WaterWastage Posted January 29, 2022 Posted January 29, 2022 Image: Armbian_20.10_Arm-64_bullseye_current_5.9.0.img.xz dtb: meson-gxl-s905x-p212.dtb u-boot: u-boot-s905x-s912 Board: Front: https://i.imgur.com/Fc2rZtd.jpg Rear: https://i.imgur.com/zTvPdCZ.jpg Other info from Device Info HW App: http://deviceinfohw.ru/devices/item.php?item=561897 , https://i.imgur.com/U6gPqeM.jpg , https://i.imgur.com/fZTB8No.jpg , https://i.imgur.com/oX37xze.jpg I think it has 2G RAM but none of the device tree I tried worked out. I tried pretty much all meson-gxl-* and a couple others. Board name on android says p201 but I can't find any GXL device tree for p201, I also looked around and found it may be p211 but the device tree I found for p211 didn't work either (https://github.com/52571abc/gxl-s905L-B-p211/blob/master/gxl_p211_2g). How do I go about making this work now?
SteeMan Posted January 29, 2022 Posted January 29, 2022 Your box only has 1GB. If you googled the part number on you memory chip from the photos (D9PSC) you could have found from specs that these are 2Gb chips and you have four on the board. So 4x 2Gb = 8Gb = 1GB 1
