Porting the RK3399 Legacy Multimedia Framework to Balena OS
@JMCC I'm trying to recreate some of this setup for the Rock Pi 4B running Balena OS (based on Debian Buster) and not getting very far.  All I need is for Chromium to recognize the GPU for acceleration. I downloaded the .deb files and tried them, but I killed the OS.  I'm willing to hire you to do it.  Or anyone else if they understand what to do.
How can I go about adapting this code for Balena OS or stock Debian on the Rock Pi 4B?  I'm looking only to activate hardware acceleration in Chromium.
I know nothing about Balena OS. But if you want to make Chromium acceleration work, the way we do it is contained in this package. Pay special attention to this config file
Thank you!  Will absolutely be donating!
I followed these steps:
  1. installed the Mali Midgard drivers for the 3399
  2. installed gcc g++ libpng-dev libjpeg-dev pkg-config libx11-dev libdrm-dev libgbm-dev libgbm1 libudev-dev mesa-utils xlibmesa xserver-xorg
  3. Installed the armbian-media git using the instructions in the readme (you have a typo for the directory of gl4es/arm64)
  4. Launched Chromium with the flags in your config file
Chrome://gpu reports:
Graphics Feature Status
Canvas: Hardware accelerated
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Force enabled
Out-of-process Rasterization: Disabled
OpenGL: Enabled
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Enabled
Video Decode: Software only. Hardware acceleration disabled
Vulkan: Disabled
WebGL: Hardware accelerated but at reduced performance
WebGL2: Hardware accelerated but at reduced performance
Any ideas how to accelerate the other GPU items: Compositing, WebGL and WebGL2?
Now I'm questioning if it worked at all... Open GL still shows LLVMPipe as the renderer and not the Mali GPU
It's confusing because I definitely see the CPU usage decline when running Chromium.  Previously it ran 40-50% and now it runs 20-30% with better frame rates.  It definitely looks like the GPU is doing something.
rock@rockpi4b:~/work/glmark2/armbian-media/gl4es/arm64$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
    GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_ARB_create_context_profile, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
    GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: VMware, Inc. (0xffffffff)
    Device: llvmpipe (LLVM 7.0, 128 bits) (0xffffffff)
    Version: 18.3.6
    Accelerated: no
    Video memory: 3811MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 3.3
    Max compat profile version: 3.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.0
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 7.0, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 18.3.6
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
    GL_AMD_gpu_shader_int64, GL_AMD_multi_draw_indirect,
    GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
    GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,
    GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_ARB_ES2_compatibility,
    GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
    GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
    GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
    GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
    GL_ARB_get_texture_sub_image, GL_ARB_gpu_shader_fp64,
    GL_ARB_gpu_shader_int64, GL_ARB_half_float_pixel,
    GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
    GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
    GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
    GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query,
    GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sampler_objects,
    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
    GL_ARB_separate_shader_objects, GL_ARB_shader_bit_encoding,
    GL_ARB_shader_objects, GL_ARB_shader_stencil_export,
    GL_ARB_shader_subroutine, GL_ARB_shader_texture_lod,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_buffer_object,
    GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
    GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_float,
    GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_viewport_array, GL_ATI_blend_equation_separate,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
    GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_integer,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
    GL_EXT_vertex_attrib_64bit, GL_IBM_multimode_draw_arrays,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
    GL_KHR_texture_compression_astc_ldr,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
    GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
    GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_NV_packed_depth_stencil, GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.1 Mesa 18.3.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
    GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
    GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_depth_texture, GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_get_texture_sub_image, GL_ARB_half_float_pixel,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing,
    GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
    GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_separate_stencil,
    GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
    GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
    GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 18.3.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
    GL_APPLE_texture_max_level, GL_EXT_base_instance,
    GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
    GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image,
    GL_EXT_discard_framebuffer, GL_EXT_disjoint_timer_query,
    GL_EXT_draw_buffers, GL_EXT_draw_buffers_indexed,
    GL_EXT_draw_elements_base_vertex, GL_EXT_frag_depth,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
    GL_EXT_read_format_bgra, GL_EXT_separate_shader_objects,
    GL_EXT_shader_integer_mix, GL_EXT_texture_border_clamp,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV,
    GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
    GL_KHR_no_error, GL_KHR_texture_compression_astc_ldr,
    GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_image_external_essl3,
    GL_OES_EGL_sync, GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image,
    GL_OES_depth24, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
    GL_OES_required_internalformat, GL_OES_rgb8_rgba8,
    GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_vertex_array_object,
    GL_OES_vertex_half_float
