Documentation is wrong for Lamobo-R1 image
mrled
The FAQ says the username is "root" and the password is "1234", but the password for the root user on at least the image in Lamobo-r1_Debian_3.2_jessie_4.1.2.zip is "pi" (apparently also the default bananian password).
edit: nope, I'm just an idiot. The docs are right. Sorry! Don't see a way to delete this topic, but I would if I could.
FAQ is correct. You must have mix something ... or you are might be using some unofficial build?
root is 1234 on all images since I start with the project. There is not a single reason to change this. At least on my builds.
The only problem / issue with Jessie is that you need to wait for first reboot until you can login. Only on Jessie.
