blood Posted September 10, 2016 Posted September 10, 2016 I'm running into a problem using the second interface with my Clearfog Base. I don't have an SFP to test the third interface, but the first works fine, though the second does not. I've tried images with 3.x and 4.x kernels from both SolidRun and Armbian and they all have the same behavior. My first concern is whether this has worked for anyone else so that I can rule out faulty hardware. Can anyone chime in with whether they've successfully used the 2nd copper interface on a Clearfog Base? If so, did it work out of the box, or did it require any extra steps? Next, can someone more familiar with ARM SOCs and device trees comment as to whether the same device tree for the Pro should work for the Base? In case it helps, here is some output I cherry-picked from the boot sequence that seems related to the NICs: Board configuration detected: Net: | port | Interface | PHY address | |--------|-----------|--------------| | egiga0 | RGMII | 0x00 | | egiga1 | SGMII | In-Band | | egiga2 | SGMII | In-Band | egiga0 [PRIME], egiga1, egiga2 | Lane # | Speed| Type | ------------------------------| | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 5 | PCIe1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | PCIe2 | | 5 | 0 | SGMII2 | ------------------------------- PCIe, Idx 1: detected no link PCIe, Idx 2: detected no link High speed PHY - Ended Successfully DDR3 Training Sequence - Ver TIP-1.39.0 DDR3 Training Sequence - Switching XBAR Window to FastPath Window DDR3 Training Sequence - Ended Successfully BootROM: Image checksum verification PASSED SoC: model = 0x6828, revision = 0x4 mvPncVirtBase = 0xf0400000, pncTcamSize = 1024 o 3 Giga ports supported o SKB recycle supported for SWF (Disabled) o NETA acceleration mode 4 o BM supported for CPU: 4 BM pools o PnC supported (Enabled) o RX Queue support: 8 Queues * 256 Descriptors o TX Queue support: 8 Queues * 532 Descriptors o GSO supported o GRO supported o Receive checksum offload supported o Transmit checksum offload supported o Driver ERROR statistics enabled o Driver INFO statistics enabled o Driver DEBUG statistics enabled port #0: is_sgmii=0, is_rgmii=1, phy_addr=0 o Loading network interface(s) for port #0: cpu_mask=0x3, tx_csum_limit=9800 o Port 0 is connected to Linux netdevice o eth0, ifindex = 3, GbE port = 0 giga p=0: mtu=1500, mac=00:50:43:02:02:01 (platform) port #1: is_sgmii=1, is_rgmii=0, phy_addr=-1 o Loading network interface(s) for port #1: cpu_mask=0x3, tx_csum_limit=2048 o Port 1 is connected to Linux netdevice o eth1, ifindex = 4, GbE port = 1 giga p=1: mtu=1500, mac=00:50:43:02:02:02 (platform) port #2: is_sgmii=1, is_rgmii=0, phy_addr=-1 o Loading network interface(s) for port #2: cpu_mask=0x3, tx_csum_limit=2048 o Port 2 is connected to Linux netdevice o eth2, ifindex = 5, GbE port = 2 giga p=2: mtu=1500, mac=00:50:43:02:02:03 (platform) libphy: orion_mdio_bus: probed
blood Posted September 11, 2016 Author Posted September 11, 2016 I think I found a workaround for this. Is there a way to make the existing Clearfog images handle both boards? Should there be distinct images for the Base and Pro versions of the Clearfog boards?
