2play Posted April 1, 2022 Posted April 1, 2022 In Alsamixer its missing the master volume. In older legacy images it was there and driver seemed to be a tinker rockchip driver? Any idea how to enable the master volume slider? If I increase volume in USB sound card (headphones) then no sound comes out at HDMI and only way to restore is to purge deb of pulseaudio and alsa and re-install. There are some errors also the moment i log into cli if I do above. If reproduced ill post here (update). Similar error posted on another topic/board If i test `aplay /usr/share/sounds/alsa/Front_Center.wav` its ok. After any change to alsamixer nothing comes out The errors that started after changing alsamixer volume as per above are: Quote From: dmesg | grep hdmi [ 25.942319] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported! [ 25.957097] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 25.983838] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported! [ 25.997931] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 26.025064] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported! [ 26.045361] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 26.072715] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported! [ 26.086661] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
2play Posted April 17, 2022 Author Posted April 17, 2022 And similar error on RockPro64, Armbian lsb_release -sd: Ubuntu 20.04.4 LTS Quote $ dmesg | grep hdmi [ 0.432728] platform ff940000.hdmi: Fixing up cyclic dependency with ff8f0000.vop [ 0.433031] platform ff940000.hdmi: Fixing up cyclic dependency with ff900000.vop [ 3.620071] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.623691] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops) [ 55.392265] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 55.393344] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 55.395450] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 55.396332] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 55.399744] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 55.400655] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 55.403022] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 55.404092] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
