Capeschae Posted February 5, 2022 Posted February 5, 2022 When using the dts editor in armbian-config, a different dts is shown than the one that I defined in extlinux.conf. For my RK3188 based minix neo X7, I decompiled an existing dtb from boot/dtb into a dts file using dtc on my Linux computer. I edited this into a new dts and compiled it into a dtb. I placed this under the name rk3188-x7.dtb in my boot/dtb folder, referenced to it in extlinux.conf and my system booted using this dtb (checked in dmesg). However, when I try to use armbian-config to edit my dtb/dts, it shows a different dts. Any idea how or where to change this so I can easily work on my dts?
Solution Capeschae Posted February 6, 2022 Author Solution Posted February 6, 2022 12 hours ago, TRS-80 said: Did you try studying armbian-config source? Thanks for pointing me in the right direction! It seems that the dts editor in armbian-config uses the "first" dtb it finds in the /root/dtb folder. Because there were multiple dtb files in my dtb folder a different one was picked than the one I have configured in my extlinux.conf file. Removing all but one dtb files from the /root/dtb folder did the trick.
