Help with installing Armbian 20.04 to EMMC from USB
Lorenzo
Hi guys,
thanks in advance for helping.
I flashed a usb (32G Lexar) with the image Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz
Next I booted up via the "Update&Backup" on a T95K Pro based on Amlogic S912 with 16G of internal storage and 2G of ram.
After apt-get update and apt-get upgrade I decided to move Armbian from the USB to the internal storage (emmc)
So I ran the file "install-aml.sh" getting this output:
Start script create MBR and filesystem
/dev/mmcblk0
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 4.45454 s, 942 kB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.00476152 s, 92.8 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.177546 s, 23.6 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24)
done.
Cppying BOOT...cp: error writing '/ddbr/install/zImage': No space left on device
done.
Edit init config...sed: couldn't flush /ddbr/install/extlinux/sedVudiPh: No space left on device
done.
done.
Formatting ROOT partition...
/dev/mmcblk0p2 contains a ext4 file system labelled 'ROOT_EMMC'
        last mounted on /ddbr/install on Sun Jul  4 17:10:59 2021
e2fsck 1.44.5 (15-Dec-2018)
ROOT_EMMC: clean, 11/863264 files, 80826/3447552 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Copy LIB64
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Complete copy OS to eMMC
This is the output of lsdisk after running the script
root@armbian:~# lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda            8:0    1  29.8G  0 disk
|-sda1         8:1    1   512M  0 part /boot
`-sda2         8:2    1    29G  0 part /
mmcblk0      179:0    0  14.6G  0 disk
|-mmcblk0p1  179:1    0   488M  0 part
`-mmcblk0p2  179:2    0  13.2G  0 part
mmcblk0boot0 179:32   0     4M  1 disk
mmcblk0boot1 179:64   0     4M  1 disk
zram0        254:0    0    50M  0 disk /var/log
zram1        254:1    0 929.2M  0 disk [SWAP]
However, after shutdown system and powered it up without the usb I get the following output:
U-Boot 2020.07-dirty (Jul 26 2020 - 13:24:26 +0200) hexdump-gxl
Model: hexdump usbkbd/hdmi u-boot gxl
SoC: Amlogic Meson GXM (S912) Revision 22:a (82:2)
Net: eth0 ethernet@c9410000
starting USB...
Bus dwx3@c9000000: Register 3000140 NbrPorts 3
Starting the controller
USB XHCI 1.00
scanning bus dwx3@c9000000 for devices... 1 USB Device(s) found
	scanning usb for storage devices... 0 Storage device(s) found
## Error insterting "stdin" variable, errno=22
Card did not respond to voltage select!
** No partition table - mmc 1 **
Hit any key to stop autoboot: [3-2-1-0]
switch to partitions #0, OK
mmc1 is current device
MMC Device 2 not found
no mmc device at solt 2
Device 0: unknown device
ethernet@c9410000 Waiting for PHY auto negotiation to complete........ TIMEOUT!
Could not initialize PHY ethernet@c9410000
missing enviroment variable: pxeuuid
missing enviroment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
*** COMMENT *** LOOPING OVER THESE 6 LINES TO INFINITY ***
If I boot up with the usb inserted it goes fine, without it no.
Output of ls -ls /dev/
root@armbian:/# ls dev -ls
total 0
0 crw-r--r-- 1 root root     10, 235 Jul  4 17:41 autofs
0 drwxr-xr-x 2 root root         740 Jul  4 17:41 block
0 drwxr-xr-x 2 root root          60 Jan  1  1970 bsg
0 crw-rw---- 1 root disk     10, 234 Jul  4 17:41 btrfs-control
0 drwxr-xr-x 3 root root          60 Jan  1  1970 bus
0 crw-rw---- 1 root video   251,   0 Jul  4 17:41 cec0
0 crw-rw---- 1 root video   251,   1 Jul  4 17:41 cec1
0 drwxr-xr-x 2 root root        3620 Jul  4 17:42 char
0 crw------- 1 root root      5,   1 Jul  4 17:52 console
0 crw------- 1 root root     10,  60 Jul  4 17:41 cpu_dma_latency
0 crw------- 1 root root     10, 203 Jul  4 17:41 cuse
0 drwxr-xr-x 7 root root         140 Jan  1  1970 disk
0 drwxr-xr-x 2 root root          80 Jan  1  1970 dma_heap
0 drwxr-xr-x 3 root root         120 Jul  4 17:41 dri
0 crw-rw---- 1 root video    29,   0 Jul  4 17:41 fb0
0 crw-rw---- 1 root video    29,   1 Jul  4 17:41 fb1
0 lrwxrwxrwx 1 root root          13 Jan  1  1970 fd -> /proc/self/fd
0 crw-rw-rw- 1 root root      1,   7 Jul  4 17:41 full
0 crw-rw-rw- 1 root root     10, 229 Jul  4 17:41 fuse
0 crw------- 1 root root    254,   0 Jul  4 17:41 gpiochip0
0 crw------- 1 root root    254,   1 Jul  4 17:41 gpiochip1
0 drwxr-xr-x 2 root root           0 Feb 14  2019 hugepages
0 crw------- 1 root root     10, 183 Jul  4 17:41 hwrng
0 crw------- 1 root root     89,   0 Jul  4 17:41 i2c-0
0 crw------- 1 root root     89,   1 Jul  4 17:41 i2c-1
0 crw------- 1 root root    248,   0 Jul  4 17:41 iio:device0
0 lrwxrwxrwx 1 root root          12 Jul  4 17:41 initctl -> /run/initctl
0 drwxr-xr-x 3 root root         140 Jul  4 17:41 input
0 crw-r--r-- 1 root root      1,  11 Jul  4 17:41 kmsg
0 crw-rw---- 1 root video   238,   0 Jul  4 17:41 lirc0
0 lrwxrwxrwx 1 root root          28 Feb 14  2019 log -> /run/systemd/journal/dev-log
0 crw-rw---- 1 root disk     10, 237 Jul  4 17:41 loop-control
0 brw-rw---- 1 root disk      7,   0 Jul  4 17:41 loop0
0 brw-rw---- 1 root disk      7,   1 Jul  4 17:41 loop1
0 brw-rw---- 1 root disk      7,   2 Jul  4 17:41 loop2
0 brw-rw---- 1 root disk      7,   3 Jul  4 17:41 loop3
0 brw-rw---- 1 root disk      7,   4 Jul  4 17:41 loop4
0 brw-rw---- 1 root disk      7,   5 Jul  4 17:41 loop5
0 brw-rw---- 1 root disk      7,   6 Jul  4 17:41 loop6
0 brw-rw---- 1 root disk      7,   7 Jul  4 17:41 loop7
0 drwxr-xr-x 2 root root          60 Jul  4 17:41 mapper
0 crw-r----- 1 root kmem      1,   1 Jul  4 17:41 mem
0 brw-rw---- 1 root disk    179,   0 Jul  4 17:41 mmcblk0
0 brw-rw---- 1 root disk    179,  32 Jul  4 17:41 mmcblk0boot0
0 brw-rw---- 1 root disk    179,  64 Jul  4 17:41 mmcblk0boot1
0 brw-rw---- 1 root disk    179,   1 Jul  4 17:41 mmcblk0p1
0 brw-rw---- 1 root disk    179,   2 Jul  4 17:41 mmcblk0p2
0 crw------- 1 root root    241,   0 Jul  4 17:41 mmcblk0rpmb
0 drwxrwxrwt 2 root root          40 Jan  1  1970 mqueue
0 drwxr-xr-x 2 root root          60 Jul  4 17:41 net
0 crw-rw-rw- 1 root root      1,   3 Jul  4 17:41 null
0 crw------- 1 root root     10,  62 Jul  4 17:41 nvme-fabrics
0 crw-r----- 1 root kmem      1,   4 Jul  4 17:41 port
0 crw------- 1 root root    108,   0 Jul  4 17:41 ppp
0 crw-rw-rw- 1 root tty       5,   2 Jul  4 17:54 ptmx
0 drwxr-xr-x 2 root root           0 Jan  1  1970 pts
0 crw------- 1 root root      2,   0 Jul  4 17:41 ptyp0
0 crw------- 1 root root      2,   1 Jul  4 17:41 ptyp1
0 crw------- 1 root root      2,   2 Jul  4 17:41 ptyp2
0 crw------- 1 root root      2,   3 Jul  4 17:41 ptyp3
0 crw------- 1 root root      2,   4 Jul  4 17:41 ptyp4
0 crw------- 1 root root      2,   5 Jul  4 17:41 ptyp5
0 crw------- 1 root root      2,   6 Jul  4 17:41 ptyp6
0 crw------- 1 root root      2,   7 Jul  4 17:41 ptyp7
0 crw------- 1 root root      2,   8 Jul  4 17:41 ptyp8
0 crw------- 1 root root      2,   9 Jul  4 17:41 ptyp9
0 crw------- 1 root root      2,  10 Jul  4 17:41 ptypa
0 crw------- 1 root root      2,  11 Jul  4 17:41 ptypb
0 crw------- 1 root root      2,  12 Jul  4 17:41 ptypc
0 crw------- 1 root root      2,  13 Jul  4 17:41 ptypd
0 crw------- 1 root root      2,  14 Jul  4 17:41 ptype
0 crw------- 1 root root      2,  15 Jul  4 17:41 ptypf
0 brw-rw---- 1 root disk      1,   0 Jul  4 17:41 ram0
0 brw-rw---- 1 root disk      1,   1 Jul  4 17:41 ram1
0 brw-rw---- 1 root disk      1,  10 Jul  4 17:41 ram10
0 brw-rw---- 1 root disk      1,  11 Jul  4 17:41 ram11
0 brw-rw---- 1 root disk      1,  12 Jul  4 17:41 ram12
0 brw-rw---- 1 root disk      1,  13 Jul  4 17:41 ram13
0 brw-rw---- 1 root disk      1,  14 Jul  4 17:41 ram14
0 brw-rw---- 1 root disk      1,  15 Jul  4 17:41 ram15
0 brw-rw---- 1 root disk      1,   2 Jul  4 17:41 ram2
0 brw-rw---- 1 root disk      1,   3 Jul  4 17:41 ram3
0 brw-rw---- 1 root disk      1,   4 Jul  4 17:41 ram4
0 brw-rw---- 1 root disk      1,   5 Jul  4 17:41 ram5
0 brw-rw---- 1 root disk      1,   6 Jul  4 17:41 ram6
0 brw-rw---- 1 root disk      1,   7 Jul  4 17:41 ram7
0 brw-rw---- 1 root disk      1,   8 Jul  4 17:41 ram8
0 brw-rw---- 1 root disk      1,   9 Jul  4 17:41 ram9
0 crw-rw-rw- 1 root root      1,   8 Jul  4 17:41 random
0 drwxr-xr-x 2 root root          60 Jan  1  1970 raw
0 crw-rw-r-- 1 root netdev   10, 242 Jul  4 17:42 rfkill
0 brw-rw---- 1 root disk      8,   0 Jul  4 17:41 sda
0 brw-rw---- 1 root disk      8,   1 Jul  4 17:41 sda1
0 brw-rw---- 1 root disk      8,   2 Jul  4 17:41 sda2
0 crw-rw---- 1 root disk     21,   0 Jul  4 17:41 sg0
0 drwxrwxrwt 2 root root          40 Feb 14  2019 shm
0 crw------- 1 root root     10, 231 Jul  4 17:41 snapshot
0 drwxr-xr-x 3 root root         140 Jul  4 17:41 snd
0 lrwxrwxrwx 1 root root          15 Jan  1  1970 stderr -> /proc/self/fd/2
0 lrwxrwxrwx 1 root root          15 Jan  1  1970 stdin -> /proc/self/fd/0
0 lrwxrwxrwx 1 root root          15 Jan  1  1970 stdout -> /proc/self/fd/1
0 crw-rw-rw- 1 root tty       5,   0 Jul  4 17:41 tty
0 crw--w---- 1 root tty       4,   0 Jul  4 17:41 tty0
0 crw--w---- 1 root tty       4,   1 Jul  4 17:52 tty1
0 crw--w---- 1 root tty       4,  10 Jul  4 17:41 tty10
0 crw--w---- 1 root tty       4,  11 Jul  4 17:41 tty11
0 crw--w---- 1 root tty       4,  12 Jul  4 17:41 tty12
0 crw--w---- 1 root tty       4,  13 Jul  4 17:41 tty13
0 crw--w---- 1 root tty       4,  14 Jul  4 17:41 tty14
0 crw--w---- 1 root tty       4,  15 Jul  4 17:41 tty15
0 crw--w---- 1 root tty       4,  16 Jul  4 17:41 tty16
0 crw--w---- 1 root tty       4,  17 Jul  4 17:41 tty17
0 crw--w---- 1 root tty       4,  18 Jul  4 17:41 tty18
0 crw--w---- 1 root tty       4,  19 Jul  4 17:41 tty19
0 crw--w---- 1 root tty       4,   2 Jul  4 17:41 tty2
0 crw--w---- 1 root tty       4,  20 Jul  4 17:41 tty20
0 crw--w---- 1 root tty       4,  21 Jul  4 17:41 tty21
0 crw--w---- 1 root tty       4,  22 Jul  4 17:41 tty22
0 crw--w---- 1 root tty       4,  23 Jul  4 17:41 tty23
0 crw--w---- 1 root tty       4,  24 Jul  4 17:41 tty24
0 crw--w---- 1 root tty       4,  25 Jul  4 17:41 tty25
0 crw--w---- 1 root tty       4,  26 Jul  4 17:41 tty26
0 crw--w---- 1 root tty       4,  27 Jul  4 17:41 tty27
0 crw--w---- 1 root tty       4,  28 Jul  4 17:41 tty28
0 crw--w---- 1 root tty       4,  29 Jul  4 17:41 tty29
0 crw--w---- 1 root tty       4,   3 Jul  4 17:41 tty3
0 crw--w---- 1 root tty       4,  30 Jul  4 17:41 tty30
0 crw--w---- 1 root tty       4,  31 Jul  4 17:41 tty31
0 crw--w---- 1 root tty       4,  32 Jul  4 17:41 tty32
0 crw--w---- 1 root tty       4,  33 Jul  4 17:41 tty33
0 crw--w---- 1 root tty       4,  34 Jul  4 17:41 tty34
0 crw--w---- 1 root tty       4,  35 Jul  4 17:41 tty35
0 crw--w---- 1 root tty       4,  36 Jul  4 17:41 tty36
0 crw--w---- 1 root tty       4,  37 Jul  4 17:41 tty37
0 crw--w---- 1 root tty       4,  38 Jul  4 17:41 tty38
0 crw--w---- 1 root tty       4,  39 Jul  4 17:41 tty39
0 crw--w---- 1 root tty       4,   4 Jul  4 17:41 tty4
0 crw--w---- 1 root tty       4,  40 Jul  4 17:41 tty40
0 crw--w---- 1 root tty       4,  41 Jul  4 17:41 tty41
0 crw--w---- 1 root tty       4,  42 Jul  4 17:41 tty42
0 crw--w---- 1 root tty       4,  43 Jul  4 17:41 tty43
0 crw--w---- 1 root tty       4,  44 Jul  4 17:41 tty44
0 crw--w---- 1 root tty       4,  45 Jul  4 17:41 tty45
0 crw--w---- 1 root tty       4,  46 Jul  4 17:41 tty46
0 crw--w---- 1 root tty       4,  47 Jul  4 17:41 tty47
0 crw--w---- 1 root tty       4,  48 Jul  4 17:41 tty48
0 crw--w---- 1 root tty       4,  49 Jul  4 17:41 tty49
0 crw--w---- 1 root tty       4,   5 Jul  4 17:41 tty5
0 crw--w---- 1 root tty       4,  50 Jul  4 17:41 tty50
0 crw--w---- 1 root tty       4,  51 Jul  4 17:41 tty51
0 crw--w---- 1 root tty       4,  52 Jul  4 17:41 tty52
0 crw--w---- 1 root tty       4,  53 Jul  4 17:41 tty53
0 crw--w---- 1 root tty       4,  54 Jul  4 17:41 tty54
0 crw--w---- 1 root tty       4,  55 Jul  4 17:41 tty55
0 crw--w---- 1 root tty       4,  56 Jul  4 17:41 tty56
0 crw--w---- 1 root tty       4,  57 Jul  4 17:41 tty57
0 crw--w---- 1 root tty       4,  58 Jul  4 17:41 tty58
0 crw--w---- 1 root tty       4,  59 Jul  4 17:41 tty59
0 crw--w---- 1 root tty       4,   6 Jul  4 17:41 tty6
0 crw--w---- 1 root tty       4,  60 Jul  4 17:41 tty60
0 crw--w---- 1 root tty       4,  61 Jul  4 17:41 tty61
0 crw--w---- 1 root tty       4,  62 Jul  4 17:41 tty62
0 crw--w---- 1 root tty       4,  63 Jul  4 17:41 tty63
0 crw--w---- 1 root tty       4,   7 Jul  4 17:41 tty7
0 crw--w---- 1 root tty       4,   8 Jul  4 17:41 tty8
0 crw--w---- 1 root tty       4,   9 Jul  4 17:41 tty9
0 crw--w---- 1 root tty     244,   0 Jul  4 17:52 ttyAML0
0 crw-rw---- 1 root dialout   4,  64 Jul  4 17:41 ttyS0
0 crw-rw---- 1 root dialout   4,  65 Jul  4 17:41 ttyS1
0 crw--w---- 1 root tty       4,  66 Jul  4 17:41 ttyS2
0 crw-rw---- 1 root dialout   4,  67 Jul  4 17:41 ttyS3
0 crw-rw---- 1 root dialout   4,  68 Jul  4 17:41 ttyS4
0 crw------- 1 root root      3,   0 Jul  4 17:41 ttyp0
0 crw------- 1 root root      3,   1 Jul  4 17:41 ttyp1
0 crw------- 1 root root      3,   2 Jul  4 17:41 ttyp2
0 crw------- 1 root root      3,   3 Jul  4 17:41 ttyp3
0 crw------- 1 root root      3,   4 Jul  4 17:41 ttyp4
0 crw------- 1 root root      3,   5 Jul  4 17:41 ttyp5
0 crw------- 1 root root      3,   6 Jul  4 17:41 ttyp6
0 crw------- 1 root root      3,   7 Jul  4 17:41 ttyp7
0 crw------- 1 root root      3,   8 Jul  4 17:41 ttyp8
0 crw------- 1 root root      3,   9 Jul  4 17:41 ttyp9
0 crw------- 1 root root      3,  10 Jul  4 17:41 ttypa
0 crw------- 1 root root      3,  11 Jul  4 17:41 ttypb
0 crw------- 1 root root      3,  12 Jul  4 17:41 ttypc
0 crw------- 1 root root      3,  13 Jul  4 17:41 ttypd
0 crw------- 1 root root      3,  14 Jul  4 17:41 ttype
0 crw------- 1 root root      3,  15 Jul  4 17:41 ttypf
0 crw------- 1 root root     10, 239 Jul  4 17:41 uhid
0 crw------- 1 root root     10, 223 Jul  4 17:41 uinput
0 crw------- 1 root root     10,  61 Jul  4 17:41 uleds
0 crw-rw-rw- 1 root root      1,   9 Jul  4 17:41 urandom
0 drwxr-xr-x 3 root root          60 Jul  4 17:41 v4l
0 crw-rw---- 1 root tty       7,   0 Jul  4 17:41 vcs
0 crw-rw---- 1 root tty       7,   1 Jul  4 17:41 vcs1
0 crw-rw---- 1 root tty       7,   2 Jul  4 17:41 vcs2
0 crw-rw---- 1 root tty       7,   3 Jul  4 17:41 vcs3
0 crw-rw---- 1 root tty       7,   4 Jul  4 17:41 vcs4
0 crw-rw---- 1 root tty       7,   5 Jul  4 17:41 vcs5
0 crw-rw---- 1 root tty       7,   6 Jul  4 17:41 vcs6
0 crw-rw---- 1 root tty       7, 128 Jul  4 17:41 vcsa
0 crw-rw---- 1 root tty       7, 129 Jul  4 17:41 vcsa1
0 crw-rw---- 1 root tty       7, 130 Jul  4 17:41 vcsa2
0 crw-rw---- 1 root tty       7, 131 Jul  4 17:41 vcsa3
0 crw-rw---- 1 root tty       7, 132 Jul  4 17:41 vcsa4
0 crw-rw---- 1 root tty       7, 133 Jul  4 17:41 vcsa5
0 crw-rw---- 1 root tty       7, 134 Jul  4 17:41 vcsa6
0 crw-rw---- 1 root tty       7,  64 Jul  4 17:41 vcsu
0 crw-rw---- 1 root tty       7,  65 Jul  4 17:41 vcsu1
0 crw-rw---- 1 root tty       7,  66 Jul  4 17:41 vcsu2
0 crw-rw---- 1 root tty       7,  67 Jul  4 17:41 vcsu3
0 crw-rw---- 1 root tty       7,  68 Jul  4 17:41 vcsu4
0 crw-rw---- 1 root tty       7,  69 Jul  4 17:41 vcsu5
0 crw-rw---- 1 root tty       7,  70 Jul  4 17:41 vcsu6
0 drwxr-xr-x 2 root root          60 Jan  1  1970 vfio
0 crw------- 1 root root     10,  63 Jul  4 17:41 vga_arbiter
0 crw------- 1 root root     10, 137 Jul  4 17:41 vhci
0 crw-rw---- 1 root video    81,   0 Jul  4 17:41 video0
0 crw------- 1 root root     10, 130 Jul  4 17:41 watchdog
0 crw------- 1 root root    246,   0 Jul  4 17:41 watchdog0
0 crw-rw-rw- 1 root root      1,   5 Jul  4 17:41 zero
0 brw-rw---- 1 root disk    254,   0 Jul  4 17:41 zram0
0 brw-rw---- 1 root disk    254,   1 Jul  4 17:41 zram1
0 brw-rw---- 1 root disk    254,   2 Jul  4 17:41 zram2
Any help is really appreciated.
Lorenzo (Italy)
Link to comment
Share on other sites
When discussing a problem make sure to provide full logs!
