I've decided to give a try for a Mainline PineA64 Armbian Full Image build.
Unfortenately, it seems that U-Boot is not in good shape, it stall right at the beginning without even trying to load kernel :
HELLO! BOOT0 is starting!
boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 29664 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 00068000.
sum=ab1a8b8a
src_sum=ab1a8b8a
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x00000200 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x0000b200 success
set arisc reset to de-assert state
Ready to disable icache.
Jump to secend Boot.
NOTICE:  BL3-1: Running in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):f11ecb4
NOTICE:  BL3-1: Built : 14:12:39, Aug 19 2016
NOTICE:  Configuring AXP PMIC
NOTICE:  PMIC: already configured for RSB
NOTICE:  PMIC: setup successful
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
Any body can explain that stall ?
Notes : the kernel build itself is Ok, because I've taken an already working Pine64 image and placed the new Kernel in it and it is booting and working properly.
https://www.mail-archive.com/u-boot@lists.denx.de/msg221063.html
Unfortunately it's a random error that can be fixed bypassed by resetting the board several times.
Edit: this is the most "interesting" part
The root cause of all these troubles is that on Allwinner A64 the
SRAM C is apparently temporarily leased from the Cedar VE accelerator
during the boot time. This was a relatively recent discovery:
http://irclog.whitequark.org/linux-sunxi/2016-06-29#16862925;
And an ugly part of it is that accessing SRAM C directly by the CPU
is unreliable if AHB1 is clocked at 200MHz (default when running the
Allwinner's Linux kernel). But the SRAM C works fine with AHB1 clocked
at 100MHz (which is, for example the default clock speed in the
FEL mode). So after AHB1 is reclocked (by boot0), nobody can safely
access SRAM C anymore.
Hi Zador,
Thanks for the info, unfortunately, the multiple reset doesn't work for me.
Is it working for you ?
According to the most "interesting" part, lowering the clock should be the way to go, but I haven't figured out where it should be done.
EDIT : I found that, but this is already commited ...
https://patchwork.ozlabs.org/patch/627962/
I managed to boot it once several days ago when I added mainline configuration for Pine64.
AFAIK this fix is already present in latest u-boot, but either it's not working or something else prevents u-boot from starting up. But since reset worked for me, I'm assuming this is still the same issue.
Hi Zador,
Thanks for the hints,
I've recompiled with having this patch Reverted : https://github.com/linux-sunxi/u-boot-sunxi/commit/1a83fb4a17d959d7b037999ab7ed7e62429abe34
U-Boot is now comes up, but with errors about ethernet, and fallback to prompt.
It seems that it doesn't look at the boot.scr.
It complains about "Unrecognized filesystem" but when prompt come up, I can easily do "ls mmc 0 /boot" ont the Ext4.
It is like it doesn't know Ext4 until getting to the prompt.
So, I've copy/paste boot.cmd commands, and it boot succesfully, but it is a tedious task on every reboot :P
Here are the ethernet errors (BTW, all forums are different : how to make this output as spoiler ?) :
set pll start
set pll end
PMU: AXP81X
DRAM clk = 672 MHz
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card no is 0
[mmc]: 50000000 Hz
[mmc]: 15193 MB
sdcard 0 init ok
sum=064d2b8c
src_sum=064d2b8c
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x0000c200 success
NOTICE:  BL3-1: Built : 20:02:40, Aug 19 2016
U-Boot 2016.09-rc1-g793fd86-dirty (Aug 19 2016 - 20:02:42 -0400) Allwinner Technology
CPU:   Allwinner A64 (SUN50I)
Model: Pine64+
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
Error: ethernet@01c30000 address not set.
No ethernet found.
starting USB...
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
1574 bytes read in 175 ms (7.8 KiB/s)
## Executing script at 4fc00000
ext4load - load binary file from a Ext4 filesystem
Usage:
ext4load <interface> [<dev[:part]> [addr [filename [bytes [pos]]]]]
    - load binary file 'filename' from 'dev' on 'interface'
      to address 'addr' from ext4 filesystem
Usage:
Usage:
Usage:
Usage:
Usage:
Usage:
Usage:
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
starting USB...
USB is stopped. Please issue 'usb start' first.
starting USB...
phy interface7
mdio_register: non unique device name 'ethernet@01c30000'
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
Retrieving file: pxelinux.cfg/default-arm-sunxi
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
Config file not found
starting USB...
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
phy interface7
phy interface7
phy interface7
phy interface7
No ethernet found.
phy interface7
=> <INTERRUPT>
=> setenv bootargs "console=ttyS0,115200 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 panic=10 consoleblank=0 enforcing=0 loglevel=7"
=> ext4load mmc 0 ${fdt_addr_r} /boot/dtb/allwinner/${fdtfile}
11661 bytes read in 243 ms (45.9 KiB/s)
=> ext4load mmc 0 ${ramdisk_addr_r} /boot/uInitrd
2910499 bytes read in 391 ms (7.1 MiB/s)
=> ext4load mmc 0 ${kernel_addr_r} /boot/Image
12530176 bytes read in 999 ms (12 MiB/s)
=> booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
Those few manual copy/paste lines at the end making the boot process occurred successfully ...
(on a SideNote, I'm seeing that my DT ConfigFS patches are not apply in this PineA64 flavor, I will have to dig that too ...
Grrrr ! first investigation is that you disabled it 3 days ago : https://github.com/igorpecovnik/lib/commit/735dee1d4da978331ed018c948938b2473f9c90e
Could tell me what was wrong there ? ... And please, send notice when such thing occurs ... :angry: )
Patches need to be updated for kernel 4.7, I disabled them since they weren't applied cleanly.  :(
Wrap it in tags manually like this:
[spoiler]
long wall of text
or quote
or image
or code block
[/spoiler]
I'll check (and fix if needed) my boot script later
I just compiled an image for Pine64 dev target without u-boot patches.
While it hanged here at first boot
single press of reset button booted it further to u-boot prompt.
And second boot attempt loaded u-boot after first try, without resetting the board.
I missed address part in some ext4load/fatload commands while merging legacy and mainline boot scripts, should be fixed now.
Hi Zador,
No worries, I've used the 4.8 version I've already done in sunxi-dev and it works, so I will submit PR in few minutes.
The only thing that would be appreciated is to let authors know when such things are disactivated instead of leaving them figure out several days later :unsure:
It is still doesn't work for me as a workaround.
But it is working is the SRAM Stack patch is unpatched. So, I've prepared the unpatch_sun50i_sram_stack_issue.patch for my next PR.
Yes, thanks for that fix. No more need to manually type the boot.cmd in u-boot shell ... ;)
EDIT : PR done ! (and since Igor gave me github rights, PR merged ...)
I've also added a /proc/cpuinfo patch to allow compatibility of RPi.GPIO-PineA64 against the older Longsleep kernel, by adding Processor/Hardware entries.
Thanks for this, I have been banging my head on this problem for two days.
My PINE64+ does not boot (tried apritzel's, DENX etc) all fail..
reverting the patch fixed it for me
board: [A-64-DB-2G-rev B]
Reverting the patch on git://git.denx.de/u-boot.git..  fixed u-boot hang but left
    "U-Boot is now comes up, but with errors about ethernet, and fallback to prompt."
Do you have boot script and all files that it loads (kernel, DT and possibly initrd image)? U-boot will fall back to network boot (which won't work due to missing Ethernet support for A64) and then to command prompt in case boot script fails.
