Hi
Is there a way to set url for kernel sources for build process of armbian?
I want to try this kernel: https://github.com/openedev/linux which has - potentially - fix for my problem described here:
and here:
https://forum.banana-pi.org/t/lcd-module-dsi-rgb-with-touch-and-s070swv20hg-dc16-lcd-panel-mainline-kernel/11172
But i have no idea how to change default url for kernel sources.
Ps.
I'm using docker to build and have question: where armbian stores its kernel sources(locally) and how to obtain its urls?
Thx ;)
Already done it ;) - but kernel won't to compile :(
@WernerDo you know
where armbian stores its kernel sources(locally) when using docker? I can't find it under output dir in work directory.
Here is my structure:
s3b0@lenovo ~/Public/git/lamobo/armbian-current $ tree -L 1
├── LICENSE
├── README.md
├── VERSION
├── build.sh
├── cache
├── compile.sh
├── config
├── kernel
├── lib
├── output
├── packages
├── patch
├── unused_patches
└── userpatches
Don't know, never used docker :)
Anyway if the build process of the kernel package was successful a linux-src deb is created in output/debs.
Everything that is downloaded like toolchains and sources is in the cache folder.
