Hi, currently container build only support docker, when I run `./compile.sh docker`(docker is an alias of podman), the build will fail.
When I switch back to docker, the build is ok.
Can Armbian dev team consider support podman? since podman is popular nowadays. :-P
I'd love to join the test procedure if you may plan to do so.
If someone wants to do the work we'll gladly review a pull request for it.  Just not something that the Armbian devs are going to work on themselves.
