Hello everybody,
I´m appareantly not capable of changing the datadir of the mariadb installation.
I googled it and followed several tutorial, yet I cant make it work.
Example
https://www.tecmint.com/change-default-mysql-mariadb-data-directory-in-linux/
I change the settings in this file /etc/mysql/mariadb.conf.d/50-server.cnf and i added under following sections the new datadirs/sockets
[mysqld]
datadir=/srv/dev-disk-by-id-ata-SanDisk_SDSSDH3_2T00_210837801141-part2/Medien/Programme/MariaDB
socket=/srv/dev-disk-by-id-ata-SanDisk_SDSSDH3_2T00_210837801141-part2/Medien/Programme/MariaDB/mysql.sock
[client]
port=3306
Also i change the owner of the folder
chown -R mysql:mysql /srv/dev-disk-by-id-ata-SanDisk_SDSSDH3_2T00_210837801141-part2/Medien/Programme/MariaDB
and changed the path of the socket in those files under /etc/mysql/conf.d/ and /etc/mysql/mariadb.conf.d/
After i get those error messages
Warning: skipping '!includedir /etc/mysql/conf.d/' directive as maximum includerecursion level was reached in file /etc/mysql/mariadb.cnf at line 22
Warning: skipping '!includedir /etc/mysql/mariadb.conf.d/' directive as maximum includerecursion level was reached in file /etc/mysql/mariadb.cnf at line 23
Did anybody make it work with armbian?
Best Regards
Vin
There should not be any difference since this is userspace and Armbian does not touch/modify mariadb packages in any way. Armbian puts a userspace environment (Debian Bullseye, Ubuntu Focal) with minimal adjustments for performance on top of a working kernel for the specific hardware.
Besides all of that it would be interesting to know on which hardware you are actually working on and
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
