[Orange Pi Zero 2 H616] Rootless docker failing install + Can't use non-legacy Kernel versions
Hello here, I thank you in advance for coming here.
I have gotten an Orange Pi Zero 2 H616 yesterday, and I wanted to install Docker as Rootless on the ARMBian Bullseye image, but It is failing every try I do to actually bring it up. It always gives the following message in Journalctl:
docker.service: Start request repeated too quickly.
I just wanted to ask if anybody has actually found a way to deal with this.
Alternatively, I cannot boot any kernel higher than the legacy 4.9 kernel given on the main page, all the others give no feedback when the board connects to the current. I am pretty sure I am missing something, but I found no info online about what to do and if anybody fixed that on the forums.
I thank you in advance for responding.
I had run podman at my orangepi zero2, you can try it.
But it only can use host network, I do not know how to fix it.
Edited by inkflaw
CHANGE: armbianEnv
DOCKER FORCE CGROUPS V1: [working docker for legacy builds]
extraargs=systemd.unified_cgroup_hierarchy=0
alistair@orangepizero2:~$ sudo docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
 1. The Docker client contacted the Docker daemon.
 2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
    (arm64v8)
 3. The Docker daemon created a new container from that image which runs the
    executable that produces the output you are currently reading.
 4. The Docker daemon streamed that output to the Docker client, which sent it
    to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
 $ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
 https://hub.docker.com/
For more examples and ideas, visit:
 https://docs.docker.com/get-started/
Possibly also (if you haven't): Debian builds
update-alternatives --set iptables /usr/sbin/iptables-legacy
Rootless: haven't tried.
