Solution therwastl07 Posted March 21, 2022 Solution Posted March 21, 2022 Hello! I have problems to install OMV on an Odroid. Bullseye is installed and then I start the install script from github. The install script of OMV does not work - some mirrors are not https but only http. Anyone has an idea? The odroid is connected to an aDSL router. I raised this issue at github and got the response to ask here. See https://github.com/OpenMediaVault-Plugin-Developers/installScript/issues/88 Thanks for any help! Updating repos before installing... OK:1 http://packages.openmediavault.org/public shaitan InRelease OK:2 http://deb.debian.org/debian bullseye InRelease Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB] Holen:4 http://security.debian.org bullseye-security InRelease [44,1 kB] Holen:5 http://deb.debian.org/debian bullseye-backports InRelease [44,2 kB] Ign:6 https://apt.armbian.com bullseye InRelease Fehl:7 https://apt.armbian.com bullseye Release Redirection from https to 'http://es.armbian.mirrors.bret.dk/apt/dists/bullsey e/Release' is forbidden [IP: 173.45.128.12 443] Holen:8 http://deb.debian.org/debian bullseye-backports/main armhf Packages.diff /Index [63,3 kB] Holen:9 http://deb.debian.org/debian bullseye-backports/main armhf Contents (deb ).diff/Index [63,7 kB] Holen:10 http://deb.debian.org/debian bullseye-backports/main armhf Packages T-2 022-03-21-0202.54-F-2022-03-21-0202.54.pdiff [929 B] Holen:10 http://deb.debian.org/debian bullseye-backports/main armhf Packages T-2 022-03-21-0202.54-F-2022-03-21-0202.54.pdiff [929 B] Holen:11 http://deb.debian.org/debian bullseye-backports/main armhf Contents (de b) T-2022-03-21-0202.54-F-2022-03-21-0202.54.pdiff [95 B] Holen:11 http://deb.debian.org/debian bullseye-backports/main armhf Contents (de b) T-2022-03-21-0202.54-F-2022-03-21-0202.54.pdiff [95 B] Paketlisten werden gelesen… Fertig E: Das Depot »https://apt.armbian.com bullseye Release« enthält keine Release-Da tei. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur chgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur ation finden Sie in der Handbuchseite apt-secure(8). Installing lsb_release... Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benöti gt: tmux zsh zsh-common Verwenden Sie »apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 ni cht aktualisiert. Es müssen noch 0 B von 27,9 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt. (Lese Datenbank ... 37010 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../lsb-release_11.1.0_all.deb ... Entpacken von lsb-release (11.1.0) über (11.1.0) ... lsb-release (11.1.0) wird eingerichtet ... Trigger für man-db (2.9.4-2) werden verarbeitet ... Supported architecture Debian :: bullseye shaitan :: 6 dpkg: Warnung: Die Anforderung, udisks2 zu entfernen, wird ignoriert; es ist nic ht installiert Install prerequisites... Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig dirmngr ist schon die neueste Version (2.2.27-2). gnupg ist schon die neueste Version (2.2.27-2). Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benöti gt: tmux zsh zsh-common Verwenden Sie »apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Installing openmediavault required packages... Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig postfix ist schon die neueste Version (3.5.6-1+b1). Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benöti gt: tmux zsh zsh-common Verwenden Sie »apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Adding openmediavault repo and key... --2022-03-21 17:06:24-- http://packages.openmediavault.org/public/archive.key Auflösen des Hostnamens packages.openmediavault.org (packages.openmediavault.org )… 178.254.11.33 Verbindungsaufbau zu packages.openmediavault.org (packages.openmediavault.org)|1 78.254.11.33|:80 … verbunden. HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK Länge: 3134 (3,1K) [application/pgp-keys] Wird in »/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc« gespeichert. /etc/apt/trusted.gp 100%[===================>] 3,06K --.-KB/s in 0s 2022-03-21 17:06:24 (48,4 MB/s) - »/etc/apt/trusted.gpg.d/openmediavault-archive -keyring.asc« gespeichert [3134/3134] Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (s ee apt-key(8)). OK Updating repos... OK:1 http://deb.debian.org/debian bullseye InRelease OK:2 http://deb.debian.org/debian bullseye-updates InRelease OK:3 http://deb.debian.org/debian bullseye-backports InRelease OK:4 http://security.debian.org bullseye-security InRelease OK:5 http://packages.openmediavault.org/public shaitan InRelease Ign:6 https://apt.armbian.com bullseye InRelease Fehl:7 https://apt.armbian.com bullseye Release Redirection from https to 'http://armbian.systemonachip.net/apt/dists/bullseye /Release' is forbidden [IP: 173.45.128.12 443] Paketlisten werden gelesen… Fertig E: Das Depot »https://apt.armbian.com bullseye Release« enthält keine Release-Da tei. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur chgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur ation finden Sie in der Handbuchseite apt-secure(8). failed to update apt repos.
therwastl07 Posted March 23, 2022 Author Posted March 23, 2022 I got it armbian-config - choose other APT-mirrors - and it works..
