E000
[ 1846.248490] Mali<7>: Mali map: mapping 0x6FA81000 to Mali address 0x4015E000 length 0x00001000
[ 1846.258065] Mali<4>: Mapping in 0xafa82000 size 4096
[ 1846.263592] Mali<7>: Mapping phys 0x6FA82000 length 0x00001000 at offset 0x0005F000
[ 1846.272113] Mali<7>: Mapping phys 0x6FA82000 length 0x00001000 at offset 0x0005F000 to CPUVA 0x0005F000
[ 1846.282559] Mali<7>: Mali map: mapping 0x6FA82000 to Mali address 0x4015F000 length 0x00001000
[ 1846.292136] Mali<4>: Mapping in 0xafa83000 size 4096
[ 1846.297644] Mali<7>: Mapping phys 0x6FA83000 length 0x00001000 at offset 0x00060000
[ 1846.306156] Mali<7>: Mapping phys 0x6FA83000 length 0x00001000 at offset 0x00060000 to CPUVA 0x00060000
[ 1846.316602] Mali<7>: Mali map: mapping 0x6FA83000 to Mali address 0x40160000 length 0x00001000
[ 1846.326182] Mali<4>: Mapping in 0xafa84000 size 4096
[ 1846.331708] Mali<7>: Mapping phys 0x6FA84000 length 0x00001000 at offset 0x00061000
[ 1846.340224] Mali<7>: Mapping phys 0x6FA84000 length 0x00001000 at offset 0x00061000 to CPUVA 0x00061000
[ 1846.350667] Mali<7>: Mali map: mapping 0x6FA84000 to Mali address 0x40161000 length 0x00001000
[ 1846.360246] Mali<4>: Mapping in 0xafa85000 size 4096
[ 1846.365753] Mali<7>: Mapping phys 0x6FA85000 length 0x00001000 at offset 0x00062000
[ 1846.374268] Mali<7>: Mapping phys 0x6FA85000 length 0x00001000 at offset 0x00062000 to CPUVA 0x00062000
[ 1846.384715] Mali<7>: Mali map: mapping 0x6FA85000 to Mali address 0x40162000 length 0x00001000
[ 1846.394293] Mali<4>: Mapping in 0xafa86000 size 4096
[ 1846.399801] Mali<7>: Mapping phys 0x6FA86000 length 0x00001000 at offset 0x00063000
[ 1846.408315] Mali<7>: Mapping phys 0x6FA86000 length 0x00001000 at offset 0x00063000 to CPUVA 0x00063000
[ 1846.418760] Mali<7>: Mali map: mapping 0x6FA86000 to Mali address 0x40163000 length 0x00001000
[ 1846.428339] Mali<4>: Mapping in 0xafa87000 size 4096
[ 1846.433866] Mali<7>: Mapping phys 0x6FA87000 length 0x00001000 at offset 0x00064000
[ 1846.442381] Mali<7>: Mapping phys 0x6FA87000 length 0x00001000 at offset 0x00064000 to CPUVA 0x00064000
[ 1846.452823] Mali<7>: Mali map: mapping 0x6FA87000 to Mali address 0x40164000 length 0x00001000
[ 1846.462402] Mali<4>: Mapping in 0xafa88000 size 4096
[ 1846.467909] Mali<7>: Mapping phys 0x6FA88000 length 0x00001000 at offset 0x00065000
[ 1846.476425] Mali<7>: Mapping phys 0x6FA88000 length 0x00001000 at offset 0x00065000 to CPUVA 0x00065000
[ 1846.486859] Mali<7>: Mali map: mapping 0x6FA88000 to Mali address 0x40165000 length 0x00001000
[ 1846.496437] Mali<4>: Mapping in 0xafa89000 size 4096
[ 1846.501962] Mali<7>: Mapping phys 0x6FA89000 length 0x00001000 at offset 0x00066000
[ 1846.510478] Mali<7>: Mapping phys 0x6FA89000 length 0x00001000 at offset 0x00066000 to CPUVA 0x00066000
[ 1846.520924] Mali<7>: Mali map: mapping 0x6FA89000 to Mali address 0x40166000 length 0x00001000
[ 1846.530508] Mali<4>: Mapping in 0xafa8a000 size 4096
[ 1846.536015] Mali<7>: Mapping phys 0x6FA8A000 length 0x00001000 at offset 0x00067000
[ 1846.544531] Mali<7>: Mapping phys 0x6FA8A000 length 0x00001000 at offset 0x00067000 to CPUVA 0x00067000
[ 1846.554975] Mali<7>: Mali map: mapping 0x6FA8A000 to Mali address 0x40167000 length 0x00001000
[ 1846.564554] Mali<4>: Mapping in 0xafa8b000 size 4096
[ 1846.570081] Mali<7>: Mapping phys 0x6FA8B000 length 0x00001000 at offset 0x00068000
[ 1846.578579] Mali<7>: Mapping phys 0x6FA8B000 length 0x00001000 at offset 0x00068000 to CPUVA 0x00068000
[ 1846.589024] Mali<7>: Mali map: mapping 0x6FA8B000 to Mali address 0x40168000 length 0x00001000
[ 1846.598602] Mali<4>: Mapping in 0xafa8c000 size 4096
[ 1846.604128] Mali<7>: Mapping phys 0x6FA8C000 length 0x00001000 at offset 0x00069000
[ 1846.612644] Mali<7>: Mapping phys 0x6FA8C000 length 0x00001000 at offset 0x00069000 to CPUVA 0x00069000
[ 1846.623089] Mali<7>: Mali map: mapping 0x6FA8C000 to Mali address 0x40169000 length 0x00001000
[ 1846.632667] Mali<4>: Mapping in 0xafa8d000 size 4096
[ 1846.638174] Mali<7>: Mapping phys 0x6FA8D000 length 0x00001000 at offset 0x0006A000
[ 1846.646691] Mali<7>: Mapping phys 0x6FA8D000 length 0x00001000 at offset 0x0006A000 to CPUVA 0x0006A000
[ 1846.657132] Mali<7>: Mali map: mapping 0x6FA8D000 to Mali address 0x4016A000 length 0x00001000
[ 1846.666711] Mali<4>: Mapping in 0xafa8e000 size 4096
[ 1846.672236] Mali<7>: Mapping phys 0x6FA8E000 length 0x00001000 at offset 0x0006B000
[ 1846.680755] Mali<7>: Mapping phys 0x6FA8E000 length 0x00001000 at offset 0x0006B000 to CPUVA 0x0006B000
[ 1846.691201] Mali<7>: Mali map: mapping 0x6FA8E000 to Mali address 0x4016B000 length 0x00001000
[ 1846.700778] Mali<4>: Mapping in 0xafa8f000 size 4096
[ 1846.706286] Mali<7>: Mapping phys 0x6FA8F000 length 0x00001000 at offset 0x0006C000
[ 1846.714801] Mali<7>: Mapping phys 0x6FA8F000 length 0x00001000 at offset 0x0006C000 to CPUVA 0x0006C000
[ 1846.725246] Mali<7>: Mali map: mapping 0x6FA8F000 to Mali address 0x4016C000 length 0x00001000
[ 1846.734824] Mali<4>: Mapping in 0xaf800000 size 4096
[ 1846.740351] Mali<7>: Mapping phys 0x6F800000 length 0x00001000 at offset 0x0006D000
[ 1846.748850] Mali<7>: Mapping phys 0x6F800000 length 0x00001000 at offset 0x0006D000 to CPUVA 0x0006D000
[ 1846.759293] Mali<7>: Mali map: mapping 0x6F800000 to Mali address 0x4016D000 length 0x00001000
[ 1846.768871] Mali<4>: Mapping in 0xaf801000 size 4096
[ 1846.774399] Mali<7>: Mapping phys 0x6F801000 length 0x00001000 at offset 0x0006E000
[ 1846.782906] Mali<7>: Mapping phys 0x6F801000 length 0x00001000 at offset 0x0006E000 to CPUVA 0x0006E000
[ 1846.793357] Mali<7>: Mali map: mapping 0x6F801000 to Mali address 0x4016E000 length 0x00001000
[ 1846.802935] Mali<4>: Mapping in 0xaf802000 size 4096
[ 1846.808443] Mali<7>: Mapping phys 0x6F802000 length 0x00001000 at offset 0x0006F000
[ 1846.816959] Mali<7>: Mapping phys 0x6F802000 length 0x00001000 at offset 0x0006F000 to CPUVA 0x0006F000
[ 1846.827403] Mali<7>: Mali map: mapping 0x6F802000 to Mali address 0x4016F000 length 0x00001000
[ 1846.836978] Mali<4>: Mapping in 0xaf803000 size 4096
[ 1846.842503] Mali<7>: Mapping phys 0x6F803000 length 0x00001000 at offset 0x00070000
[ 1846.851018] Mali<7>: Mapping phys 0x6F803000 length 0x00001000 at offset 0x00070000 to CPUVA 0x00070000
[ 1846.861463] Mali<7>: Mali map: mapping 0x6F803000 to Mali address 0x40170000 length 0x00001000
[ 1846.871040] Mali<4>: Mapping in 0xaf804000 size 4096
[ 1846.876548] Mali<7>: Mapping phys 0x6F804000 length 0x00001000 at offset 0x00071000
[ 1846.885113] Mali<7>: Mapping phys 0x6F804000 length 0x00001000 at offset 0x00071000 to CPUVA 0x00071000
[ 1846.895686] Mali<7>: Mali map: mapping 0x6F804000 to Mali address 0x40171000 length 0x00001000
[ 1846.905382] Mali<4>: Mapping in 0xaf805000 size 4096
[ 1846.910941] Mali<7>: Mapping phys 0x6F805000 length 0x00001000 at offset 0x00072000
[ 1846.919442] Mali<7>: Mapping phys 0x6F805000 length 0x00001000 at offset 0x00072000 to CPUVA 0x00072000
[ 1846.929893] Mali<7>: Mali map: mapping 0x6F805000 to Mali address 0x40172000 length 0x00001000
[ 1846.939478] Mali<4>: Mapping in 0xaf806000 size 4096
[ 1846.945007] Mali<7>: Mapping phys 0x6F806000 length 0x00001000 at offset 0x00073000
[ 1846.953530] Mali<7>: Mapping phys 0x6F806000 length 0x00001000 at offset 0x00073000 to CPUVA 0x00073000
[ 1846.963982] Mali<7>: Mali map: mapping 0x6F806000 to Mali address 0x40173000 length 0x00001000
[ 1846.973716] Mali<4>: Mapping in 0xaf807000 size 4096
[ 1846.979228] Mali<7>: Mapping phys 0x6F807000 length 0x00001000 at offset 0x00074000
[ 1846.987756] Mali<7>: Mapping phys 0x6F807000 length 0x00001000 at offset 0x00074000 to CPUVA 0x00074000
[ 1846.998206] Mali<7>: Mali map: mapping 0x6F807000 to Mali address 0x40174000 length 0x00001000
[ 1847.007783] Mali<4>: Mapping in 0xaf808000 size 4096
[ 1847.013309] Mali<7>: Mapping phys 0x6F808000 length 0x00001000 at offset 0x00075000
[ 1847.021828] Mali<7>: Mapping phys 0x6F808000 length 0x00001000 at offset 0x00075000 to CPUVA 0x00075000
[ 1847.032276] Mali<7>: Mali map: mapping 0x6F808000 to Mali address 0x40175000 length 0x00001000
[ 1847.041855] Mali<4>: Mapping in 0xaf809000 size 4096
[ 1847.047363] Mali<7>: Mapping phys 0x6F809000 length 0x00001000 at offset 0x00076000
[ 1847.055882] Mali<7>: Mapping phys 0x6F809000 length 0x00001000 at offset 0x00076000 to CPUVA 0x00076000
[ 1847.066332] Mali<7>: Mali map: mapping 0x6F809000 to Mali address 0x40176000 length 0x00001000
[ 1847.075911] Mali<4>: Mapping in 0xaf80a000 size 4096
[ 1847.081436] Mali<7>: Mapping phys 0x6F80A000 length 0x00001000 at offset 0x00077000
[ 1847.089934] Mali<7>: Mapping phys 0x6F80A000 length 0x00001000 at offset 0x00077000 to CPUVA 0x00077000
[ 1847.100401] Mali<7>: Mali map: mapping 0x6F80A000 to Mali address 0x40177000 length 0x00001000
[ 1847.109960] Mali<4>: Mapping in 0xaf80b000 size 4096
[ 1847.115487] Mali<7>: Mapping phys 0x6F80B000 length 0x00001000 at offset 0x00078000
[ 1847.124004] Mali<7>: Mapping phys 0x6F80B000 length 0x00001000 at offset 0x00078000 to CPUVA 0x00078000
[ 1847.134451] Mali<7>: Mali map: mapping 0x6F80B000 to Mali address 0x40178000 length 0x00001000
[ 1847.144030] Mali<4>: Mapping in 0xaf80c000 size 4096
[ 1847.149539] Mali<7>: Mapping phys 0x6F80C000 length 0x00001000 at offset 0x00079000
[ 1847.158053] Mali<7>: Mapping phys 0x6F80C000 length 0x00001000 at offset 0x00079000 to CPUVA 0x00079000
[ 1847.168499] Mali<7>: Mali map: mapping 0x6F80C000 to Mali address 0x40179000 length 0x00001000
[ 1847.178077] Mali<4>: Mapping in 0xaf80d000 size 4096
[ 1847.183605] Mali<7>: Mapping phys 0x6F80D000 length 0x00001000 at offset 0x0007A000
[ 1847.192121] Mali<7>: Mapping phys 0x6F80D000 length 0x00001000 at offset 0x0007A000 to CPUVA 0x0007A000
[ 1847.202569] Mali<7>: Mali map: mapping 0x6F80D000 to Mali address 0x4017A000 length 0x00001000
[ 1847.212146] Mali<4>: Mapping in 0xaf80e000 size 4096
[ 1847.217654] Mali<7>: Mapping phys 0x6F80E000 length 0x00001000 at offset 0x0007B000
[ 1847.226170] Mali<7>: Mapping phys 0x6F80E000 length 0x00001000 at offset 0x0007B000 to CPUVA 0x0007B000
[ 1847.236614] Mali<7>: Mali map: mapping 0x6F80E000 to Mali address 0x4017B000 length 0x00001000
[ 1847.246191] Mali<4>: Mapping in 0xaf80f000 size 4096
[ 1847.251717] Mali<7>: Mapping phys 0x6F80F000 length 0x00001000 at offset 0x0007C000
[ 1847.260236] Mali<7>: Mapping phys 0x6F80F000 length 0x00001000 at offset 0x0007C000 to CPUVA 0x0007C000
[ 1847.270683] Mali<7>: Mali map: mapping 0x6F80F000 to Mali address 0x4017C000 length 0x00001000
[ 1847.280260] Mali<4>: Mapping in 0xaf810000 size 4096
[ 1847.285769] Mali<7>: Mapping phys 0x6F810000 length 0x00001000 at offset 0x0007D000
[ 1847.294284] Mali<7>: Mapping phys 0x6F810000 length 0x00001000 at offset 0x0007D000 to CPUVA 0x0007D000
[ 1847.304729] Mali<7>: Mali map: mapping 0x6F810000 to Mali address 0x4017D000 length 0x00001000
[ 1847.314313] Mali<4>: Mapping in 0xaf811000 size 4096
[ 1847.319822] Mali<7>: Mapping phys 0x6F811000 length 0x00001000 at offset 0x0007E000
[ 1847.328340] Mali<7>: Mapping phys 0x6F811000 length 0x00001000 at offset 0x0007E000 to CPUVA 0x0007E000
[ 1847.338787] Mali<7>: Mali map: mapping 0x6F811000 to Mali address 0x4017E000 length 0x00001000
[ 1847.348371] Mali<4>: Mapping in 0xaf812000 size 4096
[ 1847.353897] Mali<7>: Mapping phys 0x6F812000 length 0x00001000 at offset 0x0007F000
[ 1847.362415] Mali<7>: Mapping phys 0x6F812000 length 0x00001000 at offset 0x0007F000 to CPUVA 0x0007F000
[ 1847.372861] Mali<7>: Mali map: mapping 0x6F812000 to Mali address 0x4017F000 length 0x00001000
[ 1847.382441] Mali<4>: Mapping in 0xaf813000 size 4096
[ 1847.387949] Mali<7>: Mapping phys 0x6F813000 length 0x00001000 at offset 0x00080000
[ 1847.396466] Mali<7>: Mapping phys 0x6F813000 length 0x00001000 at offset 0x00080000 to CPUVA 0x00080000
[ 1847.406908] Mali<7>: Mali map: mapping 0x6F813000 to Mali address 0x40180000 length 0x00001000
[ 1847.416486] Mali<4>: Mapping in 0xaf814000 size 4096
[ 1847.422011] Mali<7>: Mapping phys 0x6F814000 length 0x00001000 at offset 0x00081000
[ 1847.430528] Mali<7>: Mapping phys 0x6F814000 length 0x00001000 at offset 0x00081000 to CPUVA 0x00081000
[ 1847.440973] Mali<7>: Mali map: mapping 0x6F814000 to Mali address 0x40181000 length 0x00001000
[ 1847.450548] Mali<4>: Mapping in 0xaf815000 size 4096
[ 1847.456056] Mali<7>: Mapping phys 0x6F815000 length 0x00001000 at offset 0x00082000
[ 1847.464571] Mali<7>: Mapping phys 0x6F815000 length 0x00001000 at offset 0x00082000 to CPUVA 0x00082000
[ 1847.475017] Mali<7>: Mali map: mapping 0x6F815000 to Mali address 0x40182000 length 0x00001000
[ 1847.484596] Mali<4>: Mapping in 0xaf816000 size 4096
[ 1847.490123] Mali<7>: Mapping phys 0x6F816000 length 0x00001000 at offset 0x00083000
[ 1847.498620] Mali<7>: Mapping phys 0x6F816000 length 0x00001000 at offset 0x00083000 to CPUVA 0x00083000
[ 1847.509067] Mali<7>: Mali map: mapping 0x6F816000 to Mali address 0x40183000 length 0x00001000
[ 1847.518645] Mali<4>: Mapping in 0xaf817000 size 4096
[ 1847.524173] Mali<7>: Mapping phys 0x6F817000 length 0x00001000 at offset 0x00084000
[ 1847.532688] Mali<7>: Mapping phys 0x6F817000 length 0x00001000 at offset 0x00084000 to CPUVA 0x00084000
[ 1847.543134] Mali<7>: Mali map: mapping 0x6F817000 to Mali address 0x40184000 length 0x00001000
[ 1847.552709] Mali<4>: Mapping in 0xaf818000 size 4096
[ 1847.558217] Mali<7>: Mapping phys 0x6F818000 length 0x00001000 at offset 0x00085000
[ 1847.566734] Mali<7>: Mapping phys 0x6F818000 length 0x00001000 at offset 0x00085000 to CPUVA 0x00085000
[ 1847.577185] Mali<7>: Mali map: mapping 0x6F818000 to Mali address 0x40185000 length 0x00001000
[ 1847.586763] Mali<4>: Mapping in 0xaf819000 size 4096
[ 1847.592288] Mali<7>: Mapping phys 0x6F819000 length 0x00001000 at offset 0x00086000
[ 1847.600806] Mali<7>: Mapping phys 0x6F819000 length 0x00001000 at offset 0x00086000 to CPUVA 0x00086000
[ 1847.611252] Mali<7>: Mali map: mapping 0x6F819000 to Mali address 0x40186000 length 0x00001000
[ 1847.620829] Mali<4>: Mapping in 0xaf81a000 size 4096
[ 1847.626337] Mali<7>: Mapping phys 0x6F81A000 length 0x00001000 at offset 0x00087000
[ 1847.634852] Mali<7>: Mapping phys 0x6F81A000 length 0x00001000 at offset 0x00087000 to CPUVA 0x00087000
[ 1847.645299] Mali<7>: Mali map: mapping 0x6F81A000 to Mali address 0x40187000 length 0x00001000
[ 1847.654874] Mali<4>: Mapping in 0xaf81b000 size 4096
[ 1847.660401] Mali<7>: Mapping phys 0x6F81B000 length 0x00001000 at offset 0x00088000
[ 1847.668898] Mali<7>: Mapping phys 0x6F81B000 length 0x00001000 at offset 0x00088000 to CPUVA 0x00088000
[ 1847.679344] Mali<7>: Mali map: mapping 0x6F81B000 to Mali address 0x40188000 length 0x00001000
[ 1847.688922] Mali<4>: Mapping in 0xaf81c000 size 4096
[ 1847.694448] Mali<7>: Mapping phys 0x6F81C000 length 0x00001000 at offset 0x00089000
[ 1847.702961] Mali<7>: Mapping phys 0x6F81C000 length 0x00001000 at offset 0x00089000 to CPUVA 0x00089000
[ 1847.713407] Mali<7>: Mali map: mapping 0x6F81C000 to Mali address 0x40189000 length 0x00001000
[ 1847.722984] Mali<4>: Mapping in 0xaf81d000 size 4096
[ 1847.728492] Mali<7>: Mapping phys 0x6F81D000 length 0x00001000 at offset 0x0008A000
[ 1847.737008] Mali<7>: Mapping phys 0x6F81D000 length 0x00001000 at offset 0x0008A000 to CPUVA 0x0008A000
[ 1847.747452] Mali<7>: Mali map: mapping 0x6F81D000 to Mali address 0x4018A000 length 0x00001000
[ 1847.757027] Mali<4>: Mapping in 0xaf81e000 size 4096
[ 1847.762556] Mali<7>: Mapping phys 0x6F81E000 length 0x00001000 at offset 0x0008B000
[ 1847.771073] Mali<7>: Mapping phys 0x6F81E000 length 0x00001000 at offset 0x0008B000 to CPUVA 0x0008B000
[ 1847.781519] Mali<7>: Mali map: mapping 0x6F81E000 to Mali address 0x4018B000 length 0x00001000
[ 1847.791097] Mali<4>: Mapping in 0xaf81f000 size 4096
[ 1847.796605] Mali<7>: Mapping phys 0x6F81F000 length 0x00001000 at offset 0x0008C000
[ 1847.805119] Mali<7>: Mapping phys 0x6F81F000 length 0x00001000 at offset 0x0008C000 to CPUVA 0x0008C000
[ 1847.815564] Mali<7>: Mali map: mapping 0x6F81F000 to Mali address 0x4018C000 length 0x00001000
[ 1847.825142] Mali<4>: Mapping in 0xaf820000 size 4096
[ 1847.830677] Mali<7>: Mapping phys 0x6F820000 length 0x00001000 at offset 0x0008D000
[ 1847.839174] Mali<7>: Mapping phys 0x6F820000 length 0x00001000 at offset 0x0008D000 to CPUVA 0x0008D000
[ 1847.849621] Mali<7>: Mali map: mapping 0x6F820000 to Mali address 0x4018D000 length 0x00001000
[ 1847.859197] Mali<4>: Mapping in 0xaf821000 size 4096
[ 1847.864725] Mali<7>: Mapping phys 0x6F821000 length 0x00001000 at offset 0x0008E000
[ 1847.873241] Mali<7>: Mapping phys 0x6F821000 length 0x00001000 at offset 0x0008E000 to CPUVA 0x0008E000
[ 1847.883686] Mali<7>: Mali map: mapping 0x6F821000 to Mali address 0x4018E000 length 0x00001000
[ 1847.893265] Mali<4>: Mapping in 0xaf822000 size 4096
[ 1847.898774] Mali<7>: Mapping phys 0x6F822000 length 0x00001000 at offset 0x0008F000
[ 1847.907289] Mali<7>: Mapping phys 0x6F822000 length 0x00001000 at offset 0x0008F000 to CPUVA 0x0008F000
[ 1847.917734] Mali<7>: Mali map: mapping 0x6F822000 to Mali address 0x4018F000 length 0x00001000
[ 1847.927311] Mali<4>: Mapping in 0xaf823000 size 4096
[ 1847.932837] Mali<7>: Mapping phys 0x6F823000 length 0x00001000 at offset 0x00090000
[ 1847.941354] Mali<7>: Mapping phys 0x6F823000 length 0x00001000 at offset 0x00090000 to CPUVA 0x00090000
[ 1847.951798] Mali<7>: Mali map: mapping 0x6F823000 to Mali address 0x40190000 length 0x00001000
[ 1847.961377] Mali<4>: Mapping in 0xaf824000 size 4096
[ 1847.966886] Mali<7>: Mapping phys 0x6F824000 length 0x00001000 at offset 0x00091000
[ 1847.975437] Mali<7>: Mapping phys 0x6F824000 length 0x00001000 at offset 0x00091000 to CPUVA 0x00091000
[ 1847.985889] Mali<7>: Mali map: mapping 0x6F824000 to Mali address 0x40191000 length 0x00001000
[ 1847.995469] Mali<4>: Mapping in 0xaf825000 size 4096
[ 1848.000995] Mali<7>: Mapping phys 0x6F825000 length 0x00001000 at offset 0x00092000
[ 1848.009493] Mali<7>: Mapping phys 0x6F825000 length 0x00001000 at offset 0x00092000 to CPUVA 0x00092000
[ 1848.019943] Mali<7>: Mali map: mapping 0x6F825000 to Mali address 0x40192000 length 0x00001000
[ 1848.029522] Mali<4>: Mapping in 0xaf826000 size 4096
[ 1848.035072] Mali<7>: Mapping phys 0x6F826000 length 0x00001000 at offset 0x00093000
[ 1848.043589] Mali<7>: Mapping phys 0x6F826000 length 0x00001000 at offset 0x00093000 to CPUVA 0x00093000
[ 1848.054036] Mali<7>: Mali map: mapping 0x6F826000 to Mali address 0x40193000 length 0x00001000
[ 1848.063619] Mali<4>: Mapping in 0xaf827000 size 4096
[ 1848.069127] Mali<7>: Mapping phys 0x6F827000 length 0x00001000 at offset 0x00094000
[ 1848.077646] Mali<7>: Mapping phys 0x6F827000 length 0x00001000 at offset 0x00094000 to CPUVA 0x00094000
[ 1848.088088] Mali<7>: Mali map: mapping 0x6F827000 to Mali address 0x40194000 length 0x00001000
[ 1848.097671] Mali<4>: Mapping in 0xaf828000 size 4096
[ 1848.103195] Mali<7>: Mapping phys 0x6F828000 length 0x00001000 at offset 0x00095000
[ 1848.111713] Mali<7>: Mapping phys 0x6F828000 length 0x00001000 at offset 0x00095000 to CPUVA 0x00095000
[ 1848.122159] Mali<7>: Mali map: mapping 0x6F828000 to Mali address 0x40195000 length 0x00001000
[ 1848.131738] Mali<4>: Mapping in 0xaf829000 size 4096
[ 1848.137246] Mali<7>: Mapping phys 0x6F829000 length 0x00001000 at offset 0x00096000
[ 1848.145761] Mali<7>: Mapping phys 0x6F829000 length 0x00001000 at offset 0x00096000 to CPUVA 0x00096000
[ 1848.156206] Mali<7>: Mali map: mapping 0x6F829000 to Mali address 0x40196000 length 0x00001000
[ 1848.165786] Mali<4>: Mapping in 0xaf82a000 size 4096
[ 1848.171312] Mali<7>: Mapping phys 0x6F82A000 length 0x00001000 at offset 0x00097000
[ 1848.179809] Mali<7>: Mapping phys 0x6F82A000 length 0x00001000 at offset 0x00097000 to CPUVA 0x00097000
[ 1848.190273] Mali<7>: Mali map: mapping 0x6F82A000 to Mali address 0x40197000 length 0x00001000
[ 1848.199832] Mali<4>: Mapping in 0xaf82b000 size 4096
[ 1848.205358] Mali<7>: Mapping phys 0x6F82B000 length 0x00001000 at offset 0x00098000
[ 1848.213874] Mali<7>: Mapping phys 0x6F82B000 length 0x00001000 at offset 0x00098000 to CPUVA 0x00098000
[ 1848.224319] Mali<7>: Mali map: mapping 0x6F82B000 to Mali address 0x40198000 length 0x00001000
[ 1848.233897] Mali<4>: Mapping in 0xaf82c000 size 4096
[ 1848.239405] Mali<7>: Mapping phys 0x6F82C000 length 0x00001000 at offset 0x00099000
[ 1848.247922] Mali<7>: Mapping phys 0x6F82C000 length 0x00001000 at offset 0x00099000 to CPUVA 0x00099000
[ 1848.258357] Mali<7>: Mali map: mapping 0x6F82C000 to Mali address 0x40199000 length 0x00001000
[ 1848.267935] Mali<4>: Mapping in 0xaf82d000 size 4096
[ 1848.273463] Mali<7>: Mapping phys 0x6F82D000 length 0x00001000 at offset 0x0009A000
[ 1848.281978] Mali<7>: Mapping phys 0x6F82D000 length 0x00001000 at offset 0x0009A000 to CPUVA 0x0009A000
[ 1848.292423] Mali<7>: Mali map: mapping 0x6F82D000 to Mali address 0x4019A000 length 0x00001000
[ 1848.302000] Mali<4>: Mapping in 0xaf82e000 size 4096
[ 1848.307508] Mali<7>: Mapping phys 0x6F82E000 length 0x00001000 at offset 0x0009B000
[ 1848.316023] Mali<7>: Mapping phys 0x6F82E000 length 0x00001000 at offset 0x0009B000 to CPUVA 0x0009B000
[ 1848.326468] Mali<7>: Mali map: mapping 0x6F82E000 to Mali address 0x4019B000 length 0x00001000
[ 1848.336046] Mali<4>: Mapping in 0xaf82f000 size 4096
[ 1848.341572] Mali<7>: Mapping phys 0x6F82F000 length 0x00001000 at offset 0x0009C000
[ 1848.350092] Mali<7>: Mapping phys 0x6F82F000 length 0x00001000 at offset 0x0009C000 to CPUVA 0x0009C000
[ 1848.360539] Mali<7>: Mali map: mapping 0x6F82F000 to Mali address 0x4019C000 length 0x00001000
[ 1848.370118] Mali<4>: Mapping in 0xaf830000 size 4096
[ 1848.375625] Mali<7>: Mapping phys 0x6F830000 length 0x00001000 at offset 0x0009D000
[ 1848.384141] Mali<7>: Mapping phys 0x6F830000 length 0x00001000 at offset 0x0009D000 to CPUVA 0x0009D000
[ 1848.394587] Mali<7>: Mali map: mapping 0x6F830000 to Mali address 0x4019D000 length 0x00001000
[ 1848.404162] Mali<4>: Mapping in 0xaf831000 size 4096
[ 1848.409670] Mali<7>: Mapping phys 0x6F831000 length 0x00001000 at offset 0x0009E000
[ 1848.418187] Mali<7>: Mapping phys 0x6F831000 length 0x00001000 at offset 0x0009E000 to CPUVA 0x0009E000
[ 1848.428633] Mali<7>: Mali map: mapping 0x6F831000 to Mali address 0x4019E000 length 0x00001000
[ 1848.438210] Mali<4>: Mapping in 0xaf832000 size 4096
[ 1848.443737] Mali<7>: Mapping phys 0x6F832000 length 0x00001000 at offset 0x0009F000
[ 1848.452250] Mali<7>: Mapping phys 0x6F832000 length 0x00001000 at offset 0x0009F000 to CPUVA 0x0009F000
[ 1848.462696] Mali<7>: Mali map: mapping 0x6F832000 to Mali address 0x4019F000 length 0x00001000
[ 1848.472273] Mali<4>: Mapping in 0xaf833000 size 4096
[ 1848.477781] Mali<7>: Mapping phys 0x6F833000 length 0x00001000 at offset 0x000A0000
[ 1848.486298] Mali<7>: Mapping phys 0x6F833000 length 0x00001000 at offset 0x000A0000 to CPUVA 0x000A0000
[ 1848.496742] Mali<7>: Mali map: mapping 0x6F833000 to Mali address 0x401A0000 length 0x00001000
[ 1848.506317] Mali<4>: Mapping in 0xaf834000 size 4096
[ 1848.511843] Mali<7>: Mapping phys 0x6F834000 length 0x00001000 at offset 0x000A1000
[ 1848.520360] Mali<7>: Mapping phys 0x6F834000 length 0x00001000 at offset 0x000A1000 to CPUVA 0x000A1000
[ 1848.530805] Mali<7>: Mali map: mapping 0x6F834000 to Mali address 0x401A1000 length 0x00001000
[ 1848.540383] Mali<4>: Mapping in 0xaf835000 size 4096
[ 1848.545890] Mali<7>: Mapping phys 0x6F835000 length 0x00001000 at offset 0x000A2000
[ 1848.554403] Mali<7>: Mapping phys 0x6F835000 length 0x00001000 at offset 0x000A2000 to CPUVA 0x000A2000
[ 1848.564849] Mali<7>: Mali map: mapping 0x6F835000 to Mali address 0x401A2000 length 0x00001000
[ 1848.574427] Mali<4>: Mapping in 0xaf836000 size 4096
[ 1848.579935] Mali<7>: Mapping phys 0x6F836000 length 0x00001000 at offset 0x000A3000
[ 1848.588451] Mali<7>: Mapping phys 0x6F836000 length 0x00001000 at offset 0x000A3000 to CPUVA 0x000A3000
[ 1848.598897] Mali<7>: Mali map: mapping 0x6F836000 to Mali address 0x401A3000 length 0x00001000
[ 1848.608475] Mali<4>: Mapping in 0xaf837000 size 4096
[ 1848.614008] Mali<7>: Mapping phys 0x6F837000 length 0x00001000 at offset 0x000A4000
[ 1848.622524] Mali<7>: Mapping phys 0x6F837000 length 0x00001000 at offset 0x000A4000 to CPUVA 0x000A4000
[ 1848.632971] Mali<7>: Mali map: mapping 0x6F837000 to Mali address 0x401A4000 length 0x00001000
[ 1848.642549] Mali<4>: Mapping in 0xaf838000 size 4096
[ 1848.648057] Mali<7>: Mapping phys 0x6F838000 length 0x00001000 at offset 0x000A5000
[ 1848.656571] Mali<7>: Mapping phys 0x6F838000 length 0x00001000 at offset 0x000A5000 to CPUVA 0x000A5000
[ 1848.667015] Mali<7>: Mali map: mapping 0x6F838000 to Mali address 0x401A5000 length 0x00001000
[ 1848.676591] Mali<4>: Mapping in 0xaf839000 size 4096
[ 1848.682120] Mali<7>: Mapping phys 0x6F839000 length 0x00001000 at offset 0x000A6000
[ 1848.690638] Mali<7>: Mapping phys 0x6F839000 length 0x00001000 at offset 0x000A6000 to CPUVA 0x000A6000
[ 1848.701085] Mali<7>: Mali map: mapping 0x6F839000 to Mali address 0x401A6000 length 0x00001000
[ 1848.710663] Mali<4>: Mapping in 0xaf83a000 size 4096
[ 1848.716171] Mali<7>: Mapping phys 0x6F83A000 length 0x00001000 at offset 0x000A7000
[ 1848.724686] Mali<7>: Mapping phys 0x6F83A000 length 0x00001000 at offset 0x000A7000 to CPUVA 0x000A7000
[ 1848.735133] Mali<7>: Mali map: mapping 0x6F83A000 to Mali address 0x401A7000 length 0x00001000
[ 1848.744712] Mali<4>: Mapping in 0xaf83b000 size 4096
[ 1848.750237] Mali<7>: Mapping phys 0x6F83B000 length 0x00001000 at offset 0x000A8000
[ 1848.758735] Mali<7>: Mapping phys 0x6F83B000 length 0x00001000 at offset 0x000A8000 to CPUVA 0x000A8000
[ 1848.769183] Mali<7>: Mali map: mapping 0x6F83B000 to Mali address 0x401A8000 length 0x00001000
[ 1848.778762] Mali<4>: Mapping in 0xaf83c000 size 4096
[ 1848.784289] Mali<7>: Mapping phys 0x6F83C000 length 0x00001000 at offset 0x000A9000
[ 1848.792806] Mali<7>: Mapping phys 0x6F83C000 length 0x00001000 at offset 0x000A9000 to CPUVA 0x000A9000
[ 1848.803250] Mali<7>: Mali map: mapping 0x6F83C000 to Mali address 0x401A9000 length 0x00001000
[ 1848.812828] Mali<4>: Mapping in 0xaf83d000 size 4096
[ 1848.818336] Mali<7>: Mapping phys 0x6F83D000 length 0x00001000 at offset 0x000AA000
[ 1848.826853] Mali<7>: Mapping phys 0x6F83D000 length 0x00001000 at offset 0x000AA000 to CPUVA 0x000AA000
[ 1848.837287] Mali<7>: Mali map: mapping 0x6F83D000 to Mali address 0x401AA000 length 0x00001000
[ 1848.846864] Mali<4>: Mapping in 0xaf83e000 size 4096
[ 1848.852389] Mali<7>: Mapping phys 0x6F83E000 length 0x00001000 at offset 0x000AB000
[ 1848.860905] Mali<7>: Mapping phys 0x6F83E000 length 0x00001000 at offset 0x000AB000 to CPUVA 0x000AB000
[ 1848.871357] Mali<7>: Mali map: mapping 0x6F83E000 to Mali address 0x401AB000 length 0x00001000
[ 1848.880933] Mali<4>: Mapping in 0xaf83f000 size 4096
[ 1848.886441] Mali<7>: Mapping phys 0x6F83F000 length 0x00001000 at offset 0x000AC000
[ 1848.894957] Mali<7>: Mapping phys 0x6F83F000 length 0x00001000 at offset 0x000AC000 to CPUVA 0x000AC000
[ 1848.905405] Mali<7>: Mali map: mapping 0x6F83F000 to Mali address 0x401AC000 length 0x00001000
[ 1848.914985] Mali<4>: Mapping in 0xaf840000 size 4096
[ 1848.920514] Mali<7>: Mapping phys 0x6F840000 length 0x00001000 at offset 0x000AD000
[ 1848.929013] Mali<7>: Mapping phys 0x6F840000 length 0x00001000 at offset 0x000AD000 to CPUVA 0x000AD000
[ 1848.939459] Mali<7>: Mali map: mapping 0x6F840000 to Mali address 0x401AD000 length 0x00001000
[ 1848.949029] Mali<4>: Mapping in 0xaf841000 size 4096
[ 1848.954554] Mali<7>: Mapping phys 0x6F841000 length 0x00001000 at offset 0x000AE000
[ 1848.963070] Mali<7>: Mapping phys 0x6F841000 length 0x00001000 at offset 0x000AE000 to CPUVA 0x000AE000
[ 1848.973763] Mali<7>: Mali map: mapping 0x6F841000 to Mali address 0x401AE000 length 0x00001000
[ 1848.983357] Mali<4>: Mapping in 0xaf842000 size 4096
[ 1848.988866] Mali<7>: Mapping phys 0x6F842000 length 0x00001000 at offset 0x000AF000
[ 1848.997385] Mali<7>: Mapping phys 0x6F842000 length 0x00001000 at offset 0x000AF000 to CPUVA 0x000AF000
[ 1849.007829] Mali<7>: Mali map: mapping 0x6F842000 to Mali address 0x401AF000 length 0x00001000
[ 1849.017410] Mali<4>: Mapping in 0xaf843000 size 4096
[ 1849.022937] Mali<7>: Mapping phys 0x6F843000 length 0x00001000 at offset 0x000B0000
[ 1849.031454] Mali<7>: Mapping phys 0x6F843000 length 0x00001000 at offset 0x000B0000 to CPUVA 0x000B0000
[ 1849.041900] Mali<7>: Mali map: mapping 0x6F843000 to Mali address 0x401B0000 length 0x00001000
[ 1849.051475] Mali<4>: Mapping in 0xaf844000 size 4096
[ 1849.056983] Mali<7>: Mapping phys 0x6F844000 length 0x00001000 at offset 0x000B1000
[ 1849.065498] Mali<7>: Mapping phys 0x6F844000 length 0x00001000 at offset 0x000B1000 to CPUVA 0x000B1000
[ 1849.075944] Mali<7>: Mali map: mapping 0x6F844000 to Mali address 0x401B1000 length 0x00001000
[ 1849.085521] Mali<4>: Mapping in 0xaf845000 size 4096
[ 1849.091047] Mali<7>: Mapping phys 0x6F845000 length 0x00001000 at offset 0x000B2000
[ 1849.099544] Mali<7>: Mapping phys 0x6F845000 length 0x00001000 at offset 0x000B2000 to CPUVA 0x000B2000
[ 1849.109991] Mali<7>: Mali map: mapping 0x6F845000 to Mali address 0x401B2000 length 0x00001000
[ 1849.119569] Mali<4>: Mapping in 0xaf846000 size 4096
[ 1849.125096] Mali<7>: Mapping phys 0x6F846000 length 0x00001000 at offset 0x000B3000
[ 1849.133617] Mali<7>: Mapping phys 0x6F846000 length 0x00001000 at offset 0x000B3000 to CPUVA 0x000B3000
[ 1849.144064] Mali<7>: Mali map: mapping 0x6F846000 to Mali address 0x401B3000 length 0x00001000
[ 1849.153639] Mali<4>: Mapping in 0xaf847000 size 4096
[ 1849.159147] Mali<7>: Mapping phys 0x6F847000 length 0x00001000 at offset 0x000B4000
[ 1849.167664] Mali<7>: Mapping phys 0x6F847000 length 0x00001000 at offset 0x000B4000 to CPUVA 0x000B4000
[ 1849.178109] Mali<7>: Mali map: mapping 0x6F847000 to Mali address 0x401B4000 length 0x00001000
[ 1849.187686] Mali<4>: Mapping in 0xaf848000 size 4096
[ 1849.193212] Mali<7>: Mapping phys 0x6F848000 length 0x00001000 at offset 0x000B5000
[ 1849.201728] Mali<7>: Mapping phys 0x6F848000 length 0x00001000 at offset 0x000B5000 to CPUVA 0x000B5000
[ 1849.212176] Mali<7>: Mali map: mapping 0x6F848000 to Mali address 0x401B5000 length 0x00001000
[ 1849.221754] Mali<4>: Mapping in 0xaf849000 size 4096
[ 1849.227261] Mali<7>: Mapping phys 0x6F849000 length 0x00001000 at offset 0x000B6000
[ 1849.235776] Mali<7>: Mapping phys 0x6F849000 length 0x00001000 at offset 0x000B6000 to CPUVA 0x000B6000
[ 1849.246222] Mali<7>: Mali map: mapping 0x6F849000 to Mali address 0x401B6000 length 0x00001000
[ 1849.255797] Mali<4>: Mapping in 0xaf84a000 size 4096
[ 1849.261324] Mali<7>: Mapping phys 0x6F84A000 length 0x00001000 at offset 0x000B7000
[ 1849.269822] Mali<7>: Mapping phys 0x6F84A000 length 0x00001000 at offset 0x000B7000 to CPUVA 0x000B7000
[ 1849.280287] Mali<7>: Mali map: mapping 0x6F84A000 to Mali address 0x401B7000 length 0x00001000
[ 1849.289846] Mali<4>: Mapping in 0xaf84b000 size 4096
[ 1849.295372] Mali<7>: Mapping phys 0x6F84B000 length 0x00001000 at offset 0x000B8000
[ 1849.303886] Mali<7>: Mapping phys 0x6F84B000 length 0x00001000 at offset 0x000B8000 to CPUVA 0x000B8000
[ 1849.314332] Mali<7>: Mali map: mapping 0x6F84B000 to Mali address 0x401B8000 length 0x00001000
[ 1849.323909] Mali<4>: Mapping in 0xaf84c000 size 4096
[ 1849.329417] Mali<7>: Mapping phys 0x6F84C000 length 0x00001000 at offset 0x000B9000
[ 1849.337934] Mali<7>: Mapping phys 0x6F84C000 length 0x00001000 at offset 0x000B9000 to CPUVA 0x000B9000
[ 1849.348383] Mali<7>: Mali map: mapping 0x6F84C000 to Mali address 0x401B9000 length 0x00001000
[ 1849.357962] Mali<4>: Mapping in 0xaf84d000 size 4096
[ 1849.363494] Mali<7>: Mapping phys 0x6F84D000 length 0x00001000 at offset 0x000BA000
[ 1849.372013] Mali<7>: Mapping phys 0x6F84D000 length 0x00001000 at offset 0x000BA000 to CPUVA 0x000BA000
[ 1849.382460] Mali<7>: Mali map: mapping 0x6F84D000 to Mali address 0x401BA000 length 0x00001000
[ 1849.392046] Mali<4>: Mapping in 0xaf84e000 size 4096
[ 1849.397555] Mali<7>: Mapping phys 0x6F84E000 length 0x00001000 at offset 0x000BB000
[ 1849.406068] Mali<7>: Mapping phys 0x6F84E000 length 0x00001000 at offset 0x000BB000 to CPUVA 0x000BB000
[ 1849.416515] Mali<7>: Mali map: mapping 0x6F84E000 to Mali address 0x401BB000 length 0x00001000
[ 1849.426092] Mali<4>: Mapping in 0xaf84f000 size 4096
[ 1849.431617] Mali<7>: Mapping phys 0x6F84F000 length 0x00001000 at offset 0x000BC000
[ 1849.440134] Mali<7>: Mapping phys 0x6F84F000 length 0x00001000 at offset 0x000BC000 to CPUVA 0x000BC000
[ 1849.450577] Mali<7>: Mali map: mapping 0x6F84F000 to Mali address 0x401BC000 length 0x00001000
[ 1849.460155] Mali<4>: Mapping in 0xaf850000 size 4096
[ 1849.465662] Mali<7>: Mapping phys 0x6F850000 length 0x00001000 at offset 0x000BD000
[ 1849.474177] Mali<7>: Mapping phys 0x6F850000 length 0x00001000 at offset 0x000BD000 to CPUVA 0x000BD000
[ 1849.484623] Mali<7>: Mali map: mapping 0x6F850000 to Mali address 0x401BD000 length 0x00001000
[ 1849.494202] Mali<4>: Mapping in 0xaf851000 size 4096
[ 1849.499710] Mali<7>: Mapping phys 0x6F851000 length 0x00001000 at offset 0x000BE000
[ 1849.508228] Mali<7>: Mapping phys 0x6F851000 length 0x00001000 at offset 0x000BE000 to CPUVA 0x000BE000
[ 1849.518675] Mali<7>: Mali map: mapping 0x6F851000 to Mali address 0x401BE000 length 0x00001000
[ 1849.528245] Mali<4>: Mapping in 0xaf852000 size 4096
[ 1849.533771] Mali<7>: Mapping phys 0x6F852000 length 0x00001000 at offset 0x000BF000
[ 1849.542287] Mali<7>: Mapping phys 0x6F852000 length 0x00001000 at offset 0x000BF000 to CPUVA 0x000BF000
[ 1849.552731] Mali<7>: Mali map: mapping 0x6F852000 to Mali address 0x401BF000 length 0x00001000
[ 1849.562310] Mali<4>: Mapping in 0xaf853000 size 4096
[ 1849.567818] Mali<7>: Mapping phys 0x6F853000 length 0x00001000 at offset 0x000C0000
[ 1849.576335] Mali<7>: Mapping phys 0x6F853000 length 0x00001000 at offset 0x000C0000 to CPUVA 0x000C0000
[ 1849.586777] Mali<7>: Mali map: mapping 0x6F853000 to Mali address 0x401C0000 length 0x00001000
[ 1849.596357] Mali<4>: Mapping in 0xaf854000 size 4096
[ 1849.601883] Mali<7>: Mapping phys 0x6F854000 length 0x00001000 at offset 0x000C1000
[ 1849.610401] Mali<7>: Mapping phys 0x6F854000 length 0x00001000 at offset 0x000C1000 to CPUVA 0x000C1000
[ 1849.620846] Mali<7>: Mali map: mapping 0x6F854000 to Mali address 0x401C1000 length 0x00001000
[ 1849.630424] Mali<4>: Mapping in 0xaf855000 size 4096
[ 1849.635932] Mali<7>: Mapping phys 0x6F855000 length 0x00001000 at offset 0x000C2000
[ 1849.644448] Mali<7>: Mapping phys 0x6F855000 length 0x00001000 at offset 0x000C2000 to CPUVA 0x000C2000
[ 1849.654900] Mali<7>: Mali map: mapping 0x6F855000 to Mali address 0x401C2000 length 0x00001000
[ 1849.664478] Mali<4>: Mapping in 0xaf856000 size 4096
[ 1849.669986] Mali<7>: Mapping phys 0x6F856000 length 0x00001000 at offset 0x000C3000
[ 1849.678502] Mali<7>: Mapping phys 0x6F856000 length 0x00001000 at offset 0x000C3000 to CPUVA 0x000C3000
[ 1849.688949] Mali<7>: Mali map: mapping 0x6F856000 to Mali address 0x401C3000 length 0x00001000
[ 1849.698528] Mali<4>: Mapping in 0xaf857000 size 4096
[ 1849.704055] Mali<7>: Mapping phys 0x6F857000 length 0x00001000 at offset 0x000C4000
[ 1849.712569] Mali<7>: Mapping phys 0x6F857000 length 0x00001000 at offset 0x000C4000 to CPUVA 0x000C4000
[ 1849.723015] Mali<7>: Mali map: mapping 0x6F857000 to Mali address 0x401C4000 length 0x00001000
[ 1849.732593] Mali<4>: Mapping in 0xaf858000 size 4096
[ 1849.738101] Mali<7>: Mapping phys 0x6F858000 length 0x00001000 at offset 0x000C5000
[ 1849.746620] Mali<7>: Mapping phys 0x6F858000 length 0x00001000 at offset 0x000C5000 to CPUVA 0x000C5000
[ 1849.757062] Mali<7>: Mali map: mapping 0x6F858000 to Mali address 0x401C5000 length 0x00001000
[ 1849.766640] Mali<4>: Mapping in 0xaf859000 size 4096
[ 1849.772166] Mali<7>: Mapping phys 0x6F859000 length 0x00001000 at offset 0x000C6000
[ 1849.780684] Mali<7>: Mapping phys 0x6F859000 length 0x00001000 at offset 0x000C6000 to CPUVA 0x000C6000
[ 1849.791132] Mali<7>: Mali map: mapping 0x6F859000 to Mali address 0x401C6000 length 0x00001000
[ 1849.800712] Mali<4>: Mapping in 0xaf85a000 size 4096
[ 1849.806219] Mali<7>: Mapping phys 0x6F85A000 length 0x00001000 at offset 0x000C7000
[ 1849.814735] Mali<7>: Mapping phys 0x6F85A000 length 0x00001000 at offset 0x000C7000 to CPUVA 0x000C7000
[ 1849.825182] Mali<7>: Mali map: mapping 0x6F85A000 to Mali address 0x401C7000 length 0x00001000
[ 1849.834760] Mali<4>: Mapping in 0xaf85b000 size 4096
[ 1849.840288] Mali<7>: Mapping phys 0x6F85B000 length 0x00001000 at offset 0x000C8000
[ 1849.848786] Mali<7>: Mapping phys 0x6F85B000 length 0x00001000 at offset 0x000C8000 to CPUVA 0x000C8000
[ 1849.859229] Mali<7>: Mali map: mapping 0x6F85B000 to Mali address 0x401C8000 length 0x00001000
[ 1849.868808] Mali<4>: Mapping in 0xaf85c000 size 4096
[ 1849.874333] Mali<7>: Mapping phys 0x6F85C000 length 0x00001000 at offset 0x000C9000
[ 1849.882849] Mali<7>: Mapping phys 0x6F85C000 length 0x00001000 at offset 0x000C9000 to CPUVA 0x000C9000
[ 1849.893297] Mali<7>: Mali map: mapping 0x6F85C000 to Mali address 0x401C9000 length 0x00001000
[ 1849.902874] Mali<4>: Mapping in 0xaf85d000 size 4096
[ 1849.908382] Mali<7>: Mapping phys 0x6F85D000 length 0x00001000 at offset 0x000CA000
[ 1849.916905] Mali<7>: Mapping phys 0x6F85D000 length 0x00001000 at offset 0x000CA000 to CPUVA 0x000CA000
[ 1849.927351] Mali<7>: Mali map: mapping 0x6F85D000 to Mali address 0x401CA000 length 0x00001000
[ 1849.936928] Mali<4>: Mapping in 0xaf85e000 size 4096
[ 1849.942454] Mali<7>: Mapping phys 0x6F85E000 length 0x00001000 at offset 0x000CB000
[ 1849.950968] Mali<7>: Mapping phys 0x6F85E000 length 0x00001000 at offset 0x000CB000 to CPUVA 0x000CB000
[ 1849.961416] Mali<7>: Mali map: mapping 0x6F85E000 to Mali address 0x401CB000 length 0x00001000
[ 1849.971030] Mali<4>: Mapping in 0xaf85f000 size 4096
[ 1849.976539] Mali<7>: Mapping phys 0x6F85F000 length 0x00001000 at offset 0x000CC000
[ 1849.985057] Mali<7>: Mapping phys 0x6F85F000 length 0x00001000 at offset 0x000CC000 to CPUVA 0x000CC000
[ 1849.995504] Mali<7>: Mali map: mapping 0x6F85F000 to Mali address 0x401CC000 length 0x00001000
[ 1850.005081] Mali<4>: Mapping in 0xaf860000 size 4096
[ 1850.010609] Mali<7>: Mapping phys 0x6F860000 length 0x00001000 at offset 0x000CD000
[ 1850.019106] Mali<7>: Mapping phys 0x6F860000 length 0x00001000 at offset 0x000CD000 to CPUVA 0x000CD000
[ 1850.029551] Mali<7>: Mali map: mapping 0x6F860000 to Mali address 0x401CD000 length 0x00001000
[ 1850.039132] Mali<4>: Mapping in 0xaf861000 size 4096
[ 1850.044660] Mali<7>: Mapping phys 0x6F861000 length 0x00001000 at offset 0x000CE000
[ 1850.053175] Mali<7>: Mapping phys 0x6F861000 length 0x00001000 at offset 0x000CE000 to CPUVA 0x000CE000
[ 1850.063624] Mali<7>: Mali map: mapping 0x6F861000 to Mali address 0x401CE000 length 0x00001000
[ 1850.073204] Mali<4>: Mapping in 0xaf862000 size 4096
[ 1850.078713] Mali<7>: Mapping phys 0x6F862000 length 0x00001000 at offset 0x000CF000
[ 1850.087231] Mali<7>: Mapping phys 0x6F862000 length 0x00001000 at offset 0x000CF000 to CPUVA 0x000CF000
[ 1850.097675] Mali<7>: Mali map: mapping 0x6F862000 to Mali address 0x401CF000 length 0x00001000
[ 1850.107250] Mali<4>: Mapping in 0xaf863000 size 4096
[ 1850.112777] Mali<7>: Mapping phys 0x6F863000 length 0x00001000 at offset 0x000D0000
[ 1850.121294] Mali<7>: Mapping phys 0x6F863000 length 0x00001000 at offset 0x000D0000 to CPUVA 0x000D0000
[ 1850.131742] Mali<7>: Mali map: mapping 0x6F863000 to Mali address 0x401D0000 length 0x00001000
[ 1850.141321] Mali<4>: Mapping in 0xaf864000 size 4096
[ 1850.146829] Mali<7>: Mapping phys 0x6F864000 length 0x00001000 at offset 0x000D1000
[ 1850.155344] Mali<7>: Mapping phys 0x6F864000 length 0x00001000 at offset 0x000D1000 to CPUVA 0x000D1000
[ 1850.165793] Mali<7>: Mali map: mapping 0x6F864000 to Mali address 0x401D1000 length 0x00001000
[ 1850.175380] Mali<4>: Mapping in 0xaf865000 size 4096
[ 1850.180909] Mali<7>: Mapping phys 0x6F865000 length 0x00001000 at offset 0x000D2000
[ 1850.189406] Mali<7>: Mapping phys 0x6F865000 length 0x00001000 at offset 0x000D2000 to CPUVA 0x000D2000
[ 1850.199854] Mali<7>: Mali map: mapping 0x6F865000 to Mali address 0x401D2000 length 0x00001000
[ 1850.209432] Mali<4>: Mapping in 0xaf866000 size 4096
[ 1850.214959] Mali<7>: Mapping phys 0x6F866000 length 0x00001000 at offset 0x000D3000
[ 1850.223475] Mali<7>: Mapping phys 0x6F866000 length 0x00001000 at offset 0x000D3000 to CPUVA 0x000D3000
[ 1850.233921] Mali<7>: Mali map: mapping 0x6F866000 to Mali address 0x401D3000 length 0x00001000
[ 1850.243498] Mali<4>: Mapping in 0xaf867000 size 4096
[ 1850.249006] Mali<7>: Mapping phys 0x6F867000 length 0x00001000 at offset 0x000D4000
[ 1850.257521] Mali<7>: Mapping phys 0x6F867000 length 0x00001000 at offset 0x000D4000 to CPUVA 0x000D4000
[ 1850.267965] Mali<7>: Mali map: mapping 0x6F867000 to Mali address 0x401D4000 length 0x00001000
[ 1850.277543] Mali<4>: Mapping in 0xaf868000 size 4096
[ 1850.283068] Mali<7>: Mapping phys 0x6F868000 length 0x00001000 at offset 0x000D5000
[ 1850.291585] Mali<7>: Mapping phys 0x6F868000 length 0x00001000 at offset 0x000D5000 to CPUVA 0x000D5000
[ 1850.302030] Mali<7>: Mali map: mapping 0x6F868000 to Mali address 0x401D5000 length 0x00001000
[ 1850.311608] Mali<4>: Mapping in 0xaf869000 size 4096
[ 1850.317115] Mali<7>: Mapping phys 0x6F869000 length 0x00001000 at offset 0x000D6000
[ 1850.325630] Mali<7>: Mapping phys 0x6F869000 length 0x00001000 at offset 0x000D6000 to CPUVA 0x000D6000
[ 1850.336074] Mali<7>: Mali map: mapping 0x6F869000 to Mali address 0x401D6000 length 0x00001000
[ 1850.345652] Mali<4>: Mapping in 0xaf86a000 size 4096
[ 1850.351176] Mali<7>: Mapping phys 0x6F86A000 length 0x00001000 at offset 0x000D7000
[ 1850.359674] Mali<7>: Mapping phys 0x6F86A000 length 0x00001000 at offset 0x000D7000 to CPUVA 0x000D7000
[ 1850.370141] Mali<7>: Mali map: mapping 0x6F86A000 to Mali address 0x401D7000 length 0x00001000
[ 1850.379700] Mali<4>: Mapping in 0xaf86b000 size 4096
[ 1850.385226] Mali<7>: Mapping phys 0x6F86B000 length 0x00001000 at offset 0x000D8000
[ 1850.393741] Mali<7>: Mapping phys 0x6F86B000 length 0x00001000 at offset 0x000D8000 to CPUVA 0x000D8000
[ 1850.404184] Mali<7>: Mali map: mapping 0x6F86B000 to Mali address 0x401D8000 length 0x00001000
[ 1850.413764] Mali<4>: Mapping in 0xaf86c000 size 4096
[ 1850.419271] Mali<7>: Mapping phys 0x6F86C000 length 0x00001000 at offset 0x000D9000
[ 1850.427789] Mali<7>: Mapping phys 0x6F86C000 length 0x00001000 at offset 0x000D9000 to CPUVA 0x000D9000
[ 1850.438240] Mali<7>: Mali map: mapping 0x6F86C000 to Mali address 0x401D9000 length 0x00001000
[ 1850.447819] Mali<4>: Mapping in 0xaf86d000 size 4096
[ 1850.453344] Mali<7>: Mapping phys 0x6F86D000 length 0x00001000 at offset 0x000DA000
[ 1850.461859] Mali<7>: Mapping phys 0x6F86D000 length 0x00001000 at offset 0x000DA000 to CPUVA 0x000DA000
[ 1850.472306] Mali<7>: Mali map: mapping 0x6F86D000 to Mali address 0x401DA000 length 0x00001000
[ 1850.481883] Mali<4>: Mapping in 0xaf86e000 size 4096
[ 1850.487391] Mali<7>: Mapping phys 0x6F86E000 length 0x00001000 at offset 0x000DB000
[ 1850.495905] Mali<7>: Mapping phys 0x6F86E000 length 0x00001000 at offset 0x000DB000 to CPUVA 0x000DB000
[ 1850.506350] Mali<7>: Mali map: mapping 0x6F86E000 to Mali address 0x401DB000 length 0x00001000
[ 1850.515928] Mali<4>: Mapping in 0xaf86f000 size 4096
[ 1850.521454] Mali<7>: Mapping phys 0x6F86F000 length 0x00001000 at offset 0x000DC000
[ 1850.529951] Mali<7>: Mapping phys 0x6F86F000 length 0x00001000 at offset 0x000DC000 to CPUVA 0x000DC000
[ 1850.540416] Mali<7>: Mali map: mapping 0x6F86F000 to Mali address 0x401DC000 length 0x00001000
[ 1850.549974] Mali<4>: Mapping in 0xaf870000 size 4096
[ 1850.555497] Mali<7>: Mapping phys 0x6F870000 length 0x00001000 at offset 0x000DD000
[ 1850.564013] Mali<7>: Mapping phys 0x6F870000 length 0x00001000 at offset 0x000DD000 to CPUVA 0x000DD000
[ 1850.574459] Mali<7>: Mali map: mapping 0x6F870000 to Mali address 0x401DD000 length 0x00001000
[ 1850.584037] Mali<4>: Mapping in 0xaf871000 size 4096
[ 1850.589545] Mali<7>: Mapping phys 0x6F871000 length 0x00001000 at offset 0x000DE000
[ 1850.598062] Mali<7>: Mapping phys 0x6F871000 length 0x00001000 at offset 0x000DE000 to CPUVA 0x000DE000
[ 1850.608507] Mali<7>: Mali map: mapping 0x6F871000 to Mali address 0x401DE000 length 0x00001000
[ 1850.618085] Mali<4>: Mapping in 0xaf872000 size 4096
[ 1850.623612] Mali<7>: Mapping phys 0x6F872000 length 0x00001000 at offset 0x000DF000
[ 1850.632126] Mali<7>: Mapping phys 0x6F872000 length 0x00001000 at offset 0x000DF000 to CPUVA 0x000DF000
[ 1850.642572] Mali<7>: Mali map: mapping 0x6F872000 to Mali address 0x401DF000 length 0x00001000
[ 1850.652146] Mali<4>: Mapping in 0xaf873000 size 4096
[ 1850.657655] Mali<7>: Mapping phys 0x6F873000 length 0x00001000 at offset 0x000E0000
[ 1850.666171] Mali<7>: Mapping phys 0x6F873000 length 0x00001000 at offset 0x000E0000 to CPUVA 0x000E0000
[ 1850.676617] Mali<7>: Mali map: mapping 0x6F873000 to Mali address 0x401E0000 length 0x00001000
[ 1850.686192] Mali<4>: Mapping in extra guard page
[ 1850.691336] Mali<7>: Mapping phys 0x6FD9D000 length 0x00001000 at offset 0x000E1000
[ 1850.699834] Mali<7>: Mapping phys 0x6FD9D000 length 0x00001000 at offset 0x000E1000 to CPUVA 0x000E1000
[ 1850.710299] Mali<7>: Mali map: mapping 0x6FD9D000 to Mali address 0x401E1000 length 0x00001000
[ 1850.719862] Mali<5>: Returning from UMP attach
[ 1850.724975] Mali<4>: MMap() handler: start=0xB50E1000, phys=0x40040000, size=0x00040000
[ 1850.733906] Mali<6>: Allocating page array of size 256 bytes
[ 1850.740209] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00000000
[ 1850.748709] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E1000 length 0x00001000
[ 1850.758883] Mali<7>: Mapping phys 0x6FAEE000 length 0x00001000 at offset 0x00000000 to CPUVA 0xB50E1000
[ 1850.769339] Mali<7>: Mali map: mapping 0x6FAEE000 to Mali address 0x40040000 length 0x00001000
[ 1850.778919] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00001000
[ 1850.787437] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E2000 length 0x00001000
[ 1850.797612] Mali<7>: Mapping phys 0x6FAEF000 length 0x00001000 at offset 0x00001000 to CPUVA 0xB50E2000
[ 1850.808060] Mali<7>: Mali map: mapping 0x6FAEF000 to Mali address 0x40041000 length 0x00001000
[ 1850.817641] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00002000
[ 1850.826157] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E3000 length 0x00001000
[ 1850.836334] Mali<7>: Mapping phys 0x6F88D000 length 0x00001000 at offset 0x00002000 to CPUVA 0xB50E3000
[ 1850.846785] Mali<7>: Mali map: mapping 0x6F88D000 to Mali address 0x40042000 length 0x00001000
[ 1850.856360] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00003000
[ 1850.864877] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E4000 length 0x00001000
[ 1850.875046] Mali<7>: Mapping phys 0x6F88E000 length 0x00001000 at offset 0x00003000 to CPUVA 0xB50E4000
[ 1850.885496] Mali<7>: Mali map: mapping 0x6F88E000 to Mali address 0x40043000 length 0x00001000
[ 1850.895076] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00004000
[ 1850.903592] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E5000 length 0x00001000
[ 1850.913764] Mali<7>: Mapping phys 0x6F88F000 length 0x00001000 at offset 0x00004000 to CPUVA 0xB50E5000
[ 1850.924217] Mali<7>: Mali map: mapping 0x6F88F000 to Mali address 0x40044000 length 0x00001000
[ 1850.933797] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00005000
[ 1850.942315] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E6000 length 0x00001000
[ 1850.952488] Mali<7>: Mapping phys 0x6F890000 length 0x00001000 at offset 0x00005000 to CPUVA 0xB50E6000
[ 1850.962944] Mali<7>: Mali map: mapping 0x6F890000 to Mali address 0x40045000 length 0x00001000
[ 1850.972649] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00006000
[ 1850.981176] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E7000 length 0x00001000
[ 1850.991350] Mali<7>: Mapping phys 0x6F891000 length 0x00001000 at offset 0x00006000 to CPUVA 0xB50E7000
[ 1851.001804] Mali<7>: Mali map: mapping 0x6F891000 to Mali address 0x40046000 length 0x00001000
[ 1851.011383] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00007000
[ 1851.019881] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E8000 length 0x00001000
[ 1851.030074] Mali<7>: Mapping phys 0x6F892000 length 0x00001000 at offset 0x00007000 to CPUVA 0xB50E8000
[ 1851.040525] Mali<7>: Mali map: mapping 0x6F892000 to Mali address 0x40047000 length 0x00001000
[ 1851.050102] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00008000
[ 1851.058601] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E9000 length 0x00001000
[ 1851.068771] Mali<7>: Mapping phys 0x6F893000 length 0x00001000 at offset 0x00008000 to CPUVA 0xB50E9000
[ 1851.079228] Mali<7>: Mali map: mapping 0x6F893000 to Mali address 0x40048000 length 0x00001000
[ 1851.088806] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00009000
[ 1851.097324] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50EA000 length 0x00001000
[ 1851.107490] Mali<7>: Mapping phys 0x6F894000 length 0x00001000 at offset 0x00009000 to CPUVA 0xB50EA000
[ 1851.117941] Mali<7>: Mali map: mapping 0x6F894000 to Mali address 0x40049000 length 0x00001000
[ 1851.127519] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000A000
[ 1851.136032] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50EB000 length 0x00001000
[ 1851.146200] Mali<7>: Mapping phys 0x6F895000 length 0x00001000 at offset 0x0000A000 to CPUVA 0xB50EB000
[ 1851.156650] Mali<7>: Mali map: mapping 0x6F895000 to Mali address 0x4004A000 length 0x00001000
[ 1851.166229] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000B000
[ 1851.174745] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50EC000 length 0x00001000
[ 1851.184914] Mali<7>: Mapping phys 0x6F896000 length 0x00001000 at offset 0x0000B000 to CPUVA 0xB50EC000
[ 1851.195366] Mali<7>: Mali map: mapping 0x6F896000 to Mali address 0x4004B000 length 0x00001000
[ 1851.204942] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000C000
[ 1851.213465] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50ED000 length 0x00001000
[ 1851.223634] Mali<7>: Mapping phys 0x6F897000 length 0x00001000 at offset 0x0000C000 to CPUVA 0xB50ED000
[ 1851.234085] Mali<7>: Mali map: mapping 0x6F897000 to Mali address 0x4004C000 length 0x00001000
[ 1851.243664] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000D000
[ 1851.252179] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50EE000 length 0x00001000
[ 1851.262347] Mali<7>: Mapping phys 0x6F898000 length 0x00001000 at offset 0x0000D000 to CPUVA 0xB50EE000
[ 1851.272799] Mali<7>: Mali map: mapping 0x6F898000 to Mali address 0x4004D000 length 0x00001000
[ 1851.282377] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000E000
[ 1851.290894] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50EF000 length 0x00001000
[ 1851.301063] Mali<7>: Mapping phys 0x6F899000 length 0x00001000 at offset 0x0000E000 to CPUVA 0xB50EF000
[ 1851.311515] Mali<7>: Mali map: mapping 0x6F899000 to Mali address 0x4004E000 length 0x00001000
[ 1851.321094] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000F000
[ 1851.329591] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F0000 length 0x00001000
[ 1851.339762] Mali<7>: Mapping phys 0x6F89A000 length 0x00001000 at offset 0x0000F000 to CPUVA 0xB50F0000
[ 1851.350236] Mali<7>: Mali map: mapping 0x6F89A000 to Mali address 0x4004F000 length 0x00001000
[ 1851.359795] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00010000
[ 1851.368312] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F1000 length 0x00001000
[ 1851.378482] Mali<7>: Mapping phys 0x6F89B000 length 0x00001000 at offset 0x00010000 to CPUVA 0xB50F1000
[ 1851.388934] Mali<7>: Mali map: mapping 0x6F89B000 to Mali address 0x40050000 length 0x00001000
[ 1851.398511] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00011000
[ 1851.407026] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F2000 length 0x00001000
[ 1851.417195] Mali<7>: Mapping phys 0x6F89C000 length 0x00001000 at offset 0x00011000 to CPUVA 0xB50F2000
[ 1851.427647] Mali<7>: Mali map: mapping 0x6F89C000 to Mali address 0x40051000 length 0x00001000
[ 1851.437222] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00012000
[ 1851.445739] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F3000 length 0x00001000
[ 1851.455906] Mali<7>: Mapping phys 0x6F89D000 length 0x00001000 at offset 0x00012000 to CPUVA 0xB50F3000
[ 1851.466358] Mali<7>: Mali map: mapping 0x6F89D000 to Mali address 0x40052000 length 0x00001000
[ 1851.475942] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00013000
[ 1851.484458] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F4000 length 0x00001000
[ 1851.494626] Mali<7>: Mapping phys 0x6F89E000 length 0x00001000 at offset 0x00013000 to CPUVA 0xB50F4000
[ 1851.505075] Mali<7>: Mali map: mapping 0x6F89E000 to Mali address 0x40053000 length 0x00001000
[ 1851.514654] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00014000
[ 1851.523171] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F5000 length 0x00001000
[ 1851.533341] Mali<7>: Mapping phys 0x6F89F000 length 0x00001000 at offset 0x00014000 to CPUVA 0xB50F5000
[ 1851.543793] Mali<7>: Mali map: mapping 0x6F89F000 to Mali address 0x40054000 length 0x00001000
[ 1851.553369] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00015000
[ 1851.561886] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F6000 length 0x00001000
[ 1851.572057] Mali<7>: Mapping phys 0x6F8A0000 length 0x00001000 at offset 0x00015000 to CPUVA 0xB50F6000
[ 1851.582508] Mali<7>: Mali map: mapping 0x6F8A0000 to Mali address 0x40055000 length 0x00001000
[ 1851.592086] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00016000
[ 1851.600604] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F7000 length 0x00001000
[ 1851.610773] Mali<7>: Mapping phys 0x6F8A1000 length 0x00001000 at offset 0x00016000 to CPUVA 0xB50F7000
[ 1851.621223] Mali<7>: Mali map: mapping 0x6F8A1000 to Mali address 0x40056000 length 0x00001000
[ 1851.630801] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00017000
[ 1851.639299] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F8000 length 0x00001000
[ 1851.649469] Mali<7>: Mapping phys 0x6F8A2000 length 0x00001000 at offset 0x00017000 to CPUVA 0xB50F8000
[ 1851.659919] Mali<7>: Mali map: mapping 0x6F8A2000 to Mali address 0x40057000 length 0x00001000
[ 1851.669497] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00018000
[ 1851.678013] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50F9000 length 0x00001000
[ 1851.688182] Mali<7>: Mapping phys 0x6F8A3000 length 0x00001000 at offset 0x00018000 to CPUVA 0xB50F9000
[ 1851.698633] Mali<7>: Mali map: mapping 0x6F8A3000 to Mali address 0x40058000 length 0x00001000
[ 1851.708211] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00019000
[ 1851.716729] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FA000 length 0x00001000
[ 1851.726896] Mali<7>: Mapping phys 0x6F8A4000 length 0x00001000 at offset 0x00019000 to CPUVA 0xB50FA000
[ 1851.737350] Mali<7>: Mali map: mapping 0x6F8A4000 to Mali address 0x40059000 length 0x00001000
[ 1851.746929] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001A000
[ 1851.755443] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FB000 length 0x00001000
[ 1851.765613] Mali<7>: Mapping phys 0x6F8A5000 length 0x00001000 at offset 0x0001A000 to CPUVA 0xB50FB000
[ 1851.776065] Mali<7>: Mali map: mapping 0x6F8A5000 to Mali address 0x4005A000 length 0x00001000
[ 1851.785641] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001B000
[ 1851.794160] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FC000 length 0x00001000
[ 1851.804327] Mali<7>: Mapping phys 0x6F8A6000 length 0x00001000 at offset 0x0001B000 to CPUVA 0xB50FC000
[ 1851.814778] Mali<7>: Mali map: mapping 0x6F8A6000 to Mali address 0x4005B000 length 0x00001000
[ 1851.824357] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001C000
[ 1851.832874] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FD000 length 0x00001000
[ 1851.843043] Mali<7>: Mapping phys 0x6F8A7000 length 0x00001000 at offset 0x0001C000 to CPUVA 0xB50FD000
[ 1851.853492] Mali<7>: Mali map: mapping 0x6F8A7000 to Mali address 0x4005C000 length 0x00001000
[ 1851.863070] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001D000
[ 1851.871586] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FE000 length 0x00001000
[ 1851.881754] Mali<7>: Mapping phys 0x6F8A8000 length 0x00001000 at offset 0x0001D000 to CPUVA 0xB50FE000
[ 1851.892209] Mali<7>: Mali map: mapping 0x6F8A8000 to Mali address 0x4005D000 length 0x00001000
[ 1851.901786] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001E000
[ 1851.910306] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50FF000 length 0x00001000
[ 1851.920477] Mali<7>: Mapping phys 0x6F8A9000 length 0x00001000 at offset 0x0001E000 to CPUVA 0xB50FF000
[ 1851.930928] Mali<7>: Mali map: mapping 0x6F8A9000 to Mali address 0x4005E000 length 0x00001000
[ 1851.940506] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001F000
[ 1851.949004] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5100000 length 0x00001000
[ 1851.959176] Mali<7>: Mapping phys 0x6F8AA000 length 0x00001000 at offset 0x0001F000 to CPUVA 0xB5100000
[ 1851.969633] Mali<7>: Mali map: mapping 0x6F8AA000 to Mali address 0x4005F000 length 0x00001000
[ 1851.979258] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00020000
[ 1851.987780] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5101000 length 0x00001000
[ 1851.997963] Mali<7>: Mapping phys 0x6F8AB000 length 0x00001000 at offset 0x00020000 to CPUVA 0xB5101000
[ 1852.008414] Mali<7>: Mali map: mapping 0x6F8AB000 to Mali address 0x40060000 length 0x00001000
[ 1852.017995] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00021000
[ 1852.026515] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5102000 length 0x00001000
[ 1852.036722] Mali<7>: Mapping phys 0x6F8AC000 length 0x00001000 at offset 0x00021000 to CPUVA 0xB5102000
[ 1852.047174] Mali<7>: Mali map: mapping 0x6F8AC000 to Mali address 0x40061000 length 0x00001000
[ 1852.056752] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00022000
[ 1852.065274] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5103000 length 0x00001000
[ 1852.075445] Mali<7>: Mapping phys 0x6F8AD000 length 0x00001000 at offset 0x00022000 to CPUVA 0xB5103000
[ 1852.085899] Mali<7>: Mali map: mapping 0x6F8AD000 to Mali address 0x40062000 length 0x00001000
[ 1852.095477] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00023000
[ 1852.103992] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5104000 length 0x00001000
[ 1852.114162] Mali<7>: Mapping phys 0x6F8AE000 length 0x00001000 at offset 0x00023000 to CPUVA 0xB5104000
[ 1852.124614] Mali<7>: Mali map: mapping 0x6F8AE000 to Mali address 0x40063000 length 0x00001000
[ 1852.134193] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00024000
[ 1852.142712] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5105000 length 0x00001000
[ 1852.152883] Mali<7>: Mapping phys 0x6F8AF000 length 0x00001000 at offset 0x00024000 to CPUVA 0xB5105000
[ 1852.163338] Mali<7>: Mali map: mapping 0x6F8AF000 to Mali address 0x40064000 length 0x00001000
[ 1852.172918] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00025000
[ 1852.181436] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5106000 length 0x00001000
[ 1852.191606] Mali<7>: Mapping phys 0x6F8B0000 length 0x00001000 at offset 0x00025000 to CPUVA 0xB5106000
[ 1852.202057] Mali<7>: Mali map: mapping 0x6F8B0000 to Mali address 0x40065000 length 0x00001000
[ 1852.211634] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00026000
[ 1852.220152] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5107000 length 0x00001000
[ 1852.230319] Mali<7>: Mapping phys 0x6F8B1000 length 0x00001000 at offset 0x00026000 to CPUVA 0xB5107000
[ 1852.240771] Mali<7>: Mali map: mapping 0x6F8B1000 to Mali address 0x40066000 length 0x00001000
[ 1852.250353] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00027000
[ 1852.258851] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5108000 length 0x00001000
[ 1852.269021] Mali<7>: Mapping phys 0x6F8B2000 length 0x00001000 at offset 0x00027000 to CPUVA 0xB5108000
[ 1852.279473] Mali<7>: Mali map: mapping 0x6F8B2000 to Mali address 0x40067000 length 0x00001000
[ 1852.289050] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00028000
[ 1852.297568] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5109000 length 0x00001000
[ 1852.307734] Mali<7>: Mapping phys 0x6F8B3000 length 0x00001000 at offset 0x00028000 to CPUVA 0xB5109000
[ 1852.318186] Mali<7>: Mali map: mapping 0x6F8B3000 to Mali address 0x40068000 length 0x00001000
[ 1852.327765] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00029000
[ 1852.336282] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510A000 length 0x00001000
[ 1852.346449] Mali<7>: Mapping phys 0x6F8B4000 length 0x00001000 at offset 0x00029000 to CPUVA 0xB510A000
[ 1852.356897] Mali<7>: Mali map: mapping 0x6F8B4000 to Mali address 0x40069000 length 0x00001000
[ 1852.366475] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002A000
[ 1852.374990] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510B000 length 0x00001000
[ 1852.385159] Mali<7>: Mapping phys 0x6F8B5000 length 0x00001000 at offset 0x0002A000 to CPUVA 0xB510B000
[ 1852.395612] Mali<7>: Mali map: mapping 0x6F8B5000 to Mali address 0x4006A000 length 0x00001000
[ 1852.405187] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002B000
[ 1852.413704] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510C000 length 0x00001000
[ 1852.423873] Mali<7>: Mapping phys 0x6F8B6000 length 0x00001000 at offset 0x0002B000 to CPUVA 0xB510C000
[ 1852.434326] Mali<7>: Mali map: mapping 0x6F8B6000 to Mali address 0x4006B000 length 0x00001000
[ 1852.443904] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002C000
[ 1852.452418] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510D000 length 0x00001000
[ 1852.462586] Mali<7>: Mapping phys 0x6F8B7000 length 0x00001000 at offset 0x0002C000 to CPUVA 0xB510D000
[ 1852.473037] Mali<7>: Mali map: mapping 0x6F8B7000 to Mali address 0x4006C000 length 0x00001000
[ 1852.482615] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002D000
[ 1852.491132] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510E000 length 0x00001000
[ 1852.501300] Mali<7>: Mapping phys 0x6F8B8000 length 0x00001000 at offset 0x0002D000 to CPUVA 0xB510E000
[ 1852.511757] Mali<7>: Mali map: mapping 0x6F8B8000 to Mali address 0x4006D000 length 0x00001000
[ 1852.521335] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002E000
[ 1852.529833] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB510F000 length 0x00001000
[ 1852.540026] Mali<7>: Mapping phys 0x6F8B9000 length 0x00001000 at offset 0x0002E000 to CPUVA 0xB510F000
[ 1852.550473] Mali<7>: Mali map: mapping 0x6F8B9000 to Mali address 0x4006E000 length 0x00001000
[ 1852.560051] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002F000
[ 1852.568549] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5110000 length 0x00001000
[ 1852.578719] Mali<7>: Mapping phys 0x6F8BA000 length 0x00001000 at offset 0x0002F000 to CPUVA 0xB5110000
[ 1852.589172] Mali<7>: Mali map: mapping 0x6F8BA000 to Mali address 0x4006F000 length 0x00001000
[ 1852.598750] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00030000
[ 1852.607266] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5111000 length 0x00001000
[ 1852.617433] Mali<7>: Mapping phys 0x6F8BB000 length 0x00001000 at offset 0x00030000 to CPUVA 0xB5111000
[ 1852.627884] Mali<7>: Mali map: mapping 0x6F8BB000 to Mali address 0x40070000 length 0x00001000
[ 1852.637461] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00031000
[ 1852.645977] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5112000 length 0x00001000
[ 1852.656143] Mali<7>: Mapping phys 0x6F8BC000 length 0x00001000 at offset 0x00031000 to CPUVA 0xB5112000
[ 1852.666593] Mali<7>: Mali map: mapping 0x6F8BC000 to Mali address 0x40071000 length 0x00001000
[ 1852.676171] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00032000
[ 1852.684686] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5113000 length 0x00001000
[ 1852.694854] Mali<7>: Mapping phys 0x6F8BD000 length 0x00001000 at offset 0x00032000 to CPUVA 0xB5113000
[ 1852.705304] Mali<7>: Mali map: mapping 0x6F8BD000 to Mali address 0x40072000 length 0x00001000
[ 1852.714881] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00033000
[ 1852.723398] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5114000 length 0x00001000
[ 1852.733566] Mali<7>: Mapping phys 0x6F8BE000 length 0x00001000 at offset 0x00033000 to CPUVA 0xB5114000
[ 1852.744020] Mali<7>: Mali map: mapping 0x6F8BE000 to Mali address 0x40073000 length 0x00001000
[ 1852.753597] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00034000
[ 1852.762115] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5115000 length 0x00001000
[ 1852.772291] Mali<7>: Mapping phys 0x6F8BF000 length 0x00001000 at offset 0x00034000 to CPUVA 0xB5115000
[ 1852.782743] Mali<7>: Mali map: mapping 0x6F8BF000 to Mali address 0x40074000 length 0x00001000
[ 1852.792322] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00035000
[ 1852.800840] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5116000 length 0x00001000
[ 1852.811009] Mali<7>: Mapping phys 0x6F8C0000 length 0x00001000 at offset 0x00035000 to CPUVA 0xB5116000
[ 1852.821461] Mali<7>: Mali map: mapping 0x6F8C0000 to Mali address 0x40075000 length 0x00001000
[ 1852.831039] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00036000
[ 1852.839538] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5117000 length 0x00001000
[ 1852.849707] Mali<7>: Mapping phys 0x6F8C1000 length 0x00001000 at offset 0x00036000 to CPUVA 0xB5117000
[ 1852.860175] Mali<7>: Mali map: mapping 0x6F8C1000 to Mali address 0x40076000 length 0x00001000
[ 1852.869734] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00037000
[ 1852.878250] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5118000 length 0x00001000
[ 1852.888419] Mali<7>: Mapping phys 0x6F8C2000 length 0x00001000 at offset 0x00037000 to CPUVA 0xB5118000
[ 1852.898870] Mali<7>: Mali map: mapping 0x6F8C2000 to Mali address 0x40077000 length 0x00001000
[ 1852.908439] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00038000
[ 1852.916958] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5119000 length 0x00001000
[ 1852.927126] Mali<7>: Mapping phys 0x6F8C3000 length 0x00001000 at offset 0x00038000 to CPUVA 0xB5119000
[ 1852.937577] Mali<7>: Mali map: mapping 0x6F8C3000 to Mali address 0x40078000 length 0x00001000
[ 1852.947157] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00039000
[ 1852.955674] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511A000 length 0x00001000
[ 1852.965845] Mali<7>: Mapping phys 0x6F8C4000 length 0x00001000 at offset 0x00039000 to CPUVA 0xB511A000
[ 1852.976530] Mali<7>: Mali map: mapping 0x6F8C4000 to Mali address 0x40079000 length 0x00001000
[ 1852.986117] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003A000
[ 1852.994637] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511B000 length 0x00001000
[ 1853.004808] Mali<7>: Mapping phys 0x6F8C5000 length 0x00001000 at offset 0x0003A000 to CPUVA 0xB511B000
[ 1853.015260] Mali<7>: Mali map: mapping 0x6F8C5000 to Mali address 0x4007A000 length 0x00001000
[ 1853.024837] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003B000
[ 1853.033362] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511C000 length 0x00001000
[ 1853.043534] Mali<7>: Mapping phys 0x6F8C6000 length 0x00001000 at offset 0x0003B000 to CPUVA 0xB511C000
[ 1853.053983] Mali<7>: Mali map: mapping 0x6F8C6000 to Mali address 0x4007B000 length 0x00001000
[ 1853.063562] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003C000
[ 1853.072078] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511D000 length 0x00001000
[ 1853.082247] Mali<7>: Mapping phys 0x6F8C7000 length 0x00001000 at offset 0x0003C000 to CPUVA 0xB511D000
[ 1853.092699] Mali<7>: Mali map: mapping 0x6F8C7000 to Mali address 0x4007C000 length 0x00001000
[ 1853.102278] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003D000
[ 1853.110797] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511E000 length 0x00001000
[ 1853.120967] Mali<7>: Mapping phys 0x6F8C8000 length 0x00001000 at offset 0x0003D000 to CPUVA 0xB511E000
[ 1853.131420] Mali<7>: Mali map: mapping 0x6F8C8000 to Mali address 0x4007D000 length 0x00001000
[ 1853.140992] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003E000
[ 1853.149491] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB511F000 length 0x00001000
[ 1853.159650] Mali<7>: Mapping phys 0x6F8C9000 length 0x00001000 at offset 0x0003E000 to CPUVA 0xB511F000
[ 1853.170124] Mali<7>: Mali map: mapping 0x6F8C9000 to Mali address 0x4007E000 length 0x00001000
[ 1853.179683] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003F000
[ 1853.188199] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5120000 length 0x00001000
[ 1853.198369] Mali<7>: Mapping phys 0x6F8CA000 length 0x00001000 at offset 0x0003F000 to CPUVA 0xB5120000
[ 1853.208821] Mali<7>: Mali map: mapping 0x6F8CA000 to Mali address 0x4007F000 length 0x00001000
[ 1853.218399] Mali<6>: Allocated 64 pages
[ 1853.222673] Mali<6>: 192 out of 49152 pages now allocated
[ 1853.228665] Mali<7>: MMAP OK
[ 1853.231952] Mali<4>: MMap() handler: start=0xB50A1000, phys=0x40080000, size=0x00040000
[ 1853.240877] Mali<6>: Allocating page array of size 256 bytes
[ 1853.247156] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00000000
[ 1853.255671] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A1000 length 0x00001000
[ 1853.265852] Mali<7>: Mapping phys 0x6F8CB000 length 0x00001000 at offset 0x00000000 to CPUVA 0xB50A1000
[ 1853.276302] Mali<7>: Mali map: mapping 0x6F8CB000 to Mali address 0x40080000 length 0x00001000
[ 1853.285878] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00001000
[ 1853.294400] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A2000 length 0x00001000
[ 1853.304566] Mali<7>: Mapping phys 0x6F8CC000 length 0x00001000 at offset 0x00001000 to CPUVA 0xB50A2000
[ 1853.315017] Mali<7>: Mali map: mapping 0x6F8CC000 to Mali address 0x40081000 length 0x00001000
[ 1853.324595] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00002000
[ 1853.333114] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A3000 length 0x00001000
[ 1853.343287] Mali<7>: Mapping phys 0x6F8CD000 length 0x00001000 at offset 0x00002000 to CPUVA 0xB50A3000
[ 1853.353738] Mali<7>: Mali map: mapping 0x6F8CD000 to Mali address 0x40082000 length 0x00001000
[ 1853.363318] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00003000
[ 1853.371837] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A4000 length 0x00001000
[ 1853.382009] Mali<7>: Mapping phys 0x6F8CE000 length 0x00001000 at offset 0x00003000 to CPUVA 0xB50A4000
[ 1853.392463] Mali<7>: Mali map: mapping 0x6F8CE000 to Mali address 0x40083000 length 0x00001000
[ 1853.402040] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00004000
[ 1853.410558] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A5000 length 0x00001000
[ 1853.420732] Mali<7>: Mapping phys 0x6F8CF000 length 0x00001000 at offset 0x00004000 to CPUVA 0xB50A5000
[ 1853.431186] Mali<7>: Mali map: mapping 0x6F8CF000 to Mali address 0x40084000 length 0x00001000
[ 1853.440764] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00005000
[ 1853.449263] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A6000 length 0x00001000
[ 1853.459421] Mali<7>: Mapping phys 0x6F8D0000 length 0x00001000 at offset 0x00005000 to CPUVA 0xB50A6000
[ 1853.469873] Mali<7>: Mali map: mapping 0x6F8D0000 to Mali address 0x40085000 length 0x00001000
[ 1853.479451] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00006000
[ 1853.487968] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A7000 length 0x00001000
[ 1853.498137] Mali<7>: Mapping phys 0x6F8D1000 length 0x00001000 at offset 0x00006000 to CPUVA 0xB50A7000
[ 1853.508593] Mali<7>: Mali map: mapping 0x6F8D1000 to Mali address 0x40086000 length 0x00001000
[ 1853.518163] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00007000
[ 1853.526681] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A8000 length 0x00001000
[ 1853.536847] Mali<7>: Mapping phys 0x6F8D2000 length 0x00001000 at offset 0x00007000 to CPUVA 0xB50A8000
[ 1853.547298] Mali<7>: Mali map: mapping 0x6F8D2000 to Mali address 0x40087000 length 0x00001000
[ 1853.556883] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00008000
[ 1853.565401] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A9000 length 0x00001000
[ 1853.575571] Mali<7>: Mapping phys 0x6F8D3000 length 0x00001000 at offset 0x00008000 to CPUVA 0xB50A9000
[ 1853.586021] Mali<7>: Mali map: mapping 0x6F8D3000 to Mali address 0x40088000 length 0x00001000
[ 1853.595599] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00009000
[ 1853.604114] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AA000 length 0x00001000
[ 1853.614284] Mali<7>: Mapping phys 0x6F8D4000 length 0x00001000 at offset 0x00009000 to CPUVA 0xB50AA000
[ 1853.624736] Mali<7>: Mali map: mapping 0x6F8D4000 to Mali address 0x40089000 length 0x00001000
[ 1853.634314] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000A000
[ 1853.642832] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AB000 length 0x00001000
[ 1853.652998] Mali<7>: Mapping phys 0x6F8D5000 length 0x00001000 at offset 0x0000A000 to CPUVA 0xB50AB000
[ 1853.663449] Mali<7>: Mali map: mapping 0x6F8D5000 to Mali address 0x4008A000 length 0x00001000
[ 1853.673027] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000B000
[ 1853.681544] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AC000 length 0x00001000
[ 1853.691713] Mali<7>: Mapping phys 0x6F8D6000 length 0x00001000 at offset 0x0000B000 to CPUVA 0xB50AC000
[ 1853.702164] Mali<7>: Mali map: mapping 0x6F8D6000 to Mali address 0x4008B000 length 0x00001000
[ 1853.711742] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000C000
[ 1853.720260] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AD000 length 0x00001000
[ 1853.730428] Mali<7>: Mapping phys 0x6F8D7000 length 0x00001000 at offset 0x0000C000 to CPUVA 0xB50AD000
[ 1853.740881] Mali<7>: Mali map: mapping 0x6F8D7000 to Mali address 0x4008C000 length 0x00001000
[ 1853.750458] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000D000
[ 1853.758957] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AE000 length 0x00001000
[ 1853.769129] Mali<7>: Mapping phys 0x6F8D8000 length 0x00001000 at offset 0x0000D000 to CPUVA 0xB50AE000
[ 1853.779582] Mali<7>: Mali map: mapping 0x6F8D8000 to Mali address 0x4008D000 length 0x00001000
[ 1853.789161] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000E000
[ 1853.797678] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AF000 length 0x00001000
[ 1853.807843] Mali<7>: Mapping phys 0x6F8D9000 length 0x00001000 at offset 0x0000E000 to CPUVA 0xB50AF000
[ 1853.818302] Mali<7>: Mali map: mapping 0x6F8D9000 to Mali address 0x4008E000 length 0x00001000
[ 1853.827880] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000F000
[ 1853.836397] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B0000 length 0x00001000
[ 1853.846565] Mali<7>: Mapping phys 0x6F8DA000 length 0x00001000 at offset 0x0000F000 to CPUVA 0xB50B0000
[ 1853.857013] Mali<7>: Mali map: mapping 0x6F8DA000 to Mali address 0x4008F000 length 0x00001000
[ 1853.866591] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00010000
[ 1853.875108] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B1000 length 0x00001000
[ 1853.885277] Mali<7>: Mapping phys 0x6F8DB000 length 0x00001000 at offset 0x00010000 to CPUVA 0xB50B1000
[ 1853.895729] Mali<7>: Mali map: mapping 0x6F8DB000 to Mali address 0x40090000 length 0x00001000
[ 1853.905306] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00011000
[ 1853.913824] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B2000 length 0x00001000
[ 1853.923995] Mali<7>: Mapping phys 0x6F8DC000 length 0x00001000 at offset 0x00011000 to CPUVA 0xB50B2000
[ 1853.934448] Mali<7>: Mali map: mapping 0x6F8DC000 to Mali address 0x40091000 length 0x00001000
[ 1853.944026] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00012000
[ 1853.952543] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B3000 length 0x00001000
[ 1853.962715] Mali<7>: Mapping phys 0x6F8DD000 length 0x00001000 at offset 0x00012000 to CPUVA 0xB50B3000
[ 1853.973213] Mali<7>: Mali map: mapping 0x6F8DD000 to Mali address 0x40092000 length 0x00001000
[ 1853.982817] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00013000
[ 1853.991343] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B4000 length 0x00001000
[ 1854.001522] Mali<7>: Mapping phys 0x6F8DE000 length 0x00001000 at offset 0x00013000 to CPUVA 0xB50B4000
[ 1854.011982] Mali<7>: Mali map: mapping 0x6F8DE000 to Mali address 0x40093000 length 0x00001000
[ 1854.021562] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00014000
[ 1854.030080] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B5000 length 0x00001000
[ 1854.040248] Mali<7>: Mapping phys 0x6F8DF000 length 0x00001000 at offset 0x00014000 to CPUVA 0xB50B5000
[ 1854.050705] Mali<7>: Mali map: mapping 0x6F8DF000 to Mali address 0x40094000 length 0x00001000
[ 1854.060286] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00015000
[ 1854.068785] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B6000 length 0x00001000
[ 1854.078964] Mali<7>: Mapping phys 0x6F8E0000 length 0x00001000 at offset 0x00015000 to CPUVA 0xB50B6000
[ 1854.089418] Mali<7>: Mali map: mapping 0x6F8E0000 to Mali address 0x40095000 length 0x00001000
[ 1854.098999] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00016000
[ 1854.107517] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B7000 length 0x00001000
[ 1854.117685] Mali<7>: Mapping phys 0x6F8E1000 length 0x00001000 at offset 0x00016000 to CPUVA 0xB50B7000
[ 1854.128134] Mali<7>: Mali map: mapping 0x6F8E1000 to Mali address 0x40096000 length 0x00001000
[ 1854.137716] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00017000
[ 1854.146233] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B8000 length 0x00001000
[ 1854.156397] Mali<7>: Mapping phys 0x6F8E2000 length 0x00001000 at offset 0x00017000 to CPUVA 0xB50B8000
[ 1854.166849] Mali<7>: Mali map: mapping 0x6F8E2000 to Mali address 0x40097000 length 0x00001000
[ 1854.176429] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00018000
[ 1854.184945] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B9000 length 0x00001000
[ 1854.195115] Mali<7>: Mapping phys 0x6F8E3000 length 0x00001000 at offset 0x00018000 to CPUVA 0xB50B9000
[ 1854.205564] Mali<7>: Mali map: mapping 0x6F8E3000 to Mali address 0x40098000 length 0x00001000
[ 1854.215143] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00019000
[ 1854.223660] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BA000 length 0x00001000
[ 1854.233829] Mali<7>: Mapping phys 0x6F8E4000 length 0x00001000 at offset 0x00019000 to CPUVA 0xB50BA000
[ 1854.244280] Mali<7>: Mali map: mapping 0x6F8E4000 to Mali address 0x40099000 length 0x00001000
[ 1854.253856] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001A000
[ 1854.262374] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BB000 length 0x00001000
[ 1854.272544] Mali<7>: Mapping phys 0x6F8E5000 length 0x00001000 at offset 0x0001A000 to CPUVA 0xB50BB000
[ 1854.282996] Mali<7>: Mali map: mapping 0x6F8E5000 to Mali address 0x4009A000 length 0x00001000
[ 1854.292576] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001B000
[ 1854.301093] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BC000 length 0x00001000
[ 1854.311261] Mali<7>: Mapping phys 0x6F8E6000 length 0x00001000 at offset 0x0001B000 to CPUVA 0xB50BC000
[ 1854.321713] Mali<7>: Mali map: mapping 0x6F8E6000 to Mali address 0x4009B000 length 0x00001000
[ 1854.331299] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001C000
[ 1854.339797] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BD000 length 0x00001000
[ 1854.349966] Mali<7>: Mapping phys 0x6F8E7000 length 0x00001000 at offset 0x0001C000 to CPUVA 0xB50BD000
[ 1854.360434] Mali<7>: Mali map: mapping 0x6F8E7000 to Mali address 0x4009C000 length 0x00001000
[ 1854.369993] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001D000
[ 1854.378510] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BE000 length 0x00001000
[ 1854.388679] Mali<7>: Mapping phys 0x6F8E8000 length 0x00001000 at offset 0x0001D000 to CPUVA 0xB50BE000
[ 1854.399131] Mali<7>: Mali map: mapping 0x6F8E8000 to Mali address 0x4009D000 length 0x00001000
[ 1854.408706] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001E000
[ 1854.417224] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BF000 length 0x00001000
[ 1854.427391] Mali<7>: Mapping phys 0x6F8E9000 length 0x00001000 at offset 0x0001E000 to CPUVA 0xB50BF000
[ 1854.437840] Mali<7>: Mali map: mapping 0x6F8E9000 to Mali address 0x4009E000 length 0x00001000
[ 1854.447417] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001F000
[ 1854.455930] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C0000 length 0x00001000
[ 1854.466110] Mali<7>: Mapping phys 0x6F8EA000 length 0x00001000 at offset 0x0001F000 to CPUVA 0xB50C0000
[ 1854.476561] Mali<7>: Mali map: mapping 0x6F8EA000 to Mali address 0x4009F000 length 0x00001000
[ 1854.486138] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00020000
[ 1854.494654] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C1000 length 0x00001000
[ 1854.504819] Mali<7>: Mapping phys 0x6F8EB000 length 0x00001000 at offset 0x00020000 to CPUVA 0xB50C1000
[ 1854.515270] Mali<7>: Mali map: mapping 0x6F8EB000 to Mali address 0x400A0000 length 0x00001000
[ 1854.524846] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00021000
[ 1854.533364] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C2000 length 0x00001000
[ 1854.543534] Mali<7>: Mapping phys 0x6F8EC000 length 0x00001000 at offset 0x00021000 to CPUVA 0xB50C2000
[ 1854.553983] Mali<7>: Mali map: mapping 0x6F8EC000 to Mali address 0x400A1000 length 0x00001000
[ 1854.563561] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00022000
[ 1854.572080] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C3000 length 0x00001000
[ 1854.582248] Mali<7>: Mapping phys 0x6F8ED000 length 0x00001000 at offset 0x00022000 to CPUVA 0xB50C3000
[ 1854.592707] Mali<7>: Mali map: mapping 0x6F8ED000 to Mali address 0x400A2000 length 0x00001000
[ 1854.602287] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00023000
[ 1854.610805] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C4000 length 0x00001000
[ 1854.620974] Mali<7>: Mapping phys 0x6F8EE000 length 0x00001000 at offset 0x00023000 to CPUVA 0xB50C4000
[ 1854.631425] Mali<7>: Mali map: mapping 0x6F8EE000 to Mali address 0x400A3000 length 0x00001000
[ 1854.641004] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00024000
[ 1854.649502] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C5000 length 0x00001000
[ 1854.659667] Mali<7>: Mapping phys 0x6F8EF000 length 0x00001000 at offset 0x00024000 to CPUVA 0xB50C5000
[ 1854.670137] Mali<7>: Mali map: mapping 0x6F8EF000 to Mali address 0x400A4000 length 0x00001000
[ 1854.679696] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00025000
[ 1854.688213] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C6000 length 0x00001000
[ 1854.698383] Mali<7>: Mapping phys 0x6F8F0000 length 0x00001000 at offset 0x00025000 to CPUVA 0xB50C6000
[ 1854.708834] Mali<7>: Mali map: mapping 0x6F8F0000 to Mali address 0x400A5000 length 0x00001000
[ 1854.718412] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00026000
[ 1854.726929] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C7000 length 0x00001000
[ 1854.737094] Mali<7>: Mapping phys 0x6F8F1000 length 0x00001000 at offset 0x00026000 to CPUVA 0xB50C7000
[ 1854.747545] Mali<7>: Mali map: mapping 0x6F8F1000 to Mali address 0x400A6000 length 0x00001000
[ 1854.757121] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00027000
[ 1854.765638] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C8000 length 0x00001000
[ 1854.775807] Mali<7>: Mapping phys 0x6F8F2000 length 0x00001000 at offset 0x00027000 to CPUVA 0xB50C8000
[ 1854.786256] Mali<7>: Mali map: mapping 0x6F8F2000 to Mali address 0x400A7000 length 0x00001000
[ 1854.795835] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00028000
[ 1854.804349] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C9000 length 0x00001000
[ 1854.814519] Mali<7>: Mapping phys 0x6F8F3000 length 0x00001000 at offset 0x00028000 to CPUVA 0xB50C9000
[ 1854.824972] Mali<7>: Mali map: mapping 0x6F8F3000 to Mali address 0x400A8000 length 0x00001000
[ 1854.834549] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00029000
[ 1854.843067] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CA000 length 0x00001000
[ 1854.853241] Mali<7>: Mapping phys 0x6F8F4000 length 0x00001000 at offset 0x00029000 to CPUVA 0xB50CA000
[ 1854.863693] Mali<7>: Mali map: mapping 0x6F8F4000 to Mali address 0x400A9000 length 0x00001000
[ 1854.873271] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002A000
[ 1854.881789] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CB000 length 0x00001000
[ 1854.891962] Mali<7>: Mapping phys 0x6F8F5000 length 0x00001000 at offset 0x0002A000 to CPUVA 0xB50CB000
[ 1854.902413] Mali<7>: Mali map: mapping 0x6F8F5000 to Mali address 0x400AA000 length 0x00001000
[ 1854.911993] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002B000
[ 1854.920511] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CC000 length 0x00001000
[ 1854.930683] Mali<7>: Mapping phys 0x6F8F6000 length 0x00001000 at offset 0x0002B000 to CPUVA 0xB50CC000
[ 1854.941136] Mali<7>: Mali map: mapping 0x6F8F6000 to Mali address 0x400AB000 length 0x00001000
[ 1854.950712] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002C000
[ 1854.959210] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CD000 length 0x00001000
[ 1854.969381] Mali<7>: Mapping phys 0x6F8F7000 length 0x00001000 at offset 0x0002C000 to CPUVA 0xB50CD000
[ 1854.979941] Mali<7>: Mali map: mapping 0x6F8F7000 to Mali address 0x400AC000 length 0x00001000
[ 1854.989526] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002D000
[ 1854.998050] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CE000 length 0x00001000
[ 1855.008221] Mali<7>: Mapping phys 0x6F8F8000 length 0x00001000 at offset 0x0002D000 to CPUVA 0xB50CE000
[ 1855.018675] Mali<7>: Mali map: mapping 0x6F8F8000 to Mali address 0x400AD000 length 0x00001000
[ 1855.028253] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002E000
[ 1855.036770] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CF000 length 0x00001000
[ 1855.046937] Mali<7>: Mapping phys 0x6F8F9000 length 0x00001000 at offset 0x0002E000 to CPUVA 0xB50CF000
[ 1855.057386] Mali<7>: Mali map: mapping 0x6F8F9000 to Mali address 0x400AE000 length 0x00001000
[ 1855.066964] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002F000
[ 1855.075482] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D0000 length 0x00001000
[ 1855.085652] Mali<7>: Mapping phys 0x6F8FA000 length 0x00001000 at offset 0x0002F000 to CPUVA 0xB50D0000
[ 1855.096103] Mali<7>: Mali map: mapping 0x6F8FA000 to Mali address 0x400AF000 length 0x00001000
[ 1855.105679] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00030000
[ 1855.114205] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D1000 length 0x00001000
[ 1855.124375] Mali<7>: Mapping phys 0x6F8FB000 length 0x00001000 at offset 0x00030000 to CPUVA 0xB50D1000
[ 1855.134828] Mali<7>: Mali map: mapping 0x6F8FB000 to Mali address 0x400B0000 length 0x00001000
[ 1855.144406] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00031000
[ 1855.152920] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D2000 length 0x00001000
[ 1855.163089] Mali<7>: Mapping phys 0x6F8FC000 length 0x00001000 at offset 0x00031000 to CPUVA 0xB50D2000
[ 1855.173540] Mali<7>: Mali map: mapping 0x6F8FC000 to Mali address 0x400B1000 length 0x00001000
[ 1855.183119] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00032000
[ 1855.191637] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D3000 length 0x00001000
[ 1855.201806] Mali<7>: Mapping phys 0x6F8FD000 length 0x00001000 at offset 0x00032000 to CPUVA 0xB50D3000
[ 1855.212258] Mali<7>: Mali map: mapping 0x6F8FD000 to Mali address 0x400B2000 length 0x00001000
[ 1855.221837] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00033000
[ 1855.230354] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D4000 length 0x00001000
[ 1855.240523] Mali<7>: Mapping phys 0x6F8FE000 length 0x00001000 at offset 0x00033000 to CPUVA 0xB50D4000
[ 1855.250971] Mali<7>: Mali map: mapping 0x6F8FE000 to Mali address 0x400B3000 length 0x00001000
[ 1855.260552] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00034000
[ 1855.269049] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D5000 length 0x00001000
[ 1855.279218] Mali<7>: Mapping phys 0x6F8FF000 length 0x00001000 at offset 0x00034000 to CPUVA 0xB50D5000
[ 1855.289671] Mali<7>: Mali map: mapping 0x6F8FF000 to Mali address 0x400B4000 length 0x00001000
[ 1855.299250] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00035000
[ 1855.307768] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D6000 length 0x00001000
[ 1855.317936] Mali<7>: Mapping phys 0x6FB00000 length 0x00001000 at offset 0x00035000 to CPUVA 0xB50D6000
[ 1855.328389] Mali<7>: Mali map: mapping 0x6FB00000 to Mali address 0x400B5000 length 0x00001000
[ 1855.337965] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00036000
[ 1855.346486] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D7000 length 0x00001000
[ 1855.356653] Mali<7>: Mapping phys 0x6FB01000 length 0x00001000 at offset 0x00036000 to CPUVA 0xB50D7000
[ 1855.367105] Mali<7>: Mali map: mapping 0x6FB01000 to Mali address 0x400B6000 length 0x00001000
[ 1855.376691] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00037000
[ 1855.385209] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D8000 length 0x00001000
[ 1855.395378] Mali<7>: Mapping phys 0x6FB02000 length 0x00001000 at offset 0x00037000 to CPUVA 0xB50D8000
[ 1855.405826] Mali<7>: Mali map: mapping 0x6FB02000 to Mali address 0x400B7000 length 0x00001000
[ 1855.415406] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00038000
[ 1855.423922] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D9000 length 0x00001000
[ 1855.434092] Mali<7>: Mapping phys 0x6FB03000 length 0x00001000 at offset 0x00038000 to CPUVA 0xB50D9000
[ 1855.444543] Mali<7>: Mali map: mapping 0x6FB03000 to Mali address 0x400B8000 length 0x00001000
[ 1855.454118] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00039000
[ 1855.462637] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DA000 length 0x00001000
[ 1855.472805] Mali<7>: Mapping phys 0x6FB04000 length 0x00001000 at offset 0x00039000 to CPUVA 0xB50DA000
[ 1855.483256] Mali<7>: Mali map: mapping 0x6FB04000 to Mali address 0x400B9000 length 0x00001000
[ 1855.492833] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003A000
[ 1855.501350] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DB000 length 0x00001000
[ 1855.511521] Mali<7>: Mapping phys 0x6FB05000 length 0x00001000 at offset 0x0003A000 to CPUVA 0xB50DB000
[ 1855.521974] Mali<7>: Mali map: mapping 0x6FB05000 to Mali address 0x400BA000 length 0x00001000
[ 1855.531552] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003B000
[ 1855.540069] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DC000 length 0x00001000
[ 1855.550236] Mali<7>: Mapping phys 0x6FB06000 length 0x00001000 at offset 0x0003B000 to CPUVA 0xB50DC000
[ 1855.560687] Mali<7>: Mali map: mapping 0x6FB06000 to Mali address 0x400BB000 length 0x00001000
[ 1855.570267] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003C000
[ 1855.578765] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DD000 length 0x00001000
[ 1855.588933] Mali<7>: Mapping phys 0x6FB07000 length 0x00001000 at offset 0x0003C000 to CPUVA 0xB50DD000
[ 1855.599386] Mali<7>: Mali map: mapping 0x6FB07000 to Mali address 0x400BC000 length 0x00001000
[ 1855.608964] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003D000
[ 1855.617480] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DE000 length 0x00001000
[ 1855.627648] Mali<7>: Mapping phys 0x6FB08000 length 0x00001000 at offset 0x0003D000 to CPUVA 0xB50DE000
[ 1855.638102] Mali<7>: Mali map: mapping 0x6FB08000 to Mali address 0x400BD000 length 0x00001000
[ 1855.647680] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003E000
[ 1855.656197] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DF000 length 0x00001000
[ 1855.666375] Mali<7>: Mapping phys 0x6FB09000 length 0x00001000 at offset 0x0003E000 to CPUVA 0xB50DF000
[ 1855.676827] Mali<7>: Mali map: mapping 0x6FB09000 to Mali address 0x400BE000 length 0x00001000
[ 1855.686402] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003F000
[ 1855.694919] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E0000 length 0x00001000
[ 1855.705086] Mali<7>: Mapping phys 0x6FB0A000 length 0x00001000 at offset 0x0003F000 to CPUVA 0xB50E0000
[ 1855.715538] Mali<7>: Mali map: mapping 0x6FB0A000 to Mali address 0x400BF000 length 0x00001000
[ 1855.725116] Mali<6>: Allocated 64 pages
[ 1855.729370] Mali<6>: 256 out of 49152 pages now allocated
[ 1855.735381] Mali<7>: MMAP OK
[ 1855.746149] Mali<3>: Close called on vma ee22e1d8
[ 1855.751435] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1855.757718] Mali<5>: Mali group: Releasing group lock 0xED463D80
[ 1855.764410] Mali<5>: Mali group: Group lock taken 0xED463D00
[ 1855.770691] Mali<5>: Mali group: Releasing group lock 0xED463D00
[ 1855.777376] Mali<5>: Mali group: Group lock taken 0xED463B00
[ 1855.783656] Mali<5>: Mali group: Releasing group lock 0xED463B00
[ 1855.790350] Mali<6>: Releasing 64 os pages
[ 1855.794895] Mali<7>: UnMapping length 0x00040000 at offset 0x00000000
[ 1855.802281] Mali<4>: MMap() handler: start=0xB50A1000, phys=0x40080000, size=0x00040000
[ 1855.811205] Mali<6>: Allocating page array of size 256 bytes
[ 1855.817485] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00000000
[ 1855.825998] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A1000 length 0x00001000
[ 1855.836170] Mali<7>: Mapping phys 0x6FB0B000 length 0x00001000 at offset 0x00000000 to CPUVA 0xB50A1000
[ 1855.846626] Mali<7>: Mali map: mapping 0x6FB0B000 to Mali address 0x40080000 length 0x00001000
[ 1855.856203] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00001000
[ 1855.864722] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A2000 length 0x00001000
[ 1855.874890] Mali<7>: Mapping phys 0x6FB0C000 length 0x00001000 at offset 0x00001000 to CPUVA 0xB50A2000
[ 1855.885341] Mali<7>: Mali map: mapping 0x6FB0C000 to Mali address 0x40081000 length 0x00001000
[ 1855.894931] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00002000
[ 1855.903447] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A3000 length 0x00001000
[ 1855.913620] Mali<7>: Mapping phys 0x6FB0D000 length 0x00001000 at offset 0x00002000 to CPUVA 0xB50A3000
[ 1855.924072] Mali<7>: Mali map: mapping 0x6FB0D000 to Mali address 0x40082000 length 0x00001000
[ 1855.933651] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00003000
[ 1855.942168] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A4000 length 0x00001000
[ 1855.952338] Mali<7>: Mapping phys 0x6FB0E000 length 0x00001000 at offset 0x00003000 to CPUVA 0xB50A4000
[ 1855.962796] Mali<7>: Mali map: mapping 0x6FB0E000 to Mali address 0x40083000 length 0x00001000
[ 1855.972423] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00004000
[ 1855.980946] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A5000 length 0x00001000
[ 1855.991119] Mali<7>: Mapping phys 0x6FB0F000 length 0x00001000 at offset 0x00004000 to CPUVA 0xB50A5000
[ 1856.001573] Mali<7>: Mali map: mapping 0x6FB0F000 to Mali address 0x40084000 length 0x00001000
[ 1856.011155] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00005000
[ 1856.019654] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A6000 length 0x00001000
[ 1856.029827] Mali<7>: Mapping phys 0x6FB10000 length 0x00001000 at offset 0x00005000 to CPUVA 0xB50A6000
[ 1856.040330] Mali<7>: Mali map: mapping 0x6FB10000 to Mali address 0x40085000 length 0x00001000
[ 1856.049891] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00006000
[ 1856.058410] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A7000 length 0x00001000
[ 1856.068585] Mali<7>: Mapping phys 0x6FB11000 length 0x00001000 at offset 0x00006000 to CPUVA 0xB50A7000
[ 1856.079040] Mali<7>: Mali map: mapping 0x6FB11000 to Mali address 0x40086000 length 0x00001000
[ 1856.088618] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00007000
[ 1856.097135] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A8000 length 0x00001000
[ 1856.107292] Mali<7>: Mapping phys 0x6FB12000 length 0x00001000 at offset 0x00007000 to CPUVA 0xB50A8000
[ 1856.117745] Mali<7>: Mali map: mapping 0x6FB12000 to Mali address 0x40087000 length 0x00001000
[ 1856.127324] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00008000
[ 1856.135836] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A9000 length 0x00001000
[ 1856.146005] Mali<7>: Mapping phys 0x6FB13000 length 0x00001000 at offset 0x00008000 to CPUVA 0xB50A9000
[ 1856.156462] Mali<7>: Mali map: mapping 0x6FB13000 to Mali address 0x40088000 length 0x00001000
[ 1856.166044] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00009000
[ 1856.174562] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AA000 length 0x00001000
[ 1856.184733] Mali<7>: Mapping phys 0x6FB14000 length 0x00001000 at offset 0x00009000 to CPUVA 0xB50AA000
[ 1856.195187] Mali<7>: Mali map: mapping 0x6FB14000 to Mali address 0x40089000 length 0x00001000
[ 1856.204763] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000A000
[ 1856.213281] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AB000 length 0x00001000
[ 1856.223448] Mali<7>: Mapping phys 0x6FB15000 length 0x00001000 at offset 0x0000A000 to CPUVA 0xB50AB000
[ 1856.233898] Mali<7>: Mali map: mapping 0x6FB15000 to Mali address 0x4008A000 length 0x00001000
[ 1856.243476] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000B000
[ 1856.251991] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AC000 length 0x00001000
[ 1856.262158] Mali<7>: Mapping phys 0x6FB16000 length 0x00001000 at offset 0x0000B000 to CPUVA 0xB50AC000
[ 1856.272611] Mali<7>: Mali map: mapping 0x6FB16000 to Mali address 0x4008B000 length 0x00001000
[ 1856.282189] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000C000
[ 1856.290706] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AD000 length 0x00001000
[ 1856.300875] Mali<7>: Mapping phys 0x6FB17000 length 0x00001000 at offset 0x0000C000 to CPUVA 0xB50AD000
[ 1856.311326] Mali<7>: Mali map: mapping 0x6FB17000 to Mali address 0x4008C000 length 0x00001000
[ 1856.320905] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000D000
[ 1856.329403] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AE000 length 0x00001000
[ 1856.339571] Mali<7>: Mapping phys 0x6FB18000 length 0x00001000 at offset 0x0000D000 to CPUVA 0xB50AE000
[ 1856.350040] Mali<7>: Mali map: mapping 0x6FB18000 to Mali address 0x4008D000 length 0x00001000
[ 1856.359599] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000E000
[ 1856.368116] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50AF000 length 0x00001000
[ 1856.378285] Mali<7>: Mapping phys 0x6FB19000 length 0x00001000 at offset 0x0000E000 to CPUVA 0xB50AF000
[ 1856.388740] Mali<7>: Mali map: mapping 0x6FB19000 to Mali address 0x4008E000 length 0x00001000
[ 1856.398309] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000F000
[ 1856.406854] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B0000 length 0x00001000
[ 1856.417029] Mali<7>: Mapping phys 0x6FB1A000 length 0x00001000 at offset 0x0000F000 to CPUVA 0xB50B0000
[ 1856.427482] Mali<7>: Mali map: mapping 0x6FB1A000 to Mali address 0x4008F000 length 0x00001000
[ 1856.437059] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00010000
[ 1856.445576] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B1000 length 0x00001000
[ 1856.455742] Mali<7>: Mapping phys 0x6FB1B000 length 0x00001000 at offset 0x00010000 to CPUVA 0xB50B1000
[ 1856.466194] Mali<7>: Mali map: mapping 0x6FB1B000 to Mali address 0x40090000 length 0x00001000
[ 1856.475771] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00011000
[ 1856.484287] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B2000 length 0x00001000
[ 1856.494455] Mali<7>: Mapping phys 0x6FB1C000 length 0x00001000 at offset 0x00011000 to CPUVA 0xB50B2000
[ 1856.504902] Mali<7>: Mali map: mapping 0x6FB1C000 to Mali address 0x40091000 length 0x00001000
[ 1856.514480] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00012000
[ 1856.522997] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B3000 length 0x00001000
[ 1856.533165] Mali<7>: Mapping phys 0x6FB1D000 length 0x00001000 at offset 0x00012000 to CPUVA 0xB50B3000
[ 1856.543617] Mali<7>: Mali map: mapping 0x6FB1D000 to Mali address 0x40092000 length 0x00001000
[ 1856.553193] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00013000
[ 1856.561710] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B4000 length 0x00001000
[ 1856.571879] Mali<7>: Mapping phys 0x6FB1E000 length 0x00001000 at offset 0x00013000 to CPUVA 0xB50B4000
[ 1856.582331] Mali<7>: Mali map: mapping 0x6FB1E000 to Mali address 0x40093000 length 0x00001000
[ 1856.591908] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00014000
[ 1856.600426] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B5000 length 0x00001000
[ 1856.610605] Mali<7>: Mapping phys 0x6FB1F000 length 0x00001000 at offset 0x00014000 to CPUVA 0xB50B5000
[ 1856.621060] Mali<7>: Mali map: mapping 0x6FB1F000 to Mali address 0x40094000 length 0x00001000
[ 1856.630640] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00015000
[ 1856.639138] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B6000 length 0x00001000
[ 1856.649310] Mali<7>: Mapping phys 0x6FB20000 length 0x00001000 at offset 0x00015000 to CPUVA 0xB50B6000
[ 1856.659764] Mali<7>: Mali map: mapping 0x6FB20000 to Mali address 0x40095000 length 0x00001000
[ 1856.669343] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00016000
[ 1856.677866] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B7000 length 0x00001000
[ 1856.688039] Mali<7>: Mapping phys 0x6FB21000 length 0x00001000 at offset 0x00016000 to CPUVA 0xB50B7000
[ 1856.698491] Mali<7>: Mali map: mapping 0x6FB21000 to Mali address 0x40096000 length 0x00001000
[ 1856.708069] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00017000
[ 1856.716587] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B8000 length 0x00001000
[ 1856.726755] Mali<7>: Mapping phys 0x6FB22000 length 0x00001000 at offset 0x00017000 to CPUVA 0xB50B8000
[ 1856.737205] Mali<7>: Mali map: mapping 0x6FB22000 to Mali address 0x40097000 length 0x00001000
[ 1856.746786] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00018000
[ 1856.755303] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50B9000 length 0x00001000
[ 1856.765475] Mali<7>: Mapping phys 0x6FB23000 length 0x00001000 at offset 0x00018000 to CPUVA 0xB50B9000
[ 1856.775927] Mali<7>: Mali map: mapping 0x6FB23000 to Mali address 0x40098000 length 0x00001000
[ 1856.785506] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00019000
[ 1856.794022] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BA000 length 0x00001000
[ 1856.804189] Mali<7>: Mapping phys 0x6FB24000 length 0x00001000 at offset 0x00019000 to CPUVA 0xB50BA000
[ 1856.814641] Mali<7>: Mali map: mapping 0x6FB24000 to Mali address 0x40099000 length 0x00001000
[ 1856.824218] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001A000
[ 1856.832736] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BB000 length 0x00001000
[ 1856.842904] Mali<7>: Mapping phys 0x6FB25000 length 0x00001000 at offset 0x0001A000 to CPUVA 0xB50BB000
[ 1856.853352] Mali<7>: Mali map: mapping 0x6FB25000 to Mali address 0x4009A000 length 0x00001000
[ 1856.862930] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001B000
[ 1856.871448] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BC000 length 0x00001000
[ 1856.881617] Mali<7>: Mapping phys 0x6FB26000 length 0x00001000 at offset 0x0001B000 to CPUVA 0xB50BC000
[ 1856.892070] Mali<7>: Mali map: mapping 0x6FB26000 to Mali address 0x4009B000 length 0x00001000
[ 1856.901646] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001C000
[ 1856.910165] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BD000 length 0x00001000
[ 1856.920335] Mali<7>: Mapping phys 0x6FB27000 length 0x00001000 at offset 0x0001C000 to CPUVA 0xB50BD000
[ 1856.930793] Mali<7>: Mali map: mapping 0x6FB27000 to Mali address 0x4009C000 length 0x00001000
[ 1856.940372] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001D000
[ 1856.948871] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BE000 length 0x00001000
[ 1856.959038] Mali<7>: Mapping phys 0x6F8CB000 length 0x00001000 at offset 0x0001D000 to CPUVA 0xB50BE000
[ 1856.969493] Mali<7>: Mali map: mapping 0x6F8CB000 to Mali address 0x4009D000 length 0x00001000
[ 1856.979281] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001E000
[ 1856.987810] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50BF000 length 0x00001000
[ 1856.997989] Mali<7>: Mapping phys 0x6F8CC000 length 0x00001000 at offset 0x0001E000 to CPUVA 0xB50BF000
[ 1857.008443] Mali<7>: Mali map: mapping 0x6F8CC000 to Mali address 0x4009E000 length 0x00001000
[ 1857.018015] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001F000
[ 1857.026533] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C0000 length 0x00001000
[ 1857.036701] Mali<7>: Mapping phys 0x6F8CD000 length 0x00001000 at offset 0x0001F000 to CPUVA 0xB50C0000
[ 1857.047152] Mali<7>: Mali map: mapping 0x6F8CD000 to Mali address 0x4009F000 length 0x00001000
[ 1857.056728] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00020000
[ 1857.065245] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C1000 length 0x00001000
[ 1857.075414] Mali<7>: Mapping phys 0x6F8CE000 length 0x00001000 at offset 0x00020000 to CPUVA 0xB50C1000
[ 1857.085864] Mali<7>: Mali map: mapping 0x6F8CE000 to Mali address 0x400A0000 length 0x00001000
[ 1857.095442] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00021000
[ 1857.103957] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C2000 length 0x00001000
[ 1857.114125] Mali<7>: Mapping phys 0x6F8CF000 length 0x00001000 at offset 0x00021000 to CPUVA 0xB50C2000
[ 1857.124577] Mali<7>: Mali map: mapping 0x6F8CF000 to Mali address 0x400A1000 length 0x00001000
[ 1857.134155] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00022000
[ 1857.142671] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C3000 length 0x00001000
[ 1857.152836] Mali<7>: Mapping phys 0x6F8D0000 length 0x00001000 at offset 0x00022000 to CPUVA 0xB50C3000
[ 1857.163288] Mali<7>: Mali map: mapping 0x6F8D0000 to Mali address 0x400A2000 length 0x00001000
[ 1857.172866] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00023000
[ 1857.181384] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C4000 length 0x00001000
[ 1857.191559] Mali<7>: Mapping phys 0x6F8D1000 length 0x00001000 at offset 0x00023000 to CPUVA 0xB50C4000
[ 1857.202012] Mali<7>: Mali map: mapping 0x6F8D1000 to Mali address 0x400A3000 length 0x00001000
[ 1857.211590] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00024000
[ 1857.220108] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C5000 length 0x00001000
[ 1857.230276] Mali<7>: Mapping phys 0x6F8D2000 length 0x00001000 at offset 0x00024000 to CPUVA 0xB50C5000
[ 1857.240727] Mali<7>: Mali map: mapping 0x6F8D2000 to Mali address 0x400A4000 length 0x00001000
[ 1857.250302] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00025000
[ 1857.258800] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C6000 length 0x00001000
[ 1857.268971] Mali<7>: Mapping phys 0x6F8D3000 length 0x00001000 at offset 0x00025000 to CPUVA 0xB50C6000
[ 1857.279422] Mali<7>: Mali map: mapping 0x6F8D3000 to Mali address 0x400A5000 length 0x00001000
[ 1857.289000] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00026000
[ 1857.297519] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C7000 length 0x00001000
[ 1857.307684] Mali<7>: Mapping phys 0x6F8D4000 length 0x00001000 at offset 0x00026000 to CPUVA 0xB50C7000
[ 1857.318136] Mali<7>: Mali map: mapping 0x6F8D4000 to Mali address 0x400A6000 length 0x00001000
[ 1857.327714] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00027000
[ 1857.336230] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C8000 length 0x00001000
[ 1857.346402] Mali<7>: Mapping phys 0x6F8D5000 length 0x00001000 at offset 0x00027000 to CPUVA 0xB50C8000
[ 1857.356855] Mali<7>: Mali map: mapping 0x6F8D5000 to Mali address 0x400A7000 length 0x00001000
[ 1857.366435] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00028000
[ 1857.374954] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50C9000 length 0x00001000
[ 1857.385125] Mali<7>: Mapping phys 0x6F8D6000 length 0x00001000 at offset 0x00028000 to CPUVA 0xB50C9000
[ 1857.395577] Mali<7>: Mali map: mapping 0x6F8D6000 to Mali address 0x400A8000 length 0x00001000
[ 1857.405153] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00029000
[ 1857.413670] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CA000 length 0x00001000
[ 1857.423840] Mali<7>: Mapping phys 0x6F8D7000 length 0x00001000 at offset 0x00029000 to CPUVA 0xB50CA000
[ 1857.434290] Mali<7>: Mali map: mapping 0x6F8D7000 to Mali address 0x400A9000 length 0x00001000
[ 1857.443868] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002A000
[ 1857.452388] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CB000 length 0x00001000
[ 1857.462558] Mali<7>: Mapping phys 0x6F8D8000 length 0x00001000 at offset 0x0002A000 to CPUVA 0xB50CB000
[ 1857.473010] Mali<7>: Mali map: mapping 0x6F8D8000 to Mali address 0x400AA000 length 0x00001000
[ 1857.482588] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002B000
[ 1857.491105] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CC000 length 0x00001000
[ 1857.501276] Mali<7>: Mapping phys 0x6F8D9000 length 0x00001000 at offset 0x0002B000 to CPUVA 0xB50CC000
[ 1857.511727] Mali<7>: Mali map: mapping 0x6F8D9000 to Mali address 0x400AB000 length 0x00001000
[ 1857.521306] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002C000
[ 1857.529804] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CD000 length 0x00001000
[ 1857.539974] Mali<7>: Mapping phys 0x6F8DA000 length 0x00001000 at offset 0x0002C000 to CPUVA 0xB50CD000
[ 1857.550442] Mali<7>: Mali map: mapping 0x6F8DA000 to Mali address 0x400AC000 length 0x00001000
[ 1857.560019] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002D000
[ 1857.568516] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CE000 length 0x00001000
[ 1857.578685] Mali<7>: Mapping phys 0x6F8DB000 length 0x00001000 at offset 0x0002D000 to CPUVA 0xB50CE000
[ 1857.589137] Mali<7>: Mali map: mapping 0x6F8DB000 to Mali address 0x400AD000 length 0x00001000
[ 1857.598716] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002E000
[ 1857.607233] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50CF000 length 0x00001000
[ 1857.617399] Mali<7>: Mapping phys 0x6F8DC000 length 0x00001000 at offset 0x0002E000 to CPUVA 0xB50CF000
[ 1857.627852] Mali<7>: Mali map: mapping 0x6F8DC000 to Mali address 0x400AE000 length 0x00001000
[ 1857.637430] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002F000
[ 1857.645936] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D0000 length 0x00001000
[ 1857.656102] Mali<7>: Mapping phys 0x6F8DD000 length 0x00001000 at offset 0x0002F000 to CPUVA 0xB50D0000
[ 1857.666553] Mali<7>: Mali map: mapping 0x6F8DD000 to Mali address 0x400AF000 length 0x00001000
[ 1857.676132] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00030000
[ 1857.684647] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D1000 length 0x00001000
[ 1857.694815] Mali<7>: Mapping phys 0x6F8DE000 length 0x00001000 at offset 0x00030000 to CPUVA 0xB50D1000
[ 1857.705263] Mali<7>: Mali map: mapping 0x6F8DE000 to Mali address 0x400B0000 length 0x00001000
[ 1857.714846] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00031000
[ 1857.723362] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D2000 length 0x00001000
[ 1857.733530] Mali<7>: Mapping phys 0x6F8DF000 length 0x00001000 at offset 0x00031000 to CPUVA 0xB50D2000
[ 1857.743984] Mali<7>: Mali map: mapping 0x6F8DF000 to Mali address 0x400B1000 length 0x00001000
[ 1857.753562] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00032000
[ 1857.762081] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D3000 length 0x00001000
[ 1857.772251] Mali<7>: Mapping phys 0x6F8E0000 length 0x00001000 at offset 0x00032000 to CPUVA 0xB50D3000
[ 1857.782703] Mali<7>: Mali map: mapping 0x6F8E0000 to Mali address 0x400B2000 length 0x00001000
[ 1857.792282] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00033000
[ 1857.800800] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D4000 length 0x00001000
[ 1857.810968] Mali<7>: Mapping phys 0x6F8E1000 length 0x00001000 at offset 0x00033000 to CPUVA 0xB50D4000
[ 1857.821419] Mali<7>: Mali map: mapping 0x6F8E1000 to Mali address 0x400B3000 length 0x00001000
[ 1857.830996] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00034000
[ 1857.839494] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D5000 length 0x00001000
[ 1857.849662] Mali<7>: Mapping phys 0x6F8E2000 length 0x00001000 at offset 0x00034000 to CPUVA 0xB50D5000
[ 1857.860130] Mali<7>: Mali map: mapping 0x6F8E2000 to Mali address 0x400B4000 length 0x00001000
[ 1857.869689] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00035000
[ 1857.878205] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D6000 length 0x00001000
[ 1857.888374] Mali<7>: Mapping phys 0x6F8E3000 length 0x00001000 at offset 0x00035000 to CPUVA 0xB50D6000
[ 1857.898829] Mali<7>: Mali map: mapping 0x6F8E3000 to Mali address 0x400B5000 length 0x00001000
[ 1857.908406] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00036000
[ 1857.916925] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D7000 length 0x00001000
[ 1857.927097] Mali<7>: Mapping phys 0x6F8E4000 length 0x00001000 at offset 0x00036000 to CPUVA 0xB50D7000
[ 1857.937548] Mali<7>: Mali map: mapping 0x6F8E4000 to Mali address 0x400B6000 length 0x00001000
[ 1857.947130] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00037000
[ 1857.955645] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D8000 length 0x00001000
[ 1857.965815] Mali<7>: Mapping phys 0x6F8E5000 length 0x00001000 at offset 0x00037000 to CPUVA 0xB50D8000
[ 1857.976315] Mali<7>: Mali map: mapping 0x6F8E5000 to Mali address 0x400B7000 length 0x00001000
[ 1857.985895] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00038000
[ 1857.994411] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50D9000 length 0x00001000
[ 1858.004581] Mali<7>: Mapping phys 0x6F8E6000 length 0x00001000 at offset 0x00038000 to CPUVA 0xB50D9000
[ 1858.015030] Mali<7>: Mali map: mapping 0x6F8E6000 to Mali address 0x400B8000 length 0x00001000
[ 1858.024610] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00039000
[ 1858.033127] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DA000 length 0x00001000
[ 1858.043297] Mali<7>: Mapping phys 0x6F8E7000 length 0x00001000 at offset 0x00039000 to CPUVA 0xB50DA000
[ 1858.053747] Mali<7>: Mali map: mapping 0x6F8E7000 to Mali address 0x400B9000 length 0x00001000
[ 1858.063326] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003A000
[ 1858.071846] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DB000 length 0x00001000
[ 1858.082016] Mali<7>: Mapping phys 0x6F8E8000 length 0x00001000 at offset 0x0003A000 to CPUVA 0xB50DB000
[ 1858.092470] Mali<7>: Mali map: mapping 0x6F8E8000 to Mali address 0x400BA000 length 0x00001000
[ 1858.102051] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003B000
[ 1858.110569] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DC000 length 0x00001000
[ 1858.120741] Mali<7>: Mapping phys 0x6F8E9000 length 0x00001000 at offset 0x0003B000 to CPUVA 0xB50DC000
[ 1858.131193] Mali<7>: Mali map: mapping 0x6F8E9000 to Mali address 0x400BB000 length 0x00001000
[ 1858.140774] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003C000
[ 1858.149273] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DD000 length 0x00001000
[ 1858.159440] Mali<7>: Mapping phys 0x6F8EA000 length 0x00001000 at offset 0x0003C000 to CPUVA 0xB50DD000
[ 1858.169894] Mali<7>: Mali map: mapping 0x6F8EA000 to Mali address 0x400BC000 length 0x00001000
[ 1858.179474] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003D000
[ 1858.187994] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DE000 length 0x00001000
[ 1858.198164] Mali<7>: Mapping phys 0x6F8EB000 length 0x00001000 at offset 0x0003D000 to CPUVA 0xB50DE000
[ 1858.208616] Mali<7>: Mali map: mapping 0x6F8EB000 to Mali address 0x400BD000 length 0x00001000
[ 1858.218194] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003E000
[ 1858.226704] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50DF000 length 0x00001000
[ 1858.236875] Mali<7>: Mapping phys 0x6F8EC000 length 0x00001000 at offset 0x0003E000 to CPUVA 0xB50DF000
[ 1858.247325] Mali<7>: Mali map: mapping 0x6F8EC000 to Mali address 0x400BE000 length 0x00001000
[ 1858.256901] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003F000
[ 1858.265418] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50E0000 length 0x00001000
[ 1858.275587] Mali<7>: Mapping phys 0x6F8ED000 length 0x00001000 at offset 0x0003F000 to CPUVA 0xB50E0000
[ 1858.286036] Mali<7>: Mali map: mapping 0x6F8ED000 to Mali address 0x400BF000 length 0x00001000
[ 1858.295614] Mali<6>: Allocated 64 pages
[ 1858.299868] Mali<6>: 256 out of 49152 pages now allocated
[ 1858.305878] Mali<7>: MMAP OK
[ 1858.309235] Mali<4>: MMap() handler: start=0xB5061000, phys=0x400C0000, size=0x00040000
[ 1858.318167] Mali<6>: Allocating page array of size 256 bytes
[ 1858.324470] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00000000
[ 1858.332987] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5061000 length 0x00001000
[ 1858.343158] Mali<7>: Mapping phys 0x6F8EE000 length 0x00001000 at offset 0x00000000 to CPUVA 0xB5061000
[ 1858.353608] Mali<7>: Mali map: mapping 0x6F8EE000 to Mali address 0x400C0000 length 0x00001000
[ 1858.363189] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00001000
[ 1858.371709] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5062000 length 0x00001000
[ 1858.381878] Mali<7>: Mapping phys 0x6F8EF000 length 0x00001000 at offset 0x00001000 to CPUVA 0xB5062000
[ 1858.392333] Mali<7>: Mali map: mapping 0x6F8EF000 to Mali address 0x400C1000 length 0x00001000
[ 1858.401908] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00002000
[ 1858.410427] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5063000 length 0x00001000
[ 1858.420596] Mali<7>: Mapping phys 0x6F8F0000 length 0x00001000 at offset 0x00002000 to CPUVA 0xB5063000
[ 1858.431047] Mali<7>: Mali map: mapping 0x6F8F0000 to Mali address 0x400C2000 length 0x00001000
[ 1858.440625] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00003000
[ 1858.449124] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5064000 length 0x00001000
[ 1858.459289] Mali<7>: Mapping phys 0x6F8F1000 length 0x00001000 at offset 0x00003000 to CPUVA 0xB5064000
[ 1858.469743] Mali<7>: Mali map: mapping 0x6F8F1000 to Mali address 0x400C3000 length 0x00001000
[ 1858.479320] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00004000
[ 1858.487840] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5065000 length 0x00001000
[ 1858.498015] Mali<7>: Mapping phys 0x6F8F2000 length 0x00001000 at offset 0x00004000 to CPUVA 0xB5065000
[ 1858.508467] Mali<7>: Mali map: mapping 0x6F8F2000 to Mali address 0x400C4000 length 0x00001000
[ 1858.518044] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00005000
[ 1858.526561] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5066000 length 0x00001000
[ 1858.536726] Mali<7>: Mapping phys 0x6F8F3000 length 0x00001000 at offset 0x00005000 to CPUVA 0xB5066000
[ 1858.547178] Mali<7>: Mali map: mapping 0x6F8F3000 to Mali address 0x400C5000 length 0x00001000
[ 1858.556754] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00006000
[ 1858.565270] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5067000 length 0x00001000
[ 1858.575440] Mali<7>: Mapping phys 0x6F8F4000 length 0x00001000 at offset 0x00006000 to CPUVA 0xB5067000
[ 1858.585880] Mali<7>: Mali map: mapping 0x6F8F4000 to Mali address 0x400C6000 length 0x00001000
[ 1858.595458] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00007000
[ 1858.603973] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5068000 length 0x00001000
[ 1858.614140] Mali<7>: Mapping phys 0x6F8F5000 length 0x00001000 at offset 0x00007000 to CPUVA 0xB5068000
[ 1858.624591] Mali<7>: Mali map: mapping 0x6F8F5000 to Mali address 0x400C7000 length 0x00001000
[ 1858.634169] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00008000
[ 1858.642686] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5069000 length 0x00001000
[ 1858.652851] Mali<7>: Mapping phys 0x6F8F6000 length 0x00001000 at offset 0x00008000 to CPUVA 0xB5069000
[ 1858.663302] Mali<7>: Mali map: mapping 0x6F8F6000 to Mali address 0x400C8000 length 0x00001000
[ 1858.672880] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00009000
[ 1858.681398] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506A000 length 0x00001000
[ 1858.691567] Mali<7>: Mapping phys 0x6F8F7000 length 0x00001000 at offset 0x00009000 to CPUVA 0xB506A000
[ 1858.702020] Mali<7>: Mali map: mapping 0x6F8F7000 to Mali address 0x400C9000 length 0x00001000
[ 1858.711599] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000A000
[ 1858.720118] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506B000 length 0x00001000
[ 1858.730287] Mali<7>: Mapping phys 0x6F8F8000 length 0x00001000 at offset 0x0000A000 to CPUVA 0xB506B000
[ 1858.740740] Mali<7>: Mali map: mapping 0x6F8F8000 to Mali address 0x400CA000 length 0x00001000
[ 1858.750321] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000B000
[ 1858.758819] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506C000 length 0x00001000
[ 1858.768991] Mali<7>: Mapping phys 0x6F8F9000 length 0x00001000 at offset 0x0000B000 to CPUVA 0xB506C000
[ 1858.779444] Mali<7>: Mali map: mapping 0x6F8F9000 to Mali address 0x400CB000 length 0x00001000
[ 1858.789023] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000C000
[ 1858.797541] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506D000 length 0x00001000
[ 1858.807706] Mali<7>: Mapping phys 0x6F8FA000 length 0x00001000 at offset 0x0000C000 to CPUVA 0xB506D000
[ 1858.818159] Mali<7>: Mali map: mapping 0x6F8FA000 to Mali address 0x400CC000 length 0x00001000
[ 1858.827729] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000D000
[ 1858.836246] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506E000 length 0x00001000
[ 1858.846411] Mali<7>: Mapping phys 0x6F8FB000 length 0x00001000 at offset 0x0000D000 to CPUVA 0xB506E000
[ 1858.856859] Mali<7>: Mali map: mapping 0x6F8FB000 to Mali address 0x400CD000 length 0x00001000
[ 1858.866437] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000E000
[ 1858.874954] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB506F000 length 0x00001000
[ 1858.885122] Mali<7>: Mapping phys 0x6F8FC000 length 0x00001000 at offset 0x0000E000 to CPUVA 0xB506F000
[ 1858.895573] Mali<7>: Mali map: mapping 0x6F8FC000 to Mali address 0x400CE000 length 0x00001000
[ 1858.905149] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0000F000
[ 1858.913668] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5070000 length 0x00001000
[ 1858.923837] Mali<7>: Mapping phys 0x6F8FD000 length 0x00001000 at offset 0x0000F000 to CPUVA 0xB5070000
[ 1858.934289] Mali<7>: Mali map: mapping 0x6F8FD000 to Mali address 0x400CF000 length 0x00001000
[ 1858.943867] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00010000
[ 1858.952381] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5071000 length 0x00001000
[ 1858.962552] Mali<7>: Mapping phys 0x6F8FE000 length 0x00001000 at offset 0x00010000 to CPUVA 0xB5071000
[ 1858.973113] Mali<7>: Mali map: mapping 0x6F8FE000 to Mali address 0x400D0000 length 0x00001000
[ 1858.982700] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00011000
[ 1858.991221] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5072000 length 0x00001000
[ 1859.001391] Mali<7>: Mapping phys 0x6F8FF000 length 0x00001000 at offset 0x00011000 to CPUVA 0xB5072000
[ 1859.011849] Mali<7>: Mali map: mapping 0x6F8FF000 to Mali address 0x400D1000 length 0x00001000
[ 1859.021428] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00012000
[ 1859.029926] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5073000 length 0x00001000
[ 1859.040116] Mali<7>: Mapping phys 0x6FB00000 length 0x00001000 at offset 0x00012000 to CPUVA 0xB5073000
[ 1859.050564] Mali<7>: Mali map: mapping 0x6FB00000 to Mali address 0x400D2000 length 0x00001000
[ 1859.060142] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00013000
[ 1859.068641] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5074000 length 0x00001000
[ 1859.078809] Mali<7>: Mapping phys 0x6FB01000 length 0x00001000 at offset 0x00013000 to CPUVA 0xB5074000
[ 1859.089262] Mali<7>: Mali map: mapping 0x6FB01000 to Mali address 0x400D3000 length 0x00001000
[ 1859.098841] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00014000
[ 1859.107359] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5075000 length 0x00001000
[ 1859.117524] Mali<7>: Mapping phys 0x6FB02000 length 0x00001000 at offset 0x00014000 to CPUVA 0xB5075000
[ 1859.127976] Mali<7>: Mali map: mapping 0x6FB02000 to Mali address 0x400D4000 length 0x00001000
[ 1859.137553] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00015000
[ 1859.146069] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5076000 length 0x00001000
[ 1859.156236] Mali<7>: Mapping phys 0x6FB03000 length 0x00001000 at offset 0x00015000 to CPUVA 0xB5076000
[ 1859.166688] Mali<7>: Mali map: mapping 0x6FB03000 to Mali address 0x400D5000 length 0x00001000
[ 1859.176268] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00016000
[ 1859.184785] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5077000 length 0x00001000
[ 1859.194954] Mali<7>: Mapping phys 0x6FB04000 length 0x00001000 at offset 0x00016000 to CPUVA 0xB5077000
[ 1859.205403] Mali<7>: Mali map: mapping 0x6FB04000 to Mali address 0x400D6000 length 0x00001000
[ 1859.214981] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00017000
[ 1859.223496] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5078000 length 0x00001000
[ 1859.233664] Mali<7>: Mapping phys 0x6FB05000 length 0x00001000 at offset 0x00017000 to CPUVA 0xB5078000
[ 1859.244115] Mali<7>: Mali map: mapping 0x6FB05000 to Mali address 0x400D7000 length 0x00001000
[ 1859.253690] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00018000
[ 1859.262206] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5079000 length 0x00001000
[ 1859.272380] Mali<7>: Mapping phys 0x6FB06000 length 0x00001000 at offset 0x00018000 to CPUVA 0xB5079000
[ 1859.282832] Mali<7>: Mali map: mapping 0x6FB06000 to Mali address 0x400D8000 length 0x00001000
[ 1859.292410] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00019000
[ 1859.300928] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507A000 length 0x00001000
[ 1859.311096] Mali<7>: Mapping phys 0x6FB07000 length 0x00001000 at offset 0x00019000 to CPUVA 0xB507A000
[ 1859.321548] Mali<7>: Mali map: mapping 0x6FB07000 to Mali address 0x400D9000 length 0x00001000
[ 1859.331126] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001A000
[ 1859.339624] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507B000 length 0x00001000
[ 1859.349798] Mali<7>: Mapping phys 0x6FB08000 length 0x00001000 at offset 0x0001A000 to CPUVA 0xB507B000
[ 1859.360268] Mali<7>: Mali map: mapping 0x6FB08000 to Mali address 0x400DA000 length 0x00001000
[ 1859.369827] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001B000
[ 1859.378344] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507C000 length 0x00001000
[ 1859.388515] Mali<7>: Mapping phys 0x6FB09000 length 0x00001000 at offset 0x0001B000 to CPUVA 0xB507C000
[ 1859.398970] Mali<7>: Mali map: mapping 0x6FB09000 to Mali address 0x400DB000 length 0x00001000
[ 1859.408545] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001C000
[ 1859.417063] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507D000 length 0x00001000
[ 1859.427231] Mali<7>: Mapping phys 0x6FB0A000 length 0x00001000 at offset 0x0001C000 to CPUVA 0xB507D000
[ 1859.437680] Mali<7>: Mali map: mapping 0x6FB0A000 to Mali address 0x400DC000 length 0x00001000
[ 1859.447258] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001D000
[ 1859.455772] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507E000 length 0x00001000
[ 1859.465952] Mali<7>: Mapping phys 0x6FB28000 length 0x00001000 at offset 0x0001D000 to CPUVA 0xB507E000
[ 1859.476404] Mali<7>: Mali map: mapping 0x6FB28000 to Mali address 0x400DD000 length 0x00001000
[ 1859.485980] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001E000
[ 1859.494494] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB507F000 length 0x00001000
[ 1859.504662] Mali<7>: Mapping phys 0x6FB29000 length 0x00001000 at offset 0x0001E000 to CPUVA 0xB507F000
[ 1859.515114] Mali<7>: Mali map: mapping 0x6FB29000 to Mali address 0x400DE000 length 0x00001000
[ 1859.524692] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0001F000
[ 1859.533214] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5080000 length 0x00001000
[ 1859.543384] Mali<7>: Mapping phys 0x6FB2A000 length 0x00001000 at offset 0x0001F000 to CPUVA 0xB5080000
[ 1859.553832] Mali<7>: Mali map: mapping 0x6FB2A000 to Mali address 0x400DF000 length 0x00001000
[ 1859.563411] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00020000
[ 1859.571929] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5081000 length 0x00001000
[ 1859.582100] Mali<7>: Mapping phys 0x6FB2B000 length 0x00001000 at offset 0x00020000 to CPUVA 0xB5081000
[ 1859.592552] Mali<7>: Mali map: mapping 0x6FB2B000 to Mali address 0x400E0000 length 0x00001000
[ 1859.602128] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00021000
[ 1859.610645] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5082000 length 0x00001000
[ 1859.620814] Mali<7>: Mapping phys 0x6FB2C000 length 0x00001000 at offset 0x00021000 to CPUVA 0xB5082000
[ 1859.631265] Mali<7>: Mali map: mapping 0x6FB2C000 to Mali address 0x400E1000 length 0x00001000
[ 1859.640843] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00022000
[ 1859.649342] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5083000 length 0x00001000
[ 1859.659507] Mali<7>: Mapping phys 0x6FB2D000 length 0x00001000 at offset 0x00022000 to CPUVA 0xB5083000
[ 1859.669959] Mali<7>: Mali map: mapping 0x6FB2D000 to Mali address 0x400E2000 length 0x00001000
[ 1859.679538] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00023000
[ 1859.688055] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5084000 length 0x00001000
[ 1859.698223] Mali<7>: Mapping phys 0x6FB2E000 length 0x00001000 at offset 0x00023000 to CPUVA 0xB5084000
[ 1859.708675] Mali<7>: Mali map: mapping 0x6FB2E000 to Mali address 0x400E3000 length 0x00001000
[ 1859.718253] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00024000
[ 1859.726770] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5085000 length 0x00001000
[ 1859.736935] Mali<7>: Mapping phys 0x6FB2F000 length 0x00001000 at offset 0x00024000 to CPUVA 0xB5085000
[ 1859.747386] Mali<7>: Mali map: mapping 0x6FB2F000 to Mali address 0x400E4000 length 0x00001000
[ 1859.756961] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00025000
[ 1859.765478] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5086000 length 0x00001000
[ 1859.775647] Mali<7>: Mapping phys 0x6FB30000 length 0x00001000 at offset 0x00025000 to CPUVA 0xB5086000
[ 1859.786096] Mali<7>: Mali map: mapping 0x6FB30000 to Mali address 0x400E5000 length 0x00001000
[ 1859.795679] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00026000
[ 1859.804195] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5087000 length 0x00001000
[ 1859.814363] Mali<7>: Mapping phys 0x6FB31000 length 0x00001000 at offset 0x00026000 to CPUVA 0xB5087000
[ 1859.824814] Mali<7>: Mali map: mapping 0x6FB31000 to Mali address 0x400E6000 length 0x00001000
[ 1859.834390] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00027000
[ 1859.842908] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5088000 length 0x00001000
[ 1859.853073] Mali<7>: Mapping phys 0x6FB32000 length 0x00001000 at offset 0x00027000 to CPUVA 0xB5088000
[ 1859.863525] Mali<7>: Mali map: mapping 0x6FB32000 to Mali address 0x400E7000 length 0x00001000
[ 1859.873102] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00028000
[ 1859.881640] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5089000 length 0x00001000
[ 1859.891841] Mali<7>: Mapping phys 0x6FB33000 length 0x00001000 at offset 0x00028000 to CPUVA 0xB5089000
[ 1859.902303] Mali<7>: Mali map: mapping 0x6FB33000 to Mali address 0x400E8000 length 0x00001000
[ 1859.911892] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00029000
[ 1859.920414] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508A000 length 0x00001000
[ 1859.930591] Mali<7>: Mapping phys 0x6FB34000 length 0x00001000 at offset 0x00029000 to CPUVA 0xB508A000
[ 1859.941043] Mali<7>: Mali map: mapping 0x6FB34000 to Mali address 0x400E9000 length 0x00001000
[ 1859.950624] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002A000
[ 1859.959123] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508B000 length 0x00001000
[ 1859.969295] Mali<7>: Mapping phys 0x6FB35000 length 0x00001000 at offset 0x0002A000 to CPUVA 0xB508B000
[ 1859.979786] Mali<7>: Mali map: mapping 0x6FB35000 to Mali address 0x400EA000 length 0x00001000
[ 1859.989367] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002B000
[ 1859.997886] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508C000 length 0x00001000
[ 1860.008057] Mali<7>: Mapping phys 0x6FB36000 length 0x00001000 at offset 0x0002B000 to CPUVA 0xB508C000
[ 1860.018515] Mali<7>: Mali map: mapping 0x6FB36000 to Mali address 0x400EB000 length 0x00001000
[ 1860.028094] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002C000
[ 1860.036643] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508D000 length 0x00001000
[ 1860.046818] Mali<7>: Mapping phys 0x6FB37000 length 0x00001000 at offset 0x0002C000 to CPUVA 0xB508D000
[ 1860.057279] Mali<7>: Mali map: mapping 0x6FB37000 to Mali address 0x400EC000 length 0x00001000
[ 1860.066861] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002D000
[ 1860.075378] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508E000 length 0x00001000
[ 1860.085547] Mali<7>: Mapping phys 0x6FB38000 length 0x00001000 at offset 0x0002D000 to CPUVA 0xB508E000
[ 1860.095999] Mali<7>: Mali map: mapping 0x6FB38000 to Mali address 0x400ED000 length 0x00001000
[ 1860.105574] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002E000
[ 1860.114090] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB508F000 length 0x00001000
[ 1860.124261] Mali<7>: Mapping phys 0x6FB39000 length 0x00001000 at offset 0x0002E000 to CPUVA 0xB508F000
[ 1860.134712] Mali<7>: Mali map: mapping 0x6FB39000 to Mali address 0x400EE000 length 0x00001000
[ 1860.144288] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0002F000
[ 1860.152803] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5090000 length 0x00001000
[ 1860.162974] Mali<7>: Mapping phys 0x6FB3A000 length 0x00001000 at offset 0x0002F000 to CPUVA 0xB5090000
[ 1860.173425] Mali<7>: Mali map: mapping 0x6FB3A000 to Mali address 0x400EF000 length 0x00001000
[ 1860.183002] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00030000
[ 1860.191520] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5091000 length 0x00001000
[ 1860.201688] Mali<7>: Mapping phys 0x6FB3B000 length 0x00001000 at offset 0x00030000 to CPUVA 0xB5091000
[ 1860.212138] Mali<7>: Mali map: mapping 0x6FB3B000 to Mali address 0x400F0000 length 0x00001000
[ 1860.221715] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00031000
[ 1860.230232] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5092000 length 0x00001000
[ 1860.240399] Mali<7>: Mapping phys 0x6FB3C000 length 0x00001000 at offset 0x00031000 to CPUVA 0xB5092000
[ 1860.250846] Mali<7>: Mali map: mapping 0x6FB3C000 to Mali address 0x400F1000 length 0x00001000
[ 1860.260424] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00032000
[ 1860.268924] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5093000 length 0x00001000
[ 1860.279101] Mali<7>: Mapping phys 0x6FB3D000 length 0x00001000 at offset 0x00032000 to CPUVA 0xB5093000
[ 1860.289557] Mali<7>: Mali map: mapping 0x6FB3D000 to Mali address 0x400F2000 length 0x00001000
[ 1860.299135] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00033000
[ 1860.307651] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5094000 length 0x00001000
[ 1860.317826] Mali<7>: Mapping phys 0x6FB3E000 length 0x00001000 at offset 0x00033000 to CPUVA 0xB5094000
[ 1860.328276] Mali<7>: Mali map: mapping 0x6FB3E000 to Mali address 0x400F3000 length 0x00001000
[ 1860.337853] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00034000
[ 1860.346370] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5095000 length 0x00001000
[ 1860.356535] Mali<7>: Mapping phys 0x6FB3F000 length 0x00001000 at offset 0x00034000 to CPUVA 0xB5095000
[ 1860.366992] Mali<7>: Mali map: mapping 0x6FB3F000 to Mali address 0x400F4000 length 0x00001000
[ 1860.376571] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00035000
[ 1860.385088] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5096000 length 0x00001000
[ 1860.395256] Mali<7>: Mapping phys 0x6FB40000 length 0x00001000 at offset 0x00035000 to CPUVA 0xB5096000
[ 1860.405705] Mali<7>: Mali map: mapping 0x6FB40000 to Mali address 0x400F5000 length 0x00001000
[ 1860.415282] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00036000
[ 1860.423797] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5097000 length 0x00001000
[ 1860.433964] Mali<7>: Mapping phys 0x6FB41000 length 0x00001000 at offset 0x00036000 to CPUVA 0xB5097000
[ 1860.444414] Mali<7>: Mali map: mapping 0x6FB41000 to Mali address 0x400F6000 length 0x00001000
[ 1860.453988] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00037000
[ 1860.462505] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5098000 length 0x00001000
[ 1860.472672] Mali<7>: Mapping phys 0x6FB42000 length 0x00001000 at offset 0x00037000 to CPUVA 0xB5098000
[ 1860.483122] Mali<7>: Mali map: mapping 0x6FB42000 to Mali address 0x400F7000 length 0x00001000
[ 1860.492698] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00038000
[ 1860.501214] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB5099000 length 0x00001000
[ 1860.511382] Mali<7>: Mapping phys 0x6FB43000 length 0x00001000 at offset 0x00038000 to CPUVA 0xB5099000
[ 1860.521833] Mali<7>: Mali map: mapping 0x6FB43000 to Mali address 0x400F8000 length 0x00001000
[ 1860.531411] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x00039000
[ 1860.539909] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509A000 length 0x00001000
[ 1860.550091] Mali<7>: Mapping phys 0x6FB44000 length 0x00001000 at offset 0x00039000 to CPUVA 0xB509A000
[ 1860.560543] Mali<7>: Mali map: mapping 0x6FB44000 to Mali address 0x400F9000 length 0x00001000
[ 1860.570127] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003A000
[ 1860.578625] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509B000 length 0x00001000
[ 1860.588793] Mali<7>: Mapping phys 0x6FB45000 length 0x00001000 at offset 0x0003A000 to CPUVA 0xB509B000
[ 1860.599244] Mali<7>: Mali map: mapping 0x6FB45000 to Mali address 0x400FA000 length 0x00001000
[ 1860.608821] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003B000
[ 1860.617338] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509C000 length 0x00001000
[ 1860.627510] Mali<7>: Mapping phys 0x6FB46000 length 0x00001000 at offset 0x0003B000 to CPUVA 0xB509C000
[ 1860.637958] Mali<7>: Mali map: mapping 0x6FB46000 to Mali address 0x400FB000 length 0x00001000
[ 1860.647535] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003C000
[ 1860.656048] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509D000 length 0x00001000
[ 1860.666229] Mali<7>: Mapping phys 0x6FB47000 length 0x00001000 at offset 0x0003C000 to CPUVA 0xB509D000
[ 1860.676684] Mali<7>: Mali map: mapping 0x6FB47000 to Mali address 0x400FC000 length 0x00001000
[ 1860.686261] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003D000
[ 1860.694777] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509E000 length 0x00001000
[ 1860.704943] Mali<7>: Mapping phys 0x6FB48000 length 0x00001000 at offset 0x0003D000 to CPUVA 0xB509E000
[ 1860.715394] Mali<7>: Mali map: mapping 0x6FB48000 to Mali address 0x400FD000 length 0x00001000
[ 1860.724971] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003E000
[ 1860.733486] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB509F000 length 0x00001000
[ 1860.743658] Mali<7>: Mapping phys 0x6FB49000 length 0x00001000 at offset 0x0003E000 to CPUVA 0xB509F000
[ 1860.754108] Mali<7>: Mali map: mapping 0x6FB49000 to Mali address 0x400FE000 length 0x00001000
[ 1860.763686] Mali<7>: Mapping phys 0xFFFFFFFF length 0x00001000 at offset 0x0003F000
[ 1860.772203] Mali<7>: Process map: mapping 0xFFFFFFFF to process address 0xB50A0000 length 0x00001000
[ 1860.782372] Mali<7>: Mapping phys 0x6FB4A000 length 0x00001000 at offset 0x0003F000 to CPUVA 0xB50A0000
[ 1860.792823] Mali<7>: Mali map: mapping 0x6FB4A000 to Mali address 0x400FF000 length 0x00001000
[ 1860.802398] Mali<6>: Allocated 64 pages
[ 1860.806652] Mali<6>: 320 out of 49152 pages now allocated
[ 1860.812663] Mali<7>: MMAP OK
[ 1860.816117] Mali<7>: Ioctl received 0xC0048500 0xBEC9C938
[ 1860.822201] Mali<5>: Mali GP scheduler: GP scheduler lock taken
[ 1860.828770] Mali<3>: Mali GP scheduler: Job 1 (0xEDAF1E40) queued
[ 1860.835561] Mali<3>: Mali GP scheduler: Starting job 1 (0xEDAF1E40)
[ 1860.842539] Mali<4>: Mali PM: Dynamic scheme; Changing Mali GPU power state from MALI_PM_LEVEL_3_LIGHT_SLEEP to: MALI_PM_LEVEL_1_ON
[ 1860.855683] Mali<3>: Mali PM: Setting GPU power mode to MALI_POWER_MODE_ON
[ 1860.863329] Mali<4>: Mali PM: Getting device PM reference (=> requesting MALI_POWER_MODE_ON)
[ 1860.872718] Mali<3>: mali_runtime_resume() called
[ 1860.877936] Mali<3>: Mali PM: OS runtime resumed
[ 1860.883079] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1860.889358] Mali<5>: Mali group: Releasing group lock 0xED463D80
[ 1860.896041] Mali<5>: Mali group: Group lock taken 0xED463D00
[ 1860.902319] Mali<5>: Mali group: Releasing group lock 0xED463D00
[ 1860.908999] Mali<5>: Mali group: Group lock taken 0xED463B00
[ 1860.915277] Mali<5>: Mali group: Releasing group lock 0xED463B00
[ 1860.921958] Mali<3>: group: POWER ON
[ 1860.925923] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1860.931950] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000002
[ 1860.931950] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x0000001D
[ 1860.931950] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for GP
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0xCAFEBABE
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000006
[ 1860.931950] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0000, val=0x00000000
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x001C, val=0x00000003
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x70D15000
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000000
[ 1860.931950] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000003
[ 1860.931950] Mali<4>: Mali GP: Reset of core Mali-400 GP
[ 1860.931950] Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00000000
[ 1860.931950] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00080000
[ 1860.931950] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0020, val=0x00000400
[ 1860.931950] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00000000
[ 1860.931950] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0024, val=0x00080000
[ 1860.931950] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00787FFF
[ 1860.931950] Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00706E67
[ 1860.931950] Mali<5>: Mali group: Releasing group lock 0xED463D80
[ 1861.152751] Mali<5>: Mali group: Group lock taken 0xED463D00
[ 1861.159035] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000002
[ 1861.162612] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x0000001D
[ 1861.162612] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP0
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0xCAFEBABE
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000006
[ 1861.162612] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x00000000
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x001C, val=0x00000003
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0000, val=0x70D15000
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000000
[ 1861.162612] Mali<6>: register_read for core Mali-400 MMU for PP0, relative addr=0x0004, val=0x00000019
[ 1861.162612] Mali<6>: register_write for core Mali-400 MMU for PP0, relative addr=0x0008, val=0x00000003
[ 1861.162612] Mali<4>: Mali PP: Reset of core Mali-400 PP0
[ 1861.162612] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000000
[ 1861.162612] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001000
[ 1861.162612] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x100C, val=0x00000080
[ 1861.162612] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00000000
[ 1861.162612] Mali<6>: register_read for core Mali-400 PP0, relative addr=0x1020, val=0x00001000
[ 1861.162612] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1024, val=0x00001FFF
[ 1861.162612] Mali<6>: register_write for core Mali-400 PP0, relative addr=0x1028, val=0x00000F3D
[ 1861.162612] Mali<5>: Mali group: Releasing group lock 0xED463D00
[ 1861.381562] Mali<5>: Mali group: Group lock taken 0xED463B00
[ 1861.387846] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000002
[ 1861.391547] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x0000001D
[ 1861.391547] Mali<3>: Mali MMU: mali_kernel_mmu_reset: Mali-400 MMU for PP1
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0xCAFEBABE
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000006
[ 1861.391547] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x00000000
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x001C, val=0x00000003
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0000, val=0x70D15000
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000000
[ 1861.391547] Mali<6>: register_read for core Mali-400 MMU for PP1, relative addr=0x0004, val=0x00000019
[ 1861.391547] Mali<6>: register_write for core Mali-400 MMU for PP1, relative addr=0x0008, val=0x00000003
[ 1861.391547] Mali<4>: Mali PP: Reset of core Mali-400 PP1
[ 1861.391547] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000000
[ 1861.391547] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001000
[ 1861.391547] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x100C, val=0x00000080
[ 1861.391547] Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00000000
[ 1861.391547] Mali<6>: register_read for core Mali-400 PP1, relative addr=0x1020, val=0x00001000
[ 1861.391547] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1024, val=0x00001FFF
[ 1861.391547] Mali<6>: register_write for core Mali-400 PP1, relative addr=0x1028, val=0x00000F3D
[ 1861.391547] Mali<5>: Mali group: Releasing group lock 0xED463B00
[ 1861.610365] Mali<6>: register_read for core Mali-400 L2 cache, relative addr=0x0008, val=0x00000000
[ 1861.620432] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0010, val=0x00000001
[ 1861.630592] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x001C, val=0x00000003
[ 1861.640749] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0018, val=0x0000001C
[ 1861.650908] Mali<5>: Mali group: Group lock taken 0xED463D80
[ 1861.657188] Mali<6>: register_read for core Mali-400 L2 cache, relative addr=0x0008, val=0x00000000
[ 1861.660896] Mali<6>: register_write for core Mali-400 L2 cache, relative addr=0x0010, val=0x00000001
[ 1861.660896] Mali<5>: Mali group: Activating page directory 0xEDBA4000 from session 0xEE1C8680 on group 0xED463D80
[ 1861.660896] Mali<5>: Mali group: Activate session: ee1c8680 previous: 00000000 on group 0xED463D80. Ref: 1
[ 1861.660896] Mali<5>: Asked to activate page directory 0xedba4000 on MMU Mali-400 MMU for GP
[ 1861.660896] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x00000019
[ 1861.660896] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000002
[ 1861.660896] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x0000001D
[ 1861.660896] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x70D19000
[ 1861.660896] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000004
[ 1861.660896] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000003
[ 1861.660896] Mali<6>: register_write_array: for core Mali-400 GP, relative addr=0x0000, nr of regs=6
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0000, val=0x40004180
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0004, val=0x400041E0
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0008, val=0x40006180
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x000C, val=0x40006220
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0010, val=0x40040000
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0014, val=0x40070000
[ 1861.660896] Mali<3>: Mali GP: Starting job (0xedaf1e40) on core Mali-400 GP with command 0x00000003
[ 1861.660896] Mali<6>: register_write_relaxed for core Mali-400 GP, relative addr=0x0020, val=0x00000003
[ 1861.660896] Mali<5>: Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0020, val=0x00000001
[ 1861.893574] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x001C, val=0x00000000
[ 1861.893584] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x000001CB
[ 1861.893617] Mali<3>: Mali MMU: Page fault bottom half: Locking subsystems
[ 1861.660896] Mali group: Releasing group lock 0xED463D80
[ 1861.938488] Mali<5>: Mali<5>: Mali GP scheduler: Releasing GP scheduler lock
[ 1861.940002] Mali group: Group lock taken 0xED463D80
[ 1861.940002] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0014, val=0x00000001
[ 1861.940002] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x000001CB
[ 1861.940002] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x000C, val=0x40006180
[ 1861.940002] Mali<2>: Mali MMU: Page fault detected at 0x40006180 from bus id 7 of type read on Mali-400 MMU for GP
[ 1861.940002] Mali<3>: Mali group: Resetting entire group
[ 1861.940002] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0020, val=0x00000200
[ 1861.940002] Mali<3>: Activating the page fault flush page directory on MMU Mali-400 MMU for GP
[ 1861.940002] Mali<3>: Aborting MMU stall request since it is in pagefault state.
[ 1861.940002] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0000, val=0x70D18000
[ 1861.940002] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000004
[ 1861.940002] Mali<4>: Mali MMU: Mali-400 MMU for GP: Leaving page fault mode
[ 1861.940002] Mali<6>: register_write for core Mali-400 MMU for GP, relative addr=0x0008, val=0x00000005
[ 1861.940002] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0068, val=0x0000000A
[ 1862.150030] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0068, val=0x0000000A
[ 1862.150030] Mali: ERR: drivers/gpu/mali/mali/common/mali_gp.c
[ 1862.150030]            mali_gp_stop_bus_wait() 162
[ 1862.150030]            Mali GP: Failed to stop bus on Mali-400 GP
[ 1862.150030]
[ 1862.150030] Mali<4>: Mali GP: Hard reset of core Mali-400 GP
[ 1862.150030] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0010, val=0x00000000
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0034, val=0xC0FFE000
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0020, val=0x00000020
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0034, val=0xC01A0000
[ 1862.150030] Mali<6>: register_read for core Mali-400 GP, relative addr=0x0034, val=0xC01A0000
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0034, val=0x00000000
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x0028, val=0x00787FFF
[ 1862.150030] Mali<6>: register_write for core Mali-400 GP, relative addr=0x002C, val=0x00706E67
[ 1862.150030] Mali<6>: register_read for core Mali-400 MMU for GP, relative addr=0x0004, val=0x000001CB
[ 1862.150030] Mali<3>: Aborting MMU stall request since it is in pagefault state.
[ 1862.150030] Mali: ERR: drivers/gpu/mali/mali/common/mali_mmu.c
[ 1862.150030]            mali_mmu_reset() 388
[ 1862.150030]            ASSERT failed: stall_success
[ 1862.150030] [<c0016a20>] (unwind_backtrace+0x0/0xe8) from [<c0687a10>] (dump_stack+0x20/0x24)
[ 1862.150030] [<c0687a10>] (dump_stack+0x20/0x24) from [<bf27c9a8>] (_mali_osk_abort+0x18/0x24 [mali])
[ 1862.150030] [<bf27c9a8>] (_mali_osk_abort+0x18/0x24 [mali]) from [<bf27c9cc>] (_mali_osk_break+0x18/0x1c [mali])
[ 1862.150030] [<bf27c9cc>] (_mali_osk_break+0x18/0x1c [mali]) from [<bf2697a0>] (mali_mmu_reset+0x9c/0x3e4 [mali])
[ 1862.150030] [<bf2697a0>] (mali_mmu_reset+0x9c/0x3e4 [mali]) from [<bf27721c>] (mali_group_complete_jobs+0x33c/0x3f4 [mali])
[ 1862.150030] [<bf27721c>] (mali_group_complete_jobs+0x33c/0x3f4 [mali]) from [<bf2779bc>] (mali_group_bottom_half+0xbc/0xc0 [mali])
[ 1862.150030] [<bf2779bc>] (mali_group_bottom_half+0xbc/0xc0 [mali]) from [<bf268db8>] (mali_mmu_bottom_half+0x1e0/0x22c [mali])
[ 1862.150030] [<bf268db8>] (mali_mmu_bottom_half+0x1e0/0x22c [mali]) from [<bf27a9a0>] (irq_handler_bottom_half+0x20/0x24 [mali])
[ 1862.150030] [<bf27a9a0>] (irq_handler_bottom_half+0x20/0x24 [mali]) from [<c0044508>] (process_one_work+0x248/0x404)
[ 1862.150030] [<c0044508>] (process_one_work+0x248/0x404) from [<c0045940>] (worker_thread+0x1b4/0x2d0)
[ 1862.150030] [<c0045940>] (worker_thread+0x1b4/0x2d0) from [<c0049c58>] (kthread+0x94/0xa0)
[ 1862.150030] [<c0049c58>] (kthread+0x94/0xa0) from [<c000f1b0>] (kernel_thread_exit+0x0/0x8)
[ 1862.150030] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 1862.150030] pgd = c0004000
[ 1862.150030] [00000000] *pgd=00000000
Edit 2: framebuffer mode is affected too compared to the original issue
