Dear gurus good afternoon. I ask for help because itself I don't understand any more what not so I do. I should make a clone of my sdcard, but nothing leaves. I tried so:
I find the sdcard
fdisk - l
I create the empty file of an image
dd if=/dev/zero of=armbian.img bs=2048 count=1402144
also I add him to loop
losetup/dev/loop0 armbian.img
now I clone the sdcard in loop the device
dd if=/dev/sdd of=/dev/loop0
now I write down a half-scientific image on new sdcard
dd bs=2048 if=armbian.img of=/dev/sdd
As a result my sdcard doesn't seem on linux and I can't mount sections and loading doesn't happen to sdcard. Prompt please in what a mistake and as to me to make a clone of the sdcard.
I am very grateful.
i think you can just do   :
dd if=/dev/sdd of=/home/user/imagename.img
sdd is the sdcard  change user too your user
(i have not tryed this with armbian images but it works for raspberry)
My new sdcard is a little less than old therefore at record of an image on the new card which has been created so: dd if=/dev/sdd of=/home/user/imagename.img, the message is given:
dd: write error "/dev/sdd": On the device there is no empty seat left
7563265+0 records are received
7563264+0 records are sent
 15489564672 bytes (15 GB), 4249,41 c, 3,6 MB/c are copied
That's the reason why most recent Armbian images do not use the full capacity of the installation media but leave a small spare area. To prevent this sort of problems since cards of 'same' size might differ by a few sectors in reality.
A few more infos can be found by googling for 'backup sd card site:armbian.com' (seems the forum search is completely broken ATM), IIRC @rodolfo provided a script to clone in such a situation somewhere in the forums.
  On 9/1/2016 at 3:44 PM, Alexandr Kuznetsov said:
I haven't absolutely understood what next to do? how to me to transfer an image?
You can shrink the image a little with GParted, to fit to your new card. Just make sure you don't cut file area. You can use this guide:
Shrinking images on Linux
  On 9/1/2016 at 8:09 PM, rodolfo said:
Thanks a lot, everything has turned out. I had only one question: whether this method of cloning is correct whether something will break? Also I apologize that not on a subject, but I am tormented by a question why after performance of nand-sata-install the root section is in the fstab file on / dev/mmcblk1p1
/dev/mmcblk1p1/ext4 defaults, noatime, nodiratime, commit=600, errors=remount-ro 0 1
, judging by fdisk - l the root section has to be / dev/mmcblk0p1
/ dev/mmcblk0p1 2048 30469567 30467520 14.5G 83 Linux
