I found this box running Armbian at much cooler temperature than H603. Running around 40+-70c depending on ambient temperature and cpu load. The cpu never throttle.
TV Box Name X96 mini
CPU amlogic S905X
Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img
DTB file used: meson-gxl-s905x-p212.dtb
Kernel Version: 5.9.0
Distribution Installed (focal, buster, etc): focal
Working Ethernet (Yes/No): yes
Max Ethernet Speed that works (100/1000): 100
Does wifi work (Yes/No): No after boot. But managed to compile from source (RTL8189ES) and now it is working (see attaching working 8189es.ko)
Does bluetooth work (Yes/No): no
Does HDMI audio work (Yes/No): didn't test
Additional Comments (provide any additional information you feel is important):
to make the wifi works, using the attached .ko file:
# Enable the driver
sudo cp 8189es.ko /usr/lib/modules/5.9.0-arm-64/kernel/drivers/net/wireless/realtek/
sudo depmod -a
sudo modprobe 8189es
In case you want to compile by yourself:
# Install kernel headers
wget https://users.armbian.com/balbes150/arm-64/deb/linux-headers-current-arm-64_20.10_arm64.deb
or download from https://disk.yandex.ru/d/_rQgn_FosYuW0g/20.10/deb
sudo dpkg -i linux-headers-current-arm-64_20.10_arm64.deb
# Download the wifi driver
git clone https://github.com/jwrdegoede/rtl8189ES_linux.git
# Compile,
cd rtl8189ES_linux/
make -j4 ARCH=arm64 KSRC=/usr/lib/modules/5.9.0-arm-64/build
# Enable the driver
sudo depmod -a
8189es.ko
  • bthoven changed the title to X96 mini S905x, builtin wifi chipset RTL8189ES working with recompilation
Note that the X96 Mini box name is very generic.  There are many different manufacturers that make boxes with that name and each manufacturer may use different components (i.e. wifi chips) in their specific boards.  So don't assume that the above will work for you unless you verify that you have the same wifi chip on your board.
