Hi all. I'm new at this.
Please, tell me, how can I download the image Armbian for Orange Pi One along with the source codes?
It need me in order to change them a little for myself and compile them myself.
What I download from the link contains only packages and patches.
https://github.com/armbian/build
But I need the *.cpp and *.h files...
Armbian does not provide the full source code by itself. It relies on external sources like mainline Linux or WiFi drivers.
When starting the compiling process these sources will be downloaded, for example from git.kernel.org or a mirror, patched and then compiled.
You can use the CREATE_PATCHES build option to  automatically create patches from your changes to the source code which then you can apply on the next build run.
https://docs.armbian.com/Developer-Guide_Build-Options/
https://zuckerbude.org/armbian-using-create-patches/
Many thanks!
I just need to add support for the RS-485 protocol
so that when transmitting data (for example, via uart2), one of the gpio pins rises to a high level.
then, at the end of the transmission, it again return to a low level.
That's why I need to patch the kernel.
but I think it's already been done. maybe, tell me where it can be searched?
