ArmBian Kernel for OdroidXU4 is failing to compile with -C KERNEL_SOURCES O=SOMEWHERE_ELSE option
I'm trying to compile the Odroid-XU4 kernel using a make -C KERNEL_SOURCES O=SOMEWHERE_ELSE/mybuild.
This command will failed when it reaches these drivers in drivers/net/wireless: rtl8188eu, rtl8189es, rtl8189fs, rtl8192eu, rtl8723ds, rtl8723du, rtl8811cu, rtl8812au, rtl8822bs, rtl88x2bu, rtl88x2cs.
To be able to compile the Kernel outside of the source tree I had to modify this list of files below. This is an output of my scipt wich is searching an replacing and replacing "-I$(src)" with "-I$(souce)/$(src)"
Fixing compilation for driver rtl8188eu ..
  Makefile
  phydm.mk
  sd4_phydm_2_kernel.mk
  ap_makefile.mk
Fixing compilation for driver rtl8189es ..
  Makefile
Fixing compilation for driver rtl8189fs ..
  Makefile
Fixing compilation for driver rtl8192eu ..
  Makefile
  phydm.mk
  ap_makefile.mk
Fixing compilation for driver rtl8723ds ..
  Makefile
Fixing compilation for driver rtl8723du ..
  Makefile
  phydm.mk
  ap_makefile.mk
Fixing compilation for driver rtl8811cu ..
  Makefile
  phydm.mk
  ap_makefile.mk
  rtl8821c.mk
Fixing compilation for driver rtl8812au ..
  Makefile
  phydm.mk
  ap_makefile.mk
Fixing compilation for driver rtl8822bs ..
  Makefile
  phydm.mk
  rtl8822b.mk
Fixing compilation for driver rtl88x2bu ..
  Makefile
  phydm.mk
  ap_makefile.mk
  halmac.mk
  rtl8822b.mk
Fixing compilation for driver rtl88x2cs ..
  Makefile
  phydm.mk
  ap_makefile.mk
  halmac.mk
  rtl8822c.mk
The script I used to fix this issue is this:
    for i in rtl8188eu rtl8189es rtl8189fs rtl8192eu rtl8723ds rtl8723du rtl8811cu rtl8812au rtl8822bs rtl88x2bu rtl88x2cs; do
        if [[ -d "${SOURCE_DIR}/drivers/net/wireless/$i" ]]; then
            echo "Fixing compilation for driver $i .."
            if [[ -f "${SOURCE_DIR}/drivers/net/wireless/$i/Makefile" ]]; then
                echo "  Makefile"
                sed -i -e "s/-I\$(src)/-I \$(srctree)\/\$(src)/g" "${SOURCE_DIR}/drivers/net/wireless/$i/Makefile"
            fi
            ### Also there are multiple .mk files with the same issue.
            for j in `find "${SOURCE_DIR}/drivers/net/wireless/$i/" -name *.mk -type f`; do
                echo "  $(basename $j)"
                sed -i "s/-I\$(src)/-I \$(srctree)\/\$(src)/g" "${j}"
            done
        fi
    done
There ${SOURCE_DIR} is obviously the Kernel sources from ArmBian.
Hope you can fix this issue in the next release of the kernel.
I am grateful you have found a fix but sadly maintainers are unable to integrate most of the fixes that are found :(
We are trying to improve the situation this way:
Applicants: 0
We are freezing code for next release today:
https://forum.armbian.com/topic/19188-armbian-2202-pig-release-thread/#comment-135629
https://docs.armbian.com/Process_Release-Model/
Probably it should be added here:
https://github.com/armbian/build/blob/master/lib/compilation-prepare.sh
then https://github.com/armbian/build/pulls
