y52 Posted March 31, 2022 Share Posted March 31, 2022 armbian-ramlog & armbian-truncate-log are not executed due to an error parsing the XTRA_RSYNC_TO=(--delete) from /etc/default/armbian-ramlog This results in quick saturation of /var/log. I've made some advancement in debugging "armbian-ramlog & armbian-truncate-log" complex, based on the master tree here: https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-ramlog Your /usr/lib/armbian/armbian-ramlog has a syntax error in the array expression ${XTRA_RSYNC_TO[@]+"${XTRA_RSYNC_TO[@]}"} The 1st array lacks a closing } curly braces. Secondly, I can't figure out, why the same array is duplicated. Even if you parse a variable XTRA_RSYNC_TO=(--delete) from /etc/default/armbian-ramlog, it will result in : --delete+--delete Another problem comes, when you call /usr/lib/armbian/armbian-ramlog write >/dev/null 2>&1 from /usr/lib/armbian/armbian-truncate-logs. It actually produces the error: # /usr/lib/armbian/armbian-truncate-logs /usr/lib/armbian/armbian-truncate-logs: 23: /etc/default/armbian-ramlog: Syntax error: "(" unexpected I believe there is a syntax error in the way the call is made, where the XTRA_RSYNC_TO=(--delete) variable is not accounted for. Otherwise, if the XTRA_RSYNC_TO=(--delete) variable is remarked in /etc/default/armbian-ramlog and "--delete" option is hard coded in /usr/lib/armbian/armbian-ramlog, the complex starts running without raising exceptions. 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted April 1, 2022 Share Posted April 1, 2022 is this post meant to be in this thread? 0 Quote Link to comment Share on other sites More sharing options...
