NanoPi R2S doesn't boot
Go to solution Solved by MikrySoft,
I have a strange problem with my R2S.
I grabbed latest buster and focal images, burned them using Balena Etcher onto a pair of 32GB SanDisk Extreme Cards and neither is booting.
Serial console shows that boot process gives up waiting for root file system and drops me into initramfs shell.
Looking into /dev, I see no mmcblk0 device (or any other block device apart from loops).
If I now eject and re-insert the card, the device shows up. If I do it during boot process, while the board is still waiting for rootfs, boot process continues correctly. Reboots are fine, but if I unplug the board for longer than a second it's back to initramfs for me.
Serial log:
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 248
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 32737
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xab950
RunBL31 0x40000
INFO:    Preloader serial: 2
NOTICE:  BL31: v1.3(debug):403e0b816
NOTICE:  BL31: Built : 14:13:08, Aug 11 2020
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Aug 08 2021 - 16:05:19 +0200)
Model: FriendlyElec NanoPi R2S
DRAM:  1022 MiB
PMIC:  RK8050 (on=0x40, off=0x01)
MMC:   mmc@ff500000: 1
Loading Environment from MMC... MMC Device 0 not found
*** Warning - No MMC card found, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 4 ms (777.3 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
247 bytes read in 3 ms (80.1 KiB/s)
15345011 bytes read in 669 ms (21.9 MiB/s)
28582400 bytes read in 1241 ms (22 MiB/s)
65148 bytes read in 11 ms (5.6 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3de0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15344947 Bytes = 14.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 3d08b000, end 3df2d533 ... OK
   Loading Device Tree to 000000003d012000, end 000000003d08afff ... OK
Starting kernel ...
Loading, please wait...
Starting version 245.4-4ubuntu3.11
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  UUID=f9a9e443-670a-4c64-a431-b9b92bdb0765 does not exist.  Dropping to a shell!
BusyBox v1.30.1 (Ubuntu 1:1.30.1-4ubuntu6.3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs) ^[[63;13Rreboot -f
reboot -f
[  197.532837] reboot: Restarting system
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO:      Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
In
SRX
DDR4
333MHz
ddrconfig:14
OUT
ChipType = 0x11, 324
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 33575
Raw SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
DRAM:  1022 MiB
In:    serial@ff130000
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
247 bytes read in 4 ms (59.6 KiB/s)
28582400 bytes read in 1242 ms (21.9 MiB/s)
65148 bytes read in 10 ms (6.2 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
done.
Begin: Will now check root file system ... fsck from util-linux 2.34
[/usr/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: recovering journal
/dev/mmcblk0p1: clean, 44694/2579008 files, 532617/7708672 blocks
done.
done.
Welcome to Armbian 21.05.8 Focal!
