xinul Posted July 6, 2021 Posted July 6, 2021 (edited) As a newbie here I'd first like to send greetings to all members and to send a big THANK YOU to the support team. My problem is: After booting cubietruck and installing the updates the USB devices aren't recognized anymore. I'm using standard devices: wired Logitech mouse, wired Cherry keyboard. Updating went smoothly and finished normally. Immediately after it, at the console prompt the keyboard was already dead. I rebooted repeatedly via HW switch because I couldn't log in and keyboard LEDs were also off. My questions: What could I try to fix this? Is any important info missing? Here is an extraction from `/var/log/messages`: Jul 6 13:17:17 cubie kernel: [ 16.343264] hub 5-0:1.0: USB hub found Jul 6 13:17:17 cubie kernel: [ 16.343339] hub 5-0:1.0: 1 port detected Jul 6 13:17:17 cubie kernel: [ 16.351875] Adding 1027124k swap on /dev/zram0. Priority:5 extents:1 across:1027124k SSFS Jul 6 13:17:17 cubie kernel: [ 16.611900] cfg80211: Loading compiled-in X.509 certificates for regulatory database Jul 6 13:17:17 cubie kernel: [ 16.612550] Bluetooth: Core ver 2.22 Jul 6 13:17:17 cubie kernel: [ 16.612745] NET: Registered protocol family 31 Jul 6 13:17:17 cubie kernel: [ 16.612754] Bluetooth: HCI device and connection manager initialized Jul 6 13:17:17 cubie kernel: [ 16.612783] Bluetooth: HCI socket layer initialized Jul 6 13:17:17 cubie kernel: [ 16.612797] Bluetooth: L2CAP socket layer initialized Jul 6 13:17:17 cubie kernel: [ 16.612836] Bluetooth: SCO socket layer initialized Jul 6 13:17:17 cubie kernel: [ 16.630461] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' Jul 6 13:17:17 cubie kernel: [ 16.635846] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 Jul 6 13:17:17 cubie kernel: [ 16.635874] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db Jul 6 13:17:17 cubie kernel: [ 16.694365] usb 4-1: new low-speed USB device number 2 using ohci-platform Jul 6 13:17:17 cubie kernel: [ 16.803666] usb 5-1: new low-speed USB device number 2 using ohci-platform Jul 6 13:17:17 cubie kernel: [ 16.886295] Bluetooth: HCI UART driver ver 2.3 Jul 6 13:17:17 cubie kernel: [ 16.886316] Bluetooth: HCI UART protocol H4 registered Jul 6 13:17:17 cubie kernel: [ 16.886323] Bluetooth: HCI UART protocol BCSP registered Jul 6 13:17:17 cubie kernel: [ 16.886541] Bluetooth: HCI UART protocol LL registered Jul 6 13:17:17 cubie kernel: [ 16.886551] Bluetooth: HCI UART protocol ATH3K registered Jul 6 13:17:17 cubie kernel: [ 16.886622] Bluetooth: HCI UART protocol Three-wire (H5) registered Jul 6 13:17:17 cubie kernel: [ 16.886879] Bluetooth: HCI UART protocol Broadcom registered Jul 6 13:17:17 cubie kernel: [ 16.887224] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator Jul 6 13:17:17 cubie kernel: [ 16.887538] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator Jul 6 13:17:17 cubie kernel: [ 16.929566] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1 Jul 6 13:17:17 cubie kernel: [ 16.931485] usb 4-1: New USB device found, idVendor=046d, idProduct=c069, bcdDevice=56.01 Jul 6 13:17:17 cubie kernel: [ 16.931507] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 Jul 6 13:17:17 cubie kernel: [ 16.931517] usb 4-1: Product: USB Laser Mouse Jul 6 13:17:17 cubie kernel: [ 16.931524] usb 4-1: Manufacturer: Logitech Jul 6 13:17:17 cubie kernel: [ 16.944758] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt failed with error -2 Jul 6 13:17:17 cubie kernel: [ 16.944780] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43362-sdio.cubietech,cubietruck.txt Jul 6 13:17:17 cubie kernel: [ 16.948566] input: Logitech USB Laser Mouse as /devices/platform/soc/1c14400.usb/usb4/4-1/4-1:1.0/0003:046D:C069.0001/input/input2 Jul 6 13:17:17 cubie kernel: [ 16.949337] hid-generic 0003:046D:C069.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-1c14400.usb-1/input0 Jul 6 13:17:17 cubie kernel: [ 17.052416] usb 5-1: New USB device found, idVendor=046a, idProduct=0023, bcdDevice= 2.20 Jul 6 13:17:17 cubie kernel: [ 17.052440] usb 5-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 Jul 6 13:17:17 cubie kernel: [ 17.323547] Bluetooth: hci0: BCM: chip id 63 Jul 6 13:17:17 cubie kernel: [ 17.326305] Bluetooth: hci0: BCM: features 0x07 Jul 6 13:17:17 cubie kernel: [ 17.350489] Bluetooth: hci0: BCM20702A Jul 6 13:17:17 cubie kernel: [ 17.350521] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000 Jul 6 13:17:17 cubie kernel: [ 17.817602] zram1: detected capacity change from 0 to 52428800 Jul 6 13:17:17 cubie kernel: [ 17.817791] cfg80211: failed to load regulatory.db Jul 6 13:17:17 cubie kernel: [ 18.159187] input: HID 046a:0023 as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.0/0003:046A:0023.0002/input/input3 Jul 6 13:17:17 cubie kernel: [ 18.219736] cherry 0003:046A:0023.0002: input,hidraw1: USB HID v1.11 Keyboard [HID 046a:0023] on usb-1c1c400.usb-1/input0 Jul 6 13:17:17 cubie kernel: [ 18.221955] input: HID 046a:0023 as /devices/platform/soc/1c1c400.usb/usb5/5-1/5-1:1.1/0003:046A:0023.0003/input/input4 Jul 6 13:17:17 cubie kernel: [ 18.234840] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1 Jul 6 13:17:17 cubie kernel: [ 18.238871] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available Jul 6 13:17:17 cubie kernel: [ 18.242440] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d Jul 6 13:17:17 cubie kernel: [ 18.279402] cherry 0003:046A:0023.0003: input,hidraw2: USB HID v1.11 Device [HID 046a:0023] on usb-1c1c400.usb-1/input1 Jul 6 13:17:17 cubie kernel: [ 19.395382] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard At shutdown: Jul 6 14:49:07 cubie kernel: [ 3071.800161] usb 4-1: USB disconnect, device number 2 Jul 6 14:49:07 cubie kernel: [ 3071.804241] usb 5-1: USB disconnect, device number 2 And here is the same extraction from the boot messages after updating: Jul 6 15:04:45 cubie kernel: [ 12.539805] hub 5-0:1.0: USB hub found Jul 6 15:04:45 cubie kernel: [ 12.539882] hub 5-0:1.0: 1 port detected Jul 6 15:04:45 cubie kernel: [ 12.788317] Bluetooth: hci0: BCM: chip id 63 Jul 6 15:04:45 cubie kernel: [ 12.791099] Bluetooth: hci0: BCM: features 0x07 Jul 6 15:04:45 cubie kernel: [ 12.814669] Bluetooth: hci0: BCM20702A Jul 6 15:04:45 cubie kernel: [ 12.814705] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000 Jul 6 15:04:45 cubie kernel: [ 13.221320] zram1: detected capacity change from 0 to 52428800 Jul 6 15:04:45 cubie kernel: [ 13.227066] cfg80211: failed to load regulatory.db Jul 6 15:04:45 cubie kernel: [ 13.242253] random: crng init done Jul 6 15:04:45 cubie kernel: [ 13.242275] random: 7 urandom warning(s) missed due to ratelimiting Jul 6 15:04:45 cubie kernel: [ 13.776907] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1 Jul 6 15:04:45 cubie kernel: [ 13.782054] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available Jul 6 15:04:45 cubie kernel: [ 13.783075] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43362/1 wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d Jul 6 15:04:45 cubie kernel: [ 14.244615] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard My install image, the current state user@host:$ cat armbian-image-release # PLEASE DO NOT EDIT THIS FILE BOARD=cubietruck BOARD_NAME="Cubietruck" BOARDFAMILY=sun7i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=79b790cf-dirty DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.11.6 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image IMAGE_UUID=cce0e008-f223-41de-84a4-8a4f505cb5bc user@host:$ cat armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=cubietruck BOARD_NAME="Cubietruck" BOARDFAMILY=sun7i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=428a20876-dirty DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=21.05.6 LINUXFAMILY=sunxi ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image BRANCH=current B.t.w.: I tried it as an A20 bug report first but questions couldn't match my situation: Does the system boot: Yes, but I can't provide the requested info nevertheless, It's not a bug of a certain image but in the update process/of a certain package/of a certain post trigger. So please give me a hint which category I could have chosen better. Edited July 6, 2021 by xinul typo
TRS-80 Posted July 7, 2021 Posted July 7, 2021 Moved to Common issues / peer to peer technical support
