I'm newbie on ARMBian. If I wrote in the wrong place please let me know.
Because Android 6 is becoming oboslote. I followed this process for installing ARMBian on my MXQ PRO mini Nexbox a95x.
https://i12bretro.github.io/tutorials/0185.html
I booted on my USB key well but the box is staying on starting kernel message with this log I copied from my screen :
2 USB Desvoice(s) found
	scanning usb for storage devices... 1 Storage Dovice(s) found
## Error inserting "stdin" variable, errno=22
Card did not respond to voltage select?
Card did not respond to uoltage select?
** No partition table - mmc 1 **
** No partition table - mmc1 **
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1(part 0) is current device
MMC Device 2 not found
no mmc device at slot 2
Deuice 0: Vendor: SanDisk' Reu: 1.00 Prod: Cruzer Fit
	Type: Removable Hard Disk
	Capacity: 7632.0 MB = 7.4 GB (15630336 x 512)
... is now current device
Scanning usb 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1470 bytes read in 4 ms (358.4 KiB/s)
1: Armbian
Retrieving file: /ulnitrd
10922066 bytes read in 314 ms (33.2 Mill/s)
Retrieving file: /zlmage
28078592 bytes read in 802 ms (33.4 MiB/s)
append: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115020m0 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Retrieving file: /dtb/amlogic/meson-g12b-odroid-n.dtb
51611 bytes read in 7 ms (7 MiB/s)
## Loading init Ramdisk from Legacy Image at 13000000 ...
Image Mame: ulnitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 10922002 Bytes = 10.4 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 00000000
Booting using the fdt blob at Ox0000000
Error disabling PHY supply
Host not halted after 16000 microseconds.
Loading Randisk to 3b4e4000, end 3bf4e812  ... OK
Loading Device Tree to 000000003b4d4000, end 0000000003b4e399a ... OK
Starting kernel ...
What did I miss ?
Thank
It's  working
I did a mistake in extlinux.conf
I corrected like this :
LABEL Armbian
LINUX /zImage
INITRD /uInitrd
# aml s9xxx
#FDT /dtb/amlogic/meson-gxbb-p200.dtb
FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb
#FDT /dtb/amlogic/meson-gxm-q200.dtb
#FDT /dtb/amlogic/meson-g12a-x96-max.dtb
#FDT /dtb/amlogic/meson-g12b-odroid-n2.dtb
APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Like I read there is no WIFI, no blue-tooth and no sound. I've to install them. But easy I connected the MXQ PRO mini box on wired Ethernet and the apt is working
Thank for your support it was useful to read your documentation.
FYI, I installed alsa server and the sound is working in the X environment. I choice XFCE
Thank
