Not sure if this is the place for this since it isn't really a software issue, but...
So I decided to take apart my Helios64 to apply the 2.5Gb/1Gb Ethernet fix and things went badly.
I ended up accidentally destroying the 402 caps on one of the SATA ports by scrapping the board against the standoffs as I was pulling it out of the case.
As far as I can tell, they should be part of the SATA standard, 10nF DC blocking caps, so I have a rough idea of what they might have been but I don't know for sure since they are simply gone.
Does anyone happen to know what those caps were or have access to a circuit diagram or BOM I could reference? It would be nice to replace them with the original part number.
I did find the information for the Helios4, but I don't know if those are the same and that exact part seems impossible to get anyway.
You can post now and register later.
If you have an account, sign in now to post with your account.
Question
Zykr
Thanks for reading.
Link to comment
Share on other sites
1 answer to this question
