tbbw Posted August 20, 2016 Posted August 20, 2016 So... second sack at the sav here.Last time i wrote i had a kingson sd card ( a low one ) but it was recomended to buy a Samsung Evo sd card instead.So after i confirmed one of the kingston sd cards was bad i more or less whent thru the warranty getting a refund for that one ( not sure why i botherd since it was so cheap ).Anyhow.Got my Samsung EVO card and tryed with DD in linux and rufus wich you guys recomend for windows and still same issue with Armbian.It boots the other distros like Debian and Ubuntu from the orange pi's webpage but no ethernet.And when i try armbian i get the uboot text thru the ftdi but it does not find any boot device. U-Boot SPL 2016.05-armbian (Jun 23 2016 - 11:35:25) DRAM: 1024 MiB Card did not respond to voltage select! Could not determine boot source resetting ... One thing did make me wonder what's going on is something in the rufus log ( wich i attached ).So i'm starting to think there is something wierd with the raw image not having a bootable partition or something.Oh and i did do the "check device for bad blocks" for 4 passes first time i tryed and it took freaking ages but no errors since i wanted to rule that out first thing.
tbbw Posted August 20, 2016 Author Posted August 20, 2016 Figured i'll link to the original topic with the kingston sd card here http://forum.armbian.com/index.php/topic/1495-solved-another-broken-sdcard-orange-pi-pc-h3-not-booting/ And fdisking in the boot flag on the partition made no diffrance.Looking at a roll of ductape on my desk i started thinking along the lines since i can boot the images from orangepi's website... cant i boot that up and then dd the armbian's raw image directly into the built in memory and then power down, unplug sd card and then boot from that?I'll try a usb stick first and see if that works since i did remember reading something about usb install on the armbian's website here: http://www.armbian.com/orange-pi-pc/"NAND, SATA, eMMC and USB install script is included (nand-sata-install)"
rodolfo Posted August 20, 2016 Posted August 20, 2016 Figured i'll link to the original topic with the kingston sd card here http://forum.armbian.com/index.php/topic/1495-solved-another-broken-sdcard-orange-pi-pc-h3-not-booting/ And fdisking in the boot flag on the partition made no diffrance. oops ... sounds like you had some frantic moments. Just relax. 1. Your board basically works ( your tests with other images ) 2. The SDcard works on other boards ( your tests ) 3. Armbian for Orange Pi installed per http://www.armbian.com/documentation works ( tested by other Armbian users ) This leaves us with : - possibly corrupted image ( downloaded image or copy to SDcard ) - power issues ( OPIs are very picky about sufficient and stable power supply - see related forum posts ) Do a fresh download of Armbian for your board, dd it to SDcard and proceed EXACTLY as per http://www.armbian.com/documentation Best of luck and have fun.
tbbw Posted August 20, 2016 Author Posted August 20, 2016 I wanted to rule out the 2amp 5v usb adaptor so i solderd a female usb connector onto a molex connector and i'm running it from my spare coarsair psu i'm getting a stable 5v from it.As for corrupted image/download: 8c46c53ac41ad27f5541dcd48fd844a6e0d1148f423c5261e1c00323f64e9706 *./Armbian_5.14_Orangepipc_Ubuntu_xenial_3.4.112.raw Could anyone check sha256 if it matches?
tbbw Posted August 20, 2016 Author Posted August 20, 2016 I might aswell just try to build it from the github repo since i'm running out of ideas.Nope same issue: U-Boot SPL 2016.07-armbian (Aug 20 2016 - 10:50:46) DRAM: 1024 MiB Card did not respond to voltage select! Could not determine boot source resetting ...
tbbw Posted August 20, 2016 Author Posted August 20, 2016 Since power was mentioned iwe tryed diffrent ways of powering it.The way iwe always powerd it was thru the dc jack on the board.I just now tryed the micro usb and it does not seem to want to power on with power thru the micro usb connector.Not sure if i should attempt giving it 5v directly on that gpio header since i remember it bypassed alot of protection on the RasPi and probobly is simular for the OrangePi.Anyhow... not given up yet since it feels like armbian is taunting me with this board.
zador.blood.stained Posted August 20, 2016 Posted August 20, 2016 I wanted to rule out the 2amp 5v usb adaptor so i solderd a female usb connector onto a molex connector and i'm running it from my spare coarsair psu i'm getting a stable 5v from it. As for corrupted image/download: 8c46c53ac41ad27f5541dcd48fd844a6e0d1148f423c5261e1c00323f64e9706 *./Armbian_5.14_Orangepipc_Ubuntu_xenial_3.4.112.raw Could anyone check sha256 if it matches? Just tested this image on Orange Pi PC. SHA256 matches your value. Image was written with Rufus. U-Boot SPL 2016.05-armbian (Jun 23 2016 - 11:35:25) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2016.05-armbian (Jun 23 2016 - 11:35:25 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2465 bytes read in 182 ms (12.7 KiB/s) ## Executing script at 43100000 gpio: pin PL10 (gpio 298) value is 1 gpio: pin PG11 (gpio 203) value is 1 0 bytes read in 131 ms (0 Bytes/s) ** File not found /boot/.next ** ** Unrecognized filesystem type ** ** File not found .next ** 36192 bytes read in 517 ms (68.4 KiB/s) 3136481 bytes read in 3392 ms (902.3 KiB/s) 5011808 bytes read in 5366 ms (911.1 KiB/s) Kernel image @ 0x48000000 [ 0x000000 - 0x4c7960 ] ## Loading init Ramdisk from Legacy Image at 42000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3136417 Bytes = 3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Using machid 0x1029 from environment Starting kernel ... So it's definitely a problem on your side.
tbbw Posted August 20, 2016 Author Posted August 20, 2016 Hmm... you dont have the voltage select error in uboot.I wonder if it's related somehow? I also noticed when trying diffrent images not all of em have that voltage error message only some have. Could it be a revision issue with my board?Like "Orange Pi PC v1.2" vs some other version?
zador.blood.stained Posted August 20, 2016 Posted August 20, 2016 I just now tryed the micro usb and it does not seem to want to power on with power thru the micro usb connector. It's not designed to be powered through microUSB port Not sure if i should attempt giving it 5v directly on that gpio header since i remember it bypassed alot of protection on the RasPi and probobly is simular for the OrangePi. You can power it through GPIO pins (+5V to pin 4, GND to pin 6; pin 1 is marked with white triangle on PCB since GPIO connector orientation is different on different boards), but it is equivalent to powering through DC-IN socket. You can try this method if it gives you ability to try another power supply Hmm... you dont have the voltage select error in uboot. I wonder if it's related somehow? I also noticed when trying diffrent images not all of em have that voltage error message only some have. Could it be a revision issue with my board? Like "Orange Pi PC v1.2" vs some other version? I don't think there are other revisions available in public Are there any non-Armbian images that print voltage error messages for you?
tbbw Posted August 20, 2016 Author Posted August 20, 2016 No no voltage warnings on other images just armbian... well what i'm running with now is the Ubuntu_trusty_mini.img from orange pi's forum.Issue with that one is the script.bin file in ther lil boot fat partition (even ther updated kernel+script.bin had this issue) makes the ethernet card have the fritz ( on closer inspection they dont have those two gpio pins set high ) and spams the dmesg with irq errors.So since i compiled armbian from source i stole the script.bin file from armbian's boot folder and put it in the orangepi ubuntu_trusty_mini's fat partition ( all hail ductape ) and it boots up with working ethernet.The big diffrance i spot right away with how they boot, armbian uses uboot and the orangepi's ubuntu trusty uses a diffrent boot loader with a vfat partition with the uImage and script.bin. I do not get any errors from there in the bootup.The orange pi's forum got a google drive where i checked a few other images out like ther regular debian builds and ther raspbian wich does seem to use uboot but half way in when it's going to mount the rootfs it tryes to mount mmcblk0p2 wich does not exist on those images and it halts there i was abit too lazy to install x on my other linux machine with gparted just to see what would hapen if i move the root partition and just put an empty partition in between to get the "p2" part to add up since it sounded like alot easyer solution since the setenv in was ignored for some reson and i'm abit too tierd right now to figure out where else it was getting that parition number from. I might do an attempt in grabbing the first few mb of the raspbian ( yeah discoverd why you guys leave a few mb space between start of sd card and the actual rootfs ) or debian image from orangepi since they do contain working uboot mbr's and whacking in the actual root partition of armbian to see what hapens since ther uboot does spot the partition and does try to boot but tryes to mount the wrong partition number.
tbbw Posted August 20, 2016 Author Posted August 20, 2016 HELLO! BOOT0 is starting! boot0 version : 4.0.0 fel_flag = 0x00000000 rtc[0] value = 0x00000000 rtc[1] value = 0x00000000 rtc[2] value = 0x00000000 rtc[3] value = 0x00000000 rtc[4] value = 0x00000000 rtc[5] value = 0x00000000 rtc[6] value = 0x00000000 rtc[7] value = 0x00000000 DRAM DRIVE INFO: V0.8 DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM CLK = 672 MHz DRAM zq value: 003b3bfb READ DQS LCDL = 001c1d1e DRAM SIZE =1024 M odt delay dram size =1024 card boot number = 0 card no is 0 sdcard 0 line count 4 [mmc]: mmc driver ver 2014-12-10 21:20:39 [mmc]: ***Try SD card 0*** [mmc]: SD/MMC Card: 4bit, capacity: 14992MB [mmc]: vendor: Man 001b534d Snr 0bc350f0 [mmc]: product: 00000 [mmc]: revision: 1.0 [mmc]: ***SD/MMC 0 init OK!!!*** sdcard 0 init ok The size of uboot is 000dc000. sum=ede66ee7 src_sum=ede66ee7 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. SUNXI_NORMAL_MODE [ 0.346]e mode U-Boot 2011.09-rc1 (Jun 21 2015 - 19:33:17) Allwinner Technology [ 0.354]version: 1.1.0 normal mode [ 0.361]pmbus: ready not set main pmu id axp_probe error [ 0.376]PMU: pll1 1200 Mhz,PLL6=600 Mhz AXI=400 Mhz,AHB=200 Mhz, APB1=100 Mhz sid read already fel key new mode run key detect no key found no key input dram_para_set start dram_para_set end normal mode [ 0.407]DRAM: 1 GiB relocation Offset is: 35af9000 [box standby] read rtc = 0x0 [box_start_os] mag be start_type no use user_gpio config user_gpio ok gic: normal or no secure os mode workmode = 0 MMC: 0 [ 0.481][mmc]: mmc driver ver 2014-12-10 9:23:00 [ 0.486][mmc]: get sdc_phy_wipe fail. [ 0.490][mmc]: get sdc0 sdc_erase fail. [ 0.494][mmc]: get sdc_f_max fail,use default 50000000Hz [ 0.499][mmc]: get sdc_ex_dly_used fail,use default dly [ 0.505][mmc]: SUNXI SD/MMC: 0 [ 0.518][mmc]: *Try SD card 0* [ 0.551][mmc]: CID 0x1b534d30 0x30303030 0x100bc350 0xf000e73d [ 0.556][mmc]: mmc clk 50000000 [ 0.560][mmc]: SD/MMC Card: 4bit, capacity: 14992MB [ 0.565][mmc]: boot0 capacity: 0KB,boot1 capacity: 0KB [ 0.570][mmc]: ***SD/MMC 0 init OK!!!*** [ 0.574][mmc]: erase_grp_size:0x1WrBlk * 0x200 = 0x200 Byte [ 0.580][mmc]: secure_feature 0x0 [ 0.583][mmc]: secure_removal_type 0x0 [ 0.587]sunxi flash init ok script config pll_de to 864 Mhz Not Found clk pll_video1 in script script config pll_video to 297 Mhz [boot]disp_init_tv [DISP_TV] disp_init_tv enter g_tv_used screen 0 do not support TV TYPE! [BOOOT_DISP_TV] disp tv device_registered unable to find regulator vcc-hdmi-18 from [pmu1_regu] or [pmu2_regu] enable power vcc-hdmi-18, ret=-1 DRV_DISP_Init end boot_disp.auto_hpd=1 auto hpd check has 50 times! [disk_read_fs] no the partition error: open disp_rsl.fex, maybe it is not exist attched ok, mgr1<-->device1, type=2, mode=11---- ready to set mode disp_tv_enable [ 1.428]finally, output_type=0x2, output_mode=0xb, screen_id=0x1, disp_para=0x20b0000 fail to find part named env Using default environment In: serial Out: serial Err: serial --------fastboot partitions-------- mbr not exist base bootcmd=run setargs_mmc boot_normal bootcmd set setargs_mmc key 0 cant find rcvy value cant find fstbt value no misc partition is found to be run cmd=run setargs_mmc boot_normal [ 1.465][mmc]: MMC Device 2 not found [ 1.469][mmc]: Can not find mmc dev [ 1.473][mmc]: read first backup failed in fun sdmmc_secure_storage_read line 1849 sunxi_secstorage_read fail get secure storage map err the private part isn't exist WORK_MODE_BOOT adver not need show sunxi_bmp_logo_display [disk_read_fs] no the partition error: open bootlogo.bmp, maybe it is not exist sunxi bmp info error : unable to open logo file bootlogo.bmp [ 1.506]Hit any key to stop autoboot: 0
