I attached Micron M500 SSD with gpt table, also Seagate 3GB hard disk with gpt to sata data connection and powered disks with external power adapter(it supplies 5V and 12V and comes with usb-sata adapter).
U-Boot shows message:
SCSI:  AHCI PHY power up failed.
dmesg:
SATA AHCI Phy Power Failed!
SATA AHCI Phy Calibration Failed!
sw_ahci sw_ahci.0: controller can't to PMP, turning off CAP_PMP
sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
scsi0 : sw_ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
ata1: SATA link down (SStatus 0 SControl 300)
The raw "Legacy Jessie Server" image was download today.  Under U-Boot neither of scsi scan and other commands showed that it recognize disk.  If disks were connected through usb-sata adapter, linux recognizes disks.  The same U-Boot message is displayed if using opensuse image.  Funtoo does not find SSD either.
lime2 is "C" revision.  2 sata cables were tried, and these cables were working earlier ok.
Is this U-Boot message is vital, and linux relies on U-Boot while discovering SATA?  Is it necessary to use lime2 power source in order for linux to discover sata disk?  If yes, how to power sata hard disk?
Gintaras
