Junkman Posted October 20, 2021 Posted October 20, 2021 Hi, currently container build only support docker, when I run `./compile.sh docker`(docker is an alias of podman), the build will fail. When I switch back to docker, the build is ok. Can Armbian dev team consider support podman? since podman is popular nowadays. :-P
Junkman Posted October 20, 2021 Author Posted October 20, 2021 3 minutes ago, Junkman said: Hi, currently container build only support docker, when I run `./compile.sh docker`(docker is an alias of podman), the build will fail. When I switch back to docker, the build is ok. Can Armbian dev team consider support podman? since podman is popular nowadays. :-P I'd love to join the test procedure if you may plan to do so.
lanefu Posted October 20, 2021 Posted October 20, 2021 If someone wants to do the work we'll gladly review a pull request for it. Just not something that the Armbian devs are going to work on themselves.
