perfstr Posted August 25, 2016 Posted August 25, 2016 Hello, I run my program system as a service in console mode, so no login is needed. The Linux system starts up almost quietly after changes in boot.scr. The only "small" thing that needs a solution is the login prompt. How can I prevent login prompt from appearing? I've tried some autologin options I found for different Linux systems, but they didn't work for me. Any suggestion?
perfstr Posted August 26, 2016 Author Posted August 26, 2016 I found the solution - it should be similar to the change described in the link: https://wiki.archlinux.org/index.php/Getty#Automatic_login_to_virtual_console change /lib/systemd/system/getty@.service file, ExecStart string to contain ExecStart=-/usr/bin/agetty --autologin username ... After the change is applied, the console screen still shows some text, which needs to be disabled. Any idea?
lagerschaden Posted December 10, 2017 Posted December 10, 2017 under armbian 5.35 Debian Jessie 3.4.113-sun8i I added the following file /lib/systemd/system/getty@tty1.service.d/20-autologin.conf with root privileges: # /lib/systemd/system/getty@tty1.service.d/20-autologin.conf [Service] ExecStart= ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM If needed, change 'pi' with another username. Then reboot.
